    D1s tina编译失败
      AAC50 LV 2 最后由 编辑
      请教一下各位,我这边tina sdk编译失败,感觉没啥头绪.
      使用的环境是Ubuntu Server 16.04 LTS 64位.
      因为板子是100ask的.所以是按https://github.com/DongshanPI/D1s-CVBS_TinaSDK这个流程走下来的.
      报错log:
      make[3]: Leaving directory '/www/wwwroot/AAC50/tina-d1-h/package/libs/alsa-lib'
      make[3]: Entering directory '/www/wwwroot/AAC50/tina-d1-h/package/allwinner/alsa-conf-aw'
      mkdir -p /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/packages /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/compile_dir/target/alsa-conf-aw-1.0.0/ipkg-sunxi/alsa-conf-aw/CONTROL /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/staging_dir/target/pkginfo
      install -d -m0755 /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/compile_dir/target/alsa-conf-aw-1.0.0/ipkg-sunxi/alsa-conf-aw/etc/
      if [ -e ./files/d1s/d1s-cvbs/asound.conf ]; then install -m0644 ./files/d1s/d1s-cvbs/asound.conf /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/compile_dir/target/alsa-conf-aw-1.0.0/ipkg-sunxi/alsa-conf-aw/etc/; else install -m0644 ./files/asound.conf /www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/compile_dir/target/alsa-conf-aw-1.0.0/ipkg-sunxi/alsa-conf-aw/etc/; fi
      install: cannot stat './files/asound.conf': No such file or directory
      Makefile:39: recipe for target '/www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/packages/base/alsa-conf-aw_1.0.0-1_sunxi.ipk' failed
      make[3]: *** [/www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/packages/base/alsa-conf-aw_1.0.0-1_sunxi.ipk] Error 1
      make[3]: Leaving directory '/www/wwwroot/AAC50/tina-d1-h/package/allwinner/alsa-conf-aw'
      package/Makefile:192: recipe for target 'package/allwinner/alsa-conf-aw/compile' failed
      make[2]: *** [package/allwinner/alsa-conf-aw/compile] Error 2
      make[2]: Leaving directory '/www/wwwroot/AAC50/tina-d1-h'
      package/Makefile:189: recipe for target '/www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/www/wwwroot/AAC50/tina-d1-h/out/d1s-cvbs/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/www/wwwroot/AAC50/tina-d1-h'
      /www/wwwroot/AAC50/tina-d1-h/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      [2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      make failed to build some targets (11 seconds)
