    XR829 wifi 模块启动报错
    • P
      Paul_cdsz LV 3 最后由 编辑
      [10:21:04.788]收←◆1970-01-01 00:00:40:777: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:29]: wpa_supplicant exist
      1970-01-01 00:00:40:777: WMG_DEBUG [src/os/linux/linux_wpa.c:start_supplicant:359]: start wpa_supplicant times 1 success
      1970-01-01 00:00:40:777: WMG_EXCESSIVE [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1436]: start wpa_supplicant success
      1970-01-01 00:00:40:778: WMG_ERROR [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1445]: wpa_supplicant socket interface not exists
      1970-01-01 00:00:40:778: WMG_ERROR [src/wmg_sta.c:sta_mode_enable:416]: failed to connect to wpa_supplicant
      1970-01-01 00:00:40:778: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:297]: wifi sta mode enable faile
      1970-01-01 00:00:40:778: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:320]: switch after current_mode_bitmap:0x0
      1970-01-01 00:00:40:778: WMG_ERROR [src/wmg_common.c:wifimg_switch_mode:327]: switch mode faile
      1970-01-01 00:00:40:778: WMG_ERROR [src/wifimg.c:__wifi_on:34]: failed to switch wifi mode
      1970-01-01 00:00:40:778: WMG_ERROR [wifi_daemon.c:cmd_handle_o:58]: wifi on sta mode failed
      1970-01-01 00:00:40:778: WMG_ERROR [src/wifimg.c:__wifi_sta_connect:74]: wifi station mode is not enabled
      1970-01-01 00:00:40:778: WMG_INFO [wifi_daemon.c:cmd_handle_c:269]: ===Wi-Fi connect use wep===
      1970-01-01 00:00:40:778: WMG_ERROR [wifi_daemon.c:cmd_handle_c:279]: ===Wi-Fi connect failed,time 0.000000 ms===
