    Melis 文件系统问题
      leomini5 LV 6 最后由 编辑
      系统的这三个选项具体都有啥区别啊
      Rootfs Filesystem Type (Allwinner Minfs Filesystem) --->
      ARM Littlefs Filesystem
      Fat Filesystem
      我选中间那个Minfs Filesystem pack才能打包成功,但是系统没法写入了nor Flash还有很大空间,但是df出来,磁盘空间是0,这怎么往nor flash里面读写文件啊
      选上面那个ARM的,直接打包不了,提示太大了,16M的打包不了
      选FAT那个也是,打包不了报错。。。
      如果想要使用nor flash 做可读写磁盘的话怎么配置啊?
      [mbr] size = 16 [partition_start] [partition] name = bootA size = 4096 downloadfile = "melis_pkg_nor.fex" user_type = 0x8000 [partition] name = ROOTFS size = 12032 downloadfile = "data_udisk.fex" user_type = 0x8000 [partition] name = UDISK size = 10032 user_type = 0x8000
      =bootA:2048:"melis_pkg_nor.fex"=
      =ROOTFS:6016:"data_udisk.fex"=
      data_udisk.fex
      try to create image: ROOTFS to data_udisk.fex with size 6160384
      =UDISK:8256:"None"=
      melis_d1s-nezha_uart0_16Mnor.img
      INFO: running the function do_finish "sys_partition_nor.bin"
      partitation file Path=/home/leo/miles-d1s/miles/d1s-melis-master/out/d1s-nezha/image/sys_partition_nor.bin
      mbr_name file Path=/home/leo/miles-d1s/miles/d1s-melis-master/out/d1s-nezha/image/sunxi_mbr_nor.fex
      download_name file Path=/home/leo/miles-d1s/miles/d1s-melis-master/out/d1s-nezha/image/dlinfo.fex
      ERROR:  unable to open file data_udisk.fex
      ERROR: update mbr file fail
      ERROR: update_mbr failed
