    D1S 卡在uboot结束
      huerli LV 3 最后由 编辑
      使用tina sdk ,改了串口3
      修改了这些地方 env.cfg
      修改了board.dts
      上电输出如下所示。
      [192]BOOT0 commit : 88480af
      [195]set pll start
      [196]fix vccio detect value:0xc0
      [200]periph0 has been enabled
      [203]set pll end
      [204][pmu]: bus read error
      [207]board init ok
      [209]ZQ value = 0x2d
      [210]get_pmu_exist() = -1
      [213]ddr_efuse_type: 0xa
      [215]trefi:7.8ms
      [218][AUTO DEBUG] single rank and full DQ!
      [222]ddr_efuse_type: 0xa
      [224]trefi:7.8ms
      [226][AUTO DEBUG] rank 0 row = 13
      [229][AUTO DEBUG] rank 0 bank = 4
      [232][AUTO DEBUG] rank 0 page size = 2 KB
      [236]DRAM BOOT DRIVE INFO: V0.33
      [239]DRAM CLK = 528 MHz
      [241]DRAM Type = 2 (2:DDR2,3:DDR3)
      [245]DRAMC read ODT  off.
      [247]DRAM ODT off.
      [249]ddr_efuse_type: 0xa
      [252]DRAM SIZE =64 M
      [254]dram_tpr4:0x0
      [255]PLL_DDR_CTRL_REG:0xf8002b00
      [258]DRAM_CLK_REG:0xc0000000
      [261][TIMING DEBUG] MR2= 0x0
      [266]DRAM simple test OK.
      [268]dram size =64
      [270]card no is 0
      [271]sdcard 0 line count 4
      [274][mmc]: mmc driver ver 2021-04-2 16:45
      [283][mmc]: Wrong media type 0x0
      [286][mmc]: ***Try SD card 0***
      [295][mmc]: HSSDR52/SDR25 4 bit
      [298][mmc]: 50000000 Hz
      [300][mmc]: 14804 MB
      [302][mmc]: ***SD/MMC 0 init OK!!!***
      [352]Loading boot-pkg Succeed(index=0).
      [356]Entry_name        = opensbi
      [359]Entry_name        = u-boot
      [363]Entry_name        = dtb
      [365]mmc not para
      �367]Jump to second Boot.
      U-Boot 2018.05-g24521d6-dirty (Jun 19 2024 - 19:18:28 +0800) Allwinner Technology
      [00.377]DRAM:  64 MiB
      [00.379]Relocation Offset is: 01ee7000
      [00.384]secure enable bit: 0
      [00.387]CPU=720 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.393]flash init start
      [00.395]workmode = 0,storage type = 1
      [00.399][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [00.404][mmc]: get sdc_type fail and use default host:tm1.
      [00.411][mmc]: can't find node "mmc0",will add new node
      [00.416][mmc]: fdt err returned <no error>
      [00.420][mmc]: Using default timing para
      [00.423][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.441][mmc]: card_caps:0x3000000a
      [00.444][mmc]: host_caps:0x3000003f
      [00.448]sunxi flash init ok
      [00.450]line:703 init_clocks
      [00.454]drv_disp_init
      [00.474]drv_disp_init finish
      [00.477]boot_gui_init:start
      [00.480]set disp.dev2_output_type fail. using defval=0
      [00.487]boot_gui_init:finish
      54 bytes read in 2 ms (26.4 KiB/s)
      [00.517]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 5 ms (7.3 MiB/s)
      [00.549]Loading Environment from SUNXI_FLASH... OK
      [00.573]out of usb burn from boot: not need burn key
      [00.607]Item0 (Map) magic is bad
      [00.610]the secure storage item0 copy0 magic is bad
      [00.644]Item0 (Map) magic is bad
      [00.647]the secure storage item0 copy1 magic is bad
      [00.652]Item0 (Map) magic is bad
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [0[00.668]LCD open finish
      0.666]update part info
      [00.674]update bootcmd
      [00.678]change working_fdt 0x42aa6da0 to 0x42a86da0
      [00.715]update dts
      noncached_alloc(): addr = 0x42c8a080
      noncached_alloc(): addr = 0x42c8a0c0
      noncached_alloc(): addr = 0x42c8a100
      noncached_alloc(): addr = 0x42c8a940
      geth_sys_init fail!
      [00.736]Board Net Initialization Failed
      [00.739]No ethernet found.
