    make 编译报错
      cwj1986521 LV 5 最后由 编辑
      make[6]: Entering directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2/po'
      make[6]: Nothing to be done for 'all'.
      make[6]: Leaving directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2/po'
      make[6]: Entering directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2'
      CCLD login
      /home/jay/allwinner/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/6.4.1/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: cannot find -lpam
      /home/jay/allwinner/Tina-Linux/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/6.4.1/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: cannot find -lpam_misc
      collect2: error: ld returned 1 exit status
      Makefile:5603: recipe for target 'login' failed
      make[6]: *** [login] Error 1
      make[6]: Leaving directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2'
      Makefile:10068: recipe for target 'all-recursive' failed
      make[5]: *** [all-recursive] Error 1
      make[5]: Leaving directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2'
      Makefile:4366: recipe for target 'all' failed
      make[4]: *** [all] Error 2
      make[4]: Leaving directory '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2'
      Makefile:653: recipe for target '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2/.built' failed
      make[3]: *** [/home/jay/allwinner/Tina-Linux/out/t113-mq_r/compile_dir/target/util-linux-2.25.2/.built] Error 2
      make[3]: Leaving directory '/home/jay/allwinner/Tina-Linux/package/utils/util-linux'
      package/Makefile:192: recipe for target 'package/utils/util-linux/compile' failed
      make[2]: *** [package/utils/util-linux/compile] Error 2
      make[2]: Leaving directory '/home/jay/allwinner/Tina-Linux'
      package/Makefile:189: recipe for target '/home/jay/allwinner/Tina-Linux/out/t113-mq_r/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/jay/allwinner/Tina-Linux/out/t113-mq_r/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/jay/allwinner/Tina-Linux'
      /home/jay/allwinner/Tina-Linux/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      make failed to build some targets (01:51 (mm:ss))
      没找出来是哪个地方出现的问题
