    T113s3 rtl8189fs 加载到内核了,但是没有wlan0
      jr_online LV 7 最后由 编辑
      操作的结果如下:
      root@TinaLinux:/# cd lib/modules/5.4.61/
      root@TinaLinux:/lib/modules/5.4.61# ls
      8189fs.ko          iptable_filter.ko  xt_comment.ko      xt_multiport.ko
      8723ds.ko          sunxi_gpadc.ko     xt_limit.ko        xt_time.ko
      gt9xxnew_ts.ko     xt_LOG.ko          xt_mac.ko
      ipt_REJECT.ko      xt_TCPMSS.ko       xt_mark.ko
      root@TinaLinux:/lib/modules/5.4.61# insmod 8189fs.ko
      module is already loaded - 8189fs
      root@TinaLinux:/lib/modules/5.4.61# lsmod
      8189fs               1204224  0
      sunxi_gpadc            24576  0
      root@TinaLinux:/lib/modules/5.4.61# ifconfig -a
                collisions:0 txqueuelen:1000
      root@TinaLinux:/lib/modules/5.4.61# /etc/init.d/wpa_supplicant start
      root@TinaLinux:/lib/modules/5.4.61# ifconfig: SIOCGIFFLAGS: No such device
      root@TinaLinux:/lib/modules/5.4.61# ifconfig wlan0 up
      然后运行的log如下:
      insmod: can't insert '/lib/modules/5.4.61/usb-storage.ko': No such file or directory
      [    3.711044] sunxi_gpadc_init,2151, success
      [    3.715936] sunxi_gpadc_setup: get channel scan data failed
      [    3.722572] input: sunxi-gpadc0 as /devices/virtual/input/input1
      [    3.921514] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [    4.028649] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [    4.034925] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.046163] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    4.053785]
      [    4.053785] insmod_device_driver
      [    4.053785]
      [    4.060986] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    4.066315] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.073019] device_chose finished 142!
      [    4.097802] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    4.105460] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    4.112286] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.126832] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.140547] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.148080] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.155602] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.163130] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    4.169851] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      ------run rc.final file-----
      mount: mounting /dev/mmcblk0p1 on /mnt/extsd failed: No such file or directory
      ------run profile file-----
      有哪个知道应该怎么排查问题吗?指点我一二!
