    全志v851s使用fbtft驱动0.96寸st7735屏分享
    6
    6202
      whycanservice2 LV 8 最后由 whycanservice2 编辑
      最近打算做个小玩意,需要驱动0.96寸的st7735,为此也踩了些坑,特此记录分享。
      直接上配置吧:
      1.电路图:
      这里使用到spi0 以及 PD2 PD4 还有PH0 作为pwm0 没截图显示。
      2.board.dts配置
      &pio{
                  	spi0_pins_a: spi0@0 {
                  		allwinner,pins = "PC0", "PC2";
                  		allwinner,pname = "spi0_sclk", "spi0_mosi";
                  		allwinner,function = "spi0";
                  		allwinner,muxsel = <4>;
                  		allwinner,drive = <1>;
                  		allwinner,pull = <0>;
                  	spi0_pins_b: spi0@1 {
                  		allwinner,pins = "PC1";
                  		allwinner,pname = "spi0_cs0";
                  		allwinner,pull = <1>;   // only CS should be pulled up
                  	spi0_pins_c: spi0@2 {
                  		allwinner,pins = "PC0", "PC1", "PC2";
                  		allwinner,muxsel = <0xf>;
      以上为引脚配置,
      &spi0 {
      	pinctrl-1 = <&spi0_pins_c>;
      	spi0_cs_number = <1>;
      	spi1_cs_bitmap = <1>;
      	spi_slave_mode = <0>;
      	spi_dbi_enable = <0>;
      	st7789v@0 {
      	    	compatible = "sitronix,st7735r";
      		reg = <0>;
      		spi-max-frequency = <32000000>;
      		rotate = <90>;
      		bgr;
      		fps = <60>;
      		buswidth = <8>;
      		reset-gpios = <&pio PD 2 1 1 2 1>;
      		dc-gpios = <&pio PD 4 1 1 2 0>;
      		led-gpios = <&pio PH 0 1 1 2 1>;
      		debug = <1>;
      这里是spi0配置。
      2.内核配置(可以选择关闭disp2,以及 设备树 删除disp lcd0 部分)
      切记。一定要关闭uboot disp2 。
      3.修改驱动代码
      .../linux-4.9/drivers/staging/fbtft/fbtft-core.c 文件中
      static int fbtft_request_one_gpio(struct fbtft_par *par, const char *name, int index, int *gpiop) 函数,修改后代码如下:
      	struct device *dev = par->info->device;
      	struct device_node *node = dev->of_node;
      	int gpio, flags, ret = 0;
      	struct gpio_config gpio_of_flags;
      	if (of_find_property(node, name, NULL)) {
      		gpio = of_get_named_gpio_flags(node, name, index, (enum of_gpio_flags *)&gpio_of_flags);
      		if (gpio == -ENOENT)
      		if (gpio == -EPROBE_DEFER)
      			return gpio;
      		if (gpio < 0) {
      			dev_err(dev,
      				"failed to get '%s' from DT\n", name);
      			return gpio;
      		/* active low translates to initially low */
      		flags = (gpio_of_flags.data & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW :
      							GPIOF_OUT_INIT_HIGH;
      		ret = devm_gpio_request_one(dev, gpio, flags,
      						dev->driver->name);
      		if (ret) {
      			dev_err(dev,
      				"gpio_request_one('%s'=%d) failed with %d\n",
      				name, gpio, ret);
      			return ret;
      		if (gpiop)
      			*gpiop = gpio;
      		fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n",
      							__func__, name, gpio);
      	return ret;
      修改 .../linux-4.9/drivers/staging/fbtft/fb_st7735r.c 文件
      主要修改一下驱动初始化代码列表:
      static int default_init_sequence[] = {
      	-1, MIPI_DCS_SOFT_RESET,
      	-2, 150,                               /* delay */
      	-1, MIPI_DCS_EXIT_SLEEP_MODE,
      	-2, 500,                               /* delay */
      	/* FRMCTR1 - frame rate control: normal mode
      	 * frame rate = fosc / (1 x 2 + 40) * (LINE + 2C + 2D)
      	-1, 0xB1, 0x05, 0x3C, 0x3C,
      	/* FRMCTR2 - frame rate control: idle mode
      	-1, 0xB2, 0x05, 0x3C, 0x3C,
      	/* FRMCTR3 - frame rate control - partial mode
      	 * dot inversion mode, line inversion mode
      	-1, 0xB3, 0x05, 0x3C, 0x3C, 0x05, 0x3C, 0x3C,
      	/* INVCTR - display inversion control
      	 * no inversion
      	-1, 0xB4, 0x03,
      	/* PWCTR1 - Power Control
      	 * -4.6V, AUTO mode
      	-1, 0xC0, 0xAB, 0x0B, 0x04,
      	/* PWCTR2 - Power Control
      	 * VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
      	-1, 0xC1, 0xC5,
      	/* PWCTR3 - Power Control
      	 * Opamp current small, Boost frequency
      	-1, 0xC2, 0x0D, 0x00,
      	/* PWCTR4 - Power Control
      	 * BCLK/2, Opamp current small & Medium low
      	-1, 0xC3, 0x8D, 0x6A,
      	/* PWCTR5 - Power Control */
      	-1, 0xC4, 0x8D, 0xEE,
      	/* VMCTR1 - Power Control */
      	-1, 0xC5, 0x0F,
      	-1, 0x21,
      	-1, 0x3A, 0x05,
      	-1, MIPI_DCS_SET_DISPLAY_ON,
      	-2, 100,                               /* delay */
      	-1, MIPI_DCS_ENTER_NORMAL_MODE,
      	-2, 10,                               /* delay */
      	/* end marker */
      	-3
      !!修改屏偏移
      static void set_addr_win(struct fbtft_par *par, int xs, int ys, int xe, int ye)
      	xs = xs + 1 ; xe = xe + 1 ;
      	ys = ys + 26 ; ye = ye + 26;
      	write_reg(par, MIPI_DCS_SET_COLUMN_ADDRESS,
      		  xs >> 8, xs & 0xFF, xe >> 8, xe & 0xFF);
      	write_reg(par, MIPI_DCS_SET_PAGE_ADDRESS,
      		  ys >> 8, ys & 0xFF, ye >> 8, ye & 0xFF);
      	write_reg(par, MIPI_DCS_WRITE_MEMORY_START);
      修改屏参数:
      static struct fbtft_display display = {
      	.regwidth = 8,
      	.width = 80,
      	.height = 160,
      	.init_sequence = default_init_sequence,
      	.gamma_num = 2,
      	.gamma_len = 16,
      	.gamma = DEFAULT_GAMMA,
      	.fbtftops = {
      		.set_addr_win = set_addr_win,
      		.set_var = set_var,
      		.set_gamma = set_gamma,
      至此编译即可在小机端看到有fb0生成,屏幕点亮。
      最后一图:
      如有疑问,请跟贴。
      F M 2 条回复 最后回复 回复 引用 分享 4
      • F
        frank LV 3 @whycanservice2 最后由 编辑
        @whycanservice2 可以支持多个 tft 吗
        F 1 条回复 最后回复 回复 引用 分享 0
          mysteryli LV 7 @whycanservice2 最后由 编辑
          @whycanservice2
          老哥 问两个问题
          1.你的PH0做pwm调好了吗
          2.屏幕会显示启动log嘛
          • F
            frank LV 3 @frank 最后由 编辑
            @frank 这改完 lcd0 不能用了啊
            • N
              number007cool LV 1 最后由 编辑
              @whycanservice2 在 全志v851s使用fbtft驱动0.96寸st7735屏分享 中说:
              可以选择关闭disp2,一定要关闭uboot disp2 。 具体该怎么操作 ,没理解。
                likaienjoy LV 3 最后由 编辑
                可以直接操作/dev/spi0节点,不是用fb进行液晶刷新
