    小白求救T113-S3 sdc2 emmc(ZDEMMC04GA)不识别
    • N
      nbear365 LV 2 最后由 编辑
      新做的板子,sdc2 4线连接 emmc,型号ZDEMMC04GA,PPRST 是系统复位脚,emmc rst直接上拉到3.3v也试过,都是不识别。
      原理图:
      sys_config.fex
      [card2_boot_para]
      card_ctrl       = 2
      card_high_speed = 1
      card_line       = 4
      sdc_clk         = port:PC02<3><1><3><default>
      sdc_cmd         = port:PC03<3><1><3><default>
      sdc_d0          = port:PC06<3><1><3><default>
      sdc_d1          = port:PC05<3><1><3><default>
      sdc_d2          = port:PC04<3><1><3><default>
      sdc_d3          = port:PC07<3><1><3><default>
      ;cap-mmc-highspeed =
      sdc-frequency   = 5000000
      ;sdc_boot        = 2
      ;sdc_tm4_hs200_max_freq = 150
      ;sdc_tm4_hs400_max_freq = 100
      ;sdc_ex_dly_used = 2
      sdc_io_1v8      = 0
      sdc_tm4_win_th = 8
      ;sdc_dis_host_caps = 0x180
      ;sdc_erase      = 2
      sdc_boot0_sup_1v8 = 0
      sdc_type        = "tm4"
      dts:
      &sdc2 {
              non-removable;
              bus-width = <4>;
              mmc-ddr-3_3v;
              //mmc-ddr-1_8v;
              //mmc-hs200-1_8v;
              /*mmc-hs400-1_8v;*/
              no-sdio;
              no-sd;
              ctl-spec-caps = <0x308>;
              cap-mmc-highspeed;
              sunxi-power-save-mode;
              sunxi-dis-signal-vol-sw;
              mmc-bootpart-noacc;
              max-frequency = <50000000>;
              //vmmc-supply = <&reg_3p3v>;
              //vqmmc33sw-supply = <&reg_3p3v>;
              /*max-frequency = <100000>;*/
              /*emmc io vol 3.3v*/
              /*emmc io vol 1.8v*/
      用usb下载程序:
      用SD卡能启动,log
      [    1.950569] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    1.960511] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
      [    1.966904] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [    1.973225] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [    1.979628] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [    1.986057] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [    1.992572] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [    1.999073] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [    2.005584] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [    2.012111] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.021460] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.045107] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.069283] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [    2.076413] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.088880] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pfo not found, using dummy regulator
      [    2.090981] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.100142] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.112857] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.121377] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.133640] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.139136] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.145575] sunxi-mmc 4022000.sdmmc: retry:start
        cscssure LV 2 最后由 编辑
        我也遇到同样的问题,楼主有找到解决方法了吗?
          zhouguoxin LV 2 最后由 编辑
          我也是这样怎么解决
