    melis开机启动进入不了应用
    • G
      godzhou0909 LV 6 最后由 编辑
      下载nezha官方的代码,开机启动进入不了startup.sh.不知道哪里问题,求大神帮看看。melis.log
      G 1 条回复 最后回复 回复 引用 分享 0
      • G
        godzhou0909 LV 6 @godzhou0909 最后由 编辑
        @godzhou0909 贴的NOR FLASH是MX25L6406EM,是不是flash不行呢?
        [141]HELLO! BOOT0 is starting!
        [144]BOOT0 commit : 889f614
        [147]set pll start
        [149]fix vccio detect value:0xc0
        [152]periph0 has been enabled
        [155]set pll end
        [156][pmu]: bus read error
        [159]board init ok
        [161]ZQ value = 0x30
        [163]get_pmu_exist() = -1
        [165]DRAM BOOT DRIVE INFO: V0.32
        [168]DRAM CLK = 528 MHz
        [170]DRAM Type = 2 (2:DDR2,3:DDR3)
        [173]DRAMC read ODT off.
        [176]DRAM ODT off.
        [178]ddr_efuse_type: 0xa
        [180]mark_id: 0x74
        [182]DRAM SIZE =64 M
        [184]PLL_DDR_CTRL_REG:0xf9002b00
        [187]DRAM_CLK_REG:0xc0000000
        [190][TIMING DEBUG] MR2= 0x0
        [194]DRAM simple test OK.
        [197]dram size =64
        [199]spinor id is: c2 20 17, read cmd: 0b
        [202]Succeed in reading toc file head.
        [206]The size of toc is a0000.
        [314]Entry_name = melis-lzma
        [317]LZMA: Image address............... 0x41000400
        [322]LZMA: Properties address.......... 0x41000400
        [326]LZMA: Uncompressed size address... 0x41000405
        [331]LZMA: Compressed data address..... 0x4100040d
        [336]LZMA: Destination address......... 0x40000000
        [340]LZMA: Uncompresed size............ 0xffffffffffffffff
        [346]LZMA: Compresed size.............. 0xfffffffa
        [537]LZMA: Uncompressed ............... 0x0013a0f8
        [542]Entry_name = melis-config
        [546]image_base:43000000
        [548]Jump to second Boot.
        [550]jump to rtos
        sbi2ekernel
        | /'_/\ (_ ) _ ( )( ) /' _\ /' \ | | | __ | | (_) ___ ______ _ _ | || | | ( ) | | ( ) | | | (_) | /'__\ | | | |/',)()( ) ( )| || | | | | | | | | |
        | | | | |( / | | | |_, \ | _/ |( ,
        ) _ | () | _ | () |
        | () ()\____)(___)(_)(____/ _/' () ()\___/'(_)_/'
        |version : V3.9.0 |
        |commitid: a850c7b6b408b36ea58bcce024f7c788688ca5ab |
        |sunxiver: 40000 |
        |timever : Sat, 11 May 2024 19:51:43 -0700 |
        |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104) |
        |optimal : -Os -g -gdwarf-2 -gstrict-dwarf |
        |linker : GNU ld (GNU Binutils) 2.32 |
        |newlibc : 3.0.0 |
        |author : root |
        [DBG]: [__mount_parts:0299]: classname=DMS
        [DBG]: [__mount_parts:0300]: devname=dms01
        [DBG]: [__mount_parts:0327]: find last lun.
        [DBG]: [__mount_parts:0357]: nPart = 1.
        [DBG]: [__mount_parts:0486]: dmsPart: "DMS\dms010" is linked to symbel "B".
        [ERR]: [esFSYS_pread:0331]: fs fatal err
        mount errno: -19!
        [DBG]: [esFSYS_mntfs:0333]: melis_devfs,mount on B.
        [DBG]: [kservice_maintask:0845]: partition [B] plug in..
        [DBG]: [__mount_parts:0299]: classname=DISK
        [DBG]: [__mount_parts:0300]: devname=RAMDISK
        [DBG]: [__mount_parts:0486]: rawpart: "DISK\RAMDISK0" is linked to symbel "C".
        [ERR]: [esFSYS_mntfs:0314]: identify the filesystem failure.
        [ERR]: [__mount_parts:0541]: mount C failure.
        dfs already init.
        flash : 1
        sip : 0
        hal_spi_hw_config()2025 [spi0] clock_frequency = 50000000HZ
        hal_spi_init()2215 [spi0] DMA xfer enable
        nor_scan
        [ERR]: [nor_mxic_quad_mode:0079]: spinor: set mxic QE failed (0x0)
        [ERR]: [nor_scan:0537]: spinor: enable quad mode failed
        [ERR]: [nor_scan:0544]: spinor: scan nor flash failed
        [ERR]: [nor_init:0636]: spinor: init nor flash failed
        [ERR]: [nor_read:0950]: spinor: read address 0xc000 with len 16384 failed
        [ERR]: [register_blk_device:0851]: get gpt from nor flash failed - -5
        SDC:hal_sdc_create host:0x402105d8 id:0
        host debug mask 3c[ERR] SDC:name ???,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name ???,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name ???,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name ???,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name ???,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1
        [ERR] SDC:name ???,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1
        SDC:Not implement __mci_restore_io,819
        SDC:Not imp hal_sdc_init,2236
        SDC:hal_sdc_init,2269 no imp
        SDC:hal_sdc_init,2278 no imp
        SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000
        SDC:Not implement __mci_hold_io,804
        SDC:SDC cd_mode:2 present_val:0
        SDC:SDC id:0 dma_use:1 present:0
        driver version SD/MMC/SDIO Host Controller Driver(v0.29 2022-09-01 16:50) init ok.
        host_id =0!
        [ERR]: [hal_ths_init:0094]: 0x2009404, 0x2009400, 0x2009430, 0x2009408
        key name:thermal_sensor key size:64 key offset:20
        thermal_sensor:
        02 c1 73 79 0f 30 e9 01
        ERR ekernel/drivers/hal/source/usb/manager/usb_manager.c 276 usb_script_parse :script_parser_fetch usbc0 usb_drv_vbus_gpio fail
        port_info->port.port_type:2
        the cir_master_init success
        Warning: clk pll-audio0 should not be changed, please recheck whether the operation is correct
        [ehci-usb1] insmod host driver!
        phy_vbase : 0x4200800, usbc_no : 1, efuse : 0x1e9300f
        scheduler startup
        [ohci-usb1] insmod host driver!
        d: partition open failed, please check board storage device!card_detect removed sdmmc_test->card_id=0
        [WRN] SD:mmc_card_open card not exit! id:0
        card open fail
