    求教:关于D1开发板Tina Linux开机流程
    4022
      WadeDeng LV 4 最后由 编辑
      问题背景:本人有一块哪吒开发板,但是并没有买官方的显示屏,然后通过改代码点亮了一块DSI的mipi屏,但是和官方的适配的tft08006的分辨率不同,tft08006为竖屏分辨率为8001280,本人点的mipi屏是横屏分辨率是1024600。
      目前屏幕已点亮,更改了一下logo的分辨率也可以正常显示出来
      但是logo显示出来后就一直停在logo界面不动,并没有进入其他应用的UI界面?
      问:是否还要修改源码其他地方才能进入应用?还是D1 Tina linux本身就没有加载应用?
      如果没有加载应用应该怎么自己去加载一个应用显示其他的图形界面?
        whycan晕哥 LV 9 @WadeDeng 最后由 编辑
        @wadedeng
        串口终端输出什么呢?
        W 2 条回复 最后回复 回复 引用 分享 0
          WadeDeng LV 4 @whycan 最后由 whycan 编辑
          @whycan
          [   22.724104] libphy: 4500000.eth: probed
          [   22.729034] sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (4500000.eth-0:00)
          [   22.833588] br-lan: port 1(eth0) entered blocking state
          [   22.839418] br-lan: port 1(eth0) entered disabled state
          [   22.871473] device eth0 entered promiscuous mode
          [   22.877989] br-lan: port 1(eth0) entered blocking state
          [   22.883861] br-lan: port 1(eth0) entered forwarding state
          [   23.645889] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
          [   23.661255] br-lan: port 1(eth0) entered disabled state
          root@TinaLinux:/# reboot
          root@TinaLinux:/# [   28.709218] sunxi-rtc 7090000.rtc: sunxi_rtc_settime(): wait_bits_cleared() timeout (4)
          [   28.891416] [STA_WRN] !!! xradio_remove_interface: vif_id=0
          [   29.060551] device eth0 left promiscuous mode
          [   29.090415] br-lan: port 1(eth0) entered disabled state
          [   32.465725] android_work: sent uevent USB_STATE=DISCONNECTED
          [   33.973752] reboot_callback(): empty arg
          [   33.978189] sunxi_ohci_hcd_shutdown, ohci0-controller is disable, need not shutdown
          [   33.986874] sunxi_ehci_hcd_shutdown, ehci0-controller is disable, need not shutdown
          [   33.996079] [ohci1-controller]: ohci shutdown start
          [   34.001657] [ohci1-controller]: ohci shutdown end
          [   34.006921] [ehci1-controller]: ehci shutdown start
          [   34.012418] [ehci1-controller]: ehci shutdown end
          [   34.018159] [DISP] disp_lcd_disable,line:2140:
          [   34.018163] lcd 0
          [   34.025513] [DISP] disp_sys_pwm_disable,line:496:
          [   34.025519] disp_sys_pwm_Disable pwm 2
          [   34.035049] [DISP] disp_sys_pwm_set_polarity,line:536:
          [   34.035056] disp_sys_pwm_Set_Polarity pwm 2, active low
          [   34.046691] [DISP] disp_sys_pwm_free,line:462:
          [   34.046695] disp_sys_pwm_free pwm 2
          [   34.055570] [DISP] disp_lcd_disable,line:2166:
          [   34.055576] close flow:step 0 finish, to delay 0
          [   34.141146] [DISP] disp_lcd_disable,line:2166:
          [   34.141152] close flow:step 1 finish, to delay 0
          [   34.151290] [DISP] disp_lcd_disable,line:2166:
          [   34.151295] close flow:step 2 finish, to delay 200
          [   34.371154] [DISP] disp_lcd_pin_cfg,line:1104:
          [   34.371161] lcd 0 pin config, state off, 0
          [   34.431151] [DISP] disp_lcd_disable,line:2166:
          [   34.431157] close flow:step 3 finish, to delay 500
          [   34.951193] [DISP] disp_mgr_disable,line:2826:
          [   34.951198] mgr 0 disable
          [   34.959065] [DISP] disp_enhance_apply,line:126:
          [   34.959069] disp_enhance_apply, screen 0
          [   34.968515] [DISP] bsp_disp_shadow_protect,line:726:
          [   34.968520] sel=0, protect:1,  cnt=1
          [   34.978073] [DISP] de_dcsc_apply,line:74:
          [   34.978081] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
          [   34.989174] [DISP] de_enhance_apply,line:204:
          [   34.989179] disp 0, en=0, sharp=0
          [   34.997769] [DISP] de_peak_enable,line:123:
          [   34.997773] sel=0, chno=0, en=0
          [   35.005960] [DISP] bsp_disp_shadow_protect,line:726:
          [   35.005966] sel=0, protect:0,  cnt=0
          [   35.015525] [DISP] disp_mgr_apply,line:2480:
          [   35.015529] mgr 0 apply
          [   35.023056] [DISP] bsp_disp_shadow_protect,line:726:
          [   35.023061] sel=0, protect:1,  cnt=1
          [   35.032722] [DISP] de_al_lyr_apply,line:485:
          [   35.032728] ch0 z 0 dis
          [   35.040204] [DISP] de_al_lyr_apply,line:485:
          [   35.040207] ch1 z 0 en
          [   35.047620] [DISP] de_al_lyr_apply,line:488:
          [   35.047625] pipe0 z 1 en
          [   35.055235] [DISP] de_al_lyr_apply,line:488:
          [   35.055240] pipe1 z 0 dis
          [   35.062930] [DISP] de_al_lyr_apply,line:503:
          [   35.062934] format[0]=0
          [   35.070417] [DISP] de_calc_overlay_scaler_para,line:178:
          [   35.070422] ovl_rect[0]=<0,0>
          [   35.079682] [DISP] de_calc_overlay_scaler_para,line:180:
          [   35.079688] bld_rect[0]=<0,0,0,0>
          [   35.089315] [DISP] de_calc_ovl_coord,line:389:
          [   35.089320] half_shift_xy=<20000,18,0>
          [   35.098479] [DISP] de_calc_ovl_coord,line:389:
          [   35.098485] half_shift_xy=<20000,18,0>
          [   35.107631] [DISP] de_rtmx_calc_chnrect,line:1982:
          [   35.107636] layernum=4, i=0
          [   35.116125] [DISP] de_rtmx_calc_chnrect,line:1984:
          [   35.116131] crop=<0,0,1024,600>
          [   35.124993] [DISP] de_rtmx_calc_chnrect,line:1986:
          [   35.124998] layer=<0,0,1024,600>
          [   35.133961] [DISP] de_rtmx_calc_chnrect,line:1995:
          [   35.133967] ovl_rect=<0,0,1024,600>
          [   35.143212] [DISP] de_rtmx_calc_chnrect,line:1997:
          [   35.143217] bld_rect=<0,0,1024,600>
          [   35.152461] [DISP] de_calc_overlay_scaler_para,line:178:
          [   35.152467] ovl_rect[1]=<1024,600>
          [   35.162306] [DISP] de_calc_overlay_scaler_para,line:180:
          [   35.162313] bld_rect[1]=<0,0,1024,600>
          [   35.172458] [DISP] de_calc_overlay_scaler_para,line:187:
          [   35.172467] fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
          [   35.186167] [DISP] de_vsu_set_para,line:274:
          [   35.186173] sel0, ch 0, en=0, in<0x0>,out<0x0>
          [   35.195938] [DISP] de_al_lyr_apply,line:713:
          [   35.195945] sel=0, pipe_rect[0]=<0,0,1024,600>
          [   35.205699] [DISP] de_rtmx_set_route,line:1792:
          [   35.205706] sel0, pno0, zorder1, route:0x0
          [   35.215353] [DISP] de_rtmx_set_route,line:1796:
          [   35.215360] addr=0x000000005e20b5c7, reg=0x1
          [   35.225184] [DISP] de_al_lyr_apply,line:713:
          [   35.225190] sel=0, pipe_rect[1]=<0,0,0,0>
          [   35.234447] [DISP] de_rtmx_set_route,line:1792:
          [   35.234453] sel0, pno1, zorder0, route:0x1
          [   35.244083] [DISP] de_rtmx_set_route,line:1796:
          [   35.244089] addr=0x000000005e20b5c7, reg=0x1
          [   35.253933] [DISP] bsp_disp_shadow_protect,line:726:
          [   35.253939] sel=0, protect:0,  cnt=0
          [   35.263496] [DISP] disp_enhance_apply,line:126:
          [   35.263501] disp_enhance_apply, screen 0
          [   35.272955] [DISP] bsp_disp_shadow_protect,line:726:
          [   35.272960] sel=0, protect:1,  cnt=1
          [   35.282496] [DISP] de_dcsc_apply,line:74:
          [   35.282503] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
          [   35.293723] [DISP] de_enhance_apply,line:204:
          [   35.293729] disp 0, en=0, sharp=0
          [   35.302314] [DISP] de_peak_enable,line:123:
          [   35.302320] sel=0, chno=0, en=0
          [   35.310479] [DISP] bsp_disp_shadow_protect,line:726:
          [   35.310483] sel=0, protect:0,  cnt=0
          [   35.331149] [DISP] __de_clk_disable,line:213:
          [   35.331153] clk 1 mod disable
          [   35.339307] [DISP] __de_clk_disable,line:224:
          [   35.339309] clk 1 gate disable
          [   35.347597] [DISP] __de_clk_disable,line:238:
          [   35.347602] clk 1 reset disable
          [   35.356170] reboot: Restarting system
          sbi reboot
          [45]HELLO! BOOT0 is starting!
          [48]BOOT0 commit : 27369ab
          [50]set pll start
          [52]periph0 has been enabled
          [55]set pll end
          [56][pmu]: bus read error
          [59]board init ok
          [60]DRAM only have internal ZQ!!
          [63]get_pmu_exist() = -1
          [66]DRAM BOOT DRIVE INFO: V0.24
          [69]DRAM CLK = 792 MHz
          [71]DRAM Type = 3 (2:DDR2,3:DDR3)
          [74]DRAMC ZQ value: 0x7b7bfb
          [77]DRAM ODT value: 0x42.
          [79]ddr_efuse_type: 0x0
          [82]DRAM SIZE =1024 M
          [86]DRAM simple test OK.
          [88]dram size =1024
          [90]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
          [95]block from 8 to 32
          [171]Check is correct.
          [173]dma 0x2f9f8 int is not used yet
          [176]dma 0x2f9f8 int is free, you do not need to free it again
          [182]Entry_name        = opensbi
          [185]Entry_name        = u-boot
          [189]Entry_name        = dtb
          [191]Jump to second Boot.
          OpenSBI v0.6
                  |_|
          Platform Max HARTs     : 1
          Current Hart           : 0
          Runtime SBI Version    : 0.2
          MIDELEG : 0x0000000000000222
          MEDELEG : 0x000000000000b1ff
          PMP3    : 0x0000000000020000-0x0000000000027fff (A,
          U-Boot 2018.05-g0a88ac9-dirty (Nov 02 2021 - 02:22:13 -0400) Allwinner Technology
          [00.275]DRAM:  1 GiB
          [00.277]Relocation Offset is: 3def0000
          [00.281]secure enable bit: 0
          [00.283]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.290]flash init start
          [00.292]workmode = 0,storage type = 0
          [00.298]sunxi-spinand-phy: not detect any munufacture from id table
          [00.304]sunxi-spinand-phy: get spi-nand Model from fdt fail
          [00.310]sunxi-spinand-phy: get phy info from fdt fail
           #: name		size		offset		mask_flags
           0: boot0               0x00100000	0x00000000	1
           1: uboot               0x00300000	0x00100000	1
           2: secure_storage      0x00100000	0x00400000	1
           3: sys                 0x0fb00000	0x00500000	0
          defaults:
          mtdids  : nand0=nand
          [00.648]ubi0: attaching mtd4
          [01.044]ubi0: scanning is finished
          [01.054]ubi0: attached mtd4 (name "sys", size 251 MiB)
          [01.058]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
          [01.065]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
          [01.071]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
          [01.077]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
          [01.082]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
          [01.089]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
          [01.097]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
          [01.105]sunxi flash init ok
          [01.108]line:714 init_clocks
          __clk_init: clk pll_periph0x2 already initialized
          register fix_factor clk error
          [01.118]drv_disp_init
          request pwm success, pwm2:pwm2:0x2000c00.
          [01.135]drv_disp_init finish
          [01.137]boot_gui_init:start
          [01.140]set disp.dev2_output_type fail. using defval=0
          [01.247]boot_gui_init:finish
          [01.357]Uboot-lcd_panel_init
          [01.421]LCD open finish
          [01.584]bmp_name=bootlogo.bmp size 1843254
          1843254 bytes read in 105 ms (16.7 MiB/s)
          [01.907]Loading Environment from SUNXI_FLASH... OK
          [01.940]out of usb burn from boot: not need burn key
          [01.965]update bootcmd
          [01.987]change working_fdt 0x7eaafda8 to 0x7ea8fda8
          [02.008]update dts
          Android's image name: d1-nezha
          [02.942]
          Starting kernel ...
          [    0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
          [    0.000000] Linux version 5.4.61 (dengxiuwei@ubuntu) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #31 PREEMPT Tue Nov 2 08:29:47 UTC 2021
          [    0.000000] cma: Reserved 8 MiB at 0x000000007f800000
          [    0.000000] Zone ranges:
          [    0.000000]   DMA32    [mem 0x0000000040200000-0x000000007fffffff]
          [    0.000000]   node   0: [mem 0x0000000040200000-0x000000007fffffff]
          [    0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000007fffffff]
          [    0.000000] On node 0 totalpages: 261632
          [    0.000000]   DMA32 zone: 3577 pages used for memmap
          [    0.000000]   DMA32 zone: 261632 pages, LIFO batch:63
          [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258055
          [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/sbin/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:recovery@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g0a88ac9-dirty(11/02/2021-
          [    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
          [    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
          [    0.000000] Memory: 1009460K/1046528K available (6082K kernel code, 656K rwdata, 2101K rodata, 192K init, 254K bss, 28876K reserved, 8192K cma-reserved)
          [    0.000000] 	Tasks RCU enabled.
          [    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
          [    0.000022] riscv_timer_clockevent depends on broadcast, but no broadcast function available
          [    0.000319] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
          [    0.000912] Console: colour dummy device 80x25
          [    0.000950] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
          [    0.000967] pid_max: default: 32768 minimum: 301
          [    0.001172] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
          [    0.001196] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
          [    0.002850] ASID allocator initialised with 65536 entries
          [    0.003009] rcu: Hierarchical SRCU implementation.
          [    0.003676] devtmpfs: initialized
          [    0.017910] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
          [    0.018798] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [    0.018827] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
          [    0.019233] pinctrl core: initialized pinctrl subsystem
          [    0.020519] NET: Registered protocol family 16
          [    0.022366] DMA: preallocated 256 KiB pool for atomic allocations
          [    0.022911] cpuidle: using governor menu
          [    0.065147] rtc_ccu: sunxi ccu init OK
          [    0.071445] clock: sunxi ccu init OK
          [    0.072316] clock: sunxi ccu init OK
          [    0.102343] iommu: Default domain type: Translated
          [    0.102506] sunxi iommu: irq = 4
          [    0.103604] SCSI subsystem initialized
          [    0.103915] usbcore: registered new interface driver usbfs
          [    0.103988] usbcore: registered new interface driver hub
          [    0.104097] usbcore: registered new device driver usb
          [    0.104262] mc: Linux media interface: v0.10
          [    0.104314] videodev: Linux video capture interface: v2.00
          [    0.105338] sunxi-msgbox-amp 3003000.msgbox: invalid resource
          [    0.106012] Advanced Linux Sound Architecture Driver Initialized.
          [    0.106619] Bluetooth: Core ver 2.22
          [    0.106691] NET: Registered protocol family 31
          [    0.106701] Bluetooth: HCI device and connection manager initialized
          [    0.106721] Bluetooth: HCI socket layer initialized
          [    0.106736] Bluetooth: L2CAP socket layer initialized
          [    0.106770] Bluetooth: SCO socket layer initialized
          [    0.107034] pwm module init!
          [    0.108462] g2d 5410000.g2d: Adding to iommu group 0
          [    0.108925] G2D: rcq version initialized.major:250
          [    0.109622] input: sunxi-keyboard as /devices/virtual/input/input0
          [    0.111086] clocksource: Switched to clocksource riscv_clocksource
          [    0.122993] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
          [    0.137798] thermal_sys: Registered thermal governor 'step_wise'
          [    0.137804] thermal_sys: Registered thermal governor 'user_space'
          [    0.138311] NET: Registered protocol family 2
          [    0.139083] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
          [    0.139138] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [    0.139240] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [    0.139323] TCP: Hash tables configured (established 8192 bind 8192)
          [    0.139495] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [    0.139554] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
          [    0.139790] NET: Registered protocol family 1
          [    0.140961] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
          [    0.141599] spi spi0: spi0 supply spi not found, using dummy regulator
          [    0.141813] sunxi_spi_resource_get()2062 - [spi0] SPI MASTER MODE
          [    0.141921] sunxi_spi_clk_init()2138 - [spi0] mclk 100000000
          [    0.142617] sunxi_spi_probe()2542 - [spi0]: driver probe succeed, base ffffffd004060000, irq 31
          [    0.144455] Initialise system trusted keyrings
          [    0.144652] workingset: timestamp_bits=62 max_order=18 bucket_order=0
          [    0.151723] squashfs: version 4.0 (2009/01/31) Phillip Lougher
          [    0.172628] Key type asymmetric registered
          [    0.172643] Asymmetric key parser 'x509' registered
          [    0.172665] io scheduler mq-deadline registered
          [    0.172673] io scheduler kyber registered
          [    0.172691] atomic64_test: passed
          [    0.174553] sunxi_sid_init()506 - insmod ok
          [    0.175079] pwm-regulator: supplied by regulator-dummy
          [    0.182109] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
          [    0.182521] uart uart0: get regulator failed
          [    0.182549] uart uart0: uart0 supply uart not found, using dummy regulator
          [    0.182874] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
          [    0.182901] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
          [    0.921894] printk: console [ttyS0] enabled
          [    0.927376] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
          [    0.938763] uart uart1: get regulator failed
          [    0.943586] uart uart1: uart1 supply uart not found, using dummy regulator
          [    0.951620] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
          [    0.961464] misc dump reg init
          [    0.965697] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
          [    0.972940] sunxi-rfkill soc@3000000:rfkill@0: devm_pinctrl_get() failed!
          [    0.980522] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
          [    0.987838] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
          [    0.995251] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
          [    1.001787] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
          [    1.008697] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
          [    1.016420] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
          [    1.024277] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
          [    1.032404] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
          [    1.040028] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
          [    1.046791] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
          [    1.054324] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
          [    1.062533] [ADDR_MGT] addr_mgt_probe: module version: v1.0.9
          [    1.069943] [ADDR_MGT] addr_mgt_probe: success.
          [    1.075924] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
          [    1.083199] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
          [    1.091062] sunxi-spinand-phy: not detect any munufacture from id table
          [    1.098477] sunxi-spinand-phy: get spi-nand Model from fdt fail
          [    1.105129] sunxi-spinand-phy: get phy info from fdt fail
          [    1.111176] sunxi-spinand-phy: not detect munufacture from fdt
          [    1.117845] sunxi-spinand-phy: detect munufacture from id table: Mxic
          [    1.125058] sunxi-spinand-phy: detect spinand id: ff0326c2 ffffffff
          [    1.132064] sunxi-spinand-phy: ========== arch info ==========
          [    1.138566] sunxi-spinand-phy: Model:               MX35LF2GE4AD
          [    1.145280] sunxi-spinand-phy: Munufacture:         Mxic
          [    1.151222] sunxi-spinand-phy: DieCntPerChip:       1
          [    1.156850] sunxi-spinand-phy: BlkCntPerDie:        2048
          [    1.162788] sunxi-spinand-phy: PageCntPerBlk:       64
          [    1.168513] sunxi-spinand-phy: SectCntPerPage:      4
          [    1.174162] sunxi-spinand-phy: OobSizePerPage:      64
          [    1.179886] sunxi-spinand-phy: BadBlockFlag:        0x1
          [    1.185726] sunxi-spinand-phy: OperationOpt:        0x7
          [    1.191570] sunxi-spinand-phy: MaxEraseTimes:       65000
          [    1.197585] sunxi-spinand-phy: EccFlag:             0x2
          [    1.203428] sunxi-spinand-phy: EccType:             8
          [    1.209055] sunxi-spinand-phy: EccProtectedType:    3
          [    1.214703] sunxi-spinand-phy: ========================================
          [    1.222094] sunxi-spinand-phy:
          [    1.225593] sunxi-spinand-phy: ========== physical info ==========
          [    1.232500] sunxi-spinand-phy: TotalSize:    256 M
          [    1.237838] sunxi-spinand-phy: SectorSize:   512 B
          [    1.243196] sunxi-spinand-phy: PageSize:     2 K
          [    1.248340] sunxi-spinand-phy: BlockSize:    128 K
          [    1.253697] sunxi-spinand-phy: OOBSize:      64 B
          [    1.258936] sunxi-spinand-phy: ========================================
          [    1.266328] sunxi-spinand-phy:
          [    1.269825] sunxi-spinand-phy: ========== logical info ==========
          [    1.276637] sunxi-spinand-phy: TotalSize:    256 M
          [    1.281996] sunxi-spinand-phy: SectorSize:   512 B
          [    1.287331] sunxi-spinand-phy: PageSize:     4 K
          [    1.292495] sunxi-spinand-phy: BlockSize:    256 K
          [    1.297830] sunxi-spinand-phy: OOBSize:      128 B
          [    1.303186] sunxi-spinand-phy: ========================================
          [    1.310676] sunxi-spinand-phy: block lock register: 0x00
          [    1.316792] sunxi-spinand-phy: feature register: 0x11
          [    1.322465] sunxi-spinand-phy: sunxi physic nand init end
          [    1.329073] Creating 4 MTD partitions on "sunxi_mtd_nand":
          [    1.335282] 0x000000000000-0x000000100000 : "boot0"
          [    1.352178] 0x000000100000-0x000000500000 : "uboot"
          [    1.360497] random: fast init done
          [    1.392130] 0x000000500000-0x000000600000 : "secure_storage"
          [    1.412226] 0x000000600000-0x000010000000 : "sys"
          [    1.788004] random: crng init done
          [    2.492634] libphy: Fixed MDIO Bus: probed
          [    2.497206] CAN device driver interface
          [    2.502606] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
          [    2.513909] sunxi gmac driver's version: 1.0.0
          [    2.519020] gmac-power0: NULL
          [    2.522374] gmac-power1: NULL
          [    2.525680] gmac-power2: NULL
          [    2.530114] Failed to alloc md5
          [    2.533706] eth0: Use random mac address
          [    2.538415] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
          [    2.545789] sunxi-ehci: EHCI SUNXI driver
          [    2.550774] get ehci1-controller wakeup-source is fail.
          [    2.556786] sunxi ehci1-controller don't init wakeup source
          [    2.563081] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe0008f5270, 0x:ffffffd00406e000, irq_no:31
          [    2.576636] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
          [    2.589208] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
          [    2.596501] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
          [    2.606325] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
          [    2.641124] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
          [    2.649817] hub 1-0:1.0: USB hub found
          [    2.654112] hub 1-0:1.0: 1 port detected
          [    2.659265] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
          [    2.666258] sunxi-ohci: OHCI SUNXI driver
          [    2.671327] get ohci1-controller wakeup-source is fail.
          [    2.677269] sunxi ohci1-controller don't init wakeup source
          [    2.683528] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0008f5db0
          [    2.693958] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
          [    2.706473] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
          [    2.713730] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
          [    2.723509] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
          [    2.806018] hub 2-0:1.0: USB hub found
          [    2.810247] hub 2-0:1.0: 1 port detected
          [    2.815679] usbcore: registered new interface driver uas
          [    2.821844] usbcore: registered new interface driver usb-storage
          [    2.828618] usbcore: registered new interface driver ums-alauda
          [    2.835361] usbcore: registered new interface driver ums-cypress
          [    2.842166] usbcore: registered new interface driver ums-datafab
          [    2.848919] usbcore: registered new interface driver ums_eneub6250
          [    2.855912] usbcore: registered new interface driver ums-freecom
          [    2.862712] usbcore: registered new interface driver ums-isd200
          [    2.869371] usbcore: registered new interface driver ums-jumpshot
          [    2.876280] usbcore: registered new interface driver ums-karma
          [    2.882892] usbcore: registered new interface driver ums-onetouch
          [    2.889768] usbcore: registered new interface driver ums-realtek
          [    2.896574] usbcore: registered new interface driver ums-sddr09
          [    2.903278] usbcore: registered new interface driver ums-sddr55
          [    2.909935] usbcore: registered new interface driver ums-usbat
          [    2.917533] sunxi_gpadc_init,1968, success
          [    2.924263] sunxi-rtc 7090000.rtc: registered as rtc0
          [    2.930011] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:54:29 UTC (3269)
          [    2.939227] sunxi-rtc 7090000.rtc: sunxi rtc probed
          [    2.945099] i2c /dev entries driver
          [    2.949081] IR NEC protocol handler initialized
          [    2.954828] sunxi cedar version 1.1
          [    2.958970] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
          [    2.965254] VE: install start!!!
          [    2.965254]
          [    2.970729] VE: cedar-ve the get irq is 6
          [    2.970729]
          [    2.977074] VE: ve_debug_proc_info:000000000a239374, data:000000000ce3bb86, lock:00000000338eebbe
          [    2.977074]
          [    2.988654] VE: install end!!!
          [    2.988654]
          [    2.995023] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
          [    3.004171] Bluetooth: HCI UART driver ver 2.3
          [    3.009129] Bluetooth: HCI UART protocol H4 registered
          [    3.014895] Bluetooth: HCI UART protocol BCSP registered
          [    3.020818] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
          [    3.028074] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
          [    3.034491] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
          [    3.041021] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
          [    3.041021]
          [    3.049690] [XR_BT_LPM] bluesleep_probe: uart_index(1)
          [    3.058524] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
          [    3.068482] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
          [    3.074689] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
          [    3.081000] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
          [    3.087432] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
          [    3.093863] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
          [    3.100366] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
          [    3.106891] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
          [    3.113417] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
          [    3.120351] sunxi-mmc 4020000.sdmmc: Got CD GPIO
          [    3.125856] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
          [    3.132516] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.143649] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
          [    3.163785] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.188143] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
          [    3.193850] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [    3.205615] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.19 2021-03-24 19:50)
          [    3.215666] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
          [    3.221905] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
          [    3.228220] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
          [    3.234654] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
          [    3.241062] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
          [    3.247586] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
          [    3.254115] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
          [    3.260620] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
          [    3.267167] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
          [    3.276593] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.287731] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [    3.307864] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.332050] sunxi-mmc 4021000.sdmmc: detmode:manually by software
          [    3.339689] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    3.346707] sunxi_led_probe()1715 - start
          [    3.351199] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
          [    3.358068] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.369666] sunxi_get_str_of_property()1560 - failed to get the string of propname led_regulator!
          [    3.379605] sunxi_register_led_classdev()1448 - led_classdev start
          [    3.389582] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [    3.402699] sunxi_led_probe()1820 - finish
          [    3.407839] usbcore: registered new interface driver usbhid
          [    3.414198] usbhid: USB HID core driver
          [    3.419331] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    3.426756] [DISP]disp_module_init
          [    3.430570] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    3.437882] disp 5000000.disp: Adding to iommu group 0
          [    3.443632] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    3.450520] [DISP] disp_probe,line:2958:
          [    3.450525] [DISP]disp_probe
          [    3.454912] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
          [    3.464902] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
          [    3.476390] [DISP] disp_init,line:2301:
          [    3.476395] disp_init !
          [    3.483548] [DISP] parser_disp_init_para,line:1283:
          [    3.483553] of_property_read screen0_output_format fail
          [    3.494878] [DISP] parser_disp_init_para,line:1290:
          [    3.494883] of_property_read screen0_output_bits fail
          [    3.505969] [DISP] parser_disp_init_para,line:1297:
          [    3.505974] of_property_read screen0_output_eotf fail
          [    3.517057] [DISP] parser_disp_init_para,line:1304:
          [    3.517061] of_property_read screen0_output_cs fail
          [    3.527948] [DISP] parser_disp_init_para,line:1311:
          [    3.527952] of_property_read screen0_output_dvi_hdmi fail
          [    3.539424] [DISP] parser_disp_init_para,line:1318:
          [    3.539428] of_property_read screen0_output_range fail
          [    3.550608] [DISP] parser_disp_init_para,line:1325:
          [    3.550612] of_property_read screen0_output_scan fail
          [    3.561714] [DISP] parser_disp_init_para,line:1332:
          [    3.561719] of_property_read screen0_output_aspect_ratio fail
          [    3.573620] [DISP] parser_disp_init_para,line:1475:
          [    3.573623] ====display init para begin====
          [    3.583734] [DISP] parser_disp_init_para,line:1476:
          [    3.583738] b_init:1
          [    3.591620] [DISP] parser_disp_init_para,line:1477:
          [    3.591624] disp_mode:0
          [    3.591624]
          [    3.601443] [DISP] parser_disp_init_para,line:1479:
          [    3.601447] output_type[0]:1
          [    3.610080] [DISP] parser_disp_init_para,line:1480:
          [    3.610084] output_mode[0]:0
          [    3.618740] [DISP] parser_disp_init_para,line:1479:
          [    3.618745] output_type[1]:4
          [    3.627404] [DISP] parser_disp_init_para,line:1480:
          [    3.627408] output_mode[1]:10
          [    3.636160] [DISP] parser_disp_init_para,line:1483:
          [    3.636164] buffer_num[0]:2
          [    3.644723] [DISP] parser_disp_init_para,line:1484:
          [    3.644727] format[0]:0
          [    3.652900] [DISP] parser_disp_init_para,line:1485:
          [    3.652905] fb_width[0]:0
          [    3.661271] [DISP] parser_disp_init_para,line:1486:
          [    3.661276] fb_height[0]:0
          [    3.669715] [DISP] parser_disp_init_para,line:1483:
          [    3.669718] buffer_num[1]:2
          [    3.678280] [DISP] parser_disp_init_para,line:1484:
          [    3.678284] format[1]:0
          [    3.686460] [DISP] parser_disp_init_para,line:1485:
          [    3.686464] fb_width[1]:0
          [    3.694833] [DISP] parser_disp_init_para,line:1486:
          [    3.694837] fb_height[1]:0
          [    3.703298] [DISP] parser_disp_init_para,line:1488:
          [    3.703302] ====display init para end====
          [    3.713218] [DISP] disp_init,line:2323:
          [    3.713224] mod 0, base=0xffffffd004100000, irq=0
          [    3.722750] [DISP] disp_init,line:2323:
          [    3.722755] mod 1, base=0xffffffd0040ec000, irq=0
          [    3.732282] [DISP] disp_init,line:2323:
          [    3.732287] mod 2, base=0xffffffd0040ee000, irq=30
          [    3.741911] [DISP] disp_init,line:2323:
          [    3.741917] mod 3, base=0xffffffd0040f0000, irq=32
          [    3.751540] [DISP] disp_init,line:2323:
          [    3.751545] mod 4, base=0x0, irq=0
          [    3.759597] [DISP] disp_init,line:2323:
          [    3.759601] mod 5, base=0x0, irq=0
          [    3.767674] [DISP] disp_init,line:2323:
          [    3.767680] mod 6, base=0xffffffd0040f2000, irq=33
          [    3.777305] [DISP] disp_init,line:2323:
          [    3.777309] mod 7, base=0x0, irq=0
          [    3.785384] [DISP] disp_init,line:2323:
          [    3.785389] mod 8, base=0x0, irq=0
          [    3.793461] [DISP] disp_init,line:2323:
          [    3.793466] mod 9, base=0x0, irq=0
          [    3.801541] [DISP] disp_init,line:2323:
          [    3.801546] mod 10, base=0x0, irq=0
          [    3.809696] [DISP] disp_init,line:2323:
          [    3.809700] mod 11, base=0x0, irq=0
          [    3.817869] [DISP] disp_init,line:2323:
          [    3.817874] mod 12, base=0x0, irq=0
          [    3.826045] [DISP] disp_init,line:2323:
          [    3.826050] mod 13, base=0x0, irq=0
          [    3.834222] [DISP] disp_init,line:2323:
          [    3.834227] mod 14, base=0x0, irq=0
          [    3.842400] [DISP] disp_init,line:2323:
          [    3.842405] mod 15, base=0x0, irq=0
          [    3.850558] [DISP] disp_boot_para_parse,line:1189:
          [    3.850562] [DISP] boot_disp:0x104
          [    3.859696] [DISP] disp_boot_para_parse,line:1189:
          [    3.859701] [DISP] boot_disp1:0x1040000
          [    3.869328] [DISP] disp_boot_para_parse,line:1189:
          [    3.869333] [DISP] boot_disp2:0x4
          [    3.878375] [DISP] disp_init,line:2374:
          [    3.878379] output_type=1
          [    3.882672] [DISP] disp_init,line:2384:
          [    3.885586] 0:para->boot_info.sync=1
          [    3.889856] [DISP] disp_init,line:2412:
          [    3.893860] smooth display screen:0 type:1 mode:4
          [    3.903386] [DISP] disp_init,line:2429:
          [    3.903390] disp_init 111!
          [    3.910668] [DISP] bsp_disp_init,line:26:
          [    3.910671] bsp_disp_init 1!
          [    3.918366] [DISP] bsp_disp_init,line:39:
          [    3.918370] bsp_disp_init 2!
          [    3.926066] [DISP] de_rtmx_set_gld_reg_base,line:499:
          [    3.926074] sel=0x0, addr=0x000000002d8c56b2
          [    3.936483] [DISP] de_rtmx_init,line:296:
          [    3.936489] malloc memory ok(0x000000001d8f3a54) for video channel
          [    3.947859] [DISP] de_rtmx_set_overlay_reg_base,line:538:
          [    3.947866] sel=0x0, overlayer 0, addr=0x000000001d8f3a54
          [    3.959919] [DISP] de_rtmx_set_overlay_reg_base,line:538:
          [    3.959926] sel=0x0, overlayer 1, addr=0x0000000016cdf1a6
          [    3.971999] [DISP] de_rtmx_set_bld_reg_base,line:516:
          [    3.972005] sel=0, base=0x00000000f2a9edaa
          [    3.982220] [DISP] de_vsu_set_reg_base,line:197:
          [    3.982227] sel=0, chno=0, base=0x00000000a74153d7
          [    3.992731] [DISP] de_gsu_set_reg_base,line:165:
          [    3.992736] sel=0, chno=0, base=0x00000000dbe41b00
          [    4.003237] [DISP] de_rtmx_set_gld_reg_base,line:499:
          [    4.003242] sel=0x1, addr=0x0000000039842404
          [    4.013654] [DISP] de_rtmx_init,line:296:
          [    4.013660] malloc memory ok(0x000000007448a13f) for video channel
          [    4.025035] [DISP] de_rtmx_set_overlay_reg_base,line:538:
          [    4.025041] sel=0x1, overlayer 0, addr=0x000000007448a13f
          [    4.037104] [DISP] de_rtmx_set_bld_reg_base,line:516:
          [    4.037109] sel=1, base=0x00000000630952f8
          [    4.047331] [DISP] de_vsu_set_reg_base,line:197:
          [    4.047337] sel=1, chno=0, base=0x0000000034a9b830
          [    4.057849] [DISP] de_lti_init,line:69:
          [    4.057855] sel 0, lti_base[0]=0x000000000664745c
          [    4.067390] [DISP] de_peak_init,line:79:
          [    4.067397] sel 0, peak_base[0]=0x000000004ae4c459
          [    4.077124] [DISP] de_peak_set_reg_base,line:44:
          [    4.077131] sel=0, chno=0, base=0x00000000832de440
          [    4.087628] [DISP] de_ase_init,line:68:
          [    4.087634] sel 0, ase_base[0]=0x00000000b020fdc7
          [    4.097170] [DISP] de_ccsc_set_reg_base,line:48:
          [    4.097177] sel=0, chno=0, base=0x00000000fde2e11f
          [    4.107679] [DISP] de_ccsc_init,line:214:
          [    4.107685] sel0, Icsc_base[0]=0x000000009d168b43
          [    4.117409] [DISP] de_icsc_set_reg_base,line:56:
          [    4.117415] sel=0, chno=0, base=0x000000005cf30050
          [    4.127920] [DISP] de_ccsc_set_reg_base,line:48:
          [    4.127927] sel=1, chno=0, base=0x000000003733ae12
          [    4.138427] [DISP] de_dcsc_init,line:177:
          [    4.138433] sel 0, Dcsc_base=0x0000000090de15a8
          [    4.147966] [DISP] de_dcsc_set_reg_base,line:40:
          [    4.147972] sel=0, base=0x00000000b81aa647
          [    4.157696] [DISP] de_dcsc_init,line:177:
          [    4.157701] sel 1, Dcsc_base=0x000000001dbdcbf3
          [    4.167231] [DISP] de_dcsc_set_reg_base,line:40:
          [    4.167237] sel=1, base=0x00000000ec02e71c
          [    4.176961] [DISP] wb_ebios_set_reg_base,line:75:
          [    4.176967] sel=0, base=0x0000000044ddf29d
          [    4.186806] [DISP] disp_init_lcd,line:3064:
          [    4.186811] disp_init_lcd
          [    4.194627] [DISP] disp_init_lcd,line:3138:
          [    4.194632] total number of clk in dsi:1
          [    4.203693] [DISP] disp_init_lcd,line:3142:
          [    4.203698] lcd 0, irq_no=30, irq_no_dsi=33
          [    4.213631] [DISP] disp_sys_script_get_item,line:222:
          [    4.213637] of_property_read_string lcd0.lcd_bl_en_power fail
          [    4.225912] [DISP] disp_sys_script_get_item,line:222:
          [    4.225918] of_property_read_string lcd0.lcd_power fail
          [    4.237610] [DISP] disp_sys_script_get_item,line:222:
          [    4.237615] of_property_read_string lcd0.lcd_power1 fail
          [    4.249405] [DISP] disp_sys_script_get_item,line:222:
          [    4.249411] of_property_read_string lcd0.lcd_power2 fail
          [    4.261238] [DISP] disp_sys_script_get_item,line:222:
          [    4.261244] of_property_read_string lcd0.lcd_power3 fail
          [    4.273043] [DISP] disp_sys_script_get_item,line:243:
          [    4.273050] lcd0.lcd_gpio_0 gpio=205, value:1
          [    4.285233] [DISP] disp_sys_script_get_item,line:222:
          [    4.285238] of_property_read_string lcd0.lcd_gpio_power0 fail
          [    4.297490] [DISP] disp_sys_script_get_item,line:222:
          [    4.297496] of_property_read_string lcd0.lcd_gpio_power1 fail
          [    4.309746] [DISP] disp_sys_script_get_item,line:222:
          [    4.309752] of_property_read_string lcd0.lcd_gpio_power2 fail
          [    4.322018] [DISP] disp_sys_script_get_item,line:222:
          [    4.322024] of_property_read_string lcd0.lcd_pin_power fail
          [    4.334078] [DISP] disp_sys_script_get_item,line:222:
          [    4.334084] of_property_read_string lcd0.lcd_pin_power1 fail
          [    4.346237] [DISP] disp_sys_script_get_item,line:222:
          [    4.346242] of_property_read_string lcd0.lcd_pin_power2 fail
          [    4.358400] [DISP] disp_sys_script_get_item,line:214:
          [    4.358405] of_property_read_u32_array lcd0.lcd_bl_0_percent fail
          [    4.371045] [DISP] disp_sys_script_get_item,line:214:
          [    4.371050] of_property_read_u32_array lcd0.lcd_bl_1_percent fail
          [    4.383707] [DISP] disp_sys_script_get_item,line:214:
          [    4.383712] of_property_read_u32_array lcd0.lcd_bl_2_percent fail
          [    4.396348] [DISP] disp_sys_script_get_item,line:214:
          [    4.396354] of_property_read_u32_array lcd0.lcd_bl_3_percent fail
          [    4.408993] [DISP] disp_sys_script_get_item,line:214:
          [    4.408999] of_property_read_u32_array lcd0.lcd_bl_4_percent fail
          [    4.421658] [DISP] disp_sys_script_get_item,line:214:
          [    4.421664] of_property_read_u32_array lcd0.lcd_bl_5_percent fail
          [    4.434301] [DISP] disp_sys_script_get_item,line:214:
          [    4.434307] of_property_read_u32_array lcd0.lcd_bl_6_percent fail
          [    4.446944] [DISP] disp_sys_script_get_item,line:214:
          [    4.446950] of_property_read_u32_array lcd0.lcd_bl_7_percent fail
          [    4.459589] [DISP] disp_sys_script_get_item,line:214:
          [    4.459594] of_property_read_u32_array lcd0.lcd_bl_8_percent fail
          [    4.472252] [DISP] disp_sys_script_get_item,line:214:
          [    4.472257] of_property_read_u32_array lcd0.lcd_bl_9_percent fail
          [    4.484893] [DISP] disp_sys_script_get_item,line:214:
          [    4.484898] of_property_read_u32_array lcd0.lcd_bl_10_percent fail
          [    4.497632] [DISP] disp_sys_script_get_item,line:214:
          [    4.497638] of_property_read_u32_array lcd0.lcd_bl_11_percent fail
          [    4.510375] [DISP] disp_sys_script_get_item,line:214:
          [    4.510380] of_property_read_u32_array lcd0.lcd_bl_12_percent fail
          [    4.523134] [DISP] disp_sys_script_get_item,line:214:
          [    4.523140] of_property_read_u32_array lcd0.lcd_bl_13_percent fail
          [    4.535877] [DISP] disp_sys_script_get_item,line:214:
          [    4.535883] of_property_read_u32_array lcd0.lcd_bl_14_percent fail
          [    4.548618] [DISP] disp_sys_script_get_item,line:214:
          [    4.548623] of_property_read_u32_array lcd0.lcd_bl_15_percent fail
          [    4.561379] [DISP] disp_sys_script_get_item,line:214:
          [    4.561385] of_property_read_u32_array lcd0.lcd_bl_16_percent fail
          [    4.574118] [DISP] disp_sys_script_get_item,line:214:
          [    4.574124] of_property_read_u32_array lcd0.lcd_bl_17_percent fail
          [    4.586858] [DISP] disp_sys_script_get_item,line:214:
          [    4.586863] of_property_read_u32_array lcd0.lcd_bl_18_percent fail
          [    4.599601] [DISP] disp_sys_script_get_item,line:214:
          [    4.599606] of_property_read_u32_array lcd0.lcd_bl_19_percent fail
          [    4.612363] [DISP] disp_sys_script_get_item,line:214:
          [    4.612368] of_property_read_u32_array lcd0.lcd_bl_20_percent fail
          [    4.625104] [DISP] disp_sys_script_get_item,line:214:
          [    4.625109] of_property_read_u32_array lcd0.lcd_bl_21_percent fail
          [    4.637845] [DISP] disp_sys_script_get_item,line:214:
          [    4.637851] of_property_read_u32_array lcd0.lcd_bl_22_percent fail
          [    4.650587] [DISP] disp_sys_script_get_item,line:214:
          [    4.650593] of_property_read_u32_array lcd0.lcd_bl_23_percent fail
          [    4.663346] [DISP] disp_sys_script_get_item,line:214:
          [    4.663352] of_property_read_u32_array lcd0.lcd_bl_24_percent fail
          [    4.676087] [DISP] disp_sys_script_get_item,line:214:
          [    4.676093] of_property_read_u32_array lcd0.lcd_bl_25_percent fail
          [    4.688833] [DISP] disp_sys_script_get_item,line:214:
          [    4.688838] of_property_read_u32_array lcd0.lcd_bl_26_percent fail
          [    4.701592] [DISP] disp_sys_script_get_item,line:214:
          [    4.701598] of_property_read_u32_array lcd0.lcd_bl_27_percent fail
          [    4.714336] [DISP] disp_sys_script_get_item,line:214:
          [    4.714341] of_property_read_u32_array lcd0.lcd_bl_28_percent fail
          [    4.727077] [DISP] disp_sys_script_get_item,line:214:
          [    4.727083] of_property_read_u32_array lcd0.lcd_bl_29_percent fail
          [    4.739817] [DISP] disp_sys_script_get_item,line:214:
          [    4.739823] of_property_read_u32_array lcd0.lcd_bl_30_percent fail
          [    4.752578] [DISP] disp_sys_script_get_item,line:214:
          [    4.752583] of_property_read_u32_array lcd0.lcd_bl_31_percent fail
          [    4.765318] [DISP] disp_sys_script_get_item,line:214:
          [    4.765323] of_property_read_u32_array lcd0.lcd_bl_32_percent fail
          [    4.778054] [DISP] disp_sys_script_get_item,line:214:
          [    4.778059] of_property_read_u32_array lcd0.lcd_bl_33_percent fail
          [    4.790795] [DISP] disp_sys_script_get_item,line:214:
          [    4.790800] of_property_read_u32_array lcd0.lcd_bl_34_percent fail
          [    4.803557] [DISP] disp_sys_script_get_item,line:214:
          [    4.803563] of_property_read_u32_array lcd0.lcd_bl_35_percent fail
          [    4.816299] [DISP] disp_sys_script_get_item,line:214:
          [    4.816305] of_property_read_u32_array lcd0.lcd_bl_36_percent fail
          [    4.829041] [DISP] disp_sys_script_get_item,line:214:
          [    4.829047] of_property_read_u32_array lcd0.lcd_bl_37_percent fail
          [    4.841800] [DISP] disp_sys_script_get_item,line:214:
          [    4.841806] of_property_read_u32_array lcd0.lcd_bl_38_percent fail
          [    4.854538] [DISP] disp_sys_script_get_item,line:214:
          [    4.854543] of_property_read_u32_array lcd0.lcd_bl_39_percent fail
          [    4.867280] [DISP] disp_sys_script_get_item,line:214:
          [    4.867286] of_property_read_u32_array lcd0.lcd_bl_40_percent fail
          [    4.880023] [DISP] disp_sys_script_get_item,line:214:
          [    4.880028] of_property_read_u32_array lcd0.lcd_bl_41_percent fail
          [    4.892785] [DISP] disp_sys_script_get_item,line:214:
          [    4.892790] of_property_read_u32_array lcd0.lcd_bl_42_percent fail
          [    4.905525] [DISP] disp_sys_script_get_item,line:214:
          [    4.905531] of_property_read_u32_array lcd0.lcd_bl_43_percent fail
          [    4.918267] [DISP] disp_sys_script_get_item,line:214:
          [    4.918273] of_property_read_u32_array lcd0.lcd_bl_44_percent fail
          [    4.931006] [DISP] disp_sys_script_get_item,line:214:
          [    4.931012] of_property_read_u32_array lcd0.lcd_bl_45_percent fail
          [    4.943767] [DISP] disp_sys_script_get_item,line:214:
          [    4.943773] of_property_read_u32_array lcd0.lcd_bl_46_percent fail
          [    4.956510] [DISP] disp_sys_script_get_item,line:214:
          [    4.956516] of_property_read_u32_array lcd0.lcd_bl_47_percent fail
          [    4.969269] [DISP] disp_sys_script_get_item,line:214:
          [    4.969274] of_property_read_u32_array lcd0.lcd_bl_48_percent fail
          [    4.982029] [DISP] disp_sys_script_get_item,line:214:
          [    4.982035] of_property_read_u32_array lcd0.lcd_bl_49_percent fail
          [    4.994771] [DISP] disp_sys_script_get_item,line:214:
          [    4.994776] of_property_read_u32_array lcd0.lcd_bl_50_percent fail
          [    5.007514] [DISP] disp_sys_script_get_item,line:214:
          [    5.007520] of_property_read_u32_array lcd0.lcd_bl_51_percent fail
          [    5.020259] [DISP] disp_sys_script_get_item,line:214:
          [    5.020265] of_property_read_u32_array lcd0.lcd_bl_52_percent fail
          [    5.033018] [DISP] disp_sys_script_get_item,line:214:
          [    5.033024] of_property_read_u32_array lcd0.lcd_bl_53_percent fail
          [    5.045757] [DISP] disp_sys_script_get_item,line:214:
          [    5.045763] of_property_read_u32_array lcd0.lcd_bl_54_percent fail
          [    5.058499] [DISP] disp_sys_script_get_item,line:214:
          [    5.058504] of_property_read_u32_array lcd0.lcd_bl_55_percent fail
          [    5.071274] [DISP] disp_sys_script_get_item,line:214:
          [    5.071281] of_property_read_u32_array lcd0.lcd_bl_56_percent fail
          [    5.084003] [DISP] disp_sys_script_get_item,line:214:
          [    5.084009] of_property_read_u32_array lcd0.lcd_bl_57_percent fail
          [    5.096741] [DISP] disp_sys_script_get_item,line:214:
          [    5.096747] of_property_read_u32_array lcd0.lcd_bl_58_percent fail
          [    5.109484] [DISP] disp_sys_script_get_item,line:214:
          [    5.109490] of_property_read_u32_array lcd0.lcd_bl_59_percent fail
          [    5.122244] [DISP] disp_sys_script_get_item,line:214:
          [    5.122250] of_property_read_u32_array lcd0.lcd_bl_60_percent fail
          [    5.134987] [DISP] disp_sys_script_get_item,line:214:
          [    5.134993] of_property_read_u32_array lcd0.lcd_bl_61_percent fail
          [    5.147729] [DISP] disp_sys_script_get_item,line:214:
          [    5.147735] of_property_read_u32_array lcd0.lcd_bl_62_percent fail
          [    5.160472] [DISP] disp_sys_script_get_item,line:214:
          [    5.160478] of_property_read_u32_array lcd0.lcd_bl_63_percent fail
          [    5.173232] [DISP] disp_sys_script_get_item,line:214:
          [    5.173238] of_property_read_u32_array lcd0.lcd_bl_64_percent fail
          [    5.185975] [DISP] disp_sys_script_get_item,line:214:
          [    5.185981] of_property_read_u32_array lcd0.lcd_bl_65_percent fail
          [    5.198717] [DISP] disp_sys_script_get_item,line:214:
          [    5.198723] of_property_read_u32_array lcd0.lcd_bl_66_percent fail
          [    5.211477] [DISP] disp_sys_script_get_item,line:214:
          [    5.211483] of_property_read_u32_array lcd0.lcd_bl_67_percent fail
          [    5.224219] [DISP] disp_sys_script_get_item,line:214:
          [    5.224224] of_property_read_u32_array lcd0.lcd_bl_68_percent fail
          [    5.236960] [DISP] disp_sys_script_get_item,line:214:
          [    5.236965] of_property_read_u32_array lcd0.lcd_bl_69_percent fail
          [    5.249696] [DISP] disp_sys_script_get_item,line:214:
          [    5.249702] of_property_read_u32_array lcd0.lcd_bl_70_percent fail
          [    5.262459] [DISP] disp_sys_script_get_item,line:214:
          [    5.262465] of_property_read_u32_array lcd0.lcd_bl_71_percent fail
          [    5.275201] [DISP] disp_sys_script_get_item,line:214:
          [    5.275207] of_property_read_u32_array lcd0.lcd_bl_72_percent fail
          [    5.287944] [DISP] disp_sys_script_get_item,line:214:
          [    5.287950] of_property_read_u32_array lcd0.lcd_bl_73_percent fail
          [    5.300690] [DISP] disp_sys_script_get_item,line:214:
          [    5.300695] of_property_read_u32_array lcd0.lcd_bl_74_percent fail
          [    5.313451] [DISP] disp_sys_script_get_item,line:214:
          [    5.313457] of_property_read_u32_array lcd0.lcd_bl_75_percent fail
          [    5.326192] [DISP] disp_sys_script_get_item,line:214:
          [    5.326197] of_property_read_u32_array lcd0.lcd_bl_76_percent fail
          [    5.338936] [DISP] disp_sys_script_get_item,line:214:
          [    5.338942] of_property_read_u32_array lcd0.lcd_bl_77_percent fail
          [    5.351701] [DISP] disp_sys_script_get_item,line:214:
          [    5.351706] of_property_read_u32_array lcd0.lcd_bl_78_percent fail
          [    5.364444] [DISP] disp_sys_script_get_item,line:214:
          [    5.364449] of_property_read_u32_array lcd0.lcd_bl_79_percent fail
          [    5.377188] [DISP] disp_sys_script_get_item,line:214:
          [    5.377193] of_property_read_u32_array lcd0.lcd_bl_80_percent fail
          [    5.389932] [DISP] disp_sys_script_get_item,line:214:
          [    5.389938] of_property_read_u32_array lcd0.lcd_bl_81_percent fail
          [    5.402694] [DISP] disp_sys_script_get_item,line:214:
          [    5.402700] of_property_read_u32_array lcd0.lcd_bl_82_percent fail
          [    5.415435] [DISP] disp_sys_script_get_item,line:214:
          [    5.415441] of_property_read_u32_array lcd0.lcd_bl_83_percent fail
          [    5.428177] [DISP] disp_sys_script_get_item,line:214:
          [    5.428182] of_property_read_u32_array lcd0.lcd_bl_84_percent fail
          [    5.440919] [DISP] disp_sys_script_get_item,line:214:
          [    5.440924] of_property_read_u32_array lcd0.lcd_bl_85_percent fail
          [    5.453682] [DISP] disp_sys_script_get_item,line:214:
          [    5.453688] of_property_read_u32_array lcd0.lcd_bl_86_percent fail
          [    5.466424] [DISP] disp_sys_script_get_item,line:214:
          [    5.466429] of_property_read_u32_array lcd0.lcd_bl_87_percent fail
          [    5.479165] [DISP] disp_sys_script_get_item,line:214:
          [    5.479170] of_property_read_u32_array lcd0.lcd_bl_88_percent fail
          [    5.491927] [DISP] disp_sys_script_get_item,line:214:
          [    5.491932] of_property_read_u32_array lcd0.lcd_bl_89_percent fail
          [    5.504667] [DISP] disp_sys_script_get_item,line:214:
          [    5.504673] of_property_read_u32_array lcd0.lcd_bl_90_percent fail
          [    5.517409] [DISP] disp_sys_script_get_item,line:214:
          [    5.517415] of_property_read_u32_array lcd0.lcd_bl_91_percent fail
          [    5.530150] [DISP] disp_sys_script_get_item,line:214:
          [    5.530156] of_property_read_u32_array lcd0.lcd_bl_92_percent fail
          [    5.542909] [DISP] disp_sys_script_get_item,line:214:
          [    5.542915] of_property_read_u32_array lcd0.lcd_bl_93_percent fail
          [    5.555648] [DISP] disp_sys_script_get_item,line:214:
          [    5.555654] of_property_read_u32_array lcd0.lcd_bl_94_percent fail
          [    5.568389] [DISP] disp_sys_script_get_item,line:214:
          [    5.568395] of_property_read_u32_array lcd0.lcd_bl_95_percent fail
          [    5.581163] [DISP] disp_sys_script_get_item,line:214:
          [    5.581169] of_property_read_u32_array lcd0.lcd_bl_96_percent fail
          [    5.593895] [DISP] disp_sys_script_get_item,line:214:
          [    5.593901] of_property_read_u32_array lcd0.lcd_bl_97_percent fail
          [    5.606638] [DISP] disp_sys_script_get_item,line:214:
          [    5.606643] of_property_read_u32_array lcd0.lcd_bl_98_percent fail
          [    5.619379] [DISP] disp_sys_script_get_item,line:214:
          [    5.619385] of_property_read_u32_array lcd0.lcd_bl_99_percent fail
          [    5.632142] [DISP] disp_sys_script_get_item,line:214:
          [    5.632148] of_property_read_u32_array lcd0.lcd_bl_100_percent fail
          [    5.647845] [DISP] disp_sys_script_get_item,line:214:
          [    5.647851] of_property_read_u32_array lcd0.lcd_gsensor_detect fail
          [    5.660707] [DISP] disp_sys_script_get_item,line:214:
          [    5.660712] of_property_read_u32_array lcd0.lcd_hv_if fail
          [    5.673660] [DISP] disp_sys_script_get_item,line:214:
          [    5.673665] of_property_read_u32_array lcd0.lcd_lvds_io_polarity fail
          [    5.686690] [DISP] disp_sys_script_get_item,line:214:
          [    5.686695] of_property_read_u32_array lcd0.lcd_cpu_if fail
          [    5.698751] [DISP] disp_sys_script_get_item,line:214:
          [    5.698756] of_property_read_u32_array lcd0.lcd_cpu_te fail
          [    5.710813] [DISP] disp_sys_script_get_item,line:214:
          [    5.710819] of_property_read_u32_array lcd0.lcd_cpu_mode fail
          [    5.723666] [DISP] disp_sys_script_get_item,line:214:
          [    5.723672] of_property_read_u32_array lcd0.lcd_dsi_format fail
          [    5.736122] [DISP] disp_sys_script_get_item,line:214:
          [    5.736127] of_property_read_u32_array lcd0.lcd_dsi_eotp fail
          [    5.748380] [DISP] disp_sys_script_get_item,line:214:
          [    5.748386] of_property_read_u32_array lcd0.lcd_dsi_te fail
          [    5.760445] [DISP] disp_sys_script_get_item,line:214:
          [    5.760450] of_property_read_u32_array lcd0.lcd_dsi_port_num fail
          [    5.773127] [DISP] disp_sys_script_get_item,line:214:
          [    5.773132] of_property_read_u32_array lcd0.lcd_tcon_mode fail
          [    5.785476] [DISP] disp_sys_script_get_item,line:214:
          [    5.785482] of_property_read_u32_array lcd0.lcd_slave_tcon_num fail
          [    5.798315] [DISP] disp_sys_script_get_item,line:214:
          [    5.798320] of_property_read_u32_array lcd0.lcd_slave_stop_pos fail
          [    5.811186] [DISP] disp_sys_script_get_item,line:214:
          [    5.811192] of_property_read_u32_array lcd0.lcd_sync_pixel_num fail
          [    5.824009] [DISP] disp_sys_script_get_item,line:214:
          [    5.824014] of_property_read_u32_array lcd0.lcd_sync_line_num fail
          [    5.836749] [DISP] disp_sys_script_get_item,line:214:
          [    5.836754] of_property_read_u32_array lcd0.lcd_tcon_en_odd_even_div fail
          [    5.851397] [DISP] disp_sys_script_get_item,line:214:
          [    5.851403] of_property_read_u32_array lcd0.lcd_hv_data_polarity fail
          [    5.864451] [DISP] disp_sys_script_get_item,line:214:
          [    5.864456] of_property_read_u32_array lcd0.lcd_hv_srgb_seq fail
          [    5.877022] [DISP] disp_sys_script_get_item,line:214:
          [    5.877028] of_property_read_u32_array lcd0.lcd_rb_swap fail
          [    5.889200] [DISP] disp_sys_script_get_item,line:214:
          [    5.889206] of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
          [    5.901789] [DISP] disp_sys_script_get_item,line:214:
          [    5.901795] of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
          [    5.914831] [DISP] disp_sys_script_get_item,line:214:
          [    5.914837] of_property_read_u32_array lcd0.lcd_xtal_freq fail
          [    5.927174] [DISP] disp_sys_script_get_item,line:222:
          [    5.927180] of_property_read_string lcd0.lcd_size fail
          [    5.938750] [DISP] disp_sys_script_get_item,line:222:
          [    5.938756] of_property_read_string lcd0.lcd_model_name fail
          [    5.950916] [DISP] disp_sys_pwm_request,line:445:
          [    5.950922] disp_sys_pwm_request pwm 2 success!
          [    5.961267] [DISP] lcd_clk_init,line:492:
          [    5.961271] lcd 0 clk init
          [    5.968771] [DISP] disp_sys_gpio_request,line:281:
          [    5.968777] disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=205, value=1, ret=0
          [    5.982504] [DISP] bsp_disp_init,line:46:
          [    5.982509] bsp_disp_init 3!
          [    5.990381] [DISP] disp_init_hdmi,line:1052:
          [    5.990384] disp_init_hdmi
          [    5.998201] [DISP] disp_init_mgr,line:2971:
          [    5.998206] disp_init_mgr
          [    6.005817] [DISP] disp_init_mgr,line:3006:
          [    6.005825] mgr 0, 0x00000000b3ce84d4
          [    6.014589] [DISP] disp_init_mgr,line:3006:
          [    6.014595] mgr 1, 0x00000000d3f583ee
          [    6.023356] [DISP] disp_init_lyr,line:759:
          [    6.023360] disp_init_lyr
          [    6.030864] [DISP] disp_init_enhance,line:701:
          [    6.030866] disp_init_enhance
          [    6.039145] [DISP] disp_init_smbl,line:396:
          [    6.039149] disp_init_smbl
          [    6.046852] [DISP] disp_init_connections,line:450:
          [    6.046856] disp_init_connections
          [    6.055905] [DISP] disp_get_layer_1,line:137:
          [    6.055911] disp0 layer0: 0,0,0
          [    6.064279] [DISP] disp_get_layer_1,line:137:
          [    6.064285] disp0 layer1: 0,0,1
          [    6.072654] [DISP] disp_get_layer_1,line:137:
          [    6.072659] disp0 layer2: 0,0,2
          [    6.081001] [DISP] disp_get_layer_1,line:137:
          [    6.081005] disp0 layer3: 0,0,3
          [    6.089372] [DISP] disp_get_layer_1,line:137:
          [    6.089378] disp0 layer4: 0,1,0
          [    6.097745] [DISP] disp_get_layer_1,line:137:
          [    6.097750] disp0 layer5: 0,1,1
          [    6.106116] [DISP] disp_get_layer_1,line:137:
          [    6.106122] disp0 layer6: 0,1,2
          [    6.114488] [DISP] disp_get_layer_1,line:137:
          [    6.114494] disp0 layer7: 0,1,3
          [    6.122862] [DISP] disp_device_set_manager,line:23:
          [    6.122867] device 0, mgr 0
          [    6.131430] [DISP] disp_get_smbl,line:37:
          [    6.131434] get smbl0 ok
          [    6.138715] [DISP] disp_get_layer_1,line:137:
          [    6.138719] disp1 layer8: 1,0,0
          [    6.147087] [DISP] disp_get_layer_1,line:137:
          [    6.147092] disp1 layer9: 1,0,1
          [    6.155460] [DISP] disp_get_layer_1,line:137:
          [    6.155467] disp1 layer10: 1,0,2
          [    6.163928] [DISP] disp_get_layer_1,line:137:
          [    6.163934] disp1 layer11: 1,0,3
          [    6.172399] [DISP] disp_get_smbl,line:37:
          [    6.172403] get smbl1 ok
          [    6.179683] [DISP] disp_init,line:2432:
          [    6.179686] disp_init 222!
          [    6.187204] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.187211] lcd 0, driver_name WD070GXM30AA,  panel_name default_lcd
          [    6.199972] [DISP] disp_get_lcd,line:87:
          [    6.199976] disp 1 not support lcd output
          [    6.208830] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.208836] lcd 0, driver_name WD070GXM30AA,  panel_name he0801a068
          [    6.221483] [DISP] disp_get_lcd,line:87:
          [    6.221488] disp 1 not support lcd output
          [    6.230316] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.230320] lcd 0, driver_name WD070GXM30AA,  panel_name inet_dsi_panel
          [    6.243353] [DISP] disp_get_lcd,line:87:
          [    6.243358] disp 1 not support lcd output
          [    6.252210] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.252216] lcd 0, driver_name WD070GXM30AA,  panel_name lq101r1sx03
          [    6.264942] [DISP] disp_get_lcd,line:87:
          [    6.264946] disp 1 not support lcd output
          [    6.273798] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.273804] lcd 0, driver_name WD070GXM30AA,  panel_name WilliamLcd
          [    6.286432] [DISP] disp_get_lcd,line:87:
          [    6.286436] disp 1 not support lcd output
          [    6.295285] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.295290] lcd 0, driver_name WD070GXM30AA,  panel_name CC08021801_310_800X1280
          [    6.309179] [DISP] disp_get_lcd,line:87:
          [    6.309183] disp 1 not support lcd output
          [    6.318035] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.318040] lcd 0, driver_name WD070GXM30AA,  panel_name tft08006
          [    6.330474] [DISP] disp_get_lcd,line:87:
          [    6.330478] disp 1 not support lcd output
          [    6.339330] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.339335] lcd 0, driver_name WD070GXM30AA,  panel_name bp101wx1
          [    6.351790] [DISP] disp_get_lcd,line:87:
          [    6.351794] disp 1 not support lcd output
          [    6.360623] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.360628] lcd 0, driver_name WD070GXM30AA,  panel_name k101im2qa04
          [    6.373374] [DISP] disp_get_lcd,line:87:
          [    6.373378] disp 1 not support lcd output
          [    6.382229] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.382235] lcd 0, driver_name WD070GXM30AA,  panel_name fx070
          [    6.394380] [DISP] disp_get_lcd,line:87:
          [    6.394384] disp 1 not support lcd output
          [    6.403236] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.403242] lcd 0, driver_name WD070GXM30AA,  panel_name K080_IM2HYL802R_800X1280
          [    6.417229] [DISP] disp_get_lcd,line:87:
          [    6.417233] disp 1 not support lcd output
          [    6.426085] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.426091] lcd 0, driver_name WD070GXM30AA,  panel_name K101_IM2BYL02_L_800X1280
          [    6.440082] [DISP] disp_get_lcd,line:87:
          [    6.440086] disp 1 not support lcd output
          [    6.448937] [DISP] disp_lcd_set_panel_funs,line:2410:
          [    6.448943] lcd 0, driver_name WD070GXM30AA,  panel_name WD070GXM30AA
          [    6.461793] [DISP] bsp_disp_lcd_set_panel_funs,line:1604:
          [    6.461798] panel driver WD070GXM30AA register
          [    6.472779] [DISP] disp_get_lcd,line:87:
          [    6.472783] disp 1 not support lcd output
          [    6.481636] [DISP] fb_init,line:2292:
          [    6.481640] [DISP] fb_init
          [    6.488733] [DISP] disp_boot_para_parse,line:1189:
          [    6.488736] [DISP] fb_base:0x0
          [    6.497506] [DISP] disp_fb_to_var,line:401:
          [    6.497515] fmt0 para: 32bpp, a(24,8),r(16,8),g(8,8),b(0,8)
          [    6.508407] display_fb_request,fb_id:0
          [    6.517611] [DISP] fb_map_video_memory,line:115:
          [    6.517622] fb_map_video_memory(reserve),va=0x000000003f500c02, pa=0x00000000cff412ab size:0x4b0000
          [    6.544533] [DISP] Fb_map_kernel_logo,line:1807:
          [    6.544536] Fb_map_kernel_logo failed!
          [    6.556016] [DISP] var_to_disp_fb,line:522:
          [    6.560201] format0,para:32bpp,a(24,8),r(16,8),g(8,8),b(0,8)
          [    6.571218] [DISP] disp_mgr_set_layer_config,line:1593:
          [    6.571223] mgr0, config 1 layers
          [    6.580731] [DISP] disp_mgr_set_layer_config,line:1600:
          [    6.580744] layer:ch1, layer0, format=0, size=<1024,600>, crop=<0,0,1024,600>,frame=<1024,600>, en=1 addr[0xff800000,0x0,0x0> alpha=<0,255>
          [    6.600561] [DISP] disp_get_layer,line:104:
          [    6.600567] 0,1,0, name=mgr0 chn1 lyr0
          [    6.609418] [DISP] disp_lyr_save_and_dirty_check,line:529:
          [    6.609431] layer:ch1, layer0, format=0, size=<1024,600>, crop=<0,0,1024,600>,frame=<1024,600>, en=1 addr[0xff800000,0x0,0x0>
          [    6.628185] [DISP] disp_mgr_apply,line:2480:
          [    6.628189] mgr 0 apply
          [    6.635692] [DISP] bsp_disp_shadow_protect,line:726:
          [    6.635696] sel=0, protect:1,  cnt=1
          [    6.645231] [DISP] de_al_lyr_apply,line:485:
          [    6.645236] ch0 z 0 dis
          [    6.652733] [DISP] de_al_lyr_apply,line:485:
          [    6.652738] ch1 z 0 en
          [    6.660113] [DISP] de_al_lyr_apply,line:488:
          [    6.660117] pipe0 z 1 en
          [    6.667707] [DISP] de_al_lyr_apply,line:488:
          [    6.667712] pipe1 z 0 dis
          [    6.675402] [DISP] de_al_lyr_apply,line:503:
          [    6.675406] format[0]=0
          [    6.682910] [DISP] de_calc_overlay_scaler_para,line:178:
          [    6.682915] ovl_rect[0]=<0,0>
          [    6.692156] [DISP] de_calc_overlay_scaler_para,line:180:
          [    6.692162] bld_rect[0]=<0,0,0,0>
          [    6.701790] [DISP] de_calc_ovl_coord,line:389:
          [    6.701795] half_shift_xy=<20000,18,0>
          [    6.710912] [DISP] de_calc_ovl_coord,line:389:
          [    6.710916] half_shift_xy=<20000,18,0>
          [    6.720057] [DISP] de_rtmx_calc_chnrect,line:1982:
          [    6.720062] layernum=4, i=0
          [    6.728523] [DISP] de_rtmx_calc_chnrect,line:1984:
          [    6.728529] crop=<0,0,1024,600>
          [    6.737379] [DISP] de_rtmx_calc_chnrect,line:1986:
          [    6.737384] layer=<0,0,1024,600>
          [    6.746332] [DISP] de_rtmx_calc_chnrect,line:1995:
          [    6.746338] ovl_rect=<0,0,1024,600>
          [    6.755577] [DISP] de_rtmx_calc_chnrect,line:1997:
          [    6.755582] bld_rect=<0,0,1024,600>
          [    6.764819] [DISP] de_calc_overlay_scaler_para,line:178:
          [    6.764824] ovl_rect[1]=<1024,600>
          [    6.774548] [DISP] de_calc_overlay_scaler_para,line:180:
          [    6.774554] bld_rect[1]=<0,0,1024,600>
          [    6.784664] [DISP] de_calc_overlay_scaler_para,line:187:
          [    6.784673] fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
          [    6.798369] [DISP] de_vsu_set_para,line:274:
          [    6.798376] sel0, ch 0, en=0, in<0x0>,out<0x0>
          [    6.808116] [DISP] de_al_lyr_apply,line:713:
          [    6.808122] sel=0, pipe_rect[0]=<0,0,1024,600>
          [    6.817850] [DISP] de_rtmx_set_route,line:1792:
          [    6.817856] sel0, pno0, zorder1, route:0x0
          [    6.827482] [DISP] de_rtmx_set_route,line:1796:
          [    6.827489] addr=0x0000000012cb6947, reg=0x1
          [    6.837309] [DISP] de_al_lyr_apply,line:713:
          [    6.837315] sel=0, pipe_rect[1]=<0,0,0,0>
          [    6.846552] [DISP] de_rtmx_set_route,line:1792:
          [    6.846557] sel0, pno1, zorder0, route:0x1
          [    6.856183] [DISP] de_rtmx_set_route,line:1796:
          [    6.856189] addr=0x0000000012cb6947, reg=0x1
          [    6.866019] [DISP] de_enhance_apply,line:204:
          [    6.866024] disp 0, en=0, sharp=0
          [    6.874593] [DISP] de_peak_enable,line:123:
          [    6.874598] sel=0, chno=0, en=0
          [    6.882779] [DISP] bsp_disp_shadow_protect,line:726:
          [    6.882785] sel=0, protect:0,  cnt=0
          [    6.892603] [DISP] start_work,line:1812:
          [    6.892607] start_work start
          [    6.900181] [DISP] start_work,line:1863:
          [    6.900184] g_disp_drv.para.boot_info.type=1
          [    6.909353] [DISP] disp_init,line:2469:
          [    6.909357] disp_init finish
          [    6.916943] [DISP] disp_probe,line:3137:
          [    6.916947] [DISP]disp_probe finish
          [    6.925242] [DISP] bsp_disp_sync_with_hw,line:599:
          [    6.925247] para->boot_info.sync=1
          [    6.934784] [DISP]disp_module_init finish
          [    6.939687] usbcore: registered new interface driver snd-usb-audio
          [    6.946657] [DISP] bsp_disp_sync_with_hw,line:600:
          [    6.946662] para->boot_info.type=1
          [    6.958494] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
          [    6.969524] [DISP] bsp_disp_sync_with_hw,line:659:
          [    6.969530] mgr->device=0x3d3b8000
          [    6.978705] [DISP] disp_mgr_sw_enable,line:2683:
          [    6.978709] mgr 0 enable
          [    6.987914] sunxi-daudio 2034000.daudio: regulator missing or invalid
          [    6.995157] [DISP] disp_mgr_clk_enable,line:1051:
          [    6.995162] set DE rate to 300000000
          [    7.005424] [AUDIOCODEC][sunxi_codec_parse_params][2094]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
          [    7.005424]
          [    7.022558] [DISP] disp_mgr_clk_enable,line:1067:
          [    7.022564] mgr 0 clk enable
          [    7.031022] [DISP] disp_mgr_sw_enable,line:2731:
          [    7.031028] output res: 1024 x 600, cs=0, range=1, interlace=0
          [    7.042738] [AUDIOCODEC][sunxi_codec_parse_params][2130]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
          [    7.053636] [DISP] disp_mgr_apply,line:2480:
          [    7.053640] mgr 0 apply
          [    7.061282] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.061288] sel=0, protect:1,  cnt=1
          [    7.071071] [AUDIOCODEC][sunxi_internal_codec_probe][2266]:codec probe finished
          [    7.071134] disp_al_manager_apply ouput_type:1
          [    7.085435] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
          [    7.095251] [SNDCODEC][sunxi_card_init][583]:card init finished
          [    7.101898] [DISP] de_dcsc_apply,line:74:
          [    7.101905] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
          [    7.113202] [DISP] de_al_lyr_apply,line:485:
          [    7.113207] ch0 z 0 dis
          [    7.120686] [DISP] de_al_lyr_apply,line:485:
          [    7.120690] ch1 z 0 en
          [    7.128104] [DISP] de_al_lyr_apply,line:488:
          [    7.128109] pipe0 z 1 en
          [    7.135700] [DISP] de_al_lyr_apply,line:488:
          [    7.135704] pipe1 z 0 dis
          [    7.143390] [DISP] de_al_lyr_apply,line:503:
          [    7.143394] format[0]=0
          [    7.150876] [DISP] de_calc_overlay_scaler_para,line:178:
          [    7.150880] ovl_rect[0]=<0,0>
          [    7.160121] [DISP] de_calc_overlay_scaler_para,line:180:
          [    7.160127] bld_rect[0]=<0,0,0,0>
          [    7.169752] [DISP] de_calc_ovl_coord,line:389:
          [    7.169757] half_shift_xy=<20000,18,0>
          [    7.178900] [DISP] de_calc_ovl_coord,line:389:
          [    7.178906] half_shift_xy=<20000,18,0>
          [    7.188049] [DISP] de_rtmx_calc_chnrect,line:1982:
          [    7.188054] layernum=4, i=0
          [    7.196519] [DISP] de_rtmx_calc_chnrect,line:1984:
          [    7.196524] crop=<0,0,1024,600>
          [    7.205375] [DISP] de_rtmx_calc_chnrect,line:1986:
          [    7.205381] layer=<0,0,1024,600>
          [    7.214327] [DISP] de_rtmx_calc_chnrect,line:1995:
          [    7.214333] ovl_rect=<0,0,1024,600>
          [    7.223567] [DISP] de_rtmx_calc_chnrect,line:1997:
          [    7.223573] bld_rect=<0,0,1024,600>
          [    7.232809] [DISP] de_calc_overlay_scaler_para,line:178:
          [    7.232814] ovl_rect[1]=<1024,600>
          [    7.242536] [DISP] de_calc_overlay_scaler_para,line:180:
          [    7.242542] bld_rect[1]=<0,0,1024,600>
          [    7.252655] [DISP] de_calc_overlay_scaler_para,line:187:
          [    7.252664] fmt[0]=0, ovlw[0]=0,ovlh[0]=0, bld_rect[0].w=0, bld_rect[0].h=0
          [    7.266359] [DISP] de_vsu_set_para,line:274:
          [    7.266366] sel0, ch 0, en=0, in<0x0>,out<0x0>
          [    7.276115] [DISP] de_al_lyr_apply,line:713:
          [    7.276122] sel=0, pipe_rect[0]=<0,0,1024,600>
          [    7.285851] [DISP] de_rtmx_set_route,line:1792:
          [    7.285856] sel0, pno0, zorder1, route:0x0
          [    7.295481] [DISP] de_rtmx_set_route,line:1796:
          [    7.295489] addr=0x0000000012cb6947, reg=0x1
          [    7.305310] [DISP] de_al_lyr_apply,line:713:
          [    7.305316] sel=0, pipe_rect[1]=<0,0,0,0>
          [    7.314552] [DISP] de_rtmx_set_route,line:1792:
          [    7.314558] sel0, pno1, zorder0, route:0x1
          [    7.324184] [DISP] de_rtmx_set_route,line:1796:
          [    7.324189] addr=0x0000000012cb6947, reg=0x1
          [    7.334022] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.334028] sel=0, protect:0,  cnt=0
          [    7.343565] [DISP] disp_enhance_apply,line:126:
          [    7.343570] disp_enhance_apply, screen 0
          [    7.353004] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.353009] sel=0, protect:1,  cnt=1
          [    7.362539] [DISP] de_dcsc_apply,line:74:
          [    7.362547] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
          [    7.373634] [DISP] de_enhance_apply,line:204:
          [    7.373638] disp 0, en=0, sharp=0
          [    7.382206] [DISP] de_peak_enable,line:123:
          [    7.382212] sel=0, chno=0, en=0
          [    7.390368] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.390372] sel=0, protect:0,  cnt=0
          [    7.399913] [DISP] disp_enhance_apply,line:126:
          [    7.399918] disp_enhance_apply, screen 0
          [    7.409352] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.409358] sel=0, protect:1,  cnt=1
          [    7.418889] [DISP] de_dcsc_apply,line:74:
          [    7.418896] sel=0, in_fmt=0, mode=0, out_fmt=0, mode=0, range=1
          [    7.429980] [DISP] de_enhance_apply,line:204:
          [    7.429985] disp 0, en=1, sharp=0
          [    7.438554] [DISP] de_peak_enable,line:123:
          [    7.438559] sel=0, chno=0, en=0
          [    7.446737] [DISP] bsp_disp_shadow_protect,line:726:
          [    7.446743] sel=0, protect:0,  cnt=0
          [    7.456393] [DISP] lcd_clk_config,line:715:
          [    7.456399] clk_set_rate:dsi's 0 th clk with 150000000
          [    7.466799] [DISP] lcd_clk_config,line:731:
          [    7.466810] disp 0, clk: pll(360000000),clk(360000000),dclk(60000000) dsi_rate(60000000)
          [    7.466810]      clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000)
          [    7.489744] [DISP] cal_real_frame_period,line:646:
          [    7.489749] lcd frame period:34137600
          [    7.499189] [DISP] disp_sys_pwm_set_polarity,line:536:
          [    7.499195] disp_sys_pwm_Set_Polarity pwm 2, active high
          [    7.511077] [DISP] disp_sys_pwm_enable,line:479:
          [    7.511121] disp_sys_pwm_Enable pwm 2
          [    7.520345] [DISP] disp_sys_register_irq,line:113:
          [    7.520354] disp_sys_register_irq, irqNo=33, Handler=0x0000000086b0f547, pArg=0x00000000004b68ef
          [    7.535589] [DISP] start_work,line:1874:
          [    7.535593] start_work finish
          [    7.545280] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
          [    7.556446] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
          [    7.568554] [SNDCODEC][sunxi_card_dev_probe][832]:register card finished
          [    7.576765] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
          [    7.585316] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
          [    7.594414] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
          [    7.605966] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
          [    7.618057] NET: Registered protocol family 10
          [    7.624550] Segment Routing with IPv6
          [    7.628797] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
          [    7.636272] NET: Registered protocol family 17
          [    7.641406] can: controller area network core (rev 20170425 abi 9)
          [    7.648382] NET: Registered protocol family 29
          [    7.653412] can: raw protocol (rev 20170425)
          [    7.658201] can: broadcast manager protocol (rev 20170425 t)
          [    7.664553] can: netlink gateway (rev 20190810) max_hops=1
          [    7.670987] Bluetooth: RFCOMM TTY layer initialized
          [    7.676537] Bluetooth: RFCOMM socket layer initialized
          [    7.682319] Bluetooth: RFCOMM ver 1.11
          [    7.687498] Loading compiled-in X.509 certificates
          [    7.714726] twi twi2: twi2 supply twi not found, using dummy regulator
          [    7.729477] pcf857x 2-0038: probed
          [    7.733509] sunxi_i2c_probe()2262 - [i2c2] probe success
          [    7.743797] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
          [    7.754015] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
          [    7.764165] debugfs: Directory '2034000.daudio' with parent 'sndhdmi' already present!
          [    7.774766] sunxi-audio-card 20340a0.sounddaudio2: 20340a4.hdmiaudio <-> 2034000.daudio mapping ok
          [    7.786147] get ehci0-controller wakeup-source is fail.
          [    7.792164] sunxi ehci0-controller don't init wakeup source
          [    7.798387] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe0008f4eb0, 0x:ffffffd004eb0000, irq_no:2e
          [    7.811933] [sunxi-ehci0]: Not init ehci0
          [    7.816850] get ohci0-controller wakeup-source is fail.
          [    7.822873] sunxi ohci0-controller don't init wakeup source
          [    7.829096] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe0008f59f0
          [    7.839542] [sunxi-ohci0]: Not init ohci0
          [    7.844494] ubi0: attaching mtd3
          [    8.811304] ubi0: scanning is finished
          [    8.831011] ubi0: attached mtd3 (name "sys", size 250 MiB)
          [    8.837175] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
          [    8.844912] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
          [    8.852507] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
          [    8.860287] ubi0: good PEBs: 1000, bad PEBs: 0, corrupted PEBs: 0
          [    8.867105] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
          [    8.875208] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
          [    8.884547] ubi0: available PEBs: 16, total reserved PEBs: 984, PEBs reserved for bad PEB handling: 20
          [    8.894982] ubi0: background thread "ubi_bgt0d" started, PID 68
          [    8.903523] block ubiblock0_5: created from ubi0:5(rootfs)
          [    8.912071] HDMI 2.0 driver init start!
          [    8.916360] [DISP] disp_boot_para_parse,line:1189:
          [    8.916365] [DISP] boot_disp:0x104
          [    8.925575] boot_hdmi=false
          [    8.928748] ERROR: pinctrl_get for HDMI2.0 DDC fail
          [    8.935571] [DISP] bsp_disp_set_hdmi_func,line:1347:
          [    8.935576] registered!!
          [    8.944011] [DISP] start_work,line:1812:
          [    8.944015] start_work start
          [    8.951865] HDMI2.0 module init end
          [    8.955787] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [    8.964519] [DISP] start_work,line:1863:
          [    8.964524] g_disp_drv.para.boot_info.type=1
          [    8.973915] [DISP] start_work,line:1874:
          [    8.973919] start_work finish
          [    8.983673] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [    8.990965] clk: Not disabling unused clocks
          [    8.996056] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
          [    9.005751] ALSA device list:
          [    9.009089]   #0: audiocodec
          [    9.012424] cfg80211: failed to load regulatory.db
          [    9.017841]   #1: snddmic
          [    9.020760]   #2: sndhdmi
          [    9.023828] alloc_fd: slot 0 not NULL!
          [    9.032225] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
          [    9.043428] devtmpfs: mounted
          [    9.046907] Freeing unused kernel memory: 192K
          [    9.051938] This architecture does not have kernel memory protection.
          [    9.059148] Run /sbin/init as init process
          [    9.876235] init: Console is alive
          [    9.880305] init: - watchdog -
          [    9.883975] init: - preinit -
          /dev/by-name/UDISK already format by ubifs
          [   11.307848] mount_root: mounting /dev/root
          [   11.313341] mount_root: loading kmods from internal overlay
          [   11.573579] block: attempting to load /etc/config/fstab
          [   11.602543] UBIFS (ubi0:8): Mounting in unauthenticated mode
          [   11.609270] UBIFS (ubi0:8): background thread "ubifs_bgt0_8" started, PID 111
          [   11.737499] UBIFS (ubi0:8): recovery needed
          [   12.051080] UBIFS (ubi0:8): recovery completed
          [   12.056254] UBIFS (ubi0:8): UBIFS: mounted UBI device 0, volume 8, name "UDISK"
          [   12.069826] UBIFS (ubi0:8): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
          [   12.081504] UBIFS (ubi0:8): FS size: 193794048 bytes (184 MiB, 751 LEBs), journal size 9420800 bytes (8 MiB, 37 LEBs)
          [   12.093420] UBIFS (ubi0:8): reserved for root: 0 bytes (0 KiB)
          [   12.099948] UBIFS (ubi0:8): media format: w4/r0 (latest is w5/r0), UUID 89DC3E3A-6AF4-4065-9C07-9BBA54FBFF3D, small LPT model
          [   12.117153] block: extroot: UUID match (root: c6f9c21a-beff9899-487d24ac-0b0124de, overlay: c6f9c21a-beff9899-487d24ac-0b0124de)
          [   12.142036] mount_root: switched to extroot
          [   12.162922] procd: - early -
          [   12.166334] procd: - watchdog -
          [   12.451162]
          [   12.451162] insmod_device_driver
          [   12.451162]
          [   12.577232] procd: - watchdog -
          [   12.581025] procd: - ubus -
          [   12.587351] procd (1): /proc/123/oom_adj is deprecated, please use /proc/123/oom_score_adj instead.
          [   12.691172] hdmi_hpd_sys_config_release
          [   12.989346] procd: - init -
          [   14.238203] fuse: init (API version 7.31)
          [   14.457785] file system registered
          [   14.571547] usbcore: registered new interface driver uvcvideo
          [   14.577956] USB Video Class driver (1.1.1)
          [   14.602130] configfs-gadget 4100000.udc-controller: failed to start g1: -19
          [   15.136378] read descriptors
          [   15.139604] read strings
          [   15.324279] sunxi_set_cur_vol_work()394 WARN: get power supply failed
          [   15.376712] android_work: sent uevent USB_STATE=CONNECTED
          [   15.401229] sunxi_set_cur_vol_work()394 WARN: get power supply failed
          [   15.463484] configfs-gadget gadget: high-speed config #1: c
          [   15.469833] android_work: sent uevent USB_STATE=CONFIGURED
          [   17.529167] ======== XRADIO WIFI OPEN ========
          [   17.538198] [XRADIO] Driver Label:XR_V02.16.84_P2P_HT40_01.31
          [   17.551276] [XRADIO] Allocated hw_priv @ 00000000551fba87
          [   17.564825] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
          [   17.582381] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
          [   17.848323] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   17.860048] [XRADIO] Detect SDIO card 1
          [   17.871797] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
          [   17.891190] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   17.917771] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   17.935546] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
          [   17.962662] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [   17.989799] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
          [   18.015021] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
          [   18.041224] mmc1: new high speed SDIO card at address 0001
          [   18.061245] [SBUS] XRadio Device:sdio clk=50000000
          [   18.071306] [XRADIO] XRADIO_HW_REV 1.0 detected.
          [   18.191682] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x00c00000.
          [   18.263650] [XRADIO] Bootloader complete
          [   18.353167] [XRADIO] Firmware completed.
          [   18.359363] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.100 2GHZ HT40 Jan  3 2020 13:14:37
          [   18.376890] [XRADIO] Firmware Startup Done.
          [   18.382024] [XRADIO_WRN] enable Multi-Rx!
          [   18.394239] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
          [   18.424688] xt_time: kernel timezone is -0000
          [   18.467366] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
          [   18.928585] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=e0:30:d5:f8:92:4a
          [   18.946775] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=e0:30:d5:f8:92:4a
          [   18.971802] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
          [   20.188212] libphy: 4500000.eth: probed
          [   20.211613] sunxi-gmac 4500000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (4500000.eth-0:00)
          [   20.318723] br-lan: port 1(eth0) entered blocking state
          [   20.341270] br-lan: port 1(eth0) entered disabled state
          [   20.347408] device eth0 entered promiscuous mode
          [   20.362510] br-lan: port 1(eth0) entered blocking state
          [   20.368342] br-lan: port 1(eth0) entered forwarding state
          [   21.121213] br-lan: port 1(eth0) entered disabled state
          [   29.334499] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
          [   39.521152] usb1-vbus: disabling
            WadeDeng LV 4 @whycan 最后由 编辑
            @whycan 整段终端串口输出大概是这样
              yi20416yi LV 3 最后由 编辑
              解决了吗?情况一样
