    【已解决】F133最新Tina2.1sdk编译出来的镜像烧到SD卡中启动失败
    f133-b
    • N
      NNTK_ LV 3 最后由 NNTK_ 编辑
      [156]HELLO! BOOT0 is starting!
      [159]BOOT0 commit : 88480af
      [162]set pll start
      [163]fix vccio detect value:0xc0
      [167]periph0 has been enabled
      [170]set pll end
      [171][pmu]: bus read error
      [174]board init ok
      [176]ZQ value = 0x2f
      [177]get_pmu_exist() = -1
      [180]ddr_efuse_type: 0xa
      [182]trefi:7.8ms
      [184][AUTO DEBUG] single rank and full DQ!
      [188]ddr_efuse_type: 0xa
      [191]trefi:7.8ms
      [193][AUTO DEBUG] rank 0 row = 13
      [196][AUTO DEBUG] rank 0 bank = 4
      [199][AUTO DEBUG] rank 0 page size = 2 KB
      [203]DRAM BOOT DRIVE INFO: V0.33
      [206]DRAM CLK = 528 MHz
      [208]DRAM Type = 2 (2:DDR2,3:DDR3)
      [211]DRAMC read ODT  off.
      [214]DRAM ODT off.
      [216]ddr_efuse_type: 0xa
      [219]DRAM SIZE =64 M
      [221]dram_tpr4:0x0
      [222]PLL_DDR_CTRL_REG:0xf8002b00
      [225]DRAM_CLK_REG:0xc0000000
      [228][TIMING DEBUG] MR2= 0x0
      [233]DRAM simple test OK.
      [235]dram size =64
      [237]card no is 0
      [238]sdcard 0 line count 4
      [241][mmc]: mmc driver ver 2021-04-2 16:45
      [250][mmc]: Wrong media type 0x0
      [253][mmc]: ***Try SD card 0***
      [262][mmc]: HSSDR52/SDR25 4 bit
      [265][mmc]: 50000000 Hz
      [267][mmc]: 7386 MB
      [269][mmc]: ***SD/MMC 0 init OK!!!***
      [319]Loading boot-pkg Succeed(index=0).
      [323]Entry_name        = opensbi
      [326]Entry_name        = u-boot
      [330]Entry_name        = dtb
      [332]mmc not para
      [334]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
      U-Boot 2018.07-ge987def5-dirty (Nov 29 2023 - 22:12:48 -0800) Allwinner Technology
      [00.420]DRAM:  64 MiB
      [00.422]Relocation Offset is: 01eea000
      [00.426]secure enable bit: 0
      [00.429]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      sunxi flash map init
      SPI ALL:   ready
      [00.439]flash init start
      [00.442]workmode = 0,storage type = 1
      [00.445][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.451][mmc]: get sdc_type fail and use default host:tm1.
      [00.463][mmc]: get card0 default pin fail
      [00.467][mmc]: can't find node "mmc0",will add new node
      [00.471][mmc]: fdt err returned <no error>
      [00.475][mmc]: Using default timing para
      [00.479][mmc]: sunxi mmc pin set failed!
      [00.482]error card no error
      [00.485][mmc]: MMC Device -1 not found
      fail to find one useful mmc card
      initcall sequence 0000000043f91070 failed at call 000000004200df02 (err=-1)
      修改了如下内容依旧不行
      • N
        NNTK_ LV 3 最后由 编辑
        【解决方法】
        少改了一个文件
