    V851S DVP DTS/.fex 设置
    • kanken6174
      kanken6174 LV 6 最后由 编辑
      大家好,在我的基于 V851S 的主板上通过 MIPI-CSI 成功使用 GC2053 后,我尝试使用 OV5640(应该受支持,因为它有驱动程序)来验证 DVP 端口是否正常工作。
      现在我的问题是 DVP 的文档非常混乱。 他们似乎暗示现在应该通过相应地修改 DTS 来设置 DVP,而不是旧的 .fex 格式。 问题在于,与 .fex 相比,DTS 缺少一些定义,例如如何指定 MLCK 引脚? PLCK 怎么样? 目前我的配置不会产生任何结果,因为 MLCK 引脚 (NCSI_MLCK) 似乎没有为相机提供时钟。
      这是我当前的 DTS (如您所见,旧的 GC2053 定义现已禁用以避免出现问题):
      			sensor0:sensor@0 {
      				device_type = "sensor0";
      				sensor0_mname = "gc2053_mipi";
      				sensor0_twi_cci_id = <1>;
      				sensor0_twi_addr = <0x6e>;
      				sensor0_mclk_id = <0>;
      				sensor0_pos = "rear";
      				sensor0_isp_used = <1>;
      				sensor0_fmt = <1>;
      				sensor0_stby_mode = <0>;
      				sensor0_vflip = <1>;
      				sensor0_hflip = <0>;
      				sensor0_iovdd-supply = <>;
      				sensor0_iovdd_vol = <1800000>;
      				sensor0_avdd-supply = <>;
      				sensor0_avdd_vol = <2800000>;
      				sensor0_dvdd-supply = <>;
      				sensor0_dvdd_vol = <1200000>;
      				sensor0_power_en = <>;
      				sensor0_reset = <&pio PA 8 1 0 1 0>;
      				sensor0_pwdn = <&pio PA 9 1 0 1 0>;
      				/*sensor0_sm_hs = <&pio PE 2 1 0 1 0>;*/
      				/*sensor0_sm_vs = <&pio PE 3 1 0 1 0>;*/
      				flash_handle = <&flash0>;
      				act_handle = <&actuator0>;
      				status	= "disabled";
      			sensor1:sensor@1 {
      				device_type = "sensor1";
      				sensor1_mname = "ov5640";
      				sensor1_twi_cci_id = <2>;
      				sensor1_twi_addr = <0x78>;
      				sensor1_mclk_id = <1>;
      				sensor1_pos = "front";
      				sensor1_isp_used = <1>;
      				sensor1_fmt = <1>;
      				sensor1_stby_mode = <0>;
      				sensor1_vflip = <0>;
      				sensor1_hflip = <0>;
      				sensor1_iovdd-supply = <>;
      				sensor1_iovdd_vol = <1800000>;
      				sensor1_avdd-supply = <>;
      				sensor1_avdd_vol = <2800000>;
      				sensor1_dvdd-supply = <>;
      				sensor1_dvdd_vol = <1200000>;
      				sensor1_power_en = <>;
      				sensor1_reset = <&pio PD 8 1 0 1 0>;
      				sensor1_pwdn = <>;
      				sensor1_sm_hs = <&pio PE 2 1 0 1 0>;
      				sensor1_sm_vs = <&pio PE 3 1 0 1 0>;
      				flash_handle = <>;
      				act_handle = <>;
      				status	= "okay";
      这是我的引脚设置:
      谁能确认我是否需要使用 DTS 或 .fex 才能使其正常工作? 如果是这样,我如何指定 NCSI_MLCK 和 PLCK 引脚?
      I 1 条回复 最后回复 回复 引用 分享 1
      • I
        indream LV 5 @kanken6174 最后由 indream 编辑
        @kanken6174 参考文档:https://docs.aw-ol.com/docs/soc/v821/camera/init_sensor
        csi_mclk1_pins_a: csi_mclk1@0 {
        	pins = "PD2";
        	function = "ncsi";
        	allwinner,drive = <0>;
        csi_mclk1_pins_b: csi_mclk1@1 {
        	pins = "PD2";
        	function = "gpio_in";
        sensor0:sensor@0 {
              sensor0_mclk_id = <1>;
