    移植蓝牙无法扫描连接设备
      SkrLOU LV 5 最后由 编辑
      lsmod
      8733bu 2465792 0
      fuse 90112 0
      ip_tables 24576 4 iptable_raw
      ipt_REJECT 16384 0
      iptable_filter 16384 0
      iptable_mangle 16384 0
      iptable_nat 16384 0
      iptable_raw 16384 0
      rtk_btusb 61440 0
      xt_CT 16384 0
      xt_LOG 16384 0
      xt_REDIRECT 16384 0
      xt_TCPMSS 16384 0
      xt_comment 16384 0
      xt_conntrack 16384 0
      xt_limit 16384 0
      xt_mac 16384 0
      xt_mark 16384 0
      xt_multiport 16384 0
      xt_state 16384 0
      xt_time 16384 0
      root@TinaLinux:/# hciconfig -a
      hci0: Type: Primary Bus: USB
      BD Address: A8:43:A4:43:4C:CD ACL MTU: 1021:6 SCO MTU: 255:12
      DOWN
      RX bytes:641 acl:0 sco:0 events:37 errors:0
      TX bytes:393 acl:0 sco:0 commands:37 errors:0
      Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
      Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
      Link policy: RSWITCH HOLD SNIFF PARK
      Link mode: SLAVE ACCEPT
      root@TinaLinux:/# bluetoothd -d -n &
      root@TinaLinux:/# bluetoothd[2222]: Bluetooth daemon 5.54
      bluetoothd[2222]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'DiscoverableTimeout' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'AlwaysPairable' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'PairableTimeout' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'Privacy' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'JustWorksRepairing' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'Name' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'Class' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'DeviceID' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'ReverseServiceDiscovery' in group 'General'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'Cache' in group 'GATT'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'KeySize' in group 'GATT'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'ExchangeMTU' in group 'GATT'
      bluetoothd[2222]: src/main.c:parse_config() Key file does not have key 'Channels' in group 'GATT'
      bluetoothd[2222]: src/adapter.c:adapter_init() sending read version command
      bluetoothd[2222]: Starting SDP server
      bluetoothd[2222]: src/sdpd-service.c:register_device_id() Adding device id record for 0002:1d6b:0246:0536
      bluetoothd[2222]: src/plugin.c:plugin_init() Loading builtin plugins
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading hostname plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading wiimote plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading autopair plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading policy plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading a2dp plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading avrcp plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading network plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading input plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading hog plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading gap plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading scanparam plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading deviceinfo plugin
      bluetoothd[2222]: src/plugin.c:add_plugin() Loading battery plugin
      bluetoothd[2222]: src/plugin.c:plugin_init() Loading plugins /usr/lib/bluetooth/plugins
      bluetoothd[2222]: Failed to init battery plugin
      bluetoothd[2222]: profiles/input/suspend-none.c:suspend_init()
      bluetoothd[2222]: profiles/network/manager.c:read_config() /etc/bluetooth/network.conf: Key file does not have key 'DisableSecurity' in group 'General'
      bluetoothd[2222]: profiles/network/manager.c:read_config() Config options: Security=true
      bluetoothd[2222]: kernel lacks bnep-protocol support
      bluetoothd[2222]: System does not support network plugin
      bluetoothd[2222]: src/main.c:main() Entering main loop
      bluetoothd[2222]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 2 op 0 soft 1 hard 0
      bluetoothd[2222]: Bluetooth management interface 1.14 initialized
      bluetoothd[2222]: src/adapter.c:read_version_complete() sending read supported commands command
      bluetoothd[2222]: src/adapter.c:read_version_complete() sending read index list command
      bluetoothd[2222]: src/rfkill.c:rfkill_event() RFKILL event idx 1 type 2 op 0 soft 0 hard 0
      bluetoothd[2222]: src/rfkill.c:rfkill_event() RFKILL event idx 2 type 1 op 0 soft 0 hard 0
      bluetoothd[2222]: src/adapter.c:read_commands_complete() Number of commands: 65
      bluetoothd[2222]: src/adapter.c:read_commands_complete() Number of events: 35
      bluetoothd[2222]: src/adapter.c:read_commands_complete() enabling kernel-side connection control
      bluetoothd[2222]: src/adapter.c:read_index_list_complete() Number of controllers: 1
      bluetoothd[2222]: src/adapter.c:read_index_list_complete() Found index 0
      bluetoothd[2222]: src/adapter.c:index_added() index 0
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() System name: BlueZ 5.54
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() Major class: 0
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() Minor class: 0
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() Modalias: usb:v1D6Bp0246d0536
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() Discoverable timeout: 180 seconds
      bluetoothd[2222]: src/adapter.c:btd_adapter_new() Pairable timeout: 0 seconds
      bluetoothd[2222]: src/adapter.c:index_added() sending read info command for index 0
      bluetoothd[2222]: src/adapter.c:read_info_complete() index 0 status 0x00
      bluetoothd[2222]: src/adapter.c:clear_uuids() sending clear uuids command for index 0
      bluetoothd[2222]: src/adapter.c:clear_devices() sending clear devices command for index 0
      bluetoothd[2222]: src/adapter.c:set_mode() sending set mode command for index 0
      bluetoothd[2222]: src/adapter.c:set_privacy() sending set privacy command for index 0
      bluetoothd[2222]: src/adapter.c:set_privacy() setting privacy mode 0x00 for index 0
      bluetoothd[2222]: src/advertising.c:btd_adv_manager_new() LE Advertising Manager created for adapter: /org/bluez/hci0
      bluetoothd[2222]: profiles/audio/a2dp.c:media_server_probe() path /org/bluez/hci0
      bluetoothd[2222]: plugins/hostname.c:hostname_probe()
      bluetoothd[2222]: profiles/audio/avrcp.c:avrcp_controller_server_probe() path /org/bluez/hci0
      bluetoothd[2222]: src/adapter.c:adapter_service_add() /org/bluez/hci0
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Adding record with handle 0x10001
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00000017-0000-1000-8000-00805f9
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00000100-0000-1000-8000-00805f9
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 00001002-0000-1000-8000-00805f9
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110e-0000-1000-8000-00805f9
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110f-0000-1000-8000-00805f9
      bluetoothd[2222]: src/adapter.c:adapter_service_insert() /org/bluez/hci0
      bluetoothd[2222]: src/adapter.c:add_uuid() sending add uuid command for index 0
      bluetoothd[2222]: profiles/audio/avrcp.c:avrcp_target_server_probe() path /org/bluez/hci0
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Adding record with handle 0x10002
      bluetoothd[2222]: src/sdpd-service.c:add_record_to_server() Record pattern UUID 0000110c-0000-1000-8000-00805f9
      bluetoothd[2222]: profiles/audio/a2dp.c:a2dp_sink_server_probe() path /org/bluez/hci0
      bluetoothd[2222]: profiles/audio/a2dp.c:a2dp_source_server_probe() path /org/bluez/hci0
      bluetoothd[2222]: src/adapter.c:btd_adapter_unblock_address() hci0 00:00:00:00:00:00
      bluetoothd[2222]: src/adapter.c:load_link_keys() hci0 keys 0 debug_keys 0
      bluetoothd[2222]: src/adapter.c:load_ltks() hci0 keys 0
      bluetoothd[2222]: src/adapter.c:load_irks() hci0 irks 0
      bluetoothd[2222]: src/adapter.c:load_conn_params() hci0 conn params 0
      bluetoothd[2222]: src/adapter.c:set_did() hci0 source 2 vendor 1d6b product 246 version 536
      bluetoothd[2222]: src/adapter.c:adapter_register() Adapter /org/bluez/hci0 registered
      bluetoothd[2222]: src/adapter.c:set_dev_class() sending set device class command for index 0
      bluetoothd[2222]: src/adapter.c:set_name() sending set local name command for index 0
      bluetoothd[2222]: src/adapter.c:new_settings_callback() Settings: 0x000000c0
      bluetoothd[2222]: src/adapter.c:settings_changed() Changed settings: 0x00000040
      bluetoothd[2222]: src/adapter.c:settings_changed() Pending settings: 0x00000000
      bluetoothd[2222]: src/adapter.c:new_settings_callback() Settings: 0x000002c0
      bluetoothd[2222]: src/adapter.c:settings_changed() Changed settings: 0x00000200
      bluetoothd[2222]: src/adapter.c:new_settings_callback() Settings: 0x00000ac0
      bluetoothd[2222]: src/adapter.c:settings_changed() Changed settings: 0x00000800
      bluetoothd[2222]: src/adapter.c:set_privacy_complete() Successfuly set privacy for index 0
      bluetoothd[2222]: src/adapter.c:load_link_keys_complete() link keys loaded for hci0
      bluetoothd[2222]: src/adapter.c:load_ltks_complete() LTKs loaded for hci0
      bluetoothd[2222]: src/adapter.c:load_irks_complete() IRKs loaded for hci0
      bluetoothd[2222]: src/adapter.c:load_conn_params_complete() Connection Parameters loaded for hci0
      bluetoothd[2222]: src/adapter.c:local_name_changed_callback() Name: aw-bt-test-4C-CD
      bluetoothd[2222]: src/adapter.c:local_name_changed_callback() Short name:
      bluetoothd[2222]: src/adapter.c:local_name_changed_callback() Current alias: aw-bt-test-4C-CD
      root@TinaLinux:/#
      root@TinaLinux:/#
      bluealsa bluemoon bluetoothctl
      bluealsa-aplay bluetooth-meshd bluetoothd
      root@TinaLinux:/# bluetoothctl
      [bluetooth]# bluetoothd[2222]: src/agent.c:add_default_agent() Default agent set to :1.1 /org/bluez/agent
      bluetoothd[2222]: src/agent.c:agent_ref() 0xb6e88f30: ref=1
      bluetoothd[2222]: src/agent.c:register_agent() agent :1.1
      bluetoothd[2222]: src/adapter.c:new_settings_callback() Settings: 0x00000ad0
      bluetoothd[2222]: src/adapter.c:settings_changed() Changed settings: 0x00000010
      Agent registered
      [CHG] Controller A8:43:A4:43:4C:CD Pairable: yes
      [bluetooth]# show
      Controller A8:43:A4:43:4C:CD (public)
      Alias: aw-bt-test-4C-CD
      Class: 0x00000000
      Powered: no
      Discoverable: no
      DiscoverableTimeout: 0x000000b4
      Pairable: yes
      UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
      UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
      UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
      Discovering: no
      Advertising Features:
      ActiveInstances: 0x00
      SupportedInstances: 0x05
      SupportedIncludes: appearance
      SupportedIncludes: local-name
      [bluetooth]# power on
      [bluetooth]# bluetoothd[2222]: src/adapter.c:property_set_mode() sending Set Powered command for index 0
      bluetoothd[2222]: src/adapter.c:property_set_mode_complete() Success (0x00)
      bluetoothd[2222]: src/adapter.c:new_settings_callback() Settings: 0x00000ad1
      bluetoothd[2222]: src/adapter.c:settings_changed() Changed settings: 0x00000001
      bluetoothd[2222]: src/adapter.c:adapter_start() adapter /org/bluez/hci0 has been enabled
      bluetoothd[2222]: src/adapter.c:trigger_passive_scanning()
      Changing power on succeeded
      [CHG] Controller A8:43:A4:43:4C:CD Powered: yes
      [bluetooth]# scan on
      [bluetooth]# bluetoothd[2222]: src/adapter.c:start_discovery() sender :1.1
      bluetoothd[2222]: src/adapter.c:update_discovery_filter()
      bluetoothd[2222]: src/adapter.c:discovery_filter_to_mgmt_cp()
      bluetoothd[2222]: src/adapter.c:trigger_start_discovery()
      bluetoothd[2222]: src/adapter.c:cancel_passive_scanning()
      bluetoothd[2222]: src/adapter.c:start_discovery_timeout()
      bluetoothd[2222]: src/adapter.c:start_discovery_timeout() adapter->current_discovery_filter == 0
      bluetoothd[2222]: src/adapter.c:start_discovery_complete() status 0x00
      bluetoothd[2222]: src/adapter.c:discovering_callback() hci0 type 7 discovering 1 method 0
      Discovery started
      [CHG] Controller A8:43:A4:43:4C:CD Discovering: yes
      [bluetooth]# bluetoothd[2222]: src/adapter.c:discovering_callback() hci0 type 7 discovering 0 method 0
      [bluetooth]# show
      Class: 0x00000000
      Powered: yes
      Discoverable: no
      Pairable: yes
      Discovering: yes
      有没有大佬有经验 帮忙看看啥原因啊
