    D1S无法进入系统,硬件为Norflash,只将默认的串口0改为了串口3,其他未变,求大佬帮助
    • X
      xyz743508968 LV 3 最后由 q1215200171 编辑
      [34]HELLO! BOOT0 is starting!
      [37]BOOT0 commit : 88480af
      [40]set pll start
      [42]periph0 has been enabled
      [44]set pll end
      [46][pmu]: bus read error
      [48]board init ok
      [50]ZQ value = 0x2d
      [52]get_pmu_exist() = -1
      [54]DRAM BOOT DRIVE INFO: V0.33
      [57]DRAM CLK = 528 MHz
      [59]DRAM Type = 2 (2:DDR2,3:DDR3)
      [62]DRAMC read ODT  off.
      [65]DRAM ODT off.
      [67]ddr_efuse_type: 0xa
      [69]DRAM SIZE =64 M
      [71]dram_tpr4:0x0
      [73]PLL_DDR_CTRL_REG:0xf8002b00
      [76]DRAM_CLK_REG:0xc0000000
      [78][TIMING DEBUG] MR2= 0x0
      [83]DRAM simple test OK.
      [85]dram size =64
      [87]spinor id is: ef 40 18, read cmd: 0b
      [90]Succeed in reading toc file head.
      [94]The size of toc is 100000.
      [265]Entry_name        = opensbi
      [268]Entry_name        = u-boot
      [272]Entry_name        = dtb
      [274]Jump to second Boot.
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,R,W,X)
      PMP4    : 0x0000000000000000-0x000000003fffffff (A,R,W)
      ▒** 8 printk messages dropped **
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
      [    0.000000]   DMA32 zone: 224 pages used for memmap
      [    0.000000]   DMA32 zone: 16384 pages, LIFO batch:3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16160
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mtdblock5 rootfstype=squashfs init=/sbin/init partitions=boot-resource@mtdblock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@mtdblock6 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018.07-ge987def5(11/07/2022-03:11:27) mbr_offset=1556480 disp_reserve=4096000,0x0000000042afb000 androidboot.dramsize=64
      [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.000000] Memory: 44892K/65536K available (4371K kernel code, 406K rwdata, 1741K rodata, 152K init, 230K bss, 12452K reserved, 8192K cma-reserved)
      [    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000025] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [    0.000393] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.001030] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.001050] pid_max: default: 32768 minimum: 301
      [    0.001244] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.001265] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.003417] ASID allocator initialised with 65536 entries
      [    0.003620] rcu: Hierarchical SRCU implementation.
      [    0.004395] devtmpfs: initialized
      [    0.020271] random: get_random_u32 called from bucket_table_alloc.isra.27+0xfe/0x120 with crng_init=0
      [    0.021261] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.021296] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [    0.021906] pinctrl core: initialized pinctrl subsystem
      [    0.023450] NET: Registered protocol family 16
      [    0.025618] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.026213] cpuidle: using governor menu
      [    0.071848] rtc_ccu: sunxi ccu init OK
      [    0.080711] clock: sunxi ccu init OK
      [    0.082651] clock: sunxi ccu init OK
      [    0.112624] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.115065] iommu: Default domain type: Translated
      [    0.115267] sunxi iommu: irq = 4
      [    0.116602] SCSI subsystem initialized
      [    0.116842] usbcore: registered new interface driver usbfs
      [    0.116930] usbcore: registered new interface driver hub
      [    0.117051] usbcore: registered new device driver usb
      [    0.117210] videodev: Linux video capture interface: v2.00
      [    0.118289] Advanced Linux Sound Architecture Driver Initialized.
      [    0.119001] Bluetooth: Core ver 2.22
      [    0.119098] NET: Registered protocol family 31
      [    0.119110] Bluetooth: HCI device and connection manager initialized
      [    0.119135] Bluetooth: HCI socket layer initialized
      [    0.119154] Bluetooth: L2CAP socket layer initialized
      [    0.119198] Bluetooth: SCO socket layer initialized
      [    0.119502] pwm module init!
      [    0.121625] g2d 5410000.g2d: Adding to iommu group 0
      [    0.122200] G2D: rcq version initialized.major:252
      [    0.123141] clocksource: Switched to clocksource riscv_clocksource
      [    0.137357] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.140955] NET: Registered protocol family 2
      [    0.141892] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.141948] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.141970] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.141984] TCP: Hash tables configured (established 512 bind 512)
      [    0.142166] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.142215] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.142494] NET: Registered protocol family 1
      [    0.143877] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.144509] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.144819] sunxi_spi_resource_get()2438 - [spi0] SPI MASTER MODE
      [    0.144894] sunxi_spi_resource_get()2485 - sample_mode:1 sample_delay:25
      [    0.145022] sunxi_spi_clk_init()2527 - [spi0] mclk 80000000
      [    0.145898] sunxi_spi_probe()2978 - [spi0]: driver probe succeed, base ffffffd004058000, irq 31
      [    0.148246] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [    0.154541] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.154773] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.155107] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      [    0.175972] io scheduler mq-deadline registered
      [    0.175987] io scheduler kyber registered
      [    0.176950] [DISP]disp_module_init
      [    0.177607] disp 5000000.disp: Adding to iommu group 0
      [    0.178287] [DISP] disp_init,line:2387:
      [    0.178294] smooth display screen:0 type:1 mode:4
      [    0.223070] display_fb_request,fb_id:0
      [    0.263392] [DISP]disp_module_init finish
      [    0.264392] sunxi_sid_init()783 - insmod ok
      [    0.265274] pwm-regulator: supplied by regulator-dummy
      [    0.266796] disp_al_manager_apply ouput_type:1
      [    0.266926] [DISP] lcd_clk_config,line:774:
      [    0.266939] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
      [    0.266939]      clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
      [    0.267280] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.268044] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    0.268614] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.269011] uart3: ttyS3 at MMIO 0x2500c00 (irq = 21, base_baud = 1500000) is a SUNXI
      [    0.269044] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      [    0.985114] printk: console [ttyS3] enabled
      [    0.991038] misc dump reg init
      [    0.995596] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    1.006903] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.018246] Freeing logo buffer memory: 4000K
      [    1.023243] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.030561] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.038002] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.044544] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.051501] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=137 assert=1
      [    1.059471] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    1.070816] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.078982] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.086744] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.093549] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=133 assert=0
      [    1.101724] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    1.109576] [ADDR_MGT] addr_mgt_probe: success.
      [    1.116351] spi-nor spi0.0: w25q128 (16384 Kbytes)
      [    1.124195] 7 sunxipart partitions found on MTD device spi0.0
      [    1.130630] Creating 7 MTD partitions on "spi0.0":
      [    1.136103] 0x000000000000-0x000000180000 : "uboot"
      [    1.154058] 0x000000180000-0x0000001a0000 : "boot-resource"
      [    1.173999] 0x0000001a0000-0x0000001c0000 : "env"
      [    1.193996] 0x0000001c0000-0x0000001e0000 : "env-redund"
      [    1.214053] 0x0000001e0000-0x000000960000 : "boot"
      [    1.233989] 0x000000960000-0x0000023eb000 : "rootfs"
      [    1.239527] mtd: partition "rootfs" extends beyond the end of device "spi0.0" -- size truncated to 0x6a0000
      [    1.264048] 0x0000023eb000-0x000001000000 : "UDISK"
      [    1.269486] mtd: partition "UDISK" is out of reach -- disabled
      [    1.284252] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.291568] sunxi-ehci: EHCI SUNXI driver
      [    1.296756] get ehci1-controller wakeup-source is fail.
      [    1.302691] sunxi ehci1-controller don't init wakeup source
      [    1.309021] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0006ad788, 0x:ffffffd004073000, irq_no:31
      [    1.322557] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.335144] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.347508] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.354798] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.364728] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
      [    1.393202] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.400971] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [    1.410786] hub 1-0:1.0: USB hub found
      [    1.415123] hub 1-0:1.0: 1 port detected
      [    1.420548] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.427572] sunxi-ohci: OHCI SUNXI driver
      [    1.432676] get ohci1-controller wakeup-source is fail.
      [    1.438769] sunxi ohci1-controller don't init wakeup source
      [    1.445036] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0006adb50
      [    1.455522] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    1.468104] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    1.480454] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.487794] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.497662] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
      [    1.578293] hub 2-0:1.0: USB hub found
      [    1.582561] hub 2-0:1.0: 1 port detected
      [    1.590204] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.596072] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:40:32 UTC (2432)
      [    1.605359] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.611350] i2c /dev entries driver
      [    1.615417] IR NEC protocol handler initialized
      [    1.623678] usbcore: registered new interface driver uvcvideo
      [    1.630082] USB Video Class driver (1.1.1)
      [    1.634929] sunxi cedar version 1.1
      [    1.639136] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.645450] VE: install start!!!
      [    1.645450]
      [    1.651077] VE: cedar-ve the get irq is 6
      [    1.651077]
      [    1.657483] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      [    1.657483]
      [    1.669120] VE: install end!!!
      [    1.669120]
      [    1.674187] VE: sunxi_cedar_probe
      [    1.678164] Bluetooth: HCI UART driver ver 2.3
      [    1.683235] Bluetooth: HCI UART protocol H4 registered
      [    1.688956] Bluetooth: HCI UART protocol BCSP registered
      [    1.695471] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    1.702817] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
      [    1.709290] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
      [    1.716066] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
      [    1.716066]
      [    1.724744] [XR_BT_LPM] bluesleep_probe: uart_index(1)
      [    1.733611] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.743553] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.749767] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.756125] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.762554] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.768992] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.775516] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.782036] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.788600] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
      [    1.796150] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.803443] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.808949] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    1.815724] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.826923] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.847091] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.871606] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.882768] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    1.889329] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.899436] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.905701] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.912044] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.918490] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.924960] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.931460] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.937988] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.944549] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.951084] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.960893] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.972057] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    1.992304] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.006902] hub 1-1:1.0: USB hub found
      [    2.011493] hub 1-1:1.0: 4 ports detected
      [    2.016040] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.024101] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.031446] ashmem: initialized
      [    2.034977] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.041909] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.059892] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.059892]
      [    2.077281] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.088927] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      [    2.097188] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.110370] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.120381] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.127875] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.135469] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.143012] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.150284] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.160087] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.166898] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.179727] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    2.192636] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    2.203010] NET: Registered protocol family 10
      [    2.209934] Segment Routing with IPv6
      [    2.214387] NET: Registered protocol family 17
      [    2.219584] Bluetooth: RFCOMM TTY layer initialized
      [    2.225212] Bluetooth: RFCOMM socket layer initialized
      [    2.231017] Bluetooth: RFCOMM ver 1.11
      [    2.270047] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    2.285915] sunxi-i2c sunxi-i2c2: probe success
      [    2.296483] get ehci0-controller wakeup-source is fail.
      [    2.302462] sunxi ehci0-controller don't init wakeup source
      [    2.308734] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0006acff8, 0x:ffffffd0040fb000, irq_no:2e
      [    2.322279] [sunxi-ehci0]: Not init ehci0
      [    2.327352] get ohci0-controller wakeup-source is fail.
      [    2.333410] sunxi ohci0-controller don't init wakeup source
      [    2.339627] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0006ad3c0
      [    2.350083] [sunxi-ohci0]: Not init ohci0
      [    2.357481] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    2.371786] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.381518] clk: Not disabling unused clocks
      [    2.386363] ALSA device list:
      [    2.389671]   #0: audiocodec
      [    2.392892] alloc_fd: slot 0 not NULL!
      [    2.397183] cfg80211: failed to load regulatory.db
      [    2.407168] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
      [    2.422027] devtmpfs: mounted
      [    2.425686] Freeing unused kernel memory: 152K
      [    2.430670] This architecture does not have kernel memory protection.
      [    2.437886] Run /sbin/init as init process
      [    2.443528] random: fast init done
      [    2.823273] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:1
      [    3.503428]
      [    3.503428] insmod_device_driver
      [    3.503428]
      [    3.510658] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    3.522831] device_chose finished 142!
      [    3.537130] init: Console is alive
      [    3.541370] init: - preinit -
      formating /dev/by-name/UDISK to jffs2
      dd: writing '/dev/by-name/UDISK': No space left on device
      1+0 records in
      0+0 records out
      [    5.556749] mount_root: mounting /dev/root
      [    5.561964] mount_root: loading kmods from internal overlay
      [    5.615333] random: crng init done
      [    5.859954] block: attempting to load /etc/config/fstab
      [    5.901520] block: extroot: device not present, retrying in 5 seconds
      [   11.022411] block: extroot: cannot find device UDISK
      [   11.044450] procd: - early -
      [   11.271140] procd: - ubus -
      [   11.284015] procd (1): /proc/109/oom_adj is deprecated, please use /proc/109/oom_score_adj instead.
      [   11.608043] procd: - init -
      [   13.534247] file system registered
      [   13.620861] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   13.986143] read descriptors
      [   13.989371] read strings
      [   15.643964] ======== XRADIO WIFI OPEN ========
      [   15.649632] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [   15.656526] [XRADIO] Allocated hw_priv @ 000000004901d301
      [   15.673288] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   15.689556] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   15.905709] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   15.916847] [XRADIO] Detect SDIO card 1
      [   15.931540] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   15.951778] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   15.976873] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   15.984553] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   15.991391] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.006066] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   16.019874] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   16.027425] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   16.034984] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   16.042527] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   16.049292] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [   18.003329] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [   18.110606] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.121713] [XRADIO] Remove SDIO card 1
      [   18.133294] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   18.142920] [SBUS_ERR] sdio probe timeout!
      [   18.147570] [XRADIO_ERR] sbus_sdio_init failed
      [   18.153892] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.165865] xradio_core_init failed (-110)!
      [   18.196921] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   18.204616] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [   18.211443] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.226297] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   18.240143] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   18.247753] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   18.255846] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   18.263386] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [   18.270144] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      kmodloader done
      [   32.483225] usb1-vbus: disabling
      • X
        xyz743508968 LV 3 最后由 编辑
        就停在这里了,回车进不了系统
        • X
          后来发现 我插入鼠标有反应,说明系统已经起来了,控制台却无法使用,boot和内核都能打印,应该不是这两个地方的问题,猜测是文件系统配置的问题,进入SDK /tina-d1-h/target/allwinner/d1s-nezha_nor/base-files/etc下的inittab 文件:ttyS0::askfirst:/bin/ash --login 控制台串口并没有改过来,改为ttyS3就能进入系统了。
