    V853 适配IMX386摄像头 ISP配置
    • ZibetK
      ZibetK LV 3 最后由 编辑
      v853通过4lane完成了连接IMX386摄像头,也配置了ISP600,isp编译也没报错,opencv也编译成功了,但是isp因为没有对应配置导致出错
      错误如下cannot find imx386_mipi_1920_1080_30_0_0 isp config, use gc2053_mipi_1920_1080_20_0_0
      opencv_camear运行如下
      root@TinaLinux:/# opencv_camera
      [ 4433.308007] [imx386_mipi]PWR_ON!_4Lane
      [ 4433.322478] [imx386_mipi]sensor_init, version 0301
      [ 4433.328554] [imx386_mipi]camera raw sensor 0x386
      Successfully opened video device[ 4433.335764] [VIN_ERR]video0 has already stream off
      [ 4433.344530] [imx386_mipi]sensor_init, version 0301
      [ 4433.350472] [imx386_mipi]camera raw sensor 0x386
      [ISP]video device name is vin_video0
      cutils:D/AWIspApi: F:awIspGetIspId, L:48, video0 --> isp1[ISP]open isp device[1] success!
      [ISP_WARN]VIDIOC_VIN_GET_SENSOR_OTP_INFO return error:Invalid argument
      [ISP]otp disabled, msc use 1024
      [ISP]get isp_ctx from /mnt/isp1_1920_1080_30_0_ctx_sav[ 4433.383946] [imx386_mipi]sensor_s_stream on = 1, 1920*1080 fps: 30 code: 300f
      ed.bin success!!!
      [ISP_WARN]cannot find imx386_mipi_1920_1080_30_0_0 isp config, use gc2053_mipi_1920_1080_20_0_0 -> [gc2053_mipi_default_ini_v853]
      [ISP]create isp1 server thread!
      [ 4433.408060] [imx386_mipi]sensor_reg_init
      [ 4433.735844] [VIN_ERR]scaler0 frame lost!!!
      [ 4433.889966] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.044091] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.198218] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.352344] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.506471] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.660595] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.814721] [VIN_ERR]scaler0 frame lost!!!
      [ 4434.968847] [VIN_ERR]scaler0 frame lost!!!
      [ 4435.122974] [VIN_ERR]scaler0 frame lost!!!
      ^CGot signal 2, exiting ...
      [ 4435.277102] [VIN_ERR]scaler0 frame lost!!!
      [ 4435.384082] [VIN_WARN]Video0 over 2s no frame received!!!
      [ 4435.431224] [VIN_ERR]scaler0 frame lost!!!
      [ 4435.585351] [VIN_ERR]scaler0 frame lost!!!
      [ 4435.739476] [VIN_ERR]scaler0 frame lost!!!
      [ 4435.893602] [VIN_ERR]scaler0 frame lost!!!
      [ 4436.047730] [VIN_ERR]scaler0 frame lost!!!
      [ 4436.201855] [VIN_ERR]scaler0 frame lost!!!
      [ 4436.355982] [VIN_ERR]scaler0 frame lost!!!
      CameraDemo可以拍摄图片,但是只能保存为raw格式不能通过isp输出bmp 如下
      root@TinaLinux:/# camerademo
      [CAMERA][ 4473.142810] [imx386_mipi]sensor_init, version 0301
      ******************************[ 4473.151471] [imx386_mipi]camera raw sensor 0x386
      [CAMERA]
      [CAMERA]
      this is camera test. [ 4473.168685] [imx386_mipi]sensor_s_stream on = 1, 1920
      [CAMERA]
      [CAMERA]
      [CAMERA]************************************[ 4473.192759] [imx386_mipi]sensor_reg_init
      [CAMERA] open /dev/video0!
      [CAMERA]**********************************************************
      [CAMERA] The path to data saving is /tmp.
      [CAMERA] The number of captured photos is 5.
      [CAMERA] save bmp format
      [CAMERA] Using format parameters RGGB10.
      [CAMERA] camera pixelformat: RGGB10
      [CAMERA] Resolution size : 1920 * 1080
      [CAMERA] The photo save path is /tmp.
      [CAMERA] The number of photos taken is 5.
      begin ion_alloc_open
      pid: 1208, g_alloc_context = 0x39950
      [CAMERA] Camera capture framerate is 30/1
      [CAMERA] VIDIOC_S_FMT succeed
      [CAMERA] fmt.type = 9
      [CAMERA] fmt.fmt.pix_mp.width = 1920
      [CAMERA] fmt.fmt.pix_mp.height = 1080
      [CAMERA] fmt.fmt.pix_mp.pixelformat = RGGB10
      [CAMERA] fmt.fmt.pix_mp.field = 1
      [CAMERA] camera.nplanes = 1
      [CAMERA] stream on succeed
      [CAMERA] camera0 capture num is [0]
      [CAMERA_PROMPT] the time interval from the start to the first frame is 138 ms
      [CAMERA] camera0 capture num is [1]
      [CAMERA] camera0 capture num is [2]
      [CAMERA] camera0 capture num is [3]
      [CAMERA] camera0 capture num is [4]
      [CAMERA] Capture thread finish[ 4473.629398] [imx386_mipi]sensor_s_stream on = 0, 1920*1080 fps: 30 code: 300f
      [CAMERA] close /dev/video0
      ion_alloc_close
      pid: 1208, release g_alloc_context = 0x39950
      源码中openwrt/package/allwinner/vision/libAWIspAPI/src/isp600/isp_cfg/SENSOR-H/内只有gc2053和gc4663两个配置
