    t113-s tina如何使用uart1 PD21,PD22
      cjia3254 LV 5 最后由 编辑
      自制的t113开发板,使用的是百问网的sdk,现在是boot0和uboot都有输出,但是在内核阶段没有输出,不知道是内核没有启动,还是使用的串口错误。
      求大佬解惑,这个问题已经找了好几天了。
      sys_config.fex
      ;uart configuration
      ;uart_debug_port  |Boot串口控制器编号        |
      ;uart_debug_tx       |Boot串口发送的GPIO配置|
      ;uart_debug_rx  |Boot串口接收的GPIO配置     |
      [uart_para]
      uart_debug_port = 1
      uart_debug_tx   = port:PD21<4><1><default><default>
      uart_debug_rx   = port:PD22<4><1><default><default>
      board.dts
      &uart0 {
      	pinctrl-0 = <&uart0_pins_a>;
      	pinctrl-1 = <&uart0_pins_b>;
      	status = "disabled";
      &uart1 {
      	pinctrl-0 = <&uart1_pins_a>;
      	pinctrl-1 = <&uart1_pins_b>;
      &uart2 {
              pinctrl-0 = <&uart2_pins_a>;
              pinctrl-1 = <&uart2_pins_b>;
      &uart3 {
      	pinctrl-0 = <&uart3_pins_a>;
      	pinctrl-1 = <&uart3_pins_b>;
      		pins = "PD21", "PD22";
      		function = "uart1";
      		drive-strength = <10>;
      		muxsel = <4>;
      		bias-pull-up;
      	uart1_pins_b: uart1_pins@1 {  /* For EVB1 board */
      		function = "gpio_in";
      env.cfg
      earlyprintk=sunxi-uart,0x02500400
      initcall_debug=1
      console=ttyS1,115200
      config-5.4
      # CONFIG_DEBUG_USER is not set
      CONFIG_DEBUG_LL=y
      # CONFIG_DEBUG_SUNXI_UART0 is not set
      CONFIG_DEBUG_SUNXI_UART1=y
      # CONFIG_DEBUG_SUNXI_UART2 is not set
      # CONFIG_DEBUG_ICEDCC is not set
      # CONFIG_DEBUG_SEMIHOSTING is not set
      # CONFIG_DEBUG_LL_UART_8250 is not set
      # CONFIG_DEBUG_LL_UART_PL01X is not set
      CONFIG_DEBUG_LL_INCLUDE="debug/8250.S"
      CONFIG_DEBUG_UART_8250=y
      CONFIG_DEBUG_UART_PHYS=0x02500400
      CONFIG_DEBUG_UART_VIRT=0xf2500400
      CONFIG_DEBUG_UART_8250_SHIFT=2
      日志输出
      [20]HELLO! BOOT0 is starting!
      [22]BOOT0 commit : 88480af-dirty
      [25]set pll start
      [31]periph0 has been enabled
      [34]set pll end
      [36][pmu]: bus read error
      [38]board init ok
      [40]ZQ value = 0x30
      [42]get_pmu_exist() = -1
      [45]ddr_efuse_type: 0xa
      [47]trefi:7.8ms
      [49][AUTO DEBUG] single rank and full DQ!
      [53]ddr_efuse_type: 0xa
      [55]trefi:7.8ms
      [58][AUTO DEBUG] rank 0 row = 13
      [61][AUTO DEBUG] rank 0 bank = 8
      [64][AUTO DEBUG] rank 0 page size = 2 KB
      [68]DRAM BOOT DRIVE INFO: V0.33
      [71]DRAM CLK = 936 MHz
      [73]DRAM Type = 3 (2:DDR2,3:DDR3)
      [76]DRAMC read ODT  off.
      [79]DRAM ODT value: 0x42.
      [81]ddr_efuse_type: 0xa
      [84]DRAM SIZE =128 M
      [86]dram_tpr4:0x0
      [88]PLL_DDR_CTRL_REG:0xf8004d00
      [91]DRAM_CLK_REG:0xc0000000
      [94][TIMING DEBUG] MR2= 0x20
      [101]DRAM simple test OK.
      [104]rtc standby flag is 0x0, super standby flag is 0x0
      [109]dram size =128
      [111]card no is 0
      [113]sdcard 0 line count 4
      [116][mmc]: mmc driver ver 2021-05-21 14:47
      [125][mmc]: Wrong media type 0x0
      [128][mmc]: ***Try SD card 0***
      [138][mmc]: HSSDR52/SDR25 4 bit
      [141][mmc]: 50000000 Hz
      [143][mmc]: 29664 MB
      [145][mmc]: ***SD/MMC 0 init OK!!!***
      [217]Loading boot-pkg Succeed(index=0).
      [221]Entry_name        = u-boot
      [227]Entry_name        = optee
      [231]Entry_name        = dtb
      [233]mmc not para
      [235]Jump to second Boot.
      U-Boot 2018.05-g24521d6-dirty (Feb 28 2024 - 10:13:08 +0800) Allwinner Technology
      [00.288]CPU:   Allwinner Family
      [00.291]Model: sun8iw20
      ready
      [00.313]DRAM:  128 MiB
      [00.316]Relocation Offset is: 04f01000
      [00.335]secure enable bit: 0
      [00.338]smc_tee_inform_fdt failed with: -65526[00.343]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.349]gic: sec monitor mode
      [00.352]flash init start
      [00.354]workmode = 0,storage type = 1
      [00.357][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.363][mmc]: get sdc_type fail and use default host:tm1.
      [00.369][mmc]: can't find node "mmc0",will add new node
      [00.373][mmc]: fdt err returned <no error>
      [00.377][mmc]: Using default timing para
      [00.381][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.399][mmc]: card_caps:0x3000000a
      [00.402][mmc]: host_caps:0x3000003f
      [00.406]sunxi flash init ok
      [00.419]Loading Environment from SUNXI_FLASH... OK
      [00.450]Item0 (Map) magic is bad
      [00.453]the secure storage item0 copy0 magic is bad
      [00.469]Item0 (Map) magic is bad
      [00.472]the secure storage item0 copy1 magic is bad
      [00.476]Item0 (Map) magic is bad
      [00.482]secure storage read widevine fail with:-1
      [00.490]secure storage read ec_key fail with:-1
      [00.497]secure storage read ec_cert1 fail with:-1
      [00.504]secure storage read ec_cert2 fail with:-1
      [00.512]secure storage read ec_cert3 fail with:-1
      [00.519]secure storage read rsa_key fail with:-1
      [00.527]secure storage read rsa_cert1 fail with:-1
      [00.534]secure storage read rsa_cert2 fail with:-1
      [00.542]secure storage read rsa_cert3 fail with:-1
      [00.546]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.558]usb prepare ok
      [00.727]usb sof ok
      [00.729]usb probe ok
      [00.731]usb setup ok
      set address 0xc
      set address 0xc ok
      [03.736]do_burn_from_boot usb : have no handshake
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [03.746]update part info
      [03.749]update bootcmd
      [03.753]change working_fdt 0x43ec0e70 to 0x43ea0e70
      [03.774]update dts
      [06.946]no vendor_boot partition is found
      Android's image name: t113-100ask
      [06.956]Starting kernel ...
      [06.959][mmc]: MMC Device 2 not found
      [06.962][mmc]: mmc 2 not find, so not exit
      W 1 条回复 最后回复 回复 引用 分享 1
        whycanservice2 LV 8 @cjia3254 最后由 编辑
        @cjia3254 这俩引脚通常用于 显示部分,请检查处理复用
          把t113换成d1s,能启动了、
