    A133驱动 st7701s[480x480]问题
    • F
      fy123 LV 2 最后由 awwwwa 编辑
      请问下,我现在用A133 驱动st7701s[480x480],dts配置如下,我配置了2lane ,奇怪的是lane2 lane3都有数据,不知道哪里没配置对,谢谢指点
                     lcd0: lcd0@01c0c000 {
                              lcd_used            = <1>;
                              lcd_driver_name     = "st7701s";
                              lcd_backlight       = <100>;
                              lcd_if              = <4>;
                              lcd_x               = <480>;
                              lcd_y               = <480>;
                              lcd_width           = <72>;
                              lcd_height          = <72>;
                              lcd_dclk_freq       = <16>;
                              lcd_pwm_used        = <1>;
                              lcd_pwm_ch          = <3>;
                              lcd_pwm_freq        = <1000>;
                              lcd_pwm_pol         = <0>;
                              lcd_pwm_max_limit   = <255>;
                              lcd_hbp             = <30>;
                              lcd_ht              = <525>;
                              lcd_hspw            = <25>;
                              lcd_vbp             = <20>;
                              lcd_vt              = <525>;
                              lcd_vspw            = <8>;
                              lcd_frm             = <0>;
                              lcd_gamma_en        = <0>;
                              lcd_bright_curve_en = <0>;
                              lcd_cmap_en         = <0>;
                              deu_mode            = <0>;
                              lcdgamma4iep        = <22>;
                              smart_color         = <90>;
                              lcd_dsi_if          = <0>;
                              lcd_dsi_lane        = <2>;
                              lcd_dsi_format      = <0>;
                              lcd_dsi_te          = <0>;
                              lcd_dsi_eotp        = <0>;
                              lcd_pin_power = "dcdc1";
                              lcd_pin_power1 = "eldo3";
                              lcd_power = "dc1sw";
                              lcd_gpio_0 = <&r_pio PL 11 1 0 3 1>;
                              pinctrl-0 = <&dsi2lane_pins_a>;
                              pinctrl-1 = <&dsi2lane_pins_b>;
      驱动程序如下
      /* drivers/video/sunxi/disp2/disp/lcd/ST7796S.c
       * Copyright (c) 2017 Allwinnertech Co., Ltd.
       * Author: zhengxiaobin <zhengxiaobin@allwinnertech.com>
       * he0801a-068 panel driver
       * it under the terms of the GNU General Public License version 2 as
      [lcd0]
       * lcd_used            = 1
       * lcd_driver_name     = "st7701s"
       * lcd_bl_0_percent    = 0
       * lcd_bl_40_percent   = 23
       * lcd_bl_100_percent  = 100
       * lcd_backlight       = 88
       * lcd_if              = 4
       * lcd_x               = 480
       * lcd_y               = 640
       * lcd_width           = 36
       * lcd_height          = 65
       * lcd_dclk_freq       = 25
       * lcd_pwm_used        = 1
       * lcd_pwm_ch          = 8
       * lcd_pwm_freq        = 50000
       * lcd_pwm_pol         = 1
       * lcd_pwm_max_limit   = 255
       * lcd_hbp             = 70
       * lcd_ht              = 615
       * lcd_hspw            = 8
       * lcd_vbp             = 30
       * lcd_vt              = 690
       * lcd_vspw            = 10
       * lcd_dsi_if          = 0
       * lcd_dsi_lane        = 2
       * lcd_dsi_format      = 0
       * lcd_dsi_te          = 0
       * lcd_dsi_eotp        = 0
       * lcd_frm             = 0
       * lcd_io_phase        = 0x0000
       * lcd_hv_clk_phase    = 0
       * lcd_hv_sync_polarity= 0
       * lcd_gamma_en        = 0
       * lcd_bright_curve_en = 0
       * lcd_cmap_en         = 0
       * lcdgamma4iep        = 22
       * ;lcd_bl_en           = port:PD09<1><0><default><1>
       * lcd_power            = "vcc-lcd"
       * lcd_pin_power        = "vcc18-dsi"
       * lcd_pin_power1    	= "vcc-pd"
       * ;reset
       * lcd_gpio_0          = port:PD09<1><0><default><1>
      #include "st7701s.h"
      static void lcd_power_on(u32 sel);
      static void lcd_power_off(u32 sel);
      static void lcd_bl_open(u32 sel);
      static void lcd_bl_close(u32 sel);
      static void lcd_panel_init(u32 sel);
      static void lcd_panel_exit(u32 sel);
      #define panel_reset(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
      #define DBG_INFO(format, args...) (printk("[ST7701S LCD INFO] LINE:%04d-->%s:"format, __LINE__, __func__, ##args))
      #define DBG_ERR(format, args...) (printk("[ST7701S LCD ERR] LINE:%04d-->%s:"format, __LINE__, __func__, ##args))
      static void lcd_cfg_panel_info(struct panel_extend_para *info)
      	DBG_INFO("\n");
      	u32 i = 0, j = 0;
      	u32 items;
      	u8 lcd_gamma_tbl[][2] = {
      	    {0, 0},     {15, 15},   {30, 30},   {45, 45},   {60, 60},
      	    {75, 75},   {90, 90},   {105, 105}, {120, 120}, {135, 135},
      	    {150, 150}, {165, 165}, {180, 180}, {195, 195}, {210, 210},
      	    {225, 225}, {240, 240}, {255, 255},
      	u32 lcd_cmap_tbl[2][3][4] = {
      		for (j = 0; j < num; j++) {
      			u32 value = 0;
      			value =
      			    lcd_gamma_tbl[i][1] +
      			    ((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) *
      			     j) /
      				num;
      			    (value << 16) + (value << 8) + value;
      	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
      				   (lcd_gamma_tbl[items - 1][1] << 8) +
      				   lcd_gamma_tbl[items - 1][1];
      static s32 lcd_open_flow(u32 sel)
      	DBG_INFO("\n");
      	LCD_OPEN_FUNC(sel, lcd_power_on, 0);
      	LCD_OPEN_FUNC(sel, lcd_panel_init, 10);
      	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 10);
      	LCD_OPEN_FUNC(sel, lcd_bl_open, 0);
      static s32 lcd_close_flow(u32 sel)
      	DBG_INFO("\n");
      	LCD_CLOSE_FUNC(sel, lcd_bl_close, 0);
      	LCD_CLOSE_FUNC(sel, lcd_panel_exit, 10);
      	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
      	LCD_CLOSE_FUNC(sel, lcd_power_off, 0);
      	sunxi_lcd_pin_cfg(sel, 1);
      	sunxi_lcd_power_enable(sel, 0);
      	// sunxi_lcd_power_enable(sel, 1);
      	sunxi_lcd_delay_ms(10);
      	/* reset lcd by gpio */
      	panel_reset(sel, 1);
      	sunxi_lcd_delay_ms(1);
      	panel_reset(sel, 0);
      	sunxi_lcd_pin_cfg(sel, 0);
      	sunxi_lcd_power_disable(sel, 0);
      	sunxi_lcd_pwm_enable(sel);
      	sunxi_lcd_backlight_enable(sel);
      	sunxi_lcd_pwm_disable(sel);
      #define REGFLAG_DELAY         0XFE
      #define REGFLAG_END_OF_TABLE  0xFC   /* END OF REGISTERS MARKER */
      struct LCM_setting_table {
      	u8 cmd;
      	u32 count;
      	u8 para_list[18];
      static struct LCM_setting_table lcm_initialization_setting[] = {
      	{0x11, 1, {0x00} },
      	{REGFLAG_DELAY, 60, {} },
      	{0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x10} },
      	{0xc0, 2, {0x4f, 0x00} },
      	{0xc1, 2, {0x07, 0x02} },
      	{0xc2, 2, {0x31, 0x05} },
      	{0xcc, 1, {0x10} },
      	{0xb0, 16, {0x00, 0x0a, 0x11, 0x0c, 0x10, 0x05, 0x00, 0x08, 0x08, 0x1f,
      		   0x07, 0x13, 0x10, 0xa9, 0x30, 0x18} },
      	{0xb1, 16, {0x00, 0x0b, 0x11, 0x0d, 0x0f, 0x05, 0x02, 0x07, 0x06, 0x20,
      		    0x05, 0x15, 0x13, 0xa9, 0x30, 0x18} },
      	{0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x11} },
      	{0xb0, 1, {0x53} },
      	{0xb1, 1, {0x60} },
      	{0xb2, 1, {0x07} },
      	{0xb3, 1, {0x08} },
      	{0xb5, 1, {0x49} },
      	{0xb7, 1, {0x85} },
      	{0xb8, 1, {0x21} },
      	{0xb9, 1, {0x10} },
      	{0xc1, 1, {0x78} },
      	{0xc2, 1, {0x78} },
      	{REGFLAG_DELAY, 50, {} },
      	{0xd0, 1, {0x88} },
      	{0xe0, 3, {0x00, 0x00, 0x02} },
      	{0xe1, 11, {0x03, 0xa0, 0x00, 0x00, 0x02, 0xa0, 0x00, 0x00, 0x00, 0x33,
      		    0x33} },
      	{0xe2, 12, {0x22, 0x22, 0x33, 0x33, 0x88, 0xa0, 0x00, 0x00, 0x87, 0xa0,
      		    0x00, 0x00} },
      	{0xe3, 4, {0x00, 0x00, 0x22, 0x22} },
      	{0xe4, 2, {0x44, 0x44} },
      	{0xe5, 16, {0x04, 0x84, 0xa0, 0xa0, 0x06, 0x86, 0xa0, 0xa0, 0x08, 0x88,
      		    0xa0, 0xa0, 0x0a, 0x8a, 0xa0, 0xa0} },
      	{0xe6, 4, {0x00, 0x00, 0x22, 0x22} },
      	{0xe7, 2, {0x44, 0x44} },
      	{0xe8, 16, {0x03, 0x83, 0xa0, 0xa0, 0x05, 0x85, 0xa0, 0xa0, 0x07, 0x87,
      		    0xa0, 0xa0, 0x09, 0x89, 0xa0, 0xa0} },
      	{0xeb, 7, {0x00, 0x01, 0xe4, 0xe4, 0x88, 0x00, 0x40} },
      	{0xec, 2, {0x3c, 0x01} },
      	{0xed, 16, {0xab, 0x89, 0x76, 0x54, 0x02, 0xff, 0xff, 0xff, 0xff, 0xff,
      		    0xff, 0x20, 0x45, 0x67, 0x98, 0xba} },
      	{0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x00} },
      	{0x29, 1, {0x00} },
      	{REGFLAG_END_OF_TABLE, 0x00, {} }
      	u32 i = 0;
      	sunxi_lcd_dsi_clk_enable(sel);
      	for (i = 0;; i++) {
      		if (lcm_initialization_setting[i].cmd == REGFLAG_END_OF_TABLE)
      			break;
      		else if (lcm_initialization_setting[i].cmd == REGFLAG_DELAY)
      			sunxi_lcd_delay_ms(lcm_initialization_setting[i].count);
      		else {
      			dsi_dcs_wr(0, lcm_initialization_setting[i].cmd,
      				   lcm_initialization_setting[i].para_list,
      	sunxi_lcd_dsi_dcs_write_0para(sel, 0x28);
      	sunxi_lcd_dsi_dcs_write_0para(sel, 0x10);
      /*sel: 0:lcd0; 1:lcd1*/
      static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      struct __lcd_panel st7701s_panel = {
      	/* panel driver name, must mach the name of
      	 * lcd_drv_name in sys_config.fex
      	.name = "st7701s",
      	.func = {
      		.cfg_panel_info = lcd_cfg_panel_info,
      			.cfg_open_flow = lcd_open_flow,
      			.cfg_close_flow = lcd_close_flow,
      			.lcd_user_defined_func = lcd_user_defined_func,
      现在屏幕背光可以,但是屏幕没被点亮,请问可能是哪里问题?
        awwwwa LV 8 最后由 编辑
        uboot的设备树和kernel的设备树都需要配置
