    v851使用sample_rtsp 报错,vlc无法播放图像
    4459
      lw409309740 LV 3 最后由 q1215200171 编辑
      用sdk编译的sample_rtsp demo,运行报错,详细log如下:
      root@TinaLinux:/mnt/extsd/new_sample_rtsp# ./sample_rtsp -path sample_rtsp.conf
      I0101 00:22:44.416707  1040 dup2SeldomUsedFd.c:20]          <dup2SeldomUsedFdInit> gFdLock init
      I0101 00:22:44.442590  1040 sample_rtsp.c:95]               <ParseCmdLine> sample virvi2venc path:[./sample_rtsp], arg number is [3]
      I0101 00:22:44.444461  1040 confparser.c:60]                <createConfParser> load conf file sample_rtsp.conf ok!
      I0101 00:22:44.444929  1040 sample_rtsp.c:292]              <loadSampleConfig> IspAndVeLinkage config: Enable=1, StreamChn=0
      Committed_AS:       4092 kB
      I0101 00:22:44.455333  [  130.264208] VE: before freq=300000000
      1040 mpi_sys.c:840]                                         <A[  130.269931] VE: real freq=300000000
      W_MPI_SYS_SetConf> kfctmpdir is [/tmp]
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Media Process Platform<<<<<<<<<<<<<<<<<<<<<<<<<<<<
      modName : MPP-Platform
      tag   : V1.0 Release
      branch: v5-dev
      commit: 4eed413532ad87725895a8cb1ba75e22fc328233
      date  : 20170725
      author: jenkins
      iniparser: cannot open /etc/cedarx.conf
      iniparser: cannot open /vendor/etc/cedarx.conf
      I0101 00:22:44.476222  1040 mpi_sys.c:1280]                 <AW_MPI_SYS_Init> ISP init
      [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
      IPCORE: ISP600
      branch: libisp-dev
      commit: 14df8348718d093707641fea73eba7db962885f5
      date  : Thu Jul 14 15:40:38 2022 +0800
      I0101 00:22:44.477028  1040 mpi_sys.c:1282]                 <AW_MPI_SYS_Init> ISP init done
      INFO   : cedarc <VeInitialize:1185>: *** ic_version = 0x1302000023010,
      I0101 00:22:44.496470  1040 hwdisplay.c:84]                 <hw_display_init>
      I0101 00:22:44.496731  1040 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
      I0101 00:22:44.496967  1040 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
      I0101 00:22:44.501072  1040 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:0
      I0101 00:22:44.584973  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 ADC2 swap
      I0101 00:22:44.585186  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC1 volume
      I0101 00:22:44.585290  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADC2 volume
      I0101 00:22:44.585372  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCDRC
      I0101 00:22:44.585448  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:ADCHPF
      I0101 00:22:44.585522  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DAC volume
      I0101 00:22:44.585595  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACDRC
      I0101 00:22:44.585666  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:DACHPF
      I0101 00:22:44.585738  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEIN
      I0101 00:22:44.585814  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINL gain volume
      I0101 00:22:44.585910  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEINR gain volume
      I0101 00:22:44.586000  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT
      I0101 00:22:44.586277  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT Output Select
      I0101 00:22:44.586551  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:LINEOUT volume
      I0101 00:22:44.586735  1040 alsa_interface.c:756]           <alsaOpenMixer> set playback vol_val to value: 27
      I0101 00:22:44.586845  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1
      I0101 00:22:44.587089  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 Input Select
      I0101 00:22:44.587205  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC1 gain volume
      I0101 00:22:44.587293  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2
      I0101 00:22:44.587372  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 Input Select
      I0101 00:22:44.587447  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:MIC2 gain volume
      I0101 00:22:44.587526  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:SPK
      I0101 00:22:44.587725  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:digital volume
      I0101 00:22:44.587831  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 00:22:44.587939  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 00:22:44.588040  1040 alsa_interface.c:970]           <alsaMixerSetAudioCodecHubMode> aec_elem_audio_codec_hub_mode:tx hub mode-1
      E0101 00:22:44.588169  1040 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      I0101 00:22:44.588293  1040 alsa_interface.c:701]           <alsaOpenMixer> open mixer:hw:1
      I0101 00:22:44.589164  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:loopback debug
      I0101 00:22:44.589348  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:rx sync mode
      I0101 00:22:44.589471  1040 alsa_interface.c:736]           <alsaOpenMixer> alsa_elem:tx hub mode
      E0101 00:22:44.589579  1040 alsa_interface.c:993]           <alsaMixerSetDAudio0HubMode> aec_elem_daudio0_hub_mode:tx hub mode-1
      E0101 00:22:44.589708  1040 alsa_interface.c:1016]          <alsaMixerSetDAudio0LoopBackEn> aec_elem_daudio0_loopback_en:loopback debug-1
      E0101 00:22:44.589840  1040 alsa_interface.c:853]           <alsaMixerSetCapPlaySyncMode> aec_elem_sync_mode_switch:rx sync mode-1
      I0101 00:22:44.589995  1040 sample_rtsp.c:490]              <configMainStream> main vipp0 ve_online_en:1, dma_buf_num:2, venc ch0 OnlineEnable:1, OnlineShareBufNum:2
      I0101 00:22:44.590091  1040 sample_rtsp.c:517]              <configMainStream> main EncppSharpAttenCoefPer: 100%
      I0101 00:22:44.590173  1040 sample_rtsp.c:527]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
      [ISP]video device name is vin_video0
      [ISP]open video device[0], detect isp0 success!
      I0101 00:22:44.922567  1040 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:44.922957  1040 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[0] update width:1920(1920), height:1080(1088)
      I0101 00:22:44.923135  1040 videoInputHw.c:957]             <videoInputHw_SetChnAttr> ViCh[0] LBC pix:0x3132434c, line_tar_bits[0]:9216, line_tar_bits[1]:13824
      I0101 00:22:44.924095  1040 videoInputHw.c:977]             <videoInputHw_SetChnAttr> bs_len:61440, frm_bit:11520
      [ISP]video0 fd[10] ve_online_en=[  130.963110] [VIN]ve_online open, buffer_num is 2
      1, dma_buf_num=2
      open /dev/sunxi_soc_info failed![ISP]open isp device[0] success!
      [ISP_WARN]sdcard is not mounted!!!
      [ISP]prefer isp config: [gc2053_mipi], 1920x1088, 20, 0, 0
      [ISP]find gc2053_mipi_1920_1088_20_0 [gc2053_mipi_isp600_20220511_164617_vlc4_day] isp config
      [ISP]create isp0[  131.016765] [VIN]video0:buffer count is invalid, set to 2
       server thread!
        131.065767] VE: before freq=300000000Component.c:1160]
      60C<VideoViComponentInit> VideoV[  131.072873] VE: real freq=300000000
      irvi component Init! thread_id[0xb6825d50]
      I0101 00:22:45.276949  1040 VideoEnc_Component.c:704[  131.085770] VE: before freq=300000000
      2]                                                          <VideoEncComponentI[  131.091948] VE: real freq=300000000
      nit> create VideoEnc threadId:0xb6802d50
      I0101 00:22:45.277255  1040 VideoEnc_Component.c:2663]      <VideoEncSetChnAttr> vencChn[0] enable online!
      I0101 00:22:45.277401  1040 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[0] Comp StateIdle
      I0101 00:22:45.277595  1045 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 0, buf_num=2.
      I0101 00:22:45.277805  1047 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:45.278041  1047 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[0] Create VeType=265
      iniparser: cannot open /tmp/libcedarc_dynamic_log_level
      INFO   : cedarc <cdc_log_set_level:43>: Set log level to 5 from /vendor/etc/cedarc.conf
      WARNING: cedarc <LogVersionInfo:44>:
      >>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cedar Codec <<<<<<<<<<<<<<<<<<<<<<<<<<<<
      tag   :
      branch: tina-v853-dev
      commit: ee230a47e5a2392ec315795121c2d112492fac1c
      date  : Fri Jul 22 10:37:50 2022 +0800
      author: wuguanjian
      change-id : I28fe0c31c718f097d61ad6bdbcb4cb5df0bd3575
      release_author : lichaopdc
      patch :
      I0101 00:22:45.317399  1040 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[0] set new framerate:20
      I0101 00:22:45.317638  1040 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 2DFilter param
      I0101 00:22:45.317765  1040 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[0] enable and set 3DFilter param
      I0101 00:22:45.317860  1040 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[0] SuperFrm Mode:0, IfrmSize:1638400 bits, PfrmSize:546133 bits
      I0101 00:22:45.317972  1040 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      I0101 00:22:45.318076  1040 sample_rtsp.c:638]              <configSubStream> vipp[4] crop en:1 X:0 Y:0 W:1888 H:1072
      I0101 00:22:45.318194  1040 sample_rtsp.c:651]              <configSubStream> sub EncppSharpAttenCoefPer: 33%
      I0101 00:22:45.318286  1040 sample_rtsp.c:661]              <configSubStream> sub vbvThreshSize: 24000, vbvBufSize: 152000
      [ISP]video device name is vin_video4
      [ISP]open video device[4], detect isp0 success!
      I0101 00:22:45.318667  1040 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:45.318916  1040 videoInputHw.c:942]             <videoInputHw_SetChnAttr> ViCh[4] update width:640(640), height:360(368)
      I0101 00:22:45.319029  1040 videoInputHw.c:957]             <videoInputHw_SetChnAttr> ViCh[4] LBC pix:0x3132434c, line_tar_bits[0]:3072, line_tar_bits[1]:4608
      I0101 00:22:45.319446  1040 videoInputHw.c:977] [  131.333167] VE: before freq=300000000
        <videoInputHw_SetChnAt[  131.338496] VE: real freq=300000000
      tr> bs_len:20480, frm_bit:3840
      [ISP_ERR]isp_stat_process_buffer, line: 268,AEWB: stats error, skipping buffer.
      I0101 00:22:45.[  131.355381] VE: before freq=300000000
      540872  1040 videoInputHw.c:1254[  131.360537] VE: real freq=300000000
      ]                                                           <videoInputHw_SetCrop> vipp[4] set crop X:0, Y:0, Width:1888, Height:1072
      I0101 00:22:45.544077  1040 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb6738d50]
      I0101 00:22:45.545034  1040 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb6715d50
      I0101 00:22:45.545282  1040 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[1] Comp StateIdle
      I0101 00:22:45.545499  1048 videoInputHw.c:4787]            <VideoInputHw_CapThread> loop VideoInputHw_CapThread vipp_id = 4, buf_num=3.
      I0101 00:22:45.545709  1050 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:45.545948  1050 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[1] Create VeType=96
      open /dev/sunxi_soc_info failed!WARNING: cedarc <LogVersionInfo:44>:
      tag   :
      author: wuguanjian
      patch :
      I0101 00:22:45.565295  1040 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[1] set new framerate:20
      I0101 00:22:45.565528  1040 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 2DFilter param
      I0101 00:22:45.565650  1040 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[1] enable and set 3DFilter param
      I0101 00:22:45.565749  1040 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[1] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
      I0101 00:22:45.565863  1040 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      I0101 00:22:45.565967  1040 sample_rtsp.c:772]              <configSubLapseStream> subLapse EncppSharpAttenCoefPer: 33%
      I0101 00:22:45.566077  1040 sample_rtsp.c:782]              <configSubLapseStream> SubLapse vbvThreshSize: 24000, vbvBufSize: 152000
      I0101 00:22:45.566521  1040 VideoVirVi_Component.c:1160]    <VideoViComponentInit> VideoVirvi component Init! thread_id[0xb66f2d50]
      I0101 00:22:45.567498  1040 VideoEnc_Component.c:7042]      <VideoEncComponentInit> create VideoEnc threadId:0xb66cfd50
      I0101 00:22:45.567720  1040 VideoEnc_Component.c:5422]      <VideoEncSendCommand> set VencChn[2] Comp StateIdle
      I0101 00:22:45.567925  1052 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:45.568158  1052 VideoEnc_Component.c:1110]      <CedarvEncInit> VencChn[2] Create VeType=96
      tag   :
      author: wuguanjian
      patch :
      I0101 00:22:45.580668  1040 VideoEnc_Component.c:3961]      <VideoEncSetFrameRate> vencChn[2] set new framerate:20
      I0101 00:22:45.580872  1040 sample_rtsp.c:1464]             <main> Lapse set TimeLapse 1000000 us
      I0101 00:22:45.581081  1040 VideoEnc_Component.c:4036]      <VideoEncSetTimeLapse> SetTimeLapse: captureIntervalUs=1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
      I0101 00:22:45.581216  1040 sample_rtsp.c:1244]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 2DFilter param
      I0101 00:22:45.581338  1040 sample_rtsp.c:1257]             <setVenc2Dnr3Dnr> VencChn[2] enable and set 3DFilter param
      I0101 00:22:45.581432  1040 sample_rtsp.c:1275]             <setVencSuperFrameCfg> VencChn[2] SuperFrm Mode:0, IfrmSize:266666 bits, PfrmSize:88888 bits
      I0101 00:22:45.581543  1040 VideoEnc_Component.c:6284]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
      [ISP_WARN]gc2053_mipi get senso[  131.733103] VEncComp_0: r_temp failed: Invalid argument page allocation failure: order:10(22).
      I0101 00:22:45.915144  1040 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[0] Comp StateExecuting
      I0101 00:22:45.915471  1047 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FI, mode:0x24280c2(GFP_HIGHUSER|__GFP_ZERO)
      LE_PATH=(null)
      I0101 00:22:45.9[  131.768322] CPU: 0 PID: 1047 Comm: VEncComp_0 Not tainted 4.9.191 #1
      15745  1047 VideoEnc_Component.c:788]                       <setVbvBufferConfig> user set stream buffer size[933882]bytes
      I0101 00:22:45.915892  1047 VideoEnc_Component.c:[  131.791706] Hardware name: sun8iw21
      798]                                                        <setVbvBufferConf[  131.796041] [<c010d5a0>] (unwind_backtrace) from [<c010a694>] (show_stack+0x10/0x14)
      ig> user set threshSize[147450]b[  131.807584] [<c010a694>] (show_stack) from [<c017ad40>] (warn_alloc+0xe0/0x110)
      ytes
      I0101 00:22:45.915992  104[  131.818684] [<c017ad40>] (warn_alloc) from [<c017b55c>] (__alloc_pages_nodemask+0x770/0x954)
      7 VideoEnc_Component.c:825]   131.832497] [<c017b55c>] (__alloc_pages_nodemask) from [<c010e6d4>] (__dma_alloc_buffer+0x30/0x88)
      D                                                            <setVbvBufferConfig> bit r[  131.844294] [<c010e6d4>] (__dma_alloc_buffer) from [<c01108e8>] (remap_allocator_alloc+0x2c/0x7c)
      ate is 1536Kb, set encode vbv size 933888, frame length threshol[  131.859049] [<c01108e8>] (remap_allocator_alloc) from [<c010e934>] (__dma_alloc+0x1a4/0x2ac)
      d 147450
      I0101 00:22:45.916103 [  131.871685] [<c010e934>] (__dma_alloc) from [<c010eaa4>] (arm_dma_alloc+0x34/0x40)
       1047 VideoEnc_Component.c:1930][  131.883912] [<c010eaa4>] (arm_dma_alloc) from [<c04f825c>] (ion_cma_allocate+0x8c/0x1e4)
        <CedarvVideoEncInit> [  131.896228] [<c04f825c>] (ion_cma_allocate) from [<c04f52ec>] (__ion_alloc+0xc4/0x3d8)
      veChn[0], EncppEnable=1
      I0101 0[  131.906837] [<c04f52ec>] (__ion_alloc) from [<c04f5d38>] (ion_ioctl+0x1dc/0x510)
      0:22:45.916193  1047 VideoEnc_Co[  131.917588] [<c04f5d38>] (ion_ioctl) from [<c01c5b48>] (vfs_ioctl+0x18/0x3c)
      mponent.c:1936]                                             <Cedar[  131.928596] [<c01c5b48>] (vfs_ioctl) from [<c01c6434>] (do_vfs_ioctl+0x794/0x8e8)
      vVideoEncInit> DropFrameNum: 0
      [  131.939684] [<c01c6434>] (do_vfs_ioctl) from [<c01c65bc>] (SyS_ioctl+0x34/0x5c)
      I0101 00:22:45.916271  1047 Vide[  131.950899] [<c01c65bc>] (SyS_ioctl) from [<c0106d20>] (ret_fast_syscall+0x0/0x54)
        131.962031] Mem-Info:
      C<CedarvVideoEncInit> GDC enable[  131.967041] active_anon:574 inactive_anon:0 isolated_anon:0
      [  131.967041]  active_file:616 inactive_file:497 isolated_file:0
      [  131.967041]  unevictable:0 dirty:0 writeback:0 unstable:0
      [  131.967041]  slab_reclaimable:285 slab_unreclaimable:1266
      [  131.967041]  mapped:910 shmem:0 pagetables:31 bounce:0
      [  131.967041]  free:4668 free_pcp:4 free_cma:0
      : 0
      I0101 00:22:45.916356  1047[  132.005894] Node 0 active_anon:2296kB inactive_anon:0kB active_file:2464kB inactive_file:1988kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:3640kB dirty:0kB writeback:0kB shmem:0kB writeback_tmp:0kB unstable:0kB pages_scanned:0 all_unreclaimable? no
       VideoEnc_Component.c:2011]   132.034845] Normal free:18672kB min:880kB low:1100kB high:1320kB active_anon:2296kB inactive_anon:0kB active_file:2464kB inactive_file:1988kB unevictable:0kB writepending:0kB present:60928kB managed:51188kB mlocked:0kB slab_reclaimable:1140kB slab_unreclaimable:5064kB kernel_stack:608kB pagetables:124kB bounce:0kB free_pcp:16kB local_pcp:16kB free_cma:0kB
      D                                                            <CedarvVideoEncInit> Onlin[  132.072488] lowmem_reserve[]:e Mode=1, Channel=1, ShareBufNum 0=2, OnlineEnableFlag=1
      I0101 00 0:22:45.916453  1047 VideoEnc_Com 0ponent.c:2038]  <Cedarv
      VideoEncInit> rec_lbc_mode=1
      [I[  132.090281] Normal: SP_ERR]isp_sync_debug_info, line56*4kB : 747,VIDIOC_VIN_ISP_GET_INFO er(UE) ror!
      [ISP_ERR]isp_sync_debug_in76*8kB fo, line: 747,VIDIOC_VIN_ISP_GET(UME) _INFO error!
      [ISP_ERR]isp_sync_77*16kB debug_info, line: 747,VIDIOC_VIN(UME) _ISP_GET_INFO error!
      53*32kB (UME) 27*64kB (UME) 15*128kB (UME) 6*256kB (ME) 5*512kB (UME) 3*1024kB (ME) 2*2048kB (UM) 0*4096kB = 18672kB
      [  132.133154] 1113 total pagecache pages
      [  132.137608] 0 pages in swap cache
      [  132.141632] Swap cache stats: add 0, delete 0, find 0/0
      [  132.147677] Free swap  = 0kB
      [  132.151171] Total swap = 0kB
      [  132.160738] 15232 pages RAM
      [  132.170527] 0 pages HighMem/MovableOnly
      [  132.181111] 2435 pages reserved
      [  132.190943] 0 pages cma reserved
      [  132.200300] platform cma: Fail to allocate buffer
      ERROR  : ionAlloc <ion_alloc_palloc_base:349>: ION_IOC_ALLOC error , size = 3064768
      ERROR  : cedarc <h265InitMemRecRefE230:4002>: palloc failed for recRefBufLbcVir, size = 3064768
      ERROR  : cedarc <h265InitMemory:4171>: EncAdapterMemPalloc for rec/ref fail
      ERROR  : cedarc <VencInit:744>: venc_init_fail
      [ISP]video device name is vin_video12
      [ISP]open video device[12], detect isp0 success!
      I0101 00:22:46.495634  1048 videoInputHw.c:4882]            <VideoInputHw_CapThread> vipp[4] drop 10 frames done!
      E0101 00:22:46.500696  1047 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:6
      E0101 00:22:46.504844  1047 VideoEnc_Component.c:8025]      <ComponentThread> fatal error! vdeclib init fail[0xa008800c]
      E0101 00:22:46.505057  1047 mpi_venc.c:327]                 <VideoEncEventHandler> fatal error! venc state transition incorrect:a008800c.
      wlan0 ip:192.168.43.61
      				*		AW RTSP LIB VERSION: 				*
      				*		BUILD BY WHO: 										*
      				*		BUILD TIME: 						*
         rtsp://192.168.43.61:8554/ch0
      I0101 00:22:46.506906  1040 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[1] Comp StateExecuting
      I0101 00:22:46.507215  1050 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:46.507765  1050 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
      I0101 00:22:46.507938  1050 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
      I0101 00:22:46.508045  1050 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
      I0101 00:22:46.508170  1050 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[1], EncppEnable=1
      I0101 00:22:46.508280  1050 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 00:22:46.508366  1050 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 00:22:46.508454  1050 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
      I0101 00:22:46.508536  1050 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      I0101 00:22:46.513611  1056 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:46.514085  1056 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
      I0101 00:22:46.514314  1056 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[147450]bytes
      I0101 00:22:46.514449  1056 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
      I0101 00:22:46.514586  1056 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[0], EncppEnable=1
      I0101 00:22:46.514713  1056 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 00:22:46.514801  1056 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 00:22:46.514891  1056 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=1, ShareBufNum=2, OnlineEnableFlag=1
      I0101 00:22:46.514969  1056 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      WARNING: cedarc <VencInit:692>: the state[1] is not idle when call init
      E0101 00:22:46.515077  1056 VideoEnc_Component.c:2043]      <CedarvVideoEncInit> fatal error vencInit fail:ffffffff
      I0101 00:22:46.515233  1056 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[0]
      I0101 00:22:46.515345  1056 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[0] had init!
      E0101 00:22:46.515437  1056 VideoEnc_Component.c:4276]      <VideoEncExtraData> fatal error! vdeclib init fail[0xffffffff]
      E0101 00:22:46.515523  1056 sample_rtsp.c:1018]             <getVencStreamThread> fatal error! get spspps fail[0xffffffff]!
      I0101 00:22:46.521388  1050 VideoEnc_Component.c:2059]      <CedarvVideoEncInit> Venc Init success
      I0101 00:22:46.521621  1050 VideoEnc_Component.c:2068]      <CedarvVideoEncInit> Venc SetCallbacks success
      I0101 00:22:46.531410  1050 VideoEnc_Component.c:2078]      <CedarvVideoEncInit> Venc Start success
      I0101 00:22:46.531741  1050 VideoEnc_Component.c:2121]      <CedarvVideoEncInit> set Color2Grey [0], in Venchn[1]
      I0101 00:22:46.864108  1050 VideoEnc_Component.c:2128]      <CedarvVideoEncInit> vencChn[1] had init!
      I0101 00:22:46.864440  1050 VideoEnc_Component.c:8042]      <ComponentThread> VencChn[1]: idle/pause[0x2]->executing ...
      open /dev/sunxi_soc_info failed![ISP]---------   LDCI Video12 Init OK   ---------
      W0101 00:22:46.547002  1048 videoInputHw.c:4870]            <VideoInputHw_CapThread> vi_v_frm_pts_invalid:vipp4--132323665-131929315=394350(us)
      				*		BUILD BY WHO: 										*
      				*		BUILD TIME: 						*
         rtsp://192.168.43.61:8554/ch1
      I0101 00:22:46.866980  1049 VideoEnc_Component.c:6383]      <VideoEncEmptyThisBuffer> VencChn[1]: first video frame pts[132323665]us,tm1[132643694]us, vSize[640x368], frmId[2,20]
      I0101 00:22:46.867381  1040 VideoEnc_Component.c:5418]      <VideoEncSendCommand> set VencChn[2] Comp StateExecuting
      I0101 00:22:46.867719  1052 media_debug.c:45]               <getDictByConfPath> MPP_DEDIA_DEBUG_FILE_PATH=(null)
      I0101 00:22:46.868043  1052 VideoEnc_Component.c:788]       <setVbvBufferConfig> user set stream buffer size[152000]bytes
      I0101 00:22:46.868174  1052 VideoEnc_Component.c:798]       <setVbvBufferConfig> user set threshSize[24000]bytes
      I0101 00:22:46.868273  1052 VideoEnc_Component.c:825]       <setVbvBufferConfig> bit rate is 250Kb, set encode vbv size 152576, frame length threshold 24000
      I0101 00:22:46.868379  1052 VideoEnc_Component.c:1930]      <CedarvVideoEncInit> veChn[2], EncppEnable=1
      I0101 00:22:46.868465  1052 VideoEnc_Component.c:1936]      <CedarvVideoEncInit> DropFrameNum: 0
      I0101 00:22:46.868553  1052 VideoEnc_Component.c:1946]      <CedarvVideoEncInit> GDC enable: 0
      I0101 00:22:46.868643  1052 VideoEnc_Component.c:2011]      <CedarvVideoEncInit> Online Mode=1, Channel=0, ShareBufNum=0, OnlineEnableFlag=0
      I0101 00:22:46.868725  1052 VideoEnc_Component.c:2038]      <CedarvVideoEncInit> rec_lbc_mode=1
      [ISP]--------- LDCI Video12 Streamon OK ---------
      [ISP_ERR]isp_sync_debug_info, line: 747,VIDIOC_VIN_ISP_GET_INFO error!
      W0101 00:22:47.521364  1056 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      W0101 00:22:47.874405  1058 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
      W0101 00:22:48.521768  1056 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      I0101 00:22:48.867471  1049 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-0] has no frame input?
      I0101 00:22:48.867778  1051 VideoVirVi_Component.c:1354]    <Vi_ComponentThread> virvi[4-1] has no frame input?
      [ISP_ERR]video_wait_buffer, line: 488,video4 select timeout!
      W0101 00:22:48.868022  1048 videoInputHw.c:4945]            <VideoInputHw_CapThread> vipp[4] get frame fail! frameBufId[2] is not release
      W0101 00:22:48.868171  1048 videoInputHw.c:4949]            <VideoInputHw_CapThread> vipp[4] get frame fail! [1]frames are not release
      W0101 00:22:48.874793  1058 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[1] get frame failed! check code!
      W0101 00:22:49.522156  1056 sample_rtsp.c:1216]             <getVencStreamThread> fatal error! vencChn[0] get frame failed! check code!
      请问一下为什么venc获取不到帧?
      P 1 条回复 最后回复 回复 引用 分享 1
      • P
        pointzero36 LV 2 @lw409309740 最后由 编辑
        @lw409309740 34a9b48f-e011-4b57-9fb0-af871574b416-image.png 我试了用这里的地址在VLC上连接,实际是能连的,显示,目前很卡,估计跟一直报错有些关系,怀疑不是当前使用通道报的错,应该是没上的过多数量配置报的错,还在找,,,,
          lw409309740 LV 3 @pointzero36 最后由 编辑
          @pointzero36 sample_rtsp.conf 配置信息如下:
          ########### paramter (ref to tulip_cedarx.conf)############
          [parameter]
          main_isp = 0
          main_vipp = 0
          main_src_width = 1920
          main_src_height = 1080
          main_pixel_format = "aw_lbc_2_0x" #nv21,nv12,yu12,yv12;aw_lbc_2_5x,aw_lbc_2_0x,aw_lbc_1_5x,aw_lbc_1_0x
          main_wdr_enable = 0
          main_vi_buf_num = 3
          main_src_frame_rate = 20 #fps
          main_viChn = 0 #-1:disale main stream
          main_venc_chn = 0 #-1:disale main stream
          main_encode_type = "H.265"
          main_encode_width = 2304 #1280x720->720p, 1920x1080->1080p, 2304x1296->3M, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
          main_encode_height = 1296
          main_encode_frame_rate = 20 #fps
          main_encode_bitrate = 1572864 #5M:5242880, 2M:2097152, 1.5M:1572864, 1M:1048576
          main_file_path = #"/mnt/extsd/mainStream.raw" #if no path is specified, it will not be saved.
          main_online_en = 1
          main_online_share_buf_num = 2
          main_encpp_enable = 1
          sub_isp = 0
          sub_vipp = 4
          sub_src_width = 640
          sub_src_height = 360
          sub_pixel_format = "aw_lbc_2_0x" #nv21,nv12,yu12,yv12;aw_lbc_2_5x,aw_lbc_2_0x,aw_lbc_1_5x,aw_lbc_1_0x
          sub_wdr_enable = 0
          sub_vi_buf_num = 3
          sub_src_frame_rate = 20 #fps
          sub_vipp_crop_en = 1
          sub_vipp_crop_rect_x = 0
          sub_vipp_crop_rect_y = 0
          sub_vipp_crop_rect_w = 1888
          sub_vipp_crop_rect_h = 1072
          sub_viChn = 0 #-1:disale sub stream
          sub_venc_chn = 1 #-1:disale sub stream
          sub_encode_type = "H.264"
          sub_encode_width = 640 #1280x720->720p, 1920x1080->1080p, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
          sub_encode_height = 360
          sub_encode_frame_rate = 20 #fps
          sub_encode_bitrate = 256000 #5M:5242880‬, 2M:2097152, 1M:1048576‬, 0.5M:512000
          sub_file_path = #"/mnt/extsd/subStream.raw" #if no path is specified, it will not be saved.
          sub_encpp_enable = 1
          sub_lapse_viChn = 1 #-1:disale sub lapse stream
          sub_lapse_venc_chn = 2 #-1:disale sub lapse stream
          sub_lapse_encode_type = "H.264"
          sub_lapse_encode_width = 640 #1280x720->720p, 1920x1080->1080p, 2560×1440->2k, 3840x2160->4k, 7680x4320->8k
          sub_lapse_encode_height = 360
          sub_lapse_encode_frame_rate = 20 #fps
          sub_lapse_encode_bitrate = 256000 #5M:5242880‬, 2M:2097152, 1M:1048576‬, 0.5M:512000
          sub_lapse_file_path = #"/mnt/extsd/subLapseStream.raw" #if no path is specified, it will not be saved.
          sub_lapse_time = 1000000 #unit:us
          sub_lapse_encpp_enable = 1
          isp_ve_linkage_enable = 1
          isp_ve_linkage_stream_channel = 0 #0:main stream, 1:sub stream, 2:sub lapse stream
          wb_yuv_enable = 0
          wb_yuv_buf_num = 20
          wb_yuv_start_index = 0
          wb_yuv_total_cnt = 100
          wb_yuv_stream_channel = 0 #0:main stream, 1:sub stream, 2:sub lapse stream
          wb_yuv_file_path = "/mnt/extsd/wb_yuv.yuv"
          rtsp_net_type = 3 #RTSP Network type, 0: "lo", 1: "eth0", 2: "br0", 3: "wlan0"
          test_duration = 0 #unit:s, 0:Infinite duration.
          您看下配置文件,基本上使用默认的配置。有没可能内核固件版本不对,您这边能用vlc出图像吗?
          • doniyor_khalilov99
            doniyor_khalilov LV 5 最后由 q1215200171 编辑
            THIS IS MY .CONF FILE
            [parameter]
            rtsp_net_type = 1                      #RTSP Network type, 0: "lo", 1: "eth0", 2: "br0", 3: "wlan0"
            stream_buf_size = 0                    #0:default 1/10*yuv420, unit:bytes
            main_isp = 0
            main_vipp = 0
            main_wdr_enable = 0
            main_vi_buf_num = 3
            main_online_en = 0
            sub_isp = 0
            sub_vipp = 4
            sub_src_width = 640
            sub_wdr_enable = 0
            sub_vi_buf_num = 3
            sub_encode_bitrate = 256000            #5M:5242880, 2M:2097152, 1M:1048576, 0.5M:512000
            sub_lapse_encode_bitrate = 256000      #5M:5242880, 2M:2097152, 1M:1048576, 0.5M:512000
            camera_adaptive_moving_and_static_enable = 0
            ve_lens_moving_max_qp = 40
            wb_yuv_enable = 0
            wb_yuv_buf_num = 1
            AND THIS ERROR OUT :
            root@TinaLinux:/mnt/extsd# /mnt/extsd/sample_rtsp -path /mnt/extsd/sample_rtsp.c
            onf
            I0101 03:24:53.447822  1281 sample_rtsp.c:92]               <ParseCmdLine> sample virvi2venc path:[/mnt/extsd/sample_rtsp], arg number is [3]
            I0101 03:24:53.450302  1281 confparser.c:60]                <createConfParser> load conf file /mnt/extsd/sample_rtsp.conf ok!
            I0101 03:24:53.451141  1281 sample_rtsp.c:291]              <loadSampleConfig> IspAndVeLinkageEn:1, AdaptEn:0, LensMoveMaxQp:40
            Committed_AS:       5532 kB
            I0101 03:24:53.459729  1281 mpi_sys.c:842]                  <AW_MPI_SYS_SetConf> kfctmpdir is [/tmp]
            tag   : V1.0 Release
            branch: v5-dev
            date  : 20170725
            author: jenkins
            I0101 03:24:53.463345  1281 mpi_sys.c:1455]                 <AW_MPI_SYS_Init> ISP init
            I0101 03:24:53.464116  1281 isp_version.h:39]               <isp_version_info> [ISP]>>>>>>>>>>>>>>>>>>>> ISP VERSION INFO <<<<<<<<<<<<<<<<<<<
            IPCORE: ISP600
            branch: libisp-dev
            commit: 5b30d9b8f8190196d863bc91576af5356022b433
            date  : Thu Jan 25 17:23:23 2024 +0800
            I0101 03:24:53.464788  1281 mpi_sys.c:1457]                 <AW_MPI_SYS_Init> ISP init done
            I0101 03:24:53.465759  1281 hwdisplay.c:84]                 <hw_display_init>
            I0101 03:24:53.466227  1281 hwdisplay.c:993]                <hwd_init> (hwd_init 993)
            I0101 03:24:53.466883  1281 hwdisplay.c:1048]               <hwd_init> ret[0][2,0]ch[0]lyl[0] init: enable[0], screenwin[0,0, 0x0], zorder[0], alpha[mode:0, value:0]
            I0101 03:24:53.490072  1281 audio_hw.c:189]                 <MakeAllMixerElemsAvailable> pcm open and close, all MixerElems maybe exist.
            I0101 03:24:53.490593  1281 alsa_interface.c:712]           <alsaOpenMixer> open mixer:hw:0
            I0101 03:24:53.492970  1281 alsa_interface.c:767]           <alsaOpenMixer> set playback vol_val to value: 27
            I0101 03:24:53.493490  1281 alsa_interface.c:712]           <alsaOpenMixer> open mixer:hw:1
            I0101 03:24:53.494908  1281 sample_rtsp.c:422]              <configMainStream> main vipp0 ve_online_en:0, dma_buf_num:0, venc ch0 OnlineEnable:0, OnlineShareBufNum:0
            I0101 03:24:53.495407  1281 sample_rtsp.c:449]              <configMainStream> main EncppSharpAttenCoefPer: 100%
            I0101 03:24:53.495558  1281 sample_rtsp.c:463]              <configMainStream> main vbvThreshSize: 147450, vbvBufSize: 933882
            I0101 03:24:53.496132  1281 video.c:107]                    <video_init> [ISP]video device name is vin_video0
            I0101 03:24:53.496365  1281 isp_dev.c:566]                  <isp_video_open> [ISP]open video device[0], detect isp0 success!
            I0101 03:24:53.497176  1281 video.c:1063]                   <video_set_isp_bk_buffer_align> [ISP]video_set_isp_bk_buffer_align yuv_align_en = 0, lbc_align_en = 1
            E0101 03:24:53.497363  1281 video.c:1065]                   <video_set_isp_bk_buffer_align> [ISP_ERR]video0 video_set_isp_bk_buffer_align failed!!!
            I0101 03:24:53.497919  1281 videoInputHw.c:1104]            <videoInputHw_SetChnAttr> ViCh[0] LBC pix:0x3132434c, line_tar_bits[0]:9216, line_tar_bits[1]:13824
            I0101 03:24:53.499319  1281 videoInputHw.c:1124]            <videoInputHw_SetChnAttr> bs_len:61440, frm_bit:11520
            I0101 03:24:53.499939  1286 mpi_sys.c:1073]                 <MonitorEnvVarThread> detect user environment:
            I0101 03:24:53.501282  1286 mpi_sys.c:1074]                 <MonitorEnvVarThread> /tmp/mpp_log_level
            I0101 03:24:53.501455  1286 mpi_sys.c:1075]                 <MonitorEnvVarThread> /tmp/mpp_venc_sei_config_param
            I0101 03:24:53.749066  1281 video.c:172]                    <video_set_fmt> [ISP]video0 fd[9] ve_online_en=0, dma_buf_num=0
            I0101 03:24:53.756470  1281 isp_dev.c:390]                  <isp_tdm_open> [ISP]tdm_rx device name is sunxi_tdm_rx.0
            I0101 03:24:53.757127  1281 isp_dev.c:460]                  <isp_dev_open> [ISP]open isp device[0] success!
            E0101 03:24:53.757316  1281 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
            W0101 03:24:53.758671  1281 isp_helper.c:106]               <isp_ctx_save_init> [ISP_WARN]open /mnt/extsd/isp0_0_0_0_0_gc2053_mipi_ctx_saved.bin failed, err:No such file or directory.
            I0101 03:24:53.758980  1281 isp_ini_parse.c:1650]           <parser_ini_info> [ISP]prefer isp config: [gc2053_mipi], 0x0, 0, 0, 0
            W0101 03:24:53.759608  1281 isp_ini_parse.c:1669]           <parser_ini_info> [ISP_WARN]cannot find gc2053_mipi_0_0_0_0_0 isp config, use gc2053_mipi_1920_1088_20_0_0 -> [gc2053_mipi_isp600_20220511_164617_vlc4_day]
            E0101 03:24:53.762955  1281 isp_manage.c:2575]              <isp_ctx_config_init> [ISP_ERR]sensor attribute is not init.
            I0101 03:24:53.763580  1281 isp.c:1235]                     <isp_run> [ISP]create isp0 server thread!
            E0101 03:24:53.765018  1285 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
            W0101 03:24:53.765190  1285 videoInputHw.c:6258]            <VideoInputHw_CapThread> fatal error! Get isp[0] sensor information failed! must be called AW_MPI_ISP_Run before AW_MPI_VI_EnableVipp.
            I0101 03:24:53.767622  1285 videoInputHw.c:6297]            <VideoInputHw_CapThread> EnableVipp[0]: vfmt.bufs:3, online:0
            E0101 03:24:53.770593  1287 isp_dev.c:718]                  <isp_dev_start> [ISP_ERR]unable to subscribe to tdm event: Not a tty (25).
            I0101 03:24:53.798774  1281 videoInputHw.c:1316]            <videoInputHw_ChnEnable> receive enable vipp[0] reply: 0x0!
            iniparser: cannot open /etc/cedarc.conf
            INFO   : cedarc <cdc_log_set_level:43>: Set log level to 3 from /vendor/etc/cedarc.conf
            DEBUG  : cedarc <LogVersionInfo:44>:
            tag   :
            commit: 3975729c81dab9f05e2722e09e64d018b4b03c44
            date  : Sat Jan 27 15:33:52 2024 +0800
            author: chenyibin
            change-id : I1798fdb3cfa479b7f3eabb212078a906cbe503eb
            release_author : ericwang
            patch :
            DEBUG  : cedarc <VEncoderRegister:1022>: 1117 register 2:h264
            DEBUG  : cedarc <VEncoderRegister:1032>: register codec: '2:h264' success.
            INFO   : cedarc <CedarPluginVENCInit_h264:13347>: register h264 encoder success!
            DEBUG  : cedarc <VEncoderRegister:1022>: 1117 register 3:h265
            DEBUG  : cedarc <VEncoderRegister:1032>: register codec: '3:h265' success.
            INFO   : cedarc <CedarPluginVENCInit_h265:14107>: register h265 encoder success!
            DEBUG  : cedarc <VEncoderRegister:1022>: 1117 register 1:jpeg
            DEBUG  : cedarc <VEncoderRegister:1032>: register codec: '1:jpeg' success.
            INFO   : cedarc <CedarPluginVENCInit_jpeg:3199>: register jpeg encoder success!
            DEBUG  : cedarc <VeInitialize:1138>: shutdown  power up ve
            INFO   : cedarc <VeInitialize:1172>: *** ic_version = 0x1302000023010,
            DEBUG  : cedarc <CdcIniParserInit:36>: cannot parse file: /etc/cedarc.conf
            DEBUG  : cedarc <VeInitialize:1186>: bUseProcessLock = 0, eVeHwLockType = 0
            DEBUG  : cedarc <VeInitialize:1226>: *** nPhyOffset = 0x0
            DEBUG  : cedarc <VeSetSpeed:1734>: *** set ve freq to 400 Mhz ***
            DEBUG  : cedarc <VeInitialize:1281>: ve init ok
            DEBUG  : ionAlloc <__GetIonMemOpsS:965>: *** get __GetIonMemOpsS ***
            DEBUG  : ionAlloc <ion_alloc_open:140>: begin ion_alloc_open
            DEBUG  : ionAlloc <ion_alloc_open:173>: get offset by ve
            DEBUG  : ionAlloc <ion_alloc_open:182>: ** phy offset = 0
            DEBUG  : cedarc <VeRelease:1334>: ve release ok
            DEBUG  : cedarc <CdcMessageQueueCreate:47>: nMessageSize = 20
            DEBUG  : cedarc <H265SetParameter:13635>: VENC_IndexParamProductCase: 0
            I0101 03:24:53.827952  1281 VideoEnc_Component.c:7350]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            I0101 03:24:53.828115  1281 sample_rtsp.c:583]              <configSubStream> vipp[4] crop en:1 X:0 Y:0 W:1888 H:1072
            I0101 03:24:53.828195  1281 sample_rtsp.c:596]              <configSubStream> sub EncppSharpAttenCoefPer: 33%
            I0101 03:24:53.828260  1281 sample_rtsp.c:610]              <configSubStream> sub vbvThreshSize: 24000, vbvBufSize: 152000
            I0101 03:24:53.828396  1281 video.c:107]                    <video_init> [ISP]video device name is vin_video4
            I0101 03:24:53.828618  1281 isp_dev.c:566]                  <isp_video_open> [ISP]open video device[4], detect isp0 success!
            I0101 03:24:53.828803  1281 video.c:1063]                   <video_set_isp_bk_buffer_align> [ISP]video_set_isp_bk_buffer_align yuv_align_en = 0, lbc_align_en = 1
            E0101 03:24:53.828895  1281 video.c:1065]                   <video_set_isp_bk_buffer_align> [ISP_ERR]video4 video_set_isp_bk_buffer_align failed!!!
            I0101 03:24:53.828974  1281 videoInputHw.c:1104]            <videoInputHw_SetChnAttr> ViCh[4] LBC pix:0x3132434c, line_tar_bits[0]:3072, line_tar_bits[1]:4608
            I0101 03:24:53.829261  1281 videoInputHw.c:1124]            <videoInputHw_SetChnAttr> bs_len:20480, frm_bit:3840
            I0101 03:24:54.049307  1281 videoInputHw.c:1390]            <videoInputHw_SetCrop> vipp[4] set crop X:0, Y:0, Width:1888, Height:1072
            E0101 03:24:54.060158  1287 isp_dev.c:274]                  <isp_stat_process_buffer> [ISP_ERR]AEWB: stats error, skipping buffer.
            E0101 03:24:54.063049  1285 videoInputHw.c:5931]            <videoInputHw_GetData> fatal error! LBC wrong data len or buf size, offset_dst:1555200 + data_len:11520 > size:1556224
            E0101 03:24:54.063196  1285 videoInputHw.c:6607]            <VideoInputHw_CapThread> fatal error! videoInpuHw get data fail[0xa0108009], check code!
            E0101 03:24:54.063301  1285 isp_dev.c:956]                  <isp_sensor_get_configs> [ISP_ERR]gc2053_mipi get config failed: Invalid argument (22).
            W0101 03:24:54.063377  1285 videoInputHw.c:6258]            <VideoInputHw_CapThread> fatal error! Get isp[0] sensor information failed! must be called AW_MPI_ISP_Run before AW_MPI_VI_EnableVipp.
            I0101 03:24:54.064129  1285 videoInputHw.c:6297]            <VideoInputHw_CapThread> EnableVipp[4]: vfmt.bufs:3, online:0
            I0101 03:24:54.065692  1281 videoInputHw.c:1316]            <videoInputHw_ChnEnable> receive enable vipp[4] reply: 0x0!
            DEBUG  : cedarc <VencCreate:555>: now cedarc log level:3
            tag   :
            author: chenyibin
            patch :
            DEBUG  : cedarc <VEncoderRegister:1018>: Add '2:h264' fail! '2:h264' already register!
            DEBUG  : cedarc <CedarPluginVENCInit_h264:13351>: h264 encoder had already register!
            DEBUG  : cedarc <VEncoderRegister:1018>: Add '3:h265' fail! '3:h265' already register!
            DEBUG  : cedarc <CedarPluginVENCInit_h265:14111>: h265 encoder had alread  register
            DEBUG  : cedarc <VEncoderRegister:1018>: Add '1:jpeg' fail! '1:jpeg' already register!
            DEBUG  : cedarc <CedarPluginVENCInit_jpeg:3203>: jpeg encoder had already register
            DEBUG  : cedarc <H264EncOpenVer2:10490>: icverion = 0x23010, bIsRegVerE230 = 1
            DEBUG  : cedarc <H264SetParameterVer2:12870>: VENC_IndexParamProductCase: 0
            I0101 03:24:54.080081  1281 VideoEnc_Component.c:7350]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            I0101 03:24:54.080267  1281 sample_rtsp.c:730]              <configSubLapseStream> subLapse EncppSharpAttenCoefPer: 33%
            I0101 03:24:54.080351  1281 sample_rtsp.c:744]              <configSubLapseStream> SubLapse vbvThreshSize: 24000, vbvBufSize: 152000
            tag   :
            author: chenyibin
            patch :
            I0101 03:24:54.094630  1281 sample_rtsp.c:1431]             <main> Lapse set TimeLapse 1000000 us
            I0101 03:24:54.095239  1281 VideoEnc_Component.c:4345]      <VideoEncSetTimeLapse> SetTimeLapse: captureIntervalUs=1000000.000000, dstFrameIntervalUs=50000.000000, recType=1
            I0101 03:24:54.095392  1281 VideoEnc_Component.c:7350]      <VideoEncComponentTunnelRequest> set inputPortTunnelFlag = TRUE
            WARNING: cedarc <CheckSetParamInt:1039>: Notice: sVbrParam.nQuality is 10, but its suggested value is 1 !
            DEBUG  : cedarc <H265SetParameter:13487>: VENC_IndexParamPFrameIntraEn: use_intra_in_p_flag:1
            I0101 03:24:54.096084  1289 VideoEnc_Component.c:823]       <setVbvBufferConfig> user set stream buffer size[933882]bytes
            I0101 03:24:54.096235  1289 VideoEnc_Component.c:833]       <setVbvBufferConfig> user set threshSize[147450]bytes
            I0101 03:24:54.096324  1289 VideoEnc_Component.c:860]       <setVbvBufferConfig> bit rate is 1536Kb, set encode vbv size 933888, frame length threshold 147450
            DEBUG  : cedarc <H265SetParameter:13036>: set rot angle: p_enc->rot_angle = 0...
            DEBUG  : cedarc <H265SetParameter:13627>: VENC_IndexParamIsNightCaseFlag: is_night_case = 0
            I0101 03:24:54.096453  1289 VideoEnc_Component.c:2122]      <CedarvVideoEncInit> DropFrameNum: 0
            I0101 03:24:54.096525  1289 VideoEnc_Component.c:2138]      <CedarvVideoEncInit> VeRecRefBufReduceEnable: 0
            DEBUG  : cedarc <VencInit:803>: func = VencInit, line = 803
            DEBUG  : cedarc <VencInit:816>: bOnlineMode = 1, bOnlineChannel = 0
            DEBUG  : cedarc <VencInit:819>: lbc2.5 = 0, 2.0 = 1, 1.5 = 0, format = 19
            DEBUG  : cedarc <H265Init:11191>: share buf num = 1
            DEBUG  : cedarc <BitStreamCreate:129>: BitStreamCreate OK
            DEBUG  : cedarc <h265InitMemRecRefE230:4296>: recRefQsubDataBufSize = 190976, recRefQsubInfoBufSize = 8608, lbcBusSize = 3067904, lbcMode = 1
            E0101 03:24:54.110896  1287 isp_dev.c:859]                  <isp_sync_debug_info> [ISP_ERR]VIDIOC_VIN_ISP_GET_INFO error!
            W0101 03:24:54.111092  1287 isp.c:450]                      <isp_ctx_get_sensor_info> [ISP_WARN]isp debugfs node not support!!!
