    V853 vision开发板,更改为st7701s 2 plane显示,出现错误
      miller370321 LV 3 最后由 编辑
      ![替代文字](问题1.PNG 图片地址)
      显示屏驱动文件如下:
      /* drivers/video/sunxi/disp2/disp/lcd/ST7796S.c
      • Copyright (c) 2017 Allwinnertech Co., Ltd.
      • Author: zhengxiaobin zhengxiaobin@allwinnertech.com
      • he0801a-068 panel driver
      • This program is free software; you can redistribute it and/or modify
      • it under the terms of the GNU General Public License version 2 as
      • published by the Free Software Foundation.
      [lcd0]
      • lcd_used = 1
      • lcd_driver_name = "st7701s"
      • lcd_bl_0_percent = 0
      • lcd_bl_40_percent = 23
      • lcd_bl_100_percent = 100
      • lcd_backlight = 88
      • lcd_if = 4
      • lcd_x = 480
      • lcd_y = 640
      • lcd_width = 36
      • lcd_height = 65
      • lcd_dclk_freq = 25
      • lcd_pwm_used = 1
      • lcd_pwm_ch = 8
      • lcd_pwm_freq = 50000
      • lcd_pwm_pol = 1
      • lcd_pwm_max_limit = 255
      • lcd_hbp = 70
      • lcd_ht = 615
      • lcd_hspw = 8
      • lcd_vbp = 30
      • lcd_vt = 690
      • lcd_vspw = 10
      • lcd_dsi_if = 0
      • lcd_dsi_lane = 2
      • lcd_dsi_format = 0
      • lcd_dsi_te = 0
      • lcd_dsi_eotp = 0
      • lcd_frm = 0
      • lcd_io_phase = 0x0000
      • lcd_hv_clk_phase = 0
      • lcd_hv_sync_polarity= 0
      • lcd_gamma_en = 0
      • lcd_bright_curve_en = 0
      • lcd_cmap_en = 0
      • lcdgamma4iep = 22
      • ;lcd_bl_en = port:PD09<1><0><default><1>
      • lcd_power = "vcc-lcd"
      • lcd_pin_power = "vcc18-dsi"
      • lcd_pin_power1 = "vcc-pd"
      • ;reset
      • lcd_gpio_0 = port:PD09<1><0><default><1>
        // written by Miller 2024-4-1
        #include "st7701s.h"
      static void lcd_power_on(u32 sel);
      static void lcd_power_off(u32 sel);
      static void lcd_bl_open(u32 sel);
      static void lcd_bl_close(u32 sel);
      static void lcd_panel_init(u32 sel);
      static void lcd_panel_exit(u32 sel);
      #define panel_reset(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
      static void lcd_cfg_panel_info(struct panel_extend_para *info)
      u32 i = 0, j = 0;
      u32 items;
      u8 lcd_gamma_tbl[][2] = {
      {0, 0}, {15, 15}, {30, 30}, {45, 45}, {60, 60},
      {75, 75}, {90, 90}, {105, 105}, {120, 120}, {135, 135},
      {150, 150}, {165, 165}, {180, 180}, {195, 195}, {210, 210},
      {225, 225}, {240, 240}, {255, 255},
      u32 lcd_cmap_tbl[2][3][4] = {
      	for (j = 0; j < num; j++) {
      		u32 value = 0;
      		value =
      		    lcd_gamma_tbl[i][1] +
      		    ((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) *
      		     j) /
      			num;
      		    (value << 16) + (value << 8) + value;
      info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
      			   (lcd_gamma_tbl[items - 1][1] << 8) +
      			   lcd_gamma_tbl[items - 1][1];
      static s32 lcd_open_flow(u32 sel)
      LCD_OPEN_FUNC(sel, lcd_power_on, 0);
      LCD_OPEN_FUNC(sel, lcd_panel_init, 120); //miller change 10-->120
      LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 10);
      LCD_OPEN_FUNC(sel, lcd_bl_open, 200); //miller change 0--200
      static s32 lcd_close_flow(u32 sel)
      LCD_CLOSE_FUNC(sel, lcd_bl_close, 0);
      LCD_CLOSE_FUNC(sel, lcd_panel_exit, 10);
      LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
      LCD_CLOSE_FUNC(sel, lcd_power_off, 0);
      sunxi_lcd_pin_cfg(sel, 1);
      sunxi_lcd_power_enable(sel, 0);
      // sunxi_lcd_power_enable(sel, 1);
      sunxi_lcd_delay_ms(40); //Miller change 10--->40
      /* reset lcd by gpio */
      panel_reset(sel, 1);
      sunxi_lcd_delay_ms(5);  //Miller change 1--->5
      panel_reset(sel, 0);
      sunxi_lcd_delay_ms(30);   //Miller change 1--->30
      sunxi_lcd_delay_ms(10);
      sunxi_lcd_pin_cfg(sel, 0);
      sunxi_lcd_delay_ms(1);
      sunxi_lcd_power_disable(sel, 0);
      sunxi_lcd_pwm_enable(sel);
      sunxi_lcd_backlight_enable(sel);
      sunxi_lcd_pwm_disable(sel);
      #define REGFLAG_DELAY 0XFE
      #define REGFLAG_END_OF_TABLE 0xFC /* END OF REGISTERS MARKER */
      struct LCM_setting_table {
      u8 cmd;
      u32 count;
      u8 para_list[18];
      static struct LCM_setting_table lcm_initialization_setting[] = {
      {0x11, 1, {0x00} }, //miller turns off sleep
      {REGFLAG_DELAY, 60, {} },
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x13} },//miller add
      {0xef, 1, {0x08} }, //Miller add
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x10} }, //Miller 这里采用第二个0xFF
      {0xc0, 2, {0x63, 0x00} }, //Miller change 0x4f-->0x63
      {0xc1, 2, {0x0A, 0x0C} }, //Miller change 07 02 -->0a 0c
      {0xc2, 2, {0x31, 0x08} }, //miller 31 05 --> 31 08
      {0xcc, 1, {0x18} },       //miller 10  -->18
      {0xb0, 16, {0x00, 0x08, 0x10, 0x0E, 0x11, 0x07, 0x08, 0x08, 0x08, 0x25,
      	   0x04, 0x12, 0x0F, 0x2C, 0x30, 0x1F} },//Miller change
      {0xb1, 16, {0x00, 0x11, 0x18, 0x0c, 0x10, 0x05, 0x07, 0x09, 0x08, 0x24,
      	    0x04, 0x11, 0x10, 0x2B, 0x30, 0x1F} },
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x11} },
      {0xb0, 1, {0x4D} },//Miller 0x53-->0x4D
      {0xb1, 1, {0x39} },// Miller 0x60-->0x39
      {0xb2, 1, {0x87} },//miller 0x07--> 0x87
      {0xb3, 1, {0x80} },//miller 0x08-->0x80
      {0xb5, 1, {0x47} },//miller 0x49-->0x47
      {0xb7, 1, {0x8A} },//miller 85--> 8A
      {0xb8, 1, {0x20} },//miller 21---20
      {0xb9, 2, {0x10, 0x13} },//miller
          {0xc0, 1, {0x09} }, //miller add
      {0xc1, 1, {0x78} },
      {0xc2, 1, {0x78} },// miller add
      //{REGFLAG_DELAY, 50, {} }, //miller delete
      {0xd0, 1, {0x88} },
          {REGFLAG_DELAY, 100, {} },  // miller add
      {0xe0, 3, {0x00, 0x00, 0x02} },
      {0xe1, 11, {0x04, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x00, 0x20,
      	    0x20} }, //miller
      {0xe2, 13, {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      	    0x00, 0x00, 0x00} },//miller
      {0xe3, 4, {0x00, 0x00, 0x33, 0x00} },//miller
      {0xe4, 2, {0x22, 0x00} },//miller
      {0xe5, 16, {0x04, 0x34, 0xaa, 0xaa, 0x06, 0x34, 0xaa, 0xaa, 0x00, 0x00,
      	    0x00, 0x00, 0x00, 0x00, 0x00, 0x00} },//miller
      {0xe6, 4, {0x00, 0x00, 0x43, 0x00} }, //miller
      {0xe7, 2, {0x22, 0x00} },  //miller
      {0xe8, 16, {0x05, 0x35, 0xaa, 0xaa, 0x07, 0x35, 0xaa, 0xaa, 0x00, 0x00,
      {0xeb, 7, {0x02, 0x00, 0x40, 0x40, 0x00, 0x00, 0x00} },//miller
      {0xec, 2, {0x00, 0x00} },//miller
      {0xed, 16, {0xfa, 0x46, 0x0c, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
      	    0xff, 0xff, 0xff, 0xb1, 0x44, 0xbf} },//miller
      {0xef, 6, {0x10, 0x0d, 0x04, 0x08, 0x3f, 0x1f} }, //Miller
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x13} },       //miller
      //{REGFLAG_DELAY, 50, {} },//miller delete
      {0xe8, 2, {0x00, 0x0e} }, //miller add
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x00} },       //miller add
      {0x11, 1, {0x00} }, //miller add
      {REGFLAG_DELAY, 120, {} },//miller add
      {0xff, 5, {0x77, 0x01, 0x00, 0x00, 0x13} },       //miller add
      {0xe8, 2, {0x00, 0x0c} }, //miller add
      {REGFLAG_DELAY, 10, {} },//miller add
      {0xe8, 2, {0x00, 0x00} }, //miller add
      {0x29, 1, {0x00} },
      {REGFLAG_DELAY, 20, {} },//miller add
      {REGFLAG_END_OF_TABLE, 0x00, {} }
      u32 i = 0;
      sunxi_lcd_dsi_clk_enable(sel);
      for (i = 0;; i++) {
      	if (lcm_initialization_setting[i].cmd == REGFLAG_END_OF_TABLE)
      		break;
      	else if (lcm_initialization_setting[i].cmd == REGFLAG_DELAY)
      		sunxi_lcd_delay_ms(lcm_initialization_setting[i].count);
      	else {
      		dsi_dcs_wr(0, lcm_initialization_setting[i].cmd,
      			   lcm_initialization_setting[i].para_list,
      sunxi_lcd_dsi_dcs_write_0para(sel, 0x28);
      sunxi_lcd_dsi_dcs_write_0para(sel, 0x10);
      /sel: 0:lcd0; 1:lcd1/
      static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      struct __lcd_panel st7701s_panel = {
      /* panel driver name, must mach the name of
      * lcd_drv_name in sys_config.fex
      .name = "st7701s",
      .func = {
      .cfg_panel_info = lcd_cfg_panel_info,
      .cfg_open_flow = lcd_open_flow,
      .cfg_close_flow = lcd_close_flow,
      .lcd_user_defined_func = lcd_user_defined_func,
      dts 改动如下
      &lcd0{
      base_config_start   = <1>;
      lcd_used            = <1>;
      lcd_driver_name     = "st7701s";
      lcd_bl_0_percent    = <0>;
      lcd_bl_40_percent   = <23>;
      lcd_bl_100_percent  = <100>;
      lcd_backlight       = <150>;
      lcd_if              = <4>;
      lcd_x               = <800>;
      lcd_y               = <480>;
      lcd_width           = <94>;
      lcd_height          = <56>;
      lcd_dclk_freq       = <24>; //HT*VT*fps
      lcd_pwm_used        = <1>;
      lcd_pwm_ch          = <9>;
      lcd_pwm_pol         = <0>; // 0 active high
      lcd_pwm_max_limit   = <255>;
      lcd_hbp             = <86>;
      lcd_ht              = <966>;
      lcd_hspw            = <6>;
      lcd_vbp             = <36>;
      lcd_vt              = <546>;
      lcd_vspw            = <6>;
      lcd_dsi_if          = <0>;
      lcd_dsi_lane        = <2>;
      lcd_dsi_format      = <0>; //RGB888
      lcd_dsi_te          = <0>;
      lcd_dsi_eotp        = <0>;
      lcd_frm             = <0>;
      lcd_hv_clk_phase    = <0>;
      lcd_hv_sync_polarity= <0>;
      lcd_gamma_en        = <0>;
      lcd_bright_curve_en = <0>;
      lcd_cmap_en         = <0>;
      lcdgamma4iep        = <22>;
      lcd_gpio_0          = <&pio PD 19 1 0 3 1>;
      lcd_gpio_1          = <&pio PD 20 1 0 3 1>;
      pinctrl-0           = <&dsi2lane_pins_a>;
      pinctrl-1           = <&dsi2lane_pins_b>;
      base_config_end     = <1>;
      &pio{
      dsi2lane_pins_a: dsi2lane@0 {
      allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6";
      allwinner,pname = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6";
      allwinner,function = "dsi";
      allwinner,muxsel = <5>;
      allwinner,drive = <3>;
      allwinner,pull = <0>;
      dsi2lane_pins_b: dsi2lane@1 {
          allwinner,muxsel = <0xf>;
          allwinner,drive = <1>;
        lxs00 LV 2 最后由 编辑
        请问后续改好了吗?
