    D1H-nezha-tina构建报错
    4611
      mc964203886 LV 3 最后由 编辑
      ~/tina-d1-h$ make -j32
      ===This's tina environment.===
      no need rebuild boot0, the newest file is:
      	1703146033.5841266620   2023年12月21日 星期四 16时07分13秒   /tina-d1-h/lichee/brandy-2.0/spl/nboot/libsun20iw1p1_spinor.o
      no need rebuild uboot, the newest file is:
      	1703146058.1641860450   2023年12月21日 星期四 16时07分38秒   /tina-d1-h/lichee/brandy-2.0/u-boot-2018/u-boot.cfg.configs
      === Start build scp.bin ===
      Platform d1-h Skip marisc.
      [3] 276102
      报错1:
      make[6]: Entering directory '/home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18'
      Unable to find a Python 2.x interpreter for executing /home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/scons-2.4.1/setup.py install --prefix=/home/plct/tina-d1-h/out/host !
      make[3]: *** [Makefile:35: /home/plct/tina-d1-h/out/host/stamp/.scons_installed] Error 1
      make[3]: Leaving directory '/home/plct/tina-d1-h/tools/scons'
      make[2]: *** [tools/Makefile:135: tools/scons/install] Error 2
      make[2]: *** Waiting for unfinished jobs....
      报错2:
      gcc  -I.   -I/home/plct/tina-d1-h/out/host/include -I/home/plct/tina-d1-h/out/host/usr/include   -O2 -I/home/plct/tina-d1-h/out/host/include -I/home/plct/tina-d1-h/out/host/usr/include  -MT spawn-pipe.o -MD -MP -MF $depbase.Tpo -c -o spawn-pipe.o spawn-pipe.c &&\
      mv -f $depbase.Tpo $depbase.Po
      In file included from /usr/include/signal.h:328,
                       from ./signal.h:52,
                       from c-stack.c:49:
      c-stack.c:55:26: error: missing binary operator before token "("
         55 | #elif HAVE_LIBSIGSEGV && SIGSTKSZ < 16384
      depbase=`echo mkstemp-safer.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
      gcc  -I.   -I/home/plct/tina-d1-h/out/host/include -I/home/plct/tina-d1-h/out/host/usr/include   -O2 -I/home/plct/tina-d1-h/out/host/include -I/home/plct/tina-d1-h/out/host/usr/include  -MT tmpdir.o -MD -MP -MF $depbase.Tpo -c -o tmpdir.o tmpdir.c &&\
      make[7]: *** [Makefile:1910: c-stack.o] Error 1
      make[7]: *** Waiting for unfinished jobs....
      报错3
      make[7]: Leaving directory '/home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18/lib'
      make[6]: *** [Makefile:1674: all] Error 2
      make[6]: Leaving directory '/home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18/lib'
      make[5]: *** [Makefile:1572: all-recursive] Error 1
      make[5]: Leaving directory '/home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18'
      make[4]: *** [Makefile:1528: all] Error 2
      make[4]: Leaving directory '/home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18'
      make[3]: *** [Makefile:30: /home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/m4-1.4.18/.built] Error 2
      make[3]: Leaving directory '/home/plct/tina-d1-h/tools/m4'
      make[2]: *** [tools/Makefile:135: tools/m4/compile] Error 2
      警告:
      file_io.c: In function 'io_read':
      file_io.c:1021:45: warning: logical 'or' of equal expressions [-Wlogical-op]
       1021 |                         if (errno == EAGAIN || errno == EWOULDBLOCK) {
      file_io.c: In function 'io_write_buf':
      file_io.c:1109:45: warning: logical 'or' of equal expressions [-Wlogical-op]
       1109 |                         if (errno == EAGAIN || errno == EWOULDBLOCK) {
      mv -f .deps/xz-mytime.Tpo .deps/xz-mytime.Po
      mv -f .deps/xz-signals.Tpo .deps/xz-signals.Po
      mv -f .deps/xz-tuklib_mbstr_fw.Tpo .deps/xz-tuklib_mbstr_fw.Po
      message.c: In function 'progress_speed.part.0':
      message.c:378:42: warning: '%s' directive output may be truncated writing up to 23 bytes into a region of size between 0 and 14 [-Wformat-truncation=]
        378 |         snprintf(buf, sizeof(buf), "%.*f %s",
      In file included from /usr/include/stdio.h:894,
                       from private.h:23,
                       from message.c:13:
      /usr/include/x86_64-linux-gnu/bits/stdio2.h:71:10: note: '__builtin___snprintf_chk' output between 3 and 337 bytes into a destination of size 16
         71 |   return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
         72 |                                    __glibc_objsize (__s), __fmt,
         73 |                                    __va_arg_pack ());
      mv -f .deps/xz-suffix.Tpo .deps/xz-suffix.Po
      mv -f .deps/xz-options.Tpo .deps/xz-options.Po
      mv -f .deps/xz-tuklib_mbstr_width.Tpo .deps/xz-tuklib_mbstr_width.Po
      mv -f .deps/xz-tuklib_progname.Tpo .deps/xz-tuklib_progname.Po
      list.c: In function 'parse_block_header':
      list.c:480:33: warning: this statement may fall through [-Wimplicit-fallthrough=]
        479 |                 if (block.uncompressed_size == LZMA_VLI_UNKNOWN
        480 |                                 || block.uncompressed_size
        481 |                                         == iter->block.uncompressed_size)
      list.c:487:9: note: here
        487 |         case LZMA_DATA_ERROR:
      mv -f .deps/xz-tuklib_open_stdxxx.Tpo .deps/xz-tuklib_open_stdxxx.Po
      报错4:
      mkdir -p /home/plct/tina-d1-h/out/host/stamp
      touch /home/plct/tina-d1-h/out/d1-h-nezha/compile_dir/host/xz-5.2.2/.built
      touch /home/plct/tina-d1-h/out/host/stamp/.xz_installed
      make[3]: Leaving directory '/home/plct/tina-d1-h/tools/xz'
      make[2]: Leaving directory '/home/plct/tina-d1-h'
      make[1]: *** [tools/Makefile:133: /home/plct/tina-d1-h/out/d1-h-nezha/staging_dir/target/stamp/.tools_install_yyyynyyynyyyyyyynnnyyyyyyyyyyynnyyyyyyyynyyynyyyyy] Error 2
      make[1]: Leaving directory '/home/plct/tina-d1-h'
      make: *** [/home/plct/tina-d1-h/build/toplevel.mk:306:world] 错误 2
      [3]+  已完成               $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (34 seconds) ####
      不知道哪里能够找到完整的错误信息,只能根据终端输出找到部分报错位置。请问这些报错有解决方法吗?
        WhycanService LV 8 @mc964203886 最后由 编辑
        @mc964203886 在 D1H-nezha-tina构建报错 中说:
                     from ./signal.h:52,
                     from c-stack.c:49:
        系统gcc版本过高,请使用gcc-7以下版本
        M 1 条回复 最后回复 回复 引用 分享 1
          mc964203886 LV 3 @WhycanService 最后由 编辑
          @whycanservice 请问有没有gcc-7以下的安装资源及其依赖,这几天在不停的回退所有依赖项的版本,全都不能向后兼容。是不是我的安装方法有问题。
            awwwwa LV 8 @mc964203886 最后由 编辑
            @mc964203886 一般使用Ubuntu 16.04就可以
