    正常运行一天了,然后出现无法启动,再次打开就显示这个错误toc1 magic error
      missdangerous LV 4 最后由 编辑
      [29]HELLO! BOOT0 is starting!
      [32]BOOT0 commit : 88480af
      [35]set pll start
      [37]fix vccio detect value:0xc0
      [40]periph0 has been enabled
      [43]set pll end
      [44][pmu]: bus read error
      [46]board init ok
      [48]ZQ value = 0x2e
      [50]get_pmu_exist() = -1
      [52]DRAM BOOT DRIVE INFO: V0.33
      [55]DRAM CLK = 528 MHz
      [57]DRAM Type = 2 (2:DDR2,3:DDR3)
      [61]DRAMC read ODT  off.
      [63]DRAM ODT off.
      [65]ddr_efuse_type: 0xa
      [67]DRAM SIZE =64 M
      [69]dram_tpr4:0x0
      [71]PLL_DDR_CTRL_REG:0xf8002b00
      [74]DRAM_CLK_REG:0xc0000000
      [76][TIMING DEBUG] MR2= 0x0
      [81]DRAM simple test OK.
      [83]dram size =64
      [85]spinor id is: ef 40 19, read cmd: 6b
      [88]Succeed in reading toc file head.
      [92]toc1 magic error
      Y 1 条回复 最后回复 回复 引用 分享 0
        yubeer LV 5 @missdangerous 最后由 编辑
        @missdangerous 怎么处理的,我也遇到同样问题了
