    F133-B 使用干净D1S SDK,出现SD卡启动失败及解决办法
    • F
      frostcc LV 3 最后由 编辑
      出错日志:
      [33]HELLO! BOOT0 is starting!
      [36]BOOT0 commit : 88480af
      [38]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [45][pmu]: bus read error
      [47]board init ok
      [49]ZQ value = 0x31
      [51]get_pmu_exist() = -1
      [53]ddr_efuse_type: 0xa
      [55]trefi:7.8ms
      [57][AUTO DEBUG] single rank and full DQ!
      [61]ddr_efuse_type: 0xa
      [63]trefi:7.8ms
      [66][AUTO DEBUG] rank 0 row = 13
      [69][AUTO DEBUG] rank 0 bank = 4
      [72][AUTO DEBUG] rank 0 page size = 2 KB
      [75]DRAM BOOT DRIVE INFO: V0.33
      [78]DRAM CLK = 528 MHz
      [80]DRAM Type = 2 (2:DDR2,3:DDR3)
      [84]DRAMC read ODT  off.
      [86]DRAM ODT off.
      [88]ddr_efuse_type: 0xa
      [90]DRAM SIZE =64 M
      [92]dram_tpr4:0x0
      [94]PLL_DDR_CTRL_REG:0xf8002b00
      [97]DRAM_CLK_REG:0xc0000000
      [99][TIMING DEBUG] MR2= 0x0
      [104]DRAM simple test OK.
      [106]dram size =64
      [108]card no is 0
      [110]sdcard 0 line count 4
      [112][mmc]: mmc driver ver 2021-04-2 16:45
      [121][mmc]: Wrong media type 0x0
      [124][mmc]: ***Try SD card 0***
      [134][mmc]: HSSDR52/SDR25 4 bit
      [137][mmc]: 50000000 Hz
      [139][mmc]: 59607 MB
      [141][mmc]: ***SD/MMC 0 init OK!!!***
      [191]Loading boot-pkg Succeed(index=0).
      [194]Entry_name        = opensbi
      [197]Entry_name        = u-boot
      [201]Entry_name        = dtb
      [204]mmc not para
      [206]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0    : 0x0000000041fc0000-0�
      U-Boot 2018.07-ge987def5 (Nov 07 2022 - 03:11:27 +0000) Allwinner Technology
      [00.274]DRAM:  64 MiB
      [00.276]Relocation Offset is: 01ee9000
      [00.281]secure enable bit: 0
      [00.284]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      sunxi flash map init
      SPI ALL:   ready
      [00.295]flash init start
      [00.297]workmode = 0,storage type = 1
      [00.301][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.306][mmc]: get sdc_type fail and use default host:tm1.
      [00.318][mmc]: get card0 default pin fail
      [00.322][mmc]: can't find node "mmc0",will add new node
      [00.327][mmc]: fdt err returned <no error>
      [00.331][mmc]: Using default timing para
      [00.334][mmc]: sunxi mmc pin set failed!
      [00.338]error card no error
      [00.341][mmc]: MMC Device -1 not found
      fail to find one useful mmc card
      initcall sequence 0000000043f91318 failed at call 000000004200df06 (err=-1)
      板子是开源的D1s nezha,我焊了便宜的F133B芯片。用虚拟机编译的固件发现sd卡无法启动,用了韦东山的D1s补丁发现sd启动正常。于是逐个文件对比,终于找到了问题。
      /tina-d1-h/device/config/chips/d1s/configs/nezha/uboot-board.dts
      在174行 pinctrl-0 = <&sdc0_pins_a>; 默认添加了注释,难怪找不到sd卡引脚,删除注释重新make 即可使用sd卡。一开始没看见,找了好几天问题😂
      1 条回复 最后回复 回复 引用 分享 3
