    • I
      iincity LV 5 最后由 编辑
      回复: tina linux中选择rtl8723ds wifi驱动编译报错
      insmod: can't insert '/lib/modules/5.4.61/gt9xxnew_ts.ko': Operation not permitted
      ------/sbin/insmod /lib/modules/5.4.61/8723ds.ko-----
      [ 72.457769] RTW: module init start
      [ 72.461572] RTW: rtl8733bs v5.14.1.1-29-ga4429ac3f.20230614_COEX20211210-2706
      [ 72.469632] RTW: build time: Mar 7 2023 16:26:43
      [ 72.474879] RTW: rtl8733bs BT-Coex version = COEX20211210-2706
      [ 72.481540] RTW: rtw_inetaddr_notifier_register
      [ 72.486754] RTW: module init ret=0
      ------run rc.final file-----
      ------run profile file-----
      |_ ||| ___ _ _ | | || ___ _ _ _ _
      | | _ | || | | |__ | || || | ||
      | | | || | || _ | |_____||
      | |||||||_| Tina is Based on OpenWrt!
