    T113S3 longan sdk 编译python3出错
      yuri123088 LV 2 最后由 编辑
      Python build finished successfully!
      The necessary bits to build these optional modules were not found:
      _ssl
      To find the necessary bits, look in setup.py in detect_modules() for the module's name.
      The following modules found by detect_modules() in setup.py, have been
      built by the Makefile instead, as configured by the Setup files:
      _abc atexit pwd
      time
      Failed to build these modules:
      _ctypes
      make[2]: *** [sharedmods] Error 1
      make[1]: *** [/home/qianyou/下载/app/t113-s-v1.1-2.1/out/t113/s3_roc/longan/buildroot/build/host-python3-3.7.2/.stamp_built] Error 2
      make: *** [_all] Error 2
      make: Leaving directory `/home/qianyou/下载/app/t113-s-v1.1-2.1/buildroot/buildroot-201902'
      ERROR: build buildroot Failed
      INFO: mkbr failed
      也做过sudo apt-get install libffi-devel 都没有改善,请大家指教一下,谢谢
      F 1 条回复 最后回复 回复 引用 分享 0
      • F
        fuzhikun LV 5 @yuri123088 最后由 编辑
        @yuri123088 加我qq: 535888978 我发开发环境运行脚本给你,这个问题应该可以解决。
