    【T113】【spi 驱动】【大数据DMA传输】
      shiguojie1989 LV 3 最后由 编辑
      1.需求:通过gsip引脚接收来自fpga的数据等待接收中断,然后中断到来后,113的spi驱动为主控读取fpga的spi数据,数据量12800字节,驱动设置了10个缓冲区映射内存,spi内次写入一个缓冲区。中断频率为25Hz。应用程序通过map映射会读取存在的10个里面的ok的缓冲区。
      2.现状:驱动代码基于imx6ull linux4.9版本修改,驱动已经编译通过,并且可以使用read、write接口正常的进行spi通讯(1000字节以内)。但是如果是使用GPIS中断函数来完成spi的读取,调用同样的spi读写函数,spi不能正常工作,会提示:“Bufferless transfer has length ”,错误来自spi.c。(注意,gpio中断是fpga的引脚给T113的引脚,代码中通过中断函数触发spi的一次传输)
      3.驱动文件是:fsfpgain.c;read、write测试app是:test_spidev.c;gpio中断来读取spi测试app是:test_fsfpgain.c
      下面是三个文件的代码:
      fsfpgain.c
      #include <linux/types.h>
      #include <linux/kernel.h>
      #include <linux/delay.h>
      #include <linux/ide.h>
      #include <linux/init.h>
      #include <linux/module.h>
      #include <linux/errno.h>
      #include <linux/gpio.h>
      #include <linux/cdev.h>
      #include <linux/device.h>
      #include <linux/err.h>
      #include <linux/list.h>
      #include <linux/of_gpio.h>
      #include <linux/semaphore.h>
      #include <linux/timer.h>
      #include <linux/spi/spi.h>
      #include <linux/of.h>
      #include <linux/of_address.h>
      #include <linux/atomic.h>
      #include <linux/irq.h>
      #include <linux/of_irq.h>
      #include <asm/mach/map.h>
      #include <asm/uaccess.h>
      #include <asm/io.h>
      #include <linux/spi/spidev.h>
      #include <linux/acpi.h>
      #include <asm/io.h>
       * This supports access to SPI devices using normal userspace I/O calls.
       * Note that while traditional UNIX/POSIX I/O semantics are half duplex,
       * and often mask message boundaries, full SPI support requires full duplex
       * transfers.  There are several kinds of internal message boundaries to
       * handle chipselect management and other protocol options.
       * SPI has a character major number assigned.  We allocate minor numbers
       * dynamically using a bitmask.  You must use hotplug tools, such as udev
       * (or mdev with busybox) to create and destroy the /dev/spidevB.C device
       * nodes, since there is no fixed association of minor numbers with any
       * particular SPI bus or device.
      #define SPIDEV_MAJOR			153	/* assigned */
      #define N_SPI_MINORS			32	/* ... up to 256 */
      static DECLARE_BITMAP(minors, N_SPI_MINORS);
      /* Bit masks for spi_device.mode management.  Note that incorrect
       * settings for some settings can cause *lots* of trouble for other
       * devices on a shared bus:
       *  - CS_HIGH ... this device will be active when it shouldn't be
       *  - 3WIRE ... when active, it won't behave as it should
       *  - NO_CS ... there will be no explicit message boundaries; this
       *	is completely incompatible with the shared bus model
       *  - READY ... transfers may proceed when they shouldn't.
       * REVISIT should changing those flags be privileged?
      #define SPI_MODE_MASK		(SPI_CPHA | SPI_CPOL | SPI_CS_HIGH \
      				| SPI_LSB_FIRST | SPI_3WIRE | SPI_LOOP \
      				| SPI_NO_CS | SPI_READY | SPI_TX_DUAL \
      				| SPI_TX_QUAD | SPI_RX_DUAL | SPI_RX_QUAD)
      #define DMAC_CNLL_MAX_NUM           32
      #define DMAC_ONE_TR_NUM             1000 //一次spi从fpga读取的大小
      #define DMAC_MAX_TRF_SIZE           DMAC_CNLL_MAX_NUM*DMAC_ONE_TR_NUM
      #define DMA_RECV_MAX_NUM            10//环形缓冲器大小
      #define VER 0x20000113
      #define NEXT_BUF(x) (((x+1) < DMA_RECV_MAX_NUM) ? (x+1) : 0)
      struct mem_addr{
      	char* v_adr;
      	dma_addr_t p_adr;
      };//内存物理地址和虚拟地址
      //环形缓冲器,分块保存每个dma头物理地址
      struct buffer_cut{
      	unsigned int recv_num;
      	unsigned int last_buf_len;//最后一块内存的长度
      	dma_addr_t pr_buf_fpga[DMA_RECV_MAX_NUM][DMAC_CNLL_MAX_NUM];
      struct spidev_data {
      	dev_t			devt;
      	spinlock_t		spi_lock;
      	struct spi_device	*spi;
      	struct list_head	device_entry;
      	/* TX/RX buffers are NULL unless this device is open (users > 0) */
      	struct mutex		buf_lock;
      	unsigned		users;
      	u8			*tx_buffer;
      	u8			*rx_buffer;
      	u32			speed_hz;
          /*connet app param*/
          struct spi_transfer	t;
          struct spi_message	m;
          struct buffer_cut *buf_cut;
          int irq_gpio;
          int irq_num; //fpga中断号
          struct mem_addr rxbuf;
          int spi_len;//spi dma 单次长度
      	bool b_workflag;//工作状态
      	bool b_printk;//调试打印状态
      	unsigned int send_data_len;//与fpga通讯一次交换数据的长度
      	struct semaphore spi_sema;//信号量 表示环形缓冲区内的可读数据量
      	int recv_buf_no;//接收到的数据块号码
      	int copy_recv_buf_no;//被复制的“接收到的数据块号码”防止被中断修改数据
      	int read_buf_no;//可读取的数据块号码
      static LIST_HEAD(device_list);
      static DEFINE_MUTEX(device_list_lock);
      static void init_p_buf_cut(struct spidev_data	*spidev);
      static unsigned bufsiz = 40960;
      module_param(bufsiz, uint, S_IRUGO);
      MODULE_PARM_DESC(bufsiz, "data bytes in biggest supported SPI message");
      /*add shiguojie */
      static inline ssize_t
      spidev_sync_write(struct spidev_data *spidev, size_t len);
      static ssize_t
      spidev_sync(struct spidev_data *spidev)
      	int status;
      	spin_lock_irq(&spidev->spi_lock);
      	spi = spidev->spi;
      	spin_unlock_irq(&spidev->spi_lock);
      	if (spi == NULL)
      		status = -ESHUTDOWN;
      		status = spi_sync(spi, &spidev->m);
          printk("fsfpgain: spidev_sync re-%d\n",status);
      	if (status == 0)
      		status = spidev->m.actual_length;
          printk("fsfpgain: spidev_sync %d-%d-%d\n",spidev->t.speed_hz,spidev->t.len,status);
      	return status;
      spidev_sync_read(struct spidev_data *spidev, size_t len)
      	struct spi_transfer	t = {
      			.rx_buf		= spidev->rx_buffer,
      			.len		= len,
      			.speed_hz	= spidev->speed_hz,
      	spi_message_init(&spidev->m);
      	spi_message_add_tail(&t, &spidev->m);
      	return spidev_sync(spidev);
      static void spi_fpga_recv(struct spidev_data* spidev)
      	int i = 0;
          int status = -1;
          struct buffer_cut *_p = spidev->buf_cut;
          int _no = spidev->recv_buf_no;
      	//gpio_set_value(fsfpgaindev.cs_gpio, 0);
          printk("fafpgain:spi_fpga_recv %d-%d",_p->recv_num,spidev->buf_cut->last_buf_len);
      	mutex_lock(&spidev->buf_lock);
      	for (i = 0; i < _p->recv_num; i++)
              spidev_sync_write(spidev,DMAC_ONE_TR_NUM);
              memcpy((void*)spidev->buf_cut->pr_buf_fpga[_no][i],spidev->rx_buffer,DMAC_ONE_TR_NUM);
      	if(spidev->buf_cut->last_buf_len)
              spidev_sync_read(spidev,spidev->buf_cut->last_buf_len);
              memcpy((void*)spidev->buf_cut->pr_buf_fpga[_no][i],spidev->rx_buffer,spidev->buf_cut->last_buf_len);
      	mutex_unlock(&spidev->buf_lock);
      static irqreturn_t irq_gpio_spi_handler(int irq, void *dev_id)
      	//printk("irq_gpio_spi_handler run\r\n");
      	return IRQ_WAKE_THREAD;
      static irqreturn_t irq_gpio_spi_thread_func(int irq, void *data)
          struct spidev_data	*spidev = (struct spidev_data*)data;
          if(spidev->b_workflag)
      	    printk("fsfpgain:irq_gpio rec buf[%d],add:%x\r\n",
              spidev->recv_buf_no,spidev->buf_cut->pr_buf_fpga[spidev->recv_buf_no][0]);
      		spi_fpga_recv(spidev);//读取一次
      		//fsfpgaindev.read_buf_no = fsfpgaindev.recv_buf_no;
      		spidev->recv_buf_no = NEXT_BUF(spidev->recv_buf_no);//取出下个环形缓冲器编号
      		up(&spidev->spi_sema);
              spidev->b_workflag = 0;//test
      	return IRQ_HANDLED;
      void setSpidev_data(struct spidev_data *spidev)
          int ret = 0;
          spidev->speed_hz = 10000000;
          spidev->t.speed_hz = spidev->speed_hz;
          spidev->b_workflag = 0;//初始化工作状态为不工作
      	spidev->send_data_len = 0;//初始化spi收发数据长度为0
      	spidev->recv_buf_no = 0;
      	spidev->read_buf_no = 0;
      	spidev->copy_recv_buf_no = 0;
          spidev->spi->mode = SPI_MODE_1;
          ret = spi_setup(spidev->spi);
          printk("fsfpgain:spi_setup re:%d\n",ret);
      //set map
          spidev->buf_cut = kzalloc(sizeof(struct buffer_cut), GFP_KERNEL);
      	printk("fsfpgain:rxvadr value:0x%lx padr:0x%x\r\n",(long)spidev->rxbuf.v_adr,spidev->rxbuf.p_adr);
      	printk("fsfpgain:rxvadr  addr:0x%lx padr:0x%x\r\n",(long)&spidev->rxbuf.v_adr,&spidev->rxbuf.p_adr);
          if((dma_set_coherent_mask(&spidev->spi->dev,DMA_BIT_MASK(32))) != 0)
              dev_err(&spidev->spi->dev,"Failed to set 32-bit DMA mask\n");
              return -ENODEV;
      	spidev->rxbuf.v_adr = dma_alloc_coherent(&spidev->spi->dev,DMAC_MAX_TRF_SIZE*DMA_RECV_MAX_NUM,&spidev->rxbuf.p_adr,GFP_KERNEL|GFP_DMA);
      //set irq
          struct device_node *nd = of_get_parent(spidev->spi->dev.of_node);
          struct device_node *child;
      	if(NULL == nd){
      		printk("fsfpgain:nd get error\r\n");
      	}else
              printk("fsfpgain:Child scan\r\n");
              for_each_child_of_node(nd, child)
                  printk("Child node name: %s\r\n", of_node_full_name(child));
                  break;
          spidev->irq_gpio  = of_get_named_gpio(child, "irq-gpio", 0);
      	if (spidev->irq_gpio < 0)
      		printk("fsfpgaindev.irq_gpio get error\r\n");
          ret = gpio_request(spidev->irq_gpio, "irq_gpio");
          if(0 == ret)
      	    printk("fsfpgain:gpio request irq gpio ok\r\n");
      	    printk("fsfpgain:gpio request ret:%d\r\n",ret);
      	gpio_direction_input(spidev->irq_gpio);
      	spidev->irq_num = gpio_to_irq(spidev->irq_gpio);
          ret = request_threaded_irq(spidev->irq_num, irq_gpio_spi_handler,irq_gpio_spi_thread_func,IRQF_TRIGGER_RISING, "irq_gpio", spidev);
          if(0 > ret)
      		printk("request_irq error\r\n");
              printk("fsfpgain irq_num:%d\n",spidev->irq_num);
          return;
      void resetSpidev_data(struct spidev_data *spidev)
      	free_irq(spidev->irq_num, spidev);
      	gpio_direction_output(spidev->irq_gpio, 0);
      	gpio_free(spidev->irq_gpio);
          printk("fsfpgain:gpio_free\r\n");
          kfree(spidev->buf_cut);
      	dma_free_coherent(&spidev->spi->dev,DMAC_MAX_TRF_SIZE*DMA_RECV_MAX_NUM,spidev->rxbuf.v_adr, spidev->rxbuf.p_adr);
      /*add shiguojie end*/
      			.tx_buf		= spidev->tx_buffer,
                  .rx_buf     = spidev->rx_buffer,//add by shiguojie
      			.len		= len,
          printk("fsfpgain:transfer len-%d speed-%d\r\n",len,spidev->speed_hz);
      /* Read-only message with current device setup */
      static ssize_t
      spidev_read(struct file *filp, char __user *buf, size_t count, loff_t *f_pos)
      	struct spidev_data	*spidev;
      	ssize_t			status = 0;
      	/* chipselect only toggles at start or end of operation */
      	if (count > bufsiz)
      		return -EMSGSIZE;
      	spidev = filp->private_data;
      	status = spidev_sync_read(spidev, count);
      	if (status > 0) {
      		unsigned long	missing;
      		missing = copy_to_user(buf, spidev->rx_buffer, status);
      		if (missing == status)
      			status = -EFAULT;
      			status = status - missing;
      	return status;
      /* Write-only message with current device setup */
      static ssize_t
      spidev_write(struct file *filp, const char __user *buf,
          int x = 0;
      	ssize_t			status = 0;
      	if (count > bufsiz)
      		return -EMSGSIZE;
          char ttempBuf[1000];
          char rtempBuf[1000];
          spidev->tx_buffer = ttempBuf;
          spidev->rx_buffer = rtempBuf;
      	missing = copy_from_user(spidev->tx_buffer, buf, count);
      	if (missing == 0)
      		spidev_sync_write(spidev, count);
      		status = -EFAULT;
          printk("fsfpgain:write read:%s\n",spidev->rx_buffer);
      	return status;
      static int spidev_message(struct spidev_data *spidev,
      		struct spi_ioc_transfer *u_xfers, unsigned n_xfers)
      	struct spi_transfer	*k_xfers;
      	struct spi_transfer	*k_tmp;
      	struct spi_ioc_transfer *u_tmp;
      	unsigned		n, total, tx_total, rx_total;
      	u8			*tx_buf, *rx_buf;
      	int			status = -EFAULT;
      	k_xfers = kcalloc(n_xfers, sizeof(*k_tmp), GFP_KERNEL);
      	if (k_xfers == NULL)
      		return -ENOMEM;
      	/* Construct spi_message, copying any tx data to bounce buffer.
      	 * We walk the array of user-provided transfers, using each one
      	 * to initialize a kernel version of the same transfer.
      	tx_buf = spidev->tx_buffer;
      	rx_buf = spidev->rx_buffer;
      	total = 0;
      	tx_total = 0;
      	rx_total = 0;
      	for (n = n_xfers, k_tmp = k_xfers, u_tmp = u_xfers;
      			n;
      			n--, k_tmp++, u_tmp++) {
      		/* Ensure that also following allocations from rx_buf/tx_buf will meet
      		 * DMA alignment requirements.
      		unsigned int len_aligned = ALIGN(u_tmp->len, ARCH_KMALLOC_MINALIGN);
      		k_tmp->len = u_tmp->len;
      		total += k_tmp->len;
      		/* Since the function returns the total length of transfers
      		 * on success, restrict the total to positive int values to
      		 * avoid the return value looking like an error.  Also check
      		 * each transfer length to avoid arithmetic overflow.
      		if (total > INT_MAX || k_tmp->len > INT_MAX) {
      			status = -EMSGSIZE;
      			goto done;
      		if (u_tmp->rx_buf) {
      			/* this transfer needs space in RX bounce buffer */
      			rx_total += len_aligned;
      			if (rx_total > bufsiz) {
      				status = -EMSGSIZE;
      				goto done;
      			k_tmp->rx_buf = rx_buf;
      			rx_buf += len_aligned;
      		if (u_tmp->tx_buf) {
      			/* this transfer needs space in TX bounce buffer */
      			tx_total += len_aligned;
      			if (tx_total > bufsiz) {
      				status = -EMSGSIZE;
      				goto done;
      			k_tmp->tx_buf = tx_buf;
      			if (copy_from_user(tx_buf, (const u8 __user *)
      						(uintptr_t) u_tmp->tx_buf,
      					u_tmp->len))
      				goto done;
      			tx_buf += len_aligned;
      		k_tmp->cs_change = !!u_tmp->cs_change;
      		k_tmp->tx_nbits = u_tmp->tx_nbits;
      		k_tmp->rx_nbits = u_tmp->rx_nbits;
      		k_tmp->bits_per_word = u_tmp->bits_per_word;
      		k_tmp->delay_usecs = u_tmp->delay_usecs;
      		k_tmp->speed_hz = u_tmp->speed_hz;
      		k_tmp->word_delay_usecs = u_tmp->word_delay_usecs;
      		if (!k_tmp->speed_hz)
      			;//k_tmp->speed_hz = spidev->speed_hz;
      #ifdef VERBOSE
      		dev_dbg(&spidev->spi->dev,
      			"  xfer len %u %s%s%s%dbits %u usec %u usec %uHz\n",
      			u_tmp->len,
      			u_tmp->rx_buf ? "rx " : "",
      			u_tmp->tx_buf ? "tx " : "",
      			u_tmp->cs_change ? "cs " : "",
      			u_tmp->bits_per_word ? : spidev->spi->bits_per_word,
      			u_tmp->delay_usecs,
      			u_tmp->word_delay_usecs,
      			u_tmp->speed_hz ? : spidev->spi->max_speed_hz);
      		spi_message_add_tail(k_tmp, &spidev->m);
      	status = spidev_sync(spidev);
      	if (status < 0)
      		goto done;
      	/* copy any rx data out of bounce buffer */
      			n;
      			if (copy_to_user((u8 __user *)
      					(uintptr_t) u_tmp->rx_buf, k_tmp->rx_buf,
      					u_tmp->len)) {
      				status = -EFAULT;
      				goto done;
      	status = total;
      done:
      	kfree(k_xfers);
      	return status;
      static struct spi_ioc_transfer *
      spidev_get_ioc_message(unsigned int cmd, struct spi_ioc_transfer __user *u_ioc,
      		unsigned *n_ioc)
      	u32	tmp;
      	/* Check type, command number and direction */
      	if (_IOC_TYPE(cmd) != SPI_IOC_MAGIC
      			|| _IOC_NR(cmd) != _IOC_NR(SPI_IOC_MESSAGE(0))
      			|| _IOC_DIR(cmd) != _IOC_WRITE)
      		return ERR_PTR(-ENOTTY);
      	tmp = _IOC_SIZE(cmd);
      	if ((tmp % sizeof(struct spi_ioc_transfer)) != 0)
      		return ERR_PTR(-EINVAL);
      	*n_ioc = tmp / sizeof(struct spi_ioc_transfer);
      	if (*n_ioc == 0)
      		return NULL;
      	/* copy into scratch area */
      	return memdup_user(u_ioc, tmp);
      static long
      spidev_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
      	u32			tmp;
      	unsigned		n_ioc;
      	struct spi_ioc_transfer	*ioc;
          int ret = 0;
          int result = 0;//信号量就绪
          unsigned long _info = 0;//arg change kernel value
          printk("fsfpgain:spidev_ioctl is run:0x%x-0x%x\r\n",cmd,arg);
      	/* Check type and command number */
      	// if (_IOC_TYPE(cmd) != SPI_IOC_MAGIC)
          //     printk("spi is SPI_IOC_MAGIC\r\n");
      	// 	return -ENOTTY;
      	/* guard against device removal before, or while,
      	 * we issue this ioctl.
          printk("fsfpgain:spidev addr0x%x-%x;spi addr0x%x-%x\r\n",*spidev,spidev,*spidev->spi,spidev->spi);
      	spi = spi_dev_get(spidev->spi);
      	if (spi == NULL)
              printk("spi is null\r\n");
      		return -ESHUTDOWN;
      	/* use the buffer lock here for triple duty:
      	 *  - prevent I/O (from us) so calling spi_setup() is safe;
      	 *  - prevent concurrent SPI_IOC_WR_* from morphing
      	 *    data fields while SPI_IOC_RD_* reads them;
      	 *  - SPI_IOC_MESSAGE needs the buffer locked "normally".
      	switch (cmd)
      		case 0x100:
      			ret = 0x20000113;
      			break;
      		case 0x309:
      			break;
      		case 0x307:
      			ret = DMAC_MAX_TRF_SIZE*DMA_RECV_MAX_NUM;
      			break;
      		case 0x306:
      			ret = DMAC_MAX_TRF_SIZE;
      			break;
      		case 0x305:
      			ret = spidev->send_data_len;
      			break;
      		case 0x304:
      			ret = copy_from_user(&_info, &arg, sizeof(unsigned long));
      			if (_info)
      				spidev->b_printk = 1;
      				spidev->b_printk = 0;
      			break;
      		case 0x303://开始工作由APP启动工作
      			spidev->read_buf_no = spidev->recv_buf_no;//重置可读数据块编号为最新接收到的数据块编号?
      			sema_init(&spidev->spi_sema,0);//初始化信号量
      			spidev->b_workflag = 1;//开始工作标志
                  printk("fafpgain start work!\r\n");
      			ret = 1;
      			break;
      		case 0x302://设置spi传输数据大小并返回大小
      			#ifdef _DEBUG
      			printk("cmd 0x302 set len:%ld-%ld return :%d\r\n",_info,arg,ret);
      			spidev->send_data_len = arg;
      			if(DMAC_MAX_TRF_SIZE < arg)
      			{//判断设置的一次接收fpga长度是否超出预设内存
      				ret = -1;
      				printk("iotcl cmd:%d arg:%ld error\r\n",cmd,_info);
      				break;
      			init_p_buf_cut(spidev);
      			break;
      		case 0x301://应用程序获取一次buf,在此判断是否有buf
      			#ifdef _DEBUG
      			printk("test jiffies:%ld\r\n", jiffies);
      			result = down_timeout(&spidev->spi_sema,jiffies+msecs_to_jiffies(60));//获取信号
      			#ifdef _DEBUG
      			printk("down_temeout result:%d\r\n", result);
      			spidev->copy_recv_buf_no = spidev->recv_buf_no;//copy一份当前值
      			#ifdef _DEBUG
      			printk("read_no:%d-copy_recv_no:%d\r\n",spidev->read_buf_no,spidev->copy_recv_buf_no);
      			if((spidev->read_buf_no != spidev->copy_recv_buf_no) && (0 == result))
      			{//right
      				if ((spidev->read_buf_no + 1) % DMA_RECV_MAX_NUM == spidev->copy_recv_buf_no)
      					ret = (spidev->read_buf_no | 0x10000);//不明白什么意思
      				}else
      					ret = spidev->read_buf_no;
      				spidev->read_buf_no = NEXT_BUF(spidev->read_buf_no);
      			else if (0 != result)
      				ret = -2;
      			else if (spidev->read_buf_no == spidev->copy_recv_buf_no)
      				ret = -3;
      			}else
      				ret = -4;
      			#ifdef _DEBUG
      			printk("0x301 ret:%d\r\n",ret);
      		    break;
      	//#ifdef _DEBUGWZG
      	printk("2121wzg cmd 0x%x  arg:%d  ret:%d  DMAC_MAX_TRF_SIZE:%d \r\n",cmd,arg,ret,DMAC_MAX_TRF_SIZE);
      	//#endif
      	spi_dev_put(spi);
      	return ret;
      #ifdef CONFIG_COMPAT
      static long
      spidev_compat_ioc_message(struct file *filp, unsigned int cmd,
      		unsigned long arg)
      	struct spi_ioc_transfer __user	*u_ioc;
      	int				retval = 0;
      	unsigned			n_ioc, n;
      	u_ioc = (struct spi_ioc_transfer __user *) compat_ptr(arg);
           printk("fsfpgain:spidev_compat_ioc_message\r\n");
      	if (spi == NULL)
      		return -ESHUTDOWN;
      	/* SPI_IOC_MESSAGE needs the buffer locked "normally" */
      	/* Check message and copy into scratch area */
      	ioc = spidev_get_ioc_message(cmd, u_ioc, &n_ioc);
      	if (IS_ERR(ioc)) {
      		retval = PTR_ERR(ioc);
      		goto done;
      	if (!ioc)
      		goto done;	/* n_ioc is also 0 */
      	/* Convert buffer pointers */
      	for (n = 0; n < n_ioc; n++) {
      		ioc[n].rx_buf = (uintptr_t) compat_ptr(ioc[n].rx_buf);
      		ioc[n].tx_buf = (uintptr_t) compat_ptr(ioc[n].tx_buf);
      	/* translate to spi_message, execute */
      	retval = spidev_message(spidev, ioc, n_ioc);
      	kfree(ioc);
      done:
      	spi_dev_put(spi);
      	return retval;
      static long
      spidev_compat_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
          printk("fsfpgain:spidev_compat_ioctl\r\n");
      	if (_IOC_TYPE(cmd) == SPI_IOC_MAGIC
      			&& _IOC_NR(cmd) == _IOC_NR(SPI_IOC_MESSAGE(0))
      			&& _IOC_DIR(cmd) == _IOC_WRITE)
      		return spidev_compat_ioc_message(filp, cmd, arg);
      	return spidev_ioctl(filp, cmd, (unsigned long)compat_ptr(arg));
      #else
      #define spidev_compat_ioctl NULL
      #endif /* CONFIG_COMPAT */
      static int spidev_open(struct inode *inode, struct file *filp)
      	int			status = -ENXIO;
      	mutex_lock(&device_list_lock);
      	list_for_each_entry(spidev, &device_list, device_entry) {
      		if (spidev->devt == inode->i_rdev) {
      			status = 0;
      			break;
      	if (status) {
      		pr_debug("spidev: nothing for minor %d\n", iminor(inode));
      		goto err_find_dev;
      	spidev->users++;
      	filp->private_data = spidev;
      	stream_open(inode, filp);
      	mutex_unlock(&device_list_lock);
      err_alloc_rx_buf:
      	kfree(spidev->tx_buffer);
      	spidev->tx_buffer = NULL;
      err_find_dev:
      	return status;
      static int spidev_release(struct inode *inode, struct file *filp)
      	int			dofree;
      	filp->private_data = NULL;
      	/* ... after we unbound from the underlying device? */
      	dofree = (spidev->spi == NULL);
      	/* last close? */
      	spidev->users--;
      	if (!spidev->users) {
      		//kfree(spidev->tx_buffer);
      		//kfree(spidev->rx_buffer);
      		spidev->rx_buffer = NULL;
      		if (dofree)
      			kfree(spidev);
      			;//spidev->speed_hz = spidev->spi->max_speed_hz;
      #ifdef CONFIG_SPI_SLAVE
      	if (!dofree)
      		spi_slave_abort(spidev->spi);
      	int i = 0;
      	int j = 0;
      	spidev->buf_cut->recv_num = spidev->send_data_len / DMAC_ONE_TR_NUM;
      	spidev->buf_cut->last_buf_len = spidev->send_data_len % DMAC_ONE_TR_NUM;
      	printk("buf_cut recv_num:%d last_buf_len:%d\r\n",spidev->buf_cut->recv_num,spidev->buf_cut->last_buf_len);
      	for (i = 0; i < DMA_RECV_MAX_NUM; i++)
      		for (j = 0; j < DMAC_CNLL_MAX_NUM; j++)
      			spidev->buf_cut->pr_buf_fpga[i][j] = spidev->rxbuf.p_adr + (i*DMAC_MAX_TRF_SIZE) + (j*DMAC_ONE_TR_NUM);
      		printk("p_rx buf[%d] dma[%3d] padd:0x%x\r\n", i,j,spidev->buf_cut->pr_buf_fpga[i][0]);
      static int fsfpgain_mmap(struct file *filp, struct vm_area_struct *vma)
      	int ret = 0;
      	#ifdef _DEBUG
      	printk("fsfpgain_mmap run,PAGE_SIZE:%ld\r\n",PAGE_SIZE);
      	printk("vm_start:%lx vm_end:%lx\r\n", vma->vm_start,vma->vm_end);
      	//dma_mmap_attrs(struct device *dev, struct vm_area_struct *vma, void *cpu_addr,
      	//      dma_addr_t dma_addr, size_t size, unsigned long attrs)
      	ret =  dma_mmap_coherent(&spidev->spi->dev, vma, (void*)spidev->rxbuf.v_adr, spidev->rxbuf.p_adr,DMAC_MAX_TRF_SIZE*DMA_RECV_MAX_NUM);
      	memset(spidev->rxbuf.v_adr, 0,DMAC_MAX_TRF_SIZE*DMA_RECV_MAX_NUM);
      	#ifdef _DEBUG
      	memcpy(spidev->rxbuf.v_adr, "Hello,mmap!", sizeof("Hello,mmap!"));//test mmap
      	printk("fsfpgain_mmap re:%d-%s\r\n",ret,spidev->rxbuf.v_adr);
      	return ret;
      static const struct file_operations spidev_fops = {
      	.owner =	THIS_MODULE,
      	/* REVISIT switch to aio primitives, so that userspace
      	 * gets more complete API coverage.  It'll simplify things
      	 * too, except for the locking.
      	.write =	spidev_write,
      	.read =		spidev_read,
      	.unlocked_ioctl = spidev_ioctl,
      	.compat_ioctl = spidev_compat_ioctl,
      	.open =		spidev_open,
      	.release =	spidev_release,
      	.llseek =	no_llseek,
          .mmap = fsfpgain_mmap,
      /* The main reason to have this class is to make mdev/udev create the
       * /dev/spidevB.C character device nodes exposing our userspace API.
       * It also simplifies memory management.
      static struct class *spidev_class;
      #ifdef CONFIG_OF
      static const struct of_device_id spidev_dt_ids[] = {
      	{ .compatible = "fsml,fsfpgain" },
      MODULE_DEVICE_TABLE(of, spidev_dt_ids);
      #ifdef CONFIG_ACPI
      /* Dummy SPI devices not to be used in production systems */
      #define SPIDEV_ACPI_DUMMY	1
      static const struct acpi_device_id spidev_acpi_ids[] = {
      	 * The ACPI SPT000* devices are only meant for development and
      	 * testing. Systems used in production should have a proper ACPI
      	 * description of the connected peripheral and they should also use
      	 * a proper driver instead of poking directly to the SPI bus.
      	{ "SPT0001", SPIDEV_ACPI_DUMMY },
      	{ "SPT0002", SPIDEV_ACPI_DUMMY },
      	{ "SPT0003", SPIDEV_ACPI_DUMMY },
      MODULE_DEVICE_TABLE(acpi, spidev_acpi_ids);
      static void spidev_probe_acpi(struct spi_device *spi)
      	const struct acpi_device_id *id;
      	if (!has_acpi_companion(&spi->dev))
      		return;
      	id = acpi_match_device(spidev_acpi_ids, &spi->dev);
      	if (WARN_ON(!id))
      		return;
      	if (id->driver_data == SPIDEV_ACPI_DUMMY)
      		dev_warn(&spi->dev, "do not use this driver in production systems!\n");
      #else
      static inline void spidev_probe_acpi(struct spi_device *spi) {}
      static int spidev_probe(struct spi_device *spi)
      	int			status;
      	unsigned long		minor;
      	 * spidev should never be referenced in DT without a specific
      	 * compatible string, it is a Linux implementation thing
      	 * rather than a description of the hardware.
      	WARN(spi->dev.of_node &&
      	     of_device_is_compatible(spi->dev.of_node, "fsfpgain"),
      	     "%pOF: buggy DT: spidev listed directly in DT\n", spi->dev.of_node);
      	spidev_probe_acpi(spi);
      	/* Allocate driver data */
      	spidev = kzalloc(sizeof(*spidev), GFP_KERNEL);
      	if (!spidev)
      		return -ENOMEM;
      	/* Initialize the driver data */
      	spidev->spi = spi;
          printk("fsfpgain:spidev addr0x%x-%x;spi addr0x%x-%x\r\n",*spidev,spidev,*spi,spi);
      	spin_lock_init(&spidev->spi_lock);
      	mutex_init(&spidev->buf_lock);
          //sema_init(&spidev->spi_sema,0);//初始化信号量
      	INIT_LIST_HEAD(&spidev->device_entry);
      	/* If we can allocate a minor number, hook up this device.
      	 * Reusing minors is fine so long as udev or mdev is working.
      	minor = find_first_zero_bit(minors, N_SPI_MINORS);
      	if (minor < N_SPI_MINORS) {
      		struct device *dev;
      		spidev->devt = MKDEV(SPIDEV_MAJOR, minor);
      		dev = device_create(spidev_class, &spi->dev, spidev->devt,
      				    spidev, "fsfpgain");
      		status = PTR_ERR_OR_ZERO(dev);
      	} else {
      		dev_dbg(&spi->dev, "no minor number available!\n");
      		status = -ENODEV;
      	if (status == 0) {
      		set_bit(minor, minors);
      		list_add(&spidev->device_entry, &device_list);
      	//spidev->speed_hz = spi->max_speed_hz;
          setSpidev_data(spidev);
      	if (status == 0)
      		spi_set_drvdata(spi, spidev);//spidev private reg
      		kfree(spidev);
      	return status;
      static int spidev_remove(struct spi_device *spi)
      	struct spidev_data	*spidev = spi_get_drvdata(spi);
      	/* prevent new opens */
      	/* make sure ops on existing fds can abort cleanly */
      	spidev->spi = NULL;
      	list_del(&spidev->device_entry);
      	device_destroy(spidev_class, spidev->devt);
      	clear_bit(MINOR(spidev->devt), minors);
          resetSpidev_data(spidev);
      	if (spidev->users == 0)
      		kfree(spidev);
      static struct spi_driver spidev_spi_driver = {
      	.driver = {
      		.name =		"fsfpgain",
      		.of_match_table = of_match_ptr(spidev_dt_ids),
      		.acpi_match_table = ACPI_PTR(spidev_acpi_ids),
      	.probe =	spidev_probe,
      	.remove =	spidev_remove,
      	/* NOTE:  suspend/resume methods are not necessary here.
      	 * We don't do anything except pass the requests to/from
      	 * the underlying controller.  The refrigerator handles
      	 * most issues; the controller driver handles the rest.
      static int __init spidev_init(void)
      	int status;
      	/* Claim our 256 reserved device numbers.  Then register a class
      	 * that will key udev/mdev to add/remove /dev nodes.  Last, register
      	 * the driver which manages those device numbers.
      	BUILD_BUG_ON(N_SPI_MINORS > 256);
      	status = register_chrdev(SPIDEV_MAJOR, "spi", &spidev_fops);
      	if (status < 0)
      		return status;
      	spidev_class = class_create(THIS_MODULE, "fsfpgain");
      	if (IS_ERR(spidev_class)) {
      		unregister_chrdev(SPIDEV_MAJOR, spidev_spi_driver.driver.name);
      		return PTR_ERR(spidev_class);
      	status = spi_register_driver(&spidev_spi_driver);
      	if (status < 0) {
      		class_destroy(spidev_class);
      	return status;
      module_init(spidev_init);
      static void __exit spidev_exit(void)
      	spi_unregister_driver(&spidev_spi_driver);
      module_exit(spidev_exit);
      MODULE_AUTHOR("shi guojie");
      MODULE_DESCRIPTION("fsml");
      MODULE_LICENSE("GPL");
      MODULE_ALIAS("v1.0.0.0");
      test_spidev.c
      #include <ctype.h>
      #include <sys/ioctl.h>
      #include <sys/types.h>
      #include <sys/stat.h>
      #include <fcntl.h>
      #include <unistd.h>
      #define DEVICE_NAME "/dev/fsfpgain"
      #define HEAD_LEN 5
      #define PKT_MAX_LEN 0x40
      #define STATUS_LEN 0x01
      #define SUNXI_OP_WRITE 0x01
      #define SUNXI_OP_READ 0x03
      #define STATUS_WRITABLE 0x02
      #define STATUS_READABLE 0x04
      #define WRITE_DELAY 200
      #define READ_DELAY 100000
      void dump_data(unsigned char *buf, unsigned int len)
          unsigned int i;
          unsigned char tmp[len*2], cnt = 0;
          for (i = 0; i < len; i++) {
              if (i%0x10== 0)
                  cnt += sprintf(tmp + cnt, "0x%08x: ", i);
              cnt += sprintf(tmp + cnt, "%02x ", buf[i]);
              if ( (i%0x10== 0x0f) || (i == (len -1)) ) {
                  printf("%s\n", tmp);
                  cnt = 0;
      void batch_rand(char *buf, unsigned int length)
          unsigned int i;
          srand(time(0));
          for(i = 0; i < length; i++) {
              *(buf + i) = rand() % 256;
      int main(int argc, const char *argv[])
          unsigned int length = 0, test_len;
          char wbuf_head[HEAD_LEN] = {SUNXI_OP_WRITE, 0x0b, 0xb0, 0xea, 0x10};
          char rbuf_head[HEAD_LEN] = {SUNXI_OP_READ, 0x00, 0x00, 0xc0, 0x00};
          char wbuf[PKT_MAX_LEN], rbuf[PKT_MAX_LEN], i, time;
          int fd, ret;
          test_len = 10;//send 10 numbers
          if (test_len > PKT_MAX_LEN) {
              printf("invalid argument, numbers must less 64B\n");
              return -1;
          wbuf_head[4] = test_len;
          rbuf_head[4] = test_len;
          for (i = 0; i < test_len; i++)
              wbuf[i] = i;
          printf("wbuf:\n");
          dump_data(wbuf, test_len);
          fd = open(DEVICE_NAME, O_RDWR);
          if (fd <= 0) {
              printf("Fail to to open %s\n", DEVICE_NAME);
              ret = -1;
              return ret;
      	char str[100];
      	memset(str,0,100);
          int size = 1000;
          char* buffer = (char*)malloc(size * sizeof(char));
          char ch = 'a';
          for (int i = 0; i < size; i++) {
              buffer[i] = ch;
              ch++;
              if (ch > 'z') {
                  ch = 'a';
          sprintf(str,"abcdefghijklmnabcdefghijklmnabcdefghijklmnabcdefghijklmnabcdefghijklmnabcdefghijklmnabcdefghijklmn");
      //for(int x=0;x<10;x++)
              write(fd, buffer, size);
          if(0)
          {//write
              if (write(fd, wbuf_head, HEAD_LEN) != HEAD_LEN) {
                  printf("W Fail to write head\n");
                  ret = -1;
                  goto err;
              } else
                  printf("W write head successful\n");
              usleep(WRITE_DELAY);
              if (write(fd, wbuf, test_len) != test_len) {
                  printf("W Fail to write data\n");
                  ret = -1;
                  goto err;
              } else
                  printf("W write data successful\n");
              usleep(READ_DELAY);
      err:
          if (fd > 0)
              close(fd);
          return ret;
      test_fsfpgain.c
      #include <ctype.h>
      #include <fcntl.h>
      #include <unistd.h>
      #include <sys/mman.h>
      #include <string.h>
      int main()
          int ret,fpdata,fpio,i,shmm_len,one_trf_len;
          long value;
          void* shmm_buf = NULL;
          char* trf_buf[DMAC_CNLL_MAX_NUM];
          char rbuf[1];
          char cstr[100] = "hello!spi world!";
          fpdata = open("/dev/fsfpgain", O_RDWR);
          if(0 > fpdata)
              printf("open error!\r\n");
              return -1;
          ret = ioctl(fpdata, 0x100, value);
          printf("100fsfpga version = 0x%x\r\n", ret);
          sleep(1);
          value = 10240;
          ret = ioctl(fpdata, 0x302, value);
          printf("302fsfpga set send-data-len = %d\r\n", ret);
          sleep(1);
          ret = ioctl(fpdata, 0x305, value);
          printf("0x305fsfpga get send-data-len = %d\r\n", ret);
          sleep(1);
          shmm_len = ioctl(fpdata, 0x307, value);
          printf("0x307shmm len = %d\r\n",shmm_len);
          sleep(1);
          one_trf_len = ioctl(fpdata, 0x306, value);
          printf("0x306one dmaspi len = %d\r\n",one_trf_len);
          sleep(1);
          printf("&shmm_buf:0x%p shmm_buf:0x%p shmm_len:%d\r\n",&shmm_buf, shmm_buf,shmm_len);
          shmm_buf = mmap(NULL, shmm_len, PROT_READ|PROT_WRITE,MAP_SHARED, fpdata,0);
          if(MAP_FAILED == shmm_buf)
              printf("mmap error!\r\n");
              return 1;
          printf("shmm_buf:%s\r\n",(char*)shmm_buf);
          sleep(1);
          ret = ioctl(fpdata, 0x303, value);
          printf("fsfpga start work = %d\r\n", ret);
          printf("sleep...\r\n");
          sleep(1);
          for(i = 0; i < DMA_RECV_MAX_NUM; i++)
              trf_buf[i] = (char*)shmm_buf + (i * one_trf_len);
              printf("trf_buf[%d]add:0x%lx\r\n",i,(long)trf_buf[i]);
          printf("trf_buf[0]:%s\r\n", trf_buf[0]);
          printf("set trf_buf ok\r\n");
          sleep(1);
          while (1)
              //memset(shmm_buf, 0 ,shmm_len);
              ret = ioctl(fpdata, 0x301, value);
              printf("ioctl 0x301 ret:0x%x-v:0x%lx\r\n",ret, value);
              printf("get data no = %x\r\n",ret);
              value = 1;
              break;
              usleep(500*1000);
          printf("munmap return:%d\r\n",munmap(shmm_buf, shmm_len));
          close(fpdata);
      4.运行故障提示
      # ./test_fafpgain
      [ 4610.396357] fsfpgain:spidev_ioctl is run:0x100-0xb6ee3b58
      [ 4610.402515] fsfpgain:spidev addr0x9900000-650065;spi addr0xc6594000-bf002018
      [ 4610.410667] 2121wzg cmd 0x100  arg:-1225901224  ret:536871187  DMAC_MAX_TRF_SIZE:32000
      100fsfpga version = 0x20000113
      [ 4611.420340] fsfpgain:spidev_ioctl is run:0x302-0x2800
      [ 4611.426075] fsfpgain:spidev addr0x9900000-660066;spi addr0xc6594000-bf002018
      [ 4611.434057] buf_cut recv_num:10 last_buf_len:240
      [ 4611.439322] p_rx buf[0] dma[ 32] padd:0x47880000
      [ 4611.444561] p_rx buf[1] dma[ 32] padd:0x47887d00
      [ 4611.449983] p_rx buf[2] dma[ 32] padd:0x4788fa00
      [ 4611.455215] p_rx buf[3] dma[ 32] padd:0x47897700
      [ 4611.460490] p_rx buf[4] dma[ 32] padd:0x4789f400
      [ 4611.465722] p_rx buf[5] dma[ 32] padd:0x478a7100
      [ 4611.470986] p_rx buf[6] dma[ 32] padd:0x478aee00
      [ 4611.476223] p_rx buf[7] dma[ 32] padd:0x478b6b00
      [ 4611.481478] p_rx buf[8] dma[ 32] padd:0x478be800
      [ 4611.486730] p_rx buf[9] dma[ 32] padd:0x478c6500
      [ 4611.491998] 2121wzg cmd 0x302  arg:10240  ret:10240  DMAC_MAX_TRF_SIZE:32000
      302fsfpga set send-data-len = 10240
      [ 4612.500269] fsfpgain:spidev_ioctl is run:0x305-0x2800
      [ 4612.506000] fsfpgain:spidev addr0x9900000-670067;spi addr0xc6594000-bf002018
      [ 4612.513984] 2121wzg cmd 0x305  arg:10240  ret:10240  DMAC_MAX_TRF_SIZE:32000
      0x305fsfpga get send-data-len = 10240
      [ 4613.522220] fsfpgain:spidev_ioctl is run:0x307-0x2800
      [ 4613.528134] fsfpgain:spidev addr0x9900000-680068;spi addr0xc6594000-bf002018
      [ 4613.536077] 2121wzg cmd 0x307  arg:10240  ret:320000  DMAC_MAX_TRF_SIZE:32000
      0x307shmm len = 320000
      [ 4614.544450] fsfpgain:spidev_ioctl is run:0x306-0x2800
      [ 4614.550210] fsfpgain:spidev addr0x9900000-690069;spi addr0xc6594000-bf002018
      [ 4614.558175] 2121wzg cmd 0x306  arg:10240  ret:32000  DMAC_MAX_TRF_SIZE:32000
      0x306one dmaspi len = 32000
      [ 4615.566559] fsfpgain:spidev addr0x9900000-6a006a;spi addr0xc6594000-bf002018
      &shmm_buf:0x0xbe84bca4 shmm_buf:0x0xb6da9000 shmm_len:320000
      shmm_buf:
      [ 4616.579679] fsfpgain:spidev_ioctl is run:0x303-0x2800
      [ 4616.585411] fsfpgain:spidev addr0x9900000-6a006a;spi addr0xc6594000-bf002018
      [ 4616.593411] fafpgain start work!
      [ 4616.597144] 2121wzg cmd 0x303  arg:10240  ret:1  DMAC_MAX_TRF_SIZE:32000
      fsfpga start work = 1
      sleep...
      [ 4616.607572] fsfpgain:irq_gpio rec buf[0],add:47880000
      [ 4616.613588] fafpgain:spi_fpga_recv 10-240
      [ 4616.613593] fsfpgain:transfer len-1000 speed-10000000
      [ 4616.623825] fsfpgain spi1.0: Bufferless transfer has length 1000
      [ 4616.630553] fsfpgain: spidev_sync re-0
      [ 4616.634722] fsfpgain: spidev_sync 10000000-0-1000
      //fsfpgain spi1.0: Bufferless transfer has length 1000是spi.c中的报错,我没有理解为什么会跳到这里面来。使用test_spidev.c来测试,就不会跳进来,在驱动层面都是调用的write函数来读写的。
      5.问题汇总:
      1)通过GPIO中断来调用spi读写函数,spi不能正常工作,只有片选,没有时钟:
      2)如何设置缓存,使得spi可以连续读取大数据量,目前片选频繁跳动,效率太低,25Hz的中断没办法完成数据读取。
      YJ00871 1 条回复 最后回复 回复 引用 分享 0
      • YJ00871
        YJ00871 LV 2 @shiguojie1989 最后由 编辑
