    t113 tina sdb push 内核崩溃
      cjia3254 LV 5 最后由 cjia3254 编辑
      现状是小文件可以正常传输,测试的是7m的音频文件,没有问题
      但是一旦文件大起来,就无法传输了,测试56m的wav文件就无法传输了,会卡在8%或14%。
      日志
      [    0.000000] Linux version 5.4.61 (cjia@0652cdfa7734) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #17 SMP PREEMPT Thu Apr 18 01:06:14
      [    0.000000] cma: Reserved 8 MiB at 0x47800000
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500400 clk_ignore_unused initcall_debug=0 console=ttyS1,115200 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0mcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boo24-10:02:06) androidboot.dramsize=128
      [    0.000000] Memory: 108672K/131072K available (6144K kernel code, 241K rwdata, 1520K rodata, 1024K init, 1128K bss, 14208K reserved, 8192K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x26c/0x3ec with crng_init=0
      [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008016] Switching to timer-based delay loop, resolution 41ns
      [    0.014175] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023879] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.034252] pid_max: default: 32768 minimum: 301
      [    0.038999] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046332] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.054642] CPU: Testing write buffer coherency: ok
      [    0.059851] /cpus/cpu@0 missing clock-frequency property
      [    0.065185] /cpus/cpu@1 missing clock-frequency property
      [    0.070516] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.076675] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.083342] rcu: Hierarchical SRCU implementation.
      [    0.088551] smp: Bringing up secondary CPUs ...
      [    0.094180] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.094297] smp: Brought up 1 node, 2 CPUs
      [    0.104093] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.110271] CPU: All CPU(s) started in SVC mode.
      [    0.115349] devtmpfs: initialized
      [    0.129762] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.137902] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.147773] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.154987] pinctrl core: initialized pinctrl subsystem
      [    0.161138] NET: Registered protocol family 16
      [    0.167017] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.200732] rtc_ccu: sunxi ccu init OK
      [    0.206740] ccu: sunxi ccu init OK
      [    0.210544] r_ccu: sunxi ccu init OK
      [    0.231450] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.238885] iommu: Default domain type: Translated
      [    0.243922] sunxi iommu: irq = 24
      [    0.248118] SCSI subsystem initialized
      [    0.252067] usbcore: registered new interface driver usbfs
      [    0.257594] usbcore: registered new interface driver hub
      [    0.263015] usbcore: registered new device driver usb
      [    0.268831] Advanced Linux Sound Architecture Driver Initialized.
      [    0.275637] Bluetooth: Core ver 2.22
      [    0.279261] NET: Registered protocol family 31
      [    0.283724] Bluetooth: HCI device and connection manager initialized
      [    0.290121] Bluetooth: HCI socket layer initialized
      [    0.295004] Bluetooth: L2CAP socket layer initialized
      [    0.300071] Bluetooth: SCO socket layer initialized
      [    0.305203] pwm module init!
      [    0.309233] g2d 5410000.g2d: Adding to iommu group 0
      [    0.314509] G2D: rcq version initialized.major:252
      [    0.320044] clocksource: Switched to clocksource arch_sys_counter
      [    0.334460] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.343709] NET: Registered protocol family 2
      [    0.348611] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.357028] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.364710] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.371806] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.378264] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.384828] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.392001] NET: Registered protocol family 1
      [    0.397267] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.407630] spi spi1: spi1 supply spi not found, using dummy regulator
      [    0.414370] sunxi_spi_resource_get()2438 - [spi1] SPI MASTER MODE
      [    0.420535] sunxi_spi_resource_get()2476 - Failed to get sample mode
      [    0.426889] sunxi_spi_resource_get()2481 - Failed to get sample delay
      [    0.433336] sunxi_spi_resource_get()2485 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.441772] sunxi_spi_clk_init()2527 - [spi1] mclk 100000000
      [    0.448151] sunxi_spi_probe()2978 - [spi1]: driver probe succeed, base c881f000, irq 39
      [    0.457694] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.469029] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.475081] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.508267] io scheduler mq-deadline registered
      [    0.512831] io scheduler kyber registered
      [    0.518727] sunxi_sid_init()783 - insmod ok
      [    0.524104] uart uart1: uart1 supply uart not found, using dummy regulator
      [    0.531282] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.539134] sw_console_setup()1807 - console setup baud 115200 parity n bits 8, flow n
      �[    0.547123] printk: console [ttyS1] enabled
      [    0.556050] printk: bootconsole [earlycon0] disabled
      [    0.567342] misc dump reg init
      [    0.571931] dma-buf: Running sanitycheck
      [    0.576331] dma-buf: Running dma_fence
      [    0.580554] sizeof(dma_fence)=48
      [    0.584265] dma-buf: Running dma_fence/sanitycheck
      [    0.589649] dma-buf: Running dma_fence/test_signaling
      [    0.595329] dma-buf: Running dma_fence/test_add_callback
      [    0.601300] dma-buf: Running dma_fence/test_late_add_callback
      [    0.607744] dma-buf: Running dma_fence/test_rm_callback
      [    0.613612] dma-buf: Running dma_fence/test_late_rm_callback
      [    0.619959] dma-buf: Running dma_fence/test_status
      [    0.625343] dma-buf: Running dma_fence/test_error
      [    0.630626] dma-buf: Running dma_fence/test_wait
      [    0.635805] dma-buf: Running dma_fence/test_wait_timeout
      [    0.680054] dma-buf: Running dma_fence/test_stub
      [    0.685250] dma-buf: Running dma_fence/race_signal_callback
      [    0.760071] thread_signal_callback[0] completed 36525 passes, 66 misses
      [    0.767520] thread_signal_callback[1] completed 36531 passes, 73 misses
      [    0.840054] thread_signal_callback[0] completed 42309 passes, 42308 misses
      [    0.847789] thread_signal_callback[1] completed 42332 passes, 42332 misses
      [    0.856273] libphy: Fixed MDIO Bus: probed
      [    0.861999] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.873477] gmac-power0: NULL
      [    0.876805] gmac-power1: NULL
      [    0.880159] gmac-power2: NULL
      [    0.884488] Failed to alloc md5
      [    0.888019] eth0: Use random mac address
      [    0.892680] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.900003] sunxi-ehci: EHCI SUNXI driver
      [    0.904816] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.911788] sunxi-ohci: OHCI SUNXI driver
      [    0.916680] i2c /dev entries driver
      [    0.920688] sunxi cedar version 1.1
      [    0.924741] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    0.931072] VE: sunxi_cedar_probe power-domain init!!!
      [    0.936838] VE: install start!!!
      [    0.936838]
      [    0.942381] VE: cedar-ve the get irq is 40
      [    0.942381]
      [    0.948808] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    0.948808]
      [    0.958112] VE: install end!!!
      [    0.958112]
      [    0.963253] VE: sunxi_cedar_probe
      [    0.967184] Bluetooth: HCI UART driver ver 2.3
      [    0.972194] Bluetooth: HCI UART protocol H4 registered
      [    0.977955] Bluetooth: HCI UART protocol BCSP registered
      [    0.984194] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    0.992899] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    1.002776] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.008969] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.015337] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.021794] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.028237] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.034789] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.041341] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.047881] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.055180] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.066373] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.086528] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.110777] sunxi-mmc 4020000.sdmmc: detmode:manually by software
      [    1.117632] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.130090] exFAT: Version 1.3.0
      [    1.135684] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
      [    1.143856] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
      [    1.151231] sunxi-spdif: probe of 2036000.spdif failed with error -22
      [    1.152409] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.158962] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    1.181426] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    1.192840] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.193491] sunxi-daudio 2034000.daudio: regulator missing or invalid
      [    1.212125] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    1.212125]
      [    1.213029] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.229320] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    1.252322] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
      [    1.261403] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    1.271240] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    1.278376] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    1.289327] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    1.301315] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    1.309713] NET: Registered protocol family 10
      [    1.315819] Segment Routing with IPv6
      [    1.319965] mmc0: host does not support reading read-only switch, assuming write-enable
      [    1.320068] NET: Registered protocol family 17
      [    1.333963] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.333969] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    1.340192] Bluetooth: RFCOMM TTY layer initialized
      [    1.345602] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    1.352903] Bluetooth: RFCOMM socket layer initialized
      [    1.375807] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    1.375823] Bluetooth: RFCOMM ver 1.11
      [    1.387585] mmc0: new high speed SDHC card at address 5048
      [    1.392267] Registering SWP/SWPB emulation handler
      [    1.398816] mmcblk0: mmc0:5048 SD32G 29.7 GiB
      [    1.413397]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
      [    1.418705] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    1.428832] sunxi-i2c sunxi-i2c2: probe success
      [    1.435185] sunxi-spdif 2036000.spdif: request pinctrl handle for audio failed
      [    1.443335] sunxi-spdif 2036000.spdif: [sunxi_spdif_dev_probe] failed
      [    1.450679] sunxi-spdif: probe of 2036000.spdif failed with error -22
      [    1.458345] sun8iw20-pinctrl 2000000.pinctrl: pin PB3 already requested by 2034000.daudio; cannot claim for 2000000.pinctrl:35
      [    1.471159] sun8iw20-pinctrl 2000000.pinctrl: pin-35 (2000000.pinctrl:35) status -22
      [    1.479863] reg-fixed-voltage: probe of usb1-vbus failed with error -22
      [    1.487947] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
      [    1.497012] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
      [    1.508172] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    1.519575] sun8iw20-pinctrl 2000000.pinctrl: pin PB6 already requested by 2034000.daudio; cannot claim for 2000000.pinctrl:38
      [    1.532379] sun8iw20-pinctrl 2000000.pinctrl: pin-38 (2000000.pinctrl:38) status -22
      [    1.543759] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    1.550098] clk: Not disabling unused clocks
      [    1.553476] cfg80211: failed to load regulatory.db
      [    1.558212] ALSA device list:
      [    1.566929]   #0: audiocodec
      [    1.570170]   #1: snddmic
      [    1.581453] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    1.592554] devtmpfs: mounted
      [    1.597775] Freeing unused kernel memory: 1024K
      [    1.630247] Run /pseudo_init as init process
      [    1.973849] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    1.990718] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
      Didn't found ubi volume "env"
      Cannot open /dev/ubi0: No such file or directory
      Didn't found ubi volume "env-redund"
      ------- ext4 ---------
      e2fsck 1.46.4 (18-Aug-2021)
      /dev/mmcblk0p8: recovering journal
      Setting free inodes count to 1909428 (was 1909429)
      Setting free blocks count to 7471695 (was 7471727)
      /dev/mmcblk0p8: clean, 12/1909440 files, 163933/7635628 blocks
      ------- /usr/sbin/fsck.ext4 -v  -y /dev/mmcblk0p8 ---------
      [    2.336855] random: fast init done
      [    2.356488] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
      ------run rc.final file-----
      Error relocating /usr/bin/amixer: snd_ctl_elem_info_is_writable@snd_ctl_card_info_get_id: symbol not found
      ------run profile file-----
      Mon Feb  6 00:00:00 GMT 2023
      nodev   debugfs
      root@TinaLinux:/# [    2.523080] file system registered
      [    2.540667] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [    3.640337] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    3.656313] read descriptors
      [    3.659560] read strings
      [    3.869386] android_work: sent uevent USB_STATE=CONNECTED
      [    3.894803] configfs-gadget gadget: high-speed config #1: c
      [    3.901127] android_work: sent uevent USB_STATE=CONFIGURED
      root@TinaLinux:/#
      root@TinaLinux:/# [  318.002516] 8<--- cut here ---
      [  318.005954] Unable to handle kernel paging request at virtual address fef8fe56
      [  318.014054] pgd = (ptrval)
      [  318.017085] [fef8fe56] *pgd=00000000
      [  318.021096] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
      [  318.027051] Modules linked in:
      [  318.030478] CPU: 0 PID: 190 Comm: adbd Not tainted 5.4.61 #17
      [  318.036919] Hardware name: Generic DT based system
      [  318.042301] PC is at kmem_cache_alloc+0xfc/0x160
      [  318.047482] LR is at slab_pre_alloc_hook+0x18/0x2c
      [  318.052852] pc : [<c01c70d0>]    lr : [<c01c51c0>]    psr: a0000013
      [  318.059882] sp : c6585c90  ip : 00000000  fp : c77dd920
      [  318.065738] r10: 00000392  r9 : c6585c90  r8 : c01fca88
      [  318.071596] r7 : 00408d40  r6 : c6584000  r5 : c7003e00  r4 : fef8fe56
      [  318.078919] r3 : 00000000  r2 : 06d7f000  r1 : 00000392  r0 : c7003e00
      [  318.086240] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
      [  318.094242] Control: 10c5387d  Table: 4659006a  DAC: 00000051
      [  318.100684] Process adbd (pid: 190, stack limit = 0x(ptrval))
      [  318.107127] Stack: (0xc6585c90 to 0xc6586000)
      [  318.112015] 5c80:                                     00000000 00000000 00000000 00408c40
      [  318.121191] 5ca0: ffffffff ffffffff 00001000 c01fca88 00000000 00000000 00000000 c01fcbf4
      [  318.130358] 5cc0: c77dd920 00000000 00000001 c77dd920 00000000 00000000 c77dd920 c6dc9d78
      [  318.139534] 5ce0: 00001000 c6585e04 00000154 c01fcc5c c77dd920 00000000 00000000 c01fcd74
      [  318.148710] 5d00: c77dd920 c01fe8ec c01aae60 a30fff65 c0937b48 c01970b8 00000000 a30fff65
      [  318.157886] 5d20: c02756f8 c6dd9000 c65dc000 00000000 00000c40 c024aae0 c0b48888 c6585e04
      [  318.167063] 5d40: 00000154 a30fff65 00000001 c77dd920 c6dc9d78 c6dc9e78 c6584000 00001000
      [  318.176239] 5d60: c6dd9000 c6585e04 00000154 c01fedd8 00001000 c024aae0 00000000 00000000
      [  318.185415] 5d80: c77dd920 c02502c4 00001000 c024aae0 c6dc9e78 c0250f58 00154000 00000000
      [  318.194592] 5da0: 00155000 00000000 00153000 00000154 00000000 a30fff65 017830a0 00001000
      [  318.203768] 5dc0: c6585ef8 c6dc9e78 00004000 00001000 c655dc00 c070f950 c02500c0 c018e2b4
      [  318.212944] 5de0: 00001000 00000000 c6585e04 c6585e08 00154000 00000000 c6584000 00000000
      [  318.222120] 5e00: 63e0443b c77dd900 00000000 a30fff65 00000000 c7076600 c6585f10 c6585ef8
      [  318.231297] 5e20: 00000000 c655dc00 c6585ef8 00000000 c6dc9e78 c0190740 c6dc9d78 00000004
      [  318.240473] 5e40: 0051417c c018db90 c6585e50 c6c45680 00010000 c6585f10 c6dc9d78 c6585ef8
      [  318.249649] 5e60: 00000000 c6585e9c c6dc9d78 00000004 0051417c c023ffdc 00000000 a30fff65
      [  318.258826] 5e80: c6585ef8 000000b0 c6584000 c64d6800 c6c45680 c6dc9df8 c6585f70 00000000
      [  318.268000] 5ea0: 00000000 00000004 00000000 00000000 c6585ef8 00000000 00000000 a30fff65
      [  318.277176] 5ec0: 00000000 c6584000 c6585f70 c655dc00 00010000 00000000 00010000 00000004
      [  318.286352] 5ee0: 0051417c c01cd2f0 00010000 c6585ef4 0177f0a0 00010000 00000005 00004000
      [  318.295519] 5f00: 0000c000 c6585ef0 00000001 00000000 c655dc00 00000000 00150000 00000000
      [  318.304694] 5f20: 00000000 c6585e9c 00000000 00000000 00000000 00000000 c6585f48 a30fff65
      [  318.313871] 5f40: c655dc00 00010000 00000000 0177f0a0 c6585f70 c01ce690 c655dc00 c6585f70
      [  318.323047] 5f60: c6584000 0177f0a0 c6585f7c c01ce824 00150000 00000000 00000010 c655dc00
      [  318.332223] 5f80: 00000003 a30fff65 b6fef120 00000000 00000000 0052002e 00000004 c0101228
      [  318.341399] 5fa0: c6584000 c0101000 00000000 00000000 00000010 0177f0a0 00010000 00000000
      [  318.350575] 5fc0: 00000000 00000000 0052002e 00000004 00527dac 00527dac 0177f0a0 0051417c
      [  318.359752] 5fe0: b6f1c2b0 b6f1c29c b6fc745c b6fc6968 60000010 00000010 00000000 00000000
      [  318.368931] [<c01c70d0>] (kmem_cache_alloc) from [<c01fca88>] (alloc_buffer_head+0x14/0x9c)
      [  318.378309] [<c01fca88>] (alloc_buffer_head) from [<c01fcbf4>] (alloc_page_buffers+0x4c/0xa0)
      [  318.387877] [<c01fcbf4>] (alloc_page_buffers) from [<c01fcc5c>] (create_empty_buffers+0x14/0xf0)
      [  318.397742] [<c01fcc5c>] (create_empty_buffers) from [<c01fcd74>] (create_page_buffers+0x3c/0x54)
      [  318.407701] [<c01fcd74>] (create_page_buffers) from [<c01fe8ec>] (__block_write_begin_int+0x80/0x54c)
      [  318.418053] [<c01fe8ec>] (__block_write_begin_int) from [<c01fedd8>] (__block_write_begin+0x20/0x28)
      [  318.428306] [<c01fedd8>] (__block_write_begin) from [<c02502c4>] (ext4_da_write_begin+0x204/0x288)
      [  318.438367] [<c02502c4>] (ext4_da_write_begin) from [<c018e2b4>] (generic_perform_write+0xb0/0x1b4)
      [  318.448526] [<c018e2b4>] (generic_perform_write) from [<c0190740>] (__generic_file_write_iter+0x13c/0x160)
      [  318.459368] [<c0190740>] (__generic_file_write_iter) from [<c023ffdc>] (ext4_file_write_iter+0x3d8/0x3e8)
      [  318.470113] [<c023ffdc>] (ext4_file_write_iter) from [<c01cd2f0>] (__vfs_write+0xb0/0xe4)
      [  318.479296] [<c01cd2f0>] (__vfs_write) from [<c01ce690>] (vfs_write+0x98/0xbc)
      [  318.487403] [<c01ce690>] (vfs_write) from [<c01ce824>] (ksys_write+0x70/0xb8)
      [  318.495416] [<c01ce824>] (ksys_write) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
      [  318.504003] Exception stack(0xc6585fa8 to 0xc6585ff0)
      [  318.509669] 5fa0:                   00000000 00000000 00000010 0177f0a0 00010000 00000000
      [  318.518845] 5fc0: 00000000 00000000 0052002e 00000004 00527dac 00527dac 0177f0a0 0051417c
      [  318.528008] 5fe0: b6f1c2b0 b6f1c29c b6fc745c b6fc6968
      [  318.533677] Code: eb11fd86 e1a00004 e8bd87f0 e5953014 (e7940003)
      [  318.540511] ---[ end trace a5d558ca6731eb3a ]---
      分区挂载情况
      root@TinaLinux:/# df -h
      /dev/root                36.3M     36.3M         0 100% /rom
      devtmpfs                 53.1M         0     53.1M   0% /dev
      tmpfs                    57.6M         0     57.6M   0% /tmp
      /dev/by-name/rootfs_data
                              458.3M     17.0K    454.3M   0% /overlay
      overlayfs:/overlay      458.3M     17.0K    454.3M   0% /
      /dev/mmcblk0p8           28.5G      1.4M     28.5G   0% /mnt/UDISK
      root@TinaLinux:/# mount
      /dev/root on /rom type squashfs (ro,relatime)
      devtmpfs on /dev type devtmpfs (rw,relatime,size=54336k,nr_inodes=13584,mode=755)
      /proc on /proc type proc (rw,relatime)
      tmpfs on /tmp type tmpfs (rw,relatime)
      sys on /sys type sysfs (rw,relatime)
      /dev/by-name/rootfs_data on /overlay type ext4 (rw,sync,relatime,nodelalloc,data=journal)
      overlayfs:/overlay on / type overlay (rw,noatime,lowerdir=/,upperdir=/overlay/upper,workdir=/overlay/workdir)
      devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
      /dev/mmcblk0p8 on /mnt/UDISK type ext4 (rw,relatime)
      none on /sys/kernel/debug type debugfs (rw,relatime)
      adb命令
      E:\CloudMusic>adb -s 20080411 push ./voyager.wav  /mnt/UDISK
      [  7%] /mnt/UDISK/voyager.wav
