    由于没有公钥,无法验证下列签名
      liuruyi LV 3 最后由 liuruyi 编辑
      回复: 一键生成可定制的Debian rootfs,支持riscv64
      按照这个帖子操作的时候,提示无法验证签名,按照网上的说法用apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv
      操作之后还是同样的情况,这个应该怎么处理呢?
      oot@ubuntu18:/opt/riscv/debian-rootfs# ./make-rootfs.sh riscv64 multistrap_debian-ports.conf
      multistrap 2.2.9 using multistrap_debian-ports.conf
      Using foreign architecture: riscv64
      multistrap building riscv64 multistrap on 'amd64'
      I: Setting /opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/lib64 -> /opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/lib symbolic link.
      Getting package lists: APT_CONFIG=/tmp/multistrap.UQSxxX apt-get  -o Apt::Architecture=riscv64 -o Dir::Etc::TrustedParts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/etc/apt/trusted.gpg.d -o Dir::Etc::Trusted=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/etc/apt/trusted.gpg -o Apt::Get::AllowUnauthenticated=true -o Apt::Get::Download-Only=true -o Apt::Install-Recommends=false -o Dir=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/ -o Dir::Etc=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/etc/apt/ -o Dir::Etc::Parts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/etc/apt/apt.conf.d/ -o Dir::Etc::PreferencesParts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/etc/apt/preferences.d/ -o APT::Default-Release='*' -o Dir::State=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/var/lib/apt/ -o Dir::State::Status=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/var/lib/dpkg/status -o Dir::Cache=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155920Z/var/cache/apt/ update
      获取:1 http://ftp.ports.debian.org/debian-ports unstable InRelease [87.2 kB]
      错误:1 http://ftp.ports.debian.org/debian-ports unstable InRelease
        由于没有公钥,无法验证下列签名: NO_PUBKEY B523E5F3FC4E5F2C NO_PUBKEY 8D69674688B6CB36
      正在读取软件包列表... 完成
      W: GPG 错误:http://ftp.ports.debian.org/debian-ports unstable InRelease: 由于没有公钥,无法验证下列签名: NO_PUBKEY B523E5F3FC4E5F2C NO_PUBKEY 8D69674688B6CB36
      E: 仓库 “http://ftp.debian-ports.org/debian unstable InRelease” 没有数字签名。
      N: 无法安全地用该源进行更新,所以默认禁用该源。
      N: 参见 apt-secure(8) 手册以了解仓库创建和用户配置方面的细节。
      apt update failed. Exit value: 100
      mutltistrap with configuration file multistrap_debian-ports.conf failed
      root@ubuntu18:/opt/riscv/debian-rootfs# apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv B523E5F3FC4E5F2C
      Executing: /tmp/apt-key-gpghome.eCHx9ZKFsz/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv B523E5F3FC4E5F2C
      gpg: key B523E5F3FC4E5F2C: 1 signature not checked due to a missing key
      gpg: 密钥 B523E5F3FC4E5F2C:公钥“Debian Ports Archive Automatic Signing Key (2023) <ftpmaster@ports-master.debian.org>”已导入
      gpg: 合计被处理的数量:1
      gpg:               已导入:1
      root@ubuntu18:/opt/riscv/debian-rootfs# apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 8D69674688B6CB36
      Executing: /tmp/apt-key-gpghome.Zdiw1SO6tD/gpg.1.sh --keyserver hkp://keyserver.ubuntu.com:80 --recv 8D69674688B6CB36
      gpg: 密钥 8D69674688B6CB36:公钥“Debian Ports Archive Automatic Signing Key (2024) <ftpmaster@ports-master.debian.org>”已导入
      gpg: 合计被处理的数量:1
      gpg:               已导入:1
      root@ubuntu18:/opt/riscv/debian-rootfs# ./make-rootfs.sh riscv64 multistrap_debian-ports.conf
      I: Setting /opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/lib64 -> /opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/lib symbolic link.
      Getting package lists: APT_CONFIG=/tmp/multistrap.IsVTPs apt-get  -o Apt::Architecture=riscv64 -o Dir::Etc::TrustedParts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/etc/apt/trusted.gpg.d -o Dir::Etc::Trusted=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/etc/apt/trusted.gpg -o Apt::Get::AllowUnauthenticated=true -o Apt::Get::Download-Only=true -o Apt::Install-Recommends=false -o Dir=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/ -o Dir::Etc=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/etc/apt/ -o Dir::Etc::Parts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/etc/apt/apt.conf.d/ -o Dir::Etc::PreferencesParts=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/etc/apt/preferences.d/ -o APT::Default-Release='*' -o Dir::State=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/var/lib/apt/ -o Dir::State::Status=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/var/lib/dpkg/status -o Dir::Cache=/opt/riscv/debian-rootfs/build/riscv64/riscv64-rootfs-20231128T155947Z/var/cache/apt/ update
      正在读取软件包列表... 完成
        liuruyi LV 3 最后由 编辑
        @whycan 请问这个是应该怎么处理呢?
          whycan晕哥 LV 9 @liuruyi 最后由 编辑
          @liuruyi
          https://whycan.com/t_7367.html
