    D1上面跑melis,起来就崩了
    • G
      geniusgogo LV 4 最后由 编辑
      [284]HELLO! BOOT0 is starting!
      [287]BOOT0 commit : 6ef7a6c-dirty
      [290]set pll start
      [292]periph0 has been enabled
      [295]set pll end
      [296][pmu]: bus read error
      [299]board init ok
      [301]DRAM only have internal ZQ!!
      [304]get_pmu_exist() = -1
      [306]DRAM BOOT DRIVE INFO: V0.23
      [309]DRAM CLK = 792 MHz
      [311]DRAM Type = 3 (2:DDR2,3:DDR3)
      [315]DRAMC ZQ value: 0x7b7bfb
      [317]DRAM ODT value: 0x42.
      [320]ddr_type: 0x0
      [323]DRAM SIZE =1024 M
      [326]DRAM simple test OK.
      [328]dram size =1024
      [330]spinor id is: ef 40 18, read cmd: 6b
      [334]Succeed in reading toc file head.
      [338]The size of toc is 90000.
      [364]Entry_name        = melis-lzma
      [367]LZMA: Image address............... 0x41000400
      [372]LZMA: Properties address.......... 0x41000400
      [377]LZMA: Uncompressed size address... 0x41000405
      [381]LZMA: Compressed data address..... 0x4100040d
      [386]LZMA: Destination address......... 0x40000000
      [390]LZMA: Uncompresed size............ 0xffffffffffffffff
      [396]LZMA: Compresed size.............. 0xfffffffa
      [564]LZMA: Uncompressed ............... 0x001191e8
      [569]Entry_name        = melis-config
      [572]image_base:43000000
      [575]Jump to second Boot.
      [577]jump to rtos
      OpenSBI v0.6
              |_|
      Platform Name          : T-HEAD Xuantie c910
      Platform Max HARTs     : 1
      Current Hart           : 0
      Firmware Size          : 56 KB
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP0    : 0x0000000040000000-0x000000004000ffff (A)
      PMP2    : 0x0000000000000000-0x0000000007ffffff (A,R,W)
      PMP3    : 0x0000000009000000-0x000000000901ffff (A,R,W)
      PMP4    : 0x0000000010000000-0x0000000017ffffff (A,R,W)
      sbi2ekernel
      |                   /'\_/`\       (_ )  _                       /'_  )    /'_ `\   /' _`\                     |
      |                   |     |   __   | | (_)  ___  ______  _   _ (_)_) |   ( (_) |   | ( ) |                    |
      |                   | (_) | /'__`\ | | | |/',__)(______)( ) ( ) _(_ <     \__, |   | | | |                    |
      |                   | | | |(  ___/ | | | |\__, \        | \_/ |( )_) | _     | | _ | (_) |                    |
      |                   (_) (_)`\____)(___)(_)(____/        `\___/'`\____)(_)    (_)(_)`\___/'                    |
      |version : V3.9.0        |
      |commitid: 976499a346a3d5d6d80047f3844d1d5c3e37ac55                                                           |
      |sunxiver: 30800        |
      |timever : Mon, 01 Nov 2021 18:21:20 +0800        |
      |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104)                                           |
      |optimal : -Os -g -gdwarf-2 -gstrict-dwarf        |
      |linker  : GNU ld (GNU Binutils) 2.32        |
      |newlibc : 3.0.0        |
      |author  : zhouji        |
      [DBG]: [__mount_parts:0273]:                                classname=DMS
      [DBG]: [__mount_parts:0274]:                                devname=dms01
      [DBG]: [__mount_parts:0301]:                                find last lun.
      [DBG]: [__mount_parts:0331]:                                nPart = 1.
      [DBG]: [__mount_parts:0460]:                                dmsPart: "DMS\dms010" is linked to symbel "B".
      [ERR]: [esFSYS_pread:0318]:                                 fs fatal err
      [DBG]: [esFSYS_mntfs:0317]:                                 devfs,mount on B.
      [DBG]: [kservice_maintask:0834]:                            partition [B] plug in..
      [DBG]: [__mount_parts:0273]:                                classname=DISK
      [DBG]: [__mount_parts:0274]:                                devname=RAMDISK
      [DBG]: [__mount_parts:0460]:                                rawpart: "DISK\RAMDISK0" is linked to symbel "C".
      [ERR]: [esFSYS_mntfs:0298]:                                 identify the filesystem failure.
      [ERR]: [scheduler startup
      [DBG]: [__mount_parts:0274]:                                devname=ROOTFS
      [DBG]: [__mount_parts:0460]:                                rawpart: "DISK\ROOTFS0" is linked to symbel "D".
      [DBG]: [esFSYS_mntfs:0317]:                                 minfs,mount on D.
      [DBG]: [kservice_maintask:0834]:                            partition [D] plug in..
      [DBG]: [melis_udisk_part_check:0553]:                       melis_udisk_part_check 553 copy udisk_buff
      [DBG]: [__mount_parts:0274]:                                devname=UDISK
      [DBG]: [__mount_parts:0423]:                                rawpart: "DISK\UDISK0" is linked to symbel "E".
      [ERR]: [__mount_parts:0501]:                                mount E failure.
      [ERR]: [sunxi_driver_sdmmc_init:0930]:                      get	card no failed, card no: 0
      [ERR]: [hal_ths_init:0094]:                                 0x2009404, 0x2009400, 0x2009430, 0x2009408
      key name:thermal_sensor key size:64 key offset:20
      thermal_sensor:
      19 91 37 79 10 20 00 00
      [ERR]: [gpio_conf_set:0456]:                                gpio_desc is not inited
      [ERR]: [hal_gpio_pinmux_set_function:0689]:                 set pin mux error!
      s[DBG]: [console_LKeyDevEvent:0530]:                        input sys keydev not init!
      unxi_cir_init()509 cir[0] hardware init error, ret:-4
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\slib.mod.
      [ERR]: [LDR_LoadFile:0257]:                                 open file [d:\mod\slib.mod] failed
      [ERR]: [esMODS_MInstall:0585]:                              load module file [d:\mod\slib.mod] failed
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\display.mod.
      [DBG]: [LDR_LoadFile:0247]:                                 filepath = d:\mod\mixture.mod.
                                               EXC_LOAD_PAGE_FAULT
      thread: kstartup, entry: 0x0000000040029d24, stack_base: 0x0000000040234000,stack_size: 0x00004000.
      gprs:
       x0:0x0000000000000000   ra:0x00000000e9b00e88   sp:0x0000000040237f60   gp:0x0000000040118dc0
       tp:0x0000000040214080   t0:0x0000000000000048   t1:0x00000000e9b00e00   t2:0x000000004124e644
       s0:0x00000000000001f4   s1:0x00000000e9b037c0   a0:0x00000000402f8448   a1:0x0000000000000000
       a2:0x00000000000000c8   a3:0x0000000000afdb90   a4:0x000000004012cbe0   a5:0x00000000e8700000
       a6:0x0000000000000007   a7:0x0000000010000207   s2:0x00000000e9b037c8   s3:0x000000004002eb54
       s4:0x0000000040214038   s5:0x00000000deadbeef   s6:0x00000000deadbeef   s7:0x00000000deadbeef
       s8:0x00000000deadbeef   s9:0x00000000deadbeef  s10:0x00000000deadbeef  s11:0x00000000deadbeef
       t3:0x000000000000075c   t4:0x00000000000000c6   t5:0x0000000000000121   t6:0x00000000000000d5
      other:
      sepc    :0x00000000e9b01948
      sstatus :0x0000000000004120
      sscratch:0x0000000000000000
      stval   :0x00000000e87000a8
      -------backtrace-----------
      backtrace : 0XE9B01948
      backtrace : invalid lr
      backtrace : 0XE9B00E84
      backtrace : 0X40128976
          -----------------------------------------------TSK Usage Report----------------------------------------------------------
              name     errno    entry       stat   prio     tcb     slice stacksize      stkfree  lt    si   so       stack_range
                disp2    0   0x4002fac8    suspend   15   0x402151b8   10     8192        7872    10  0000 0000  [0x40f78000-0x40f7a000]
            kmsg2appq    0   0x400a6794    suspend    6   0x40214538   10     4096        3392    08  0000 0000  [0x403c0000-0x403c1000]
              fs-pmnt    0   0x400cfe9e    suspend    7   0x402142b8   10    16384       15424    06  0000 0000  [0x40358000-0x4035c000]
             kstartup    0   0x40029d24    running   25   0x40214038   10    16384       13120    01  0000 0000  [0x40234000-0x40238000]
                tidle    0   0x4002bc80    running   31   0x40126030   32     8192        7504    19  0000 0000  [0x401262a8-0x401282a8]
                timer    0   0x4002f974    suspend    8   0x40128978   10    16384       16064    10  0000 0000  [0x40128bd0-0x4012cbd0]
          memory info:
      	Total  0x1feb4000
      	Used   0x00af7840
      	Max    0x00afdb90
          ------------------------------------------------memory information-------------------------------------------------------
      dump stack memory:
      0x0000000040237f60: 0x0000075c 0x00000000 0x000000c6 0x00000000
      0x0000000040237f70: 0x000001f4 0x00000000 0x000000fb 0x00000000
      0x0000000040237f80: 0x00000000 0x00000000 0x40029dec 0x00000000
      0x0000000040237f90: 0x40029164 0x00000000 0x00004120 0x00000000
      0x0000000040237fa0: 0xffffffff 0xffffffff 0x40029d24 0x00000000
      0x0000000040237fb0: 0x00000000 0x00000000 0x40128978 0x00000000
      0x0000000040237fc0: 0x40029d24 0x00000000 0x400291c4 0x00000000
      0x0000000040237fd0: 0xffffffff 0xffffffff 0x40029d24 0x00000000
      0x0000000040237fe0: 0x00000000 0x00000000 0x4002eb54 0x00000000
      0x0000000040237ff0: 0xdeadbeef 0x00000000 0x40029164 0x00000000
      0x0000000040238000: 0x51ab51ab 0x00000c4a 0x00000081 0x00000ccb
      0x0000000040238010: 0x00000000 0x00000000 0x40238038 0x00000000
      0x0000000040238020: 0x00000080 0x00000028 0x00000004 0x00000000
      0x0000000040238030: 0x00000000 0x00000000 0x40258038 0x00000000
      0x0000000040238040: 0x00000000 0xffffff00 0x40237f08 0x00000000
      0x0000000040238050: 0x016e3600 0x00000000 0x00000000 0x00000000
      0x0000000040238060: 0x402580b0 0x00000000 0x00000001 0xffffff00
      0x0000000040238070: 0x40237f08 0x00000000 0x00008000 0x00000000
      0x0000000040238080: 0x00000000 0x00000000 0x40258128 0x00000000
      0x0000000040238090: 0x00000002 0xffffff00 0x40237f08 0x00000000
      0x00000000402380a0: 0x00f42400 0x00000000 0x11e1a300 0x00000000
      0x00000000402380b0: 0x402581a0 0x00000000 0x00000003 0xffffff00
      0x00000000402380c0: 0x40237f08 0x00000000 0x00008000 0x00000000
      0x00000000402380d0: 0x00000000 0x00000000 0x00000000 0x00000000
      0x00000000402380e0: 0x40258128 0x00000000 0x00000000 0x00000000
      0x00000000402380f0: 0x400d5410 0x00000000 0xffffffff 0xffffffff
      0x0000000040238100: 0x00000000 0x00000000 0x402581a0 0x00000000
      0x0000000040238110: 0x00000000 0x00000000 0x400d5408 0x00000000
      0x0000000040238120: 0xffffffff 0xffffffff 0x00000000 0x00000000
      0x0000000040238130: 0x40258218 0x00000000 0x00000000 0x00000000
      0x0000000040238140: 0x400d4cd8 0x00000000 0xffffffff 0xffffffff
      0x0000000040238150: 0x00000000 0x00000000 0x40258038 0x00000000
      dump sepc memory:
      0x00000000e9b01948: 0x0a87b303 0x77b78302 0x07a200e8 0x0b07b303
      0x00000000e9b01958: 0xc5058302 0x4781471d 0x02b77263 0x46111141
      0x00000000e9b01968: 0x00002597 0xe4058593 0xf0efe406 0x3793fc5f
      0x00000000e9b01978: 0x60a20015 0x0141853e 0x47818082 0x8082853e
      0x00000000e9b01988: 0x479dc539 0x04b7f563 0x46111141 0x00002597
      0x00000000e9b01998: 0xe1458593 0xe406e022 0xf0ef842a 0xe515f95f
      0x00000000e9b019a8: 0x00544783 0x00444503 0x0087979b 0x45039fa9
      0x00000000e9b019b8: 0x151b0064 0x9fa90105 0x00744503 0x0185151b
      0x00000000e9b019c8: 0x60a29d3d 0x01416402 0x45018082 0x4501bfdd
      0x00000000e9b019d8: 0x87b28082 0xcd118736 0xfc63469d 0xca1100b6
      0x00000000e9b019e8: 0x7c05b68b 0x00850613 0x7c07358b 0x006f853e
      0x00000000e9b019f8: 0x45010080 0x16ed8082 0xe42e1101 0x8732e036
      0x00000000e9b01a08: 0x002c868a 0x06154795 0x00efec06 0x353301e0
      0x00000000e9b01a18: 0x60e200a0 0x40a00533 0x80826105 0xf06f852e
      0x00000000e9b01a28: 0x852ef05f 0xef5ff06f 0x00002817 0xd8080813
      0x00000000e9b01a38: 0xe0427179 0x01f10893 0x27814801 0x10eff406
      0x00000000e9b01a48: 0x70a25640 0x80826145 0x07934d78 0x069b1100
      0x00000000e9b01a58: 0xed63fff7 0x468b04d7 0x380bffd5 0x38837c07
      0x00000000e9b01a68: 0x83330185 0x457040d5 0x746387ba 0x87bb0103
      0x00000000e9b01a78: 0x280340d5 0x412c0445 0x00081a63 0x00c52803
      0x00000000e9b01a88: 0x40b8033b 0x0067e463 0x05052223 0x9f1d9dbd
      0x00000000e9b01a98: 0xcd78c12c 0x873685be 0x360b5e7d 0x35fd7c06
      0x00000000e9b01aa8: 0x01c59763 0x7c07b78b 0xf91c97b6 0x08338082
      0x00000000e9b01ab8: 0x837640c7 0x00c76363 0x98464301 0x8068480b
      0x00000000e9b01ac8: 0x00e8d80b 0xbfe10705 0xe5a67115 0xe9a26485
      0x00000000e9b01ad8: 0xe1caed86 0xf952fd4e 0xf15af556 0xe962ed5e
      0x00000000e9b01ae8: 0xe16ae566 0x842afcee 0xf432e42e 0x8004849b
      0x00000000e9b01af8: 0x04442a83 0x04042e03 0x6b227810 0x000a9d63
      0x00000000e9b01b08: 0x0733445c 0x87bb40cb 0xb78b41c7 0xf4637c07
      0x00000000e9b01b18: 0x8b3300e7 0x288300c7 0x587d0084 0x18bb680c
      0x00000000e9b01b28: 0xc8930118 0x2881fff8 0x2883fc46 0x401c0044
      0x00000000e9b01b38: 0x03843a03 0x0118183b 0x88936885 0x98aea688
                                               EXC_LOAD_PAGE_FAULT
      gprs:
       x0:0x0000000000000000   ra:0x0000000040095800   sp:0x0000000040237d90   gp:0x0000000040118dc0
       tp:0x0000000040214080   t0:0x0000000040013388   t1:0x000000000000000f   t2:0x000000000000000a
       s0:0x0000000040fd6278   s1:0x0000000040fd6460   a0:0x0000000040fd6460   a1:0x0000000000000000
       a2:0x0000000000000000   a3:0x0000000040fd64b0   a4:0x0000000040fd64b0   a5:0x0000000000000000
       a6:0x0000000002500000   a7:0x00000000400dd8b0   s2:0x00000000400d4a38   s3:0x000000004002eb54
       t3:0x0000000000000000   t4:0x0000000000000008   t5:0x0000000000000039   t6:0x0000000000000030
      other:
      sepc    :0x00000000400956d2
      sstatus :0x0000000000004100
      stval   :0x0000000000000052
      backtrace : 0X400956D2
      backtrace : 0X400957FC
      backtrace : 0X4002903A
      backtrace : 0X400290DA
      backtrace : 0X4002A008
          memory info:
      	Total  0x1feb4000
      	Used   0x00af7a80
      	Max    0x00afdb90
      dump stack memory:
      0x0000000040237d90: 0x400d4960 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237da0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237db0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237dc0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237dd0: 0x40214038 0x00000000 0x4002eb54 0x00000000
      0x0000000040237de0: 0x400d4a38 0x00000000 0xe87000a8 0x00000000
      0x0000000040237df0: 0x40237e50 0x00000000 0x4002903e 0x00000000
      0x0000000040237e00: 0xe9b037c8 0x00000000 0x40234000 0x00000000
      0x0000000040237e10: 0x40029d24 0x00000000 0x40214038 0x00000000
      0x0000000040237e20: 0x40237e50 0x00000000 0x00004120 0x00000002
      0x0000000040237e30: 0xe9b037c8 0x00000000 0x400290de 0x00000000
      0x0000000040237e40: 0x40237e50 0x00000000 0x4002a00c 0x00000000
      0x0000000040237e50: 0xe9b01948 0x00000000 0xe9b00e88 0x00000000
      0x0000000040237e60: 0x40237f60 0x00000000 0x40118dc0 0x00000000
      0x0000000040237e70: 0x40214080 0x00000000 0x00000048 0x00000000
      0x0000000040237e80: 0xe9b00e00 0x00000000 0x4124e644 0x00000000
      0x0000000040237e90: 0x000001f4 0x00000000 0xe9b037c0 0x00000000
      0x0000000040237ea0: 0x402f8448 0x00000000 0x00000000 0x00000000
      0x0000000040237eb0: 0x000000c8 0x00000000 0x00afdb90 0x00000000
      0x0000000040237ec0: 0x4012cbe0 0x00000000 0xe8700000 0x00000000
      0x0000000040237ed0: 0x00000007 0x00000000 0x10000207 0x00000000
      0x0000000040237ee0: 0xe9b037c8 0x00000000 0x4002eb54 0x00000000
      0x0000000040237ef0: 0x40214038 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237f00: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237f10: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237f20: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x0000000040237f30: 0x0000075c 0x00000000 0x000000c6 0x00000000
      0x0000000040237f40: 0x00000121 0x00000000 0x000000d5 0x00000000
      0x0000000040237f50: 0x00004120 0x00000002 0x00000000 0x00000000
      dump sepc memory:
      0x00000000400956d2: 0x0527c783 0x0797eb91 0x8c23000a 0x0517d207
      0x00000000400956e2: 0x0513000a 0x8082d305 0x07971101 0x8793000a
      0x00000000400956f2: 0xec0612c7 0xe826e422 0xc195638c 0x40000613
      0x0000000040095702: 0x000a0517 0xd0e50513 0xc067f0ef 0x642260e2
      0x0000000040095712: 0x051764c2 0x0513000a 0x6105cfc5 0xf0ef8082
      0x0000000040095722: 0x5597d4af 0x85930006 0xe509c6c5 0x00065597
      0x0000000040095732: 0xc6a58593 0x000a0517 0xcda50513 0xd137e0ef
      0x0000000040095742: 0x000a0417 0xcce40413 0x80ef8522 0x84aaeee9
      0x0000000040095752: 0x80ef8522 0x0593ee69 0x8d894000 0x00940533
      0x0000000040095762: 0x2a2060ef 0x00065597 0xc3a58593 0xe0ef8522
      0x0000000040095772: 0xbf69ae17 0xe0221141 0x5517842a 0x05130006
      0x0000000040095782: 0xe406cc45 0x88e960ef 0xf3fff0ef 0x061385aa
      0x0000000040095792: 0x55171e84 0x05130006 0x60efcb45 0x64028789
      0x00000000400957a2: 0x450160a2 0x80820141 0xeca67159 0x051384aa
      0x00000000400957b2: 0xf4862400 0xe8caf0a2 0xe0d2e4ce 0xf85afc56
      0x00000000400957c2: 0xf062f45e 0xe86aec66 0xd0efe46e 0x842a74f0
      0x00000000400957d2: 0x24000613 0xd0ef4581 0x90efb857 0x85a6d1e9
      0x00000000400957e2: 0x78d030ef 0x1e840493 0x05000613 0x85264581
      0x00000000400957f2: 0xb6b7d0ef 0x08a34785 0xf0ef04f4 0x60efecdf
      0x0000000040095802: 0x17978149 0x87930009 0x439c81c7 0x45b5e78d
      0x0000000040095812: 0x00065517 0xbd650513 0xd25ff0ef 0x1c6357fd
      0x0000000040095822: 0x559700f5 0x85930006 0x5517bc45 0x05130006
      0x0000000040095832: 0x50efbcc5 0x4c6dfe19 0x59174a05 0x09130006
      0x0000000040095842: 0x0993be49 0x0a931984 0x0c930a84 0x0b130584
      0x0000000040095852: 0x0b930f84 0x40ef1484 0x8d2a3300 0x3e051163
      0x0000000040095862: 0x95f7c0ef 0xfe0549e3 0x0b634785 0x47830185
      0x0000000040095872: 0x99630504 0x07930747 0x166305b0 0x478900f5
      0x0000000040095882: 0x04f40823 0x0823bfc9 0xd5710404 0x0ff00793
      0x0000000040095892: 0xfcf503e3 0x156347a5 0x578312f5 0x4c6323a4
      0x00000000400958a2: 0x251710fd 0x05130006 0x50efa6c5 0xf0eff699
      0x00000000400958b2: 0x1563bbaf 0x85260145 0xf9aff0ef 0xe0bff0ef
      0x00000000400958c2: 0x862685aa 0x00065517 0xb8250513 0xf47950ef
      panic_goto_cli can not be reentrant!
      Z 1 条回复 最后回复 回复 引用 分享 0
        ZZJ123 LV 3 @geniusgogo 最后由 编辑
        @geniusgogo 另外一个帖子有回复处理方法。
