    SyterKit 启动 T527 失败
    • chainsx
      woshishabi LV 3 最后由 编辑
      启动 log 如下:
      [    0.000209][I]  _____     _           _____ _ _
      [    0.005537][I] |   __|_ _| |_ ___ ___|  |  |_| |_
      [    0.010874][I] |__   | | |  _| -_|  _|    -| | _|
      [    0.016216][I] |_____|_  |_| |___|_| |__|__|_|_|
      [    0.021563][I]       |___|
      [    0.026911][I] ***********************************
      [    0.032259][I]  SyterKit v0.2.4 Commit: 6223ad1
      [    0.037323][I]  github.com/YuzukiHD/SyterKit
      [    0.042668][I] ***********************************
      [    0.048013][I]  Built by: arm-none-eabi-gcc 10.3.1
      [    0.053364][I]
      [    0.055329][I] Model: Sipeed LM4B Based board.
      [    0.060283][I] Core: Arm Octa-Core Cortex-A55 v65 r2p0
      [    0.066017][I] Chip SID = 03005f3070a0482475901010508c2293
      [    0.072344][I] Chip type = T527M00X0DCH Chip Version = 2
      [    0.081250][I] PMU: Found AXP717 PMU, Addr 0x34
      [    0.087814][I] PMU: Found AXP323 PMU
      [    0.112943][I] DRAM BOOT DRIVE INFO: V0.6581
      [    0.117427][I] Set DRAM Voltage to 1160mv
      [    0.121615][I] DRAM_VCC set to 1160 mv
      [    0.167384][I] DRAM retraining ten
      [    0.177036][I] [AUTO DEBUG]32bit,2 ranks training success!
      [    0.191164][I] DRAM CLK =1200 MHZ
      [    0.194540][I] DRAM Type =8 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
      [    0.205551][I] DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 6061
      [    0.214895][I] DRAM simple test OK.
      [    0.218482][I] Init DRAM Done, DRAM Size = 4096M
      [    0.243618][I] SMHC: sdhci0 controller initialized
      [    0.254886][I] SMHC: capacity 15.5GB
      [    0.259460][I] SHMC: SD card detected
      [    0.284958][I] FATFS: read bl31.bin addr=48000000
      [    0.301008][I] FATFS: read in 11ms at 6.99MB/S
      [    0.305806][I] FATFS: read scp.bin addr=48100000
      [    0.333961][I] FATFS: read in 22ms at 8.00MB/S
      [    0.338754][I] FATFS: read extlinux/extlinux.conf addr=40020000
      [    0.346835][I] FATFS: read in 1ms at 0.10MB/S
      [    0.352771][I] FATFS: read /Image addr=40080000
      [    2.427835][I] FATFS: read in 2070ms at 8.31MB/S
      [    2.432819][I] FATFS: read /dtb/allwinner/sun55i-t527-demo.dtb addr=4a200000
      [    2.460789][I] FATFS: read in 17ms at 8.66MB/S
      [    2.465581][I] FATFS: read /uInitrd addr=4b200000
      [    3.236414][I] FATFS: read in 766ms at 8.28MB/S
      [    3.260385][I] Hit any key to stop autoboot:  0
      [    6.270448][I] ATF: Kernel addr: 0x40080000
      [    6.275027][I] ATF: Kernel DTB addr: 0x4a200000
      [    6.279997][I] disable mmu ok...
      [    6.283609][I] disable dcache ok...
      [    6.287507][I] disable icache ok...
      [    6.291408][I] free interrupt ok...
      NOTICE:  BL31: v2.5(debug):20a8ac62a
      NOTICE:  BL31: Built : 17:17:28, Jan 22 2024
      NOTICE:  BL31: No DTB found.
      nsi init ok 2022-11-08
      NOTICE:  [SCP] :wait arisc ready....
      NOTICE:  [SCP] :arisc version: []
      NOTICE:  [SCP] :arisc startup ready
      NOTICE:  [SCP] :arisc startup notify message feedback
      NOTICE:  [SCP] :sunxi-arisc driver is starting
      ERROR:   Error initializing runtime service opteed_fast
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
      [    0.000000] Linux version 5.15.123-legacy-sun55iw3 (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Fri Feb 16 09:49:32 UTC 2024
      [    0.000000] Machine model: sun55iw3
      [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
      [    0.000000] OF: reserved mem: 0x0000000000020000..0x000000000002ffff (64 KiB) nomap non-reusable mcu0iram@20000
      [    0.000000] OF: reserved mem: 0x0000000000030000..0x0000000000037fff (32 KiB) nomap non-reusable mcu0dram0@30000
      [    0.000000] OF: reserved mem: 0x0000000000038000..0x000000000003ffff (32 KiB) nomap non-reusable mcu0dram1@38000
      [    0.000000] OF: reserved mem: 0x0000000007280000..0x00000000072bffff (256 KiB) nomap non-reusable riscvsram0@7280000
      [    0.000000] OF: reserved mem: 0x00000000072c0000..0x00000000072fffff (256 KiB) nomap non-reusable riscvsram1@72c0000
      [    0.000000] OF: reserved mem: 0x0000000048000000..0x0000000048ffffff (16384 KiB) map non-reusable bl31
      [    0.000000] OF: reserved mem: 0x000000004a000000..0x000000004a9fffff (10240 KiB) nomap non-reusable dsp0ddr@4a000000
      [    0.000000] OF: reserved mem: 0x000000004ab00000..0x000000004ab0ffff (64 KiB) nomap non-reusable dsp_share_space@4ab00000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ac00000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@4ac00000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ac00000..0x000000004ac3ffff (256 KiB) nomap non-reusable vdev0buffer@4ac00000
      [    0.000000] OF: reserved mem: 0x000000004ac40000..0x000000004ac41fff (8 KiB) nomap non-reusable vdev0vring0@4ac40000
      [    0.000000] OF: reserved mem: 0x000000004ac42000..0x000000004ac43fff (8 KiB) nomap non-reusable vdev0vring1@4ac42000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ae00000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@4ae00000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ae00000..0x000000004ae3ffff (256 KiB) nomap non-reusable vdev0buffer@4ae00000
      [    0.000000] OF: reserved mem: 0x000000004ae40000..0x000000004ae41fff (8 KiB) nomap non-reusable vdev0vring0@4ae40000
      [    0.000000] OF: reserved mem: 0x000000004ae42000..0x000000004ae43fff (8 KiB) nomap non-reusable vdev0vring1@4ae42000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ae44000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node dsp0_rpbuf@4ae44000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ae44000..0x000000004ae4bfff (32 KiB) nomap non-reusable dsp0_rpbuf@4ae44000
      [    0.000000] Kernel panic - not syncing: Failed to allocate page table page
      [    0.000000] CPU: 0 PID: 0 Comm: swapper Not tainted 5.15.123-legacy-sun55iw3 #1
      [    0.000000] Hardware name: sun55iw3 (DT)
      [    0.000000] Call trace:
      [    0.000000]  dump_backtrace+0x0/0x18c
      [    0.000000]  show_stack+0x18/0x24
      [    0.000000]  dump_stack_lvl+0x7c/0xa0
      [    0.000000]  dump_stack+0x18/0x34
      [    0.000000]  panic+0x170/0x318
      [    0.000000]  early_pgtable_alloc+0x34/0xa8
      [    0.000000]  __create_pgd_mapping+0x10c/0x5b0
      [    0.000000]  map_kernel_segment+0x74/0xdc
      [    0.000000]  paging_init+0x104/0x524
      [    0.000000]  setup_arch+0x26c/0x584
      [    0.000000]  start_kernel+0x8c/0x5e4
      [    0.000000]  __primary_switched+0xa0/0xa8
      [    0.000000] ---[ end Kernel panic - not syncing: Failed to allocate page table page ]---
      设备树:
      /dts-v1/;
      #include "sun55iw3p1.dtsi"
      	board = "T527", "T527-DEMO-AXP717B";
      	compatible = "allwinner,t527", "arm,sun55iw3p1";
      	aliases {
      		pmu0 = &pmu0;
      		serial0 = &uart0;
      		hdmi = &hdmi;
      		reg-tcs0 = &reg_tcs0;
      		reg-sy0 = &reg_sy0;
      		reg-axp1530 = &reg_ext_axp1530_dcdc1;
      		tcs0 = &tcs0;
      		sy0 = &sy0;
      		axp1530 = &axp1530;
      		cpu-ext = &cpu4;
      		standby-param = &standby_param;
      		arisc-config = &arisc_config;
      		cir_param = &cir_param;
      	reg_usb0_vbus: usb0-vbus {
      		regulator-name = "usb0-vbus";
      		gpio = <&pio PB 12 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      	reg_usb1_vbus: usb1-vbus {
      		regulator-name = "usb1-vbus";
      		gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>;
      		enable-active-high;
      	standby_param: standby_param {
      		vdd-cpu = <0x00000001>;
      		vdd-cpub = <0x00000001>;
      		vdd-sys = <0x00000002>;
      		vcc-pll = <0x00000080>;
      		vcc-io  = <0x00004000>;
      		osc24m-on = <0x0>;
      	cir_param: cir_param {
      		gpio_group = <1>;      /* 0:PL 1:PM */
      		gpio_pin = <11>;
      		gpio_function = <2>;
      		count = <15>;
      		ir_power_key_code0 = <0x40>;
      		ir_addr_code0 = <0xfe01>;
      		ir_power_key_code1 = <0x1a>;
      		ir_addr_code1 = <0xfb04>;
      		ir_power_key_code2 = <0xf2>;
      		ir_addr_code2 = <0x2992>;
      		ir_power_key_code3 = <0x57>;
      		ir_addr_code3 = <0x9f00>;
      		ir_power_key_code4 = <0xdc>;
      		ir_addr_code4 = <0x4cb3>;
      		ir_power_key_code5 = <0x18>;
      		ir_addr_code5 = <0xff00>;
      		ir_power_key_code6 = <0xdc>;
      		ir_addr_code6 = <0xdd22>;
      		ir_power_key_code7 = <0x0d>;
      		ir_addr_code7 = <0xbc00>;
      		ir_power_key_code8 = <0x4d>;
      		ir_addr_code8 = <0x4040>;
      		ir_power_key_code9 = <0x08>;
      		ir_addr_code9 = <0xfb04>;
      		ir_power_key_code10 = <0x00>;
      		ir_addr_code10 = <0xfc03>;
      		ir_power_key_code11 = <0x00>;
      		ir_addr_code11 = <0xbf00>;
      		ir_power_key_code12 = <0xea>;
      		ir_addr_code12 = <0xfb04>;
      		ir_power_key_code13 = <0x42>;
      		ir_addr_code13 = <0xbf00>;
      		ir_power_key_code14 = <0x0f>;
      		ir_addr_code14 = <0xff00>;
      	arisc_config: arisc_config {
      		s_uart_config {
      			pins = "PL2", "PL3";
      			function = <2>, <2>;
      			status = "disabled";
      	reserved-memory {
      		dsp0ddr_reserved: dsp0ddr@4a000000 {
      			reg = <0x0 0x4a000000 0x0 0x00a00000>;
      			no-map;
      		riscvsram0_reserved: riscvsram0@7280000 {
      			reg = <0x0 0x07280000 0x0 0x40000>;
      			no-map;
      		riscvsram1_reserved: riscvsram1@72c0000 {
      			reg = <0x0 0x072c0000 0x0 0x40000>;
      			no-map;
      		* The name should be "vdev%dbuffer".
      		* Its size should be not less than
      		*     RPMSG_BUF_SIZE * (num of buffers in a vring) * 2
      		*   = 512 * (num of buffers in a vring) * 2
      		dsp_vdev0buffer: vdev0buffer@4ac00000 {
      			compatible = "shared-dma-pool";
      			reg = <0x0 0x4ac00000 0x0 0x40000>;
      			no-map;
      		* The name should be "vdev%dvring%d".
      		* The size of each should be not less than
      		*     PAGE_ALIGN(vring_size(num, align))
      		*   = PAGE_ALIGN(16 * num + 6 + 2 * num + (pads for align) + 6 + 8 * num)
      		* (Please refer to the vring layout in include/uapi/linux/virtio_ring.h)
      		dsp_vdev0vring0: vdev0vring0@4ac40000 {
      			reg = <0x0 0x4ac40000 0x0 0x2000>;
      			no-map;
      		dsp_vdev0vring1: vdev0vring1@4ac42000 {
      			reg = <0x0 0x4ac42000 0x0 0x2000>;
      			no-map;
      		rv_vdev0buffer: vdev0buffer@4ae00000 {
      			reg = <0x0 0x4ae00000 0x0 0x40000>;
      			no-map;
      		rv_vdev0vring0: vdev0vring0@4ae40000 {
      			reg = <0x0 0x4ae40000 0x0 0x2000>;
      			no-map;
      		rv_vdev0vring1: vdev0vring1@4ae42000 {
      			reg = <0x0 0x4ae42000 0x0 0x2000>;
      			no-map;
      		* mcu ram addr
      		mcu0iram_reserved: mcu0iram@20000 {
      			reg = <0x0 0x20000 0x0 0x10000>;
      			no-map;
      		mcu0dram0_reserved: mcu0dram0@30000 {
      			reg = <0x0 0x30000 0x0 0x8000>;
      			no-map;
      		mcu0dram1_reserved: mcu0dram1@38000 {
      			reg = <0x0 0x38000 0x0 0x8000>;
      			no-map;
      		dsp0_rpbuf_reserved: dsp0_rpbuf@4ae44000 {
      			no-map;
      			reg = <0x0 0x4ae44000 0x0 0x8000>;
      		dsp_share_space@4ab00000 {
      			no-map;
      			reg = <0x0 0x4ab00000 0x0 0x10000>;
      	rpbuf_controller0: rpbuf_controller@0 {
      		compatible = "allwinner,rpbuf-controller";
      		remoteproc = <&dsp0_rproc>;
      		ctrl_id = <0>;
      		memory-region = <&dsp0_rpbuf_reserved>;
      	edp_panel_backlight: edp_backlight {
      		compatible = "pwm-backlight";
      		brightness-levels = <
      			  0   1   2   3   4   5   6   7
      			  8   9  10  11  12  13  14  15
      			 16  17  18  19  20  21  22  23
      			 24  25  26  27  28  29  30  31
      			 32  33  34  35  36  37  38  39
      			 40  41  42  43  44  45  46  47
      			 48  49  50  51  52  53  54  55
      			 56  57  58  59  60  61  62  63
      			 64  65  66  67  68  69  70  71
      			 72  73  74  75  76  77  78  79
      			 80  81  82  83  84  85  86  87
      			 88  89  90  91  92  93  94  95
      			 96  97  98  99 100 101 102 103
      			104 105 106 107 108 109 110 111
      			112 113 114 115 116 117 118 119
      			120 121 122 123 124 125 126 127
      			128 129 130 131 132 133 134 135
      			136 137 138 139 140 141 142 143
      			144 145 146 147 148 149 150 151
      			152 153 154 155 156 157 158 159
      			160 161 162 163 164 165 166 167
      			168 169 170 171 172 173 174 175
      			176 177 178 179 180 181 182 183
      			184 185 186 187 188 189 190 191
      			192 193 194 195 196 197 198 199
      			200 201 202 203 204 205 206 207
      			208 209 210 211 212 213 214 215
      			216 217 218 219 220 221 222 223
      			224 225 226 227 228 229 230 231
      			232 233 234 235 236 237 238 239
      			240 241 242 243 244 245 246 247
      			248 249 250 251 252 253 254 255>;
      		default-brightness-level = <200>;
      		enable-gpios = <&pio PI 5 GPIO_ACTIVE_HIGH>;
      		/* power-supply = <&reg_backlight_12v>; */
      		pwms = <&pwm0 5 5000000 0>;
      	edp_panel: edp_panel {
      		compatible = "edp-general-panel";
      		power0-supply = <&reg_dcdc4>;
      		backlight = <&edp_panel_backlight>;
      		panel-timing {
      			clock-frequency = <348577920>; /* pixel clock */
      			hactive = <2560>;
      			hback-porch = <120>;
      			hfront-porch = <88>;
      			hsync-len = <32>;
      			vactive = <1600>;
      			vback-porch = <71>;
      			vfront-porch = <28>;
      			vsync-len = <5>;
      			/* hor_sync_polarity */
      			hsync-active = <1>;
      			/* ver_sync_polarity */
      			vsync-active = <1>;
      			// unused now
      			de-active = <1>;
      			pixelclk-active = <1>;
      			syncclk-active = <0>;
      			interlaced;
      			doublescan;
      			doubleclk;
      		ports {
      			#address-cells = <1>;
      			#size-cells = <0>;
      			panel_in: port@0 {
      				#size-cells = <0>;
      				reg = <0>;
      				edp_panel_in: endpoint@0 {
      					reg = <0>;
      					remote-endpoint = <&edp_panel_out>;
      	lvds_panel0_backlight: backlight0 {
      			  0   1   2   3   4   5   6   7
      		enable-gpios = <&pio PI 2 GPIO_ACTIVE_HIGH>;
      		pwms = <&pwm0 4 50000 0>;
      	lvds_panel0: panel@0 {
      		compatible = "BP101WX1";
      		reg = <0>;
      		power0-supply = <&reg_cldo3>;
      		power1-supply = <&reg_dcdc4>;
      		power2-supply = <&reg_cldo1>;
      		backlight = <&lvds_panel0_backlight>;
      		lcd_if              = <3>;
      		lcd_width           = <150>;
      		lcd_height          = <94>;
      		pinctrl-0 = <&lvds0_pins_a>;
      		pinctrl-1 = <&lvds0_pins_b>;
      		pinctrl-names = "active","sleep";
      		panel-timing {
      			clock-frequency = <74871600>; /* pixel clock */
      			hback-porch = <88>;
      			hactive = <1280>;
      			hfront-porch = <83>;
      			hsync-len = <18>;
      			vback-porch = <23>;
      			vactive = <800>;
      			vfront-porch = <37>;
      			vsync-len = <10>;
      			// unused now
      			hsync-active = <0>;
      			vsync-active = <0>;
      			de-active = <1>;
      		ports {
      			#size-cells = <0>;
      			lvds_panel0_in: port@0 {
      				#size-cells = <0>;
      				reg = <0>;
      				lvds_panel0_in_lcd0: endpoint@0 {
      					reg = <0>;
      					remote-endpoint = <&tcon0_out_panel>;
      	lvds_panel1: panel@1 {
      		reg = <1>;
      		backlight = <&lvds_panel1_backlight>;
      		lcd_if              = <3>;
      		lcd_width           = <150>;
      		lcd_height          = <94>;
      		pinctrl-0 = <&lvds2_pins_a>;
      		pinctrl-1 = <&lvds2_pins_b>;
      		panel-timing {
      			hback-porch = <88>;
      			hactive = <1280>;
      			hsync-len = <18>;
      			vback-porch = <23>;
      			vactive = <800>;
      			vsync-len = <10>;
      			// unused now
      			hsync-active = <0>;
      			vsync-active = <0>;
      			de-active = <1>;
      		ports {
      			#size-cells = <0>;
      			lvds_panel1_in: port@0 {
      				#size-cells = <0>;
      				reg = <0>;
      				lvds_panel1_in_lcd2: endpoint@0 {
      					reg = <0>;
      					remote-endpoint = <&tcon4_out_panel>;
      	lvds_panel1_backlight: backlight1 {
      			  0   1   2   3   4   5   6   7
      &de {
      	chn_cfg_mode = <3>;
      &vo0 {
      &vo1 {
      &dlcd0 {
      	panel = <&lvds_panel0>;
      	ports {
      		tcon0_out: port@1 {
      			tcon0_out_panel: endpoint@2 {
      				reg = <2>;
      				remote-endpoint = <&lvds_panel0_in_lcd0>;
      &dlcd2 {
      	panel = <&lvds_panel1>;
      	ports {
      		tcon4_out: port@1 {
      			tcon4_out_panel: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&lvds_panel1_in_lcd2>;
      &dsi0combophy {
      &dsi1combophy {
      &drm_edp {
      	edp_ssc_en = <0>;
      	edp_ssc_mode = <0>;
      	edp_psr_support = <0>;
      	edp_colordepth = <8>; /* 6/8/10/12/16 */
      	edp_color_fmt = <0>; /* 0:RGB  1: YUV444  2: YUV422 */
      	lane1_sw = <0>;
      	lane1_pre = <0>;
      	lane2_sw = <0>;
      	lane2_pre = <0>;
      	lane3_sw = <0>;
      	lane3_pre = <0>;
      	efficient_training = <0>;
      	sink_capacity_prefer = <1>;
      	edid_timings_prefer = <1>;
      	timings_fixed = <1>;
      	vcc-edp-supply = <&reg_bldo3>;
      	vdd-edp-supply = <&reg_dcdc2>;
      	panel = <&edp_panel>;
      	ports {
      		edp_out: port@1 {
      			edp_panel_out: endpoint@0 {
      				reg = <0>;
      				remote-endpoint = <&edp_panel_in>;
      &r_pio {
      	uart8_pins_a: uart8_pins@0 {
      		function = "s_uart0";
      	uart8_pins_b: uart8_pins@1 {
      		function = "gpio_in";
      	uart9_pins_a: uart9_pins@0 {
      		pins = "PM0", "PM1";
      		function = "s_uart1";
      	uart9_pins_b: uart9_pins@1 {
      	s_twi0_pins_default: s_twi0@0 {
      		pins = "PL0", "PL1";
      		function = "s_twi0";
      		drive-strength = <10>;
      		bias-pull-up;
      	s_twi0_pins_sleep: s_twi0@1 {
      	s_twi1_pins_default: s_twi1@0 {
      		pins = "PL8", "PL9";
      		function = "s_twi1";
      		bias-pull-up;
      	s_twi1_pins_sleep: s_twi1@1 {
      	s_twi2_pins_default: s_twi2@0 {
      		pins = "PL12", "PL13";
      		function = "s_twi2";
      		bias-pull-up;
      	s_twi2_pins_sleep: s_twi2@1 {
      	s_irrx_pins_default: s_irrx@0 {
      		pins = "PL11";
      		function = "s_cir";
      	s_irrx_pins_sleep: s_irrx@1 {
      		pins = "PL11";
      &pio {
      	vcc-pg-supply = <&reg_pio1_8>;
      	vcc-pf-supply = <&reg_pio1_8>;
      	vcc-pfo-supply = <&reg_pio3_3>;
      	vcc-pd-supply = <&reg_dcdc4>;
      	vcc-pe-supply = <&reg_pio1_8>;
      	vcc-pi-supply = <&reg_dcdc4>;
      	vcc-pj-supply = <&reg_dcdc4>;
      	vcc-pk-supply = <&reg_dcdc4>;
      	uart0_pins_a: uart0_pins@0 {
      		pins = "", "";
      		function = "uart0";
      	uart0_pins_b: uart0_pins@1 {
      		pins = "", "";
      	uart2_pins_a: uart2_pins@0 {
      		pins = "PB0", "PB1";
      		function = "uart2";
      	uart2_pins_b: uart2_pins@1 {
      	uart3_pins_a: uart3_pins@0 {
      		pins = "PD14", "PD15";
      		function = "uart3";
      	uart3_pins_b: uart3_pins@1 {
      	uart4_pins_a: uart4_pins@0 {
      		pins = "PD18", "PD19";
      		function = "uart4";
      	uart4_pins_b: uart4_pins@1 {
      	uart5_pins_a: uart5_pins@0 {
      		pins = "PE11", "PE12";
      		function = "uart5";
      	uart5_pins_b: uart5_pins@1 {
      	uart6_pins_a: uart6_pins@0 {
      		pins = "PI6", "PI7";
      		function = "uart6";
      	uart6_pins_b: uart6_pins@1 {
      	uart7_pins_a: uart7_pins@0 {
      		pins = "PB11", "PB12";
      		function = "uart7";
      	uart7_pins_b: uart7_pins@1 {
      	pwm0_0_pin_active: pwm0_0@0 {
      		pins = "PD23";
      		function = "pwm0_0";
      	pwm0_0_pin_sleep: pwm0_0@1 {
      		pins = "PD23";
      		bias-pull-down;
      	pwm0_1_pin_active: pwm0_1@0 {
      		pins = "PD22";
      		function = "pwm0_1";
      	pwm0_1_pin_sleep: pwm0_1@1 {
      		pins = "PD22";
      		bias-pull-down;
      	pwm0_2_pin_active: pwm0_2@0 {
      		pins = "PB11";
      		function = "pwm0_2";
      	pwm0_2_pin_sleep: pwm0_2@1 {
      		pins = "PB11";
      		bias-pull-down;
      	pwm0_3_pin_active: pwm0_3@0 {
      		pins = "PB12";
      		function = "pwm0_3";
      	pwm0_3_pin_sleep: pwm0_3@1 {
      		pins = "PB12";
      		bias-pull-down;
      	pwm0_4_pin_active: pwm0_4@0 {
      		pins = "PI3";
      		function = "pwm0_4";
      	pwm0_4_pin_sleep: pwm0_4@1 {
      		pins = "PI3";
      		bias-pull-down;
      	pwm0_5_pin_active: pwm0_5@0 {
      		pins = "PI4";
      		function = "pwm0_5";
      	pwm0_5_pin_sleep: pwm0_5@1 {
      		pins = "PI4";
      		bias-pull-down;
      	ledc_pins_a: ledc@0 {
      		pins = "PG0";
      		function = "ledc";
      	ledc_pins_b: ledc@1 {
      		pins = "PG0";
      	irrx_pins_default: irrx@0 {
      		pins = "PI8";
      		function = "cir";
      	irrx_pins_sleep: irrx@1 {
      		pins = "PI8";
      	irtx_pins_default: irtx@0 {
      		pins = "PH18";
      		function = "cir";
      	irtx_pins_sleep: irtx@1 {
      		pins = "PH18";
      	twi0_pins_default: twi0@0 {
      		pins = "PD22", "PD23";
      		function = "twi0";
      		bias-pull-up;
      	twi0_pins_sleep: twi0@1 {
      	twi1_pins_default: twi1@0 {
      		pins = "PH2", "PH3";
      		function = "twi1";
      		bias-pull-up;
      	twi1_pins_sleep: twi1@1 {
      	twi2_pins_default: twi2@0 {
      		pins = "PE1", "PE2";
      		function = "twi2";
      		drive-strength = <20>;
      		bias-pull-up;
      	twi2_pins_sleep: twi2@1 {
      	twi3_pins_default: twi3@0 {
      		pins = "PE3", "PE4";
      		function = "twi3";
      		bias-pull-up;
      	twi3_pins_sleep: twi3@1 {
      	twi4_pins_default: twi4@0 {
      		pins = "PE13", "PE14";
      		function = "twi4";
      		bias-pull-up;
      	twi4_pins_sleep: twi4@1 {
      	twi5_pins_default: twi5@0 {
      		pins = "PI8", "PI9";
      		function = "twi5";
      		bias-pull-up;
      	twi5_pins_sleep: twi5@1 {
      	owa_pins_a: owa@0 {
      		pins = "PI10";
      		function = "owa";
      		bias-disable;
      	owa_pins_b: owa@1 {
      		pins = "PI10";
      		function = "io_disabled";
      		bias-disable;
      	i2s0_pins_a: i2s0@0 {
      		pins = "PB4", "PB5", "PB6";
      		function = "i2s0";
      		bias-disable;
      	i2s0_pins_b: i2s0@1 {
      		pins = "PB4", "PB5", "PB6", "PB7", "PB8";
      		bias-disable;
      	i2s0_pins_c: i2s0@2 {
      		pins = "PB7";
      		function = "i2s0_dout";
      		bias-disable;
      	i2s0_pins_d: i2s0@3 {
      		pins = "PB8";
      		function = "i2s0_din";
      		bias-disable;
      	i2s1_pins_a: i2s1@0 {
      		pins = "PG10", "PG11", "PG12";
      		function = "i2s1";
      		bias-disable;
      	i2s1_pins_b: i2s1@1 {
      		pins = "PG10", "PG11", "PG12", "PG13", "PG14";
      		bias-disable;
      	i2s1_pins_c: i2s1@2 {
      		pins = "PG13";
      		function = "i2s1_dout";
      		bias-disable;
      	i2s1_pins_d: i2s1@3 {
      		pins = "PG14";
      		function = "i2s1_din";
      		bias-disable;
      	i2s2_pins_a: i2s2@0 {
      		pins = "PH9", "PH10";
      		function = "i2s2";
      		bias-disable;
      	i2s2_pins_b: i2s2@1 {
      		pins = "PH2", "PH3", "PH8", "PH9", "PH10", "PH11", "PH12";
      		bias-disable;
      	i2s2_pins_c: i2s2@2 {
      		pins = "PH2", "PH3", "PH12";
      		function = "i2s2_din";
      		bias-disable;
      	i2s2_pins_d: i2s2@3 {
      		pins = "PH11";
      		function = "i2s2_dout";
      		bias-disable;
      	i2s2_pins_e: i2s2@4 {
      		pins = "PH8";
      		function = "i2s2_mclk";
      		bias-disable;
      	i2s3_pins_a: i2s3@0 {
      		pins = "PF3", "PF5", "PF6";
      		function = "i2s3";
      		bias-disable;
      	i2s3_pins_b: i2s3@1 {
      		pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5", "PF6";
      		bias-disable;
      	i2s3_pins_c: i2s3@2 {
      		pins = "PF0", "PF2", "PF4";
      		function = "i2s3_din";
      		bias-disable;
      	i2s3_pins_d: i2s3@3 {
      		pins = "PF1";
      		function = "i2s3_dout";
      		bias-disable;
      	rgb24_pins_a: rgb24@0 {
      		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", \
      			"PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", \
      			"PD20", "PD21", "PD22","PD23","PD24","PD25","PD26","PD27";
      		      function = "dpss";
      		      drive-strength = <30>;
      	rgb24_pins_b: rgb24@1 {
      			"PD20", "PD21", "PD22", "PD23","PD24","PD25","PD26","PD27";
      	lvds0_pins_a: lvds0@0 {
      		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
      		      function = "lvds0";
      	lvds0_pins_b: lvds0@1 {
      	nand0_pins_default: nand0@0 {
      		pins = "PC0", "PC1", "PC2", "PC5",
      			 "PC8", "PC9", "PC10", "PC11",
      			 "PC12", "PC13", "PC14", "PC15",
      			 "PC16";
      		function = "nand0";
      	nand0_pins_rb: nand0@1 {
      		pins = "PC4", "PC6", "PC3", "PC7";
      		function = "nand0";
      		bias-pull-up;   /* only RB&CE should be pulled up */
      	nand0_pins_sleep: nand0@2 {
      		pins = "PC0", "PC1", "PC2", "PC3",
      			 "PC4", "PC5", "PC6", "PC7",
      			 "PC16";
      	gmac0_pins_default: gmac0@0 {
      		pins = "PH0", "PH1", "PH2", "PH3",
      			"PH4", "PH5", "PH6", "PH7",
      			 "PH9", "PH10","PH13","PH14",
      			  "PH15","PH16","PH17","PH18";
      		drive-strength = <40>;
      		function = "gmac0";
      		bias-pull-up;
      	gmac0_pins_sleep: gmac0@1 {
      	gmac1_pins_default: gmac1@0 {
      		pins = "PJ0", "PJ1", "PJ2", "PJ3",
      			"PJ4", "PJ5", "PJ6", "PJ7",
      			"PJ8", "PJ9", "PJ10", "PJ11",
      			"PJ12","PJ13", "PJ14", "PJ15";
      		function = "gmac1";
      		bias-pull-up;
      	gmac1_pins_sleep: gmac1@1 {
      &soc {
      	auto_print@54321 {
      		reg = <0x0 0x54321 0x0 0x0>;
      		device_type = "auto_print";
      	car_reverse: car-reverse {
      		compatible = "allwinner,sunxi-car-reverse";
      		/* video source setting*/
      		video_channel = <0>;
      		video_source = <0>;
      		format_type = <0>;
      		video_source_width = <1920>;
      		video_source_height = <1080>;
      		src_size_adaptive = <1>;
      		/* display setting */
      		overview_type = <1>;
      		screen_width = <1280>;
      		screen_height = <800>;
      		screen_size_adaptive = <1>;
      		discard_frame = <0>;
      		di_used = <0>;
      		g2d_used = <1>;
      		rotation = <0>;
      		/* auxiliary line setting */
      		auxiliary_line_type = <1>;
      		aux_angle = <0>;
      		aux_lr = <0>;
      		reverse_int_pin = <&pio PI 15 GPIO_ACTIVE_HIGH>;
      	gpio_leds {
      		compatible = "allwinner,sunxi-gpio-leds";
      		supply-num = <1>;
      		gpio1-supply = <&reg_bldo1>;
      		gpio-pins = <&pio PG 10 GPIO_ACTIVE_LOW>, <&pio PC 7 GPIO_ACTIVE_LOW>;
      		pin-names = "normal_led", "standby_led";
      		init-status = <GPIO_ACTIVE_HIGH>, <GPIO_ACTIVE_LOW>;
      	dsp0_rproc: dsp0_rproc@0 {
      		mboxes = <&msgbox 4>;
      		mbox-names = "arm-kick";
      		memory-region = <&dsp0ddr_reserved>, <&dsp_vdev0buffer>, <&dsp_vdev0vring0>, <&dsp_vdev0vring1>,
      				<&mcu0iram_reserved>, <&mcu0dram0_reserved>, <&mcu0dram1_reserved>;
      		memory-mappings =
      			/* < DA         len             PA >    */
      			/* local SRAM via external bus */
      			< 0x20000       0x20000         0x20000 >,
      			/* local SRAM via internal bus */
      			< 0x400000      0x10000         0x20000 >,
      			< 0x420000      0x8000          0x30000 >,
      			< 0x440000      0x8000          0x38000 >,
      			/* DDR front 256MB */
      			< 0x10000000    0x10000000      0x40000000 >,
      			< 0x20020000    0x10000         0x400000 >,
      			< 0x20030000    0x8000          0x420000 >,
      			< 0x20038000    0x8000          0x440000 >,
      			< 0x30000000    0x10000000      0x40000000 >,
      			/* DDR front 1GB */
      			< 0x40000000    0x40000000      0x40000000 >,
      			/* DDR front 1GB */
      			< 0x80000000    0x40000000      0x40000000 >,
      			/* DDR front 1GB */
      			< 0xC0000000    0x40000000      0x40000000 >;
      	e906_rproc: e906_rproc@7130000 {
      		mboxes = <&msgbox 8>;
      		memory-region = <&riscvsram0_reserved>, <&riscvsram1_reserved>, <&rv_vdev0buffer>, <&rv_vdev0vring0>, <&rv_vdev0vring1>;
      		memory-mappings =
      			/* < DA		len		PA >	*/
      			/* DSP RAM */
      			/* SRAM A2 */
      			< 0x40000	0x24000		0x40000 >,
      			/* DDR */
      			< 0x8000000	0x37f00000	0x8000000 >,
      			/* SRAM SPACE 0 */
      			< 0x3ffc0000	0x40000		0x07280000 >,
      			/* SRAM SPACE 1 */
      			< 0x40000000	0x40000		0x072c0000 >,
      			/* DRAM SPACE */
      			< 0x40040000	0x3ffc0000	0x40040000>;
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      	uart-supply = <&reg_cldo3>;
      &uart1 {
      &uart2 {
      	pinctrl-0 = <&uart2_pins_a>;
      	pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      &uart4 {
      	pinctrl-0 = <&uart4_pins_a>;
      	pinctrl-1 = <&uart4_pins_b>;
      &uart5 {
      	pinctrl-0 = <&uart5_pins_a>;
      	pinctrl-1 = <&uart5_pins_b>;
      &uart6 {
      	pinctrl-0 = <&uart6_pins_a>;
      	pinctrl-1 = <&uart6_pins_b>;
      &uart7 {
      	pinctrl-0 = <&uart7_pins_a>;
      	pinctrl-1 = <&uart7_pins_b>;
      &uart8 {
      	pinctrl-0 = <&uart8_pins_a>;
      	pinctrl-1 = <&uart8_pins_b>;
      &uart9 {
      	pinctrl-0 = <&uart9_pins_a>;
      	pinctrl-1 = <&uart9_pins_b>;
      &lradc {
      	key_cnt = <5>;
      	key0 = <210 0x73>;
      	key1 = <410 0x72>;
      	key2 = <590 0x8B>;
      	key3 = <750 0x1c>;
      	key4 = <880 0x66>;
      	key_debounce;
      	debounce_value = <50>;
      &irrx {
      	pinctrl-0 = <&irrx_pins_default>;
      	pinctrl-1 = <&irrx_pins_sleep>;
      &s_irrx {
      	pinctrl-0 = <&s_irrx_pins_default>;
      	pinctrl-1 = <&s_irrx_pins_sleep>;
      &irtx {
      	pinctrl-0 = <&irtx_pins_default>;
      	pinctrl-1 = <&irtx_pins_sleep>;
      &gpadc0 {
      	channel_num = <2>;
      	channel_select = <3>;
      	channel_data_select = <3>;
      	channel_compare_select = <3>;
      	channel_cld_select = <3>;
      	channel_chd_select = <3>;
      &gpadc1 {
      	channel_num = <2>;
      &pwm0_0 {
      	pinctrl-0 = <&pwm0_0_pin_active>;
      	pinctrl-1 = <&pwm0_0_pin_sleep>;
      &pwm0_1 {
      	pinctrl-0 = <&pwm0_1_pin_active>;
      	pinctrl-1 = <&pwm0_1_pin_sleep>;
      &pwm0_2 {
      	pinctrl-0 = <&pwm0_2_pin_active>;
      	pinctrl-1 = <&pwm0_2_pin_sleep>;
      &pwm0_3 {
      	pinctrl-0 = <&pwm0_3_pin_active>;
      	pinctrl-1 = <&pwm0_3_pin_sleep>;
      &pwm0_4 {
      	pinctrl-0 = <&pwm0_4_pin_active>;
      	pinctrl-1 = <&pwm0_4_pin_sleep>;
      &pwm0_5 {
      	pinctrl-0 = <&pwm0_5_pin_active>;
      	pinctrl-1 = <&pwm0_5_pin_sleep>;
      &ledc  {
      	pinctrl-0 = <&ledc_pins_a>;
      	pinctrl-1 = <&ledc_pins_b>;
      	led_count = <34>;
      	output_mode = "GRB";
      	reset_ns = <84>;
      	t1h_ns = <800>;
      	t1l_ns = <320>;
      	t0h_ns = <300>;
      	t0l_ns = <800>;
      	wait_time0_ns = <84>;
      	wait_time1_ns = <84>;
      	wait_data_time_ns = <600000>;
      &twi0 {
      	clock-frequency = <400000>;
      	pinctrl-0 = <&twi0_pins_default>;
      	pinctrl-1 = <&twi0_pins_sleep>;
      	/* For stability and backwards compatibility, we recommend setting ‘twi_drv_used’ to 1 */
      	twi_drv_used = <1>;
      	twi-supply = <&reg_dcdc4>;
      	eeprom@50 {
      		compatible = "atmel,24c16";
      		reg = <0x50>;
      	pcie_usb_phy@74 {
      		compatible = "combphy,phy74";
      		reg = <0x74>;
      	pcie_usb_phy@75 {
      		compatible = "combphy,phy75";
      		reg = <0x75>;
      	ctp {
      		reg = <0x5d>;
      		device_type = "ctp";
      		ctp_name = "gt9xxnew_ts";
      		ctp_twi_id = <0x0>;
      		ctp_twi_addr = <0x5d>;
      		ctp_screen_max_x = <0x320>;
      		ctp_screen_max_y = <0x500>;
      		ctp_revert_x_flag = <0x1>;
      		ctp_revert_y_flag = <0x1>;
      		ctp_int_port = <&pio PH 9 GPIO_ACTIVE_LOW>;
      		ctp_wakeup = <&pio PH 10 GPIO_ACTIVE_LOW>;
      		ctp-supply = <&reg_cldo2>;
      		ctp_power_ldo_vol = <3300>;
      	gt9xx {
      		compatible = "goodix,gt9xx";
      		reg = <0x5d>;
      		irq-gpios = <&pio PD 20 GPIO_ACTIVE_LOW>;
      		irq-flags = <2>;
      		reset-gpios = <&pio PD 21 GPIO_ACTIVE_LOW>;
      		vdd_ana-supply = <&reg_dcdc4>;
      		touchscreen-max-id = <11>;
      		touchscreen-size-x = <1280>;
      		touchscreen-size-y = <800>;
      		touchscreen-max-w = <512>;
      		touchscreen-max-p = <512>;
      		//touchscreen-key-map = <172>, <158>; /*KEY_HOMEPAGE=172, KEY_BACK=158,KEY_MENU=139*/
      		goodix,slide-wakeup = <0>;
      		goodix,type-a-report = <1>;
      		goodix,driver-send-cfg = <0>;
      		goodix,send-cfg-id = <0>;
      		goodix,resume-in-workqueue = <0>;
      		goodix,int-sync = <1>;
      		goodix,revert_x = <0>;
      		goodix,revert_y = <0>;
      		goodix,swap-x2y = <0>;
      		goodix,tp_idle_support = <1>;
      		goodix,esd-protect = <1>;
      		goodix,auto-update-cfg = <0>;
      		goodix,power-off-sleep = <1>;
      		goodix,pen-suppress-finger = <0>;
      		/* GT9271_Config_20221222_v67.cfg*/
      		goodix,cfg-group0 = [
      			B4 00 05 20 03 0A 3D 00 01 0A
      			28 0F 50 32 03 05 00 00 00 00
      			00 00 06 17 19 1F 14 8E 2E 99
      			2D 2F 35 11 00 00 00 1A 03 10
      			00 00 00 00 00 00 00 00 00 00
      			00 32 50 94 D5 02 07 00 00 04
      			8E 48 00 8A 4D 00 86 53 00 83
      			59 00 80 60 00 80 00 00 00 00
      			00 00 00 01 04 05 06 07 08 09
      			0C 0D 0E 0F 10 11 14 15 16 17
      			FF FF FF FF FF FF FF FF FF FF
      			FF FF 28 27 26 25 24 23 22 21
      			20 1F 1E 1C 1B 19 13 12 11 10
      			0F 0D 0C 0A 08 07 06 04 02 00
      			FF FF FF FF AB 01
      &twi1 {
      	pinctrl-0 = <&twi1_pins_default>;
      	pinctrl-1 = <&twi1_pins_sleep>;
      	twi_drv_used = <1>;
      	mir3da {
      		compatible = "allwinner,mir3da";
      		reg = <0x26>;
      		device_type = "gsensor";
      		gsensor_twi_id = <0x1>;
      		gsensor_twi_addr = <0x26>;
      		gsensor_int1 = <&pio PH 11 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
      		gsensor-supply = <&reg_cldo3>;
      		gsensor_vcc_io_val = <3300>;
      &twi2 {
      	pinctrl-0 = <&twi2_pins_default>;
      	pinctrl-1 = <&twi2_pins_sleep>;
      	twi_drv_used = <1>;
      &twi3 {
      	pinctrl-0 = <&twi3_pins_default>;
      	pinctrl-1 = <&twi3_pins_sleep>;
      	twi_drv_used = <1>;
      &twi4 {
      	pinctrl-0 = <&twi4_pins_default>;
      	pinctrl-1 = <&twi4_pins_sleep>;
      	twi_drv_used = <1>;
      &twi5 {
      	pinctrl-0 = <&twi5_pins_default>;
      	pinctrl-1 = <&twi5_pins_sleep>;
      	twi_drv_used = <1>;
      	gt9xx_secondary {
      		compatible = "goodix,gt9xx_secondary";
      		reg = <0x5d>;
      		irq-gpios = <&pio PI 13 GPIO_ACTIVE_LOW>;
      		irq-flags = <2>;
      		reset-gpios = <&pio PI 14 GPIO_ACTIVE_LOW>;
      			43 B0 04 80 07 0A 35 00 01 08
      			00 00 00 17 19 1B 14 90 2B 99
      			2F 31 8E 12 00 00 00 DA 03 10
      			00 00 00 00 00 00 00 00 00 11
      			00 29 4B 94 C5 02 07 00 00 04
      			85 2B 00 7D 31 00 77 37 00 72
      			3E 00 6F 46 00 6F 00 00 00 00
      			00 00 00 00 C0 00 00 00 00 00
      			00 00 17 16 15 14 11 10 0F 0E
      			0D 0C 09 08 07 06 05 04 01 00
      			FF FF FF FF FF FF 00 00 00 00
      			00 00 25 24 23 22 21 20 1F 1E
      			1C 1B 19 14 13 12 11 10 0F 0E
      			0D 0C 0A 08 07 06 04 02 00 FF
      			FF FF FF FF 00 00 00 00 00 00
      			00 00 00 00 73 01
      &csi_mclk3_pins_a {
      	pins = "PK13";
      	function = "ncsi";
      &csi_mclk3_pins_b {
      	pins = "PK13";
      &mipib_4lane_pins_a {
         pins = "PK6", "PK7", "PK8",
                              "PK9";
      &mipib_4lane_pins_b {
                              "PK9";
      &vind0 {
      	csi_top = <360000000>;
      	csi_isp = <300000000>;
      	vind_mclkpin-supply = <&reg_bldo3>; /* vcc-pe */
      	vind_mclkpin_vol = <1800000>;
      	vind_mcsipin-supply = <&reg_bldo3>; /* vcc-pk */
      	vind_mcsipin_vol = <1800000>;
      	vind_mipipin-supply = <&reg_bldo3>; /* vcc-mcsi */
      	vind_mipipin_vol = <1800000>;
      	csi3:csi@5823000 {
      		pinctrl-0 = <&ncsi_bt1120_pins_a>;
      		pinctrl-1 = <&ncsi_bt1120_pins_b>;
      	tdm0:tdm@5908000 {
      		work_mode = <0>;
      	isp00:isp@5900000 {
      		work_mode = <0>;
      	isp01:isp@58ffffc {
      	isp02:isp@58ffff8 {
      	isp03:isp@58ffff4 {
      	isp10:isp@4 {
      	isp20:isp@5 {
      	scaler00:scaler@5910000 {
      		work_mode = <0>;
      	scaler01:scaler@590fffc {
      	scaler02:scaler@590fff8 {
      	scaler03:scaler@590fff4 {
      	scaler10:scaler@5910400 {
      		work_mode = <0>;
      	scaler11:scaler@59103fc {
      	scaler12:scaler@59103f8 {
      	scaler13:scaler@59103f4 {
      	scaler20:scaler@5910800 {
      		work_mode = <0>;
      	scaler21:scaler@59107fc {
      	scaler22:scaler@59107f8 {
      	scaler23:scaler@59107f4 {
      	scaler30:scaler@5910c00 {
      		work_mode = <0>;
      	scaler31:scaler@5910bfc {
      	scaler32:scaler@5910bf8 {
      	scaler33:scaler@5910bf4 {
      	scaler40:scaler@16 {
      	scaler50:scaler@17 {
      	actuator0: actuator@2108180 {
      		device_type = "actuator0";
      		actuator0_name = "dw9714_act";
      		actuator0_slave = <0x18>;
      		actuator0_af_pwdn = <>;
      	flash0: flash@2108190 {
      		device_type = "flash0";
      		flash0_type = <2>;
      		flash0_en = <&r_pio PL 11 GPIO_ACTIVE_LOW>;
      		flash0_mode = <>;
      		flash0_flvdd = "";
      		flash0_flvdd_vol = <>;
      		device_id = <0>;
      	sensor0:sensor@5812000 {
      		device_type = "sensor0";
      		sensor0_mname = "tp2815_mipi";
      		sensor0_twi_cci_id = <2>;
      		sensor0_twi_addr = <0x88>;
      		sensor0_mclk_id = <0>;
      		sensor0_pos = "rear";
      		sensor0_isp_used = <0>;
      		sensor0_fmt = <0>;
      		sensor0_stby_mode = <0>;
      		sensor0_vflip = <0>;
      		sensor0_hflip = <0>;
      		sensor0_cameravdd-supply = <>;
      		sensor0_cameravdd_vol = <>;
      		sensor0_iovdd-supply = <>;
      		sensor0_iovdd_vol = <>;
      		sensor0_avdd-supply = <>;
      		sensor0_avdd_vol = <>;
      		sensor0_dvdd-supply = <>;
      		sensor0_dvdd_vol = <>;
      		sensor0_power_en = <>;
      		sensor0_reset = <&pio PK 11 GPIO_ACTIVE_LOW>;
      		sensor0_pwdn = <>;
      	sensor1:sensor@5812010 {
      		device_type = "sensor1";
      		sensor1_mname = "nvp6158";
      		sensor1_twi_cci_id = <3>;
      		sensor1_twi_addr = <0x64>;
      		sensor1_mclk_id = <3>;
      		sensor1_pos = "front";
      		sensor1_isp_used = <0>;
      		sensor1_fmt = <0>;
      		sensor1_stby_mode = <0>;
      		sensor1_vflip = <0>;
      		sensor1_hflip = <0>;
      		sensor1_iovdd-supply = <>;
      		sensor1_iovdd_vol = <>;
      		sensor1_avdd-supply = <>;
      		sensor1_avdd_vol = <>;
      		sensor1_dvdd-supply = <>;
      		sensor1_dvdd_vol = <>;
      		sensor1_power_en = <>;
      		sensor1_reset = <&pio PK 10 GPIO_ACTIVE_LOW>;
      		sensor1_pwdn = <>;
      	vinc00:vinc@5830000 {
      		vinc0_csi_sel = <0>;
      		vinc0_mipi_sel = <0>;
      		vinc0_isp_sel = <4>;
      		vinc0_isp_tx_ch = <0>;
      		vinc0_tdm_rx_sel = <0>;
      		vinc0_rear_sensor_sel = <0>;
      		vinc0_front_sensor_sel = <0>;
      		vinc0_sensor_list = <0>;
      		device_id = <0>;
      		work_mode = <0x0>;
      	vinc01:vinc@582fffc {
      		vinc1_csi_sel = <1>;
      		vinc1_mipi_sel = <2>;
      		vinc1_isp_sel = <1>;
      		vinc1_isp_tx_ch = <0>;
      		vinc1_tdm_rx_sel = <1>;
      		vinc1_rear_sensor_sel = <1>;
      		vinc1_front_sensor_sel = <1>;
      		vinc1_sensor_list = <0>;
      		device_id = <1>;
      	vinc02:vinc@582fff8 {
      		vinc2_csi_sel = <2>;
      		vinc2_mipi_sel = <0xff>;
      		vinc2_isp_sel = <2>;
      		vinc2_isp_tx_ch = <2>;
      		vinc2_tdm_rx_sel = <2>;
      		vinc2_rear_sensor_sel = <0>;
      		vinc2_front_sensor_sel = <0>;
      		vinc2_sensor_list = <0>;
      		device_id = <2>;
      	vinc03:vinc@582fff4 {
      		vinc3_csi_sel = <0>;
      		vinc3_mipi_sel = <0xff>;
      		vinc3_isp_sel = <0>;
      		vinc3_isp_tx_ch = <0>;
      		vinc3_tdm_rx_sel = <0>;
      		vinc3_rear_sensor_sel = <1>;
      		vinc3_front_sensor_sel = <1>;
      		vinc3_sensor_list = <0>;
      		device_id = <3>;
      	vinc10:vinc@5831000 {
      		vinc4_csi_sel = <0>;
      		vinc4_mipi_sel = <0>;
      		vinc4_isp_sel = <4>;
      		vinc4_isp_tx_ch = <1>;
      		vinc4_tdm_rx_sel = <0>;
      		vinc4_rear_sensor_sel = <0>;
      		vinc4_front_sensor_sel = <0>;
      		vinc4_sensor_list = <0>;
      		device_id = <4>;
      		work_mode = <0x0>;
      	vinc11:vinc@5830ffc {
      		vinc5_csi_sel = <2>;
      		vinc5_mipi_sel = <0xff>;
      		vinc5_isp_sel = <1>;
      		vinc5_isp_tx_ch = <1>;
      		vinc5_tdm_rx_sel = <1>;
      		vinc5_rear_sensor_sel = <0>;
      		vinc5_front_sensor_sel = <0>;
      		vinc5_sensor_list = <0>;
      		device_id = <5>;
      	vinc12:vinc@5830ff8 {
      		vinc6_csi_sel = <2>;
      		vinc6_mipi_sel = <0xff>;
      		vinc6_isp_sel = <0>;
      		vinc6_isp_tx_ch = <0>;
      		vinc6_tdm_rx_sel = <0>;
      		vinc6_rear_sensor_sel = <0>;
      		vinc6_front_sensor_sel = <0>;
      		vinc6_sensor_list = <0>;
      		device_id = <6>;
      	vinc13:vinc@5830ff4 {
      		vinc7_csi_sel = <2>;
      		vinc7_mipi_sel = <0xff>;
      		vinc7_isp_sel = <0>;
      		vinc7_isp_tx_ch = <0>;
      		vinc7_tdm_rx_sel = <0>;
      		vinc7_rear_sensor_sel = <0>;
      		vinc7_front_sensor_sel = <0>;
      		vinc7_sensor_list = <0>;
      		device_id = <7>;
      	vinc20:vinc@5832000 {
      		vinc8_csi_sel = <0>;
      		vinc8_mipi_sel = <0>;
      		vinc8_isp_sel = <4>;
      		vinc8_isp_tx_ch = <2>;
      		vinc8_tdm_rx_sel = <0>;
      		vinc8_rear_sensor_sel = <0>;
      		vinc8_front_sensor_sel = <0>;
      		vinc8_sensor_list = <0>;
      		device_id = <8>;
      		work_mode = <0x0>;
      	vinc21:vinc@5831ffc {
      		vinc9_csi_sel = <2>;
      		vinc9_mipi_sel = <0xff>;
      		vinc9_isp_sel = <0>;
      		vinc9_isp_tx_ch = <0>;
      		vinc9_tdm_rx_sel = <0>;
      		vinc9_rear_sensor_sel = <0>;
      		vinc9_front_sensor_sel = <0>;
      		vinc9_sensor_list = <0>;
      		device_id = <9>;
      	vinc22:vinc@5831ff8 {
      		vinc10_csi_sel = <2>;
      		vinc10_mipi_sel = <0xff>;
      		vinc10_isp_sel = <0>;
      		vinc10_isp_tx_ch = <0>;
      		vinc10_tdm_rx_sel = <0>;
      		vinc10_rear_sensor_sel = <0>;
      		vinc10_front_sensor_sel = <0>;
      		vinc10_sensor_list = <0>;
      		device_id = <10>;
      	vinc23:vinc@5831ff4 {
      		vinc11_csi_sel = <2>;
      		vinc11_mipi_sel = <0xff>;
      		vinc11_isp_sel = <0>;
      		vinc11_isp_tx_ch = <0>;
      		vinc11_tdm_rx_sel = <0>;
      		vinc11_rear_sensor_sel = <0>;
      		vinc11_front_sensor_sel = <0>;
      		vinc11_sensor_list = <0>;
      		device_id = <11>;
      	vinc30:vinc@5833000 {
      		vinc12_csi_sel = <0>;
      		vinc12_mipi_sel = <0>;
      		vinc12_isp_sel = <4>;
      		vinc12_isp_tx_ch = <3>;
      		vinc12_tdm_rx_sel = <0>;
      		vinc12_rear_sensor_sel = <0>;
      		vinc12_front_sensor_sel = <0>;
      		vinc12_sensor_list = <0>;
      		device_id = <12>;
      		work_mode = <0x0>;
      	vinc31:vinc@5832ffc {
      		vinc13_csi_sel = <2>;
      		vinc13_mipi_sel = <0xff>;
      		vinc13_isp_sel = <0>;
      		vinc13_isp_tx_ch = <0>;
      		vinc13_tdm_rx_sel = <0>;
      		vinc13_rear_sensor_sel = <0>;
      		vinc13_front_sensor_sel = <0>;
      		vinc13_sensor_list = <0>;
      		device_id = <13>;
      	vinc32:vinc@5832ff8 {
      		vinc14_csi_sel = <2>;
      		vinc14_mipi_sel = <0xff>;
      		vinc14_isp_sel = <0>;
      		vinc14_isp_tx_ch = <0>;
      		vinc14_tdm_rx_sel = <0>;
      		vinc14_rear_sensor_sel = <0>;
      		vinc14_front_sensor_sel = <0>;
      		vinc14_sensor_list = <0>;
      		device_id = <14>;
      	vinc33:vinc@5832ff4 {
      		vinc15_csi_sel = <2>;
      		vinc15_mipi_sel = <0xff>;
      		vinc15_isp_sel = <0>;
      		vinc15_isp_tx_ch = <0>;
      		vinc15_tdm_rx_sel = <0>;
      		vinc15_rear_sensor_sel = <0>;
      		vinc15_front_sensor_sel = <0>;
      		vinc15_sensor_list = <0>;
      		device_id = <15>;
      	vinc40:vinc@5834000 {
      		vinc16_csi_sel = <3>;
      		vinc16_mipi_sel = <0xff>;
      		vinc16_isp_sel = <5>;
      		vinc16_isp_tx_ch = <0>;
      		vinc16_tdm_rx_sel = <0>;
      		vinc16_rear_sensor_sel = <1>;
      		vinc16_front_sensor_sel = <1>;
      		vinc16_sensor_list = <0>;
      		device_id = <16>;
      	vinc50:vinc@5835000 {
      		vinc17_csi_sel = <3>;
      		vinc17_mipi_sel = <0xff>;
      		vinc17_isp_sel = <5>;
      		vinc17_isp_tx_ch = <1>;
      		vinc17_tdm_rx_sel = <0>;
      		vinc17_rear_sensor_sel = <1>;
      		vinc17_front_sensor_sel = <1>;
      		vinc17_sensor_list = <0>;
      		device_id = <17>;
      &twi6 {
      	pinctrl-0 = <&s_twi0_pins_default>;
      	pinctrl-1 = <&s_twi0_pins_sleep>;
      	device_type = "twi6";
      	twi_drv_used = <1>;
      	no_suspend = <1>;
      	tcs0: tcs@41 {
      		compatible = "ext,tcs4838";
      		reg = <0x41>;
      		tcs4838_delay = <0>;
      		regulator1: regulators@1 {
      			reg_tcs0: dcdc0 {
      				regulator-name = "tcs4838-dcdc0";
      				regulator-min-microvolt = <712500>;
      				regulator-max-microvolt = <1500000>;
      				regulator-ramp-delay = <520>;
      				regulator-always-on;
      				regulator-boot-on;
      			reg_tcs1: dcdc1 {
      				regulator-name = "tcs4838-dcdc1";
      		virtual-ext-dcdc0 {
      			compatible = "xpower-vregulator,ext-dcdc0";
      			dcdc0-supply = <&reg_tcs0>;
      		virtual-ext-dcdc1 {
      			compatible = "xpower-vregulator,ext-dcdc1";
      			dcdc1-supply = <&reg_tcs1>;
      	sy0: sy@60 {
      		compatible = "ext,sy8827g";
      		reg = <0x60>;
      		sy8827g_delay = <0>;
      		regulator2: regulators@2 {
      			reg_sy0: dcdc0 {
      				regulator-name = "sy8827g-dcdc0";
      				regulator-boot-on;
      			reg_sy1: dcdc1 {
      				regulator-name = "sy8827g-dcdc1";
      		virtual-ext-dcdc0 {
      			dcdc0-supply = <&reg_sy0>;
      		virtual-ext-dcdc1 {
      			dcdc1-supply = <&reg_sy1>;
      	axp1530: axp1530@36{
      		compatible = "ext,axp1530";
      		reg = <0x36>;
      		wakeup-source;
      		regulators{
      			reg_ext_axp1530_dcdc1: dcdc1 {
      				regulator-name = "axp1530-dcdc1";
      				regulator-min-microvolt = <500000>;
      				regulator-max-microvolt = <3400000>;
      				regulator-step-delay-us = <25>;
      				regulator-final-delay-us = <50>;
      			reg_ext_axp1530_dcdc2: dcdc2 {
      				regulator-name = "axp1530-dcdc2";
      				regulator-max-microvolt = <1540000>;
      				regulator-ramp-delay = <200>; /* FIXME */
      			reg_ext_axp1530_dcdc3: dcdc3 {
      				regulator-name = "axp1530-dcdc3";
      				regulator-max-microvolt = <1840000>;
      			reg_ext_axp1530_aldo1: ldo1 {
      				regulator-name = "axp1530-aldo1";
      				regulator-max-microvolt = <3500000>;
      			reg_ext_axp1530_dldo1: ldo2 {
      				regulator-name = "axp1530-dldo1";
      		virtual-ext-dcdc1 {
      			dcdc1-supply = <&reg_ext_axp1530_dcdc1>;
      		virtual-ext-dcdc2 {
      			compatible = "xpower-vregulator,ext-dcdc2";
      			dcdc2-supply = <&reg_ext_axp1530_dcdc2>;
      		virtual-ext-dcdc3 {
      			compatible = "xpower-vregulator,ext-dcdc3";
      			dcdc3-supply = <&reg_ext_axp1530_dcdc3>;
      		virtual-ext-aldo1 {
      			compatible = "xpower-vregulator,ext-aldo1";
      			aldo1-supply = <&reg_ext_axp1530_aldo1>;
      		virtual-ext-dldo1 {
      			compatible = "xpower-vregulator,ext-dldo1";
      			dldo1-supply = <&reg_ext_axp1530_dldo1>;
      	pmu0: pmu@35 {
      		compatible = "x-powers,axp2202";
      		reg = <0x35>;
      		interrupts = <0 IRQ_TYPE_LEVEL_LOW>;
      		interrupt-parent = <&nmi_intc>;
      		x-powers,drive-vbus-en;
      		pmu_reset = <0>;
      		pmu_irq_wakeup = <1>;
      		pmu_hot_shutdown = <1>;
      		pmu_over_current = <1>;
      		pmu_hot_shutdown_value = <125>;
      		wakeup-source;
      		usb_power_supply: usb_power_supply {
      			compatible = "x-powers,axp2202-usb-power-supply";
      			pmu_usbpc_vol = <4600>;
      			pmu_usbpc_cur = <500>;
      			pmu_usbad_vol = <4000>;
      			pmu_usbad_cur = <2500>;
      			pmu_usb_typec_used = <1>;
      			wakeup_usb_in;
      			wakeup_usb_out;
      			det_acin_supply = <&gpio_power_supply>;
      			pmu_acin_usbid_drv = <&pio PH 12 GPIO_ACTIVE_LOW>;
      			pmu_vbus_det_gpio = <&pio PH 13 GPIO_ACTIVE_LOW>;
      		gpio_power_supply: gpio_power_supply {
      			compatible = "x-powers,gpio-supply";
      			pmu_acin_det_gpio = <&pio PH 14 GPIO_ACTIVE_LOW>;
      			det_usb_supply = <&usb_power_supply>;
      		bat_power_supply: bat-power-supply {
      			compatible = "x-powers,axp2202-bat-power-supply";
      			param = <&axp2202_parameter>;
      			pmu_chg_ic_temp = <0>;
      			pmu_battery_rdc= <147>;
      			pmu_battery_cap = <1771>;
      			pmu_runtime_chgcur = <1000>;
      			pmu_suspend_chgcur = <1500>;
      			pmu_shutdown_chgcur = <1500>;
      			pmu_init_chgvol = <4200>;
      			pmu_battery_warning_level1 = <15>;
      			pmu_battery_warning_level2 = <0>;
      			pmu_chgled_func = <0>;
      			pmu_chgled_type = <0>;
      			pmu_bat_para1 = <0>;
      			pmu_bat_para2 = <0>;
      			pmu_bat_para3 = <0>;
      			pmu_bat_para4 = <0>;
      			pmu_bat_para5 = <0>;
      			pmu_bat_para6 = <0>;
      			pmu_bat_para7 = <2>;
      			pmu_bat_para8 = <3>;
      			pmu_bat_para9 = <4>;
      			pmu_bat_para10 = <6>;
      			pmu_bat_para11 = <9>;
      			pmu_bat_para12 = <14>;
      			pmu_bat_para13 = <26>;
      			pmu_bat_para14 = <38>;
      			pmu_bat_para15 = <49>;
      			pmu_bat_para16 = <52>;
      			pmu_bat_para17 = <56>;
      			pmu_bat_para18 = <60>;
      			pmu_bat_para19 = <64>;
      			pmu_bat_para20 = <70>;
      			pmu_bat_para21 = <77>;
      			pmu_bat_para22 = <83>;
      			pmu_bat_para23 = <87>;
      			pmu_bat_para24 = <90>;
      			pmu_bat_para25 = <95>;
      			pmu_bat_para26 = <99>;
      			pmu_bat_para27 = <99>;
      			pmu_bat_para28 = <100>;
      			pmu_bat_para29 = <100>;
      			pmu_bat_para30 = <100>;
      			pmu_bat_para31 = <100>;
      			pmu_bat_para32 = <100>;
      			pmu_bat_temp_enable = <1>;
      			pmu_jetia_en        = <1>;
      			pmu_bat_charge_ltf = <1738>; //-5
      			pmu_bat_charge_htf = <150>; //60
      			pmu_bat_shutdown_ltf = <2125>; //-10
      			pmu_bat_shutdown_htf = <130>; //65
      			pmu_jetia_cool = <1390>; //0
      			pmu_jetia_warm = <206>; //50
      			pmu_jcool_ifall = <2>;//75%
      			pmu_jwarm_ifall = <2>;//75%
      			pmu_bat_temp_para1 = <4592>; //SDNT-25
      			pmu_bat_temp_para2 = <2781>; //-15
      			pmu_bat_temp_para3 = <2125>; //-10
      			pmu_bat_temp_para4 = <1738>; //-5
      			pmu_bat_temp_para5 = <1390>;//0
      			pmu_bat_temp_para6 = <1118>; //5
      			pmu_bat_temp_para7 = <906>; //10
      			pmu_bat_temp_para8 = <606>; //20
      			pmu_bat_temp_para9 = <415>; //30
      			pmu_bat_temp_para10 = <290>; //40
      			pmu_bat_temp_para11 = <244>; //45
      			pmu_bat_temp_para12 = <206>; //50
      			pmu_bat_temp_para13 = <175>; //55
      			pmu_bat_temp_para14 = <150>; //60
      			pmu_bat_temp_para15 = <110>; //70
      			pmu_bat_temp_para16 = <83>; //80
      			wakeup_bat_out;
      			/* wakeup_bat_in; */
      			/* wakeup_bat_charging; */
      			/* wakeup_bat_charge_over; */
      			/* wakeup_low_warning1; */
      			/* wakeup_low_warning2; */
      			/* wakeup_bat_untemp_work; */
      			/* wakeup_bat_ovtemp_work; */
      			/* wakeup_bat_untemp_chg; */
      			/* wakeup_bat_ovtemp_chg; */
      		powerkey0: powerkey@0 {
      			compatible = "x-powers,axp2101-pek";
      			pmu_powkey_off_time = <6000>;
      			pmu_powkey_off_func = <0>;
      			pmu_powkey_off_en = <1>;
      			pmu_powkey_long_time = <1500>;
      			pmu_powkey_on_time = <512>;
      			wakeup_rising;
      			wakeup_falling;
      		regulator0: regulators@0 {
      			reg_dcdc1: dcdc1 {
      				regulator-name = "axp2202-dcdc1";
      				regulator-ramp-delay = <250>;
      				regulator-boot-on;
      			reg_dcdc2: dcdc2 {
      				regulator-name = "axp2202-dcdc2";
      				regulator-boot-on;
      			reg_dcdc3: dcdc3 {
      				regulator-name = "axp2202-dcdc3";
      			reg_dcdc4: dcdc4 {
      				regulator-name = "axp2202-dcdc4";
      				regulator-min-microvolt = <1000000>;
      				regulator-max-microvolt = <3700000>;
      			reg_rtcldo: rtcldo {
      				/* RTC_LDO is a fixed, always-on regulator */
      				regulator-name = "axp2202-rtcldo";
      				regulator-min-microvolt = <1800000>;
      				regulator-max-microvolt = <1800000>;
      				regulator-boot-on;
      			reg_aldo1: aldo1 {
      				regulator-name = "axp2202-aldo1";
      			reg_aldo2: aldo2 {
      				regulator-name = "axp2202-aldo2";
      			reg_aldo3: aldo3 {
      				regulator-name = "axp2202-aldo3";
      				regulator-boot-on;
      			reg_aldo4: aldo4 {
      				regulator-name = "axp2202-aldo4";
      				regulator-boot-on;
      			reg_bldo1: bldo1 {
      				regulator-name = "axp2202-bldo1";
      				regulator-boot-on;
      			reg_bldo2: bldo2 {
      				regulator-name = "axp2202-bldo2";
      				regulator-boot-on;
      			reg_bldo3: bldo3 {
      				regulator-name = "axp2202-bldo3";
      			reg_bldo4: bldo4 {
      				regulator-name = "axp2202-bldo4";
      			reg_cldo1: cldo1 {
      				regulator-name = "axp2202-cldo1";
      			reg_cldo2: cldo2 {
      				regulator-name = "axp2202-cldo2";
      			reg_cldo3: cldo3 {
      				regulator-name = "axp2202-cldo3";
      				regulator-ramp-delay = <2500>;
      				regulator-boot-on;
      			reg_cldo4: cldo4 {
      				regulator-name = "axp2202-cldo4";
      			reg_cpusldo: cpusldo {
      				/* cpus */
      				regulator-name = "axp2202-cpusldo";
      				regulator-max-microvolt = <1400000>;
      				regulator-boot-on;
      			reg_vmid: vmid {
      				regulator-name = "axp2202-vmid";
      			reg_drivevbus: drivevbus {
      				regulator-name = "axp2202-drivevbus";
      				drivevbusin-supply = <&reg_vmid>;
      		virtual-dcdc1 {
      			compatible = "xpower-vregulator,dcdc1";
      			dcdc1-supply = <&reg_dcdc1>;
      		virtual-dcdc2 {
      			compatible = "xpower-vregulator,dcdc2";
      			dcdc2-supply = <&reg_dcdc2>;
      		virtual-dcdc3 {
      			compatible = "xpower-vregulator,dcdc3";
      			dcdc3-supply = <&reg_dcdc3>;
      		virtual-dcdc4 {
      			compatible = "xpower-vregulator,dcdc4";
      			dcdc4-supply = <&reg_dcdc4>;
      		virtual-rtcldo {
      			compatible = "xpower-vregulator,rtcldo";
      			rtcldo-supply = <&reg_rtcldo>;
      		virtual-aldo1 {
      			compatible = "xpower-vregulator,aldo1";
      			aldo1-supply = <&reg_aldo1>;
      		virtual-aldo2 {
      			compatible = "xpower-vregulator,aldo2";
      			aldo2-supply = <&reg_aldo2>;
      		virtual-aldo3 {
      			compatible = "xpower-vregulator,aldo3";
      			aldo3-supply = <&reg_aldo3>;
      		virtual-aldo4 {
      			compatible = "xpower-vregulator,aldo4";
      			aldo4-supply = <&reg_aldo4>;
      		virtual-bldo1 {
      			compatible = "xpower-vregulator,bldo1";
      			bldo1-supply = <&reg_bldo1>;
      		virtual-bldo2 {
      			compatible = "xpower-vregulator,bldo2";
      			bldo2-supply = <&reg_bldo2>;
      		virtual-bldo3 {
      			compatible = "xpower-vregulator,bldo3";
      			bldo3-supply = <&reg_bldo3>;
      		virtual-bldo4 {
      			compatible = "xpower-vregulator,bldo4";
      			bldo4-supply = <&reg_bldo4>;
      		virtual-cldo1 {
      			compatible = "xpower-vregulator,cldo1";
      			cldo1-supply = <&reg_cldo1>;
      		virtual-cldo2 {
      			compatible = "xpower-vregulator,cldo2";
      			cldo2-supply = <&reg_cldo2>;
      		virtual-cldo3 {
      			compatible = "xpower-vregulator,cldo3";
      			cldo3-supply = <&reg_cldo3>;
      		virtual-cldo4 {
      			compatible = "xpower-vregulator,cldo4";
      			cldo4-supply = <&reg_cldo4>;
      		virtual-cpusldo {
      			compatible = "xpower-vregulator,cpusldo";
      			cpusldo-supply = <&reg_cpusldo>;
      		virtual-drivevbus {
      			compatible = "xpower-vregulator,drivevbus";
      			drivevbus-supply = <&reg_drivevbus>;
      		axp_gpio0: axp_gpio@0 {
      			gpio-controller;
      			#size-cells = <0>;
      			#gpio-cells = <6>;
      	axp2202_parameter:axp2202-parameter {
      		select = "battery-model";
      		battery-model {
      			parameter = /bits/ 8 <0x01 0xf5 0x40 0x00 0x1b 0x1e 0x28 0x0f
      				0x0c 0x1e 0x32 0x02 0x14 0x05 0x0a 0x04
      				0x74 0xfb 0xc8 0x0d 0x43 0x10 0x36 0xfb
      				0x46 0x01 0xea 0x0d 0x2a 0x06 0x36 0x05
      				0xf4 0x0a 0xb5 0x0f 0x42 0x0e 0xe6 0x09
      				0x9a 0x0e 0x42 0x0e 0x3b 0x04 0x2d 0x04
      				0x23 0x09 0x18 0x0e 0x09 0x0e 0x04 0x08
      				0xf7 0x0d 0xda 0x0d 0xd0 0x03 0xbb 0x03
      				0x9d 0x08 0x7f 0x0d 0x6a 0x0d 0x55 0x07
      				0xc2 0x57 0x2b 0x27 0x1e 0x0d 0x14 0x08
      				0xc5 0x98 0x7e 0x66 0x4e 0x44 0x38 0x1a
      				0x12 0x0a 0xf6 0x00 0x00 0xf6 0x00 0xf6
      				0x00 0xfb 0x00 0x00 0xfb 0x00 0x00 0xfb
      				0x00 0x00 0xf6 0x00 0x00 0xf6 0x00 0xf6
      				0x00 0x00 0xf6 0x00 0x00 0xf6 0x00 0xf6>;
      &twi7 {
      	pinctrl-0 = <&s_twi1_pins_default>;
      	pinctrl-1 = <&s_twi1_pins_sleep>;
      	twi_drv_used = <1>;
      	twi-supply = <&reg_aldo3>;
      	ac107: ac107@36 {
      		#sound-dai-cells        = <0>;
      		compatible              = "allwinner,sunxi-ac107";
      		reg                     = <0x36>;
      		pllclk-src              = "MCLK";
      		sysclk-src              = "MCLK";
      		pcm-bit-first           = "MSB";
      		frame-sync-width        = <1>;
      		rx-chmap                = <0xaaaa>;
      		ch1-dig-vol             = <160>;
      		ch2-dig-vol             = <160>;
      		ch1-pga-gain            = <26>;
      		ch2-pga-gain            = <26>;
      		status                  = "okay";
      &twi8 {
      	pinctrl-0 = <&s_twi2_pins_default>;
      	pinctrl-1 = <&s_twi2_pins_sleep>;
      	twi_drv_used = <1>;
      &sdc2 {
      	non-removable;
      	bus-width = <8>;
      	mmc-ddr-1_8v;
      	mmc-hs200-1_8v;
      	mmc-hs400-1_8v;
      	no-sdio;
      	no-sd;
      	ctl-spec-caps = <0x308>;
      	cap-mmc-highspeed;
      	sunxi-power-save-mode;
      	sunxi-dis-signal-vol-sw;
      	mmc-bootpart-noacc;
      	/*cap-hsq;*/
      	cqe-on;
      	ctl-cmdq-md = <0x2>;
      	max-frequency = <150000000>;
      	vmmc-supply = <&reg_cldo3>;
      	/*emmc io vol 3.3v*/
      	/*emmc io vol 1.8v*/
      	vqmmc-supply = <&reg_cldo1>;
      &sdc0 {
      	bus-width = <4>;
      	/*non-removable;*/
      	/*broken-cd;*/
      	/*cd-inverted*/
      	/*data3-detect;*/
      	cd-used-24M;
      	cd-set-debounce = <0x1>;
      	cap-sd-highspeed;
      	sd-uhs-sdr50;
      	sd-uhs-ddr50;
      	sd-uhs-sdr104;
      	no-sdio;
      	no-mmc;
      	/*sunxi-dis-signal-vol-sw;*/
      	ctl-spec-caps = <0x408>;
      	sunxi-dly-208M  = <0xff 1 0xff 0xff 0xff 0xff>;
      	vqmmc33sw-supply = <&reg_cldo3>;
      	vdmmc33sw-supply = <&reg_cldo3>;
      	vqmmc18sw-supply = <&reg_bldo3>;
      	vdmmc18sw-supply = <&reg_bldo3>;
      &sdc1 {
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	/*sd-uhs-sdr12*/
      	sd-uhs-sdr25;
      	sd-uhs-sdr50;
      	sd-uhs-ddr50;
      	sd-uhs-sdr104;
      	/*sunxi-power-save-mode;*/
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      &nand0 {
      	compatible = "allwinner,sun55iw3-nand";
      	device_type = "nand0";
      	//reg = <0x0 0x04011000 0x0 0x1000>;/* nand0 */
      	pinctrl-0 = <&nand0_pins_default &nand0_pins_rb>;
      	pinctrl-1 = <&nand0_pins_sleep>;
      	nand0_regulator1 = "vcc-nand";
      	nand0_regulator2 = "none";
      	nand0_cache_level = <0x55aaaa55>;
      	nand0_flush_cache_num = <0x55aaaa55>;
      	nand0_capacity_level = <0x55aaaa55>;
      	nand0_id_number_ctl = <0x55aaaa55>;
      	nand0_print_level = <0x55aaaa55>;
      	nand0_p0 = <0x55aaaa55>;
      	nand0_p1 = <0x55aaaa55>;
      	nand0_p2 = <0x55aaaa55>;
      	nand0_p3 = <0x55aaaa55>;
      	chip_code = "sun55iw3";
      &rfkill {
      	compatible = "allwinner,sunxi-rfkill";
      	chip_en;
      	power_en;
      	pinctrl-0;
      	pinctrl-names;
      	/* wlan session */
      	wlan {
      		clocks;
      		clock-names;
      		wlan_power    = "axp2202-aldo3", "axp2202-bldo1"; /* vcc-pl/vcc-pg/vcc-pm */
      		wlan_power_vol= <3300000>, <1800000>;
      		wlan_busnum   = <0x1>;
      		wlan_regon    = <&r_pio PM 1 GPIO_ACTIVE_HIGH>;
      		wlan_hostwake = <&r_pio PM 0 GPIO_ACTIVE_HIGH>;
      		wakeup-source;
      	/* bt session */
      	bt {
      		clocks;
      		clock-names;
      		bt_power    = "axp2202-aldo3", "axp2202-bldo1"; /* vcc-pl/vcc-pg/vcc-pm */
      		bt_power_vol= <3300000>, <1800000>;
      		bt_rst_n      = <&r_pio PM 2 GPIO_ACTIVE_LOW>;
      &addr_mgt {
      	type_addr_wifi = <0x0>;
      	type_addr_bt   = <0x0>;
      	type_addr_eth  = <0x0>;
      	status         = "okay";
      &btlpm {
      	uart_index  = <0x1>;
      	bt_wake     = <&r_pio PM 3 GPIO_ACTIVE_HIGH>;
      	bt_hostwake = <&r_pio PM 4 GPIO_ACTIVE_HIGH>;
      	wakeup-source;
      	status      = "okay";
      &usbc0 {
      	device_type = "usbc0";
      	usb_port_type = <0x2>;
      	usb_detect_type = <0x1>;
      	usb_detect_mode = <0x0>;
      	usb_id_gpio = <&r_pio PL 10 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	usb_det_vbus_gpio = <&r_pio PM 5 GPIO_ACTIVE_HIGH>;
      	enable-active-high;
      	detvbus_io-supply = <&reg_bldo1>;
      	usb_regulator_io = "nocare";
      	usb_wakeup_suspend = <0>;
      	usb_luns = <3>;
      	usb_serial_unique = <0>;
      	rndis_wceis = <1>;
      &udc {
      	det_vbus_supply = <&usb_power_supply>;
      	phy_range = <0x153>;
      &ehci0 {
      	drvvbus-supply = <&reg_usb0_vbus>;
      &ohci0 {
      &usbc1 {
      	device_type = "usbc1";
      &ehci1 {
      &ohci1 {
      &usbc2 {
      	device_type = "usbc2";
      &xhci2 {
      	dr_mode = "host";
      &u2phy {
      &combophy {
      	resets = <&ccu RST_BUS_PCIE_USB3>;
      	phy_use_sel = <1>; /* 0:PCIE; 1:USB3 */
      &gpu {
      	gpu_idle = <1>;
      	dvfs_status = <1>;
      	mali-supply = <&reg_dcdc2>;
      disp init configuration
      set fbX_height to lcd_x)
                         in display.
      &disp {
              screen0_to_lcd_index     = <0>;
              screen1_output_mode      = <5>;
              screen1_to_lcd_index     = <2>;
              display_device_num          = <3>;
              primary_display_type        = "LCD";
              primary_de_id               = <0>;
              primary_framebuffer_width   = <1280>;
              primary_framebuffer_height  = <800>;
              primary_dpix                = <213>;
              primary_dpiy                = <213>;
              extend0_display_type        = "HDMI";
              extend0_de_id               = <1>;
              extend0_framebuffer_width   = <1920>;
              extend0_framebuffer_height  = <1080>;
              extend0_dpix                = <160>;
              extend0_dpiy                = <160>;
              extend1_display_type        = "DP";
              extend1_de_id               = <1>;
              extend1_framebuffer_width   = <1920>;
              extend1_framebuffer_height  = <1080>;
              extend1_dpix                = <160>;
              extend1_dpiy                = <160>;
              fb_format                = <0>;
              fb_num                   = <2>;
              /*<disp channel layer zorder>*/
              fb0_map                  = <0 1 0 16>;
              fb0_width                = <1280>;
              fb0_height               = <800>;
              fb1_map                  = <1 1 0 16>;
              fb1_width                = <1920>;
              fb1_height               = <1080>;
              fb2_map                  = <1 0 0 16>;
              fb2_width                = <1280>;
              fb2_height               = <720>;
              fb3_map                  = <1 1 0 16>;
              fb3_width                = <300>;
              fb3_height               = <300>;
              chn_cfg_mode             = <3>;
              /* dual display clock constraints:
                 1. two tcons cannot share a parent clock.
                 2. when dsi uses ccu clock, combphy and corresponding tcon use the
                  same parent clock.
              assigned-clocks = <&ccu CLK_DE>,
                        <&ccu CLK_VO0_TCONLCD0>,
                        <&ccu CLK_VO0_TCONLCD1>,
                        <&ccu CLK_VO1_TCONLCD0>,
                        <&ccu CLK_TCONTV>,
                        <&ccu CLK_TCONTV1>,
                        <&ccu CLK_COMBPHY0>,
                        <&ccu CLK_COMBPHY1>,
                        <&ccu CLK_DSI0>,
                        <&ccu CLK_DSI1>,
                        <&ccu CLK_EDP>;
              assigned-clock-parents = <&ccu CLK_PLL_VIDEO3_4X>,
                               <&ccu CLK_PLL_VIDEO0_4X>,
                               <&ccu CLK_PLL_VIDEO1_4X>,
                               <&ccu CLK_PLL_PERI0_150M>,
                               <&ccu CLK_PLL_VIDEO1_4X>;
              assigned-clock-rates = <600000000>;
      	pwms = <&pwm0 4 5000000 0>, <&pwm0 5 5000000 0>;
      	pwm-names = "lvds0_backlight", "lvds2_backlight";
              power-domains = <&pd1 A523_PCK_DE>, <&pd1 A523_PCK_VO0>, <&pd1 A523_PCK_VO1>;
              power-domain-names = "pd_de", "pd_vo0", "pd_vo1";
      #if 1
      &lcd0 {
              lcd_used            = <1>;
              lcd_driver_name     = "bp101wx1";
              lcd_backlight       = <50>;
              lcd_if              = <3>;
              lcd_x               = <1280>;
              lcd_y               = <800>;
              lcd_width           = <150>;
              lcd_height          = <94>;
              lcd_dclk_freq       = <75>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <4>;
              lcd_pwm_pol         = <0>;
              lcd_pwm_max_limit   = <255>;
      	lcd_pwm_name	    = "lvds0_backlight";
              lcd_hbp             = <88>;
              lcd_ht              = <1451>;
              lcd_hspw            = <18>;
              lcd_vbp             = <23>;
              lcd_vt              = <860>;
              lcd_vspw            = <10>;
              lcd_lvds_if         = <0>;
              lcd_lvds_colordepth = <0>;
              lcd_lvds_mode       = <0>;
              lcd_frm             = <0>;
              lcd_hv_clk_phase    = <0>;
              lcd_hv_sync_polarity= <0>;
              lcd_gamma_en        = <0>;
              lcd_bright_curve_en = <0>;
              lcd_cmap_en         = <0>;
              lcd_fsync_en        = <0>;
      	lcd_fsync_act_time  = <1000>;
      	lcd_fsync_dis_time  = <1000>;
              lcd_fsync_pol       = <0>;
      	lcd_start_delay     = <5>;
              deu_mode            = <0>;
              lcdgamma4iep        = <22>;
              smart_color         = <90>;
              lcd_pin_power = "cldo3";
              lcd_power = "dcdc4";
              lcd_power1 = "cldo1";
              lcd_gpio_0 = <&pio PI 2 GPIO_ACTIVE_HIGH>; //reset
              lcd_bl_en        = <&pio PI 2 GPIO_ACTIVE_HIGH>;
              lvds0_pinctrl-0 = <&lvds0_pins_a>;
              lvds0_pinctrl-1 = <&lvds0_pins_b>;
              lvds1_pinctrl-0 = <&lvds1_pins_a>;
              lvds1_pinctrl-1 = <&lvds1_pins_b>;
              dsi0_pinctrl-0 = <&dsi0_4lane_pins_a>;
              dsi0_pinctrl-1 = <&dsi0_4lane_pins_b>;
              dual_dsi_pinctrl-0 = <&dsi0_4lane_pins_a>, <&dsi1_4lane_pins_a>;
              dual_dsi_pinctrl-1 = <&dsi0_4lane_pins_b>, <&dsi1_4lane_pins_b>;
              dual_lvds0_pinctrl-0 = <&lvds0_pins_a>, <&lvds1_pins_a>;
              dual_lvds0_pinctrl-1 = <&lvds0_pins_b>, <&lvds1_pins_b>;
      #else
      &lcd0 {
      	/* dual-lvds */
      	lcd_used            = <1>;
      	status              = "okay";
      	lcd_if              = <3>;
      	lcd_x               = <1920>;
      	lcd_y               = <1080>;
      	lcd_width           = <476>;
      	lcd_height          = <268>;
      	lcd_dclk_freq       = <149>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <4>;
      	lcd_pwm_pol         = <0>;
      	lcd_hbp             = <148>;
      	lcd_ht              = <2200>;
      	lcd_hspw            = <44>;
      	lcd_vbp             = <36>;
      	lcd_vt              = <1125>;
      	lcd_vspw            = <5>;
      	lcd_lvds_if         = <1>;
      	lcd_frm             = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_cmap_en         = <0>;
      	lcd_fsync_en        = <0>;
      	deu_mode            = <0>;
      	smart_color         = <90>;
      #if 1
      &lcd1 {
              lcd_used            = <1>;
              status              = "okay";
              lcd_driver_name     = "SQ101D_Q5DI404_84H501";
              lcd_backlight       = <200>;
              lcd_if              = <4>;
              lcd_x               = <1200>;
              lcd_y               = <1920>;
              lcd_width           = <136>;
              lcd_height          = <217>;
              lcd_dclk_freq       = <157>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <0>;
              lcd_pwm_pol         = <0>;
              lcd_hbp             = <50>;
              lcd_ht              = <1330>;
              lcd_hspw            = <10>;
              lcd_vbp             = <20>;
              lcd_vt              = <1960>;
              lcd_vspw            = <4>;
              lcd_frm             = <0>;
              lcd_gamma_en        = <0>;
              lcd_cmap_en         = <0>;
              deu_mode            = <0>;
              smart_color         = <90>;
              lcd_dsi_if          = <0>;
              lcd_dsi_lane        = <4>;
              lcd_dsi_format      = <0>;
              lcd_dsi_te          = <0>;
              lcd_dsi_eotp        = <0>;
              lcd_power1 = "cldo4";
              lcd_power2 = "cldo1";
              // lcd_gpio_2 = <&pio PD 22 GPIO_ACTIVE_HIGH>; //reset
              pinctrl-0 = <&dsi1_4lane_pins_a>;
              pinctrl-1 = <&dsi1_4lane_pins_b>;
              // lcd_bl_en = <&pio PH 16 GPIO_ACTIVE_HIGH>;
              lcd_bl_0_percent        = <5>;
      #else
      &lcd1 {
              lcd_used            = <1>;
              lcd_if              = <0>;
              lcd_x               = <800>;
              lcd_y               = <480>;
              lcd_width           = <150>;
              lcd_height          = <94>;
              lcd_dclk_freq       = <48>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <7>;
              lcd_pwm_pol         = <0>;
              lcd_hbp             = <55>;
              lcd_ht              = <1240>;
              lcd_hspw            = <20>;
              lcd_vbp             = <35>;
              lcd_vt              = <650>;
              lcd_vspw            = <10>;
              lcd_lvds_if         = <0>;
              lcd_lvds_colordepth = <1>;
              lcd_frm             = <1>;
              lcd_gamma_en        = <0>;
              lcd_cmap_en         = <0>;
              deu_mode            = <0>;
              smart_color         = <90>;
      &lcd2 {
      	lcd_used            = <0>;
              lcd_if              = <3>;
              lcd_x               = <1280>;
              lcd_y               = <800>;
              lcd_width           = <150>;
              lcd_height          = <94>;
              lcd_pwm_used        = <1>;
              lcd_pwm_ch          = <5>;
              lcd_pwm_pol         = <0>;
      	lcd_pwm_name        = "lvds2_backlight";
              lcd_hbp             = <88>;
              lcd_ht              = <1451>;
              lcd_hspw            = <18>;
              lcd_vbp             = <23>;
              lcd_vt              = <860>;
              lcd_vspw            = <10>;
              lcd_lvds_if         = <0>;
              lcd_frm             = <0>;
              lcd_gamma_en        = <0>;
              lcd_cmap_en         = <0>;
              lcd_fsync_en        = <0>;
              deu_mode            = <0>;
              smart_color         = <90>;
              /* lvds_power & other interface power */
              lcd_bl_en  = <&pio PI 5 GPIO_ACTIVE_HIGH>;
              lvds2_pinctrl-0 = <&lvds2_pins_a>;
              lvds2_pinctrl-1 = <&lvds2_pins_b>;
              lvds3_pinctrl-0 = <&lvds3_pins_a>;
              lvds3_pinctrl-1 = <&lvds3_pins_b>;
              dual_lvds1_pinctrl-0 = <&lvds2_pins_a>, <&lvds3_pins_a>;
              dual_lvds1_pinctrl-1 = <&lvds2_pins_b>, <&lvds3_pins_b>;
      &edp0 {
      	// use if hardware reset pin is need
      	/* edp_hw_reset_pin = <&pio PH XX GPIO_ACTIVE_LOW>; */
      	edp_ssc_en = <0>;
      	edp_ssc_mode = <0>;
      	lane0_sw = <0>;
      	lane0_pre = <0>;
      	lane1_sw = <0>;
      	lane1_pre = <0>;
      	lane2_sw = <0>;
      	lane2_pre = <0>;
      	lane3_sw = <0>;
      	lane3_pre = <0>;
      	edp_panel_used = <1>;
      	edp_panel_driver = "general_panel";
      	edp_bl_en = <&pio PI 5 GPIO_ACTIVE_HIGH>;
      	edp_pwm_used = <1>;
      	edp_pwm_ch = <5>;
      	edp_pwm_freq = <50000>;
      	edp_pwm_pol = <0>;
      	edp_default_backlight = <200>;
      	edp_panel_power_0 = "edp-panel";
      	edp-panel-supply = <&reg_dcdc4>;
      &ve {
      	ve-supply = <&reg_dcdc2>;
      	enable_setup_ve_freq       = <0>;   /* default disable */
      	ve_freq_value              = <624>; /* setup to 624MHz */
      /* audio dirver module -> audio codec */
      &codec {
      	tx-hub-en;
      	rx-sync-en;
      	dac-vol		= <63>;		/* default value:63 range:0->63 */
      	dacl-vol	= <160>;	/* default value:160 range:0->255 */
      	dacr-vol	= <160>;	/* default value:160 range:0->255 */
      	adc1-vol	= <160>;	/* default value:160 range:0->255 */
      	adc2-vol	= <160>;	/* default value:160 range:0->255 */
      	adc3-vol	= <160>;	/* default value:160 range:0->255 */
      	lineout-gain	= <31>;		/* default value:31 range:0->31 */
      	hpout-gain	= <7>;		/* default value:7 range:0->7 */
      	adc1-gain	= <31>;		/* default value:31 range:0->31 */
      	adc2-gain	= <31>;		/* default value:31 range:0->31 */
      	adc3-gain	= <31>;		/* default value:31 range:0->31 */
      	/* to do: avcc-1.8 vdd33-3.3 cpvin-1.8 */
      	avcc-external;
      	avcc-supply	= <&reg_aldo4>;
      	avcc-vol	= <1800000>;
      	vdd-external;
      	vdd-supply	= <&reg_cldo3>;
      	vdd-vol		= <3300000>;
      	cpvin-external;
      	cpvin-supply	= <&reg_bldo3>;
      	cpvin-vol	= <1800000>;
      	pa-pin-max	= <1>;
      	pa-pin-0	= <&r_pio PL 7 GPIO_ACTIVE_HIGH>;
      	pa-pin-level-0	= <1>;
      	pa-pin-msleep-0	= <0>;
      	jack-det-level		= <0>;
      	jack-det-threshold	= <8>;
      	jack-det-debouce-time	= <250>;
      	/* extcon                  = <&usb_power_supply>;
      	 * jack-swpin-mic-sel      = <&pio PH 8 GPIO_ACTIVE_HIGH>;
      	 * jack-swpin-hp-en        = <&pio PH 15 GPIO_ACTIVE_HIGH>;
      	 * jack-swpin-hp-sel       = <&pio PH 11 GPIO_ACTIVE_HIGH>;
      	 * jack-swmode-hp-off      = <0x00>;
      	 * jack-swmode-hp-usb      = <0x11>;
      	 * jack-swmode-hp-audio    = <0x10>;
      	 * jack-det-level          = <1>;
      	 * jack-det-threshold      = <8>;
      	 * jack-det-debouce-time   = <250>;
      &codec_plat {
      &codec_mach {
      	soundcard-mach,jack-support = <1>;
      	soundcard-mach,cpu {
      		sound-dai = <&codec_plat>;
      	soundcard-mach,codec {
      		sound-dai = <&codec>;
      &hdmi_codec {
      	extcon = <&hdmi>;
      &edp_codec {
      /* audio dirver module -> owa */
      &owa_plat {
      	pinctrl-used;
      	pinctrl-0	= <&owa_pins_a>;
      	pinctrl-1	= <&owa_pins_b>;
      	tx-hub-en;
      	status		= "okay";
      &owa_mach {
      	status		= "okay";
      		sound-dai = <&owa_plat>;
      /* audio dirver module -> DMIC */
      &dmic_plat {
      	rx-chmap	= <0x76543210>;
      	data-vol	= <0xB0>;
      	rxdelaytime	= <0>;
      	/* pinctrl-used; */
      	/* pinctrl-names	= "default","sleep"; */
      	/* pinctrl-0	= <&dmic_pins_a>; */
      	/* pinctrl-1	= <&dmic_pins_b>; */
      	rx-sync-en;
      &dmic_mach {
      		sound-dai = <&dmic_plat>;
      /* audio dirver module -> I2S/PCM */
      &i2s0_plat {
      	tdm-num		= <0>;
      	tx-pin		= <0>;
      	rx-pin		= <0>;
      	pinctrl-used;
      	pinctrl-0	= <&i2s0_pins_a &i2s0_pins_c &i2s0_pins_d>;
      	pinctrl-1	= <&i2s0_pins_b>;
      	tx-hub-en;
      	rx-sync-en;
      	status		= "okay";
      &i2s0_mach {
      	soundcard-mach,format		= "i2s";
      	soundcard-mach,frame-master	= <&i2s0_cpu>;
      	soundcard-mach,bitclock-master	= <&i2s0_cpu>;
      	/* soundcard-mach,frame-inversion; */
      	/* soundcard-mach,bitclock-inversion; */
      	soundcard-mach,slot-num		= <2>;
      	soundcard-mach,slot-width	= <32>;
      	soundcard-mach,capture-only;
      	status		= "okay";
      	i2s0_cpu: soundcard-mach,cpu {
      		sound-dai = <&i2s0_plat>;
      		/* note: pll freq = 24.576M or 22.5792M * pll-fs */
      		soundcard-mach,pll-fs	= <1>;
      		/* note:
      		 * mclk freq = mclk-fs * 12.288M or 11.2896M	(when mclk-fp ture)
      		 * mclk freq = mclk-fs * pcm rate		(when mclk-fp false)
      		soundcard-mach,mclk-fp;
      		soundcard-mach,mclk-fs	= <1>;
      	i2s0_codec: soundcard-mach,codec {
      		sound-dai               = <&ac107>;
      &i2s1_plat {
      	tdm-num		= <1>;
      	tx-pin		= <0>;
      	rx-pin		= <0>;
      	/* pinctrl-used; */
      	/* pinctrl-names= "default","sleep"; */
      	/* pinctrl-0	= <&i2s1_pins_a &i2s1_pins_c &i2s1_pins_d>; */
      	/* pinctrl-1	= <&i2s1_pins_b>; */
      	tx-hub-en;
      	rx-sync-en;
      &i2s1_mach {
      	soundcard-mach,frame-master	= <&i2s1_cpu>;
      	soundcard-mach,bitclock-master	= <&i2s1_cpu>;
      	i2s1_cpu: soundcard-mach,cpu {
      		sound-dai = <&i2s1_plat>;
      		soundcard-mach,mclk-fs	= <0>;
      	i2s1_codec: soundcard-mach,codec {
      &i2s2_plat {
      	tdm-num		= <2>;
      	tx-pin		= <0 1 2 3>;
      /* e.g.
       * tx-pin0-map0 = <0xFEDC3210> -> tx_pin_map[0][0] (Dout0-slot[7:0]  map channel[15:12, 3:0])
       * tx-pin0-map1 = <0x3210FEDC> -> tx_pin_map[0][1] (Dout0-slot[15:8] map channel[3:0, 15:12])
       * tx-pin1-map0 = <0x76543210> -> tx_pin_map[1][0] (Dout1-slot[7:0]  map channel[7:0])
      	tx-pin0-map0	= <0x76543210>;
      	tx-pin0-map1	= <0xFEDCBA98>;
      	tx-pin1-map0	= <0x76543210>;
      	tx-pin1-map1	= <0xFEDCBA98>;
      	tx-pin2-map0	= <0x76543210>;
      	tx-pin2-map1	= <0xFEDCBA98>;
      	tx-pin3-map0	= <0x76543210>;
      	tx-pin3-map1	= <0xFEDCBA98>;
      	rx-pin		= <0>;
      	/* pinctrl-used; */
      	/* pinctrl-0	= <&i2s2_pins_a &i2s2_pins_c &i2s2_pins_d &i2s2_pins_e>; */
      	/* pinctrl-1	= <&i2s2_pins_b>; */
      	tx-hub-en;
      	rx-sync-en;
      	/* edp not need dai-type */
      	dai-type = "hdmi";
      	status		= "okay";
      &i2s2_mach {
      	soundcard-mach,frame-master	= <&i2s2_cpu>;
      	soundcard-mach,bitclock-master	= <&i2s2_cpu>;
      	soundcard-mach,playback-only;
      	status		= "okay";
      	i2s2_cpu: soundcard-mach,cpu {
      		sound-dai = <&i2s2_plat>;
      		/* edp mclk: 512fs */
      	i2s2_codec: soundcard-mach,codec {
      		sound-dai               = <&hdmi_codec>;
      &i2s3_plat {
      	tdm-num		= <3>;
      	tx-pin		= <0>;
      	rx-pin		= <0>;
      	/* pinctrl-used; */
      	/* pinctrl-0	= <&i2s3_pins_a &i2s3_pins_c &i2s3_pins_d>; */
      	/* pinctrl-1	= <&i2s3_pins_b>; */
      	tx-hub-en;
      	rx-sync-en;
      &i2s3_mach {
      	soundcard-mach,frame-master	= <&i2s3_cpu>;
      	soundcard-mach,bitclock-master	= <&i2s3_cpu>;
      	i2s3_cpu: soundcard-mach,cpu {
      		sound-dai = <&i2s3_plat>;
      	i2s3_codec: soundcard-mach,codec {
      &hdmi {
      	hdmi_used = <1>;
      	hdmi_power0 = "bldo3";
      	hdmi_power_cnt = <1>;
      	hdmi_hdcp_enable = <1>;
      	hdmi_hdcp22_enable = <0>;
      	hdmi_cts_compatibility = <0>;
      	hdmi_cec_support = <1>;
      	hdmi_cec_super_standby = <1>;
      	hdmi_skip_bootedid = <1>;
      	ddc_en_io_ctrl = <0>;
      	power_io_ctrl = <0>;
      &cpu0 {
      	cpu-supply = <&reg_dcdc1>;
      &dsufreq {
      	dsu-supply = <&reg_dcdc1>;
      &mdio0 {
      	gmac0_phy0: ethernet-phy@1 {
      		reset-gpios = <&pio PH 8 GPIO_ACTIVE_LOW>;
      &gmac0 {
      	phy-mode = "rgmii";
      	pinctrl-0 = <&gmac0_pins_default>;
      	pinctrl-1 = <&gmac0_pins_sleep>;
      	sunxi,phy-clk-type = <0>;
      	tx-delay = <3>;
      	rx-delay = <4>;
      	gmac3v3-supply = <&reg_cldo3>;
      &gmac1 {
      	phy-mode = "rgmii";
      	pinctrl-0 = <&gmac1_pins_default>;
      	pinctrl-1 = <&gmac1_pins_sleep>;
      	aw,soc-phy25m;
      	tx-delay = <3>;
      	rx-delay = <4>;
      	dwmac3v3-supply = <&reg_cldo3>;
      	mdio1: mdio1@1 {
      		gmac1_phy0: ethernet-phy@1 {
      			reset-gpios = <&pio PI 5 GPIO_ACTIVE_LOW>;
      &npu {
      	npu-supply = <&reg_ext_axp1530_dcdc3>;
      &dram {
      	dram_para00 = <0x00000000>;
      	dram_para01 = <0x00000000>;
      	dram_para02 = <0x00000000>;
      	dram_para03 = <0x00000000>;
      	dram_para04 = <0x00000000>;
      	dram_para05 = <0x00000000>;
      	dram_para06 = <0x00000000>;
      	dram_para07 = <0x00000000>;
      	dram_para08 = <0x00000000>;
      	dram_para09 = <0x00000000>;
      	dram_para10 = <0x00000000>;
      	dram_para11 = <0x00000000>;
      	dram_para12 = <0x00000000>;
      	dram_para13 = <0x00000000>;
      	dram_para14 = <0x00000000>;
      	dram_para15 = <0x00000000>;
      	dram_para16 = <0x00000000>;
      	dram_para17 = <0x00000000>;
      	dram_para18 = <0x00000000>;
      	dram_para19 = <0x00000000>;
      	dram_para20 = <0x00000000>;
      	dram_para21 = <0x00000000>;
      	dram_para22 = <0x00000000>;
      	dram_para23 = <0x00000000>;
      	dram_para24 = <0x00000000>;
      	dram_para25 = <0x00000000>;
      	dram_para26 = <0x00000000>;
      	dram_para27 = <0x00000000>;
      	dram_para28 = <0x00000000>;
      	dram_para29 = <0x00000000>;
      	dram_para30 = <0x00000000>;
      	dram_para31 = <0x00000000>;
      	dram_para32 = <0x00000000>;
      	dram_para33 = <0x00000000>;
      	dram_para34 = <0x00000000>;
      	dram_para35 = <0x00000000>;
      	dram_para36 = <0x00000000>;
      	dram_para37 = <0x00000000>;
      	dram_para38 = <0x00000000>;
      	dram_para39 = <0x00000000>;
      	dram_para40 = <0x00000000>;
      	dram_para41 = <0x00000000>;
      	dram_para42 = <0x00000000>;
      	dram_para43 = <0x00000000>;
      	dram_para44 = <0x00000000>;
      	dram_para45 = <0x00000000>;
      	dram_para46 = <0x00000000>;
      	dram_para47 = <0x00000000>;
      	dram_para48 = <0x00000000>;
      	dram_para49 = <0x00000000>;
      	dram_para50 = <0x00000000>;
      	dram_para51 = <0x00000000>;
      	dram_para52 = <0x00000000>;
      	dram_para53 = <0x00000000>;
      	dram_para54 = <0x00000000>;
      	dram_para55 = <0x00000000>;
      	dram_para56 = <0x00000000>;
      	dram_para57 = <0x00000000>;
      	dram_para58 = <0x00000000>;
      	dram_para59 = <0x00000000>;
      	dram_para60 = <0x00000000>;
      	dram_para61 = <0x00000000>;
      	dram_para62 = <0x00000000>;
      	dram_para63 = <0x00000000>;
      	dram_para64 = <0x00000000>;
      	dram_para65 = <0x00000000>;
      	dram_para66 = <0x00000000>;
      	dram_para67 = <0x00000000>;
      	dram_para68 = <0x00000000>;
      	dram_para69 = <0x00000000>;
      	dram_para70 = <0x00000000>;
      	dram_para71 = <0x00000000>;
      	dram_para72 = <0x00000000>;
      	dram_para73 = <0x00000000>;
      	dram_para74 = <0x00000000>;
      	dram_para75 = <0x00000000>;
      	dram_para76 = <0x00000000>;
      	dram_para77 = <0x00000000>;
      	dram_para78 = <0x00000000>;
      	dram_para79 = <0x00000000>;
      	dram_para80 = <0x00000000>;
      	dram_para81 = <0x00000000>;
      	dram_para82 = <0x00000000>;
      	dram_para83 = <0x00000000>;
      	dram_para84 = <0x00000000>;
      	dram_para85 = <0x00000000>;
      	dram_para86 = <0x00000000>;
      	dram_para87 = <0x00000000>;
      	dram_para88 = <0x00000000>;
      	dram_para89 = <0x00000000>;
      	dram_para90 = <0x00000000>;
      	dram_para91 = <0x00000000>;
      	dram_para92 = <0x00000000>;
      	dram_para93 = <0x00000000>;
      	dram_para94 = <0x00000000>;
      	dram_para95 = <0x00000000>;
      &cpul_thermal_zone {
      	cpul_trips: trips {
      		cpul_crit: cpu_crit@0 {
      			temperature = <115000>;
      			type = "critical";
      			hysteresis = <0>;
      &cpub_thermal_zone {
      	cpub_trips: trips {
      		cpub_crit: cpu_crit@0 {
      			type = "critical";
      			hysteresis = <0>;
      &gpu_thermal_zone {
      	gpu_trips: trips {
      		gpu_crit: gpu_crit@0 {
      			type = "critical";
      			hysteresis = <0>;
        awwwwa LV 8 最后由 编辑
        修改设备树,增加memory和chosen
        /dts-v1/;
        #include "sun55iw3p1.dtsi"
        	board = "T527", "T527-LM4B";
        	compatible = "allwinner,t527", "arm,sun55iw3p1";
        	chosen {
        		bootargs = "earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 init=/init cma=64M";
        	memory@40000000 {
        		device_type = "memory";
        		reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
        	aliases {
        		pmu0 = &pmu0;
        		serial0 = &uart0;
        		hdmi = &hdmi;
        		reg-axp1530 = &reg_ext_axp1530_dcdc1;
        		axp1530 = &axp1530;
        		cpu-ext = &cpu4;
        		standby-param = &standby_param;
        		arisc-config = &arisc_config;
        		cir_param = &cir_param;
        	reg_usb0_vbus: usb0-vbus {
        		regulator-name = "usb0-vbus";
        		gpio = <&pio PB 12 GPIO_ACTIVE_HIGH>;
        		enable-active-high;
        	reg_usb1_vbus: usb1-vbus {
        		regulator-name = "usb1-vbus";
        		gpio = <&pio PB 3 GPIO_ACTIVE_HIGH>;
        		enable-active-high;
        	standby_param: standby_param {
        		vdd-cpu = <0x00000001>;
        		vdd-cpub = <0x00000001>;
        		vdd-sys = <0x00000002>;
        		vcc-pll = <0x00000080>;
        		vcc-io  = <0x00004000>;
        		osc24m-on = <0x0>;
        	cir_param: cir_param {
        		gpio_group = <1>;      /* 0:PL 1:PM */
        		gpio_pin = <11>;
        		gpio_function = <2>;
        		count = <15>;
        		ir_power_key_code0 = <0x40>;
        		ir_addr_code0 = <0xfe01>;
        		ir_power_key_code1 = <0x1a>;
        		ir_addr_code1 = <0xfb04>;
        		ir_power_key_code2 = <0xf2>;
        		ir_addr_code2 = <0x2992>;
        		ir_power_key_code3 = <0x57>;
        		ir_addr_code3 = <0x9f00>;
        		ir_power_key_code4 = <0xdc>;
        		ir_addr_code4 = <0x4cb3>;
        		ir_power_key_code5 = <0x18>;
        		ir_addr_code5 = <0xff00>;
        		ir_power_key_code6 = <0xdc>;
        		ir_addr_code6 = <0xdd22>;
        		ir_power_key_code7 = <0x0d>;
        		ir_addr_code7 = <0xbc00>;
        		ir_power_key_code8 = <0x4d>;
        		ir_addr_code8 = <0x4040>;
        		ir_power_key_code9 = <0x08>;
        		ir_addr_code9 = <0xfb04>;
        		ir_power_key_code10 = <0x00>;
        		ir_addr_code10 = <0xfc03>;
        		ir_power_key_code11 = <0x00>;
        		ir_addr_code11 = <0xbf00>;
        		ir_power_key_code12 = <0xea>;
        		ir_addr_code12 = <0xfb04>;
        		ir_power_key_code13 = <0x42>;
        		ir_addr_code13 = <0xbf00>;
        		ir_power_key_code14 = <0x0f>;
        		ir_addr_code14 = <0xff00>;
        	arisc_config: arisc_config {
        		s_uart_config {
        			pins = "PL2", "PL3";
        			function = <2>, <2>;
        			status = "disabled";
        	edp_panel_backlight: edp_backlight {
        		compatible = "pwm-backlight";
        		brightness-levels = <
        			  0   1   2   3   4   5   6   7
        			  8   9  10  11  12  13  14  15
        			 16  17  18  19  20  21  22  23
        			 24  25  26  27  28  29  30  31
        			 32  33  34  35  36  37  38  39
        			 40  41  42  43  44  45  46  47
        			 48  49  50  51  52  53  54  55
        			 56  57  58  59  60  61  62  63
        			 64  65  66  67  68  69  70  71
        			 72  73  74  75  76  77  78  79
        			 80  81  82  83  84  85  86  87
        			 88  89  90  91  92  93  94  95
        			 96  97  98  99 100 101 102 103
        			104 105 106 107 108 109 110 111
        			112 113 114 115 116 117 118 119
        			120 121 122 123 124 125 126 127
        			128 129 130 131 132 133 134 135
        			136 137 138 139 140 141 142 143
        			144 145 146 147 148 149 150 151
        			152 153 154 155 156 157 158 159
        			160 161 162 163 164 165 166 167
        			168 169 170 171 172 173 174 175
        			176 177 178 179 180 181 182 183
        			184 185 186 187 188 189 190 191
        			192 193 194 195 196 197 198 199
        			200 201 202 203 204 205 206 207
        			208 209 210 211 212 213 214 215
        			216 217 218 219 220 221 222 223
        			224 225 226 227 228 229 230 231
        			232 233 234 235 236 237 238 239
        			240 241 242 243 244 245 246 247
        			248 249 250 251 252 253 254 255>;
        		default-brightness-level = <200>;
        		enable-gpios = <&pio PI 5 GPIO_ACTIVE_HIGH>;
        		/* power-supply = <&reg_backlight_12v>; */
        		pwms = <&pwm0 5 5000000 0>;
        	edp_panel: edp_panel {
        		compatible = "edp-general-panel";
        		power0-supply = <&reg_dcdc4>;
        		backlight = <&edp_panel_backlight>;
        		panel-timing {
        			clock-frequency = <348577920>; /* pixel clock */
        			hactive = <2560>;
        			hback-porch = <120>;
        			hfront-porch = <88>;
        			hsync-len = <32>;
        			vactive = <1600>;
        			vback-porch = <71>;
        			vfront-porch = <28>;
        			vsync-len = <5>;
        			/* hor_sync_polarity */
        			hsync-active = <1>;
        			/* ver_sync_polarity */
        			vsync-active = <1>;
        			// unused now
        			de-active = <1>;
        			pixelclk-active = <1>;
        			syncclk-active = <0>;
        			interlaced;
        			doublescan;
        			doubleclk;
        		ports {
        			#address-cells = <1>;
        			#size-cells = <0>;
        			panel_in: port@0 {
        				#size-cells = <0>;
        				reg = <0>;
        				edp_panel_in: endpoint@0 {
        					reg = <0>;
        					remote-endpoint = <&edp_panel_out>;
        	lvds_panel0_backlight: backlight0 {
        			  0   1   2   3   4   5   6   7
        		enable-gpios = <&pio PI 2 GPIO_ACTIVE_HIGH>;
        		pwms = <&pwm0 4 50000 0>;
        	lvds_panel0: panel@0 {
        		compatible = "BP101WX1";
        		reg = <0>;
        		power0-supply = <&reg_cldo3>;
        		power1-supply = <&reg_dcdc4>;
        		power2-supply = <&reg_cldo1>;
        		backlight = <&lvds_panel0_backlight>;
        		lcd_if              = <3>;
        		lcd_width           = <150>;
        		lcd_height          = <94>;
        		pinctrl-names = "active","sleep";
        		panel-timing {
        			clock-frequency = <74871600>; /* pixel clock */
        			hback-porch = <88>;
        			hactive = <1280>;
        			hfront-porch = <83>;
        			hsync-len = <18>;
        			vback-porch = <23>;
        			vactive = <800>;
        			vfront-porch = <37>;
        			vsync-len = <10>;
        			// unused now
        			hsync-active = <0>;
        			vsync-active = <0>;
        			de-active = <1>;
        		ports {
        			#size-cells = <0>;
        			lvds_panel0_in: port@0 {
        				#size-cells = <0>;
        				reg = <0>;
        				lvds_panel0_in_lcd0: endpoint@0 {
        					reg = <0>;
        					remote-endpoint = <&tcon0_out_panel>;
        	lvds_panel1: panel@1 {
        		reg = <1>;
        		backlight = <&lvds_panel1_backlight>;
        		lcd_if              = <3>;
        		lcd_width           = <150>;
        		lcd_height          = <94>;
        		panel-timing {
        			hback-porch = <88>;
        			hactive = <1280>;
        			hsync-len = <18>;
        			vback-porch = <23>;
        			vactive = <800>;
        			vsync-len = <10>;
        			// unused now
        			hsync-active = <0>;
        			vsync-active = <0>;
        			de-active = <1>;
        		ports {
        			#size-cells = <0>;
        			lvds_panel1_in: port@0 {
        				#size-cells = <0>;
        				reg = <0>;
        				lvds_panel1_in_lcd2: endpoint@0 {
        					reg = <0>;
        					remote-endpoint = <&tcon4_out_panel>;
        	lvds_panel1_backlight: backlight1 {
        			  0   1   2   3   4   5   6   7
        &de {
        	chn_cfg_mode = <3>;
        &vo0 {
        &vo1 {
        &tv0 {
        &dlcd0 {
        	panel = <&lvds_panel0>;
        	ports {
        		tcon0_out: port@1 {
        			tcon0_out_panel: endpoint@2 {
        				reg = <2>;
        				remote-endpoint = <&lvds_panel0_in_lcd0>;
        &dlcd2 {
        	panel = <&lvds_panel1>;
        	ports {
        		tcon4_out: port@1 {
        			tcon4_out_panel: endpoint@0 {
        				reg = <0>;
        				remote-endpoint = <&lvds_panel1_in_lcd2>;
        &dsi0combophy {
        &dsi1combophy {
        &drm_edp {
        	edp_ssc_en = <0>;
        	edp_ssc_mode = <0>;
        	edp_psr_support = <0>;
        	edp_colordepth = <8>; /* 6/8/10/12/16 */
        	edp_color_fmt = <0>; /* 0:RGB  1: YUV444  2: YUV422 */
        	lane1_sw = <0>;
        	lane1_pre = <0>;
        	lane2_sw = <0>;
        	lane2_pre = <0>;
        	lane3_sw = <0>;
        	lane3_pre = <0>;
        	efficient_training = <0>;
        	sink_capacity_prefer = <1>;
        	edid_timings_prefer = <1>;
        	timings_fixed = <1>;
        	vcc-edp-supply = <&reg_bldo3>;
        	vdd-edp-supply = <&reg_dcdc2>;
        	panel = <&edp_panel>;
        	ports {
        		edp_out: port@1 {
        			edp_panel_out: endpoint@0 {
        				reg = <0>;
        				remote-endpoint = <&edp_panel_in>;
        &r_pio {
        	uart8_pins_a: uart8_pins@0 {
        		function = "s_uart0";
        	uart8_pins_b: uart8_pins@1 {
        		function = "gpio_in";
        	uart9_pins_a: uart9_pins@0 {
        		pins = "PM0", "PM1";
        		function = "s_uart1";
        	uart9_pins_b: uart9_pins@1 {
        	s_twi0_pins_default: s_twi0@0 {
        		pins = "PL0", "PL1";
        		function = "s_twi0";
        		drive-strength = <10>;
        		bias-pull-up;
        	s_twi0_pins_sleep: s_twi0@1 {
        	s_twi1_pins_default: s_twi1@0 {
        		pins = "PL8", "PL9";
        		function = "s_twi1";
        		bias-pull-up;
        	s_twi1_pins_sleep: s_twi1@1 {
        	s_twi2_pins_default: s_twi2@0 {
        		pins = "PL12", "PL13";
        		function = "s_twi2";
        		bias-pull-up;
        	s_twi2_pins_sleep: s_twi2@1 {
        	s_irrx_pins_default: s_irrx@0 {
        		pins = "PL11";
        		function = "s_cir";
        	s_irrx_pins_sleep: s_irrx@1 {
        		pins = "PL11";
        &pio {
        	vcc-pg-supply = <&reg_pio1_8>;
        	vcc-pf-supply = <&reg_pio1_8>;
        	vcc-pfo-supply = <&reg_pio3_3>;
        	vcc-pd-supply = <&reg_dcdc4>;
        	vcc-pe-supply = <&reg_pio1_8>;
        	vcc-pi-supply = <&reg_dcdc4>;
        	vcc-pj-supply = <&reg_dcdc4>;
        	vcc-pk-supply = <&reg_dcdc4>;
        	uart0_pins_a: uart0_pins@0 {
        		pins = "", "";
        		function = "uart0";
        	uart0_pins_b: uart0_pins@1 {
        		pins = "", "";
        	uart2_pins_a: uart2_pins@0 {
        		pins = "PB0", "PB1";
        		function = "uart2";
        	uart2_pins_b: uart2_pins@1 {
        	uart3_pins_a: uart3_pins@0 {
        		pins = "PD14", "PD15";
        		function = "uart3";
        	uart3_pins_b: uart3_pins@1 {
        	uart4_pins_a: uart4_pins@0 {
        		pins = "PD18", "PD19";
        		function = "uart4";
        	uart4_pins_b: uart4_pins@1 {
        	uart5_pins_a: uart5_pins@0 {
        		pins = "PE11", "PE12";
        		function = "uart5";
        	uart5_pins_b: uart5_pins@1 {
        	uart6_pins_a: uart6_pins@0 {
        		pins = "PI6", "PI7";
        		function = "uart6";
        	uart6_pins_b: uart6_pins@1 {
        	uart7_pins_a: uart7_pins@0 {
        		pins = "PB11", "PB12";
        		function = "uart7";
        	uart7_pins_b: uart7_pins@1 {
        	pwm0_0_pin_active: pwm0_0@0 {
        		pins = "PD23";
        		function = "pwm0_0";
        	pwm0_0_pin_sleep: pwm0_0@1 {
        		pins = "PD23";
        		bias-pull-down;
        	pwm0_1_pin_active: pwm0_1@0 {
        		pins = "PD22";
        		function = "pwm0_1";
        	pwm0_1_pin_sleep: pwm0_1@1 {
        		pins = "PD22";
        		bias-pull-down;
        	pwm0_2_pin_active: pwm0_2@0 {
        		pins = "PB11";
        		function = "pwm0_2";
        	pwm0_2_pin_sleep: pwm0_2@1 {
        		pins = "PB11";
        		bias-pull-down;
        	pwm0_3_pin_active: pwm0_3@0 {
        		pins = "PB12";
        		function = "pwm0_3";
        	pwm0_3_pin_sleep: pwm0_3@1 {
        		pins = "PB12";
        		bias-pull-down;
        	pwm0_4_pin_active: pwm0_4@0 {
        		pins = "PI3";
        		function = "pwm0_4";
        	pwm0_4_pin_sleep: pwm0_4@1 {
        		pins = "PI3";
        		bias-pull-down;
        	pwm0_5_pin_active: pwm0_5@0 {
        		pins = "PI4";
        		function = "pwm0_5";
        	pwm0_5_pin_sleep: pwm0_5@1 {
        		pins = "PI4";
        		bias-pull-down;
        	ledc_pins_a: ledc@0 {
        		pins = "PG0";
        		function = "ledc";
        	ledc_pins_b: ledc@1 {
        		pins = "PG0";
        	irrx_pins_default: irrx@0 {
        		pins = "PI8";
        		function = "cir";
        	irrx_pins_sleep: irrx@1 {
        		pins = "PI8";
        	irtx_pins_default: irtx@0 {
        		pins = "PH18";
        		function = "cir";
        	irtx_pins_sleep: irtx@1 {
        		pins = "PH18";
        	twi0_pins_default: twi0@0 {
        		pins = "PD22", "PD23";
        		function = "twi0";
        		bias-pull-up;
        	twi0_pins_sleep: twi0@1 {
        	twi1_pins_default: twi1@0 {
        		pins = "PH2", "PH3";
        		function = "twi1";
        		bias-pull-up;
        	twi1_pins_sleep: twi1@1 {
        	twi2_pins_default: twi2@0 {
        		pins = "PE1", "PE2";
        		function = "twi2";
        		drive-strength = <20>;
        		bias-pull-up;
        	twi2_pins_sleep: twi2@1 {
        	twi3_pins_default: twi3@0 {
        		pins = "PE3", "PE4";
        		function = "twi3";
        		bias-pull-up;
        	twi3_pins_sleep: twi3@1 {
        	twi4_pins_default: twi4@0 {
        		pins = "PE13", "PE14";
        		function = "twi4";
        		bias-pull-up;
        	twi4_pins_sleep: twi4@1 {
        	twi5_pins_default: twi5@0 {
        		pins = "PI8", "PI9";
        		function = "twi5";
        		bias-pull-up;
        	twi5_pins_sleep: twi5@1 {
        	owa_pins_a: owa@0 {
        		pins = "PI10";
        		function = "owa";
        		bias-disable;
        	owa_pins_b: owa@1 {
        		pins = "PI10";
        		function = "io_disabled";
        		bias-disable;
        	i2s0_pins_a: i2s0@0 {
        		pins = "PB4", "PB5", "PB6";
        		function = "i2s0";
        		bias-disable;
        	i2s0_pins_b: i2s0@1 {
        		pins = "PB4", "PB5", "PB6", "PB7", "PB8";
        		bias-disable;
        	i2s0_pins_c: i2s0@2 {
        		pins = "PB7";
        		function = "i2s0_dout";
        		bias-disable;
        	i2s0_pins_d: i2s0@3 {
        		pins = "PB8";
        		function = "i2s0_din";
        		bias-disable;
        	i2s1_pins_a: i2s1@0 {
        		pins = "PG10", "PG11", "PG12";
        		function = "i2s1";
        		bias-disable;
        	i2s1_pins_b: i2s1@1 {
        		pins = "PG10", "PG11", "PG12", "PG13", "PG14";
        		bias-disable;
        	i2s1_pins_c: i2s1@2 {
        		pins = "PG13";
        		function = "i2s1_dout";
        		bias-disable;
        	i2s1_pins_d: i2s1@3 {
        		pins = "PG14";
        		function = "i2s1_din";
        		bias-disable;
        	i2s2_pins_a: i2s2@0 {
        		pins = "PH9", "PH10";
        		function = "i2s2";
        		bias-disable;
        	i2s2_pins_b: i2s2@1 {
        		pins = "PH2", "PH3", "PH8", "PH9", "PH10", "PH11", "PH12";
        		bias-disable;
        	i2s2_pins_c: i2s2@2 {
        		pins = "PH2", "PH3", "PH12";
        		function = "i2s2_din";
        		bias-disable;
        	i2s2_pins_d: i2s2@3 {
        		pins = "PH11";
        		function = "i2s2_dout";
        		bias-disable;
        	i2s2_pins_e: i2s2@4 {
        		pins = "PH8";
        		function = "i2s2_mclk";
        		bias-disable;
        	i2s3_pins_a: i2s3@0 {
        		pins = "PF3", "PF5", "PF6";
        		function = "i2s3";
        		bias-disable;
        	i2s3_pins_b: i2s3@1 {
        		pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5", "PF6";
        		bias-disable;
        	i2s3_pins_c: i2s3@2 {
        		pins = "PF0", "PF2", "PF4";
        		function = "i2s3_din";
        		bias-disable;
        	i2s3_pins_d: i2s3@3 {
        		pins = "PF1";
        		function = "i2s3_dout";
        		bias-disable;
        	rgb24_pins_a: rgb24@0 {
        		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", \
        			"PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", \
        			"PD20", "PD21", "PD22","PD23","PD24","PD25","PD26","PD27";
        		      function = "dpss";
        		      drive-strength = <30>;
        	rgb24_pins_b: rgb24@1 {
        			"PD20", "PD21", "PD22", "PD23","PD24","PD25","PD26","PD27";
        	lvds0_pins_a: lvds0@0 {
        		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
        		      function = "lvds0";
        	lvds0_pins_b: lvds0@1 {
        	nand0_pins_default: nand0@0 {
        		pins = "PC0", "PC1", "PC2", "PC5",
        			 "PC8", "PC9", "PC10", "PC11",
        			 "PC12", "PC13", "PC14", "PC15",
        			 "PC16";
        		function = "nand0";
        	nand0_pins_rb: nand0@1 {
        		pins = "PC4", "PC6", "PC3", "PC7";
        		function = "nand0";
        		bias-pull-up;   /* only RB&CE should be pulled up */
        	nand0_pins_sleep: nand0@2 {
        		pins = "PC0", "PC1", "PC2", "PC3",
        			 "PC4", "PC5", "PC6", "PC7",
        			 "PC16";
        	gmac0_pins_default: gmac0@0 {
        		pins = "PH0", "PH1", "PH2", "PH3",
        			"PH4", "PH5", "PH6", "PH7",
        			 "PH9", "PH10","PH13","PH14",
        			  "PH15","PH16","PH17","PH18";
        		drive-strength = <40>;
        		function = "gmac0";
        		bias-pull-up;
        	gmac0_pins_sleep: gmac0@1 {
        	gmac1_pins_default: gmac1@0 {
        		pins = "PJ0", "PJ1", "PJ2", "PJ3",
        			"PJ4", "PJ5", "PJ6", "PJ7",
        			"PJ8", "PJ9", "PJ10", "PJ11",
        			"PJ12","PJ13", "PJ14", "PJ15";
        		function = "gmac1";
        		bias-pull-up;
        	gmac1_pins_sleep: gmac1@1 {
        &soc {
        	auto_print@54321 {
        		reg = <0x0 0x54321 0x0 0x0>;
        		device_type = "auto_print";
        	gpio_leds {
        		compatible = "allwinner,sunxi-gpio-leds";
        		supply-num = <1>;
        		gpio1-supply = <&reg_bldo1>;
        		gpio-pins = <&pio PG 10 GPIO_ACTIVE_LOW>, <&pio PC 7 GPIO_ACTIVE_LOW>;
        		pin-names = "normal_led", "standby_led";
        		init-status = <GPIO_ACTIVE_HIGH>, <GPIO_ACTIVE_LOW>;
        &uart0 {
        &uart1 {
        &uart2 {
        &uart3 {
        &uart4 {
        &uart5 {
        &uart6 {
        &uart7 {
        &uart8 {
        &uart9 {
        &lradc {
        	key_cnt = <5>;
        	key0 = <210 0x73>;
        	key1 = <410 0x72>;
        	key2 = <590 0x8B>;
        	key3 = <750 0x1c>;
        	key4 = <880 0x66>;
        	key_debounce;
        &irrx {
        &s_irrx {
        &irtx {
        &gpadc0 {
        	channel_num = <2>;
        &gpadc1 {
        	channel_num = <2>;
        &pwm0_0 {
        &pwm0_1 {
        &pwm0_2 {
        &pwm0_3 {
        &pwm0_4 {
        &pwm0_5 {
        &ledc  {
        	led_count = <34>;
        	reset_ns = <84>;
        	t1h_ns = <800>;
        	t1l_ns = <320>;
        	t0h_ns = <300>;
        	t0l_ns = <800>;
        &twi0 {
        	twi_drv_used = <1>;
        	eeprom@50 {
        		reg = <0x50>;
        	pcie_usb_phy@74 {
        		reg = <0x74>;
        	pcie_usb_phy@75 {
        		reg = <0x75>;
        	ctp {
        		reg = <0x5d>;
        		ctp_twi_id = <0x0>;
        	gt9xx {
        		reg = <0x5d>;
        		irq-flags = <2>;
        			FF FF FF FF AB 01
        &twi1 {
        	twi_drv_used = <1>;
        	mir3da {
        		reg = <0x26>;
        &twi2 {
        	twi_drv_used = <1>;
        &twi3 {
        	twi_drv_used = <1>;
        &twi4 {
        	twi_drv_used = <1>;
        &twi5 {
        	twi_drv_used = <1>;
        	gt9xx_secondary {
        		reg = <0x5d>;
        		irq-flags = <2>;
        			00 00 00 00 73 01
        &csi_mclk3_pins_a {
        	pins = "PK13";
        	function = "ncsi";
        &csi_mclk3_pins_b {
        	pins = "PK13";
                                "PK9";
                                "PK9";
        &vind0 {
        	csi3:csi@5823000 {
        	tdm0:tdm@5908000 {
        		work_mode = <0>;
        	isp00:isp@5900000 {
        		work_mode = <0>;
        	isp01:isp@58ffffc {
        	isp02:isp@58ffff8 {
        	isp03:isp@58ffff4 {
        	isp10:isp@4 {
        	isp20:isp@5 {
        		work_mode = <0>;
        		work_mode = <0>;
        		work_mode = <0>;
        		work_mode = <0>;
        		flash0_type = <2>;
        		flash0_mode = <>;
        		flash0_flvdd = "";
        		device_id = <0>;
        		sensor0_fmt = <0>;
        		sensor0_pwdn = <>;
        		sensor1_fmt = <0>;
        		sensor1_pwdn = <>;
        		device_id = <0>;
        		work_mode = <0x0>;
        		device_id = <1>;
        		device_id = <2>;
        		device_id = <3>;
        		device_id = <4>;
        		work_mode = <0x0>;
        		device_id = <5>;
        		device_id = <6>;
        		device_id = <7>;
        		device_id = <8>;
        		work_mode = <0x0>;
        		device_id = <9>;
        		device_id = <10>;
        		device_id = <11>;
        		device_id = <12>;
        		work_mode = <0x0>;
        		device_id = <13>;
        		device_id = <14>;
        		device_id = <15>;
        		device_id = <16>;
        		device_id = <17>;
        &twi6 {
        	twi_drv_used = <1>;
        	no_suspend = <1>;
        	tcs0: tcs@41 {
        		reg = <0x41>;
        			reg_tcs0: dcdc0 {
        				regulator-boot-on;
        			reg_tcs1: dcdc1 {
        		virtual-ext-dcdc0 {
        		virtual-ext-dcdc1 {
        	sy0: sy@60 {
        		reg = <0x60>;
        			reg_sy0: dcdc0 {
        				regulator-boot-on;
        			reg_sy1: dcdc1 {
        		virtual-ext-dcdc0 {
        		virtual-ext-dcdc1 {
        		reg = <0x36>;
        		wakeup-source;
        		regulators{
        		virtual-ext-dcdc1 {
        		virtual-ext-dcdc2 {
        		virtual-ext-dcdc3 {
        		virtual-ext-aldo1 {
        		virtual-ext-dldo1 {
        	pmu0: pmu@34 {
        		reg = <0x34>;
        		pmu_reset = <0>;
        		wakeup-source;
        			wakeup_usb_in;
        			wakeup_usb_out;
        			pmu_battery_rdc= <170>;
        			pmu_battery_cap = <5000>;
        			pmu_init_chgvol = <4350>;
        			pmu_jetia_en        = <1>;
        			pmu_bat_charge_ltf = <1695>; //-5
        			pmu_bat_charge_htf = <151>; //60
        			pmu_bat_shutdown_htf = <131>; //65
        			pmu_jetia_cool = <1361>; //0
        			pmu_jetia_warm = <208>; //50
        			pmu_jcool_ifall = <0>;//100%
        			pmu_jwarm_ifall = <0>;//100%
        			pmu_bat_temp_para1 = <4378>; //Murata -25
        			pmu_bat_temp_para2 = <2682>; //-15
        			pmu_bat_temp_para4 = <1695>; //-5
        			pmu_bat_temp_para5 = <1361>;//0
        			pmu_bat_temp_para6 = <1101>; //5
        			pmu_bat_temp_para7 = <896>; //10
        			pmu_bat_temp_para8 = <604>; //20
        			pmu_bat_temp_para9 = <416>; //30
        			pmu_bat_temp_para10 = <292>; //40
        			pmu_bat_temp_para11 = <246>; //45
        			pmu_bat_temp_para12 = <208>; //50
        			pmu_bat_temp_para13 = <177>; //55
        			pmu_bat_temp_para14 = <151>; //60
        			pmu_bat_temp_para15 = <111>; //70
        			wakeup_bat_out;
        			wakeup_new_soc;
        			wakeup_rising;
        			wakeup_falling;
        			reg_dcdc1: dcdc1 {
        				regulator-boot-on;
        			reg_dcdc2: dcdc2 {
        				regulator-boot-on;
        			reg_dcdc3: dcdc3 {
        			reg_dcdc4: dcdc4 {
        				regulator-boot-on;
        			reg_aldo1: aldo1 {
        			reg_aldo2: aldo2 {
        			reg_aldo3: aldo3 {
        				regulator-boot-on;
        			reg_aldo4: aldo4 {
        				regulator-boot-on;
        			reg_bldo1: bldo1 {
        			reg_bldo2: bldo2 {
        				regulator-boot-on;
        			reg_bldo3: bldo3 {
        			reg_bldo4: bldo4 {
        			reg_cldo1: cldo1 {
        			reg_cldo2: cldo2 {
        			reg_cldo3: cldo3 {
        				regulator-boot-on;
        			reg_cldo4: cldo4 {
        				regulator-boot-on;
        				/* cpus */
        				regulator-boot-on;
        			reg_vmid: vmid {
        		virtual-dcdc1 {
        		virtual-dcdc2 {
        		virtual-dcdc3 {
        		virtual-dcdc4 {
        		virtual-rtcldo {
        		virtual-aldo1 {
        		virtual-aldo2 {
        		virtual-aldo3 {
        		virtual-aldo4 {
        		virtual-bldo1 {
        		virtual-bldo2 {
        		virtual-bldo3 {
        		virtual-bldo4 {
        		virtual-cldo1 {
        		virtual-cldo2 {
        		virtual-cldo3 {
        		virtual-cldo4 {
        		virtual-cpusldo {
        		virtual-drivevbus {
        			gpio-controller;
        			#size-cells = <0>;
        			#gpio-cells = <6>;
        		battery-model {
        				0x74 0xfb 0xc8 0x0d 0x43 0x10 0xcc 0xfb
        				0x46 0x01 0xea 0x14 0x10 0x06 0xcc 0x06
        				0x9d 0x0b 0x63 0x0f 0xf4 0x0f 0x94 0x0a
        				0x4f 0x0e 0xf4 0x0e 0xeb 0x04 0xdd 0x04
        				0xd1 0x09 0xc7 0x0e 0xb9 0x0e 0xb6 0x09
        				0xae 0x0e 0x97 0x0e 0x97 0x04 0x86 0x04
        				0x73 0x09 0x69 0x0e 0x60 0x0e 0x1e 0x08
        				0x21 0x58 0x28 0x22 0x18 0x06 0x0d 0x01
        &twi7 {
        	clock-frequency = <400000>;
        	/* For stability and backwards compatibility, we recommend setting ‘twi_drv_used’ to 1 */
        	twi_drv_used = <1>;
        	ac107: ac107@36 {
        		reg                     = <0x36>;
        &twi8 {
        	twi_drv_used = <1>;
        &sdc2 {
        	non-removable;
        	bus-width = <8>;
        	mmc-ddr-1_8v;
        	mmc-hs200-1_8v;
        	mmc-hs400-1_8v;
        	no-sdio;
        	no-sd;
        	cap-mmc-highspeed;
        	mmc-bootpart-noacc;
        	/*cap-hsq;*/
        	cqe-on;
        &sdc0 {
        	bus-width = <4>;
        	/*non-removable;*/
        	/*broken-cd;*/
        	/*cd-inverted*/
        	/*data3-detect;*/
        	cd-used-24M;
        	cap-sd-highspeed;
        	sd-uhs-sdr50;
        	sd-uhs-ddr50;
        	sd-uhs-sdr104;
        	no-sdio;
        	no-mmc;
        &sdc1 {
        	bus-width = <4>;
        	no-mmc;
        	no-sd;
        	cap-sd-highspeed;
        	/*sd-uhs-sdr12*/
        	sd-uhs-sdr25;
        	sd-uhs-sdr50;
        	sd-uhs-ddr50;
        	sd-uhs-sdr104;
        	cap-sdio-irq;
        	ignore-pm-notify;
        &nand0 {
        &rfkill {
        	chip_en;
        	power_en;
        	pinctrl-0;
        	pinctrl-names;
        	/* wlan session */
        	wlan {
        		clocks;
        		clock-names;
        		wakeup-source;
        	/* bt session */
        	bt {
        		clocks;
        		clock-names;
        &addr_mgt {
        	status         = "okay";
        &btlpm {
        	uart_index  = <0x1>;
        	wakeup-source;
        	status      = "okay";
        &usbc0 {
        	enable-active-high;
        	enable-active-high;
        	usb_luns = <3>;
        	rndis_wceis = <1>;
        &udc {
        &ehci0 {
        &ohci0 {
        &usbc1 {
        &ehci1 {
        &ohci1 {
        &usbc2 {
        &xhci2 {
        	dr_mode = "host";
        &u2phy {
        &combophy {
        &gpu {
        	gpu_idle = <1>;
        	dvfs_status = <1>;
                           in display.
        &disp {
                fb_format                = <0>;
                fb_num                   = <2>;
                fb0_width                = <1280>;
                fb0_height               = <800>;
                fb1_width                = <1920>;
                fb2_width                = <1280>;
                fb2_height               = <720>;
                fb3_width                = <300>;
                fb3_height               = <300>;
                chn_cfg_mode             = <3>;
                    same parent clock.
                          <&ccu CLK_TCONTV>,
                          <&ccu CLK_TCONTV1>,
                          <&ccu CLK_DSI0>,
                          <&ccu CLK_DSI1>,
                          <&ccu CLK_EDP>;
        	pinctrl-0 = <&pwm0_0_pin_active>;
        	pinctrl-1 = <&pwm0_0_pin_sleep>;
        #if 1
        &lcd0 {
                lcd_used            = <1>;
                lcd_if              = <3>;
                lcd_x               = <1280>;
                lcd_y               = <800>;
                lcd_width           = <150>;
                lcd_height          = <94>;
                lcd_pwm_used        = <1>;
                lcd_pwm_ch          = <4>;
                lcd_pwm_pol         = <0>;
                lcd_hbp             = <88>;
                lcd_ht              = <1451>;
                lcd_hspw            = <18>;
                lcd_vbp             = <23>;
                lcd_vt              = <860>;
                lcd_vspw            = <10>;
                lcd_lvds_if         = <0>;
                lcd_frm             = <0>;
                lcd_gamma_en        = <0>;
                lcd_cmap_en         = <0>;
                lcd_fsync_en        = <0>;
                deu_mode            = <0>;
                smart_color         = <90>;
        #else
        &lcd0 {
        	/* dual-lvds */
        	lcd_used            = <1>;
        	status              = "okay";
        	lcd_if              = <3>;
        	lcd_x               = <1920>;
        	lcd_y               = <1080>;
        	lcd_width           = <476>;
        	lcd_height          = <268>;
        	lcd_pwm_used        = <1>;
        	lcd_pwm_ch          = <4>;
        	lcd_pwm_pol         = <0>;
        	lcd_hbp             = <148>;
        	lcd_ht              = <2200>;
        	lcd_hspw            = <44>;
        	lcd_vbp             = <36>;
        	lcd_vt              = <1125>;
        	lcd_vspw            = <5>;
        	lcd_lvds_if         = <1>;
        	lcd_frm             = <0>;
        	lcd_gamma_en        = <0>;
        	lcd_cmap_en         = <0>;
        	lcd_fsync_en        = <0>;
        	deu_mode            = <0>;
        	smart_color         = <90>;
        #if 1
        &lcd1 {
                lcd_used            = <1>;
                status              = "okay";
                lcd_if              = <4>;
                lcd_x               = <1200>;
                lcd_y               = <1920>;
                lcd_width           = <136>;
                lcd_height          = <217>;
                lcd_pwm_used        = <1>;
                lcd_pwm_ch          = <0>;
                lcd_pwm_pol         = <0>;
                lcd_hbp             = <50>;
                lcd_ht              = <1330>;
                lcd_hspw            = <10>;
                lcd_vbp             = <20>;
                lcd_vt              = <1960>;
                lcd_vspw            = <4>;
                lcd_frm             = <0>;
                lcd_gamma_en        = <0>;
                lcd_cmap_en         = <0>;
                deu_mode            = <0>;
                smart_color         = <90>;
                lcd_dsi_if          = <0>;
                lcd_dsi_lane        = <4>;
                lcd_dsi_te          = <0>;
                lcd_dsi_eotp        = <0>;
        #else
        &lcd1 {
                lcd_used            = <1>;
                lcd_if              = <0>;
                lcd_x               = <800>;
                lcd_y               = <480>;
                lcd_width           = <150>;
                lcd_height          = <94>;
                lcd_pwm_used        = <1>;
                lcd_pwm_ch          = <7>;
                lcd_pwm_pol         = <0>;
                lcd_hbp             = <55>;
                lcd_ht              = <1240>;
                lcd_hspw            = <20>;
                lcd_vbp             = <35>;
                lcd_vt              = <650>;
                lcd_vspw            = <10>;
                lcd_lvds_if         = <0>;
                lcd_frm             = <1>;
                lcd_gamma_en        = <0>;
                lcd_cmap_en         = <0>;
                deu_mode            = <0>;
                smart_color         = <90>;
        &lcd2 {
        	lcd_used            = <0>;
                lcd_if              = <3>;
                lcd_x               = <1280>;
                lcd_y               = <800>;
                lcd_width           = <150>;
                lcd_height          = <94>;
                lcd_pwm_used        = <1>;
                lcd_pwm_ch          = <5>;
                lcd_pwm_pol         = <0>;
                lcd_hbp             = <88>;
                lcd_ht              = <1451>;
                lcd_hspw            = <18>;
                lcd_vbp             = <23>;
                lcd_vt              = <860>;
                lcd_vspw            = <10>;
                lcd_lvds_if         = <0>;
                lcd_frm             = <0>;
                lcd_gamma_en        = <0>;
                lcd_cmap_en         = <0>;
                lcd_fsync_en        = <0>;
                deu_mode            = <0>;
                smart_color         = <90>;
        &edp0 {
        	edp_ssc_en = <0>;
        	edp_ssc_mode = <0>;
        	lane0_sw = <0>;
        	lane0_pre = <0>;
        	lane1_sw = <0>;
        	lane1_pre = <0>;
        	lane2_sw = <0>;
        	lane2_pre = <0>;
        	lane3_sw = <0>;
        	lane3_pre = <0>;
        	edp_pwm_used = <1>;
        	edp_pwm_ch = <5>;
        	edp_pwm_pol = <0>;
        &ve {
        &codec {
        	tx-hub-en;
        	rx-sync-en;
        	avcc-external;
        	vdd-external;
        	cpvin-external;
        	pa-pin-max	= <1>;
        &codec_plat {
        &codec_mach {
        &hdmi_codec {
        	extcon = <&hdmi>;
        &edp_codec {
        &owa_plat {
        	pinctrl-used;
        	tx-hub-en;
        	status		= "okay";
        &owa_mach {
        	status		= "okay";
        &dmic_plat {
        	data-vol	= <0xB0>;
        	rxdelaytime	= <0>;
        	/* pinctrl-used; */
        	rx-sync-en;
        &dmic_mach {
        &i2s0_plat {
        	tdm-num		= <0>;
        	tx-pin		= <0>;
        	rx-pin		= <0>;
        	pinctrl-used;
        	tx-hub-en;
        	rx-sync-en;
        	status		= "okay";
        &i2s0_mach {
        	status		= "okay";
        		/* note:
        &i2s1_plat {
        	tdm-num		= <1>;
        	tx-pin		= <0>;
        	rx-pin		= <0>;
        	/* pinctrl-used; */
        	tx-hub-en;
        	rx-sync-en;
        &i2s1_mach {
        &i2s2_plat {
        	tdm-num		= <2>;
        	tx-pin		= <0 1 2 3>;
        /* e.g.
        	rx-pin		= <0>;
        	/* pinctrl-used; */
        	tx-hub-en;
        	rx-sync-en;
        	dai-type = "hdmi";
        	status		= "okay";
        &i2s2_mach {
        	status		= "okay";
        &i2s3_plat {
        	tdm-num		= <3>;
        	tx-pin		= <0>;
        	rx-pin		= <0>;
        	/* pinctrl-used; */
        	tx-hub-en;
        	rx-sync-en;
        &i2s3_mach {
        &hdmi {
        	hdmi_used = <1>;
        &cpu0 {
        &dsufreq {
        &mdio0 {
        &gmac0 {
        	phy-mode = "rgmii";
        	tx-delay = <3>;
        	rx-delay = <4>;
        	gmac3v3-supply = <&reg_cldo4>;
        &gmac1 {
        	phy-mode = "rgmii";
        	aw,soc-phy25m;
        	tx-delay = <3>;
        	rx-delay = <4>;
        	dwmac3v3-supply = <&reg_cldo4>;
        	mdio1: mdio1@1 {
        &npu {
        &dram {
        	cpul_trips: trips {
        			type = "critical";
        			hysteresis = <0>;
        	cpub_trips: trips {
        			type = "critical";
        			hysteresis = <0>;
        &gpu_thermal_zone {
        	gpu_trips: trips {
        			type = "critical";
        			hysteresis = <0>;
        • chainsx
          woshishabi LV 3 最后由 编辑
          问题已解决,感谢大佬
          • Moved from 其它全志芯片讨论区 by  Kirin Kirin
