    R128 作为TCP客户端连接问题
      Mxf4511 LV 3 最后由 Mxf4511 编辑
      R128作为AP,电脑作为STA连接上R128的WIFI之后,
      R128作为TCP的客户端,电脑作为TCP的服务端,在R128这边创建socket之后,进行connect的时候,一直连接失败,用wireshark抓包看,R128这边好像发不出任何TCP的数据包然后就返回connect失败了,
      connect() 返回的错误码是103,
      然后R128自己输出的LOG是 [WAR:1612]drop=1341, fctl=0x00d0.
      电脑端IP地址:
      tcp客户端连接代码:
      void app_tcp_open_socket(char* ip_addr, uint16_t port)
          printf("[AppTcp] create a socket\n");
          tcp_sock = socket(AF_INET, SOCK_STREAM, 0);
          if (tcp_sock < 0) {
              printf("[AppTcp] Unable to create socket: errno %d\n", errno);
              return ;
          tcp_dest_addr.sin_family = AF_INET;
          // tcp_dest_addr.sin_addr.s_addr = inet_addr(ip_addr);
          tcp_dest_addr.sin_port = htons(port);
          if (inet_aton(ip_addr, &tcp_dest_addr.sin_addr) == 0) {
              printf("Error: Invalid server IP address\n");
              close(tcp_sock);
              return;
          printf("[AppTcp] Socket created, connecting to %s:%d", ip_addr, port);
          int err = connect(tcp_sock, (struct sockaddr *)&tcp_dest_addr, sizeof(tcp_dest_addr));
          if (err != 0) {
              printf("[AppTcp] Socket unable to connect: errno %d\n", errno);
              return ;
          printf("[AppTcp] Successfully connected");
      Hello,R128!!
      [csi_jpeg][csi] probe ok, irq is 109
      [csi_err]output size morn than sensor size, sensor:640*480, output:1280*768
      [csi_jpeg]csi_size = 0, jpeg_size = 51200, total size = 52863
      [gc2145]V4L2_IDENT_SENSOR = 2145
      [gc2145]GC2145 chip id read success 0x2145
      [gc2145]GC2145 Init Done
      [gc2145]GC2145 Init ok!!
      [ACT D][ring_buff_init,29]enter
      [ACT D][ring_buff_start,176]ring buffer start enter
      [ACT D][ring_buff_start,190]ring buffer start quit
      en0: CTRL-EVENT-TERMINATING
      [WAR:1262]join_status:0
      [WAR:852]do not read pout from efuse!!!!
      interface name: en1
      WIF: wifi mode ap onUsing interface en1 with hwaddr 18:1c:1d:1e:1f:20 and ssid "AP-XRADIO"
      en1: interface state UNINITIALIZED->ENABLED
      en1: AP-ENABLED
      en1: AP-DISANBLED
      g <wlan connected>
      [net INF] bring up netif
      [net INF] netif (IPv4) is up
      [net INF] address: 192.168.51.1
      [net INF] gateway: 192.168.51.1
      [net INF] netmask: 255.255.255.0
      wifi enable
      [net INF] msg <network up>
      event unknow WAR: unknown msg (19, 0)
      vif0, AP/GO mode THROTTLE=38
      en1: interface state ENABLED->DISABLED
      [net INF] msg <wlan disconnected>
      [net INF] netif is link down
      wifi disable
      Using interface en1 with hwaddr 18:1c:1d:1e:1f:20 and ssid "ToothScan"
      en1: interface state DISABLED->ENABLED
      en1: AP-ENABLED
      [net INF] msg <wlan connected>
      [net INF] netif is link up
      [net INF] netif is already up
      wifi enable
      event unknow vif0, AP/GO mode THROTTLE=38
      9, 0)
      ap param:
      ssid:ToothScan
      psk:
      wifi channel:6
      IPV4 Addr:192.168.51.1
      MAC Addr: 0: 0: 0: 0: 0: 0
      Init app_tcp task
      xr_newassoc(): link_id:0 mac:60:45:2e:7f:0b:66
      en1: STA 60:45:2e:7f:0b:66 IEEE 802.11: associated
      en1: AP-STA-CONNECTED 60:45:2e:7f:0b:66
      [net INF] msg <wlan ap-sta connected>
      wifi sta connected
      dev param:
      dev:
      [AppTcp] Reconnect Tcp Services
      [AppTcp] Socket created, connecting to 192.168.51.100
      :1347[AppTcp] Socket unable to connect: errno 103
      • Moved from A Series by  xiaowenge xiaowenge
