    T113 usb0 acm cdc 无法使用 ttyGS0 直接卡主啦
    5259
      leomini5 LV 6 最后由 编辑
      我按照usb开发手册倒腾了一圈,那个ttyGS0 也出了,但是连上pc,没有任何反应
      确认线是好的,setusbconfig adb,adb有效
      修改成 rndis,win10系统无法使用,驱动都是感叹号,貌似是win10就不爱支持这个,要么就是驱动太老啦?反正死活没法联通
      现在寄希望于acm cdc ,但是貌似也没用。。。
      而且我发现这东西编译进内核以后连那个 soc/usb0
      去找usb的role都没有显示的。。。
      下面这个是完整的log,我是在系统加载好以后去用那个acm.sh加载usb0 的 acm cdc,但是不成功
      哪位大佬能够提供一份完整的usb acm cdc,这个功能的教程啊,谢谢啦
      root@TinaLinux:/# [725]fes begin commit:88480af-dirty
      [728]set pll start
      [734]periph0 has been enabled
      [737]set pll end
      [738][pmu]: bus read error
      [741]board init ok
      [743]beign to init dram
      [745]ZQ value = 0x2e
      [747]get_pmu_exist() = -1
      [749]ddr_efuse_type: 0xa
      [752]trefi:7.8ms
      [754][AUTO DEBUG] single rank and full DQ!
      [758]ddr_efuse_type: 0xa
      [760]trefi:7.8ms
      [762][AUTO DEBUG] rank 0 row = 13
      [766][AUTO DEBUG] rank 0 bank = 8
      [769][AUTO DEBUG] rank 0 page size = 2 KB
      [772]DRAM BOOT DRIVE INFO: V0.33
      [775]DRAM CLK = 936 MHz
      [778]DRAM Type = 3 (2:DDR2,3:DDR3)
      [781]DRAMC read ODT  off.
      [783]DRAM ODT value: 0x42.
      [786]ddr_efuse_type: 0xa
      [789]DRAM SIZE =128 M
      [791]dram_tpr4:0x0
      [792]PLL_DDR_CTRL_REG:0xf8004d00
      [795]DRAM_CLK_REG:0xc0000000
      [798][TIMING DEBUG] MR2= 0x20
      [802]DRAM simple test OK.
      [804]rtc standby flag is 0x0, super standby flag is 0x0
      [809]init dram ok
      [29]HELLO! BOOT0 is starting!
      [32]BOOT0 commit : 88480af-dirty
      [35]set pll start
      [41]periph0 has been enabled
      [44]set pll end
      [45][pmu]: bus read error
      [48]board init ok
      [50]ZQ value = 0x2d
      [51]get_pmu_exist() = -1
      [54]DRAM BOOT DRIVE INFO: V0.33
      [57]DRAM CLK = 936 MHz
      [59]DRAM Type = 3 (2:DDR2,3:DDR3)
      [62]DRAMC read ODT  off.
      [64]DRAM ODT value: 0x42.
      [67]ddr_efuse_type: 0xa
      [70]DRAM SIZE =128 M
      [72]dram_tpr4:0x0
      [74]PLL_DDR_CTRL_REG:0xf8004d00
      [77]DRAM_CLK_REG:0xc0000000
      [79][TIMING DEBUG] MR2= 0x20
      [87]DRAM simple test OK.
      [89]rtc standby flag is 0x0, super standby flag is 0x0
      [94]dram size =128
      [97]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [102]block from 8 to 32
      [204]Check is correct.
      [206]dma 0x29c0c int is not used yet
      [209]dma 0x29c0c int is free, you do not need to free it again
      [215]Entry_name        = u-boot
      [222]Entry_name        = optee
      [226]Entry_name        = dtb
      [229]Jump to second Boot.
      M/TC: OP-TEE version: 6aef7bb2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Jul 23 09:                        25:11 UTC 2021 arm
      [    3.968116] printk: console [ttyS0] enabled
      [    3.976979] printk: bootconsole [earlycon0] disabled
      [    3.987894] probe of uart0 returned 1 after 61699 usecs
      [    3.994061] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regula                        tor
      [    4.005353] uart uart1: get regulator failed
      [    4.010158] uart uart1: uart1 supply uart not found, using dummy regulator
      [    4.018114] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
      [    4.027225] probe of uart1 returned 1 after 33470 usecs
      [    4.033260] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regula                        tor
      [    4.044574] uart uart4: get regulator failed
      [    4.049356] uart uart4: uart4 supply uart not found, using dummy regulator
      [    4.057297] uart4: ttyS4 at MMIO 0x2501000 (irq = 36, base_baud = 1500000) is a SUNXI
      [    4.066399] probe of uart4 returned 1 after 33338 usecs
      [    4.072447] initcall sunxi_uart_init+0x0/0x4c returned 0 after 142960 usecs
      [    4.080239] calling  sunxi_dump_reg_driver_init+0x0/0x10 @ 1
      [    4.086794] probe of 20000.dump_reg returned 1 after 215 usecs
      [    4.093572] initcall sunxi_dump_reg_driver_init+0x0/0x10 returned 0 after 6860 usecs
      [    4.102214] calling  misc_dump_reg_init+0x0/0x58 @ 1
      [    4.107746] misc dump reg init
      [    4.111394] initcall misc_dump_reg_init+0x0/0x58 returned 0 after 3550 usecs
      [    4.119267] calling  iommu_debug_init+0x0/0x80 @ 1
      [    4.125106] initcall iommu_debug_init+0x0/0x80 returned 0 after 491 usecs
      [    4.132716] calling  topology_sysfs_init+0x0/0x3c @ 1
      [    4.138447] initcall topology_sysfs_init+0x0/0x3c returned 0 after 93 usecs
      [    4.146219] calling  cacheinfo_sysfs_init+0x0/0x3c @ 1
      [    4.151968] initcall cacheinfo_sysfs_init+0x0/0x3c returned -2 after 21 usecs
      [    4.159928] calling  rfkill_driver_init+0x0/0x18 @ 1
      [    4.165795] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    4.172990] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    4.180268] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    4.187653] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    4.194140] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    4.201041] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    4.208707] sunxi-rfkill soc@3000000:rfkill@0: get gpio wlan_regon failed
      [    4.216292] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    4.224361] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    4.231993] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    4.238733] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    4.246210] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=136 assert=0
      [    4.253799] probe of soc@3000000:rfkill@0 returned 1 after 88123 usecs
      [    4.261150] initcall rfkill_driver_init+0x0/0x18 returned 0 after 93431 usecs
      [    4.269164] calling  addr_mgt_driver_init+0x0/0x18 @ 1
      [    4.275153] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
      [    4.282342] [ADDR_MGT] addr_mgt_probe: success.
      [    4.287552] probe of soc@3000000:addr_mgt@0 returned 1 after 12447 usecs
      [    4.295077] initcall addr_mgt_driver_init+0x0/0x18 returned 0 after 19712 usecs
      [    4.303308] calling  udmabuf_dev_init+0x0/0xc @ 1
      [    4.308783] initcall udmabuf_dev_init+0x0/0xc returned 0 after 210 usecs
      [    4.316241] calling  st_init+0x0/0xe8 @ 1
      [    4.320754] dma-buf: Running sanitycheck
      [    4.325114] dma-buf: Running dma_fence
      [    4.329299] sizeof(dma_fence)=48
      [    4.333003] dma-buf: Running dma_fence/sanitycheck
      [    4.338384] dma-buf: Running dma_fence/test_signaling
      [    4.344000] dma-buf: Running dma_fence/test_add_callback
      [    4.349925] dma-buf: Running dma_fence/test_late_add_callback
      [    4.356330] dma-buf: Running dma_fence/test_rm_callback
      [    4.362149] dma-buf: Running dma_fence/test_late_rm_callback
      [    4.368448] dma-buf: Running dma_fence/test_status
      [    4.373780] dma-buf: Running dma_fence/test_error
      [    4.379019] dma-buf: Running dma_fence/test_wait
      [    4.384155] dma-buf: Running dma_fence/test_wait_timeout
      [    4.426729] dma-buf: Running dma_fence/test_stub
      [    4.431880] dma-buf: Running dma_fence/race_signal_callback
      [    4.506747] thread_signal_callback[0] completed 38180 passes, 14242 misses
      [    4.514424] thread_signal_callback[1] completed 38161 passes, 14223 misses
      [    4.586722] thread_signal_callback[0] completed 39907 passes, 39904 misses
      [    4.594404] thread_signal_callback[1] completed 39921 passes, 39921 misses
      [    4.602182] initcall st_init+0x0/0xe8 returned 0 after 274823 usecs
      [    4.609196] calling  init_sd+0x0/0x1a8 @ 1
      [    4.613913] initcall init_sd+0x0/0x1a8 returned 0 after 150 usecs
      [    4.620734] calling  init_mtd+0x0/0x104 @ 1
      [    4.625638] initcall init_mtd+0x0/0x104 returned 0 after 236 usecs
      [    4.632550] calling  ofpart_parser_init+0x0/0x2c @ 1
      [    4.638103] initcall ofpart_parser_init+0x0/0x2c returned 0 after 1 usecs
      [    4.645654] calling  init_mtdblock+0x0/0xc @ 1
      [    4.650613] initcall init_mtdblock+0x0/0xc returned 0 after 6 usecs
      [    4.657601] calling  aw_spinand_drv_init+0x0/0x10 @ 1
      [    4.663296] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
      [    4.670507] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
      [    4.678356] sunxi-spinand-phy: not detect any munufacture from id table
      [    4.685712] sunxi-spinand-phy: get spi-nand Model from fdt fail
      [    4.692319] sunxi-spinand-phy: get phy info from fdt fail
      [    4.698390] sunxi-spinand-phy: not detect munufacture from fdt
      [    4.705046] sunxi-spinand-phy: detect munufacture from id table: Winbond
      [    4.712536] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [    4.719517] sunxi-spinand-phy: ========== arch info ==========
      [    4.726017] sunxi-spinand-phy: Model:               W25N01GVZEIG
      [    4.732702] sunxi-spinand-phy: Munufacture:         Winbond
      [    4.738908] sunxi-spinand-phy: DieCntPerChip:       1
      [    4.744529] sunxi-spinand-phy: BlkCntPerDie:        1024
      [    4.750441] sunxi-spinand-phy: PageCntPerBlk:       64
      [    4.756153] sunxi-spinand-phy: SectCntPerPage:      4
      [    4.761789] sunxi-spinand-phy: OobSizePerPage:      64
      [    4.767514] sunxi-spinand-phy: BadBlockFlag:        0x0
      [    4.773326] sunxi-spinand-phy: OperationOpt:        0x7
      [    4.779154] sunxi-spinand-phy: MaxEraseTimes:       65000
      [    4.785158] sunxi-spinand-phy: EccFlag:             0x0
      [    4.790970] sunxi-spinand-phy: EccType:             2
      [    4.796586] sunxi-spinand-phy: EccProtectedType:    3
      [    4.802207] sunxi-spinand-phy: ========================================
      [    4.809567] sunxi-spinand-phy:
      [    4.813060] sunxi-spinand-phy: ========== physical info ==========
      [    4.819945] sunxi-spinand-phy: TotalSize:    128 M
      [    4.825270] sunxi-spinand-phy: SectorSize:   512 B
      [    4.830619] sunxi-spinand-phy: PageSize:     2 K
      [    4.835756] sunxi-spinand-phy: BlockSize:    128 K
      [    4.841097] sunxi-spinand-phy: OOBSize:      64 B
      [    4.846333] sunxi-spinand-phy: ========================================
      [    4.853699] sunxi-spinand-phy:
      [    4.857194] sunxi-spinand-phy: ========== logical info ==========
      [    4.863975] sunxi-spinand-phy: TotalSize:    128 M
      [    4.869315] sunxi-spinand-phy: SectorSize:   512 B
      [    4.874639] sunxi-spinand-phy: PageSize:     4 K
      [    4.879773] sunxi-spinand-phy: BlockSize:    256 K
      [    4.885101] sunxi-spinand-phy: OOBSize:      128 B
      [    4.890430] sunxi-spinand-phy: ========================================
      [    4.897910] sunxi-spinand-phy: block lock register: 0x00
      [    4.903935] sunxi-spinand-phy: feature register: 0x19
      [    4.909576] sunxi-spinand-phy: sunxi physic nand init end
      [    4.915984] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    4.922117] 0x000000000000-0x000000100000 : "boot0"
      [    4.937693] 0x000000100000-0x000000400000 : "uboot"
      [    4.946285] random: fast init done
      [    4.957665] 0x000000400000-0x000000500000 : "secure_storage"
      [    4.977701] 0x000000500000-0x000008000000 : "sys"
      [    5.197719] probe of spi0.0 returned 1 after 534467 usecs
      [    5.203793] initcall aw_spinand_drv_init+0x0/0x10 returned 0 after 527894 usecs
      [    5.211961] calling  aw_spinand_debug_init+0x0/0x50 @ 1
      [    5.217821] initcall aw_spinand_debug_init+0x0/0x50 returned 0 after 24 usecs
      [    5.225762] calling  spidev_init+0x0/0xb8 @ 1
      [    5.230749] initcall spidev_init+0x0/0xb8 returned 0 after 117 usecs
      [    5.237845] calling  net_olddevs_init+0x0/0x74 @ 1
      [    5.243192] initcall net_olddevs_init+0x0/0x74 returned 0 after 11 usecs
      [    5.250656] calling  blackhole_netdev_init+0x0/0x84 @ 1
      [    5.256504] initcall blackhole_netdev_init+0x0/0x84 returned 0 after 30 usecs
      [    5.264480] calling  fixed_mdio_bus_init+0x0/0x104 @ 1
      [    5.270507] libphy: Fixed MDIO Bus: probed
      [    5.275076] initcall fixed_mdio_bus_init+0x0/0x104 returned 0 after 4742 usecs
      [    5.283130] calling  phy_module_init+0x0/0x14 @ 1
      [    5.289474] initcall phy_module_init+0x0/0x14 returned 0 after 1057 usecs
      [    5.297065] calling  geth_driver_init+0x0/0x10 @ 1
      [    5.302703] initcall geth_driver_init+0x0/0x10 returned 0 after 287 usecs
      [    5.310280] calling  dwc2_platform_driver_init+0x0/0x10 @ 1
      [    5.317134] initcall dwc2_platform_driver_init+0x0/0x10 returned 0 after 631 usecs
      [    5.325566] calling  ehci_hcd_init+0x0/0x70 @ 1
      [    5.330611] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    5.337888] initcall ehci_hcd_init+0x0/0x70 returned 0 after 7101 usecs
      [    5.345248] calling  ehci_platform_init+0x0/0x54 @ 1
      [    5.350782] ehci-platform: EHCI generic platform driver
      [    5.356922] initcall ehci_platform_init+0x0/0x54 returned 0 after 5984 usecs
      [    5.364768] calling  sunxi_ehci_hcd_init+0x0/0x5c @ 1
      [    5.370403] sunxi-ehci: EHCI SUNXI driver
      [    5.375300] get ehci0-controller wakeup-source is fail.
      [    5.381231] sunxi ehci0-controller don't init wakeup source
      [    5.387462] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c68db0, 0x:c88390                        00, irq_no:3a
      [    5.399370] [sunxi-ehci0]: Not init ehci0
      [    5.403930] probe of 4101000.ehci0-controller returned 1 after 28808 usecs
      [    5.411782] get ehci1-controller wakeup-source is fail.
      [    5.417700] sunxi ehci1-controller don't init wakeup source
      [    5.423909] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c692d0, 0x:c883d0                        00, irq_no:3c
      [    5.435847] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using                         dummy regulator
      [    5.448280] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dum                        my regulator
      [    5.460405] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    5.467627] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    5.477502] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
      [    5.506743] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    5.515353] hub 1-0:1.0: USB hub found
      [    5.519593] hub 1-0:1.0: 1 port detected
      [    5.524218] probe of 1-0:1.0 returned 1 after 8889 usecs
      [    5.530309] probe of usb1 returned 1 after 15185 usecs
      [    5.536183] probe of 4200000.ehci1-controller returned 1 after 124570 usecs
      [    5.544063] initcall sunxi_ehci_hcd_init+0x0/0x5c returned 0 after 169577 usecs
      [    5.552213] calling  ohci_hcd_mod_init+0x0/0x64 @ 1
      [    5.557641] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    5.564545] initcall ohci_hcd_mod_init+0x0/0x64 returned 0 after 6737 usecs
      [    5.572304] calling  ohci_platform_init+0x0/0x54 @ 1
      [    5.577832] ohci-platform: OHCI generic platform driver
      [    5.583963] initcall ohci_platform_init+0x0/0x54 returned 0 after 5977 usecs
      [    5.591822] calling  sunxi_ohci_hcd_init+0x0/0x5c @ 1
      [    5.597450] sunxi-ohci: OHCI SUNXI driver
      [    5.602346] get ohci0-controller wakeup-source is fail.
      [    5.608294] sunxi ohci0-controller don't init wakeup source
      [    5.614497] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c69040
      [    5.624094] [sunxi-ohci0]: Not init ohci0
      [    5.628672] probe of 4101400.ohci0-controller returned 1 after 26501 usecs
      [    5.636512] get ohci1-controller wakeup-source is fail.
      [    5.642447] sunxi ohci1-controller don't init wakeup source
      [    5.648678] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c69560
      [    5.658292] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using                         dummy regulator
      [    5.670703] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dum                        my regulator
      [    5.682817] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    5.690031] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    5.699794] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
      [    5.781632] hub 2-0:1.0: USB hub found
      [    5.785845] hub 2-0:1.0: 1 port detected
      [    5.790492] probe of 2-0:1.0 returned 1 after 8897 usecs
      [    5.796552] probe of usb2 returned 1 after 15164 usecs
      [    5.802459] probe of 4200400.ohci1-controller returned 1 after 166114 usecs
      [    5.810338] initcall sunxi_ohci_hcd_init+0x0/0x5c returned 0 after 207883 usecs
      [    5.818486] calling  acm_init+0x0/0x114 @ 1
      [    5.823245] usbcore: registered new interface driver cdc_acm
      [    5.829557] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    5.838475] initcall acm_init+0x0/0x114 returned 0 after 14964 usecs
      [    5.845547] calling  ci_hdrc_platform_register+0x0/0x1c @ 1
      [    5.851907] initcall ci_hdrc_platform_register+0x0/0x1c returned 0 after 141 usecs
      [    5.860350] calling  ci_hdrc_usb2_driver_init+0x0/0x10 @ 1
      [    5.866739] initcall ci_hdrc_usb2_driver_init+0x0/0x10 returned 0 after 267 usecs
      [    5.875073] calling  ci_hdrc_msm_driver_init+0x0/0x10 @ 1
      [    5.881314] initcall ci_hdrc_msm_driver_init+0x0/0x10 returned 0 after 199 usecs
      [    5.889565] calling  ci_hdrc_zevio_driver_init+0x0/0x10 @ 1
      [    5.895957] initcall ci_hdrc_zevio_driver_init+0x0/0x10 returned 0 after 182 usecs
      [    5.904402] calling  usbmisc_imx_driver_init+0x0/0x10 @ 1
      [    5.910936] initcall usbmisc_imx_driver_init+0x0/0x10 returned 0 after 499 usecs
      [    5.919187] calling  ci_hdrc_imx_driver_init+0x0/0x10 @ 1
      [    5.925636] initcall ci_hdrc_imx_driver_init+0x0/0x10 returned 0 after 426 usecs
      [    5.933883] calling  tegra_udc_driver_init+0x0/0x10 @ 1
      [    5.939991] initcall tegra_udc_driver_init+0x0/0x10 returned 0 after 277 usecs
      [    5.948047] calling  gadget_cfs_init+0x0/0x48 @ 1
      [    5.953528] initcall gadget_cfs_init+0x0/0x48 returned 0 after 237 usecs
      [    5.961019] calling  acmmod_init+0x0/0xc @ 1
      [    5.965772] initcall acmmod_init+0x0/0xc returned 0 after 1 usecs
      [    5.972567] calling  userial_init+0x0/0x124 @ 1
      [    5.977634] initcall userial_init+0x0/0x124 returned 0 after 10 usecs
      [    5.984801] calling  gsermod_init+0x0/0xc @ 1
      [    5.989658] initcall gsermod_init+0x0/0xc returned 0 after 1 usecs
      [    5.996535] calling  rndismod_init+0x0/0xc @ 1
      [    6.001489] initcall rndismod_init+0x0/0xc returned 0 after 0 usecs
      [    6.008472] calling  ffsmod_init+0x0/0xc @ 1
      [    6.013220] initcall ffsmod_init+0x0/0xc returned 0 after 0 usecs
      [    6.020005] calling  hidmod_init+0x0/0xc @ 1
      [    6.024755] initcall hidmod_init+0x0/0xc returned 0 after 1 usecs
      [    6.031540] calling  evdev_init+0x0/0xc @ 1
      [    6.036196] initcall evdev_init+0x0/0xc returned 0 after 2 usecs
      [    6.042883] calling  i2c_dev_init+0x0/0xb8 @ 1
      [    6.047825] i2c /dev entries driver
      [    6.051756] initcall i2c_dev_init+0x0/0xb8 returned 0 after 3830 usecs
      [    6.059037] calling  init_rc_map_adstech_dvb_t_pci+0x0/0xc @ 1
      [    6.065522] initcall init_rc_map_adstech_dvb_t_pci+0x0/0xc returned 0 after 1 usecs
      [    6.074052] calling  init_rc_map_alink_dtu_m+0x0/0xc @ 1
      [    6.079977] initcall init_rc_map_alink_dtu_m+0x0/0xc returned 0 after 0 usecs
      [    6.087931] calling  init_rc_map_anysee+0x0/0xc @ 1
      [    6.093360] initcall init_rc_map_anysee+0x0/0xc returned 0 after 0 usecs
      [    6.100826] calling  init_rc_map_apac_viewcomp+0x0/0xc @ 1
      [    6.106942] initcall init_rc_map_apac_viewcomp+0x0/0xc returned 0 after 0 usecs
      [    6.115074] calling  init_rc_map_t2hybrid+0x0/0xc @ 1
      [    6.120703] initcall init_rc_map_t2hybrid+0x0/0xc returned 0 after 0 usecs
      [    6.128363] calling  init_rc_map_asus_pc39+0x0/0xc @ 1
      [    6.134078] initcall init_rc_map_asus_pc39+0x0/0xc returned 0 after 0 usecs
      [    6.141829] calling  init_rc_map_asus_ps3_100+0x0/0xc @ 1
      [    6.147845] initcall init_rc_map_asus_ps3_100+0x0/0xc returned 0 after 0 usecs
      [    6.155877] calling  init_rc_map_ati_tv_wonder_hd_600+0x0/0xc @ 1
      [    6.162662] initcall init_rc_map_ati_tv_wonder_hd_600+0x0/0xc returned 0 after 0 usecs
      [    6.171478] calling  init_rc_map_ati_x10+0x0/0xc @ 1
      [    6.177015] initcall init_rc_map_ati_x10+0x0/0xc returned 0 after 0 usecs
      [    6.184568] calling  init_rc_map_avermedia_a16d+0x0/0xc @ 1
      [    6.190777] initcall init_rc_map_avermedia_a16d+0x0/0xc returned 0 after 0 usecs
      [    6.199013] calling  init_rc_map_avermedia+0x0/0xc @ 1
      [    6.204728] initcall init_rc_map_avermedia+0x0/0xc returned 0 after 0 usecs
      [    6.212482] calling  init_rc_map_avermedia_cardbus+0x0/0xc @ 1
      [    6.218986] initcall init_rc_map_avermedia_cardbus+0x0/0xc returned 0 after 0 usecs
      [    6.227514] calling  init_rc_map_avermedia_dvbt+0x0/0xc @ 1
      [    6.233708] initcall init_rc_map_avermedia_dvbt+0x0/0xc returned 0 after 0 usecs
      [    6.241947] calling  init_rc_map_avermedia_m135a+0x0/0xc @ 1
      [    6.248252] initcall init_rc_map_avermedia_m135a+0x0/0xc returned 0 after 0 usecs
      [    6.256572] calling  init_rc_map_avermedia_m733a_rm_k6+0x0/0xc @ 1
      [    6.263454] initcall init_rc_map_avermedia_m733a_rm_k6+0x0/0xc returned 0 after 0 usecs
      [    6.272369] calling  init_rc_map_avermedia_rm_ks+0x0/0xc @ 1
      [    6.278678] initcall init_rc_map_avermedia_rm_ks+0x0/0xc returned 0 after 0 usecs
      [    6.287012] calling  init_rc_map_avertv_303+0x0/0xc @ 1
      [    6.292826] initcall init_rc_map_avertv_303+0x0/0xc returned 0 after 0 usecs
      [    6.300692] calling  init_rc_map_azurewave_ad_tu700+0x0/0xc @ 1
      [    6.307296] initcall init_rc_map_azurewave_ad_tu700+0x0/0xc returned 0 after 0 usecs
      [    6.315909] calling  init_rc_map_behold+0x0/0xc @ 1
      [    6.321347] initcall init_rc_map_behold+0x0/0xc returned 0 after 0 usecs
      [    6.328810] calling  init_rc_map_behold_columbus+0x0/0xc @ 1
      [    6.335105] initcall init_rc_map_behold_columbus+0x0/0xc returned 0 after 0 usecs
      [    6.343437] calling  init_rc_map_budget_ci_old+0x0/0xc @ 1
      [    6.349546] initcall init_rc_map_budget_ci_old+0x0/0xc returned 0 after 0 usecs
      [    6.357685] calling  init_rc_map_cec+0x0/0xc @ 1
      [    6.362821] initcall init_rc_map_cec+0x0/0xc returned 0 after 0 usecs
      [    6.369992] calling  init_rc_map_cinergy_1400+0x0/0xc @ 1
      [    6.375997] initcall init_rc_map_cinergy_1400+0x0/0xc returned 0 after 0 usecs
      [    6.384046] calling  init_rc_map_cinergy+0x0/0xc @ 1
      [    6.389579] initcall init_rc_map_cinergy+0x0/0xc returned 0 after 0 usecs
      [    6.397145] calling  init_rc_map_d680_dmb+0x0/0xc @ 1
      [    6.402762] initcall init_rc_map_d680_dmb+0x0/0xc returned 0 after 0 usecs
      [    6.410418] calling  init_rc_map_delock_61959+0x0/0xc @ 1
      [    6.416432] initcall init_rc_map_delock_61959+0x0/0xc returned 0 after 0 usecs
      [    6.424474] calling  init_rc_map+0x0/0xc @ 1
      [    6.429235] initcall init_rc_map+0x0/0xc returned 0 after 0 usecs
      [    6.436012] calling  init_rc_map+0x0/0xc @ 1
      [    6.440776] initcall init_rc_map+0x0/0xc returned 0 after 0 usecs
      [    6.447564] calling  init_rc_map_digitalnow_tinytwin+0x0/0xc @ 1
      [    6.454246] initcall init_rc_map_digitalnow_tinytwin+0x0/0xc returned 0 after 0 usecs
      [    6.462969] calling  init_rc_map_digittrade+0x0/0xc @ 1
      [    6.468794] initcall init_rc_map_digittrade+0x0/0xc returned 0 after 0 usecs
      [    6.476634] calling  init_rc_map_dm1105_nec+0x0/0xc @ 1
      [    6.482464] initcall init_rc_map_dm1105_nec+0x0/0xc returned 0 after 0 usecs
      [    6.490316] calling  init_rc_map_dntv_live_dvb_t+0x0/0xc @ 1
      [    6.496610] initcall init_rc_map_dntv_live_dvb_t+0x0/0xc returned 0 after 0 usecs
      [    6.504940] calling  init_rc_map_dntv_live_dvbt_pro+0x0/0xc @ 1
      [    6.511531] initcall init_rc_map_dntv_live_dvbt_pro+0x0/0xc returned 0 after 0 usecs
      [    6.520154] calling  init_rc_map_dtt200u+0x0/0xc @ 1
      [    6.525676] initcall init_rc_map_dtt200u+0x0/0xc returned 0 after 0 usecs
      [    6.533237] calling  init_rc_map_rc5_dvbsky+0x0/0xc @ 1
      [    6.539058] initcall init_rc_map_rc5_dvbsky+0x0/0xc returned 0 after 0 usecs
      [    6.546905] calling  init_rc_map_dvico_mce+0x0/0xc @ 1
      [    6.552619] initcall init_rc_map_dvico_mce+0x0/0xc returned 0 after 0 usecs
      [    6.560372] calling  init_rc_map_dvico_portable+0x0/0xc @ 1
      [    6.566571] initcall init_rc_map_dvico_portable+0x0/0xc returned 0 after 0 usecs
      [    6.574813] calling  init_rc_map_em_terratec+0x0/0xc @ 1
      [    6.580736] initcall init_rc_map_em_terratec+0x0/0xc returned 0 after 0 usecs
      [    6.588686] calling  init_rc_map_encore_enltv2+0x0/0xc @ 1
      [    6.594785] initcall init_rc_map_encore_enltv2+0x0/0xc returned 0 after 0 usecs
      [    6.602922] calling  init_rc_map_encore_enltv+0x0/0xc @ 1
      [    6.608936] initcall init_rc_map_encore_enltv+0x0/0xc returned 0 after 0 usecs
      [    6.616984] calling  init_rc_map_encore_enltv_fm53+0x0/0xc @ 1
      [    6.623474] initcall init_rc_map_encore_enltv_fm53+0x0/0xc returned 0 after 0 usecs
      [    6.632001] calling  init_rc_map_evga_indtube+0x0/0xc @ 1
      [    6.638018] initcall init_rc_map_evga_indtube+0x0/0xc returned 0 after 0 usecs
      [    6.646053] calling  init_rc_map_eztv+0x0/0xc @ 1
      [    6.651293] initcall init_rc_map_eztv+0x0/0xc returned 0 after 0 usecs
      [    6.658567] calling  init_rc_map_flydvb+0x0/0xc @ 1
      [    6.663995] initcall init_rc_map_flydvb+0x0/0xc returned 0 after 0 usecs
      [    6.671454] calling  init_rc_map_flyvideo+0x0/0xc @ 1
      [    6.677100] initcall init_rc_map_flyvideo+0x0/0xc returned 0 after 0 usecs
      [    6.684748] calling  init_rc_map_fusionhdtv_mce+0x0/0xc @ 1
      [    6.690959] initcall init_rc_map_fusionhdtv_mce+0x0/0xc returned 0 after 0 usecs
      [    6.699205] calling  init_rc_map_gadmei_rm008z+0x0/0xc @ 1
      [    6.705309] initcall init_rc_map_gadmei_rm008z+0x0/0xc returned 0 after 0 usecs
      [    6.713451] calling  init_rc_map_geekbox+0x0/0xc @ 1
      [    6.718980] initcall init_rc_map_geekbox+0x0/0xc returned 0 after 0 usecs
      [    6.726530] calling  init_rc_map_genius_tvgo_a11mce+0x0/0xc @ 1
      [    6.733128] initcall init_rc_map_genius_tvgo_a11mce+0x0/0xc returned 0 after 0 usecs
      [    6.741751] calling  init_rc_map_gotview7135+0x0/0xc @ 1
      [    6.747670] initcall init_rc_map_gotview7135+0x0/0xc returned 0 after 0 usecs
      [    6.755606] calling  init_rc_map_hisi_poplar+0x0/0xc @ 1
      [    6.761527] initcall init_rc_map_hisi_poplar+0x0/0xc returned 0 after 0 usecs
      [    6.769475] calling  init_rc_map_hisi_tv_demo+0x0/0xc @ 1
      [    6.775483] initcall init_rc_map_hisi_tv_demo+0x0/0xc returned 0 after 0 usecs
      [    6.783531] calling  init_rc_map_imon_mce+0x0/0xc @ 1
      [    6.789160] initcall init_rc_map_imon_mce+0x0/0xc returned 0 after 0 usecs
      [    6.796815] calling  init_rc_map_imon_pad+0x0/0xc @ 1
      [    6.802435] initcall init_rc_map_imon_pad+0x0/0xc returned 0 after 0 usecs
      [    6.810098] calling  init_rc_map_imon_rsc+0x0/0xc @ 1
      [    6.815716] initcall init_rc_map_imon_rsc+0x0/0xc returned 0 after 0 usecs
      [    6.823371] calling  init_rc_map_iodata_bctv7e+0x0/0xc @ 1
      [    6.829484] initcall init_rc_map_iodata_bctv7e+0x0/0xc returned 0 after 0 usecs
      [    6.837624] calling  init_rc_it913x_v1_map+0x0/0xc @ 1
      [    6.843339] initcall init_rc_it913x_v1_map+0x0/0xc returned 0 after 0 usecs
      [    6.851097] calling  init_rc_it913x_v2_map+0x0/0xc @ 1
      [    6.856824] initcall init_rc_it913x_v2_map+0x0/0xc returned 0 after 0 usecs
      [    6.864568] calling  init_rc_map_kaiomy+0x0/0xc @ 1
      [    6.870010] initcall init_rc_map_kaiomy+0x0/0xc returned 0 after 0 usecs
      [    6.877481] calling  init_rc_map_khadas+0x0/0xc @ 1
      [    6.882910] initcall init_rc_map_khadas+0x0/0xc returned 0 after 0 usecs
      [    6.890372] calling  init_rc_map_kworld_315u+0x0/0xc @ 1
      [    6.896284] initcall init_rc_map_kworld_315u+0x0/0xc returned 0 after 0 usecs
      [    6.904231] calling  init_rc_map_kworld_pc150u+0x0/0xc @ 1
      [    6.910340] initcall init_rc_map_kworld_pc150u+0x0/0xc returned 0 after 0 usecs
      [    6.918490] calling  init_rc_map_kworld_plus_tv_analog+0x0/0xc @ 1
      [    6.925369] initcall init_rc_map_kworld_plus_tv_analog+0x0/0xc returned 0 after 0 usecs
      [    6.934281] calling  init_rc_map_leadtek_y04g0051+0x0/0xc @ 1
      [    6.940689] initcall init_rc_map_leadtek_y04g0051+0x0/0xc returned 0 after 0 usecs
      [    6.949122] calling  init_rc_lme2510_map+0x0/0xc @ 1
      [    6.954643] initcall init_rc_lme2510_map+0x0/0xc returned 0 after 0 usecs
      [    6.962199] calling  init_rc_map_manli+0x0/0xc @ 1
      [    6.967542] initcall init_rc_map_manli+0x0/0xc returned 0 after 0 usecs
      [    6.974898] calling  init_rc_map_medion_x10+0x0/0xc @ 1
      [    6.980729] initcall init_rc_map_medion_x10+0x0/0xc returned 0 after 0 usecs
      [    6.988580] calling  init_rc_map_medion_x10_digitainer+0x0/0xc @ 1
      [    6.995454] initcall init_rc_map_medion_x10_digitainer+0x0/0xc returned 0 after 0 usecs
      [    7.004377] calling  init_rc_map_medion_x10_or2x+0x0/0xc @ 1
      [    7.010682] initcall init_rc_map_medion_x10_or2x+0x0/0xc returned 0 after 0 usecs
      [    7.019016] calling  init_rc_map_msi_digivox_ii+0x0/0xc @ 1
      [    7.025215] initcall init_rc_map_msi_digivox_ii+0x0/0xc returned 0 after 0 usecs
      [    7.033447] calling  init_rc_map_msi_digivox_iii+0x0/0xc @ 1
      [    7.039754] initcall init_rc_map_msi_digivox_iii+0x0/0xc returned 0 after 0 usecs
      [    7.048088] calling  init_rc_map_msi_tvanywhere+0x0/0xc @ 1
      [    7.054286] initcall init_rc_map_msi_tvanywhere+0x0/0xc returned 0 after 0 usecs
      [    7.062520] calling  init_rc_map_msi_tvanywhere_plus+0x0/0xc @ 1
      [    7.069209] initcall init_rc_map_msi_tvanywhere_plus+0x0/0xc returned 0 after 0 usecs
      [    7.077937] calling  init_rc_map_nebula+0x0/0xc @ 1
      [    7.083360] initcall init_rc_map_nebula+0x0/0xc returned 0 after 0 usecs
      [    7.090827] calling  init_rc_map_nec_terratec_cinergy_xs+0x0/0xc @ 1
      [    7.097909] initcall init_rc_map_nec_terratec_cinergy_xs+0x0/0xc returned 0 after 0 usecs
      [    7.107023] calling  init_rc_map_norwood+0x0/0xc @ 1
      [    7.112545] initcall init_rc_map_norwood+0x0/0xc returned 0 after 0 usecs
      [    7.120106] calling  init_rc_map_npgtech+0x0/0xc @ 1
      [    7.125629] initcall init_rc_map_npgtech+0x0/0xc returned 0 after 0 usecs
      [    7.133191] calling  init_rc_map_odroid+0x0/0xc @ 1
      [    7.138624] initcall init_rc_map_odroid+0x0/0xc returned 0 after 0 usecs
      [    7.146082] calling  init_rc_map_pctv_sedna+0x0/0xc @ 1
      [    7.151914] initcall init_rc_map_pctv_sedna+0x0/0xc returned 0 after 0 usecs
      [    7.159766] calling  init_rc_map_pinnacle_color+0x0/0xc @ 1
      [    7.165965] initcall init_rc_map_pinnacle_color+0x0/0xc returned 0 after 0 usecs
      [    7.174205] calling  init_rc_map_pinnacle_grey+0x0/0xc @ 1
      [    7.180323] initcall init_rc_map_pinnacle_grey+0x0/0xc returned 0 after 0 usecs
      [    7.188472] calling  init_rc_map_pinnacle_pctv_hd+0x0/0xc @ 1
      [    7.194863] initcall init_rc_map_pinnacle_pctv_hd+0x0/0xc returned 0 after 0 usecs
      [    7.203296] calling  init_rc_map_pixelview+0x0/0xc @ 1
      [    7.209023] initcall init_rc_map_pixelview+0x0/0xc returned 0 after 0 usecs
      [    7.216782] calling  init_rc_map_pixelview+0x0/0xc @ 1
      [    7.222502] initcall init_rc_map_pixelview+0x0/0xc returned 0 after 0 usecs
      [    7.230256] calling  init_rc_map_pixelview+0x0/0xc @ 1
      [    7.235971] initcall init_rc_map_pixelview+0x0/0xc returned 0 after 0 usecs
      [    7.243723] calling  init_rc_map_pixelview_new+0x0/0xc @ 1
      [    7.249836] initcall init_rc_map_pixelview_new+0x0/0xc returned 0 after 0 usecs
      [    7.257997] calling  init_rc_map_powercolor_real_angel+0x0/0xc @ 1
      [    7.264873] initcall init_rc_map_powercolor_real_angel+0x0/0xc returned 0 after 0 usecs
      [    7.273789] calling  init_rc_map_proteus_2309+0x0/0xc @ 1
      [    7.279807] initcall init_rc_map_proteus_2309+0x0/0xc returned 0 after 0 usecs
      [    7.287854] calling  init_rc_map_purpletv+0x0/0xc @ 1
      [    7.293476] initcall init_rc_map_purpletv+0x0/0xc returned 0 after 0 usecs
      [    7.301133] calling  init_rc_map_pv951+0x0/0xc @ 1
      [    7.306462] initcall init_rc_map_pv951+0x0/0xc returned 0 after 0 usecs
      [    7.313829] calling  init_rc_map_rc5_hauppauge_new+0x0/0xc @ 1
      [    7.320329] initcall init_rc_map_rc5_hauppauge_new+0x0/0xc returned 0 after 0 usecs
      [    7.328857] calling  init_rc_map_rc6_mce+0x0/0xc @ 1
      [    7.334375] initcall init_rc_map_rc6_mce+0x0/0xc returned 0 after 0 usecs
      [    7.341936] calling  init_rc_map_real_audio_220_32_keys+0x0/0xc @ 1
      [    7.348920] initcall init_rc_map_real_audio_220_32_keys+0x0/0xc returned 0 after 0 usecs
      [    7.357931] calling  init_rc_map_reddo+0x0/0xc @ 1
      [    7.363266] initcall init_rc_map_reddo+0x0/0xc returned 0 after 0 usecs
      [    7.370634] calling  init_rc_map_snapstream_firefly+0x0/0xc @ 1
      [    7.377235] initcall init_rc_map_snapstream_firefly+0x0/0xc returned 0 after 0 usecs
      [    7.385846] calling  init_rc_map_streamzap+0x0/0xc @ 1
      [    7.391574] initcall init_rc_map_streamzap+0x0/0xc returned 0 after 0 usecs
      [    7.399330] calling  init_rc_map_tango+0x0/0xc @ 1
      [    7.404658] initcall init_rc_map_tango+0x0/0xc returned 0 after 0 usecs
      [    7.412033] calling  init_rc_map_tanix_tx3mini+0x0/0xc @ 1
      [    7.418145] initcall init_rc_map_tanix_tx3mini+0x0/0xc returned 0 after 0 usecs
      [    7.426276] calling  init_rc_map_tanix_tx5max+0x0/0xc @ 1
      [    7.432291] initcall init_rc_map_tanix_tx5max+0x0/0xc returned 0 after 0 usecs
      [    7.440338] calling  init_rc_map_tbs_nec+0x0/0xc @ 1
      [    7.445860] initcall init_rc_map_tbs_nec+0x0/0xc returned 0 after 0 usecs
      [    7.453421] calling  init_rc_map+0x0/0xc @ 1
      [    7.458181] initcall init_rc_map+0x0/0xc returned 0 after 0 usecs
      [    7.464959] calling  init_rc_map+0x0/0xc @ 1
      [    7.469722] initcall init_rc_map+0x0/0xc returned 0 after 0 usecs
      [    7.476500] calling  init_rc_map_terratec_cinergy_c_pci+0x0/0xc @ 1
      [    7.483487] initcall init_rc_map_terratec_cinergy_c_pci+0x0/0xc returned 0 after 0 usecs
      [    7.492495] calling  init_rc_map_terratec_cinergy_s2_hd+0x0/0xc @ 1
      [    7.499482] initcall init_rc_map_terratec_cinergy_s2_hd+0x0/0xc returned 0 after 0 usecs
      [    7.508496] calling  init_rc_map_terratec_cinergy_xs+0x0/0xc @ 1
      [    7.515179] initcall init_rc_map_terratec_cinergy_xs+0x0/0xc returned 0 after 0 usecs
      [    7.523893] calling  init_rc_map_terratec_slim+0x0/0xc @ 1
      [    7.530005] initcall init_rc_map_terratec_slim+0x0/0xc returned 0 after 0 usecs
      [    7.538145] calling  init_rc_map_terratec_slim_2+0x0/0xc @ 1
      [    7.544443] initcall init_rc_map_terratec_slim_2+0x0/0xc returned 0 after 0 usecs
      [    7.552780] calling  init_rc_map_tevii_nec+0x0/0xc @ 1
      [    7.558505] initcall init_rc_map_tevii_nec+0x0/0xc returned 0 after 0 usecs
      [    7.566249] calling  init_rc_map_tivo+0x0/0xc @ 1
      [    7.571492] initcall init_rc_map_tivo+0x0/0xc returned 0 after 0 usecs
      [    7.578768] calling  init_rc_map_total_media_in_hand+0x0/0xc @ 1
      [    7.585452] initcall init_rc_map_total_media_in_hand+0x0/0xc returned 0 after 0 usecs
      [    7.594170] calling  init_rc_map_total_media_in_hand_02+0x0/0xc @ 1
      [    7.601150] initcall init_rc_map_total_media_in_hand_02+0x0/0xc returned 0 after 0 usecs
      [    7.610160] calling  init_rc_map_trekstor+0x0/0xc @ 1
      [    7.615777] initcall init_rc_map_trekstor+0x0/0xc returned 0 after 0 usecs
      [    7.623440] calling  init_rc_map_tt_1500+0x0/0xc @ 1
      [    7.628972] initcall init_rc_map_tt_1500+0x0/0xc returned 0 after 0 usecs
      [    7.636523] calling  init_rc_map_twinhan_dtv_cab_ci+0x0/0xc @ 1
      [    7.643127] initcall init_rc_map_twinhan_dtv_cab_ci+0x0/0xc returned 0 after 0 usecs
      [    7.651749] calling  init_rc_map_twinhan_vp1027+0x0/0xc @ 1
      [    7.657962] initcall init_rc_map_twinhan_vp1027+0x0/0xc returned 0 after 0 usecs
      [    7.666187] calling  init_rc_map_videomate_k100+0x0/0xc @ 1
      [    7.672401] initcall init_rc_map_videomate_k100+0x0/0xc returned 0 after 0 usecs
      [    7.680641] calling  init_rc_map_videomate_s350+0x0/0xc @ 1
      [    7.686852] initcall init_rc_map_videomate_s350+0x0/0xc returned 0 after 0 usecs
      [    7.695096] calling  init_rc_map_videomate_tv_pvr+0x0/0xc @ 1
      [    7.701500] initcall init_rc_map_videomate_tv_pvr+0x0/0xc returned 0 after 0 usecs
      [    7.709933] calling  init_rc_map_kii_pro+0x0/0xc @ 1
      [    7.715458] initcall init_rc_map_kii_pro+0x0/0xc returned 0 after 0 usecs
      [    7.723021] calling  init_rc_map_wetek_hub+0x0/0xc @ 1
      [    7.728754] initcall init_rc_map_wetek_hub+0x0/0xc returned 0 after 0 usecs
      [    7.736496] calling  init_rc_map_wetek_play2+0x0/0xc @ 1
      [    7.742415] initcall init_rc_map_wetek_play2+0x0/0xc returned 0 after 0 usecs
      [    7.750361] calling  init_rc_map_winfast+0x0/0xc @ 1
      [    7.755881] initcall init_rc_map_winfast+0x0/0xc returned 0 after 0 usecs
      [    7.763437] calling  init_rc_map_winfast_usbii_deluxe+0x0/0xc @ 1
      [    7.770222] initcall init_rc_map_winfast_usbii_deluxe+0x0/0xc returned 0 after 0 usecs
      [    7.779044] calling  init_rc_map_su3000+0x0/0xc @ 1
      [    7.784464] initcall init_rc_map_su3000+0x0/0xc returned 0 after 0 usecs
      [    7.791923] calling  init_rc_map+0x0/0xc @ 1
      [    7.796672] initcall init_rc_map+0x0/0xc returned 0 after 0 usecs
      [    7.803456] calling  init_rc_map_x96max+0x0/0xc @ 1
      [    7.808892] initcall init_rc_map_x96max+0x0/0xc returned 0 after 0 usecs
      [    7.816343] calling  init_rc_map_zx_irdec+0x0/0xc @ 1
      [    7.821971] initcall init_rc_map_zx_irdec+0x0/0xc returned 0 after 0 usecs
      [    7.829622] calling  sunxi_cedar_init+0x0/0x24 @ 1
      [    7.834945] sunxi cedar version 1.1
      [    7.839033] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    7.845263] VE: sunxi_cedar_probe power-domain init!!!
      [    7.851007] VE: install start!!!
      [    7.851007]
      [    7.856591] VE: cedar-ve the get irq is 42
      [    7.856591]
      [    7.863035] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    7.863035]
      [    7.872258] VE: install end!!!
      [    7.872258]
      [    7.877317] VE: sunxi_cedar_probe
      [    7.881113] probe of 1c0e000.ve returned 1 after 42159 usecs
      [    7.887632] initcall sunxi_cedar_init+0x0/0x24 returned 0 after 51436 usecs
      [    7.895385] calling  hci_uart_init+0x0/0xe0 @ 1
      [    7.900444] Bluetooth: HCI UART driver ver 2.3
      [    7.905390] Bluetooth: HCI UART protocol H4 registered
      [    7.911119] Bluetooth: HCI UART protocol BCSP registered
      [    7.917039] initcall hci_uart_init+0x0/0xe0 returned 0 after 16202 usecs
      [    7.924491] calling  mmc_pwrseq_simple_driver_init+0x0/0x10 @ 1
      [    7.931325] initcall mmc_pwrseq_simple_driver_init+0x0/0x10 returned 0 after 229 usecs
      [    7.940170] calling  mmc_pwrseq_emmc_driver_init+0x0/0x10 @ 1
      [    7.946782] initcall mmc_pwrseq_emmc_driver_init+0x0/0x10 returned 0 after 210 usecs
      [    7.955402] calling  mmc_blk_init+0x0/0xec @ 1
      [    7.960472] initcall mmc_blk_init+0x0/0xec returned 0 after 102 usecs
      [    7.967664] calling  sunxi_mmc_driver_init+0x0/0x10 @ 1
      [    7.974889] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    7.984804] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    7.990978] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    7.997284] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    8.003672] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    8.010070] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    8.016559] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    8.023060] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    8.029575] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    8.036490] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    8.041831] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    8.048448] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12)                         dt B
      [    8.059528] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    8.079617] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SD                        R12) dt B
      [    8.103949] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    8.109621] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12)                         dt B
      [    8.116966] probe of 4020000.sdmmc returned 1 after 143162 usecs
      [    8.127714] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    8.137633] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    8.143787] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    8.150106] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    8.156504] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    8.162909] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    8.169409] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    8.175900] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    8.182401] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    8.188935] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    8.198255] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12)                         dt B
      [    8.209364] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    8.229458] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SD                        R12) dt B
      [    8.253619] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    8.260599] probe of 4021000.sdmmc returned 1 after 133201 usecs
      [    8.267678] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SD                        R12) dt B
      [    8.277161] initcall sunxi_mmc_driver_init+0x0/0x10 returned 0 after 296558 usecs
      [    8.282230] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SD                        R12) dt B
      [    8.287558] calling  led_pwm_driver_init+0x0/0x10 @ 1
      [    8.300752] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [    8.305028] initcall led_pwm_driver_init+0x0/0x10 returned 0 after 320 usecs
      [    8.321585] calling  netlink_init+0x0/0xa0 @ 1
      [    8.323551] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR                        25) dt B
      [    8.326546] Netlink socket created.
      [    8.338088] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(S                        DR25) dt B
      [    8.341846] initcall netlink_init+0x0/0xa0 returned 0 after 14956 usecs
      [    8.353618] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(S                        DR25) dt B
      [    8.360833] calling  sunxi_led_driver_init+0x0/0x10 @ 1
      [    8.361109] sunxi_led_probe()1881 - start
      [    8.373293] mmc1: new high speed SDIO card at address 0001
      [    8.378315] sunxi_get_str_of_property()1693 - failed to get the string of propname led_regulator!
      [    8.383059] probe of mmc1:0001 returned 0 after 51 usecs
      [    8.388982] sunxi_register_led_classdev()1581 - led_classdev start
      [    8.454401] sunxi_led_probe()1977 - finish
      [    8.459079] probe of 2008000.ledc returned 1 after 98123 usecs
      [    8.465759] initcall sunxi_led_driver_init+0x0/0x10 returned 0 after 102446 usecs
      [    8.474117] calling  timer_led_trigger_init+0x0/0xc @ 1
      [    8.480051] initcall timer_led_trigger_init+0x0/0xc returned 0 after 101 usecs
      [    8.488097] calling  defon_led_trigger_init+0x0/0xc @ 1
      [    8.493957] initcall defon_led_trigger_init+0x0/0xc returned 0 after 44 usecs
      [    8.501908] calling  netdev_trig_init+0x0/0xc @ 1
      [    8.507195] initcall netdev_trig_init+0x0/0xc returned 0 after 40 usecs
      [    8.514559] calling  hid_init+0x0/0x6c @ 1
      [    8.519236] hidraw: raw HID events driver (C) Jiri Kosina
      [    8.525275] initcall hid_init+0x0/0x6c returned 0 after 5999 usecs
      [    8.532176] calling  usb_kbd_driver_init+0x0/0x18 @ 1
      [    8.537896] usbcore: registered new interface driver usbkbd
      [    8.544101] initcall usb_kbd_driver_init+0x0/0x18 returned 0 after 6142 usecs
      [    8.552065] calling  usb_mouse_driver_init+0x0/0x18 @ 1
      [    8.557952] usbcore: registered new interface driver usbmouse
      [    8.564349] initcall usb_mouse_driver_init+0x0/0x18 returned 0 after 6309 usecs
      [    8.572502] calling  init_exfat+0x0/0x70 @ 1
      [    8.577274] exFAT: Version 1.3.0
      [    8.581002] initcall init_exfat+0x0/0x70 returned 0 after 3631 usecs
      [    8.588188] calling  extcon_class_init+0x0/0x20 @ 1
      [    8.593683] initcall extcon_class_init+0x0/0x20 returned 0 after 60 usecs
      [    8.601257] calling  alsa_timer_init+0x0/0x16c @ 1
      [    8.606881] initcall alsa_timer_init+0x0/0x16c returned 0 after 279 usecs
      [    8.614433] calling  alsa_pcm_init+0x0/0x18 @ 1
      [    8.619530] initcall alsa_pcm_init+0x0/0x18 returned 0 after 4 usecs
      [    8.626603] calling  snd_soc_init+0x0/0x84 @ 1
      [    8.632063] probe of snd-soc-dummy returned 1 after 122 usecs
      [    8.638754] initcall snd_soc_init+0x0/0x84 returned 0 after 7001 usecs
      [    8.646019] calling  dmic_driver_init+0x0/0x10 @ 1
      [    8.651620] initcall dmic_driver_init+0x0/0x10 returned 0 after 227 usecs
      [    8.659210] calling  asoc_simple_card_init+0x0/0x10 @ 1
      [    8.665244] initcall asoc_simple_card_init+0x0/0x10 returned 0 after 208 usecs
      [    8.673307] calling  sunxi_asoc_cpudai_driver_init+0x0/0x10 @ 1
      [    8.680244] probe of 203034c.dummy_cpudai returned 1 after 154 usecs
      [    8.687427] initcall sunxi_asoc_cpudai_driver_init+0x0/0x10 returned 0 after 7322 usecs
      [    8.696344] calling  sunxi_spdif_driver_init+0x0/0x10 @ 1
      [    8.702617] initcall sunxi_spdif_driver_init+0x0/0x10 returned 0 after 232 usecs
      [    8.710875] calling  sunxi_dmic_driver_init+0x0/0x10 @ 1
      [    8.717029] initcall sunxi_dmic_driver_init+0x0/0x10 returned 0 after 220 usecs
      [    8.725166] calling  sunxi_daudio_driver_init+0x0/0x10 @ 1
      [    8.731533] initcall sunxi_daudio_driver_init+0x0/0x10 returned 0 after 231 usecs
      [    8.739888] calling  sunxi_internal_codec_driver_init+0x0/0x10 @ 1
      [    8.747009] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2                        gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    8.747009]
      [    8.764060] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf                        :0
      [    8.775369] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    8.783612] probe of 2030000.codec returned 1 after 36674 usecs
      [    8.790311] initcall sunxi_internal_codec_driver_init+0x0/0x10 returned 0 after 42505 usecs
      [    8.799624] calling  sunxi_machine_driver_init+0x0/0x10 @ 1
      [    8.806624] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    8.816373] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    8.823425] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    8.834359] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0                        /input0
      [    8.846358] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    8.853967] probe of 2030340.sound returned 1 after 47937 usecs
      [    8.860583] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    8.866932] initcall sunxi_machine_driver_init+0x0/0x10 returned 0 after 59664 usecs
      [    8.876481] calling  sock_diag_init+0x0/0x40 @ 1
      [    8.881773] initcall sock_diag_init+0x0/0x40 returned 0 after 70 usecs
      [    8.889077] calling  llc_init+0x0/0x24 @ 1
      [    8.893635] initcall llc_init+0x0/0x24 returned 0 after 1 usecs
      [    8.900245] calling  snap_init+0x0/0x44 @ 1
      [    8.904903] initcall snap_init+0x0/0x44 returned 0 after 3 usecs
      [    8.911610] calling  blackhole_init+0x0/0xc @ 1
      [    8.916651] initcall blackhole_init+0x0/0xc returned 0 after 2 usecs
      [    8.923753] calling  fq_codel_module_init+0x0/0xc @ 1
      [    8.929390] initcall fq_codel_module_init+0x0/0xc returned 0 after 1 usecs
      [    8.937053] calling  init_cgroup_cls+0x0/0xc @ 1
      [    8.942199] initcall init_cgroup_cls+0x0/0xc returned 0 after 0 usecs
      [    8.949379] calling  nfnetlink_init+0x0/0x70 @ 1
      [    8.954531] initcall nfnetlink_init+0x0/0x70 returned 0 after 16 usecs
      [    8.961812] calling  nfnl_osf_init+0x0/0x50 @ 1
      [    8.966867] initcall nfnl_osf_init+0x0/0x50 returned 0 after 2 usecs
      [    8.973934] calling  nf_conntrack_standalone_init+0x0/0xa0 @ 1
      [    8.980932] initcall nf_conntrack_standalone_init+0x0/0xa0 returned 0 after 464 usecs
      [    8.989690] calling  ctnetlink_init+0x0/0x88 @ 1
      [    8.994850] initcall ctnetlink_init+0x0/0x88 returned 0 after 5 usecs
      [    9.002042] calling  cttimeout_init+0x0/0x78 @ 1
      [    9.007193] initcall cttimeout_init+0x0/0x78 returned 0 after 2 usecs
      [    9.014370] calling  nf_log_common_init+0x0/0x8 @ 1
      [    9.019810] initcall nf_log_common_init+0x0/0x8 returned 0 after 0 usecs
      [    9.027277] calling  nf_log_netdev_init+0x0/0x54 @ 1
      [    9.033336] initcall nf_log_netdev_init+0x0/0x54 returned 0 after 506 usecs
      [    9.041145] calling  nf_nat_init+0x0/0x104 @ 1
      [    9.046103] initcall nf_nat_init+0x0/0x104 returned 0 after 17 usecs
      [    9.053209] calling  xt_init+0x0/0xe4 @ 1
      [    9.057692] initcall xt_init+0x0/0xe4 returned 0 after 4 usecs
      [    9.064178] calling  tcpudp_mt_init+0x0/0x10 @ 1
      [    9.069328] initcall tcpudp_mt_init+0x0/0x10 returned 0 after 3 usecs
      [    9.076491] calling  connmark_mt_init+0x0/0x48 @ 1
      [    9.081837] initcall connmark_mt_init+0x0/0x48 returned 0 after 1 usecs
      [    9.089208] calling  netmap_tg_init+0x0/0x10 @ 1
      [    9.094349] initcall netmap_tg_init+0x0/0x10 returned 0 after 1 usecs
      [    9.101522] calling  redirect_tg_init+0x0/0x10 @ 1
      [    9.106863] initcall redirect_tg_init+0x0/0x10 returned 0 after 1 usecs
      [    9.114216] calling  masquerade_tg_init+0x0/0x3c @ 1
      [    9.119761] initcall masquerade_tg_init+0x0/0x3c returned 0 after 9 usecs
      [    9.127323] calling  conntrack_mt_init+0x0/0x10 @ 1
      [    9.132750] initcall conntrack_mt_init+0x0/0x10 returned 0 after 1 usecs
      [    9.140215] calling  state_mt_init+0x0/0xc @ 1
      [    9.145159] initcall state_mt_init+0x0/0xc returned 0 after 0 usecs
      [    9.152135] calling  gre_offload_init+0x0/0x44 @ 1
      [    9.157478] initcall gre_offload_init+0x0/0x44 returned 0 after 1 usecs
      [    9.164838] calling  sysctl_ipv4_init+0x0/0x4c @ 1
      [    9.170367] initcall sysctl_ipv4_init+0x0/0x4c returned 0 after 186 usecs
      [    9.177933] calling  nf_defrag_init+0x0/0xc @ 1
      [    9.182971] initcall nf_defrag_init+0x0/0xc returned 0 after 1 usecs
      [    9.190057] calling  ip_tables_init+0x0/0x88 @ 1
      [    9.195227] initcall ip_tables_init+0x0/0x88 returned 0 after 31 usecs
      [    9.202534] calling  iptable_mangle_init+0x0/0x74 @ 1
      [    9.208333] initcall iptable_mangle_init+0x0/0x74 returned 0 after 159 usecs
      [    9.216174] calling  cubictcp_register+0x0/0x64 @ 1
      [    9.221632] initcall cubictcp_register+0x0/0x64 returned 0 after 3 usecs
      [    9.229106] calling  inet6_init+0x0/0x320 @ 1
      [    9.234534] NET: Registered protocol family 10
      [    9.240471] Segment Routing with IPv6
      [    9.244638] initcall inet6_init+0x0/0x320 returned 0 after 10423 usecs
      [    9.251942] calling  nf_defrag_init+0x0/0x4c @ 1
      [    9.257193] initcall nf_defrag_init+0x0/0x4c returned 0 after 58 usecs
      [    9.264456] calling  packet_init+0x0/0x78 @ 1
      [    9.269324] NET: Registered protocol family 17
      [    9.274281] initcall packet_init+0x0/0x78 returned 0 after 4839 usecs
      [    9.281467] calling  br_init+0x0/0x9c @ 1
      [    9.285955] initcall br_init+0x0/0x9c returned 0 after 26 usecs
      [    9.292559] calling  nf_conntrack_l3proto_bridge_init+0x0/0x18 @ 1
      [    9.299448] initcall nf_conntrack_l3proto_bridge_init+0x0/0x18 returned 0 after 1 usecs
      [    9.308795] calling  init_machine_late+0x0/0x8c @ 1
      [    9.314231] initcall init_machine_late+0x0/0x8c returned 0 after 7 usecs
      [    9.321704] calling  swp_emulation_init+0x0/0x64 @ 1
      [    9.327241] Registering SWP/SWPB emulation handler
      [    9.332575] initcall swp_emulation_init+0x0/0x64 returned 0 after 5213 usecs
      [    9.340429] calling  init_oops_id+0x0/0x40 @ 1
      [    9.345382] initcall init_oops_id+0x0/0x40 returned 0 after 6 usecs
      [    9.352373] calling  pm_qos_power_init+0x0/0x84 @ 1
      [    9.358075] initcall pm_qos_power_init+0x0/0x84 returned 0 after 252 usecs
      [    9.365733] calling  pm_debugfs_init+0x0/0x34 @ 1
      [    9.371006] initcall pm_debugfs_init+0x0/0x34 returned 0 after 18 usecs
      [    9.378376] calling  wakeup_reason_init+0x0/0xec @ 1
      [    9.383957] initcall wakeup_reason_init+0x0/0xec returned 0 after 54 usecs
      [    9.391612] calling  printk_late_init+0x0/0x1cc @ 1
      [    9.397053] initcall printk_late_init+0x0/0x1cc returned 0 after 4 usecs
      [    9.404508] calling  init_srcu_module_notifier+0x0/0x2c @ 1
      [    9.410721] initcall init_srcu_module_notifier+0x0/0x2c returned 0 after 1 usecs
      [    9.418967] calling  tk_debug_sleep_time_init+0x0/0x34 @ 1
      [    9.425083] initcall tk_debug_sleep_time_init+0x0/0x34 returned 0 after 14 usecs
      [    9.433327] calling  fault_around_debugfs+0x0/0x34 @ 1
      [    9.439061] initcall fault_around_debugfs+0x0/0x34 returned 0 after 9 usecs
      [    9.446818] calling  check_early_ioremap_leak+0x0/0x60 @ 1
      [    9.452927] initcall check_early_ioremap_leak+0x0/0x60 returned 0 after 0 usecs
      [    9.461071] calling  ubifs_init+0x0/0xc4 @ 1
      [    9.466014] initcall ubifs_init+0x0/0xc4 returned 0 after 185 usecs
      [    9.473005] calling  init_root_keyring+0x0/0xc @ 1
      [    9.478414] initcall init_root_keyring+0x0/0xc returned 0 after 63 usecs
      [    9.485878] calling  prandom_reseed+0x0/0x34 @ 1
      [    9.491041] initcall prandom_reseed+0x0/0x34 returned 0 after 10 usecs
      [    9.498322] calling  clk_debug_init+0x0/0x100 @ 1
      [    9.517098] initcall clk_debug_init+0x0/0x100 returned 0 after 13203 usecs
      [    9.524761] calling  sync_state_resume_initcall+0x0/0x10 @ 1
      [    9.531091] initcall sync_state_resume_initcall+0x0/0x10 returned 0 after 2 usecs
      [    9.539432] calling  deferred_probe_initcall+0x0/0x98 @ 1
      [    9.548174] initcall deferred_probe_initcall+0x0/0x98 returned 0 after 2656 usecs
      [    9.556521] calling  genpd_debug_init+0x0/0x178 @ 1
      [    9.562067] initcall genpd_debug_init+0x0/0x178 returned 0 after 90 usecs
      [    9.569649] calling  genpd_power_off_unused+0x0/0x70 @ 1
      [    9.575597] initcall genpd_power_off_unused+0x0/0x70 returned 0 after 9 usecs
      [    9.583551] calling  sync_debugfs_init+0x0/0x74 @ 1
      [    9.589027] initcall sync_debugfs_init+0x0/0x74 returned 0 after 25 usecs
      [    9.596585] calling  ubi_init+0x0/0x230 @ 1
      [    9.601595] ubi0: attaching mtd3
      [    9.824014] random: crng init done
      [    9.870008] ubi0: scanning is finished
      [    9.883802] ubi0: attached mtd3 (name "sys", size 123 MiB)
      [    9.889971] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [    9.897633] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [    9.905188] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [    9.912946] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [    9.919632] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [    9.927685] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [    9.936979] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [    9.947260] ubi0: background thread "ubi_bgt0d" started, PID 1141
      [    9.955224] block ubiblock0_5: created from ubi0:5(rootfs)
      [    9.961414] initcall ubi_init+0x0/0x230 returned 0 after 351708 usecs
      [    9.968601] calling  init_sunxi_hci_class+0x0/0x40 @ 1
      [    9.974403] initcall init_sunxi_hci_class+0x0/0x40 returned 0 after 67 usecs
      [    9.982263] calling  usb_manager_init+0x0/0x10 @ 1
      [    9.988482] probe of soc@3000000:usbc0@0 returned 1 after 666 usecs
      [    9.995593] initcall usb_manager_init+0x0/0x10 returned 0 after 7795 usecs
      [   10.003298] calling  of_fdt_raw_init+0x0/0x80 @ 1
      [   10.010187] OF: fdt: not creating '/sys/firmware/fdt': CRC check failed
      [   10.017571] initcall of_fdt_raw_init+0x0/0x80 returned 0 after 8777 usecs
      [   10.025127] calling  tcp_congestion_default+0x0/0x14 @ 1
      [   10.031061] initcall tcp_congestion_default+0x0/0x14 returned 0 after 3 usecs
      [   10.039013] calling  regulatory_init_db+0x0/0x90 @ 1
      [   10.044671] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [   10.046738] initcall regulatory_init_db+0x0/0x90 returned 0 after 14 usecs
      [   10.054310] cfg80211: failed to load regulatory.db
      [   10.061963] calling  clk_disable_unused+0x0/0xd8 @ 1
      [   10.072792] clk: Not disabling unused clocks
      [   10.077557] initcall clk_disable_unused+0x0/0xd8 returned 0 after 4647 usecs
      [   10.085402] calling  regulator_init_complete+0x0/0x4c @ 1
      [   10.091428] initcall regulator_init_complete+0x0/0x4c returned 0 after 3 usecs
      [   10.099469] calling  of_platform_sync_state_init+0x0/0x10 @ 1
      [   10.105864] initcall of_platform_sync_state_init+0x0/0x10 returned 0 after 2 usecs
      [   10.114298] calling  alsa_sound_last_init+0x0/0x78 @ 1
      [   10.120028] ALSA device list:
      [   10.123324]   #0: audiocodec
      [   10.126530] initcall alsa_sound_last_init+0x0/0x78 returned 0 after 6344 usecs
      [   10.134577] alloc_fd: slot 0 not NULL!
      [   10.142136] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
      [   10.152332] devtmpfs: mounted
      [   10.157590] Freeing unused kernel memory: 1024K
      [   10.186890] Run /pseudo_init as init process
      [   10.423312] UBIFS (ubi0:7): default file-system created
      [   10.429875] UBIFS (ubi0:7): Mounting in unauthenticated mode
      [   10.436309] UBIFS (ubi0:7): background thread "ubifs_bgt0_7" started, PID 1177
      [   10.545064] UBIFS (ubi0:7): UBIFS: mounted UBI device 0, volume 7, name "rootfs_data"
      [   10.553850] UBIFS (ubi0:7): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 b                        ytes
      [   10.564904] UBIFS (ubi0:7): FS size: 43352064 bytes (41 MiB, 168 LEBs), journal size 2064385 bytes (1 MiB                        , 8 LEBs)
      [   10.576437] UBIFS (ubi0:7): reserved for root: 2047624 bytes (1999 KiB)
      [   10.583811] UBIFS (ubi0:7): media format: w5/r0 (latest is w5/r0), UUID A990054B-7A51-40E3-88D5-D2ADE4302                        641, small LPT model
      [   10.726898] UBIFS (ubi0:8): default file-system created
      [   10.733373] UBIFS (ubi0:8): Mounting in unauthenticated mode
      [   10.739836] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 1207
      [   10.847452] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
      [   10.855619] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 b                        ytes
      [   10.866690] UBIFS (ubi0:8): FS size: 6451200 bytes (6 MiB, 25 LEBs), journal size 2064385 bytes (1 MiB, 6                         LEBs)
      [   10.877943] UBIFS (ubi0:8): reserved for root: 304706 bytes (297 KiB)
      [   10.885118] UBIFS (ubi0:8): media format: w5/r0 (latest is w5/r0), UUID 7F2A6990-A27D-4A9F-A55D-0BFEB024E                        E5F, small LPT model
      [   11.026483] calling  init_module+0x0/0x1000 [usb_storage] @ 1210
      [   11.033383] usbcore: registered new interface driver usb-storage
      [   11.040173] initcall init_module+0x0/0x1000 [usb_storage] returned 0 after 6739 usecs
      [   11.277307] calling  init_module+0x0/0x1000 [8821cs] @ 1213
      [   11.418801] probe of mmc1:0001:1 returned 1 after 135086 usecs
      [   11.433472] initcall init_module+0x0/0x1000 [8821cs] returned 0 after 145536 usecs
      [   12.442525] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
      ------run rc.final file-----
        : values=on
      [   12.703215] file system registered
      Load mpp modules
      mkdir: can't create directory '/dev/pts': File exists
      [   12.723016] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      mkdir: can't create directory '/dev/shm': File exists
      [   12.758806] read descriptors
      [   12.762055] read strings
      cat: can't open '/sys/class/sunxi_info/sys_info': No such file or directory
      Starting network: Failed to connect to ubus
      /sbin/ifup: line 51: /sbin/wifi: not found
      FAIL
      ifconfig: invalid hw-addr 00:
      udhcpc: SIOCGIFINDEX: No such device
      [leo start] chage file
      File does not exist.
      /etc/init.d/S60sshd: line 55: touch: not found
      Connecting to the network(leo)......
      [   13.536735]
      [   13.536735] insmod_device_driver
      [   13.536735]
      [   13.543901] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dumm                        y regulator
      [   13.739511] sunxi_set_cur_vol_work()397 WARN: get power supply failed
      [   13.785946] android_work: sent uevent USB_STATE=CONNECTED
      [   13.812985] configfs-gadget gadget: high-speed config #1: c
      [   13.819318] android_work: sent uevent USB_STATE=CONFIGURED
      [   18.468861] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
      Connected to the AP(leo)
      Getting ip address(leo)......
      udhcpc: started, v1.27.2
      udhcpc: sending discover
      udhcpc: sending select for 192.168.199.177
      udhcpc: lease of 192.168.199.177 obtained, lease time 86400
      Wifi connect ap : Success!
      [leo start]Start SSH-----------
      sh: odhcp6c: not found
      ------run profile file-----
      Wed Jun  1 00:00:00 GMT 2022
      nodev   debugfs
      root@TinaLinux:/# swu_param: ####
      swu_software: ####
      swu_mode: ####
      /etc/rc.common: line 128: procd_add_mdns: not found
      [   40.376750] usb1-vbus: disabling
      root@TinaLinux:/#
      root@TinaLinux:/# /etc/init.d/acm.sh
      mount: mounting none on /sys/kernel/config failed: Resource busy
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1': File exists
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/strings/0x409': File exists
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/configs/c.1': File exists
      mkdir: can't create directory '/sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409': File exists
      echo: write error: Resource busy
      root@TinaLinux:/# cd dev/
      root@TinaLinux:/dev# ls
      bus              mtd0ro           random           ubi0_2
      by-name          mtd1             shm              ubi0_3
      cedar_dev        mtd1ro           snd              ubi0_4
      console          mtd2             sunxi-reg        ubi0_5
      cpu_dma_latency  mtd2ro           sunxi-wlan       ubi0_6
      disp             mtd3             sunxi_pwm0       ubi0_7
      fb0              mtd3ro           tty              ubi0_8
      full             mtdblock0        ttyGS0           ubi_ctrl
      g2d              mtdblock1        ttyS0            ubiblock0_5
      gpiochip0        mtdblock2        ttyS1            udmabuf
      input            mtdblock3        ttyS4            urandom
      ion              null             ubi0             usb-ffs
      kmsg             ptmx             ubi0_0           zero
      mtd0             pts              ubi0_1
      root@TinaLinux:/dev# echo "asdasd" > ttyGS0
      ^C
      root@TinaLinux:/dev# cat /etc/init.d/acm.sh
      mount -t configfs none /sys/kernel/config
      mkdir /sys/kernel/config/usb_gadget/g1
      echo "0x1f3a" > /sys/kernel/config/usb_gadget/g1/idVendor
      echo "0x0007" > /sys/kernel/config/usb_gadget/g1/idProduct
      mkdir /sys/kernel/config/usb_gadget/g1/strings/0x409
      mkdir /sys/kernel/config/usb_gadget/g1/functions/acm.usb0
      mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1
      echo 0xc0 > /sys/kernel/config/usb_gadget/g1/configs/c.1/bmAttributes
      echo 500 > /sys/kernel/config/usb_gadget/g1/configs/c.1/MaxPower
      mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409
      ln -s /sys/kernel/config/usb_gadget/g1/functions/acm.usb0/ /sys/kernel/config/usb_gadget/g1/configs/c.1/acm.usb0
      ls /sys/class/udc/ | xargs echo > /sys/kernel/config/usb_gadget/g1/UDCroot@TinaLinux:/dev#
      1 条回复 最后回复 回复 引用 分享 4
        哈哈哈,我自己搞定了,嘿嘿嘿
        X Z 2 条回复 最后回复 回复 引用 分享 1
        • X
          xlbwxbl LV 5 @leomini5 最后由 编辑
          @leomini5 弄出来了麻烦共享出来给大伙做个参考呀,这样才能营造和谐社会嘛😁
            zsn19931119 LV 3 @leomini5 最后由 编辑
            @leomini5 在 T113 usb0 acm cdc 无法使用 ttyGS0 直接卡主啦 中说:
            哈哈,我自己搞定了,嘿嘿嘿
            大佬能够提供一份完整的usb acm cdc,这个功能的教程吗
