    f1c100s USB问题请教
    5525
      smbzd LV 4 最后由 编辑
      f1c100s上跑主线linux5.7。使用在使用USB的过程中发现有以下问题:从U盘读取文件放到SD卡,计算MD5,源文件与复制文件校验码一致。但从SD卡读文件放到U盘上,就有10%的概率文件会出错。是USB驱动有问题么?下面是我的设备树文件:
      // SPDX-License-Identifier: (GPL-2.0+ OR X11)
       * Copyright 2018 Icenowy Zheng <icenowy@aosc.io>
       * Copyright 2018 Mesih Kilinc <mesihkilinc@gmail.com>
      #include <dt-bindings/clock/suniv-ccu-f1c100s.h>
      #include <dt-bindings/reset/suniv-ccu-f1c100s.h>
      #include <dt-bindings/interrupt-controller/irq.h>
      	#address-cells = <1>;
      	#size-cells = <1>;
      	interrupt-parent = <&intc>;
      	clocks {
      		#size-cells = <1>;
      		ranges;
      		osc24M: clk-24M {
      			#clock-cells = <0>;
      			compatible = "fixed-clock";
      			clock-frequency = <24000000>;
      			clock-output-names = "osc24M";
      		osc32k: clk-32k {
      			#clock-cells = <0>;
      			clock-frequency = <32768>;
      			clock-output-names = "osc32k";
      		fake100M: clk-100M {
      			#clock-cells = <0>;
      			clock-output-names = "fake-100M";
      	cpus {
      		cpu {
      			compatible = "arm,arm926ej-s";
      			device_type = "cpu";
      	soc {
      		compatible = "simple-bus";
      		#size-cells = <1>;
      		ranges;
      		sram-controller@1c00000 {
      			compatible = "allwinner,suniv-f1c100s-system-control",
      				     "allwinner,sun4i-a10-system-control";
      			reg = <0x01c00000 0x30>;
      			#size-cells = <1>;
      			ranges;
      			sram_d: sram@10000 {
      				compatible = "mmio-sram";
      				reg = <0x00010000 0x1000>;
      				#size-cells = <1>;
      				ranges = <0 0x00010000 0x1000>;
      				otg_sram: sram-section@0 {
      					compatible = "allwinner,suniv-f1c100s-sram-d",
      						     "allwinner,sun4i-a10-sram-d";
      					reg = <0x0000 0x1000>;
      					status = "disabled";
      		ccu: clock@1c20000 {
      			compatible = "allwinner,suniv-f1c100s-ccu";
      			reg = <0x01c20000 0x400>;
      			clocks = <&osc24M>, <&osc32k>;
      			clock-names = "hosc", "losc";
      			#clock-cells = <1>;
      			#reset-cells = <1>;
      		intc: interrupt-controller@1c20400 {
      			compatible = "allwinner,suniv-f1c100s-ic";
      			reg = <0x01c20400 0x400>;
      			interrupt-controller;
      			#interrupt-cells = <1>;
      		pio: pinctrl@1c20800 {
      			compatible = "allwinner,suniv-f1c100s-pinctrl";
      			reg = <0x01c20800 0x400>;
      			interrupts = <38>, <39>, <40>;
      			clocks = <&ccu 37>, <&osc24M>, <&osc32k>;
      			clock-names = "apb", "hosc", "losc";
      			gpio-controller;
      			#interrupt-cells = <3>;
      			#gpio-cells = <3>;
      			uart0_pe_pins: uart0-pe-pins {
      				pins = "PE0", "PE1";
      				function = "uart0";
      			mmc0_pins: mmc0-pins {
                      		pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
                      		function = "mmc0";
      		timer@1c20c00 {
      			compatible = "allwinner,suniv-f1c100s-timer";
      			reg = <0x01c20c00 0x90>;
      			interrupts = <13>;
      			clocks = <&osc24M>;
      		wdt: watchdog@1c20ca0 {
      			compatible = "allwinner,suniv-f1c100s-wdt",
      				     "allwinner,sun4i-a10-wdt";
      			reg = <0x01c20ca0 0x20>;
      		uart0: serial@1c25000 {
      			compatible = "snps,dw-apb-uart";
      			reg = <0x01c25000 0x400>;
      			interrupts = <1>;
      			reg-shift = <2>;
      			reg-io-width = <4>;
      			clocks = <&ccu 38>;
      			resets = <&ccu 24>;
      		uart1: serial@1c25400 {
      			reg = <0x01c25400 0x400>;
      			interrupts = <2>;
      			reg-shift = <2>;
      			reg-io-width = <4>;
      			clocks = <&ccu 39>;
      			resets = <&ccu 25>;
      		uart2: serial@1c25800 {
      			reg = <0x01c25800 0x400>;
      			interrupts = <3>;
      			reg-shift = <2>;
      			reg-io-width = <4>;
      			clocks = <&ccu 40>;
      			resets = <&ccu 26>;
      		mmc0: mmc@1c0f000 {
                  		compatible = "allwinner,suniv-f1c100s-mmc",
                  		         "allwinner,sun7i-a20-mmc";
                  		reg = <0x01c0f000 0x1000>;
                  		clocks = <&ccu CLK_BUS_MMC0>,
                       		<&ccu CLK_MMC0>,
                       		<&ccu CLK_MMC0_OUTPUT>,
                       		<&ccu CLK_MMC0_SAMPLE>;
                  		clock-names = "ahb",
                                		"mmc",
                                		"output",
                                		"sample";
                  		resets = <&ccu RST_BUS_MMC0>;
                  		reset-names = "ahb";
                  		interrupts = <23>;
                  		pinctrl-names = "default";
                  		pinctrl-0 = <&mmc0_pins>;
                  		#size-cells = <0>;
      		usb_otg: usb@1c13000 {
      			// compatible = "allwinner,suniv-musb";
      			compatible = "allwinner,sun4i-a10-musb";
      			reg = <0x01c13000 0x0400>;
      			clocks = <&ccu CLK_BUS_OTG>;
      			resets = <&ccu RST_BUS_OTG>;
      			interrupts = <26>;
      			interrupt-names = "mc";
      			phys = <&usbphy 0>;
      			phy-names = "usb";
      			extcon = <&usbphy 0>;
      			allwinner,sram = <&otg_sram 1>;
      		usbphy: phy@1c13400 {
      			// compatible = "allwinner,suniv-usb-phy";
      			compatible = "allwinner,sun4i-a10-usb-phy";
      			reg = <0x01c13400 0x10>;
      			reg-names = "phy_ctrl";
      			clocks = <&ccu CLK_USB_PHY0>;
      			clock-names = "usb0_phy";
      			resets = <&ccu RST_USB_PHY0>;
      			reset-names = "usb0_reset";
      			#phy-cells = <1>;
        Alb702 LV 5 @smbzd 最后由 编辑
        @smbzd 在 f1c100s USB问题请教 中说:
        linux5.7
        关于DTS,唯一的问题是 :
        您使用什么驱动程序?
        MUSB 设置是什么:DMA 还是 PIO?
        S 2 条回复 最后回复 回复 引用 分享 0
          smbzd LV 4 @Alb702 最后由 编辑
          @alb702 感谢回复。我不太清楚在哪里确定是DMA还是PIO模式,但在menuconfig上我没有勾选Disable DMA,我猜测应该是DMA模式的。
          是需要禁用DMA么?
            @alb702 驱动程序用的是musb-sunxi
              musb-sunxi
              你有DMA。 一切安好。 这可能不是这里的问题。
              Linux 文档说您可以在 SCSI 协议中启用数据完整性检查。
              https://docs.kernel.org/block/data-integrity.html : Block Layer Integrity API
              您可以尝试这个方法来澄清问题。
              S 1 条回复 最后回复 回复 引用 分享 0
                @alb702 好的,非常感谢您的建议。我会尝试一下
