    LVGL 与 SPI TFT GUI案例报错
    A Series
      zy614 LV 2 最后由 awwwwa 编辑
      打包LVGL 与 SPI TFT GUI案例会出现
      ERROR: update mbr file fail
      ERROR: update mbr failed
      修改内存扇区后可以编译打包但在启动后会出现踩地址的情况
      [330]load_start_sector=4704, load_sectors=1747, loadaddr=0x08200000,first_part_size=0x00000180
      [383]load_start_sector=8404
      [386]load dsp-hpsram to 0xc000000 from 4302976, size 504740
      [391]load_start_sector=8404, load_sectors=986, loadaddr=0x0c000000,first_part_size=0x00000180
      [438]load_start_sector=17404
      [441]config not image header magic
      [444]load config to 0x8000000 from 8910848, size 17408
      [449]load_start_sector=17404, load_sectors=34, loadaddr=0x08000000,first_part_size=0x00000000
      [458]9: not :
      [459]load_parts end
      [461]Jump to second Boot.
      [463]jump to rtos
      [465]rtos run addr 0x8004001
      baiwen 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 最后由 awwwwa 编辑
        https://r128.docs.aw-ol.com/others/faq/#_3
        建议 删除 PMU 相关配置
        [pmu]
        pmu_irq_pin      = port:PA14<14><0><default><default>
        pmu_irq_wakeup   = 2
        pmu_hot_shutdown = 1
        pmu_bat_unused = 0
        pmu_usbad_vol = 4600
        pmu_usbad_cur = 1500
        pmu_usbpc_vol = 4600
        pmu_usbpc_cur = 500
        pmu_chg_ic_temp = 0
        pmu_battery_rdc = 100
        pmu_battery_cap = 3568
        pmu_runtime_chgcur = 900
        pmu_suspend_chgcur = 1200
        pmu_shutdown_chgcur = 1200
        pmu_init_chgvol = 4200
        pmu_init_chg_pretime = 50
        pmu_init_chg_csttime = 1200
        pmu_chgled_type = 0
        pmu_init_bc_en = 1
        pmu_bat_temp_enable = 0
        pmu_bat_charge_ltf = 2261
        pmu_bat_charge_htf = 388
        pmu_bat_shutdown_ltf = 3200
        pmu_bat_shutdown_htf = 237
        pmu_bat_para[0] = 0
        pmu_bat_para[1] = 0
        pmu_bat_para[2] = 0
        pmu_bat_para[3] = 0
        pmu_bat_para[4] = 0
        pmu_bat_para[5] = 0
        pmu_bat_para[6] = 1
        pmu_bat_para[7] = 1
        pmu_bat_para[8] = 2
        pmu_bat_para[9] = 4
        pmu_bat_para[10] = 5
        pmu_bat_para[11] = 12
        pmu_bat_para[12] = 19
        pmu_bat_para[13] = 32
        pmu_bat_para[14] = 41
        pmu_bat_para[15] = 45
        pmu_bat_para[16] = 48
        pmu_bat_para[17] = 51
        pmu_bat_para[18] = 54
        pmu_bat_para[19] = 59
        pmu_bat_para[20] = 63
        pmu_bat_para[21] = 68
        pmu_bat_para[22] = 71
        pmu_bat_para[23] = 74
        pmu_bat_para[24] = 78
        pmu_bat_para[25] = 81
        pmu_bat_para[26] = 82
        pmu_bat_para[27] = 84
        pmu_bat_para[28] = 88
        pmu_bat_para[29] = 92
        pmu_bat_para[30] = 96
        pmu_bat_para[31] = 100
        pmu_bat_temp_para[0] = 7466
        pmu_bat_temp_para[1] = 4480
        pmu_bat_temp_para[2] = 3518
        pmu_bat_temp_para[3] = 2786
        pmu_bat_temp_para[4] = 2223
        pmu_bat_temp_para[5] = 1788
        pmu_bat_temp_para[6] = 1448
        pmu_bat_temp_para[7] = 969
        pmu_bat_temp_para[8] = 664
        pmu_bat_temp_para[9] = 466
        pmu_bat_temp_para[10] = 393
        pmu_bat_temp_para[11] = 333
        pmu_bat_temp_para[12] = 283
        pmu_bat_temp_para[13] = 242
        pmu_bat_temp_para[14] = 179
        pmu_bat_temp_para[15] = 134
        • baiwen
          100ask LV 6 @zy614 最后由 编辑
          @zy614 视频教程:https://www.bilibili.com/video/BV1oC4y1w7AH?p=20
