    F133编译出现错误,不知道怎么解决。
    4253
    • B
      bugwtq LV 2 最后由 编辑
      prfdcach.c: At top level:
      prfdcach.c:153:42: error: unknown type name 'PRIntn'; did you mean 'PRInt64'?
      PR_IMPLEMENT(PRStatus) PR_SetFDCacheSize(PRIntn low, PRIntn high)
      PRInt64
      prfdcach.c:153:54: error: unknown type name 'PRIntn'; did you mean 'PRInt64'?
      PRInt64
      ../../../config/rules.mk:446: recipe for target 'prfdcach.o' failed
      make[7]: *** [prfdcach.o] Error 1
      make[7]: Leaving directory '/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/nspr/pr/src/io'
      ../../config/rules.mk:163: recipe for target 'export' failed
      make[6]: *** [export] Error 2
      make[6]: Leaving directory '/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/nspr/pr/src'
      make[5]: *** [export] Error 2
      make[5]: Leaving directory '/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/nspr/pr'
      make[4]: *** [export] Error 2
      make[4]: Leaving directory '/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/nspr'
      Makefile💯 recipe for target '/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/.built' failed
      make[3]: *** [/home/test/LC/Tina-Linux/out/f133-mq_r/compile_dir/target/nspr-4.12/.built] Error 2
      make[3]: Leaving directory '/home/test/LC/Tina-Linux/package/libs/nspr'
      package/Makefile:192: recipe for target 'package/libs/nspr/compile' failed
      make[2]: *** [package/libs/nspr/compile] Error 2
      make[2]: Leaving directory '/home/test/LC/Tina-Linux'
      package/Makefile:189: recipe for target '/home/test/LC/Tina-Linux/out/f133-mq_r/staging_dir/target/stamp/.package_compile' failed
      make[1]: *** [/home/test/LC/Tina-Linux/out/f133-mq_r/staging_dir/target/stamp/.package_compile] Error 2
      make[1]: Leaving directory '/home/test/LC/Tina-Linux'
      /home/test/LC/Tina-Linux/build/toplevel.mk:304: recipe for target 'world' failed
      make: *** [world] Error 2
      make failed to build some targets (47:41 (mm:ss))
        zhangjingxun12 LV 4 最后由 编辑
        目测,你跟我用的,同一家的板子……哈哈
        如果是你动了menuconfig,但又不知道动了那里之后引起的,还原config,路径
        LC/Tina-Linux/device/config/chips/f133/configs/mq_r/linux-5.4
        下面的config-5.4_recovery覆盖config-5.4,然后试试
        B 2 条回复 最后回复 回复 引用 分享 0
        • B
          bugwtq LV 2 @zhangjingxun12 最后由 编辑
          • B
            @zhangjingxun12 我是想安装apache,一安装这个就无法编译过去。
            Z 1 条回复 最后回复 回复 引用 分享 0
              zhangjingxun12 LV 4 @bugwtq 最后由 编辑
              @bugwtq 这就不知道了,没用过,但从错误看,可能涉及到apache的源码,是数据类型不匹配……没有提示依赖错误
