    T527系统不断重启,貌似是电源管理芯片的问题,如何解决?
    • K
      Kamila LV 3 最后由 编辑
      U-Boot 2018.07-ga42aebb (Jan 29 2024 - 02:25:02 +0000) Allwinner Technology
      [00.417]CPU:   Allwinner Family
      [00.420]Model: sun55iw3
      I2C:   ready
      [00.430]DRAM:  2 GiB
      [00.435]Relocation Offset is: 75e98000
      [00.484]secure enable bit: 0
      [00.488]PMU: AXP2202
      [00.490]BMU: AXP2202
      [00.492][AXP2202] comm status : 0x0 = 0x20, 0x1 = 0x90
      [00.497][AXP2202] onoff status: 0x20 = 0x0, 0x21 = 0x0
      [00.501][AXP2202] reboot/charge status: 0xf0 = 0x0
      [00.512]PMU: AXP1530
      [00.515]CPU=1296 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=600Mhz
      [00.521]gic: sec monitor mode
      [00.560]flash init start
      [00.562]workmode = 0,storage type = 2
      [00.565][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
      [00.572][mmc]: SUNXI SDMMC Controller Version:0x50500
      [00.596][mmc]: Best spd md: 4-HS400, freq: 4-150000000, Bus width: 8
      [00.602]sunxi flash init ok
      do not runing  scanning usb for storage devices ...
      no usb storage device detect!
      [00.622]drv_disp_init
      [00.667]boot-resource is not found!
      ** Unable to read file disp_config.ini **
      pwm_request: err:this pwm has been requested!
      [EDP_INFO]: edp0 probe start!
      [EDP_INFO]: g_edp_info[sel].irq = 176
      [EDP_INFO]: vdd_regulator:dcdc2
      [EDP_INFO]: vcc_regulator:bldo3
      [00.777]drv_disp_init finish
      [00.782]Loading Environment from SUNXI_FLASH... OK
      [00.788]boot_gui_init:start
      hdmi hpd out, force open?
      [00.920]LCD open finish
      [01.068]boot_gui_init:finish
      [01.076][boot disp] can not find the partition Reserve0
      [01.085]bmp_name=bootlogo.bmp size 3072054
      [01.118]Item0 (Map) magic is bad
      [01.121]the secure storage item0 copy0 magic is bad
      [01.132]Item0 (Map) magic is bad
      [01.135]the secure storage item0 copy1 magic is bad
      [01.140]Item0 (Map) magic is bad
      [01.143]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.153]usb prepare ok
      [01.344]usb sof ok
      [01.345]usb probe ok
      [01.347]usb setup ok
      set address 0x29
      set address 0x29 ok
      try to update
      spurious irq !!
      [01.754]do_burn_from_boot usb : have no handshake
      skip update boot_param
      root_partition is rootfs
      set root to /dev/mmcblk0p4
      [01.786]update part info
      [01.789]update bootcmd
      [01.792]change working_fdt 0xbbe47e50 to 0xbbe17e50
      [01.800]The storage not support sample function
      [01.822]boot-resource is not found!
      [01.833]err:part > PART_MAP_MAX
      [01.862]update dts
      avb_footer.c:22: ERROR: Footer magic is incorrect.
      [01.989]no vendor_boot partition is found
      Android's image name: sun55i_arm64
      The loading address of the kernel is not in the boot image
      ERROR: reserving fdt memory region failed (addr=bbf24000 size=3e8000)
      [02.037]Starting kernel ...
      [02.039][mmc]: mmc exit start
      [02.057][mmc]: mmc 2 exit ok
      NOTICE:  [SCP] :wait arisc ready....
      NOTICE:  [SCP] :arisc version: [toia25t-il-7-xun0.1vrid-]
      NOTICE:  [SCP] :arisc startup ready
      NOTICE:  [SCP] :arisc startup notify message feedback
      NOTICE:  [SCP] :sunxi-arisc driver is starting
      BL3-1: Next image address = 0x40080000
      BL3-1: Next image spsr = 0x3c5
      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
      [    0.000000] Linux version 5.15.123 (root@chen-virtual-machine) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #17 SMP PREEMPT Sun Apr 28 19:46:05 CST 2024
      [    0.000000] Machine model: sun55iw3
      [    0.000000] earlycon: uart8250 at MMIO32 0x0000000002500000 (options '')
      [    0.000000] printk: bootconsole [uart8250] enabled
      [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
      [    0.000000] OF: reserved mem: 0x0000000000020000..0x000000000002ffff (64 KiB) nomap non-reusable mcu0iram@20000
      [    0.000000] OF: reserved mem: 0x0000000000030000..0x0000000000037fff (32 KiB) nomap non-reusable mcu0dram0@30000
      [    0.000000] OF: reserved mem: 0x0000000000038000..0x000000000003ffff (32 KiB) nomap non-reusable mcu0dram1@38000
      [    0.000000] OF: reserved mem: 0x0000000007280000..0x00000000072bffff (256 KiB) nomap non-reusable riscvsram0@7280000
      [    0.000000] OF: reserved mem: 0x00000000072c0000..0x00000000072fffff (256 KiB) nomap non-reusable riscvsram1@72c0000
      [    0.000000] OF: reserved mem: 0x0000000048000000..0x0000000048ffffff (16384 KiB) map non-reusable bl31
      [    0.000000] OF: reserved mem: 0x000000004a000000..0x000000004a9fffff (10240 KiB) nomap non-reusable dsp0ddr@4a000000
      [    0.000000] OF: reserved mem: 0x000000004ab00000..0x000000004ab0ffff (64 KiB) nomap non-reusable dsp_share_space@4ab00000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ac00000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@4ac00000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ac00000..0x000000004ac3ffff (256 KiB) nomap non-reusable vdev0buffer@4ac00000
      [    0.000000] OF: reserved mem: 0x000000004ac40000..0x000000004ac41fff (8 KiB) nomap non-reusable vdev0vring0@4ac40000
      [    0.000000] OF: reserved mem: 0x000000004ac42000..0x000000004ac43fff (8 KiB) nomap non-reusable vdev0vring1@4ac42000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ae00000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node vdev0buffer@4ae00000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ae00000..0x000000004ae3ffff (256 KiB) nomap non-reusable vdev0buffer@4ae00000
      [    0.000000] OF: reserved mem: 0x000000004ae40000..0x000000004ae41fff (8 KiB) nomap non-reusable vdev0vring0@4ae40000
      [    0.000000] OF: reserved mem: 0x000000004ae42000..0x000000004ae43fff (8 KiB) nomap non-reusable vdev0vring1@4ae42000
      [    0.000000] Reserved memory: created DMA memory pool at 0x000000004ae44000, size 0 MiB
      [    0.000000] OF: reserved mem: initialized node dsp0_rpbuf@4ae44000, compatible id shared-dma-pool
      [    0.000000] OF: reserved mem: 0x000000004ae44000..0x000000004ae4bfff (32 KiB) nomap non-reusable dsp0_rpbuf@4ae44000
      [    0.000000] Zone ranges:
      [    0.000000]   DMA      [mem 0x0000000040000000-0x00000000bfffffff]
      [    0.000000]   DMA32    empty
      [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000049ffffff]
      [    0.000000]   node   0: [mem 0x000000004a000000-0x000000004a9fffff]
      [    0.000000]   node   0: [mem 0x000000004aa00000-0x000000004aafffff]
      [    0.000000]   node   0: [mem 0x000000004ab00000-0x000000004ab0ffff]
      [    0.000000]   node   0: [mem 0x000000004ab10000-0x000000004abfffff]
      [    0.000000]   node   0: [mem 0x000000004ac00000-0x000000004ac43fff]
      [    0.000000]   node   0: [mem 0x000000004ac44000-0x000000004adfffff]
      [    0.000000]   node   0: [mem 0x000000004ae00000-0x000000004ae4bfff]
      [    0.000000]   node   0: [mem 0x000000004ae4c000-0x00000000bfffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfffffff]
      [    0.000000] cma: Reserved 64 MiB at 0x00000000b7c00000
      [    0.000000] psci: PSCIv1.1 detected in firmware.
      [    0.000000] psci: SMC Calling Convention v1.2
      [    0.000000] percpu: Embedded 18 pages/cpu s33304 r8192 d32232 u73728
      [    0.000000] pcpu-alloc: s33304 r8192 d32232 u73728 alloc=18*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
      [    0.000000] Detected VIPT I-cache on CPU0
      [    0.000000] CPU features: detected: GIC system register CPU interface
      [    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
      [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
      [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 root=/dev/mmcblk0p4 init=/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:userdata@mmcblk0p5 cma=64M snum=60075779c1820762094 mac_addr= wifi_mac= bt_mac= selinux=0 specialstr= gpt=1 pd_ignore_unused=1 slub_debug=UFPZ androidboot.mode=normal androidboot.serialno=60075779c1820762094 androidboot.hardware=sun55iw3p1 boot_type=2 androidboot.boot_type=2 androidboot.secure_os_exist=0 androidboot.trustchain=false androidboot.drmkey=false gpt=1 uboot_message=2018.07-ga42aebb(01/29/2024-02:25:02) disp_reserve=4096000,0xbbf24000 bootreason=unknow androidboot.dramfreq=1200 androidboot.dramsize=2048 uboot_backup=ubootA
      [    0.000000] Unknown kernel command line parameters "partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:userdata@mmcblk0p5 snum=60075779c1820762094 mac_addr= wifi_mac= bt_mac= selinux=0 specialstr= boot_type=2 uboot_message=2018.07-ga42aebb(01/29/2024-02:25:02) disp_reserve=4096000,0xbbf24000 uboot_backup=ubootA", will be passed to user space.
      [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
      [    0.000000] Memory: 1935468K/2097152K available (10368K kernel code, 2738K rwdata, 3548K rodata, 1536K init, 463K bss, 96148K reserved, 65536K cma-reserved)
      [    0.000000] **********************************************************
      [    0.000000] **   NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE   **
      [    0.000000] **                                                      **
      [    0.000000] ** This system shows unhashed kernel memory addresses   **
      [    0.000000] ** via the console, logs, and other interfaces. This    **
      [    0.000000] ** might reduce the security of your system.            **
      [    0.000000] **                                                      **
      [    0.000000] ** If you see this message and you are not debugging    **
      [    0.000000] ** the kernel, report this immediately to your system   **
      [    0.000000] ** administrator!                                       **
      [    0.000000] **                                                      **
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
      [    0.000000] rcu:     RCU event tracing is enabled.
      [    0.000000]  Trampoline variant of Tasks RCU enabled.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
      [    0.000000] GICv3: 256 SPIs implemented
      [    0.000000] GICv3: 0 Extended SPIs implemented
      [    0.000000] GICv3: Distributor has no Range Selector support
      [    0.000000] Root IRQ handler: gic_handle_irq
      [    0.000000] GICv3: 16 PPIs implemented
      [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000003460000
      [    0.000000] ITS: No ITS available, not enabling LPIs
      [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
      [    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.009658] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
      [    0.020122] pid_max: default: 32768 minimum: 301
      [    0.025181] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.032893] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.043522] rcu: Hierarchical SRCU implementation.
      [    0.049950] smp: Bringing up secondary CPUs ...
      [    0.055337] Detected VIPT I-cache on CPU1
      [    0.055366] GICv3: CPU1: found redistributor 100 region 0:0x0000000003480000
      [    0.055402] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
      [    0.056062] Detected VIPT I-cache on CPU2
      [    0.056087] GICv3: CPU2: found redistributor 200 region 0:0x00000000034a0000
      [    0.056115] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
      [    0.056751] Detected VIPT I-cache on CPU3
      [    0.056773] GICv3: CPU3: found redistributor 300 region 0:0x00000000034c0000
      [    0.056797] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
      [    0.057420] Detected VIPT I-cache on CPU4
      [    0.057444] GICv3: CPU4: found redistributor 400 region 0:0x00000000034e0000
      [    0.057468] CPU4: Booted secondary processor 0x0000000400 [0x412fd050]
      [    0.058070] Detected VIPT I-cache on CPU5
      [    0.058093] GICv3: CPU5: found redistributor 500 region 0:0x0000000003500000
      [    0.058119] CPU5: Booted secondary processor 0x0000000500 [0x412fd050]
      [    0.058786] Detected VIPT I-cache on CPU6
      [    0.058810] GICv3: CPU6: found redistributor 600 region 0:0x0000000003520000
      [    0.058834] CPU6: Booted secondary processor 0x0000000600 [0x412fd050]
      [    0.059465] Detected VIPT I-cache on CPU7
      [    0.059489] GICv3: CPU7: found redistributor 700 region 0:0x0000000003540000
      [    0.059513] CPU7: Booted secondary processor 0x0000000700 [0x412fd050]
      [    0.059583] smp: Brought up 1 node, 8 CPUs
      [    0.192512] SMP: Total of 8 processors activated.
      [    0.197328] CPU features: detected: 32-bit EL0 Support
      [    0.202713] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
      [    0.211748] CPU features: detected: Common not Private translations
      [    0.218312] CPU features: detected: CRC32 instructions
      [    0.223663] CPU features: detected: RCpc load-acquire (LDAPR)
      [    0.229670] CPU features: detected: Privileged Access Never
      [    0.235493] CPU features: detected: RAS Extension Support
      [    0.241135] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
      [    0.248475] CPU: All CPU(s) started at EL1
      [    0.252663] alternatives: patching kernel code
      [    0.258465] devtmpfs: initialized
      [    0.358122] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.367906] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
      [    0.376258] pinctrl core: initialized pinctrl subsystem
      [    0.384002] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.392315] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
      [    0.399594] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.408438] thermal_sys: Registered thermal governor 'fair_share'
      [    0.408445] thermal_sys: Registered thermal governor 'bang_bang'
      [    0.414545] thermal_sys: Registered thermal governor 'step_wise'
      [    0.420544] thermal_sys: Registered thermal governor 'user_space'
      [    0.426543] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.434150] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
      [    0.448943] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
      [    0.456979] cpuidle: using governor menu
      [    0.461799] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
      [    0.468759] ASID allocator initialised with 65536 entries
      [    0.499125] AW BSP version: 92300645dd, 2024-01-29 10:26:51 +0800
      [    0.505444] sunxi:ccu_sunxi_ng:[INFO]: rtc_ccu: sunxi ccu init OK
      [    0.523723] sunxi:ccu_sunxi_ng:[INFO]: clock: sunxi ccu init OK
      [    0.529707] sun55iw3-cpupll 8817000.clock: Sunxi pll_cpu clk init OK
      [    0.544052] sunxi:ccu_sunxi_ng:[INFO]: ccu: sunxi ccu init OK
      [    0.552705] sunxi:ccu_sunxi_ng:[INFO]: r_ccu: sunxi ccu init OK
      [    0.563106] sunxi:ccu_sunxi_ng:[INFO]: mcu_ccu: sunxi ccu init OK
      [    0.578969] sunxi:pinctrl_sunxi-7022000.pinctrl:[INFO]: find i2s0 route contrl
      [    0.586234] sunxi:pinctrl_sunxi-7022000.pinctrl:[INFO]: find dmic route contrl
      [    0.593473] sunxi:pinctrl_sunxi-7022000.pinctrl:[INFO]: initialized sunXi PIO driver
      [    0.613471] sunxi hwspinlock vbase:0xffffffc008055000
      [    0.680360] iommu: Default domain type: Translated
      [    0.685256] iommu: DMA domain TLB invalidation policy: strict mode
      [    0.692667] SCSI subsystem initialized
      [    0.696700] usbcore: registered new interface driver usbfs
      [    0.702298] usbcore: registered new interface driver hub
      [    0.707686] usbcore: registered new device driver usb
      [    0.713212] mc: Linux media interface: v0.10
      [    0.717643] videodev: Linux video capture interface: v2.00
      [    0.724602] Advanced Linux Sound Architecture Driver Initialized.
      [    0.752621] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.767805] sun6i-dma 7121000.dma1-controller: sunxi dma probed
      [    0.774419] sunxi iommu: irq = 14
      [    0.784494] Bluetooth: Core ver 2.22
      [    0.788206] NET: Registered PF_BLUETOOTH protocol family
      [    0.793516] Bluetooth: HCI device and connection manager initialized
      [    0.799872] Bluetooth: HCI socket layer initialized
      [    0.804752] Bluetooth: L2CAP socket layer initialized
      [    0.809828] Bluetooth: SCO socket layer initialized
      [    0.815669] sun55iw3-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
      [    0.824784] sunxi-twi 7081400.s_twi0: supply twi not found, using dummy regulator
      [    0.833715] sunxi:axp2101-6-0036:[ERR]: Unable to match OF ID
      [    0.842395] sunxi:pmu_ext_core-6-0036:[INFO]: pmu_ext_dev variant AXP1530 found
      [    0.850370] axp1530-dcdc1: supplied by regulator-dummy
      [    0.856248] axp1530-dcdc2: supplied by regulator-dummy
      [    0.861985] axp1530-dcdc3: supplied by regulator-dummy
      [    0.867973] axp1530-aldo1: supplied by regulator-dummy
      [    0.873676] axp1530-dldo1: supplied by regulator-dummy
      [    0.880905] sunxi:pmu_ext_core-6-0036:[INFO]: pmu_ext:AXP1530 driver loaded
      [    0.892045] sunxi:axp2101-6-0035:[INFO]: AXP20x variant AXP2202 found
      [    0▒
      T527系统一直找不到电源管理芯片,不断重启,请问可能是什么原因导致的?或者有排查的思路或者方向知道一下吗?有大佬遇到过吗
      • Deleted by  K Kamila
      • Restored by  q1215200171 q1215200171
