    T113 切换存储,nand flash切换到SD卡启动,挂载文件系统报错
      shz18877605430 LV 6 最后由 编辑
      nand flash切换到SD卡启动,挂载分区的时候报错,文件系统均改为ext4le ,内核已开启ext4文件系统,以及make menuconfig下的e2fprogs,但是还是不行,配置如下:
      env
      #kernel command arguments
      earlyprintk=sunxi-uart,0x02500C00
      initcall_debug=0
      console=ttyS3,115200
      nand_root=/dev/ubiblock0_5
      mmc_root=/dev/mmcblk0p5
      mtd_name=sys
      rootfstype=squashfs
      root_partition=rootfs
      boot_partition=boot
      init=/sbin/init
      loglevel=8
      cma=8M
      mac=
      wifi_mac=
      bt_mac=
      specialstr=
      keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
      dsp0_partition=dsp0
      rootdelay=2
      #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
      setargs_nand=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      #nand command syntax: sunxi_flash read address partition_name read_bytes
      #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
      #boot_dsp0=sunxi_flash read 45000000 ${dsp0_partition};bootr 45000000 0 0
      #boot_normal=sunxi_flash read 45000000 ${boot_partition};bootm 45000000
      boot_dsp0=sunxi_flash read 40000000 ${dsp0_partition};bootr 40000000 0 0
      boot_normal=sunxi_flash read 41000000 ${boot_partition};bootm 41000000
      boot_recovery=sunxi_flash read 43000000 recovery;bootm 43000000
      boot_fastboot=fastboot
      #uboot system env config
      bootdelay=1
      #default nand boot
      bootcmd=run setargs_mmc boot_normal
      sys_config
      ;storage_type   = boot medium, 0-nand, 1-sd, 2-emmc, 3-nor, 4-emmc3, 5-spinand -1(defualt)auto scan
      [target]
      boot_clock   	= 1008
      storage_type    = 1
      nand_use_ubi	= 0
      board.dts
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi_slave_mode = <0>;
      	spi0_cs_number = <1>;
          spi0_cs_bitmap = <1>;
      	status = "disabled";
      	spi-nand@0 {
      		compatible = "spi-nand";
      		spi-max-frequency=<100000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x04>;
      		spi-tx-bus-width=<0x04>;
      		status="disabled";
      	spi-nor@0 {
      		compatible = "jedec,spi-nor";
      		spi-max-frequency=<30000000>;
      		reg = <0x0>;
      		spi-rx-bus-width=<0x01>;
      		spi-tx-bus-width=<0x01>;
      		status="disabled";
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	/*broken-cd;*/
      	/*cd-inverted;*/
      	/*data3-detect;*/
      	cd-used-24M;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr50;*/
      	/*sd-uhs-ddr50;*/
      	/*sd-uhs-sdr104;*/
      	no-sdio;
      	//no-mmc;
      	sunxi-power-save-mode;
      	/*sunxi-dis-signal-vol-sw;*/
      	max-frequency = <150000000>;
      	ctl-spec-caps = <0x8>;
      syslog如下:
        lztmfx LV 5 最后由 编辑
        @shz18877605430 在 T113 切换存储,nand flash切换到SD卡启动,挂载文件系统报错 中说:
        rootfstype=squashfs
        rootfstype=ext4
