    uboot 无法启动,pack 打包, 如何自定义自己板卡,相关文件配置问题
      super0759 LV 5 最后由 编辑
      按照提示需改,发现uboot 无法启动,请问如何配置: uboot打印如下 :
      U-Boot 2018.07 (Jun 02 2024 - 21:21:38 +0800) Allwinner Technology
      [00.503]CPU: Allwinner Family
      [00.506]Model: sun8iw21
      [00.508]DRAM: 64 MiB
      [00.512]Relocation Offset is: 00ece000
      [00.545]secure enable bit: 0
      E/TC:0 fdt_getprop_u32:343 prop trace_level not found
      [00.561]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz MBus=300Mhz
      [00.567]gic: sec monitor mode
      sunxi flash map init
      SPI ALL: ready
      [00.574]line:724 init_clocks
      [00.577]flash init start
      [00.579]workmode = 0,storage type = 0
      [00.587]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1a
      #: name size offset mask_flags
      0: boot0 0x00100000 0x00000000 1
      1: uboot 0x00300000 0x00100000 1
      2: secure_storage 0x00100000 0x00400000 1
      3: sys 0x07b00000 0x00500000 0
      defaults:
      mtdids : nand0=nand
      [00.704]ubi0: attaching mtd4
      [00.933]ubi0: scanning is finished
      [00.943]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [00.948]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.954]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.960]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.966]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [00.972]ubi0: user volume: 7, internal volumes: 1, max. volumes count: 128
      [00.978]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.986]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [00.994]sunxi flash init ok
      [00.997]drv_disp_init
      [01.004]handle_num : 4
      Get bootloader and boot-resource partition number fail!
      request pwm success, pwm6:pwm6:0x2000c00.
      [01.356]drv_disp_init finish
      [01.521]Loading Environment from SUNXI_FLASH... *** Warning - bad CRC, using default environment
      *** Warning - no device, using default environment
      Failed (-5)
      [01.551]boot_gui_init:start
      [01.554]set disp.dev2_output_type fail. using defval=0
      [01.559][T050K589 LCD INFO] LINE:0142-->lcd_open_flow:
      [01.565][T050K589 LCD INFO] LINE:0163-->lcd_power_on:
      [01.583]set disp.fb0_rot_used fail. using defval=0
      [01.587]set disp.fb0_rot_degree fail. using defval=0
      [01.593]boot_gui_init:finish
      [01.598][T050K589 LCD INFO] LINE:0441-->lcd_panel_init:
      [01.615][T050K589 LCD INFO] LINE:0456-->lcd_panel_init:initialization:jd9365
      [01.732]Get bootloader and boot-resource partition number fail!
      [01.761]update bootcmd
      [01.786]change working_fdt 0x42a8de70 to 0x42a6de70
      [01.798]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [01.807][T050K589 LCD INFO] LINE:0199-->lcd_bl_open:
      [01.819]LCD open finish
      [02.004]update dts
      Error: "distro_bootcmd" not defined
      => print
      aw-ubi-spinand.ubootblks=24
      baudrate=115200
      bootcmd=run distro_bootcmd
      bootdelay=2
      fdtcontroladdr=42a8de70
      filesize=10000
      force_normal_boot=1
      mtdids=nand0=nand
      mtdparts=mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      partition=nand0,0
      partitions=mbr@ubi0_0:boot-res@ubi0_1:env@ubi0_2:boot@ubi0_3:rootfs@ubi0_4:rootfs_data@ubi0_5:UDISK@ubi0_6:
      rotpk_status=0
      ubi_attach_mtdnum=3
      Environment size: 450/131068 bytes
