    Tina-sdk T113编译报错-intltool-0.51.0 FAQ
      mr_yan LV 3 最后由 编辑
      各位大佬们,请问有遇到这个问题吗? 我上周同样操作步骤,能够编译成功并输出固件,这周换了几个编译环境了,都是一样的问题,ubuntu18.04,20.04,22.04,都是一样的报错,原来能编译过的环境时20.04,我给SDK换了下路径,清理,重新编译,也无法编译通过了,都是报的intltool-0.51.0错误。
      一、编译环境搭建
      1、WSL2 Ubuntu20.04
      2、安装编译环境依赖
      sudo apt-get update
      sudo apt-get upgrade -y
      安装开发依赖
      sudo apt-get install build-essential subversion git libncurses5-dev zlib1g-dev gawk flex bison quilt libssl-dev xsltproc libxml-parser-perl mercurial bzr ecj cvs unzip lsof
      安装相关工具
      sudo apt-get install kconfig-frontends android-tools-mkbootimg python2 libpython3-dev
      增加架构支持
      sudo dpkg --add-architecture i386
      sudo apt-get update
      安装支持包
      sudo apt install gcc-multilib
      sudo apt install libc6:i386 libstdc++6:i386 lib32z1
      二、SDK源码拉取及编译
      1、拉取社区tina sdk
      repo init -u https://sdk.aw-ol.com/git_repo/D1_Tina_Open/manifest.git -b master -m tina-d1-h.xml
      2、同步最新代码到本地
      repo sync
      此时sdk目录下文件如下:
      :~/workspace/system$ ls tina-t113-sdk/
      Config.in  Makefile  README.md  build  config  device  dl  lichee  out  package  prebuilt  rules.mk  scripts  target  tmp  toolchain  tools
      3、拉取t113s3 sdk支持包
      git clone https://gitee.com/weidongshan/100ASK_T113-Pro_TinaSDK.git
      cd 100ASK_T113-Pro_TinaSDK && git submodule update --init
      4、将t113s3配置导入tina-sdk
      cp ./100ASK_T113-Pro_TinaSDK* -rfvd   ./tina-t113-sdk
      5、导入环境变量,选择编译选项 选择 4
      :~/workspace/system/tina-t113-sdk$ source build/envsetup.sh
      Setup env done! Please run lunch next.
      :~/workspace/system$ lunch
      You're building on Linux
      Lunch menu... pick a combo:
           1. d1-h_nezha-tina
           2. d1-h_nezha_min-tina
           3. d1s_nezha-tina
           4. t113_100ask-tina
      Which would you like? [Default t113_100ask]: 4
      三、编译报错
      1、mboot 编译uboot,成功
      /home/yann/workspace/system/tina-t113-sdk/lichee/brandy-2.0/spl/../tools/toolchain/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin/arm-linux-gnueabi-strip -g /home/yann/workspace/system/tina-t113-sdk/lichee/brandy-2.0/spl/sboot/libsun8iw20p1_sboot.o
      'sboot_sun8iw20p1.bin' -> '/home/yann/workspace/system/tina-t113-sdk/lichee/brandy-2.0/spl/../../../device/config/chips/t113/bin/sboot_sun8iw20p1.bin'
      'sboot_sun8iw20p1.bin' -> '/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/sboot_sun8iw20p1.bin'
      mboot0 success!
      2、mkernek编译内核,成功
      make[3]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk/target/allwinner/t113-100ask'
      make[2]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk/target/allwinner'
      make[1]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk'
      #### make completed successfully (04:37 (mm:ss)) ####
      3、make 编译所有,失败,报错
      make[3]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk/package/libs/libinput'
      make[3]: Entering directory '/home/yann/workspace/system/tina-t113-sdk/package/libs/intltool'
      (cd /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0; rm -f aclocal.m4; if [ -f ./configure.ac ] || [ -f ./configure.in ]; then [ -d ./autom4te.cache ] && rm -rf autom4te.cache; [ -e ./config.rpath ] || ln -s /home/yann/workspace/system/tina-t113-sdk/scripts/config.rpath ./config.rpath; touch NEWS AUTHORS COPYING ABOUT-NLS ChangeLog; AUTOM4TE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autom4te AUTOCONF=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoconf AUTOMAKE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/automake ACLOCAL=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/aclocal AUTOHEADER=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoheader LIBTOOLIZE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/libtoolize LIBTOOL=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/libtool M4=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/m4 AUTOPOINT=true /home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoreconf -v -f -i -s -B /home/yann/workspace/system/tina-t113-sdk/out/host/share/aclocal -I m4 -I . . || true; fi; );   (cd /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0; rm -f aclocal.m4; if [ -f ./configure.ac ] || [ -f ./configure.in ]; then [ -d ./autom4te.cache ] && rm -rf autom4te.cache; [ -e ./config.rpath ] || ln -s /home/yann/workspace/system/tina-t113-sdk/scripts/config.rpath ./config.rpath; touch NEWS AUTHORS COPYING ABOUT-NLS ChangeLog; AUTOM4TE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autom4te AUTOCONF=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoconf AUTOMAKE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/automake ACLOCAL=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/aclocal AUTOHEADER=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoheader LIBTOOLIZE=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/libtoolize LIBTOOL=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/libtool M4=/home/yann/workspace/system/tina-t113-sdk/out/host/bin/m4 AUTOPOINT=true /home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoreconf -v -f -i -s -B /home/yann/workspace/system/tina-t113-sdk/out/host/share/aclocal -I m4 -I . . || true; fi; );
      autoreconf: Entering directory `.'
      autoreconf: configure.ac: not using Gettext
      autoreconf: running: /home/yann/workspace/system/tina-t113-sdk/out/host/bin/aclocal -I m4 -I . --force
      autoreconf: configure.ac: tracing
      autoreconf: configure.ac: not using Libtool
      autoreconf: running: /home/yann/workspace/system/tina-t113-sdk/out/host/bin/autoconf --include=m4 --include=. --prepend-include=/home/yann/workspace/system/tina-t113-sdk/out/host/share/aclocal --force
      autoreconf: configure.ac: not using Autoheader
      autoreconf: running: /home/yann/workspace/system/tina-t113-sdk/out/host/bin/automake --add-missing --force-missing
      autoreconf: Leaving directory `.'
      (cd /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0/; if [ -x configure ]; then cp -fpR /home/yann/workspace/system/tina-t113-sdk/scripts/config.{guess,sub} /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0// &&  bash ./configure CC="gcc" CFLAGS="-O2 -I/home/yann/workspace/system/tina-t113-sdk/out/host/include -I/home/yann/workspace/system/tina-t113-sdk/out/host/usr/include -I/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/include" CPPFLAGS="-I/home/yann/workspace/system/tina-t113-sdk/out/host/include -I/home/yann/workspace/system/tina-t113-sdk/out/host/usr/include -I/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/include" LDFLAGS="-L/home/yann/workspace/system/tina-t113-sdk/out/host/lib -L/home/yann/workspace/system/tina-t113-sdk/out/host/usr/lib -L/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/lib" SHELL="/usr/bin/env bash" PATH=/bin:/usr/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/.local/bin/:/home/yann/.local/bin:/home/yann/.local/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/mnt/c/Program:Files:(x86)/VMware/VMware:Workstation/bin/:/mnt/c/Windows/system32:/mnt/c/Windows:/mnt/c/Windows/System32/Wbem:/mnt/c/Windows/System32/WindowsPowerShell/v1.0/:/mnt/c/Windows/System32/OpenSSH/:/mnt/c/Program:Files/Git/cmd:/mnt/c/Program:Files/Microsoft:VS:Code/bin:/mnt/c/User/QT/Tools/CMake_64/bin:/mnt/c/User/QT/Tools/mingw810_64/bin:/mnt/c/User/QT/Tools/mingw1120_64/bin:/mnt/c/User/QT/Tools/QtCreator/bin:/mnt/c/User/QT/Tools/sdktool/bin:/mnt/c/User/QT/5.15.2/mingw81_64/bin:/mnt/c/Users/Administrator/AppData/Local/Microsoft/WindowsApps/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0:/mnt/c/Users/Administrator/AppData/Local/Packages/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0/LocalCache/local-packages/Python310/site-packages:/mnt/c/qp/qtools/MinGW32/bin:/mnt/c/qp/qtools/bin:/mnt/c/User/usbip-win-0.3.6-dev:/mnt/c/Users/Administrator/AppData/Local/Packages/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0/LocalCache/local-packages/Python310/Scripts:/mnt/d/ProgramFiles/mysql-8.3.0-winx64/bin:/mnt/d/ProgramFiles/ADB_auto_tab/platform-tools_r30.0.5-windows_tab自动补全/platform-tools:/mnt/c/Users/Administrator/AppData/Local/Microsoft/WindowsApps:/mnt/d/ProgramFiles/PyCharm:2023.2.3/bin:/mnt/f/files/T113/T113-Pro开发板/02-100ASK_T113-Pro开发板上手体验/AllwinnertechPhoeniSuit/:/snap/bin --target=x86_64-linux-gnu --host=x86_64-linux-gnu --build=x86_64-linux-gnu --program-prefix="" --program-suffix="" --prefix=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host --exec-prefix=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host --sysconfdir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/etc --localstatedir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/var --sbindir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/bin ; fi )
      bash: -c: line 0: syntax error near unexpected token `('
      bash: -c: line 0: `(cd /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0/; if [ -x configure ]; then cp -fpR /home/yann/workspace/system/tina-t113-sdk/scripts/config.{guess,sub} /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0// &&  bash ./configure CC="gcc" CFLAGS="-O2 -I/home/yann/workspace/system/tina-t113-sdk/out/host/include -I/home/yann/workspace/system/tina-t113-sdk/out/host/usr/include -I/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/include" CPPFLAGS="-I/home/yann/workspace/system/tina-t113-sdk/out/host/include -I/home/yann/workspace/system/tina-t113-sdk/out/host/usr/include -I/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/include" LDFLAGS="-L/home/yann/workspace/system/tina-t113-sdk/out/host/lib -L/home/yann/workspace/system/tina-t113-sdk/out/host/usr/lib -L/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/lib" SHELL="/usr/bin/env bash" PATH=/bin:/usr/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/usr/bin:/home/yann/workspace/system/tina-t113-sdk/prebuilt/gcc/linux-x86/arm/toolchain-sunxi-musl/toolchain/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/workspace/system/tina-t113-sdk/out/host/bin:/home/yann/.local/bin/:/home/yann/.local/bin:/home/yann/.local/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/mnt/c/Program:Files:(x86)/VMware/VMware:Workstation/bin/:/mnt/c/Windows/system32:/mnt/c/Windows:/mnt/c/Windows/System32/Wbem:/mnt/c/Windows/System32/WindowsPowerShell/v1.0/:/mnt/c/Windows/System32/OpenSSH/:/mnt/c/Program:Files/Git/cmd:/mnt/c/Program:Files/Microsoft:VS:Code/bin:/mnt/c/User/QT/Tools/CMake_64/bin:/mnt/c/User/QT/Tools/mingw810_64/bin:/mnt/c/User/QT/Tools/mingw1120_64/bin:/mnt/c/User/QT/Tools/QtCreator/bin:/mnt/c/User/QT/Tools/sdktool/bin:/mnt/c/User/QT/5.15.2/mingw81_64/bin:/mnt/c/Users/Administrator/AppData/Local/Microsoft/WindowsApps/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0:/mnt/c/Users/Administrator/AppData/Local/Packages/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0/LocalCache/local-packages/Python310/site-packages:/mnt/c/qp/qtools/MinGW32/bin:/mnt/c/qp/qtools/bin:/mnt/c/User/usbip-win-0.3.6-dev:/mnt/c/Users/Administrator/AppData/Local/Packages/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0/LocalCache/local-packages/Python310/Scripts:/mnt/d/ProgramFiles/mysql-8.3.0-winx64/bin:/mnt/d/ProgramFiles/ADB_auto_tab/platform-tools_r30.0.5-windows_tab自动补全/platform-tools:/mnt/c/Users/Administrator/AppData/Local/Microsoft/WindowsApps:/mnt/d/ProgramFiles/PyCharm:2023.2.3/bin:/mnt/f/files/T113/T113-Pro开发板/02-100ASK_T113-Pro开发板上手体验/AllwinnertechPhoeniSuit/:/snap/bin --target=x86_64-linux-gnu --host=x86_64-linux-gnu --build=x86_64-linux-gnu --program-prefix="" --program-suffix="" --prefix=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host --exec-prefix=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host --sysconfdir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/etc --localstatedir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/var --sbindir=/home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/host/bin ; fi )'
      make[3]: *** [Makefile:43: /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/compile_dir/target/host/intltool-0.51.0/.configured] Error 1
      make[3]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk/package/libs/intltool'
      make[2]: *** [package/Makefile:192: package/libs/intltool/host/compile] Error 2
      make[2]: Leaving directory '/home/yann/workspace/system/tina-t113-sdk'
      make[1]: *** [package/Makefile:189: /home/yann/workspace/system/tina-t113-sdk/out/t113-100ask/staging_dir/target/stamp/.package_compile] Error 2
      make: *** [/home/yann/workspace/system/tina-t113-sdk/build/toplevel.mk:306: world] Error 2
      [2]+  Done                    $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
      #### make failed to build some targets (32 seconds) ####
        mr_yan LV 3 最后由 编辑
        回复: Tina-sdk T113编译报错-intltool-0.51.0 FAQ
        结帖---问题已解决,由于wsl 环境变量导致 包含了win11的环境变量,环境变量有中文路径,linux无法识别
        :~/workspace/system/tina-d1-h$ echo $PATH
        /home/yann/.local/bin:/home/yann/.local/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/mnt/c/Program Files (x86)/NVIDIA Corporation/PhysX/Common:/mnt/c/WINDOWS/system32:/mnt/c/WINDOWS:/mnt/c/WINDOWS/System32/Wbem:/mnt/c/WINDOWS/System32/WindowsPowerShell/v1.0/:/mnt/c/WINDOWS/System32/OpenSSH/:/mnt/c/Program Files/Microsoft VS Code/bin:/mnt/c/Program Files/Git/cmd:/mnt/c/Program Files/Docker/Docker/resources/bin:/mnt/c/Users/Administrator/AppData/Local/Packages/PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0/LocalCache/local-packages/Python310/Scripts:/mnt/c/Program Files (x86)/Windows Kits/8.1/Windows Performance Toolkit/:/mnt/c/qp/qtools/MinGW32/bin:/mnt/c/qp/qtools/bin:/mnt/c/UserApp/qt/Tools/mingw810_64/bin:/mnt/c/UserApp/ADB-tab/platform-tools_r30.0.5-windows_tab/platform-tools:/mnt/c/Users/Administrator/AppData/Local/Microsoft/WindowsApps:/mnt/c/Program Files/JetBrains/PyCharm 2023.2.3/bin:/mnt/f/嵌入式资料/T113S3/AllwinnertechPhoeniSuit/:/snap/bin
        解决方法: 重新设置环境变量即可
        export PATH=/home/yann/.local/bin:/home/yann/.local/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib
        S 1 条回复 最后回复 回复 引用 分享 2
          SixPi LV 5 @mr_yan 最后由 编辑
          我在编的时候正好遇到这个问题, 采用相同的解决方法, 确认有效
          另外WSL1下, 不要用win的目录
