    t113烧写spi nand卡在 [08.895]fill gap start: volume mbr sects 0x7f80
    • K
      kkkkkkkk LV 3 最后由 编辑
      [1045]fes begin commit:88480af-dirty
      [1048]set pll start
      [1054]periph0 has been enabled
      [1057]set pll end
      [1059][pmu]: bus read error
      [1061]board init ok
      [1063]beign to init dram
      [1065]ZQ value = 0x2f
      [1067]get_pmu_exist() = -1
      [1070]ddr_efuse_type: 0xa
      [1072]trefi:7.8ms
      [1075][AUTO DEBUG] single rank and full DQ!
      [1079]ddr_efuse_type: 0xa
      [1081]trefi:7.8ms
      [1084][AUTO DEBUG] rank 0 row = 13
      [1087][AUTO DEBUG] rank 0 bank = 8
      [1090][AUTO DEBUG] rank 0 page size = 2 KB
      [1094]DRAM BOOT DRIVE INFO: V0.33
      [1097]DRAM CLK = 936 MHz
      [1100]DRAM Type = 3 (2:DDR2,3:DDR3)
      [1103]DRAMC read ODT off.
      [1105]DRAM ODT value: 0x42.
      [1108]ddr_efuse_type: 0xa
      [1111]DRAM SIZE =128 M
      [1113]dram_tpr4:0x0
      [1115]PLL_DDR_CTRL_REG:0xf8004d00
      [1118]DRAM_CLK_REG:0xc0000000
      [1121][TIMING DEBUG] MR2= 0x20
      [1125]DRAM simple test OK.
      [1127]rtc standby flag is 0x0, super standby flag is 0x0
      [1133]init dram ok
      U-Boot 2018.05-g24521d6-dirty (Apr 29 2024 - 06:49:57 -0700) Allwinner Technology
      [02.544]CPU: Allwinner Family
      [02.547]Model: sun8iw20
      I2C: FDT ERROR:fdt_set_all_pin:[twi0]-->FDT_ERR_BADPATH
      ready
      [02.568]DRAM: 128 MiB
      [02.571]Relocation Offset is: 04f01000
      [02.591]secure enable bit: 0
      [02.593]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [02.600]gic: normal mode
      [02.602]flash init start
      [02.604]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [02.612][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [02.619][mmc]: Is not Boot mode!
      [02.621][mmc]: SUNXI SDMMC Controller Version:0x50310
      [02.632][mmc]: Try SD card 2
      [02.638][mmc]: mmc 2 cmd timeout 100 status 100
      [02.642][mmc]: smc 2 err, cmd 8, RTO
      [02.645][mmc]: mmc 2 close bus gating and reset
      [02.650][mmc]: mmc 2 cmd timeout 100 status 100
      [02.654][mmc]: smc 2 err, cmd 55, RTO
      [02.658][mmc]: mmc 2 close bus gating and reset
      [02.662][mmc]: Try MMC card 2
      [02.671][mmc]: mmc 2 cmd timeout 100 status 100
      [02.675][mmc]: smc 2 err, cmd 1, RTO
      [02.678][mmc]: mmc 2 close bus gating and reset
      [02.683][mmc]: Card did not respond to voltage select!
      [02.688][mmc]: SD/MMC 2 init error!
      [02.693][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [02.699]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [02.705]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [02.713]sunxi-spinand-phy: request spi0 gpio ok
      [02.717]sunxi-spinand-phy: request general tx dma channel ok!
      [02.723]sunxi-spinand-phy: request general rx dma channel ok!
      [02.728]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [02.733]sunxi-spinand-phy: init spic0 clk ok
      [02.778]sunxi-spinand-phy: not detect any munufacture from id table
      [02.784]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [02.789]sunxi-spinand-phy: get phy info from fdt fail
      [02.794]sunxi-spinand-phy: not detect munufacture from fdt
      [02.799]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [02.805]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
      [02.811]sunxi-spinand-phy: ========== arch info ==========
      [02.816]sunxi-spinand-phy: Model: W25N01GVZEIG
      [02.822]sunxi-spinand-phy: Munufacture: Winbond
      [02.827]sunxi-spinand-phy: DieCntPerChip: 1
      [02.831]sunxi-spinand-phy: BlkCntPerDie: 1024
      [02.836]sunxi-spinand-phy: PageCntPerBlk: 64
      [02.840]sunxi-spinand-phy: SectCntPerPage: 4
      [02.845]sunxi-spinand-phy: OobSizePerPage: 64
      [02.849]sunxi-spinand-phy: BadBlockFlag: 0x0
      [02.854]sunxi-spinand-phy: OperationOpt: 0x7
      [02.858]sunxi-spinand-phy: MaxEraseTimes: 65000
      [02.863]sunxi-spinand-phy: EccFlag: 0x0
      [02.868]sunxi-spinand-phy: EccType: 2
      [02.872]sunxi-spinand-phy: EccProtectedType: 3
      [02.877]sunxi-spinand-phy: ========================================
      [02.882]sunxi-spinand-phy:
      [02.885]sunxi-spinand-phy: ========== physical info ==========
      [02.891]sunxi-spinand-phy: TotalSize: 128 M
      [02.895]sunxi-spinand-phy: SectorSize: 512 B
      [02.899]sunxi-spinand-phy: PageSize: 2 K
      [02.903]sunxi-spinand-phy: BlockSize: 128 K
      [02.907]sunxi-spinand-phy: OOBSize: 64 B
      [02.911]sunxi-spinand-phy: ========================================
      [02.917]sunxi-spinand-phy:
      [02.920]sunxi-spinand-phy: ========== logical info ==========
      [02.925]sunxi-spinand-phy: TotalSize: 128 M
      [02.929]sunxi-spinand-phy: SectorSize: 512 B
      [02.933]sunxi-spinand-phy: PageSize: 4 K
      [02.937]sunxi-spinand-phy: BlockSize: 256 K
      [02.942]sunxi-spinand-phy: OOBSize: 128 B
      [02.946]sunxi-spinand-phy: ========================================
      [02.952]sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
      [02.958]sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
      [02.963]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [02.968]sunxi-spinand-phy: block lock register: 0x00
      [02.972]sunxi-spinand-phy: feature register: 0x19
      [02.977]sunxi-spinand-phy: sunxi physic nand init end
      [02.982]Loading Environment from SUNXI_FLASH... OK
      [02.986]try to burn key
      [02.988]out of usb burn from boot: not boot mode
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 16384
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x3
      set address 0x3 ok
      set address 0x3
      set address 0x3 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      MBR DUMP**
      total mbr part 8
      part[0] name :boot-resource
      part[0] classname :DISK
      part[0] addrlo :0x8000
      part[0] lenlo :0x1f8
      part[0] user_type :32768
      part[0] keydata :0
      part[0] ro :0
      part[1] name :env
      part[1] classname :DISK
      part[1] addrlo :0x81f8
      part[1] lenlo :0x1f8
      part[1] user_type :32768
      part[1] keydata :0
      part[1] ro :0
      part[2] name :env-redund
      part[2] classname :DISK
      part[2] addrlo :0x83f0
      part[2] lenlo :0x1f8
      part[2] user_type :32768
      part[2] keydata :0
      part[2] ro :0
      part[3] name :boot
      part[3] classname :DISK
      part[3] addrlo :0x85e8
      part[3] lenlo :0x1e00
      part[3] user_type :32768
      part[3] keydata :0
      part[3] ro :0
      part[4] name :rootfs
      part[4] classname :DISK
      part[4] addrlo :0xa3e8
      part[4] lenlo :0x12048
      part[4] user_type :32768
      part[4] keydata :0
      part[4] ro :0
      part[5] name :private
      part[5] classname :DISK
      part[5] addrlo :0x1c430
      part[5] lenlo :0x2800
      part[5] user_type :32768
      part[5] keydata :0
      part[5] ro :0
      part[6] name :rootfs_data
      part[6] classname :DISK
      part[6] addrlo :0x1ec30
      part[6] lenlo :0x2800
      part[6] user_type :32768
      part[6] keydata :0
      part[6] ro :0
      part[7] name :UDISK
      part[7] classname :DISK
      part[7] addrlo :0x21430
      part[7] lenlo :0x0
      part[7] user_type :32768
      part[7] keydata :0
      part[7] ro :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 1f8, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 1e00, 8000
      rootfs 5, 12048, 8000
      private 6, 2800, 8000
      rootfs_data 7, 2800, 8000
      UDISK 8, 0, 8000
      [06.238]erase blk 0 to blk 32
      need erase flash: 18
      [06.261]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      #: name size offset mask_flags
      0: boot0 0x00100000 0x00000000 1
      1: uboot 0x00300000 0x00100000 1
      2: secure_storage 0x00100000 0x00400000 1
      3: sys 0x07b00000 0x00500000 0
      defaults:
      mtdids : nand0=nand
      [06.311]MTD info (4)
      [06.313]pagesize: 0x1000
      [06.316]blksize: 0x40000
      [06.318]num offset bytes name
      [06.321]0 0x00000000 0x00100000 boot0
      [06.325]1 0x00100000 0x00300000 uboot
      [06.329]2 0x00400000 0x00100000 secure_storage
      [06.333]3 0x00500000 0x07b00000 sys
      [06.337]ubi attach the last part of mtd device: NO.3
      [06.408]ubi0: attaching mtd4
      [06.632]ubi0: scanning is finished
      [06.640]ubi0 warning: init_volumes: static volume 0 misses 65 LEBs - corrupted
      [06.648]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [06.652]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [06.659]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [06.665]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [06.671]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [06.676]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [06.683]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [06.691]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [06.699]erase blk 0 to blk 32
      [06.718]erase blk 40 to blk 1024
      [07.422]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [07.430]Item0 (Map) magic is bad
      [07.433]the secure storage map is empty
      [07.528]sunxi-spinand: write secure storage itme 0 ok
      [07.533]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids : nand0=nand
      [07.581]MTD info (4)
      [07.583]pagesize: 0x1000
      [07.585]blksize: 0x40000
      [07.588]num offset bytes name
      [07.591]0 0x00000000 0x00100000 boot0
      [07.595]1 0x00100000 0x00300000 uboot
      [07.599]2 0x00400000 0x00100000 secure_storage
      [07.603]3 0x00500000 0x07b00000 sys
      [07.606]MBR info (unalign):
      [07.609]partno addr sects type name
      [07.614]0 0x00000000 0x00008000 0x00000001 mbr
      [07.619]1 0x00008000 0x000001f8 0x00008000 boot-resource
      [07.624]2 0x000081f8 0x000001f8 0x00008000 env
      [07.629]3 0x000083f0 0x000001f8 0x00008000 env-redund
      [07.634]4 0x000085e8 0x00001e00 0x00008000 boot
      [07.639]5 0x0000a3e8 0x00012048 0x00008000 rootfs
      [07.644]6 0x0001c430 0x00002800 0x00008000 private
      [07.649]7 0x0001ec30 0x00002800 0x00008000 rootfs_data
      [07.655]8 0x00021430 0x00000000 0x00008000 UDISK
      [07.660]ubi attach the last part of mtd device: NO.3
      [07.664]MBR info (align):
      [07.667]partno addr sects type name
      [07.672]0 0x00002800 0x000081f0 0x00000001 mbr
      [07.676]1 0x0000a9f0 0x000001f8 0x00008000 boot-resource
      [07.682]2 0x0000abe8 0x000001f8 0x00008000 env
      [07.687]3 0x0000ade0 0x000001f8 0x00008000 env-redund
      [07.692]4 0x0000afd8 0x00001f80 0x00008000 boot
      [07.697]5 0x0000cf58 0x00012168 0x00008000 rootfs
      [07.702]6 0x0001f0c0 0x00002958 0x00008000 private
      [07.707]7 0x00021a18 0x00002958 0x00008000 rootfs_data
      [07.713]8 0x00024370 0x00000000 0x00008000 UDISK
      [07.717]ubi attach the last part of mtd device: NO.3
      [07.722]ubi attatch mtd, name: sys
      [07.725]ubi0: detaching mtd4
      [07.728]ubi0: mtd4 is detached
      [07.731]ubi0: attaching mtd4
      [07.844]ubi0: scanning is finished
      [07.847]ubi0: empty MTD device detected
      [07.867]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [07.872]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [07.878]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [07.884]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [07.890]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [07.896]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [07.902]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [07.910]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
      Creating dynamic volume boot-resource of size 258048
      Creating dynamic volume boot of size 4128768
      Creating dynamic volume rootfs of size 37933056
      Creating dynamic volume private of size 5419008
      Creating dynamic volume rootfs_data of size 5419008
      No size specified -> Using max size (50061312)
      [08.847]reset last volume size to 0x17df0
      Creating dynamic volume UDISK of size 50061312
      • F
        fanhuacloud LV 6 最后由 编辑
        WP HOLD引脚需要设置上拉
        K 1 条回复 最后回复 回复 引用 分享 0
        • K
          kkkkkkkk LV 3 @fanhuacloud 最后由 编辑
          @fanhuacloud 都有上拉的
