    T113-i longan系统 LCD MIPI驱动开发时显示FB地址分配出错
    • V
      vc LV 4 最后由 编辑
      查看显示模块状态时,发现BUF的addr全为0,想了解一下出现这种状况一般是设备树配置问题?还是lcd驱动问题导致的?
      root@myd-yt113-i:~# cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:60
      mgr0: 800x800 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[0] force_sync[0] unblank direct_show[false] iommu[1]
              lcd output      backlight(100)  fps:60.6         800x 800
              err:1   skip:1118       irq:14376       vsync:0 vsync_skip:0
         BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 800, 800; 800, 800; 800, 800] crop[   0,   0, 800, 800] frame[   0,   0, 800, 800] addr[       0,       0,       0] flags[0x       0] trd[0,0]
      下面是disp部分的log信息,没有看出问题
      [    0.665450] atomic64_test: passed
      [    0.671434] [DISP]disp_module_init
      [    0.675645] disp 5000000.disp: Adding to iommu group 0
      [    0.698643] [DISP] disp_init_hdmi,line:1047:
      [    0.698647] dont support hdmi
      [    0.706567] display_fb_request,fb_id:0
      [    0.712730] [DISP] Fb_copy_boot_fb,line:1453:
      [    0.712735] no boot_fb0
      [    0.720403] disp_al_manager_apply ouput_type:0
      [    0.725442] [DISP] lcd_clk_config,line:741:
      [    0.725454] disp 0, clk: pll(360000000),clk(360000000),dclk(60000000) dsi_rate(60000000)
      [    0.725454]      clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000)
      [    0.726093] [DISP]disp_module_init finish
      [    0.752690] sunxi_sid_init()563 - insmod ok
      [    0.757389] of_pwm_get(): can't parse "pwms" property
      • V
        vc LV 4 最后由 编辑
        [123]HELLO! BOOT0 is starting!
        [126]BOOT0 commit : 09b36272
        [129]set pll start
        [131]fix vccio detect value:0xc0
        [138]periph0 has been enabled
        [141]set pll end
        [143][pmu]: bus read error
        [145]board init ok
        [147]enable_jtag
        [149]DRAM only have internal ZQ!!
        [152]get_pmu_exist() = -1
        [155]ddr_efuse_type: 0x0
        [157]mark_id: 0x34
        [159]trefi:7.8ms
        [161][AUTO DEBUG] single rank and full DQ!
        [165]ddr_efuse_type: 0x0
        [168]mark_id: 0x34
        [170]trefi:7.8ms
        [172][AUTO DEBUG] rank 0 row = 15
        [175][AUTO DEBUG] rank 0 bank = 8
        [179][AUTO DEBUG] rank 0 page size = 2 KB
        [183]DRAM BOOT DRIVE INFO: V0.32
        [186]DRAM CLK = 792 MHz
        [188]DRAM Type = 3 (2:DDR2,3:DDR3)
        [191]DRAMC ZQ value: 0x7b7bfb
        [194]DRAM ODT value: 0x42.
        [197]ddr_efuse_type: 0x0
        [199]mark_id: 0x34
        [202]DRAM SIZE =512 M
        [204]PLL_DDR_CTRL_REG:0xf8004100
        [207]DRAM_CLK_REG:0xc0000000
        [210][TIMING DEBUG] MR2= 0x18
        [218]DRAM simple test OK.
        [220]rtc standby flag is 0x0, super standby flag is 0x0
        [225]dram size =512
        [228]card no is 0
        [230]sdcard 0 line count 4
        [232][mmc]: mmc driver ver 2021-05-21 14:47
        [242][mmc]: Wrong media type 0x0
        [245][mmc]: ***Try SD card 0***
        [274][mmc]: HSSDR52/SDR25 4 bit
        [277][mmc]: 50000000 Hz
        [279][mmc]: 3781 MB
        [281][mmc]: ***SD/MMC 0 init OK!!!***
        [378]Loading boot-pkg Succeed(index=0).
        [381]Entry_name        = u-boot
        [389]Entry_name        = optee
        [393]Entry_name        = dtb
        [396]mmc not para
        [397]Jump to second Boot.
        M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
        U-Boot 2018.05-g512bff9-dirty (Jul 13 2023 - 07:52:56 +0000) Allwinner Technology
        [00.449]CPU:   Allwinner Family
        [00.452]Model: sun8iw20
        [00.454]DRAM:  512 MiB
        [00.458]Relocation Offset is: 1cebf000
        [00.495]secure enable bit: 0
        [00.509]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [00.515]gic: sec monitor mode
        [00.518]flash init start
        [00.520]workmode = 0,storage type = 1
        [00.523][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
        [00.529][mmc]: get sdc_type fail and use default host:tm1.
        [00.535][mmc]: can't find node "mmc0",will add new node
        [00.540][mmc]: fdt err returned <no error>
        [00.544][mmc]: Using default timing para
        [00.547][mmc]: SUNXI SDMMC Controller Version:0x50310
        [00.583][mmc]: card_caps:0x3000000a
        [00.586][mmc]: host_caps:0x3000003f
        [00.593]sunxi flash init ok
        [00.595]line:717 init_clocks
        [00.598]drv_disp_init
        request pwm success, pwm2:pwm2:0x2000c00.
        [00.615]drv_disp_init finish
        [04.631]env/env.c:env_load:232:Waiting for display 1 timeout
        [04.636]Loading Environment from SUNXI_FLASH... OK
        [04.667]Item0 (Map) magic is bad
        [04.669]the secure storage item0 copy0 magic is bad
        [04.675]Item0 (Map) magic is bad
        [04.678]the secure storage item0 copy1 magic is bad
        [04.682]Item0 (Map) magic is bad
        [04.688]secure storage read widevine fail with:-1
        [04.695]secure storage read ec_key fail with:-1
        [04.703]secure storage read ec_cert1 fail with:-1
        [04.710]secure storage read ec_cert2 fail with:-1
        [04.718]secure storage read ec_cert3 fail with:-1
        [04.725]secure storage read rsa_key fail with:-1
        [04.732]secure storage read rsa_cert1 fail with:-1
        [04.740]secure storage read rsa_cert2 fail with:-1
        [04.748]secure storage read rsa_cert3 fail with:-1
        [04.752]usb burn from boot
        delay time 0
        weak:otg_phy_config
        [04.763]usb prepare ok
        [05.566]overtime
        [05.569]do_burn_from_boot usb : no usb exist
        List file under ULI/factory
        [05.586]update part info
        [05.589]update bootcmd
        [05.597]change working_fdt 0x5c87ee70 to 0x5c85ee70
        [05.617]update dts
        [05.619]No ethernet found.
        [09.485]no vendor_boot partition is found
        [09.508]Starting kernel ...
        [09.510][mmc]: MMC Device 2 not found
        [09.514][mmc]: mmc 2 not find, so not exit
        [    0.000000] Linux version 5.4.61+ (damon@t113-VirtualBox) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #28 SMP PREEMPT Tue May 7 09:15:57 CST 2024
        [    0.000000] earlycon: uart8250 at MMIO32 0x02501400 (options '')
        [    0.000000] printk: bootconsole [uart8250] enabled
        [    0.000000] cma: Reserved 16 MiB at 0x5f000000
        [    0.000000] percpu: Embedded 15 pages/cpu s31744 r8192 d21504 u61440
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129792
        [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02501400 clk_ignore_unused initcall_debug=0 console=ttyAS5,115200 loglevel=7 root=/dev/mmcblk0p5 rootdelay=5 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-g512bff9-dirty(07/13/2023-07:52:56) androidboot.dramsize=512
        [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
        [    0.000000] Memory: 479548K/523264K available (9216K kernel code, 629K rwdata, 3192K rodata, 1024K init, 235K bss, 27332K reserved, 16384K cma-reserved, 0K highmem)
        [    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
        [    0.008372] Switching to timer-based delay loop, resolution 41ns
        [    0.014830] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [    0.025038] Console: colour dummy device 80x30
        [    0.029724] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.040589] pid_max: default: 32768 minimum: 301
        [    0.045574] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.053250] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.061985] CPU: Testing write buffer coherency: ok
        [    0.067458] /cpus/cpu@0 missing clock-frequency property
        [    0.073045] /cpus/cpu@1 missing clock-frequency property
        [    0.078625] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.085123] Setting up static identity map for 0x40100000 - 0x40100060
        [    0.092099] rcu: Hierarchical SRCU implementation.
        [    0.097430] BOOTEVENT:        97.421040: ON
        [    0.102023] smp: Bringing up secondary CPUs ...
        [    0.107969] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.108123] smp: Brought up 1 node, 2 CPUs
        [    0.118367] SMP: Total of 2 processors activated (96.00 BogoMIPS).
        [    0.124850] CPU: All CPU(s) started in SVC mode.
        [    0.130152] devtmpfs: initialized
        [    0.145956] random: get_random_u32 called from bucket_table_alloc+0xf8/0x124 with crng_init=0
        [    0.146751] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.164239] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.174590] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
        [    0.182466] pinctrl core: initialized pinctrl subsystem
        [    0.189396] NET: Registered protocol family 16
        [    0.196321] DMA: preallocated 256 KiB pool for atomic coherent allocations
        [    0.204877] cpuidle: using governor menu
        [    0.244572] rtc_ccu: sunxi ccu init OK
        [    0.250952] ccu: sunxi ccu init OK
        [    0.255048] r_ccu: sunxi ccu init OK
        [    0.353160] Deinterlace Module initialized.
        [    0.357822] iommu: Default domain type: Translated
        [    0.363338] sunxi iommu: irq = 24
        [    0.367879] SCSI subsystem initialized
        [    0.372245] usbcore: registered new interface driver usbfs
        [    0.378300] usbcore: registered new interface driver hub
        [    0.383986] usbcore: registered new device driver usb
        [    0.389561] mc: Linux media interface: v0.10
        [    0.394103] videodev: Linux video capture interface: v2.00
        [    0.401109] Advanced Linux Sound Architecture Driver Initialized.
        [    0.408176] Bluetooth: Core ver 2.22
        [    0.412031] NET: Registered protocol family 31
        [    0.416696] Bluetooth: HCI device and connection manager initialized
        [    0.423391] Bluetooth: HCI socket layer initialized
        [    0.428484] Bluetooth: L2CAP socket layer initialized
        [    0.433802] Bluetooth: SCO socket layer initialized
        [    0.439219] pwm module init!
        [    0.443714] g2d 5410000.g2d: Adding to iommu group 0
        [    0.449391] G2D: rcq version initialized.major:250
        [    0.455132] input: sunxi-keyboard as /devices/virtual/input/input0
        [    0.463668] clocksource: Switched to clocksource arch_sys_counter
        [    0.480120] sun8iw20-pinctrl pio: initialized sunXi PIO driver
        [    0.500727] thermal_sys: Registered thermal governor 'step_wise'
        [    0.500735] thermal_sys: Registered thermal governor 'user_space'
        [    0.507647] NET: Registered protocol family 2
        [    0.519316] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    0.528140] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
        [    0.536346] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
        [    0.543718] TCP: Hash tables configured (established 4096 bind 4096)
        [    0.550291] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.557208] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.564762] NET: Registered protocol family 1
        [    0.572123] Initialise system trusted keyrings
        [    0.577001] workingset: timestamp_bits=30 max_order=17 bucket_order=0
        [    0.598844] fuse: init (API version 7.31)
        [    0.632799] NET: Registered protocol family 38
        [    0.637539] Key type asymmetric registered
        [    0.641848] Asymmetric key parser 'x509' registered
        [    0.647074] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
        [    0.654859] io scheduler mq-deadline registered
        [    0.659610] io scheduler kyber registered
        [    0.663926] atomic64_test: passed
        [    0.669982] [DISP]disp_module_init
        [    0.674138] disp 5000000.disp: Adding to iommu group 0
        [    0.680177] [DISP] disp_init_lcd,line:3094:
        [    0.680182] [damon_lcd] disp_init_lcd
        [    0.688432] [DISP] disp_lcd_init,line:2843:
        [    0.688436] [damon_lcd] disp_lcd_init
        [    0.713303] [DISP] disp_init_hdmi,line:1047:
        [    0.713307] dont support hdmi
        [    0.721203] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.721208] [damon_lcd] disp_lcd_set_panel_funs
        [    0.731298] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.731304] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name default_lcd
        [    0.744018] [DISP] lcd_set_panel_funs,line:146:
        [    0.744022] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.754143] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.754145] [damon_lcd] disp_lcd_set_panel_funs
        [    0.764178] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.764183] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name jd9365da
        [    0.776556] [DISP] disp_lcd_set_panel_funs,line:2455:
        [    0.776559] [damon_lcd] strcmp(lcdp->panel_info.lcd_driver_name, name)
        [    0.788674] [DISP] lcd_set_panel_funs,line:146:
        [    0.788677] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.798788] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.798790] [damon_lcd] disp_lcd_set_panel_funs
        [    0.808814] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.808819] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name he0801a068
        [    0.821391] [DISP] lcd_set_panel_funs,line:146:
        [    0.821394] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.831522] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.831524] [damon_lcd] disp_lcd_set_panel_funs
        [    0.841549] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.841553] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name inet_dsi_panel
        [    0.854511] [DISP] lcd_set_panel_funs,line:146:
        [    0.854515] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.864647] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.864650] [damon_lcd] disp_lcd_set_panel_funs
        [    0.874686] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.874691] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name lq101r1sx03
        [    0.887350] [DISP] lcd_set_panel_funs,line:146:
        [    0.887353] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.897464] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.897466] [damon_lcd] disp_lcd_set_panel_funs
        [    0.907507] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.907512] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name WilliamLcd
        [    0.920084] [DISP] lcd_set_panel_funs,line:146:
        [    0.920087] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.930233] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.930236] [damon_lcd] disp_lcd_set_panel_funs
        [    0.940260] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.940265] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name CC08021801_310_800X1280
        [    0.954025] [DISP] lcd_set_panel_funs,line:146:
        [    0.954028] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.964147] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.964150] [damon_lcd] disp_lcd_set_panel_funs
        [    0.974199] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    0.974204] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name bp101wx1
        [    0.986628] [DISP] lcd_set_panel_funs,line:146:
        [    0.986632] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    0.996762] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    0.996766] [damon_lcd] disp_lcd_set_panel_funs
        [    1.006806] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.006810] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name k101im2qa04
        [    1.019489] [DISP] lcd_set_panel_funs,line:146:
        [    1.019493] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.029621] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    1.029624] [damon_lcd] disp_lcd_set_panel_funs
        [    1.039640] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.039644] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name fx070
        [    1.051747] [DISP] lcd_set_panel_funs,line:146:
        [    1.051750] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.061852] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    1.061855] [damon_lcd] disp_lcd_set_panel_funs
        [    1.071888] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.071893] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name K080_IM2HYL802R_800X1280
        [    1.085751] [DISP] lcd_set_panel_funs,line:146:
        [    1.085755] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.095865] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    1.095868] [damon_lcd] disp_lcd_set_panel_funs
        [    1.105917] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.105922] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name K101_IM2BYL02_L_800X1280
        [    1.119785] [DISP] lcd_set_panel_funs,line:146:
        [    1.119789] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.129917] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    1.129920] [damon_lcd] disp_lcd_set_panel_funs
        [    1.139956] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.139960] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name kd080d24
        [    1.152355] [DISP] lcd_set_panel_funs,line:146:
        [    1.152358] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.162492] [DISP] disp_lcd_set_panel_funs,line:2441:
        [    1.162494] [damon_lcd] disp_lcd_set_panel_funs
        [    1.172575] [DISP] disp_lcd_set_panel_funs,line:2453:
        [    1.172580] [damon_lcd] lcd 0, driver_name jd9365da,  panel_name super_lcd_driver
        [    1.185709] [DISP] lcd_set_panel_funs,line:146:
        [    1.185712] [damon_lcd] sunxi_lcd_set_panel_funs ret 0
        [    1.195822] [DISP] disp_init,line:2436:
        [    1.195825] [damon_lcd] lcd_init
        [    1.203184] [DISP] fb_init,line:2321:
        [    1.203186] [damon] fb_init
        [    1.209961] [DISP] display_fb_request,line:1991:
        [    1.209964] [damon] display_fb_request
        [    1.218717] display_fb_request,fb_id:0
        [    1.222642] [DISP] fb_map_video_memory,line:104:
        [    1.222645] [damon_lcd] is CONFIG_ION
        [    1.231317] [DISP] disp_ion_malloc,line:1594:
        [    1.231320] [damon_alloc] disp_ion_malloc
        [    1.241235] [DISP] disp_dma_map,line:202:
        [    1.241239] [damon_alloc] disp_dma_map
        [    1.249403] [DISP] disp_dma_map,line:210:
        [    1.249408] [damon_alloc] __LINUX_PLAT__ item ddc4dc40
        [    1.259010] [DISP] dma_buf_map_attachment,line:751:
        [    1.259013] [damon_alloc] dma_buf_map_attachment
        [    1.269133] [DISP] dma_buf_map_attachment,line:782:
        [    1.269141] [damon_alloc] ok: sgt 0xddc4dd40, direction 0x00000002, ((sg_table->sgl)->dma_address) 0x00000000, attach->dmabuf->ops->cache_sgt_mapping 0
        [    1.288483] [DISP] disp_dma_map_core,line:174:
        [    1.288490] [damon_alloc] item->dmabuf 0xddd04600, item->sgt 0xddc4dd40, item->attachment 0xddc4dcc0, item->dma_addr 0x00000000
        [    1.305172] [DISP] disp_dma_map,line:226:
        [    1.305177] [damon_alloc] disp_dma_map_end item ddc4dc40, item->dma_addr 00000000
        [    1.317212] [DISP] __disp_ion_alloc_coherent,line:1560:
        [    1.317216] [damon_alloc] mem->p_item ddc4dc40, mem->p_item->dma_addr 00000000
        [    1.330258] [DISP] disp_ion_malloc,line:1626:
        [    1.330263] [damon_alloc] disp_ion_malloc ok! mem 0xddc4db48, num_bytes 2560000, paddr 0x00000000
        [    1.344138] [DISP] fb_map_video_memory,line:115:
        [    1.344142] [damon] fb_map_video_memory addr 0x00000000
        [    1.354444] [DISP] fb_map_video_memory,line:121:
        [    1.354450] fb_map_video_memory(reserve),va=0xe0d01000, pa=0x00000000 size:0x271000
        [    1.368200] [DISP] Fb_map_kernel_logo,line:1806:
        [    1.368203] [damon] Fb_map_kernel_logo
        [    1.376962] [DISP] Fb_copy_boot_fb,line:1354:
        [    1.376965] [damon] Fb_copy_boot_fb
        [    1.385201] [DISP] Fb_copy_boot_fb,line:1462:
        [    1.385203] no boot_fb0
        [    1.392286] [DISP] var_to_disp_fb,line:416:
        [    1.392289] [damon] var_to_disp_fb
        [    1.400225] [DISP] display_fb_request,line:2133:
        [    1.400229] [damon] config.info.fb.addr[0] = 0x00000000
        [    1.410997] [DISP] start_work,line:1812:
        [    1.411004] [damon_lcd]sel=0, output_type=1, lcd_reg=1,hdmi_reg=0
        [    1.414308] [DISP]disp_module_init finish
        [    1.415153] [DISP] disp_lcd_enable,line:2051:
        [    1.415156] [damon_lcd] disp_lcd_enable
        [    1.423045] sunxi_sid_init()563 - insmod ok
        [    1.425971] disp_al_manager_apply ouput_type:0
        [    1.430632] of_pwm_get(): can't parse "pwms" property
        [    1.434833] [DISP] lcd_clk_config,line:741:
        [    1.434845] disp 0, clk: pll(360000000),clk(360000000),dclk(60000000) dsi_rate(60000000)
        [    1.434845]      clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000)
        [    1.438835] pwm-regulator vdd-cpu: Failed to get PWM: -2
        [    1.475840] pwm-regulator: probe of vdd-cpu failed with error -2
        [    1.482987] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
        [    1.491485] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
        [    1.500372] uart uart4: get regulator failed
        [    1.504937] uart uart4: uart4 supply uart not found, using dummy regulator
        [    1.512398] sw_uart_probe()2167 - error to get uart4_rs485
        [    1.518236] uart4: ttyAS4 at MMIO 0x2501000 (irq = 33, base_baud = 1500000) is a SUNXI
        [    1.527323] uart uart5: get regulator failed
        [    1.531816] uart uart5: uart5 supply uart not found, using dummy regulator
        [    1.539341] sw_uart_probe()2167 - error to get uart5_rs485
        [    1.545164] uart5: ttyAS5 at MMIO 0x2501400 (irq = 34, base_baud = 1500000) is a SUNXI
        [    1.553467] sw_console_setup()1887 - console setup baud 115200 parity n bits 8, flow n
        [    1.561825] printk: console [ttyAS5] enabled
        [    1.571104] printk: bootconsole [uart8250] disabled
        [    1.582842] misc dump reg init
        [    1.589165] libphy: Fixed MDIO Bus: probed
        [    1.594165] CAN device driver interface
        [    1.599344] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
        [    1.608679] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
        [    1.614015] sunxi gmac driver's version: 1.0.0
        [    1.622343] sunxi gmac driver's version: 1.0.0
        [    1.627629] gmac-power0: NULL
        [    1.630958] gmac-power1: NULL
        [    1.634301] gmac-power2: NULL
        [    1.638902] Failed to alloc md5
        [    1.642438] eth0: Use random mac address
        [    1.647236] PPP generic driver version 2.4.2
        [    1.652314] PPP BSD Compression module registered
        [    1.657813] PPP Deflate Compression module registered
        [    1.663491] PPP MPPE Compression module registered
        [    1.668886] NET: Registered protocol family 24
        [    1.674032] usbcore: registered new interface driver catc
        [    1.680151] usbcore: registered new interface driver kaweth
        [    1.686435] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
        [    1.694812] usbcore: registered new interface driver pegasus
        [    1.701162] hso: /home/damon/t113/auto-t113x-linux/kernel/linux-5.4/drivers/net/usb/hso.c: Option Wireless
        [    1.712102] usbcore: registered new interface driver hso
        [    1.718171] usbcore: registered new interface driver asix
        [    1.724310] usbcore: registered new interface driver ax88179_178a
        [    1.731215] usbcore: registered new interface driver cdc_ether
        [    1.737844] usbcore: registered new interface driver cdc_eem
        [    1.744274] usbcore: registered new interface driver dm9601
        [    1.750579] usbcore: registered new interface driver net1080
        [    1.757005] usbcore: registered new interface driver cdc_subset
        [    1.763742] usbcore: registered new interface driver zaurus
        [    1.770060] usbcore: registered new interface driver cdc_phonet
        [    1.776976] usbcore: registered new interface driver sierra_net
        [    1.783751] usbcore: registered new interface driver cdc_ncm
        [    1.790162] usbcore: registered new interface driver huawei_cdc_ncm
        [    1.797288] usbcore: registered new interface driver qmi_wwan
        [    1.803828] usbcore: registered new interface driver qmi_wwan_q
        [    1.810530] usbcore: registered new interface driver cdc_mbim
        [    1.816999] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [    1.824335] sunxi-ehci: EHCI SUNXI driver
        [    1.829326] get ehci0-controller wakeup-source is fail.
        [    1.835337] sunxi ehci0-controller don't init wakeup source
        [    1.841593] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0fc6580, 0x:e0833000, irq_no:39
        [    1.853608] [sunxi-ehci0]: Not init ehci0
        [    1.858440] get ehci1-controller wakeup-source is fail.
        [    1.864434] sunxi ehci1-controller don't init wakeup source
        [    1.870688] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0fc6aa0, 0x:e0837000, irq_no:3b
        [    1.882957] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
        [    1.895312] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
        [    1.902569] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
        [    1.912611] sunxi-ehci 4200000.ehci1-controller: irq 59, io mem 0x04200000
        [    1.923758] [DISP] lcd_panel_init,line:333:
        [    1.923762] [damon_lcd] lcd_panel_init
        [    1.943691] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
        [    1.951515] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
        [    1.960680] hub 1-0:1.0: USB hub found
        [    1.964974] hub 1-0:1.0: 1 port detected
        [    1.970160] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [    1.977148] sunxi-ohci: OHCI SUNXI driver
        [    1.982127] get ohci0-controller wakeup-source is fail.
        [    1.988141] sunxi ohci0-controller don't init wakeup source
        [    1.994413] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0fc6810
        [    2.003871] [DISP] disp_device_attached_and_enable,line:235:
        [    2.003877] attached ok, mgr0<-->dev0
        [    2.004087] [sunxi-ohci0]: Not init ohci0
        [    2.010427] [DISP] disp_device_attached_and_enable,line:248:
        [    2.010436] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
        [    2.014865] get ohci1-controller wakeup-source is fail.
        [    2.019300] [DISP] start_work,line:1812:
        [    2.019305] [damon_lcd]sel=1, output_type=4, lcd_reg=0,hdmi_reg=0
        [    2.025521] sunxi ohci1-controller don't init wakeup source
        [    2.058143] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0fc6d30
        [    2.068091] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
        [    2.080601] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
        [    2.087901] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
        [    2.097837] sunxi-ohci 4200400.ohci1-controller: irq 60, io mem 0x04200400
        [    2.178669] hub 2-0:1.0: USB hub found
        [    2.182925] hub 2-0:1.0: 1 port detected
        [    2.189031] usbcore: registered new interface driver cdc_wdm
        [    2.195712] usbcore: registered new interface driver uas
        [    2.201791] usbcore: registered new interface driver usb-storage
        [    2.208632] usbcore: registered new interface driver ums-alauda
        [    2.215358] usbcore: registered new interface driver ums-cypress
        [    2.222153] usbcore: registered new interface driver ums-datafab
        [    2.228975] usbcore: registered new interface driver ums_eneub6250
        [    2.235988] usbcore: registered new interface driver ums-freecom
        [    2.242803] usbcore: registered new interface driver ums-isd200
        [    2.249533] usbcore: registered new interface driver ums-jumpshot
        [    2.256447] usbcore: registered new interface driver ums-karma
        [    2.263055] usbcore: registered new interface driver ums-onetouch
        [    2.270129] usbcore: registered new interface driver ums-realtek
        [    2.276979] usbcore: registered new interface driver ums-sddr09
        [    2.283716] usbcore: registered new interface driver ums-sddr55
        [    2.290420] usbcore: registered new interface driver ums-usbat
        [    2.297313] usbcore: registered new interface driver ipw
        [    2.303319] usbserial: USB Serial support registered for IPWireless converter
        [    2.311442] usbcore: registered new interface driver option
        [    2.317766] usbserial: USB Serial support registered for GSM modem (1-port)
        [    2.325781] usbcore: registered new interface driver qcserial
        [    2.332273] usbserial: USB Serial support registered for Qualcomm USB modem
        [    2.340130] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
        [    2.343929] usbcore: registered new interface driver usb_serial_simple
        [    2.355222] usbserial: USB Serial support registered for carelink
        [    2.362177] usbserial: USB Serial support registered for zio
        [    2.368674] usbserial: USB Serial support registered for funsoft
        [    2.375499] usbserial: USB Serial support registered for flashloader
        [    2.382667] usbserial: USB Serial support registered for google
        [    2.389373] usbserial: USB Serial support registered for libtransistor
        [    2.396777] usbserial: USB Serial support registered for vivopay
        [    2.403562] usbserial: USB Serial support registered for moto_modem
        [    2.410673] usbserial: USB Serial support registered for motorola_tetra
        [    2.418164] usbserial: USB Serial support registered for novatel_gps
        [    2.425368] usbserial: USB Serial support registered for hp4x
        [    2.431851] usbserial: USB Serial support registered for suunto
        [    2.438553] usbserial: USB Serial support registered for siemens_mpi
        [    2.446668] tp_key_probe: start
        [    2.450321] key adc value:210 key code:115
        [    2.454961] key adc value:410 key code:114
        [    2.459578] key adc value:590 key code:119
        [    2.464191] key adc value:750 key code:373
        [    2.468801] channel_tpadc val : 49
        [    2.555142] hub 1-1:1.0: USB hub found
        [    2.559539] hub 1-1:1.0: 4 ports detected
        [    2.983693] usb 1-1.4: new high-speed USB device number 3 using sunxi-ehci
        [    2.983901] input: sunxi-tpadc as /devices/virtual/input/input1
        [    2.999275] sunxi_gpadc_init,2137, success
        [    3.004220] sunxi_gpadc_setup: get channel scan data failed
        [    3.010818] input: sunxi-gpadc0 as /devices/virtual/input/input2
        [    3.018737] i2c /dev entries driver
        [    3.022894] IR NEC protocol handler initialized
        [    3.028089] IR RC5(x/sz) protocol handler initialized
        [    3.034234] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
        [    3.043262] sunxi_ir_startup: get ir protocol failed
        [    3.043281] (NULL device *): deviceless supply  not found, using dummy regulator
        [    3.057317] Registered IR keymap rc_map_sunxi
        [    3.062412] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
        [    3.071148] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
        [    3.083346] usbcore: registered new interface driver uvcvideo
        [    3.089846] USB Video Class driver (1.1.1)
        [    3.094542] gspca_main: v2.14.0 registered
        [    3.099143] sunxi cedar version 1.1
        [    3.103308] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
        [    3.109939] VE: cedar-ve the get irq is 41
        [    3.109939]
        [    3.116452] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
        [    3.116452]
        [    3.127093] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
        [    3.136490] Bluetooth: HCI UART driver ver 2.3
        [    3.141545] Bluetooth: HCI UART protocol H4 registered
        [    3.149241] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
        [    3.158225] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
        [    3.168275] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
        [    3.174761] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
        [    3.181115] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
        [    3.187604] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
        [    3.194079] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
        [    3.200641] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
        [    3.207234] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
        [    3.213820] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
        [    3.220409] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
        [    3.230051] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.253840] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.278189] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
        [    3.285403] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.294968] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
        [    3.300549] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.307042] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
        [    3.319914] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.324718] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
        [    3.342672] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
        [    3.342707] random: fast init done
        [    3.349132] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
        [    3.359377] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
        [    3.365940] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
        [    3.372483] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
        [    3.376873] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.379039] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
        [    3.390774] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.409282] sunxi-mmc 4020000.sdmmc: Got CD GPIO
        [    3.411857] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.426580] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.437769] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
        [    3.454473] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.457928] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.478777] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [    3.488581] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [    3.490354] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
        [    3.498373] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [    3.504451] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.514211] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [    3.537006] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
        [    3.537047] usbcore: registered new interface driver usbhid
        [    3.552616] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [    3.554934] usbhid: USB HID core driver
        [    3.554984] RTW: module init start
        [    3.566673] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [    3.570513] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.574601] mmc0: new HS200 MMC card at address 0001
        [    3.585872] RTW: rtl8733bu v5.13.0-36-g1780015fd.20210304_COEX20210106-2002_beta
        [    3.598996] mmcblk0: mmc0:0001 88A398 7.28 GiB
        [    3.603073] RTW: build time: Apr 23 2024 20:14:05
        [    3.611878] mmcblk0rpmb: mmc0:0001 88A398 partition 3 4.00 MiB, chardev (242:0)
        [    3.616623] RTW: rtl8733bu BT-Coex version = COEX20210106-2002
        [    3.625534]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
        [    3.630116] RTW: rtw_inetaddr_notifier_register
        [    3.646732] RTW:
        [    3.646732] usb_endpoint_descriptor(0):
        [    3.653206] RTW: bLength=7
        [    3.656271] RTW: bDescriptorType=5
        [    3.660083] RTW: bEndpointAddress=84
        [    3.664136] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.673699] RTW: wMaxPacketSize=512
        [    3.679694] RTW: bInterval=0
        [    3.680960] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [    3.682925] RTW: RT_usb_endpoint_is_bulk_in = 4
        [    3.699717] RTW:
        [    3.699717] usb_endpoint_descriptor(1):
        [    3.706194] RTW: bLength=7
        [    3.709247] RTW: bDescriptorType=5
        [    3.713064] RTW: bEndpointAddress=5
        [    3.716992] RTW: wMaxPacketSize=512
        [    3.720905] RTW: bInterval=0
        [    3.724180] RTW: RT_usb_endpoint_is_bulk_out = 5
        [    3.729371] RTW:
        [    3.729371] usb_endpoint_descriptor(2):
        [    3.735835] RTW: bLength=7
        [    3.738886] RTW: bDescriptorType=5
        [    3.742720] RTW: bEndpointAddress=6
        [    3.746664] RTW: wMaxPacketSize=512
        [    3.750578] RTW: bInterval=0
        [    3.753824] RTW: RT_usb_endpoint_is_bulk_out = 6
        [    3.759012] RTW:
        [    3.759012] usb_endpoint_descriptor(3):
        [    3.765483] RTW: bLength=7
        [    3.768528] RTW: bDescriptorType=5
        [    3.772354] RTW: bEndpointAddress=87
        [    3.776394] RTW: wMaxPacketSize=64
        [    3.780222] RTW: bInterval=3
        [    3.783462] RTW: RT_usb_endpoint_is_int_in = 7, Interval = 3
        [    3.789839] RTW:
        [    3.789839] usb_endpoint_descriptor(4):
        [    3.796322] RTW: bLength=7
        [    3.799369] RTW: bDescriptorType=5
        [    3.803194] RTW: bEndpointAddress=8
        [    3.807127] RTW: wMaxPacketSize=512
        [    3.811057] mmc1: host does not support reading read-only switch, assuming write-enable
        [    3.820070] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    3.831609] RTW: bInterval=0
        [    3.831675] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
        [    3.834856] RTW: RT_usb_endpoint_is_bulk_out = 8
        [    3.834863] RTW: nr_endpoint=5, in_num=2, out_num=3
        [    3.834863]
        [    3.858944] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
        [    3.859005] mmc1: new high speed SDHC card at address aaaa
        [    3.870672] RTW: USB_SPEED_HIGH
        [    3.870679] RTW: CHIP TYPE: RTL8733B
        [    3.877946] mmcblk1: mmc1:aaaa SU04G 3.69 GiB
        [    3.880614] RTW: [HALMAC]129
        [    3.880614] HALMAC_MAJOR_VER = 1
        [    3.880614] HALMAC_PROTOTYPE_VER = 6
        [    3.880614] HALMAC_MINOR_VER = 6
        [    3.880614] HALMAC_PATCH_VER = 0
        [    3.908409] RTW: Chip Version Info: CHIP_8733B_U4_1T1R_RomVer(3)
        [    3.915284] RTW: config_chip_out_EP OutEpQueueSel(0x07), OutEpNumber(3)
        [    3.915321]  mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8
        [    3.923036] RTW: ERROR [HALMAC][ERR]Dump efuse in suspend
        [    4.062039] RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_LOGICAL_EFUSE
        [    4.069452] RTW: HW EFUSE
        [    4.072397] RTW: 0x000: 29 81 80 86  10 00 84 00  B0 0D B4 10  08 94 8A 1B
        [    4.080363] RTW: 0x010: 00 00 00 00  00 00 00 00  00 06 06 FF  FF FF FF FF
        [    4.088328] RTW: 0x020: FF FF 09 0B  07 0C 09 0A  0B 0A 10 0E  0A 0B 08 0A
        [    4.096283] RTW: 0x030: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.104235] RTW: 0x040: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.112173] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.120129] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.128134] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.136091] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.144045] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.151978] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.159936] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  7F 61 21 00  FF FF FF FF
        [    4.167884] RTW: 0x0C0: FF 21 00 10  00 00 00 00  40 11 05 FF  FF FF FF FF
        [    4.175840] RTW: 0x0D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.183788] RTW: 0x0E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.191738] RTW: 0x0F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.199688] RTW: 0x100: DA 0B 33 B7  E0 67 02 00  54 F2 9F 50  25 35 09 03
        [    4.207647] RTW: 0x110: 52 65 61 6C  74 65 6B 17  03 38 30 32  2E 31 31 6E
        [    4.215608] RTW: 0x120: 20 20 57 4C  41 4E 20 41  64 61 70 74  65 72 0E 03
        [    4.223546] RTW: 0x130: 30 30 65 30  34 63 30 30  30 30 30 31  FF FF FF FF
        [    4.231507] RTW: 0x140: FF FF FF FF  FF FF FF FF  00 00 00 0F  FF FF FF FF
        [    4.239458] RTW: 0x150: 9F 38 7B 8D  C8 58 90 C1  25 EF 00 00  00 11 06 66
        [    4.247410] RTW: 0x160: FC 8C 00 11  9B 15 00 0E  FF FF FF FF  FF FF FF FF
        [    4.255358] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.263308] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.271257] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.279210] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.287159] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.295112] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.303046] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.311000] RTW: 0x1E0: D0 B0 58 59  32 07 55 C0  C0 00 A0 C4  63 DD 98 BB
        [    4.318953] RTW: 0x1F0: 14 05 24 E7  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.326908] RTW: 0x200: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.334856] RTW: 0x210: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.342794] RTW: 0x220: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.350746] RTW: 0x230: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.358699] RTW: 0x240: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.366651] RTW: 0x250: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.374619] RTW: 0x260: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.382553] RTW: 0x270: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.390501] RTW: 0x280: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.398456] RTW: 0x290: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.406404] RTW: 0x2A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.414363] RTW: 0x2B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.422298] RTW: 0x2C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.430252] RTW: 0x2D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.438203] RTW: 0x2E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.446155] RTW: 0x2F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
        [    4.454107] RTW: check_phy_efuse_tx_power_info_valid: tpt_mode is TSSI, skip check
        [    4.462607] RTW: EEPROM ID = 0x8129
        [    4.466536] RTW: EEPROM Version = 0
        [    4.470461] RTW: Hal_EfuseParseTxPowerInfo tpt_mode=4, PG with TSSI_OFFSET
        [    4.478198] RTW: EEPROM Regulatory=0x01
        [    4.482505] RTW: EEPROM Board Type=0x01
        [    4.486824] RTW: EEPROM Enable BT-coex, ant_num=2
        [    4.492113] RTW: hal_com_config_channel_plan chplan:0x7F
        [    4.498088] RTW: EEPROM crystal_cap=0x61
        [    4.502489] RTW: EEPROM ThermalMeter=0x21
        [    4.507002] RTW: EEPROM efuse[0xc9]=0x11 is valid
        [    4.512286] RTW: EEPROM Customer ID=0x00
        [    4.516708] RTW: EEPROM SupportRemoteWakeup=0
        [    4.521597] RTW: EEPROM PAType_2G is 0x0, ExternalPA_2G = 0
        [    4.527874] RTW: EEPROM PAType_5G is 0x0, external_pa_5g = 0
        [    4.534238] RTW: EEPROM LNAType_2G is 0x0, ExternalLNA_2G = 0
        [    4.540706] RTW: EEPROM LNAType_5G is 0x0, external_lna_5g = 0
        [    4.547267] RTW: EEPROM TypeGPA = 0x0
        [    4.551375] RTW: EEPROM TypeAPA = 0x0
        [    4.555498] RTW: EEPROM TypeGLNA = 0x0
        [    4.559710] RTW: EEPROM TypeALNA = 0x0
        [    4.563931] RTW: EEPROM rfe_type=0x5
        [    4.567945] RTW: EEPROM USB Switch=0
        [    4.571964] RTW: EEPROM VID = 0x0BDA, PID = 0xB733
        [    4.587272] RTW: SetHwReg: bMacPwrCtrlOn=1
        [    4.594519] RTW: rtl8733b_fw_dl fw source from array
        [    5.324526] RTW: ERROR [HALMAC][ERR]Check 0x80 = 0xC078 fail
        [    5.331272] RTW: ERROR download_fw: download firmware FAIL! status=0x69
        [    5.338897] RTW: _debug_dlfw_fail: 0x80 = 0x6078
        [    5.344272] RTW: _debug_dlfw_fail: 0x10F8 = 0x03ffffff
        [    5.350147] RTW: _debug_dlfw_fail: 0x10FC = 0x0000ffff (0/5)
        [    5.356647] RTW: _debug_dlfw_fail: 0x10FC = 0x0000ffff (1/5)
        [    5.363146] RTW: _debug_dlfw_fail: 0x10FC = 0x0000ffff (2/5)
        [    5.369647] RTW: _debug_dlfw_fail: 0x10FC = 0x0000ffff (3/5)
        [    5.376147] RTW: _debug_dlfw_fail: 0x10FC = 0x0000ffff (4/5)
        [    5.382776] RTW: _debug_dlfw_fail: 0x3A = 0x28
        [    5.388020] RTW: _debug_dlfw_fail: 0xF6 = 0x01
        [    5.393147] RTW: _debug_dlfw_fail: 0xC0 = 0x6180d600 (0/5)
        [    5.399522] RTW: _debug_dlfw_fail: 0xC0 = 0x6180d600 (1/5)
        [    5.405896] RTW: _debug_dlfw_fail: 0xC0 = 0x6180d602 (2/5)
        [    5.412146] RTW: _debug_dlfw_fail: 0xC0 = 0x6180d600 (3/5)
        [    5.418523] RTW: _debug_dlfw_fail: 0xC0 = 0x6180d601 (4/5)
        [    5.424716] RTW: ======= MAC REG =======
        [    5.429117] RTW: 0x0000 0xdc1f8f98  0x30030012  0x0020fc23  0x00000000
        [    5.437089] RTW: 0x0010 0x0009a200  0x0000ffff  0x00400100  0x874bd100
        [    5.445096] RTW: 0x0020 0x077777ff  0x32171150  0x07286000  0x0051b54b
        [    5.453074] RTW: 0x0030 0xa7a1ffff  0x34000000  0x10280000  0x00000000
        [    5.461102] RTW: 0x0040 0x00040004  0x00000000  0x00100000  0x08428282
        [    5.469089] RTW: 0x0050 0x00000000  0x00000e02  0x00000000  0x00000040
        [    5.477093] RTW: 0x0060 0x00000040  0x3e040800  0x8000c0e4  0x0000000f
        [    5.485091] RTW: 0x0070 0x04180000  0x87000405  0x08000000  0x08c00000
        [    5.493080] RTW: 0x0080 0x00606078  0x00000000  0x00000000  0x00000000
        [    5.501094] RTW: 0x0090 0x14008200  0x00be2aaa  0x00000000  0x00000000
        [    5.509094] RTW: 0x00a0 0x008006a0  0x00000000  0x00000000  0x00000000
        [    5.517092] RTW: 0x00b0 0x00000000  0x80000000  0x00000000  0x00000000
        [    5.525103] RTW: 0x00c0 0x6180d602  0x00000000  0xeaeaeaea  0x00ff0069
        [    5.533076] RTW: 0x00d0 0x00000000  0x00000000  0x00005544  0x00000000
        [    5.541106] RTW: 0x00e0 0x00000000  0x00000000  0x00000000  0x0000007f
        [    5.549089] RTW: 0x00f0 0x0069333f  0x30010054  0x00058129  0x00000016
        [    5.557088] RTW: 0x0100 0x00000000  0x00000110  0x00000000  0x00000000
        [    5.565089] RTW: 0x0110 0x00000000  0x3fff0ff6  0x00000000  0x00000000
        [    5.573074] RTW: 0x0120 0x00000000  0x00002010  0x00000000  0x00000000
        [    5.581101] RTW: 0x0130 0x00000000  0x00000000  0x00000000  0x00008000
        [    5.589087] RTW: 0x0140 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.597095] RTW: 0x0150 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.605087] RTW: 0x0160 0x00000000  0x00000001  0x00000000  0x00000000
        [    5.613080] RTW: 0x0170 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.621098] RTW: 0x0180 0x00000000  0x00000000  0x00000000  0x01312d00
        [    5.629097] RTW: 0x0190 0x00000000  0x00000800  0x00000002  0x00008000
        [    5.637087] RTW: 0x01a0 0x34060019  0x1fe56c2b  0xffffffff  0x00fefcf8
        [    5.645098] RTW: 0x01b0 0x00000000  0x0a000512  0x00000000  0x80045929
        [    5.653074] RTW: 0x01c0 0x8020ffc0  0x00000000  0x00000000  0x00000000
        [    5.661105] RTW: 0x01d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.669088] RTW: 0x01e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.677095] RTW: 0x01f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.685087] RTW: 0x0200 0x00000000  0x00000000  0x00000010  0x00fd0000
        [    5.693080] RTW: 0x0210 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.701092] RTW: 0x0220 0x00000000  0x00000000  0xfa00f800  0x00000000
        [    5.709099] RTW: 0x0230 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.717090] RTW: 0x0240 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.725103] RTW: 0x0250 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.733075] RTW: 0x0260 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.741107] RTW: 0x0270 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.749090] RTW: 0x0280 0x00002003  0x00020000  0x00000000  0x00000000
        [    5.757089] RTW: 0x0290 0x00000004  0x00000000  0x00000000  0x00000000
        [    5.765087] RTW: 0x02a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.773074] RTW: 0x02b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.781100] RTW: 0x02c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.789088] RTW: 0x02d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.797093] RTW: 0x02e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.805091] RTW: 0x02f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    5.813079] RTW: 0x0300 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.821097] RTW: 0x0310 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.829093] RTW: 0x0320 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.837094] RTW: 0x0330 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.845094] RTW: 0x0340 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.853074] RTW: 0x0350 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.861099] RTW: 0x0360 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.869090] RTW: 0x0370 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.877096] RTW: 0x0380 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.885089] RTW: 0x0390 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.893079] RTW: 0x03a0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.901093] RTW: 0x03b0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.909094] RTW: 0x03c0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.917092] RTW: 0x03d0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.925104] RTW: 0x03e0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.933075] RTW: 0x03f0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    5.941108] RTW: 0x0400 0x007f80ff  0x007f80ff  0x007f80ff  0x007f80ff
        [    5.949089] RTW: 0x0410 0x007f80ff  0x007f80ff  0x0fff00f6  0x000000f6
        [    5.957089] RTW: 0x0420 0x00703f83  0xf510f6f6  0x20201616  0x0000c000
        [    5.965091] RTW: 0x0430 0x02000000  0x08070504  0x04030201  0x08070605
        [    5.973073] RTW: 0x0440 0x00600011  0x00000000  0x00000000  0x00000000
        [    5.981100] RTW: 0x0450 0x00000000  0xf664f64d  0xffffffff  0x1000f600
        [    5.989087] RTW: 0x0460 0x03000000  0x00ff00ff  0x007f80ff  0x007f80ff
        [    5.997094] RTW: 0x0470 0x007f80ff  0x007f80ff  0x00000000  0xfe050000
        [    6.005090] RTW: 0x0480 0x000c0400  0x00000000  0x00000000  0xdeadbeef
        [    6.013083] RTW: 0x0490 0x00000000  0x00008028  0x0000fc00  0xdeadbeef
        [    6.021094] RTW: 0x04a0 0xdeadbeef  0x00000000  0x00000000  0x00000005
        [    6.029094] RTW: 0x04b0 0x00000000  0x00000000  0x00000000  0x00040040
        [    6.037087] RTW: 0x04c0 0x10001000  0x00040340  0x0c140101  0x0102ff7f
        [    6.045108] RTW: 0x04d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.053076] RTW: 0x04e0 0x00000000  0x00f23000  0x00000000  0x00000000
        [    6.061101] RTW: 0x04f0 0x00000000  0x00000000  0x00000000  0xffff0000
        [    6.069088] RTW: 0x0500 0x002f3224  0x005e4326  0x0000a42b  0x0000a549
        [    6.077095] RTW: 0x0510 0x281c4413  0x10101010  0x09140002  0x00000500
        [    6.085087] RTW: 0x0520 0x00003f0f  0x0000c80f  0x806c0a8f  0x00000040
        [    6.093082] RTW: 0x0530 0x00000000  0x00100000  0x00000000  0x00000000
        [    6.101095] RTW: 0x0540 0x8000c802  0x00400180  0x00000000  0x00000000
        [    6.109095] RTW: 0x0550 0x00001414  0x00640064  0x00000305  0x0f0f1014
        [    6.117090] RTW: 0x0560 0x00000001  0x00000000  0x0015b2a2  0x00000000
        [    6.125135] RTW: 0x0570 0x7f0a0100  0x88ff1000  0x00141414  0x80808080
        [    6.133072] RTW: 0x0580 0x00000000  0x00000000  0x00000000  0x00200060
        [    6.140982] RTW: 0x0590 0x800f000f  0x00000000  0x00000000  0x00000000
        [    6.148964] RTW: 0x05a0 0x02020202  0x00000000  0x00000000  0x000100ff
        [    6.156964] RTW: 0x05b0 0x00000200  0x00021040  0x00640064  0x00040064
        [    6.164962] RTW: 0x05c0 0x00000000  0x00000000  0x00000000  0x01e21051
        [    6.172949] RTW: 0x05d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.180968] RTW: 0x05e0 0x00001000  0x00003000  0x00001000  0x00000003
        [    6.188966] RTW: 0x05f0 0x00000000  0x00000000  0x00000000  0xffff0000
        [    6.196969] RTW: 0x0600 0x04000000  0x20300000  0x00000000  0x04000410
        [    6.204964] RTW: 0x0610 0x00000000  0x001f0000  0x00000000  0x00000000
        [    6.212954] RTW: 0x0620 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.220967] RTW: 0x0630 0x08840000  0x00000002  0x100a1414  0x10101010
        [    6.228971] RTW: 0x0640 0x013a1414  0x00c00064  0x00000010  0x00000000
        [    6.236962] RTW: 0x0650 0x00000426  0x00000000  0x00000000  0x00000000
        [    6.244960] RTW: 0x0660 0x00000010  0x00000000  0x0e301000  0x00042007
        [    6.252949] RTW: 0x0670 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.260968] RTW: 0x0680 0x0000000c  0x00000000  0x00000000  0x00000000
        [    6.268963] RTW: 0x0690 0x00000000  0x000a0200  0x00000000  0x00000000
        [    6.276974] RTW: 0x06a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.284964] RTW: 0x06b0 0x00000000  0x00000000  0x00000000  0x03800000
        [    6.292954] RTW: 0x06c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.300956] RTW: 0x06d0 0x00000000  0x00000000  0x0000003f  0x4b040000
        [    6.308959] RTW: 0x06e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.316970] RTW: 0x06f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.324976] RTW: 0x0700 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.332948] RTW: 0x0710 0x00000000  0x00000000  0x20000280  0x00000000
        [    6.340976] RTW: 0x0720 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.348964] RTW: 0x0730 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.356963] RTW: 0x0740 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.364966] RTW: 0x0750 0x00000076  0x00000000  0x00000000  0x00000000
        [    6.372946] RTW: 0x0760 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.380844] RTW: 0x0770 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.388837] RTW: 0x0780 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.396846] RTW: 0x0790 0x00000000  0x0000017f  0x04444400  0x02030405
        [    6.404843] RTW: 0x07a0 0x4a004010  0x01223425  0x88e088e0  0x880b880b
        [    6.412832] RTW: 0x07b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.420841] RTW: 0x07c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.428845] RTW: 0x07d0 0x0fff0fff  0x5080a000  0x30810041  0x00000000
        [    6.436839] RTW: 0x07e0 0x001845a5  0x00000000  0x00000000  0x00780064
        [    6.444851] RTW: 0x07f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.452823] RTW: 0x1000 0x0003300f  0x00000002  0x0000000b  0x00000000
        [    6.460848] RTW: 0x1010 0xb62d98d8  0x92696aa1  0x0001cdf4  0x30298a41
        [    6.468840] RTW: 0x1020 0x3802611a  0x00110000  0x00000053  0x00000000
        [    6.476845] RTW: 0x1030 0x00000000  0xc0000000  0x0000000c  0x008103ff
        [    6.484838] RTW: 0x1040 0xfe1dcb50  0x00000002  0x1b61b61b  0x000001b5
        [    6.492833] RTW: 0x1050 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.500839] RTW: 0x1060 0x00000000  0x0061b2f3  0x001ee0eb  0x6607ffe8
        [    6.508845] RTW: 0x1070 0x00000034  0x63ff7f02  0x0000001e  0x0006007f
        [    6.516842] RTW: 0x1080 0x0006ffe8  0x0000001f  0x4275f8aa  0x000000c5
        [    6.524853] RTW: 0x1090 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.532826] RTW: 0x10a0 0x00000000  0x00000000  0x00000000  0xfafafafa
        [    6.540853] RTW: 0x10b0 0x00000000  0x03020100  0x07060504  0x00000000
        [    6.548840] RTW: 0x10c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.556838] RTW: 0x10d0 0x05050505  0x05000000  0x00000000  0x1b1b0000
        [    6.564840] RTW: 0x10e0 0x00000000  0x00000000  0x00000000  0x000007ff
        [    6.572823] RTW: 0x10f0 0x02020202  0x00002222  0x03ffffff  0x0000ffff
        [    6.580848] RTW: 0x1100 0x0c000000  0x0004c4b4  0x80000109  0x00200020
        [    6.588839] RTW: 0x1110 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.596847] RTW: 0x1120 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.604839] RTW: 0x1130 0x00000000  0x00000000  0x00000000  0x20000000
        [    6.612830] RTW: 0x1140 0xfffff800  0x00000000  0xfffffffc  0x00000000
        [    6.620846] RTW: 0x1150 0x00000000  0x00000080  0x00000000  0x00000000
        [    6.628845] RTW: 0x1160 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.636839] RTW: 0x1170 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.644846] RTW: 0x1180 0x00000000  0x00000000  0x00000000  0x07e00000
        [    6.652823] RTW: 0x1190 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.660844] RTW: 0x11a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.668842] RTW: 0x11b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.676845] RTW: 0x11c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.684839] RTW: 0x11d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.692830] RTW: 0x11e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.700838] RTW: 0x11f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.708847] RTW: 0x1200 0x18780028  0x14058000  0x21000ae0  0x00000000
        [    6.716842] RTW: 0x1210 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.724852] RTW: 0x1220 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.732824] RTW: 0x1230 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.740852] RTW: 0x1240 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.748840] RTW: 0x1250 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.756841] RTW: 0x1260 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.764838] RTW: 0x1270 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.772825] RTW: 0x1280 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.780845] RTW: 0x1290 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.788838] RTW: 0x12a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.796848] RTW: 0x12b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.804838] RTW: 0x12c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.812830] RTW: 0x12d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.820841] RTW: 0x12e0 0x0000003f  0x00000000  0x00000000  0x00000000
        [    6.828847] RTW: 0x12f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.836839] RTW: 0x1300 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.844849] RTW: 0x1310 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.852823] RTW: 0x1320 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.860846] RTW: 0x1330 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.868838] RTW: 0x1340 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.876846] RTW: 0x1350 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.884841] RTW: 0x1360 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.892831] RTW: 0x1370 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.900840] RTW: 0x1380 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.908846] RTW: 0x1390 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.916842] RTW: 0x13a0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.924853] RTW: 0x13b0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.932824] RTW: 0x13c0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.940853] RTW: 0x13d0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.948840] RTW: 0x13e0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.956839] RTW: 0x13f0 0xeaeaeaea  0xeaeaeaea  0xeaeaeaea  0xeaeaeaea
        [    6.964840] RTW: 0x1400 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.972826] RTW: 0x1410 0x00000000  0x00000000  0x00000000  0x00000000
        [    6.980848] RTW: 0x1420 0x00000000  0x00000000  0x0fffffff  0x0fffffff
        [    6.988838] RTW: 0x1430 0x00000303  0x00000000  0x00000000  0x00000000
        [    6.996845] RTW: 0x1440 0x00000000  0x00000000  0x08040804  0x08040804
        [    7.004839] RTW: 0x1450 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.012832] RTW: 0x1460 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.020842] RTW: 0x1470 0x10000000  0x00000000  0x10000000  0x00000000
        [    7.028845] RTW: 0x1480 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.036838] RTW: 0x1490 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.044845] RTW: 0x14a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.052822] RTW: 0x14b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.060850] RTW: 0x14c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.068838] RTW: 0x14d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.076845] RTW: 0x14e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.084849] RTW: 0x14f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.092830] RTW: 0x1500 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.100842] RTW: 0x1510 0x05050505  0x00000000  0x00003224  0x00000000
        [    7.108845] RTW: 0x1520 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.116842] RTW: 0x1530 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.124853] RTW: 0x1540 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.132823] RTW: 0x1550 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.140853] RTW: 0x1560 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.148841] RTW: 0x1570 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.156838] RTW: 0x1580 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.164860] RTW: 0x1590 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.172823] RTW: 0x15a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.180846] RTW: 0x15b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.188844] RTW: 0x15c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.196844] RTW: 0x15d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.204838] RTW: 0x15e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.212832] RTW: 0x15f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.220841] RTW: 0x1600 0x00000000  0x00000000  0x00000000  0xffffffff
        [    7.228845] RTW: 0x1610 0x000400c0  0x00000000  0x00000024  0x00000000
        [    7.236842] RTW: 0x1620 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.244845] RTW: 0x1630 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.252823] RTW: 0x1640 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.260845] RTW: 0x1650 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.268838] RTW: 0x1660 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.276847] RTW: 0x1670 0x00000000  0x00000000  0x00000000  0x1f2a4800
        [    7.284839] RTW: 0x1680 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.292832] RTW: 0x1690 0x00000000  0x02000000  0x00000000  0x0f1607ce
        [    7.300839] RTW: 0x16a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.308845] RTW: 0x16b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.316841] RTW: 0x16c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.324856] RTW: 0x16d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.332823] RTW: 0x16e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.340853] RTW: 0x16f0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.348838] RTW: 0x1700 0x20000000  0x00000000  0x00000000  0x00000000
        [    7.356838] RTW: 0x1710 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.364843] RTW: 0x1720 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.372823] RTW: 0x1730 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.380845] RTW: 0x1740 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.388869] RTW: 0x1750 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.396851] RTW: 0x1760 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.404839] RTW: 0x1770 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.412833] RTW: 0x1780 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.420842] RTW: 0x1790 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.428846] RTW: 0x17a0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.436839] RTW: 0x17b0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.444846] RTW: 0x17c0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.452826] RTW: 0x17d0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.460845] RTW: 0x17e0 0x00000000  0x00000000  0x00000000  0x00000000
        [    7.468839] RTW: 0x17f0 0x00000000  0x00000000  0x00000000  0x00000000
        [   10.458254] random: crng init done
        [   17.803782] RTW: _debug_dlfw_fail: 0x80 = 0x6078 (after 10 secs)
        [   17.810539] RTW: ERROR rtl8733b_fw_dl Download Firmware from array failed
        [   17.818197] RTW: SetHwReg: bMacPwrCtrlOn=0
        [   17.830525] RTW: hal_read_mac_hidden_rpt Fail! (0, 13250ms), fwdl:0, id:0xfd
        [   17.838466] RTW: rtw_hal_read_chip_info in 13920 ms
        [   17.843986] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
        [   17.849282] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
        [   17.859560] RTW: [RF_PATH] PG's trx_path_bmp:0x11, max_tx_cnt:0
        [   17.866227] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
        [   17.875050] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
        [   17.882182] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
        [   17.889526] RTW: rtw_hal_rfpath_init trx_path_bmp:0x11(RF_1T1R), NumTotalRFPath:1, max_tx_cnt:1
        [   17.899312] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
        [   17.905203] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
        [   17.911172] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
        [   17.917050] RTW: rtw_hal_trxnss_init tx_nss:1, rx_nss:1
        [   17.922917] RTW: txpath=0x1, rxpath=0x1
        [   17.927241] RTW: txpath_1ss:0x1, num:1
        [   17.932065] RTW: NR_RECVBUFF: 8, recvbuf_nr: 8
        [   17.937118] RTW: MAX_RECVBUF_SZ: 32768
        [   17.941376] RTW: NR_PREALLOC_RECV_SKB: 8
        [   17.946054] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
        [   17.954409] RTW: rtw_init_pwrctrl_priv: IPS_mode=1, LPS_mode=2, LPS_level=0
        [   17.962256] RTW: IQK FW offload:disable
        [   17.966592] RTW: init_phydm_cominfo: Fv=1 Cv=3
        [   17.971586] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
        [   17.981752] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
        [   17.991411] RTW: default power by rate loaded
        [   17.996381] RTW: WARN HW band_cap has no intersection with SW wireless_mode setting
        [   18.005021] RTW: can't get autopm:
        [   18.008869] RTW: rtw_macaddr_cfg mac addr:54:f2:9f:50:25:35
        [   18.015150] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
        [   18.024293] RTW: rtw_cfg80211_init_wiphy_band:rf_type=0
        [   18.030160] RTW: rtw_wiphy_alloc(phy0)
        [   18.034449] RTW: rtw_wdev_alloc(padapter=7d8cf5dd)
        [   18.039832] RTW: rtw_wiphy_register(phy0)
        [   18.044359] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
        [   18.051198] ------------[ cut here ]------------
        [   18.056408] WARNING: CPU: 0 PID: 1 at /home/damon/t113/auto-t113x-linux/kernel/linux-5.4/net/wireless/core.c:872 wiphy_register+0x7f8/0x9c4
        [   18.070476] Modules linked in:
        [   18.073927] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61+ #28
        [   18.080760] Hardware name: Generic DT based system
        [   18.086153] [<c010d96c>] (unwind_backtrace) from [<c010a1e4>] (show_stack+0x10/0x14)
        [   18.094845] [<c010a1e4>] (show_stack) from [<c08ea01c>] (dump_stack+0x7c/0x98)
        [   18.102954] [<c08ea01c>] (dump_stack) from [<c0118df0>] (__warn+0xac/0xdc)
        [   18.110671] [<c0118df0>] (__warn) from [<c0118e84>] (warn_slowpath_fmt+0x64/0x78)
        [   18.119070] [<c0118e84>] (warn_slowpath_fmt) from [<c08bd008>] (wiphy_register+0x7f8/0x9c4)
        [   18.128445] [<c08bd008>] (wiphy_register) from [<c0671f80>] (rtw_wiphy_register+0x64/0x70)
        [   18.137720] [<c0671f80>] (rtw_wiphy_register) from [<c0672424>] (rtw_cfg80211_dev_res_register+0xc/0x18)
        [   18.148361] [<c0672424>] (rtw_cfg80211_dev_res_register) from [<c0652208>] (rtw_os_ndevs_register+0x14/0x170)
        [   18.159488] [<c0652208>] (rtw_os_ndevs_register) from [<c06523b0>] (rtw_os_ndevs_init+0x1c/0x44)
        [   18.169346] [<c06523b0>] (rtw_os_ndevs_init) from [<c06547f0>] (rtw_drv_init+0x608/0x6cc)
        [   18.178527] [<c06547f0>] (rtw_drv_init) from [<c04ac9e0>] (usb_probe_interface+0x168/0x204)
        [   18.187901] [<c04ac9e0>] (usb_probe_interface) from [<c0420508>] (really_probe+0x1a8/0x418)
        [   18.197274] [<c0420508>] (really_probe) from [<c04209bc>] (driver_probe_device+0x10c/0x158)
        [   18.206646] [<c04209bc>] (driver_probe_device) from [<c0420b94>] (device_driver_attach+0x44/0x5c)
        [   18.216602] [<c0420b94>] (device_driver_attach) from [<c0420c58>] (__driver_attach+0xac/0xb8)
        [   18.226171] [<c0420c58>] (__driver_attach) from [<c041eb60>] (bus_for_each_dev+0x54/0x78)
        [   18.235352] [<c041eb60>] (bus_for_each_dev) from [<c041f964>] (bus_add_driver+0xdc/0x1bc)
        [   18.244531] [<c041f964>] (bus_add_driver) from [<c04213e8>] (driver_register+0xb0/0xf8)
        [   18.253514] [<c04213e8>] (driver_register) from [<c04ab528>] (usb_register_driver+0x70/0x124)
        [   18.263084] [<c04ab528>] (usb_register_driver) from [<c0e21be4>] (rtw_drv_entry+0xf0/0x15c)
        [   18.272458] [<c0e21be4>] (rtw_drv_entry) from [<c0102f38>] (do_one_initcall+0x70/0x198)
        [   18.281443] [<c0102f38>] (do_one_initcall) from [<c0e00d7c>] (kernel_init_freeable+0x108/0x1cc)
        [   18.291208] [<c0e00d7c>] (kernel_init_freeable) from [<c08fd818>] (kernel_init+0x8/0x118)
        [   18.300386] [<c08fd818>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
        [   18.308876] Exception stack(0xde43dfb0 to 0xde43dff8)
        [   18.314542] dfa0:                                     00000000 00000000 00000000 00000000
        [   18.323717] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
        [   18.332891] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
        [   18.340416] ---[ end trace 3bd1e33f9ddd11c4 ]---
        [   18.345637] ------------[ cut here ]------------
        [   18.350828] WARNING: CPU: 0 PID: 1 at /home/damon/t113/auto-t113x-linux/out/kernel/build/source/drivers/staging/rtl8733BU//os_dep/linux/os_intfs.c:3705 rtw_os_ndevs_register+0x54/0x170
        [   18.369281] Modules linked in:
        [   18.372719] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W         5.4.61+ #28
        [   18.381110] Hardware name: Generic DT based system
        [   18.386493] [<c010d96c>] (unwind_backtrace) from [<c010a1e4>] (show_stack+0x10/0x14)
        [   18.395184] [<c010a1e4>] (show_stack) from [<c08ea01c>] (dump_stack+0x7c/0x98)
        [   18.403290] [<c08ea01c>] (dump_stack) from [<c0118df0>] (__warn+0xac/0xdc)
        [   18.411006] [<c0118df0>] (__warn) from [<c0118e84>] (warn_slowpath_fmt+0x64/0x78)
        [   18.419404] [<c0118e84>] (warn_slowpath_fmt) from [<c0652248>] (rtw_os_ndevs_register+0x54/0x170)
        [   18.429359] [<c0652248>] (rtw_os_ndevs_register) from [<c06523b0>] (rtw_os_ndevs_init+0x1c/0x44)
        [   18.439217] [<c06523b0>] (rtw_os_ndevs_init) from [<c06547f0>] (rtw_drv_init+0x608/0x6cc)
        [   18.448396] [<c06547f0>] (rtw_drv_init) from [<c04ac9e0>] (usb_probe_interface+0x168/0x204)
        [   18.457769] [<c04ac9e0>] (usb_probe_interface) from [<c0420508>] (really_probe+0x1a8/0x418)
        [   18.467141] [<c0420508>] (really_probe) from [<c04209bc>] (driver_probe_device+0x10c/0x158)
        [   18.476513] [<c04209bc>] (driver_probe_device) from [<c0420b94>] (device_driver_attach+0x44/0x5c)
        [   18.486469] [<c0420b94>] (device_driver_attach) from [<c0420c58>] (__driver_attach+0xac/0xb8)
        [   18.496037] [<c0420c58>] (__driver_attach) from [<c041eb60>] (bus_for_each_dev+0x54/0x78)
        [   18.505217] [<c041eb60>] (bus_for_each_dev) from [<c041f964>] (bus_add_driver+0xdc/0x1bc)
        [   18.514396] [<c041f964>] (bus_add_driver) from [<c04213e8>] (driver_register+0xb0/0xf8)
        [   18.523379] [<c04213e8>] (driver_register) from [<c04ab528>] (usb_register_driver+0x70/0x124)
        [   18.532947] [<c04ab528>] (usb_register_driver) from [<c0e21be4>] (rtw_drv_entry+0xf0/0x15c)
        [   18.542319] [<c0e21be4>] (rtw_drv_entry) from [<c0102f38>] (do_one_initcall+0x70/0x198)
        [   18.551302] [<c0102f38>] (do_one_initcall) from [<c0e00d7c>] (kernel_init_freeable+0x108/0x1cc)
        [   18.561065] [<c0e00d7c>] (kernel_init_freeable) from [<c08fd818>] (kernel_init+0x8/0x118)
        [   18.570243] [<c08fd818>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
        [   18.578732] Exception stack(0xde43dfb0 to 0xde43dff8)
        [   18.584396] dfa0:                                     00000000 00000000 00000000 00000000
        [   18.593571] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
        [   18.602744] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
        [   18.610249] ---[ end trace 3bd1e33f9ddd11c5 ]---
        [   18.615474] RTW: rtw_wdev_free(wdev=9c59dee1)
        [   18.620389] RTW: rtw_wiphy_free(phy0)
        [   18.624562] RTW: rtw_usb_primary_adapter_deinit((null))
        [   18.630430] RTW: rtw_dev_unload: bup==_FALSE
        [   18.635247] RTW: +r871xu_dev_remove, hw_init_completed=0
        [   18.641695] RTW: WARN free_recv_skb_queue not empty, 8
        [   18.647751] usbcore: registered new interface driver rtl8733bu
        [   18.654339] RTW: module init ret=0
        [   18.659165] rpmsg_tty_init: Sunxi rpmsg tty driver will init
        [   18.665618] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
        [   18.675739] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
        [   18.675739]
        [   18.693000] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
        [   18.704479] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
        [   18.713938] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
        [   18.723797] [SNDCODEC][sunxi_card_init][583]:card init finished
        [   18.731123] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
        [   18.742327] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
        [   18.754512] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
        [   18.763803] NET: Registered protocol family 10
        [   18.769969] Segment Routing with IPv6
        [   18.774196] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
        [   18.781646] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
        [   18.790004] NET: Registered protocol family 17
        [   18.795094] NET: Registered protocol family 15
        [   18.800089] can: controller area network core (rev 20170425 abi 9)
        [   18.807150] NET: Registered protocol family 29
        [   18.812166] can: raw protocol (rev 20170425)
        [   18.816991] can: broadcast manager protocol (rev 20170425 t)
        [   18.823355] can: netlink gateway (rev 20190810) max_hops=1
        [   18.829986] Bluetooth: RFCOMM TTY layer initialized
        [   18.835523] Bluetooth: RFCOMM socket layer initialized
        [   18.841359] Bluetooth: RFCOMM ver 1.11
        [   18.845653] NET: Registered protocol family 35
        [   18.851736] Registering SWP/SWPB emulation handler
        [   18.857539] Loading compiled-in X.509 certificates
        [   18.865335] HDMI2.0 module init end
        [   18.888063] sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
        [   18.898500] rtc-rx8025t 1-0032: power-on reset was detected, you may have to readjust the clock
        [   18.908375] rtc-rx8025t 1-0032: a power voltage drop was detected, you may have to readjust the clock
        [   18.918904] rtc-rx8025t 1-0032: bad conditions detected, resetting date
        [   18.927262] rtc-rx8025t 1-0032: registered as rtc0
        [   18.933786] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
        [   18.941946] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x38)
        [   18.949615] edt_ft5x06 1-0038: touchscreen probe failed
        [   18.955542] edt_ft5x06: probe of 1-0038 failed with error -22
        [   18.962060] i2c i2c-1: of_i2c: modalias failure on /soc@3000000/twi@2502400/ctp
        [   18.970284] i2c i2c-1: Failed to create I2C device for /soc@3000000/twi@2502400/ctp
        [   18.978912] sunxi-i2c sunxi-i2c1: probe success
        [   18.984535] sunxi-i2c sunxi-i2c3: sunxi-i2c3 supply twi not found, using dummy regulator
        [   18.995192] at24 3-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
        [   19.003989] ptn5150 3-003d: NXP PTN5150: Version ID:0x1, Vendor ID:0x3
        [   19.012496] at9555 gpio_base=224
        [   19.017616] at9555_gpio 3-0020: probed
        [   19.021965] sunxi-i2c sunxi-i2c3: probe success
        [   19.027344] deinterlace 5400000.deinterlace: Adding to iommu group 0
        [   19.035091] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
        [   19.043873] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
        [   19.052202] cpu_reg=0xdd135100
        [   19.055768] cpu cpu0: Failed to set regulator for cpu0: -517
        [   19.066727] get det_vbus is fail, -84
        [   19.072055] input: gpio-keys as /devices/platform/gpio-keys/input/input6
        [   19.084762] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [   19.096331] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [   19.104057] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
        [   19.113776] clk: Not disabling unused clocks
        [   19.118571] ALSA device list:
        [   19.121896]   #0: audiocodec
        [   19.125310] cfg80211: failed to load regulatory.db
        [   19.130775] alloc_fd: slot 0 not NULL!
        [   19.135299] Waiting 5 sec before mounting root device...
        [   23.163682]
        [   23.163682] insmod_device_driver
        [   23.163682]
        [   23.170915] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
        [   24.216878] EXT4-fs (mmcblk0p5): INFO: recovery required on readonly filesystem
        [   24.225156] EXT4-fs (mmcblk0p5): write access will be enabled during recovery
        [   24.245955] EXT4-fs (mmcblk0p5): recovery complete
        [   24.252495] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
        [   24.261713] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
        [   24.271393] Freeing unused kernel memory: 1024K
        [   24.313900] Kernel init done
        [   24.317145] Run /init as init process
        [   24.384272] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
        Starting syslogd: OK
        Starting klogd: OK
        Populating /dev using udev: [   24.608068] udevd[1364]: starting version 3.2.7
        [   24.628086] udevd[1364]: specified group 'input' unknown
        [   24.635038] udevd[1364]: specified group 'kvm' unknown
        [   24.661039] udevd[1365]: starting eudev-3.2.7
        [   24.666282] udevd[1365]: inotify_init failed: Function not implemented
        [   24.673822] udevd[1365]: error initializing inotify
        done
        Initializing random number generator... done.
        Starting system message bus: done
        Starting network: [   25.233292] libphy: 4500000.eth: probed
        [   25.333937] 8531 val=620
        [   25.337452] yt8521_config_init, 8521 init call out.
        [   25.343705] sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 4f51e91a at 0 IRQ poll (4500000.eth-0:00)
        udhcpc: started, v1.29.3
        udhcpc: sending discover
        udhcpc: no lease, failing
        FAIL
        Starting dropbear sshd: OK
        Initializing postgresql data base...
        su: unknown user postgres
        done
        Starting postgresql: su: unknown user postgres
        OK
        Starting sshd: Privilege separation user sshd does not exist
        OK
        Starting telnetd: OK
        >>>PN:MYD-YT113i-8E512D-110-I
        >>>SN:WK202307130090012
        create /dev/mmcblk1p7
        mount: mounting /dev/mmcblk1p7 on /mnt/sdcard/mmcblk1p7 failed: Invalid argument
        NTFS signature is missing.
        Failed to mount '/dev/mmcblk1p7': Invalid argument
        The device '/dev/mmcblk1p7' doesn't seem to have a valid NTFS.
        Maybe the wrong device is used? Or the whole disk instead of a
        partition (e.g. /dev/sda, not /dev/sda1)? Or the other way around?
        FUSE exf[   35.232812] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        ERROR: exFAT file system is not found.
        create /dev/mmcblk1p5
        mount: mounting /dev/mmcblk1p5 on /mnt/sdcard/mmcblk1p5 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p5': Invalid argument
        The device '/dev/mmcblk1p5' doesn't seem to have a valid NTFS.
        FUSE exfat 1.3.0
        [   35.332279] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: errors=continue
        create /dev/mmcblk1p8
        mount: mounting /dev/mmcblk1p8 on /mnt/sdcard/mmcblk1p8 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p8': Invalid argument
        The device '/dev/mmcblk1p8' doesn't seem to have a valid NTFS.
        FUSE exf[   35.424740] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        create /dev/mmcblk1p3
        mount: mounting /dev/mmcblk1p3 on /mnt/sdcard/mmcblk1p3 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p3': Invalid argument
        The device '/dev/mmcblk1p3' doesn't seem to have a valid NTFS.
        FUSE exf[   35.509704] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        create /dev/mmcblk1
        /etc/mdev/sdcard_insert: line 2: [: too many arguments
        create /dev/mmcblk1p6
        mount: mounting /dev/mmcblk1p6 on /mnt/sdcard/mmcblk1p6 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p6': Invalid argument
        The device '/dev/mmcblk1p6' doesn't seem to have a valid NTFS.
        FUSE exf[   35.628964] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        create /dev/mmcblk1p4
        mount: mounting /dev/mmcblk1p4 on /mnt/sdcard/mmcblk1p4 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p4': Invalid argument
        The device '/dev/mmcblk1p4' doesn't seem to have a valid NTFS.
        FUSE exf[   35.717793] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        create /dev/mmcblk1p2
        mount: mounting /dev/mmcblk1p2 on /mnt/sdcard/mmcblk1p2 failed: Invalid argument
        Failed to mount '/dev/mmcblk1p2': Invalid argument
        The device '/dev/mmcblk1p2' doesn't seem to have a valid NTFS.
        FUSE exf[   35.809262] fuseblk: Unknown parameter 'errors'
        at 1.3.0
        create /dev/mmcblk1p1
        Starting adb [   36.023002] file system registered
        Error:Input device generic ft5x06 (79) can not be found,plz check it!
        find qt5 installed done
        install_listener('tcp:5037','*smartsocket*')
        [   36.110588] read descriptors
        [   36.117537] read strings
        Welcome to MYIR
        myd-yt113-i login: [   36.537644] sunxi-mmc 4022000.sdmmc: retry:start
        [   36.542862] sunxi-mmc 4022000.sdmmc: retry:stop
        [   36.548064] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   36.553999] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   36.561094] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   36.567912] sunxi-mmc 4022000.sdmmc: retry:start
        [   36.573099] sunxi-mmc 4022000.sdmmc: retry:stop
        [   36.578252] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   36.584147] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   36.591818] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   36.598936] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   36.605750] sunxi-mmc 4022000.sdmmc: retry:start
        [   36.610947] sunxi-mmc 4022000.sdmmc: retry:stop
        [   36.616081] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   36.621955] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   36.629632] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   36.636731] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   36.643519] sunxi-mmc 4022000.sdmmc: retry:start
        [   36.648738] sunxi-mmc 4022000.sdmmc: retry:stop
        [   36.653868] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   36.659749] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   36.667417] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   36.674542] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   36.681280] 4,end
        [   37.115606]
        [   37.115606] rmmod_device_driver
        [   37.115606]
        [   37.122585] rmmod_device_driver()223 WARN: get power supply failed
        [   37.129795]
        [   37.129795] insmod_device_driver
        [   37.129795]
        device_chose finished!
        QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
        [   37.608503] [DISP] sunxi_fb_mmap,line:812:
        [   37.608509] [damon] sunxi_fb_mmap ok
        xkbcommon: ERROR: failed to add default include path /usr/share/X11/xkb
        Failed to create xkb context
        Cannot open mouse input device /dev/input/event6 (No such file or directory)
        evdevmouse: Failed to open mouse device /dev/input/event6
        sh: ./adl10-e: No such file or directory
        qml: index=0
        qml: currentIndex=0
        qml: index=0
        [   38.516199] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.521416] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.526612] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.532513] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   38.539615] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.546431] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.551620] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.556780] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.562685] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   38.569770] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.576569] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.581756] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.586894] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.592798] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   38.599880] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.606672] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.611867] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.616996] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.622900] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   38.629989] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.636778] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.641971] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.647104] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.652991] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   38.660089] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.666894] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.672081] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.677221] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.683112] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   38.690196] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.697011] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.702196] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.707364] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.713253] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   38.720341] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.727155] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.732346] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.737481] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.743383] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   38.750467] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.757257] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.762452] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.767587] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.773474] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   38.780573] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.787362] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.792558] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.797697] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.803585] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   38.810695] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.817489] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.822677] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.827833] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.833738] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   38.840823] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.847625] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.852814] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.857982] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.863887] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   38.870945] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.877746] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.882932] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.888070] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.893970] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   38.901613] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   38.908716] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.915513] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.920697] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.925841] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.931741] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   38.938829] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.945635] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.950830] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.955964] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.961863] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   38.968956] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   38.975758] sunxi-mmc 4022000.sdmmc: retry:start
        [   38.980949] sunxi-mmc 4022000.sdmmc: retry:stop
        [   38.986080] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   38.991984] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   38.999072] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.005862] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.011064] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.016200] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.022086] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   39.029182] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.035981] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.041196] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.046336] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.052229] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   39.059332] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.066128] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.071313] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.076455] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.082347] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   39.089432] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.096236] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.101423] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.106554] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.112448] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   39.120114] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   39.127207] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.134002] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.139201] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.144349] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.150222] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   39.157918] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   39.164997] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.171772] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.177007] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.182121] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.188042] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   39.195146] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.201914] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.207125] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.212259] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.218174] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   39.225261] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.232114] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.237406] sunxi-mmc 4022000.sdmmc: retry:stop
        sh: ./adl10-e_client: No such file or directory
        [   39.242633] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.252715] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   39.259868] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.266729] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.271921] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.277162] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.283098] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   39.290216] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.297105] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.302301] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.307576] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.313505] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   39.320673] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.327602] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.332806] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.337975] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.343921] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   39.350992] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.357823] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.363014] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.368157] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.374089] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   39.381151] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.387955] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.393153] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.398294] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.404196] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   39.411292] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.418083] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.423271] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.428419] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.434330] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   39.441413] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.448213] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.453398] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.458564] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.464452] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   39.472093] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   39.479206] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.486016] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.491229] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.496376] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.502268] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   39.509386] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.516180] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.521372] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.526518] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.532408] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   39.539665] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   39.547901] sunxi-mmc 4022000.sdmmc: retry:give up
        [   39.554484] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.559689] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.564844] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.570729] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   39.577810] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.584585] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.589769] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.594912] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.600799] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   39.607903] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.614712] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.619898] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.625058] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.630946] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   39.638033] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.644837] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.650027] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.655166] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.661066] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   39.668149] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.674966] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.680150] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.685285] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.691191] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   39.698279] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.705075] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.710270] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.715402] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.721289] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   39.728377] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.735173] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.740361] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.745514] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.751401] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   39.758517] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.765306] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.770492] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.775632] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.781523] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   39.788601] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.795400] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.800585] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.805722] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.811618] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   39.818700] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.825501] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.830687] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.835817] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.841729] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   39.848812] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.855603] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.860807] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.865944] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.871834] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   39.878940] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.885746] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.890960] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.896097] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.901988] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   39.909088] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.915887] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.921070] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.926209] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.932094] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   39.939176] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.945972] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.951157] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.956286] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.962180] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   39.969843] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   39.976925] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   39.983711] sunxi-mmc 4022000.sdmmc: retry:start
        [   39.988897] sunxi-mmc 4022000.sdmmc: retry:stop
        [   39.994035] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   39.999926] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   40.007013] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.013808] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.018991] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.024143] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.030030] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   40.037112] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.043911] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.049096] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.054226] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.060128] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   40.067223] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.074043] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.079229] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.084366] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.090259] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   40.097355] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.104154] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.109350] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.114482] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.120372] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   40.127466] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.134260] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.139444] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.144583] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.150453] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   40.158133] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   40.165206] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.171981] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.177197] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.182310] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.188224] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   40.195320] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.202085] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.207308] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.212438] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.218350] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   40.225429] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.232193] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.237403] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.242520] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.248429] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   40.255499] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.262275] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.267483] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.272598] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.278523] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   40.285597] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.292368] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.297576] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.302685] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.308614] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   40.315690] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.322456] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.327681] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.332803] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.338780] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   40.345939] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.352721] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.358035] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.363183] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.369170] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   40.376282] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.383073] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.388346] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.393524] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.399519] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   40.406673] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.413494] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.418735] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.423874] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.429778] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   40.436871] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.443688] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.448876] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.454011] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.459920] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   40.467012] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.473802] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.479015] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.484161] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.490037] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   40.497719] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   40.504795] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.511581] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.516791] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.521901] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.527826] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   40.534897] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.541700] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.546909] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.552025] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.557956] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   40.565203] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   40.573414] sunxi-mmc 4022000.sdmmc: retry:give up
        [   40.579992] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.585226] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.590340] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.596267] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   40.603334] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.610159] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.615360] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.620472] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.626388] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   40.633450] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.640238] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.645446] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.650555] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.656467] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   40.663532] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.670319] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.675522] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.680637] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.686555] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   40.693623] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.700433] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.705661] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.710782] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.716695] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   40.723765] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.730542] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.735751] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.740893] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.746808] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   40.753881] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.760664] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.765871] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.770983] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.776898] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   40.783980] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.790779] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.795992] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.801104] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.807032] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   40.814129] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.820895] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.826111] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.831227] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.837136] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   40.844218] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.850982] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.856190] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.861308] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.867217] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   40.874315] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.881082] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.886289] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.891419] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.897334] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   40.904418] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.911192] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.916400] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.921516] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.927448] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   40.934529] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.941319] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.946541] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.951656] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.957570] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   40.965233] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   40.972292] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   40.979093] sunxi-mmc 4022000.sdmmc: retry:start
        [   40.984290] sunxi-mmc 4022000.sdmmc: retry:stop
        [   40.989401] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   40.995298] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   41.002953] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   41.010058] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.016851] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.022036] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.027180] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.033067] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   41.040148] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.046947] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.052137] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.057268] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.063170] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   41.070257] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.077070] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.082256] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.087393] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.093295] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   41.100379] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.107185] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.112381] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.117513] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.123400] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   41.130490] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.137283] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.142479] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.147610] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.153496] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   41.160585] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.167381] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.172567] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.177703] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.183580] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   41.191271] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   41.198352] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.205160] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.210370] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.215507] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.221395] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   41.228485] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.235276] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.240460] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.245597] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.251484] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   41.258590] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.265380] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.270571] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.275714] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.281602] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   41.288679] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.295475] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.300659] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.305799] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.311710] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   41.318792] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.325592] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.330792] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.335924] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.341849] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   41.348927] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.355717] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.360920] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.366047] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.371937] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   41.379026] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.385814] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.391018] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.396151] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.402040] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   41.409138] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.415972] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.421167] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.426414] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.432343] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   41.439469] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.446306] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.451521] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.456692] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.462638] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   41.469768] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.476623] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.481818] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.487017] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.493002] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   41.500152] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.506968] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.512198] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.517357] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.523231] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   41.530919] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   41.538002] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.544819] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.550005] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.555146] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.561050] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   41.568134] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.574959] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.580146] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.585279] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.591184] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   41.598440] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   41.606664] sunxi-mmc 4022000.sdmmc: retry:give up
        [   41.613251] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.618502] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.623625] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.629555] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   41.636625] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.643399] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.648598] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.653721] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.659620] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   41.666700] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.673467] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.678707] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.683833] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.689716] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   41.696805] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.703575] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.708790] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.713911] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.719807] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   41.726892] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.733688] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.738872] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.744011] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.749901] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   41.756994] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.763798] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.768986] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.774163] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.780063] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   41.787151] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.793959] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.799146] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.804279] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.810179] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   41.817258] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.824087] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.829274] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.834408] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.840298] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   41.847387] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.854177] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.859370] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.864503] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.870389] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   41.877498] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.884301] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.889488] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.894633] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.900521] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   41.907626] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.914416] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.919600] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.924764] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.930650] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   41.937733] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.944530] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.949715] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.954843] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.960743] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   41.967842] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   41.974670] sunxi-mmc 4022000.sdmmc: retry:start
        [   41.979855] sunxi-mmc 4022000.sdmmc: retry:stop
        [   41.984992] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   41.990904] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   41.997989] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.004783] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.009983] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.015115] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.020987] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   42.028586] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   42.035661] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.042436] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.047650] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.052766] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.058696] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   42.065771] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.072539] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.077765] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.082879] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.088786] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   42.095869] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.102636] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.107870] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.112982] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.118893] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   42.125996] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.132774] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.137982] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.143112] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.149026] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   42.156099] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.162889] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.168095] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.173206] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.179140] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   42.186216] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.192991] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.198197] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.203312] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.209214] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   42.216870] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   42.223952] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.230741] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.235957] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.241100] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.246999] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   42.254655] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   42.261724] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.268516] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.273721] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.278855] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.284764] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   42.291861] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.298650] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.303848] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.308971] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.314883] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   42.321942] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.328740] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.333940] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.339061] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.344976] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   42.352037] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.358836] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.364033] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.369142] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.375080] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   42.382139] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.388928] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.394142] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.399255] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.405167] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   42.412239] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.419025] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.424264] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.429375] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.435286] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   42.442378] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.449168] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.454365] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.459483] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.465393] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   42.472452] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.479268] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.484464] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.489574] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.495488] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   42.502585] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.509463] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.514705] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.519856] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.525805] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   42.532902] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.539764] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.545014] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.550145] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.556113] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   42.563847] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   42.570937] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.577807] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.583001] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.588151] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.594070] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   42.601136] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.607957] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.613147] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.618284] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.624237] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   42.631469] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   42.639701] sunxi-mmc 4022000.sdmmc: retry:give up
        [   42.655009] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.660224] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.665401] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.671300] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   42.678403] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.685211] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.690395] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.695540] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.701428] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   42.708564] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.715365] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.720551] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.725714] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.731600] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   42.738697] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.745507] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.750695] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.755830] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.761726] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   42.768807] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.775606] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.780792] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.785922] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.791833] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   42.798920] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.805705] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.810899] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.816036] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.821924] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   42.829023] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.835827] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.841039] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.846183] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.852068] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   42.859160] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.865949] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.871134] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.876275] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.882163] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   42.889247] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.896047] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.901233] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.906366] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.912262] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   42.919346] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.926141] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.931330] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.936472] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.942368] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   42.949459] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.956262] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.961456] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.966589] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   42.972479] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   42.979574] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   42.986364] sunxi-mmc 4022000.sdmmc: retry:start
        [   42.991576] sunxi-mmc 4022000.sdmmc: retry:stop
        [   42.996709] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.002597] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   43.009687] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.016482] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.021666] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.026804] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.032674] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   43.040349] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   43.047430] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.054223] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.059423] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.064565] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.070436] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   43.078019] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   43.085111] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.091896] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.097105] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.102229] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.108163] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   43.115240] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.122006] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.127222] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.132333] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.138243] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   43.145338] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.152105] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.157317] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.162453] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.168362] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   43.175457] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.182221] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.187428] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.192551] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.198459] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   43.205533] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.212307] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.217516] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.222627] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.228557] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   43.235634] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.242410] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.247618] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.252728] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.258649] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   43.266304] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   43.273363] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.280161] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.285360] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.290469] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.296387] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   43.303447] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.310243] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.315438] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.320552] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.326469] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   43.333540] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.340326] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.345538] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.350645] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.356554] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   43.363694] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.370465] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.375679] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.380794] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.386702] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   43.393785] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.400549] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.405756] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.410879] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.416787] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   43.423857] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.430632] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.435837] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.440982] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.446890] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   43.453965] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.460756] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.465967] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.471079] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.476994] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   43.484064] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.490849] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.496061] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.501171] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.507077] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   43.514155] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.520921] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.526133] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.531243] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.537149] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   43.544230] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.550998] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.556205] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.561333] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.567250] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   43.574394] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.581175] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.586458] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.591648] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.597575] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   43.605250] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   43.612342] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.619213] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.624494] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.629651] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.635628] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   43.642753] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.649586] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.654805] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.659962] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.665883] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   43.673138] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   43.681389] sunxi-mmc 4022000.sdmmc: retry:give up
        [   43.687017] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [   43.704769] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.726209] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.748179] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.759998] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.775167] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.810094] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   43.823040] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   43.833116] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   43.842927] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   43.852895] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   43.863446] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
        [   43.878727] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [   43.890423] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [   43.903188] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.908435] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.913549] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.919450] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   43.926524] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.933291] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.938484] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.943596] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.949490] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   43.956565] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.963331] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.968526] sunxi-mmc 4022000.sdmmc: retry:stop
        [   43.973629] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   43.979540] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   43.986605] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   43.993371] sunxi-mmc 4022000.sdmmc: retry:start
        [   43.998564] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.003677] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.009571] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   44.016635] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.023397] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.028598] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.033715] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.039607] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   44.046686] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.053452] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.058662] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.063784] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.069666] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   44.076740] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.083511] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.088706] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.093824] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.099708] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   44.106799] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.113579] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.118792] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.123928] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.129823] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   44.136908] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.143708] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.148895] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.154054] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.159952] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   44.167037] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.173827] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.179022] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.184159] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.190054] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   44.197147] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.203936] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.209131] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.214261] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.220148] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   44.227244] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.234040] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.239229] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.244384] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.250269] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   44.257379] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.264169] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.269354] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.274501] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.280374] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   44.287951] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   44.295044] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.301808] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.307015] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.312134] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.318026] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   44.325612] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   44.332680] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.339465] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.344671] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.349779] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.355688] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   44.362751] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.369547] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.374771] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.379884] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.385796] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   44.392879] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.399678] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.404886] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.410004] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.415917] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   44.422974] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.429772] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.434969] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.440080] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.445993] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   44.453055] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.459857] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.465056] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.470171] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.476083] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   44.483141] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.489927] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.495159] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.500280] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.506179] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   44.513855] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   44.520916] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.527711] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.532898] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.538027] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.543937] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   44.550994] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.557807] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.562992] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.568122] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.574049] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   44.581108] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.587896] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.593094] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.598229] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.604129] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   44.611206] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.617994] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.623179] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.628321] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.634228] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   44.641307] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.648096] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.653306] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.658522] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.664464] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   44.671540] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.678434] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.683650] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.688835] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.694853] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   44.701982] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.708878] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.714086] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.719214] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.725234] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   44.732350] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.739190] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.744415] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.749538] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.755458] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   44.762539] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.769352] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.774587] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.779703] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.785613] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   44.792687] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.799478] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.804684] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.809822] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.815724] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   44.823368] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   44.830475] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.837269] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.842472] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.847607] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.853484] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   44.861157] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   44.868233] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.875047] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.880237] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.885370] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.891283] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   44.898371] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.905169] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.910376] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.915508] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.921395] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   44.928659] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   44.936881] sunxi-mmc 4022000.sdmmc: retry:give up
        [   44.942477] blk_update_request: I/O error, dev mmcblk0, sector 642286 op 0x0:(READ) flags 0x80700 phys_seg 12 prio class 0
        [   44.955787] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.960999] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.966166] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   44.972063] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   44.979157] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   44.985950] sunxi-mmc 4022000.sdmmc: retry:start
        [   44.991164] sunxi-mmc 4022000.sdmmc: retry:stop
        [   44.996300] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.002189] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   45.009303] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.016086] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.021274] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.026418] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.032306] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   45.039374] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.046165] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.051349] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.056479] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.062376] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   45.069456] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.076269] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.081459] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.086594] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.092513] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   45.099586] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.106373] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.111587] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.116725] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.122613] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   45.129696] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.136477] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.141691] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.146824] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.152712] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   45.159804] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.166590] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.171774] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.176926] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.182813] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   45.189884] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.196674] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.201864] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.206999] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.212912] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   45.219985] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.226792] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.231978] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.237110] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.243015] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   45.250089] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.256866] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.262072] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.267206] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.273094] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   45.280171] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.286955] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.292161] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.297293] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.303180] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   45.310259] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.317044] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.322230] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.327367] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.333275] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   45.340349] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.347145] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.352330] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.357509] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.363385] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   45.370953] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   45.378040] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.384824] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.390008] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.395149] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.401036] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   45.408131] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.414914] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.420114] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.425261] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.431150] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   45.438217] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.445007] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.450189] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.455320] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.461230] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   45.468304] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.475102] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.480288] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.485419] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.491326] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   45.498399] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.505180] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.510373] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.515504] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.521403] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   45.528490] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.535269] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.540454] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.545588] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.551470] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   45.559151] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   45.566212] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.572969] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.578182] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.583292] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.589202] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   45.596277] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.603033] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.608271] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.613382] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.619293] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   45.626371] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.633130] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.638339] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.643460] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.649366] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   45.656428] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.663204] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.668412] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.673523] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.679446] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   45.686505] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.693269] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.698476] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.703586] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.709498] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   45.716559] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.723317] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.728536] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.733645] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.739597] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   45.746765] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.753540] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.758850] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.764015] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.769953] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   45.777111] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.783950] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.789164] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.794360] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.800290] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   45.807509] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.814342] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.819536] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.824728] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.830641] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   45.837733] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.844535] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.849726] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.854863] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.860760] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   45.868438] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   45.875528] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.882290] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.887501] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.892628] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.898520] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   45.906077] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   45.913136] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.919918] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.925140] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.930252] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.936168] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   45.943234] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   45.950013] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.955209] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.960338] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   45.966247] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   45.973480] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   45.981725] sunxi-mmc 4022000.sdmmc: retry:give up
        [   45.987646] sunxi-mmc 4022000.sdmmc: retry:start
        [   45.992852] sunxi-mmc 4022000.sdmmc: retry:stop
        [   45.998002] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.003916] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   46.010982] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.017774] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.022962] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.028108] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.034017] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   46.041109] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.047897] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.053082] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.058267] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.064172] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   46.071225] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.078020] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.083208] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.088340] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.094253] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   46.101302] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.108103] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.113289] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.118434] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.124386] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   46.131439] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.138218] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.143425] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.148561] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.154464] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   46.161524] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.168306] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.173488] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.178630] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.184529] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   46.191598] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.198403] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.203594] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.208738] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.214645] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   46.221694] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.228488] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.233684] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.238794] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.244718] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   46.251773] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.258576] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.263776] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.268891] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.274823] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   46.281882] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.288666] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.293884] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.298997] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.304915] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   46.311973] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.318755] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.323953] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.329071] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.334994] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   46.342056] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.348852] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.354054] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.359170] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.365081] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   46.372129] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.378928] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.384129] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.389237] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.395144] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   46.402785] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   46.409866] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.416647] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.421839] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.426989] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.432875] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   46.439947] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.446735] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.451930] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.457061] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.462963] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   46.470042] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.476841] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.482027] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.487157] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.493053] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   46.500132] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.506922] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.512119] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.517252] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.523140] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   46.530219] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.537006] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.542197] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.547328] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.553229] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   46.560306] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.567085] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.572270] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.577404] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.583278] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   46.590965] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   46.598042] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.604823] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.610023] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.615154] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.621047] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   46.628124] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.634910] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.640093] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.645234] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.651119] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   46.658218] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.664998] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.670185] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.675323] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.681211] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   46.688283] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.695079] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.700262] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.705392] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.711287] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   46.718359] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.725155] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.730344] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.735474] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.741366] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   46.749032] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   46.756097] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.762873] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.768084] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.773197] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.779114] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   46.786177] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.792941] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.798153] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.803262] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.809178] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   46.816281] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.823050] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.828347] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.833474] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.839447] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   46.846620] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.853397] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.858689] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.863847] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.869736] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   46.876907] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.883741] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.888952] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.894160] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.900037] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   46.907756] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   46.914831] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.921598] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.926815] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.931930] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.937851] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   46.944942] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.951703] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.956916] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.962037] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.967959] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   46.975050] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   46.981809] sunxi-mmc 4022000.sdmmc: retry:start
        [   46.987019] sunxi-mmc 4022000.sdmmc: retry:stop
        [   46.992148] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   46.998068] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   47.005323] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   47.013540] sunxi-mmc 4022000.sdmmc: retry:give up
        [   47.019464] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.024710] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.029828] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.035736] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.043393] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   47.050476] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.057265] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.062464] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.067602] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.073509] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   47.080597] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.087383] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.092577] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.097736] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.103625] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   47.110709] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.117491] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.122680] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.127818] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.133721] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   47.140794] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.147582] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.152767] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.157932] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.163847] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   47.170901] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.177703] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.182891] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.188025] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.193946] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   47.200995] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.207795] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.212986] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.218122] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.224047] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   47.231097] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.237876] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.243072] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.248205] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.254110] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   47.261165] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.267947] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.273132] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.278298] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.284197] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   47.291286] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.298071] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.303257] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.308423] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.314330] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   47.321378] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.328177] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.333374] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.338509] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.344422] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   47.351471] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.358269] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.363456] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.368586] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.374507] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   47.381568] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.388351] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.393547] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.398680] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.404583] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   47.411660] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.418436] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.423624] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.428781] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.434664] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.442314] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   47.449387] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.456166] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.461367] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.466498] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.472389] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   47.479468] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.486254] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.491464] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.496595] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.502484] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   47.509572] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.516358] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.521542] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.526681] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.532566] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   47.539637] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.546421] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.551608] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.556734] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.562634] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   47.569704] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.576491] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.581674] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.586809] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.592705] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   47.599778] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.606557] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.611763] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.616893] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.622766] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.630441] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   47.637500] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.644290] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.649477] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.654606] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.660501] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   47.667570] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.674372] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.679559] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.684689] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.690578] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.698246] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   47.705311] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.712086] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.717294] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.722405] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.728320] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   47.735384] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.742152] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.747358] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.752469] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.758404] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   47.765464] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.772221] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.777437] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.782547] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.788454] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   47.795531] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.802288] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.807525] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.812634] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.818542] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   47.825615] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.832371] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.837577] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.842694] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.848600] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   47.855658] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.862426] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.867633] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.872745] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.878658] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   47.885738] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.892562] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.897804] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.902953] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.908934] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   47.916062] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.922858] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.928160] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.933289] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.939246] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.946939] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   47.954080] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.960898] sunxi-mmc 4022000.sdmmc: retry:start
        [   47.966175] sunxi-mmc 4022000.sdmmc: retry:stop
        [   47.971304] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   47.977235] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   47.984895] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   47.991965] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   47.998763] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.003964] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.009108] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.015030] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   48.022085] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.028892] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.034093] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.039208] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.045136] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   48.052374] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   48.060626] sunxi-mmc 4022000.sdmmc: retry:give up
        [   48.066537] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.071730] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.076907] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.082806] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   48.089900] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.096698] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.101894] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.107038] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.112936] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   48.120012] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.126807] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.131993] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.137124] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.143022] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   48.150096] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.156879] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.162071] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.167206] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.173094] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   48.180174] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.186958] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.192153] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.197296] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.203202] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   48.210296] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.217087] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.222271] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.227412] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.233299] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   48.240380] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.247167] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.252354] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.257520] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.263410] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   48.270482] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.277273] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.282458] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.287591] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.293488] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   48.300566] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.307394] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.312584] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.317728] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.323614] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   48.330736] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.337519] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.342722] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.347858] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.353758] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   48.360817] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.367597] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.372781] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.377927] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.383833] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   48.390911] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.397689] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.402876] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.408047] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.413949] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   48.420996] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.427783] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.432970] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.438099] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.443994] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   48.451538] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   48.458625] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.465407] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.470591] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.475734] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.481603] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   48.489169] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   48.496240] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.502998] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.508242] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.513353] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.519264] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   48.526343] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.533100] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.538308] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.543428] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.549339] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   48.556399] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.563170] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.568375] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.573521] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.579445] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   48.586509] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.593290] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.598496] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.603607] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.609553] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   48.616617] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.623375] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.628589] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.633722] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.639607] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   48.646696] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.653463] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.658682] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.663805] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.669677] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   48.677347] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   48.684410] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.691199] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.696412] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.701524] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.707467] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   48.714537] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.721295] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.726509] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.731622] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.737533] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   48.744606] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.751362] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.756576] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.761695] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.767605] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   48.774706] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.781470] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.786676] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.791810] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.797718] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   48.804782] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.811559] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.816772] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.821881] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.827804] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   48.834865] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.841645] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.846852] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.851967] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.857899] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   48.864966] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.871726] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.876947] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.882058] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.887966] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   48.895042] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.901798] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.907005] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.912152] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.918069] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   48.925164] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.931923] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.937128] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.942249] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.948156] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   48.955218] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.961987] sunxi-mmc 4022000.sdmmc: retry:start
        [   48.967194] sunxi-mmc 4022000.sdmmc: retry:stop
        [   48.972303] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   48.978265] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   48.985980] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   48.993075] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   48.999942] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.005187] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.010396] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.016311] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   49.023904] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   49.030985] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.037829] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.043049] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.048263] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.054179] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   49.061265] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.068104] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.073300] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.078467] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.084376] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   49.091650] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   49.099887] sunxi-mmc 4022000.sdmmc: retry:give up
        [   49.105845] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.111054] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.116222] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.122121] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   49.129226] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.136021] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.141233] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.146372] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.152260] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   49.159362] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.166154] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.171340] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.176483] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.182372] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   49.189447] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.196237] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.201421] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.206561] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.212457] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   49.219536] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.226320] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.231517] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.236654] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.242553] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   49.249626] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.256412] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.261610] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.266750] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.272637] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   49.279718] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.286499] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.291712] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.296846] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.302736] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   49.309829] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.316613] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.321798] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.326941] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.332849] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   49.339923] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.346715] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.351904] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.357035] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.362933] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   49.370004] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.376801] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.381989] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.387121] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.393036] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   49.400116] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.406899] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.412112] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.417252] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.423142] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   49.430228] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.437023] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.442218] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.447348] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.453234] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   49.460316] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.467095] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.472281] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.477415] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.483307] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   49.490377] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.497169] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.502353] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.507525] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.513398] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   49.521062] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   49.528154] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.534935] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.540132] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.545279] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.551168] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   49.558266] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.565048] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.570238] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.575410] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.581299] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   49.588368] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.595160] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.600344] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.605474] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.611389] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   49.618461] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.625253] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.630439] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.635564] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.641492] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   49.648571] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.655354] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.660561] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.665692] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.671581] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   49.678665] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.685444] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.690630] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.695767] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.701643] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   49.709323] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   49.716385] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.723145] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.728362] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.733473] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.739382] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   49.746462] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.753219] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.758445] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.763559] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.769467] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   49.776544] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.783301] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.788509] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.793643] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.799557] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   49.806625] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.813408] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.818615] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.823738] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.829644] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   49.836715] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.843481] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.848694] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.853815] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.859712] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   49.866780] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.873544] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.878757] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.883879] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.889763] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   49.896839] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.903594] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.908828] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.913949] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.919837] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   49.926914] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.933694] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.938877] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.944016] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.949913] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   49.956984] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.963772] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.968958] sunxi-mmc 4022000.sdmmc: retry:stop
        [   49.974106] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   49.979995] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   49.987066] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   49.993853] sunxi-mmc 4022000.sdmmc: retry:start
        [   49.999037] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.004167] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.010062] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   50.017725] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   50.024807] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.031566] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.036773] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.041905] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.047798] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   50.055368] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   50.062446] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.069288] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.074569] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.079720] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.085709] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   50.092819] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.099628] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.104870] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.110041] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.116027] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   50.123274] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   50.131595] sunxi-mmc 4022000.sdmmc: retry:give up
        [   50.137220] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
        [   50.151180] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.174991] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.199287] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.211031] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.225899] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.264603] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
        [   50.277371] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   50.287168] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   50.297215] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   50.307022] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
        [   50.317713] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
        [   50.332979] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [   50.344666] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS200 dt B
        [   50.357017] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.362224] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.367385] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.373271] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   50.380341] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.387107] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.392297] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.397414] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.403307] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   50.410378] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.417143] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.422325] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.427447] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.433328] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   50.440384] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.447157] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.452342] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.457484] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.463368] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   50.470432] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.477202] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.482384] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.487502] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.493391] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   50.500461] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.507237] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.512432] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.517550] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.523434] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   50.530500] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.537266] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.542454] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.547571] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.553452] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   50.560515] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.567310] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.572512] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.577656] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.583547] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   50.590629] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.597422] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.602608] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.607781] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.613689] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   50.620742] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.627537] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.632722] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.637855] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.643764] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   50.650814] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.657611] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.662801] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.667933] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.673852] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   50.680910] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.687690] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.692882] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.698012] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.703913] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   50.710971] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.717750] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.722935] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.728072] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.733994] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   50.741064] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.747854] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.753039] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.758191] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.764075] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   50.771714] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   50.778797] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.785579] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.790786] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.795917] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.801805] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   50.808885] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.815672] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.820859] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.825995] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.831884] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   50.838960] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.845763] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.850947] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.856078] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.861973] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   50.869042] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.875829] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.881027] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.886156] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.892051] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   50.899124] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.905903] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.911097] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.916225] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.922115] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   50.929193] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.935979] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.941185] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.946324] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.952196] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   50.959869] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   50.966935] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   50.973715] sunxi-mmc 4022000.sdmmc: retry:start
        [   50.978908] sunxi-mmc 4022000.sdmmc: retry:stop
        [   50.984048] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   50.989934] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   50.997012] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.003797] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.008989] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.014127] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.020012] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   51.027093] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.033871] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.039056] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.044195] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.050086] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   51.057167] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.063964] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.069148] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.074309] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.080197] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   51.087298] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.094134] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.099351] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.104518] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.110433] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   51.117520] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.124347] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.129533] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.134673] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.140567] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   51.147664] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.154484] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.159694] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.164926] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.170853] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   51.178000] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.184833] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.190068] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.195268] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.201194] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   51.208349] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.215151] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.220374] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.225564] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.231472] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   51.238597] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.245431] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.250618] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.255761] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.261646] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   51.269315] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   51.276394] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.283154] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.288361] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.293502] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.299398] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   51.307061] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   51.314157] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.320929] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.326154] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.331282] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.337194] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   51.344278] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.351037] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.356241] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.361368] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.367275] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   51.374551] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   51.382761] sunxi-mmc 4022000.sdmmc: retry:give up
        [   51.388387] blk_update_request: I/O error, dev mmcblk0, sector 642374 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [   51.400752] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.405996] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.411135] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.417070] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   51.424171] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.430935] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.436149] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.441287] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.447205] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   51.454272] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.461041] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.466250] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.471358] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.477277] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   51.484339] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.491122] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.496330] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.501454] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.507387] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   51.514479] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.521235] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.526450] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.531561] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.537475] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   51.544548] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.551304] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.556518] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.561639] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.567558] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   51.574648] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.581409] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.586617] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.591745] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.597664] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   51.604738] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.611504] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.616717] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.621832] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.627747] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   51.634811] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.641590] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.646798] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.651909] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.657835] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   51.664903] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.671660] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.676872] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.681983] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.687894] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   51.694979] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.701735] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.706949] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.712079] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.718005] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   51.725089] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.731848] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.737056] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.742175] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.748084] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   51.755156] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.761920] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.767129] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.772240] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.778141] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   51.785793] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   51.792849] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.799635] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.804833] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.809960] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.815866] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   51.823506] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   51.830587] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.837360] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.842556] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.847686] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.853574] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   51.860652] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.867434] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.872617] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.877751] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.883642] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   51.890737] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.897515] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.902701] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.907850] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.913766] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   51.920812] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.927604] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.932788] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.937918] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.943821] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   51.950870] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.957668] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.962855] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.967986] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   51.973890] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   51.980946] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   51.987727] sunxi-mmc 4022000.sdmmc: retry:start
        [   51.992918] sunxi-mmc 4022000.sdmmc: retry:stop
        [   51.998050] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.003933] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   52.011582] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   52.018668] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.025461] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.030645] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.035777] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.041683] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   52.048757] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.055544] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.060746] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.065880] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.071772] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   52.078855] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.085637] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.090844] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.095978] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.101867] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   52.108951] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.115740] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.120937] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.126082] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.131973] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   52.139044] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.145837] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.151021] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.156151] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.162046] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   52.169117] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.175910] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.181099] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.186229] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.192144] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   52.199217] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.206011] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.211210] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.216346] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.222250] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   52.229348] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.236168] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.241409] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.246608] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.252511] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   52.259681] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.266541] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.271753] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.276944] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.282873] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   52.289984] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.296842] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.302061] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.307287] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.313194] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   52.320926] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   52.328079] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.334883] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.340074] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.345228] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.351101] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   52.358775] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   52.365846] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.372606] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.377831] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.382939] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.388847] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   52.395918] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.402677] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.407920] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.413035] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.418926] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   52.426600] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   52.433858] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   52.442081] sunxi-mmc 4022000.sdmmc: retry:give up
        [   52.448004] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.453201] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.458402] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.464311] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   52.471364] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.478159] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.483347] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.488481] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.494416] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   52.501471] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.508277] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.513464] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.518608] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.524552] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   52.531603] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.538402] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.543598] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.548735] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.554635] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   52.561695] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.568475] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.573684] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.578800] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.584713] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   52.591786] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.598567] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.603765] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.608886] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.614795] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   52.621849] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.628659] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.633873] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.638981] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.644909] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   52.651960] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.658750] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.663946] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.669056] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.674992] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   52.682044] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.688822] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.694030] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.699140] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.705050] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   52.712108] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.718892] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.724121] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.729234] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.735143] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   52.742204] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.748990] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.754192] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.759313] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.765223] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   52.772273] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.779078] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.784276] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.789389] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.795308] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   52.802361] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.809150] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.814348] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.819457] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.825381] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   52.832430] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.839210] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.844423] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.849532] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.855428] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   52.862983] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   52.870054] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.876843] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.882029] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.887158] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.893057] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   52.900132] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.906911] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.912117] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.917245] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.923134] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   52.930225] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.937013] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.942207] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.947337] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.953222] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   52.960309] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.967089] sunxi-mmc 4022000.sdmmc: retry:start
        [   52.972275] sunxi-mmc 4022000.sdmmc: retry:stop
        [   52.977414] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   52.983302] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   52.990370] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   52.997159] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.002342] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.007494] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.013380] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   53.020455] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.027250] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.032436] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.037563] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.043445] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   53.051106] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   53.058198] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.064989] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.070178] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.075333] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.081223] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   53.088295] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.095088] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.100273] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.105405] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.111307] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   53.118377] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.125187] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.130375] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.135505] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.141415] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   53.148487] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.155273] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.160476] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.165612] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.171499] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   53.178599] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.185380] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.190567] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.195728] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.201614] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   53.208705] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.215485] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.220668] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.225816] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.231710] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   53.238783] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.245586] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.250772] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.255903] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.261803] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   53.268883] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.275682] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.280869] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.286005] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.291923] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   53.298994] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.305775] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.310970] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.316106] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.322031] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   53.329198] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.336057] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.341300] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.346516] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.352422] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   53.360150] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   53.367254] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.374122] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.379341] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.384529] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.390426] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   53.398061] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   53.405141] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.411920] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.417136] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.422251] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.428194] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   53.435259] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.442029] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.447242] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.452355] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.458315] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   53.465564] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   53.473800] sunxi-mmc 4022000.sdmmc: retry:give up
        [   53.479700] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.484945] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.490068] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.496022] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   53.503089] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.509888] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.515087] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.520201] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.526118] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   53.533168] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.539949] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.545162] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.550269] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.556180] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   53.563238] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.570018] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.575244] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.580368] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.586280] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   53.593342] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.600131] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.605336] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.610455] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.616375] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   53.623429] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.630228] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.635431] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.640542] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.646479] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   53.653537] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.660334] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.665534] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.670647] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.676571] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   53.683635] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.690420] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.695636] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.700747] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.706655] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   53.713726] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.720486] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.725704] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.730814] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.736730] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   53.743813] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.750572] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.755779] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.760907] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.766822] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   53.773884] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.780650] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.785862] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.791002] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.796929] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   53.803990] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.810760] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.815969] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.821081] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.826995] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   53.834060] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.840835] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.846046] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.851161] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.857067] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   53.864740] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   53.871794] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.878597] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.883798] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.888935] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.894852] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   53.902397] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   53.909481] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.916261] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.921447] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.926583] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.932469] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   53.939542] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.946338] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.951522] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.956652] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.962548] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   53.969620] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   53.976406] sunxi-mmc 4022000.sdmmc: retry:start
        [   53.981594] sunxi-mmc 4022000.sdmmc: retry:stop
        [   53.986723] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   53.992633] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   53.999704] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.006483] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.011686] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.016818] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.022704] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   54.029787] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.036565] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.041774] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.046904] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.052796] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   54.059882] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.066667] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.071855] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.077001] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.082872] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   54.090537] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   54.097620] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.104403] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.109608] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.114747] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.120633] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   54.127722] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.134504] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.139689] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.144826] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.150714] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   54.157822] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.164605] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.169789] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.174952] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.180824] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   54.188489] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   54.195577] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.202353] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.207589] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.212707] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.218605] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   54.225677] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.232433] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.237641] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.242764] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.248672] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   54.255732] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.262498] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.267706] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.272816] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.278733] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   54.285798] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.292567] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.297776] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.302887] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.308828] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   54.315900] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.322659] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.327885] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.333014] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.338927] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   54.346006] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.352764] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.357995] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.363106] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.369015] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   54.376088] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.382847] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.388051] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.393220] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.399137] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   54.406823] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   54.413999] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.420789] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.426081] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.431215] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.437169] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   54.444917] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   54.452001] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.458842] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.464083] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.469241] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.475233] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   54.482299] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.489098] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.494312] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.499430] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.505343] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   54.512588] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   54.520831] sunxi-mmc 4022000.sdmmc: retry:give up
        [   54.529981] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.535210] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.540337] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.546278] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   54.553341] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.560142] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.565340] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.570454] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.576379] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   54.583431] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.590213] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.595438] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.600550] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.606461] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   54.613519] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.620292] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.625503] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.630615] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.636524] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   54.643585] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.650364] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.655586] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.660706] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.666626] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   54.673695] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.680467] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.685674] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.690819] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.696742] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   54.703809] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.710575] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.715784] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.720895] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.726823] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   54.733893] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.740649] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.745878] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.750992] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.756899] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   54.763971] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.770731] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.775946] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.781056] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.786970] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   54.794061] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.800822] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.806031] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.811159] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.817069] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   54.824156] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.830924] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.836134] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.841262] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.847175] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   54.854250] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.861018] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.866227] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.871337] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.877237] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   54.884892] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   54.891947] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.898738] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.903936] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.909056] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.914970] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   54.922023] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.928821] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.934040] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.939150] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.945054] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   54.952597] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   54.959678] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.966458] sunxi-mmc 4022000.sdmmc: retry:start
        [   54.971644] sunxi-mmc 4022000.sdmmc: retry:stop
        [   54.976779] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   54.982668] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   54.989742] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   54.996539] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.001724] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.006855] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.012751] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   55.019825] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.026612] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.031805] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.036940] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.042840] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   55.049917] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.056715] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.061909] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.067046] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.072938] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   55.080023] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.086807] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.092002] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.097142] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.103032] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   55.110114] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.116899] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.122084] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.127221] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.133091] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   55.140789] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   55.147854] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.154635] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.159830] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.164975] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.170863] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   55.177954] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.184749] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.189936] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.195085] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.200974] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   55.208071] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.214852] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.220037] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.225186] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.231073] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   55.238145] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.244941] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.250130] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.255256] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.261157] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   55.268227] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.275031] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.280216] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.285348] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.291260] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   55.298333] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.305118] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.310325] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.315455] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.321344] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   55.328439] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.335228] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.340411] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.345565] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.351452] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   55.358548] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.365334] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.370519] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.375656] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.381544] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   55.388620] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.395410] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.400594] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.405722] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.411629] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   55.418701] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.425492] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.430678] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.435802] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.441705] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   55.449365] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   55.456427] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.463193] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.468400] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.473545] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.479482] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   55.487201] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   55.494328] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.501104] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.506370] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.511562] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.517554] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   55.524689] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.531459] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.536740] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.541954] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.547944] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   55.555211] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   55.563444] sunxi-mmc 4022000.sdmmc: retry:give up
        [   55.569479] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.574740] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.579863] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.585786] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   55.592856] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.599658] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.604875] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.609996] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.615909] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   55.622958] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.629753] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.634967] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.640079] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.645999] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   55.653051] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.659847] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.665048] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.670157] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.676081] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   55.683138] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.689924] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.695138] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.700252] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.706162] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   55.713239] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.720025] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.725247] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.730366] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.736278] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   55.743342] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.750127] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.755324] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.760446] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.766361] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   55.773417] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.780215] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.785414] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.790522] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.796437] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   55.803489] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.810278] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.815478] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.820589] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.826512] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   55.833563] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.840344] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.845567] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.850677] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.856588] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   55.863677] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.870448] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.875676] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.880790] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.886699] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   55.893781] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.900538] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.905750] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.910871] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.916784] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   55.923842] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.930609] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.935814] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.940954] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.946848] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   55.954404] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   55.961460] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   55.968238] sunxi-mmc 4022000.sdmmc: retry:start
        [   55.973436] sunxi-mmc 4022000.sdmmc: retry:stop
        [   55.978587] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   55.984470] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   55.992028] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   55.999104] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.005886] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.011094] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.016224] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.022111] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   56.029194] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.035974] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.041183] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.046316] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.052209] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   56.059294] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.066077] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.071261] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.076417] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.082311] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   56.089386] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.096174] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.101360] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.106485] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.112383] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   56.119452] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.126252] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.131437] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.136568] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.142465] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   56.149540] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.156316] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.161512] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.166643] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.172515] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   56.180205] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   56.187272] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.194086] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.199276] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.204410] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.210323] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   56.217397] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.224205] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.229391] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.234523] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.240412] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   56.247495] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.254277] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.259474] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.264604] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.270491] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   56.277583] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.284375] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.289560] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.294700] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.300589] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   56.307685] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.314470] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.319658] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.324815] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.330716] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   56.337785] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.344579] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.349763] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.354893] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.360794] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   56.367866] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.374672] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.379859] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.384996] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.390913] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   56.397985] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.404765] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.409958] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.415089] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.420975] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   56.428062] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.434841] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.440024] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.445160] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.451047] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   56.458139] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.464917] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.470104] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.475267] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.481143] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   56.488813] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   56.495886] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.502643] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.507866] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.512976] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.518870] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   56.526433] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   56.533483] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.540258] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.545465] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.550600] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.556587] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   56.563707] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.570499] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.575758] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.580910] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.586892] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   56.594212] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   56.602451] sunxi-mmc 4022000.sdmmc: retry:give up
        [   56.608504] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.613756] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.618889] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.624861] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
        [   56.631926] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.638724] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.643937] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.649062] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.654974] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
        [   56.662036] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.668820] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.674064] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.679179] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.685098] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
        [   56.692164] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.698957] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.704155] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.709274] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.715184] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
        [   56.722235] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.729024] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.734233] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.739343] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.745289] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
        [   56.752340] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.759141] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.764339] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.769454] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.775371] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
        [   56.782432] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.789214] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.794413] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.799523] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.805429] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
        [   56.812487] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.819283] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.824513] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.829624] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.835534] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
        [   56.842593] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.849372] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.854570] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.859687] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.865604] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
        [   56.872654] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.879454] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.884670] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.889782] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.895697] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
        [   56.902748] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.909546] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.914747] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.919857] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.925776] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
        [   56.932827] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.939609] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.944833] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.949944] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.955939] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
        [   56.963026] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   56.969868] sunxi-mmc 4022000.sdmmc: retry:start
        [   56.975117] sunxi-mmc 4022000.sdmmc: retry:stop
        [   56.980246] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   56.986142] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   56.993827] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
        [   57.000891] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.007717] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.012922] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.018060] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.023945] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   57.031611] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
        [   57.038690] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.045486] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.050671] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.055801] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.061718] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
        [   57.068795] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.075585] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.080772] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.085906] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.091825] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
        [   57.098900] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.105682] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.110877] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.116015] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.121902] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
        [   57.128995] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.135775] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.141007] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.146143] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.152037] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
        [   57.159135] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.165923] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.171111] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.176262] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.182151] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
        [   57.189225] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.196014] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.201201] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.206328] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.212210] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   57.219883] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
        [   57.226962] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.233742] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.238933] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.244071] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.249958] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
        [   57.257035] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.263845] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.269030] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.274188] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.280077] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
        [   57.287150] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.293940] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.299126] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.304256] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.310155] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
        [   57.317226] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.324035] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.329221] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.334364] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.340252] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
        [   57.347335] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.354115] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.359308] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.364437] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.370324] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
        [   57.377413] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.384199] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.389389] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.394536] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.400425] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
        [   57.407520] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.414301] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.419485] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.424642] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.430530] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
        [   57.437606] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.444401] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.449584] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.454713] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.460613] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
        [   57.467683] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.474490] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.479680] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.484812] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.490720] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
        [   57.497789] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.504569] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.509762] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.514892] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.520766] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 100
        [   57.528443] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
        [   57.535506] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.542273] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.547479] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.552590] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.558500] sunxi-mmc 4022000.sdmmc: send  manual stop command failed 42
        [   57.566059] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
        [   57.573107] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.579905] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.585102] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.590210] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.596124] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
        [   57.603174] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
        [   57.609963] sunxi-mmc 4022000.sdmmc: retry:start
        [   57.615161] sunxi-mmc 4022000.sdmmc: retry:stop
        [   57.620269] sunxi-mmc 4022000.sdmmc: retry:stop recover
        [   57.626187] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
        [   57.633431] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
        [   57.641685] sunxi-mmc 4022000.sdmmc: retry:give up
        [   57.647252] blk_update_request: I/O error, dev mmcblk0, sector 642374 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
        [   57.813523] [DISP] sunxi_fb_release,line:567:
        [   57.813529] [damon] sunxi_fb_release
        这里是log信息,可以看到disp部分dma分配到最后开始地址dma_addr却是0,有大佬知道为什么吗😟
