    t113-s3 eMMc问题
      yubeer LV 5 最后由 编辑
      1、没焊接eMMC前用的SD卡启动,debug用的uart2,可以引导系统;(但是uboot debug没改过来)
      2、焊接了eMMC型号,能从SD卡启动,但看不到emmc设备,把uboot中与uart2复用的lcd等功能disabled,然后就不能引导系统了;
      3、重新焊接了eMMC还是不行(型号KLM8G1GETF-B041)
      U-Boot 2018.05-g2a1965a-dirty (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
      [00.508]CPU: Allwinner Family
      [00.511]Model: sun8iw20
      [00.513]DRAM: 128 MiB
      [00.517]Relocation Offset is: 04ebc000
      [00.542]secure enable bit: 0
      [00.545]smc_tee_inform_fdt failed with: -65526[00.549]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.555]gic: sec monitor mode
      [00.558]flash init start
      [00.560]workmode = 0,storage type = 1
      [00.563][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.569][mmc]: get sdc_type fail and use default host:tm1.
      [00.575][mmc]: can't find node "mmc0",will add new node
      [00.580][mmc]: fdt err returned <no error>
      [00.584][mmc]: Using default timing para
      [00.587][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.613][mmc]: card_caps:0x3000000a
      [00.617][mmc]: host_caps:0x3000003f
      [00.621]sunxi flash init ok
      [00.624]line:703 init_clocks
      [00.627]drv_disp_init
      [00.637]unable to map hdmi registers
      [00.640]drv_disp_init finish
      [00.650]Loading Environment from SUNXI_FLASH... OK
      [00.668]boot_gui_init:start
      [00.671]set disp.dev2_output_type fail. using defval=0
      drv_lcd_open_callback lcd open flow is NULL! LCD enable fail!
      [00.682]boot_gui_init:finish
      [00.693]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 3 ms (12.2 MiB/s)
      [00.705]Item0 (Map) magic is bad
      [00.708]the secure storage item0 copy0 magic is bad
      [00.713]Item0 (Map) magic is bad
      [00.716]the secure storage item0 copy1 magic is bad
      [00.720]Item0 (Map) magic is bad
      [00.723]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.739]update part info
      [00.742]update bootcmd
      [00.745]change working_fdt 0x43e7be70 to 0x43e5be70
      [00.766]update dts
      [03.012]no vendor_boot partition is found
      Android's image name: t113-mq_r
      [03.024]Starting kernel ...
      [03.027][mmc]: MMC Device 2 not found
      [03.030][mmc]: mmc 2 not find, so not exit
      Y 1 条回复 最后回复 回复 引用 分享 0
        yubeer LV 5 @yubeer 最后由 q1215200171 编辑
        [03.025]Starting kernel ...
        [03.031][mmc]: mmc 2 not find, so not exit
        [    0.000000] Linux version 5.4.61 (xinhy@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #58 SMP PREEMPT Tue Jan 23 09:51:41 UTC 2024
        [    0.000000]   Normal zone: 288 pages used for memmap
        [    0.000000] percpu: Embedded 15 pages/cpu s31116 r8192 d22132 u61440
        [    0.000000] pcpu-alloc: s31116 r8192 d22132 u61440 alloc=15*4096
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32480
        [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500800 clk_ignore_unused initcall_debug=0 console=ttyS2,115200 rootdelay=1 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g2a1965a-dirty(07/10/2022-02:50:57) mbr_offset=1032192 disp_reserve=1536000,0x43f06000 androidboot.dramsize=128
        [    0.000000] Memory: 103640K/131072K available (8192K kernel code, 484K rwdata, 2240K rodata, 1024K init, 201K bss, 23336K reserved, 4096K cma-reserved)
        [    0.000000] random: get_random_bytes called from start_kernel+0x258/0x3e4 with crng_init=0
        [    0.008018] Switching to timer-based delay loop, resolution 41ns
        [    0.014183] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [    0.023954] Console: colour dummy device 80x30
        [    0.028421] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.038791] pid_max: default: 32768 minimum: 301
        [    0.043477] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.050812] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.059425] CPU: Testing write buffer coherency: ok
        [    0.064664] /cpus/cpu@0 missing clock-frequency property
        [    0.069992] /cpus/cpu@1 missing clock-frequency property
        [    0.075337] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.081719] Setting up static identity map for 0x40100000 - 0x40100060
        [    0.088439] rcu: Hierarchical SRCU implementation.
        [    0.093630] BOOTEVENT:        93.620790: ON
        [    0.098036] smp: Bringing up secondary CPUs ...
        [    0.103878] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.104040] smp: Brought up 1 node, 2 CPUs
        [    0.113877] SMP: Total of 2 processors activated (96.00 BogoMIPS).
        [    0.120058] CPU: All CPU(s) started in SVC mode.
        [    0.125327] devtmpfs: initialized
        [    0.222473] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.234547] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.244426] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
        [    0.251583] pinctrl core: initialized pinctrl subsystem
        [    0.267696] NET: Registered protocol family 16
        [    0.274333] DMA: preallocated 256 KiB pool for atomic coherent allocations
        [    0.512124] rtc_ccu: sunxi ccu init OK
        [    0.548173] ccu: sunxi ccu init OK
        [    0.557937] r_ccu: sunxi ccu init OK
        [    1.045308] iommu: Default domain type: Translated
        [    1.050426] sunxi iommu: irq = 24
        [    1.077743] SCSI subsystem initialized
        [    1.090435] usbcore: registered new interface driver usbfs
        [    1.096103] usbcore: registered new interface driver hub
        [    1.101533] usbcore: registered new device driver usb
        [    1.112160] mc: Linux media interface: v0.10
        [    1.116915] videodev: Linux video capture interface: v2.00
        [    1.143320] Advanced Linux Sound Architecture Driver Initialized.
        [    1.159151] Bluetooth: Core ver 2.22
        [    1.162937] NET: Registered protocol family 31
        [    1.167397] Bluetooth: HCI device and connection manager initialized
        [    1.173795] Bluetooth: HCI socket layer initialized
        [    1.178673] Bluetooth: L2CAP socket layer initialized
        [    1.183755] Bluetooth: SCO socket layer initialized
        [    1.196058] g2d 5410000.g2d: Adding to iommu group 0
        [    1.203731] G2D: rcq version initialized.major:251
        [    1.216806] clocksource: Switched to clocksource arch_sys_counter
        [    1.416119] sun8iw20-pinctrl pio: initialized sunXi PIO driver
        [    1.735152] thermal_sys: Registered thermal governor 'step_wise'
        [    1.735159] thermal_sys: Registered thermal governor 'user_space'
        [    1.752810] NET: Registered protocol family 2
        [    1.775434] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    1.783859] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    1.791552] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
        [    1.798628] TCP: Hash tables configured (established 1024 bind 1024)
        [    1.805103] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    1.811684] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    1.819037] NET: Registered protocol family 1
        [    1.835231] RPC: Registered named UNIX socket transport module.
        [    1.841233] RPC: Registered udp transport module.
        [    1.845942] RPC: Registered tcp transport module.
        [    1.850664] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    1.891248] Initialise system trusted keyrings
        [    1.895949] workingset: timestamp_bits=14 max_order=15 bucket_order=1
        [    1.911473] squashfs: version 4.0 (2009/01/31) Phillip Lougher
        [    1.920902] NFS: Registering the id_resolver key type
        [    1.928741] Key type id_resolver registered
        [    1.932927] Key type id_legacy registered
        [    1.937178] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    1.943873] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
        [    1.954023] ntfs: driver 2.1.32 [Flags: R/W].
        [    1.964505] fuse: init (API version 7.31)
        [    2.000713] NET: Registered protocol family 38
        [    2.005179] Key type asymmetric registered
        [    2.009331] Asymmetric key parser 'x509' registered
        [    2.014241] io scheduler mq-deadline registered
        [    2.018808] io scheduler kyber registered
        [    2.022943] atomic64_test: passed
        [    2.041921] [DISP]disp_module_init
        [    2.054676] [DISP]disp_module_init finish
        [    2.065523] sunxi_sid_init()551 - insmod ok
        [    2.087878] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
        [    2.104733] uart uart2: uart2 supply uart not found, using dummy regulator
        [    2.120623] uart2: ttyS2 at MMIO 0x2500800 (irq = 34, base_baud = 1500000) is a SUNXI
        [    2.128491] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
        ⚌[    2.136475] printk: console [ttyS2] enabled
        [    2.145407] printk: bootconsole [earlycon0] disabled
        [    2.168966] misc dump reg init
        [    2.195248] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
        [    2.205428] [ADDR_MGT] addr_mgt_probe: success.
        [    2.241904] libphy: Fixed MDIO Bus: probed
        [    2.246514] CAN device driver interface
        [    2.257377] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
        [    2.266313] sunxi gmac driver's version: 1.0.0
        [    2.274288] gmac-power0: NULL
        [    2.277673] gmac-power1: NULL
        [    2.281002] gmac-power2: NULL
        [    2.304591] Failed to alloc md5
        [    2.308228] eth0: Use random mac address
        [    2.315924] PPP generic driver version 2.4.2
        [    2.330279] PPP BSD Compression module registered
        [    2.335570] PPP Deflate Compression module registered
        [    2.341278] PPP MPPE Compression module registered
        [    2.346659] NET: Registered protocol family 24
        [    2.351711] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [    2.359050] sunxi-ehci: EHCI SUNXI driver
        [    2.363996] get ehci0-controller wakeup-source is fail.
        [    2.370005] sunxi ehci0-controller don't init wakeup source
        [    2.376267] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0d9ba70, 0x:c8825000, irq_no:33
        [    2.388289] [sunxi-ehci0]: Not init ehci0
        [    2.393117] get ehci1-controller wakeup-source is fail.
        [    2.399117] sunxi ehci1-controller don't init wakeup source
        [    2.405378] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0d9bf90, 0x:c8829000, irq_no:35
        [    2.418242] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
        [    2.436751] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
        [    2.452000] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
        [    2.459335] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
        [    2.469432] sunxi-ehci 4200000.ehci1-controller: irq 53, io mem 0x04200000
        [    2.516821] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
        [    2.524642] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
        [    2.548786] hub 1-0:1.0: USB hub found
        [    2.553155] hub 1-0:1.0: 1 port detected
        [    2.567610] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [    2.574579] sunxi-ohci: OHCI SUNXI driver
        [    2.579563] get ohci0-controller wakeup-source is fail.
        [    2.591558] sunxi ohci0-controller don't init wakeup source
        [    2.597855] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0d9bd00
        [    2.607535] [sunxi-ohci0]: Not init ohci0
        [    2.612458] get ohci1-controller wakeup-source is fail.
        [    2.618478] sunxi ohci1-controller don't init wakeup source
        [    2.624738] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0d9c220
        [    2.634449] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
        [    2.650196] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
        [    2.662596] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
        [    2.670019] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
        [    2.685934] sunxi-ohci 4200400.ohci1-controller: irq 54, io mem 0x04200400
        [    2.774949] hub 2-0:1.0: USB hub found
        [    2.779487] hub 2-0:1.0: 1 port detected
        [    2.797540] usbcore: registered new interface driver uas
        [    2.803669] usbcore: registered new interface driver usb-storage
        [    2.810557] usbcore: registered new interface driver ums-alauda
        [    2.817392] usbcore: registered new interface driver ums-cypress
        [    2.824219] usbcore: registered new interface driver ums-datafab
        [    2.831075] usbcore: registered new interface driver ums_eneub6250
        [    2.841183] usbcore: registered new interface driver ums-freecom
        [    2.848084] usbcore: registered new interface driver ums-isd200
        [    2.854807] usbcore: registered new interface driver ums-jumpshot
        [    2.864819] usbcore: registered new interface driver ums-karma
        [    2.871522] usbcore: registered new interface driver ums-onetouch
        [    2.878495] usbcore: registered new interface driver ums-realtek
        [    2.885338] usbcore: registered new interface driver ums-sddr09
        [    2.892099] usbcore: registered new interface driver ums-sddr55
        [    2.905088] usbcore: registered new interface driver ums-usbat
        [    2.918021] usbcore: registered new interface driver option
        [    2.924364] usbserial: USB Serial support registered for GSM modem (1-port)
        [    2.935954] sunxi_gpadc_init,2151, success
        [    2.939286] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
        [    2.950835] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
        [    2.978785] sunxi-rtc 7090000.rtc: registered as rtc0
        [    2.984605] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:07 UTC (7)
        [    2.993552] sunxi-rtc 7090000.rtc: sunxi rtc probed
        [    2.999512] i2c /dev entries driver
        [    3.003650] IR NEC protocol handler initialized
        [    3.008782] IR RC5(x/sz) protocol handler initialized
        [    3.015149] usbcore: registered new interface driver uvcvideo
        [    3.021668] USB Video Class driver (1.1.1)
        [    3.026270] gspca_main: v2.14.0 registered
        [    3.030888] sunxi cedar version 1.1
        [    3.042423] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
        [    3.056950] Bluetooth: HCI UART driver ver 2.3
        [    3.061945] Bluetooth: HCI UART protocol H4 registered
        [    3.089983] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
        [    3.098964] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
        [    3.109186] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
        [    3.115597] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
        [    3.121990] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
        [    3.128492] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
        [    3.134950] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
        [    3.141523] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
        [    3.148109] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
        [    3.154656] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
        [    3.161295] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
        [    3.190324] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.190382] hub 1-1:1.0: USB hub found
        [    3.205879] hub 1-1:1.0: 4 ports detected
        [    3.214168] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.239762] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
        [    3.247037] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.271147] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.287297] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
        [    3.288455] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.297311] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
        [    3.314900] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.321698] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.326905] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
        [    3.326913] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
        [    3.333283] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [    3.339719] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
        [    3.346758] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.353199] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
        [    3.359931] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.366465] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
        [    3.373222] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.379762] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
        [    3.384950] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [    3.391482] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
        [    3.398526] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.399343] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.418622] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.422311] sunxi-mmc 4020000.sdmmc: Got CD GPIO
        [    3.423827] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [    3.429274] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
        [    3.436088] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.442821] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.449254] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.460438] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
        [    3.467132] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.479961] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [    3.486876] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.487034] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.505370] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.511710] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
        [    3.512134] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.517843] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.522985] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [    3.539212] hidraw: raw HID events driver (C) Jiri Kosina
        [    3.541645] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.554423] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.558257] usbcore: registered new interface driver usbhid
        [    3.561224] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.570706] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.572627] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [    3.584820] usbhid: USB HID core driver
        [    3.591299] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.602394] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.609204] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.614420] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [    3.621504] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.628310] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.630245] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.635076] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.651933] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [    3.659020] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.662178] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
        [    3.662178]
        [    3.665772] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.683378] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
        [    3.689695] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.705876] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [    3.710418] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.712958] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.728563] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
        [    3.731264] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.746242] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.751515] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [    3.758641] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.765395] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.771021] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
        [    3.772172] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.782164] [SNDCODEC][sunxi_card_init][583]:card init finished
        [    3.787147] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [    3.800849] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.804140] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
        [    3.807629] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.807646] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.807680] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [    3.836617] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.843419] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.850221] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.853644] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
        [    3.855456] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [    3.873930] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.878524] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
        [    3.880723] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.894991] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.898833] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
        [    3.900245] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [    3.914594] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.919621] mmc1: host does not support reading read-only switch, assuming write-enable
        [    3.921358] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.937090] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.941198] xt_time: kernel timezone is -0000
        [    3.942297] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [    3.947261] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    3.954244] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.972494] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    3.979274] sunxi-mmc 4022000.sdmmc: retry:start
        [    3.984494] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [    3.991568] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    3.998330] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.005087] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.008786] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
        [    4.010316] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [    4.017705] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 10000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    4.024441] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.038438] NET: Registered protocol family 10
        [    4.042887] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.054615] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.059852] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [    4.066978] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.067595] Segment Routing with IPv6
        [    4.073749] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.077903] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 6000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [    4.084587] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.096380] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
        [    4.101401] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [    4.108128] mmc1: new high speed SDHC card at address aaaa
        [    4.115060] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.127957] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.134717] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.139961] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [    4.147034] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.153782] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.157227] mmcblk1: mmc1:aaaa SD32G 29.7 GiB
        [    4.160554] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.170742] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [    4.177820] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.184569] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.191377] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.196591] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [    4.203669] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.210452] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.211451] NET: Registered protocol family 17
        [    4.217232] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.217266] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [    4.222490] NET: Registered protocol family 15
        [    4.227455] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.228276] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.234714] can: controller area network core (rev 20170425 abi 9)
        [    4.239546] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.246339] NET: Registered protocol family 29
        [    4.253086] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [    4.259988] can: raw protocol (rev 20170425)
        [    4.265175] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.270143] can: broadcast manager protocol (rev 20170425 t)
        [    4.277183] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.281955] can: netlink gateway (rev 20190810) max_hops=1
        [    4.288710] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.298636] Bluetooth: RFCOMM TTY layer initialized
        [    4.301865] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [    4.308162] Bluetooth: RFCOMM socket layer initialized
        [    4.313176] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.318750] Bluetooth: RFCOMM ver 1.11
        [    4.325669] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.334888] lib80211: common routines for IEEE802.11 drivers
        [    4.338176] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.338213] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [    4.342433] lib80211_crypt: registered algorithm 'NULL'
        [    4.349171] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.355517] lib80211_crypt: registered algorithm 'WEP'
        [    4.360695] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.360708] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.367760] lib80211_crypt: registered algorithm 'CCMP'
        [    4.373612] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [    4.380343] lib80211_crypt: registered algorithm 'TKIP'
        [    4.386111] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.394066] Registering SWP/SWPB emulation handler
        [    4.398029] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.398043] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.411504] Loading compiled-in X.509 certificates
        [    4.416834] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [    4.453333] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.460113] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.466889] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.472105] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [    4.479200] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.485949] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.492739] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.497987] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [    4.505041] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.511824] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.518614] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.523818] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [    4.531002] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.537799] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.544570] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.549829] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [    4.556913] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [    4.563662] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
        [    4.570443] sunxi-mmc 4022000.sdmmc: retry:start
        [    4.575653] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [    4.582914] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [    4.591163] sunxi-mmc 4022000.sdmmc: retry:give up
        [    4.597575] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [    4.610974]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
        [    4.679935] usb 1-1.1: new high-speed USB device number 3 using sunxi-ehci
        [    4.823815] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
        [    4.836430] sunxi-i2c sunxi-i2c3: sunxi-i2c3 supply twi not found, using dummy regulator
        [    4.863614] sunxi-i2c sunxi-i2c3: probe success
        [    4.950122] get usb_detect_mode is fail, -22
        [    4.958049] get det_vbus is fail, -84
        [    4.962162] get id is fail, -84
        [    5.001167] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    5.013076] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    5.020697] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
        [    5.027028] clk: Not disabling unused clocks
        [    5.030396] cfg80211: failed to load regulatory.db
        [    5.035152] ALSA device list:
        [    5.043985]   #0: audiocodec
        [    5.047523] Waiting 1 sec before mounting root device...
        [    6.006830]
        [    6.006830] insmod_device_driver
        [    6.006830]
        [    6.014048] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
        [    6.029810] device_chose finished 142!
        [    6.087055] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
        [    6.095749] Please append a correct "root=" boot option; here are the available partitions:
        [    6.105178] b300        31166976 mmcblk1
        [    6.105182]  driver: mmcblk
        [    6.112827]   b301             252 mmcblk1p1 a0085546-4166-744a-a353-fca9272b8e45
        [    6.112830]
        [    6.122909]   b302             252 mmcblk1p2 a0085546-4166-744a-a353-fca9272b8e46
        [    6.122912]
        [    6.132991]   b303             252 mmcblk1p3 a0085546-4166-744a-a353-fca9272b8e47
        [    6.132994]
        [    6.143071]   b304            6400 mmcblk1p4 a0085546-4166-744a-a353-fca9272b8e48
        [    6.143073]
        [    6.153184]   b305           30720 mmcblk1p5 a0085546-4166-744a-a353-fca9272b8e49
        [    6.153186]
        [    6.163273]   b306            5120 mmcblk1p6 a0085546-4166-744a-a353-fca9272b8e4a
        [    6.163276]
        [    6.173368]   b307           25200 mmcblk1p7 a0085546-4166-744a-a353-fca9272b8e4b
        [    6.173371]
        [    6.183450]   103:00000   31061899 mmcblk1p8 a0085546-4166-744a-a353-fca9272b8e4c
        [    6.183452]
        [    6.193541] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
        [    6.202820] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #58
        [    6.209558] Hardware name: Generic DT based system
        [    6.214956] [<c010e1d8>] (unwind_backtrace) from [<c010a7e0>] (show_stack+0x10/0x14)
        [    6.223649] [<c010a7e0>] (show_stack) from [<c08ada00>] (dump_stack+0x7c/0x98)
        [    6.231758] [<c08ada00>] (dump_stack) from [<c01198e0>] (panic+0x104/0x3d8)
        [    6.239574] [<c01198e0>] (panic) from [<c0c012d4>] (mount_block_root+0x230/0x328)
        [    6.247974] [<c0c012d4>] (mount_block_root) from [<c0c01584>] (prepare_namespace+0x138/0x178)
        [    6.257541] [<c0c01584>] (prepare_namespace) from [<c```
        code_text
        ```08c2450>] (kernel_init+0x8/0x118)
        [    6.266432] [<c08c2450>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
        [    6.274922] Exception stack(0xc7419fb0 to 0xc7419ff8)
        [    6.280589] 9fa0:                                     00000000 00000000 00000000 00000000
        [    6.289769] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
        [    6.298944] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
        [    6.306368] CPU0: stopping
