    V851SE TinyVision地表最帅AI开发板来了! @yuzukihd
    7
    5977
    • baiwen
      100ask LV 6 最后由 编辑
      baiwen 1 条回复 最后回复 回复 引用 分享 3
      • baiwen
        100ask LV 6 @baiwen 最后由 baiwen 编辑
        @baiwen 使用tina-sdk 4.0 启动 提示 ERROR: reserving fdt memory region failed (addr=41f12000 size=384000)
        有问题固件
        tina_v851se-tinyvision_uart0_kernel-error.zip
        sd线刷
        330db410-2984-48f5-8b60-ad3b94fe6689-sd-tina_v851se-tinyvision_uart0.zip
        env.cfg
        ubuntu@ubuntu1804:~/Downloads/tina-v851/device/config/chips/v851se/configs/default$ cat env.cfg
        #kernel command arguments
        earlyprintk=sunxi-uart,0x02500000
        initcall_debug=0
        console=ttyS0,115200
        nand_root=ubi0_4
        mmc_root=/dev/mmcblk0p4
        nor_root=/dev/mtdblock1
        init=/init
        loglevel=8
        coherent_pool=16K
        #reserve_list=30M@64M,78M@128M,200M@512M
        mac=
        wifi_mac=
        bt_mac=
        specialstr=
        root_partition=rootfs
        mtd_name=sys
        rootfstype=ubifs, rw
        #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
        setargs_nor=setenv bootargs  earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nor_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        setargs_nand=setenv bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel}  ubi.mtd=${mtd_name} root=${nand_root} rootfstype=${rootfstype} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
        setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${mmc_root}  rootwait init=${init} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        #nand command syntax: sunxi_flash read address partition_name read_bytes
        #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
        boot_partition=boot
        boot_normal=sunxi_flash read 44800000 ${boot_partition};bootm 44800000
        boot_recovery=sunxi_flash read 44800000 extend;bootm 44800000
        boot_fastboot=fastboot
        #recovery key
        recovery_key_value_max=0x13
        recovery_key_value_min=0x10
        #fastboot key
        fastboot_key_value_max=0x8
        fastboot_key_value_min=0x2
        #uboot system env config
        bootdelay=1
        bootcmd=run setargs_nand boot_normal#default nand boot
        #verify the kernel
        verify=N
        u-boot-2018.tar.gz
          awwwwa LV 8 最后由 awwwwa 编辑
          配置 CONFIG_SUNXI_MALLOC_LEN=0x1400000
          修改文件
          lichee/brandy-2.0/u-boot-2018/include/configs/sun8iw21p1.h
          把
          define SUNXI_SYS_MALLOC_LEN	(32 << 20)
          改为
          #ifdef CONFIG_SUNXI_MALLOC_LEN
          #define SUNXI_SYS_MALLOC_LEN	CONFIG_SUNXI_MALLOC_LEN
          #else
          #define SUNXI_SYS_MALLOC_LEN	(32 << 20)
            awwwwa LV 8 最后由 编辑
              codedogejack123 LV 4 最后由 编辑
              有链接地址吗?在百问网旗舰店好像找不到
                budbool LV 9 @codedogejack123 最后由 编辑
                @codedogejack123 https://item.taobao.com/item.htm?id=756255119524&spm=a1z10.3-c-s.w4002-18944745109.54.6e6e303119s3fO
                  codedogejack123 LV 4 @q1215200171 最后由 编辑
                  @q1215200171 非常感谢
