    TinyVision tina5.0编译问题
    • X
      xzhang LV 2 最后由 编辑
      代码使用的是:
      repo init -u https://sdk.aw-ol.com/git_repo/V853Tina_Open/manifest.git -b master -m tina-v853-open.xml
      代码 sync 下来后编译遇到如下错误
      Makefile:228: recipe for target '/home/tina/code/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/linux-v851se-tinyvision/busybox-init-base-files/.prepared_c5a8af3b7eb42e811341240525c0a279_6664517399ebbbc92a37c5bb081b5c53' failed
      make[3]: [/home/tina/code/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/linux-v851se-tinyvision/busybox-init-base-files/.prepared_c5a8af3b7eb42e811341240525c0a279_6664517399ebbbc92a37c5bb081b5c53] Error 1 (ignored)
      touch /home/tina/code/tina-v853-open/out/v851se/tinyvision/openwrt/build_dir/target/linux-v851se-tinyvision/busybox-init-base-files/.prepared_c5a8af3b7eb42e811341240525c0a279_6664517399ebbbc92a37c5bb081b5c53
      touch: setting times of '-': Permission denied
      Makefile:228: recipe for target '-' failed
      make[3]: *** [-] Error 1
      make[3]: Leaving directory '/home/tina/code/tina-v853-open/openwrt/package/allwinner/system/busybox-init-base-files'
      time: package/subpackage/allwinner/system/busybox-init-base-files/compile#0.15#0.10#0.24
          ERROR: package/subpackage/allwinner/system/busybox-init-base-files failed to build.
      package/Makefile:114: recipe for target 'package/subpackage/allwinner/system/busybox-init-base-files/compile' failed
      make[2]: *** [package/subpackage/allwinner/system/busybox-init-base-files/compile] Error 1
      make[2]: Leaving directory '/home/tina/code/tina-v853-open/openwrt/openwrt'
      package/Makefile:110: recipe for target '/home/tina/code/tina-v853-open/openwrt/openwrt/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/tina/code/tina-v853-open/openwrt/openwrt/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/tina/code/tina-v853-open/openwrt/openwrt'
      /home/tina/code/tina-v853-open/openwrt/openwrt/include/toplevel.mk:236: recipe for target 'world' failed
      make: *** [world] Error 2
      make: Leaving directory '/home/tina/code/tina-v853-open/openwrt/openwrt'
      INFO: build_openwrt_rootfs failed
      请教大家是否遇到类似问题?可能是什么原因呢?
        yuLife LV 3 最后由 编辑
        @xzhang 在 TinyVision tina5.0编译问题 中说:
        指的是使用makefile调用touch命令对目录"-"读写失败(没有权限),touch会创建文件并更新文件的时间戳
        你可以用 ls -alh 把目录下的权限列出并贴图上来让人帮你排查
