    T113 启动报错
      cwj1986521 LV 5 最后由 编辑
      [ 3.043024] UBIFS (ubi0:7): default file-system created
      [ 3.049693] UBIFS (ubi0:7): Mounting in unauthenticated mode
      [ 3.056267] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 104
      [ 3.193917] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
      [ 3.202758] UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
      [ 3.213900] UBIFS (ubi0:7): FS size: 23224320 bytes (22 MiB, 90 LEBs), journal size 2064385 bytes (1 MiB, 6 LEBs)
      [ 3.225444] UBIFS (ubi0:7): reserved for root: 1096942 bytes (1071 KiB)
      [ 3.232882] UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID C837F313-E818-4741-AE48-A45FF3DC7A88, small LPT model
      Cannot get MTD information for /dev/by-name/env
      Cannot get MTD information for /dev/by-name/env-redund
      [ 3.293656] overlayfs: upper fs does not support file handles, falling back to index=off.
      /pseudo_init: [ 3.325650] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
      exec: line 410: /sbin/init: not found
      [ 3.335317] CPU0: stopping
      [ 3.341722] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #142
      [ 3.348553] Hardware name: Generic DT based system
      [ 3.353950] [<c010dee8>] (unwind_backtrace) from [<c010a678>] (show_stack+0x10/0x14)
      [ 3.362647] [<c010a678>] (show_stack) from [<c0635e90>] (dump_stack+0x88/0xa4)
      [ 3.370754] [<c0635e90>] (dump_stack) from [<c010c2b4>] (handle_IPI+0xe4/0x180)
      [ 3.378963] [<c010c2b4>] (handle_IPI) from [<c032000c>] (gic_handle_irq+0x70/0x78)
      [ 3.387460] [<c032000c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [ 3.395856] Exception stack(0xc0a01f40 to 0xc0a01f88)
      [ 3.401524] 1f40: 00016154 c7aba334 00000000 c0114800 00000001 c0a00000 c0a04e24 c0a04e60
      [ 3.410701] 1f60: c0a3d000 c7bff500 c09280c0 00000000 c0b43748 c0a01f90 c0107fb0 c0107fa0
      [ 3.419872] 1f80: 60000013 ffffffff
      [ 3.423789] [<c01021cc>] (__irq_svc) from [<c0107fa0>] (arch_cpu_idle+0x1c/0x38)
      [ 3.432092] [<c0107fa0>] (arch_cpu_idle) from [<c013d564>] (do_idle+0xd4/0x128)
      [ 3.440298] [<c013d564>] (do_idle) from [<c013d848>] (cpu_startup_entry+0x18/0x20)
      [ 3.448793] [<c013d848>] (cpu_startup_entry) from [<c0900c80>] (start_kernel+0x360/0x3ec)
      [ 3.457978] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
      code_text
