    D1系列烧录出现问题
    • G
      Godoword LV 2 最后由 编辑
      按FEL后连接USB进行烧录,烧录到一半时,PhoenixSuit提示“烧写固件失败!请确保固件文件有效并且只能设备可以正常工作!”
      然后第二次再尝试时,PhoenixSuit就无法检测到设备了;
      请大家帮忙看下是什么情况
      下面是log
      [733]fes begin commit:0e43dde-dirty
      [737]set pll start
      [738]periph0 has been enabled
      [741]set pll end
      [743][pmu]: bus read error
      [745]board init ok
      [747]beign to init dram
      [749]DRAM only have internal ZQ!!
      [752]get_pmu_exist() = -1
      [755]ddr_type: 0x0
      [757][AUTO DEBUG] two rank and full DQ!
      [761]ddr_type: 0x0
      [764][AUTO DEBUG] rank 0 row = 15
      [767][AUTO DEBUG] rank 0 bank = 8
      [770][AUTO DEBUG] rank 0 page size = 2 KB
      [774][AUTO DEBUG] rank 1 row = 15
      [777][AUTO DEBUG] rank 1 bank = 8
      [780][AUTO DEBUG] rank 1 page size = 2 KB
      [784]rank1 config same as rank0
      [787]DRAM BOOT DRIVE INFO: V0.23
      [790]DRAM CLK = 936 MHz
      [792]DRAM Type = 3 (2:DDR2,3:DDR3)
      [795]DRAMC ZQ value: 0x7b7bfb
      [798]DRAM ODT value: 0x42.
      [800]ddr_type: 0x0
      [803]DRAM SIZE =1024 M
      [806]DRAM simple test OK.
      [809]init dram ok
      U-Boot 2018.05-00015-ge960255fc6-dirty (Aug 26 2021 - 16:05:15 +0800) Allwinner Technology
      [02.815]DRAM: 512 MiB
      [02.820]Relocation Offset is: 1df22000
      [02.835]secure enable bit: 0
      [02.840]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [02.846]flash init start
      [02.848]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [02.856][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
      [02.864][mmc]: get sdc_type fail and use default host:tm4.
      [02.887][mmc]: Is not Boot mode!
      [02.890][mmc]: SUNXI SDMMC Controller Version:0x50310
      [02.901][mmc]: Try SD card 2
      [02.906][mmc]: mmc 2 cmd timeout 100 status 100
      [02.910][mmc]: smc 2 err, cmd 8, RTO
      [02.914][mmc]: mmc 2 close bus gating and reset
      [02.919][mmc]: mmc 2 cmd timeout 100 status 100
      [02.923][mmc]: smc 2 err, cmd 55, RTO
      [02.926][mmc]: mmc 2 close bus gating and reset
      [02.930][mmc]: Try MMC card 2
      [02.939][mmc]: mmc 2 cmd timeout 100 status 100
      [02.943][mmc]: smc 2 err, cmd 1, RTO
      [02.947][mmc]: mmc 2 close bus gating and reset
      [02.951][mmc]: Card did not respond to voltage select!
      [02.956][mmc]: SD/MMC 2 init error!
      [02.961][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [02.974]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [02.980]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [03.023]sunxi-spinand-phy: request spi0 gpio ok
      [03.027]sunxi-spinand-phy: request general tx dma channel ok!
      [03.033]sunxi-spinand-phy: request general rx dma channel ok!
      [03.038]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [03.043]sunxi-spinand-phy: init spic0 clk ok
      [BCR] 0x4025030 = 0x00000000, [TCR] 0x4025034 = 0x00000000, [BCC] 0x4025038 = 0x00000000
      [DMA] 0x4025088 = 0x000000e5
      [03.085]sunxi-spinand-phy: not detect any munufacture from id table
      [03.098]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [03.103]sunxi-spinand-phy: get phy info from fdt fail
      [03.108]sunxi-spinand-phy: not detect munufacture from fdt
      [03.113]sunxi-spinand-phy: detect munufacture from id table: Mxic
      [03.119]sunxi-spinand-phy: detect spinand id: ff0326c2 ffffffff
      [03.125]sunxi-spinand-phy: ========== arch info ==========
      [03.130]sunxi-spinand-phy: Model: MX35LF2GE4AD
      [03.135]sunxi-spinand-phy: Munufacture: Mxic
      [03.140]sunxi-spinand-phy: DieCntPerChip: 1
      [03.144]sunxi-spinand-phy: BlkCntPerDie: 2048
      [03.149]sunxi-spinand-phy: PageCntPerBlk: 64
      [03.154]sunxi-spinand-phy: SectCntPerPage: 4
      [03.158]sunxi-spinand-phy: OobSizePerPage: 64
      [03.162]sunxi-spinand-phy: BadBlockFlag: 0x1
      [03.167]sunxi-spinand-phy: OperationOpt: 0x7
      [03.172]sunxi-spinand-phy: MaxEraseTimes: 65000
      [03.176]sunxi-spinand-phy: EccFlag: 0x2
      [03.181]sunxi-spinand-phy: EccType: 8
      [03.185]sunxi-spinand-phy: EccProtectedType: 3
      [03.190]sunxi-spinand-phy: ========================================
      [03.196]sunxi-spinand-phy:
      [03.198]sunxi-spinand-phy: ========== physical info ==========
      [03.204]sunxi-spinand-phy: TotalSize: 256 M
      [03.208]sunxi-spinand-phy: SectorSize: 512 B
      [03.212]sunxi-spinand-phy: PageSize: 2 K
      [03.216]sunxi-spinand-phy: BlockSize: 128 K
      [03.220]sunxi-spinand-phy: OOBSize: 64 B
      [03.224]sunxi-spinand-phy: ========================================
      [03.230]sunxi-spinand-phy:
      [03.233]sunxi-spinand-phy: ========== logical info ==========
      [03.238]sunxi-spinand-phy: TotalSize: 256 M
      [03.243]sunxi-spinand-phy: SectorSize: 512 B
      [03.247]sunxi-spinand-phy: PageSize: 4 K
      [03.251]sunxi-spinand-phy: BlockSize: 256 K
      [03.255]sunxi-spinand-phy: OOBSize: 128 B
      [03.259]sunxi-spinand-phy: ========================================
      [03.272]sunxi-spinand-phy: MX35LF2GE4AD reset rx bit width to 1
      [03.277]sunxi-spinand-phy: MX35LF2GE4AD reset tx bit width to 1
      [03.283]sunxi-spinand-phy: set spic0 clk to 80 Mhz
      [03.287]sunxi-spinand-phy: block lock register: 0x00
      [03.292]sunxi-spinand-phy: feature register: 0x11
      [03.296]sunxi-spinand-phy: sunxi physic nand init end
      [03.305]Loading Environment from SUNXI_FLASH... OK
      [03.315]try to burn key
      [03.318]out of usb burn from boot: not boot mode
      [03.323]Net: [03.324]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x6
      set address 0x6 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x0
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      SUNXI_EFEX_EXT4_UBIFS_TAG & do nothing
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      MBR DUMP**
      total mbr part 8
      part[0] name :boot-resource
      part[0] classname :DISK
      part[0] addrlo :0x8000
      part[0] lenlo :0x7e0
      part[0] user_type :32768
      part[0] keydata :0
      part[0] ro :0
      part[1] name :env
      part[1] classname :DISK
      part[1] addrlo :0x87e0
      part[1] lenlo :0x1f8
      part[1] user_type :32768
      part[1] keydata :0
      part[1] ro :0
      part[2] name :env-redund
      part[2] classname :DISK
      part[2] addrlo :0x89d8
      part[2] lenlo :0x1f8
      part[2] user_type :32768
      part[2] keydata :0
      part[2] ro :0
      part[3] name :boot
      part[3] classname :DISK
      part[3] addrlo :0x8bd0
      part[3] lenlo :0x89d0
      part[3] user_type :32768
      part[3] keydata :0
      part[3] ro :0
      part[4] name :rootfs
      part[4] classname :DISK
      part[4] addrlo :0x115a0
      part[4] lenlo :0x89d0
      part[4] user_type :32768
      part[4] keydata :0
      part[4] ro :0
      part[5] name :dsp0
      part[5] classname :DISK
      part[5] addrlo :0x19f70
      part[5] lenlo :0x800
      part[5] user_type :32768
      part[5] keydata :0
      part[5] ro :0
      part[6] name :opensbi
      part[6] classname :DISK
      part[6] addrlo :0x1a770
      part[6] lenlo :0x800
      part[6] user_type :32768
      part[6] keydata :0
      part[6] ro :0
      part[7] name :UDISK
      part[7] classname :DISK
      part[7] addrlo :0x1af70
      part[7] lenlo :0x0
      part[7] user_type :0
      part[7] keydata :0
      part[7] ro :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 7e0, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 89d0, 8000
      rootfs 5, 89d0, 8000
      dsp0 6, 800, 8000
      opensbi 7, 800, 8000
      UDISK 8, 0, 0
      [06.301]erase blk 0 to blk 32
      need erase flash: 0
      [06.369]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      #: name size offset mask_flags
      0: boot0 0x00100000 0x00000000 1
      1: uboot 0x00300000 0x00100000 1
      2: secure_storage 0x00100000 0x00400000 1
      3: sys 0x0fb00000 0x00500000 0
      defaults:
      mtdids : nand0=nand
      [06.425]MTD info (4)
      [06.427]pagesize: 0x1000
      [06.430]blksize: 0x40000
      [06.432]num offset bytes name
      [06.435]0 0x00000000 0x00100000 boot0
      [06.439]1 0x00100000 0x00300000 uboot
      [06.443]2 0x00400000 0x00100000 secure_storage
      [06.447]3 0x00500000 0x0fb00000 sys
      [06.451]ubi attach the last part of mtd device: NO.3
      [06.855]ubi0: attaching mtd4
      [07.473]ubi0: scanning is finished
      [07.495]ubi0 warning: init_volumes: static volume 0 misses 21 LEBs - corrupted
      [07.517]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [07.522]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [07.528]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [07.535]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [07.541]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [07.546]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [07.553]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [07.561]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      no part need to protect user data
      [07.572]erase blk 0 to blk 32
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids : nand0=nand
      [07.680]MTD info (4)
      [07.682]pagesize: 0x1000
      [07.684]blksize: 0x40000
      [07.687]num offset bytes name
      [07.690]0 0x00000000 0x00100000 boot0
      [07.694]1 0x00100000 0x00300000 uboot
      [07.697]2 0x00400000 0x00100000 secure_storage
      [07.702]3 0x00500000 0x0fb00000 sys
      [07.705]MBR info (unalign):
      [07.708]partno addr sects type name
      [07.713]0 0x00000000 0x00008000 0x00000001 mbr
      [07.717]1 0x00008000 0x000007e0 0x00008000 boot-resource
      [07.723]2 0x000087e0 0x000001f8 0x00008000 env
      [07.728]3 0x000089d8 0x000001f8 0x00008000 env-redund
      [07.733]4 0x00008bd0 0x000089d0 0x00008000 boot
      [07.738]5 0x000115a0 0x000089d0 0x00008000 rootfs
      [07.743]6 0x00019f70 0x00000800 0x00008000 dsp0
      [07.748]7 0x0001a770 0x00000800 0x00008000 opensbi
      [07.753]8 0x0001af70 0x00000000 0x00000000 UDISK
      [07.758]ubi attach the last part of mtd device: NO.3
      [07.763]MBR info (align):
      [07.765]partno addr sects type name
      [07.770]0 0x00002800 0x000081f0 0x00000001 mbr
      [07.775]1 0x0000a9f0 0x000007e0 0x00008000 boot-resource
      [07.780]2 0x0000b1d0 0x000001f8 0x00008000 env
      [07.785]3 0x0000b3c8 0x000001f8 0x00008000 env-redund
      [07.790]4 0x0000b5c0 0x000089d0 0x00008000 boot
      [07.795]5 0x00013f90 0x000089d0 0x00008000 rootfs
      [07.800]6 0x0001c960 0x000009d8 0x00008000 dsp0
      [07.805]7 0x0001d338 0x000009d8 0x00008000 opensbi
      [07.810]8 0x0001dd10 0x00000000 0x00000000 UDISK
      [07.815]ubi attach the last part of mtd device: NO.3
      [07.820]ubi attatch mtd, name: sys
      [07.823]ubi0: detaching mtd4
      [07.828]ubi0: mtd4 is detached
      [07.831]ubi0: attaching mtd4
      [08.446]ubi0: scanning is finished
      [08.469]ubi0 warning: init_volumes: static volume 0 misses 21 LEBs - corrupted
      [08.490]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [08.495]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [08.501]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [08.507]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [08.514]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [08.519]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [08.526]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [08.533]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [08.542]volume mbr existed, not create again
      [08.546]volume boot-resource existed, not create again
      [08.551]volume env existed, not create again
      [08.555]volume env-redund existed, not create again
      [08.560]volume boot existed, not create again
      [08.564]volume rootfs existed, not create again
      [08.568]volume dsp0 existed, not create again
      [08.572]volume opensbi existed, not create again
      [08.576]volume UDISK existed, not create again
      [08.803]fill gap start: volume mbr sects 0x7f80
      [22.646]fill gap end: volume mbr
      [22.649]update partition map
      [22.652]logical area info: 960 258048 last_lba: 483839
      [22.670]logical area info: 960 258048 last_lba: 483839
      [22.688]logical area info: 960 258048 last_lba: 483839
      [22.706]logical area info: 960 258048 last_lba: 483839
      [22.724]logical area info: 960 258048 last_lba: 483839
      [22.742]logical area info: 960 258048 last_lba: 483839
      [22.760]logical area info: 960 258048 last_lba: 483839
      [22.778]logical area info: 960 258048 last_lba: 483839
      [22.796]logical area info: 960 258048 last_lba: 483839
      [22.814]logical area info: 960 258048 last_lba: 483839
      [22.832]logical area info: 960 258048 last_lba: 483839
      [22.850]logical area info: 960 258048 last_lba: 483839
      [22.868]logical area info: 960 258048 last_lba: 483839
      [22.886]logical area info: 960 258048 last_lba: 483839
      [22.904]logical area info: 960 258048 last_lba: 483839
      [22.922]logical area info: 960 258048 last_lba: 483839
      [22.940]logical area info: 960 258048 last_lba: 483839
      [22.958]logical area info: 960 258048 last_lba: 483839
      [22.976]logical area info: 960 258048 last_lba: 483839
      [22.994]logical area info: 960 258048 last_lba: 483839
      [23.012]logical area info: 960 258048 last_lba: 483839
      [23.030]logical area info: 960 258048 last_lba: 483839
      [23.048]logical area info: 960 258048 last_lba: 483839
      [23.066]logical area info: 960 258048 last_lba: 483839
      [23.084]logical area info: 960 258048 last_lba: 483839
      [23.102]logical area info: 960 258048 last_lba: 483839
      [23.120]logical area info: 960 258048 last_lba: 483839
      [23.138]logical area info: 960 258048 last_lba: 483839
      [23.203]fill gap start: volume env sects 0xf8
      [23.353]fill gap end: volume env
      FEX_CMD_fes_verify_value, start 0x87e0, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x208e6f46
      [23.447]fill gap start: volume env-redund sects 0xf8
      [23.597]fill gap end: volume env-redund
      FEX_CMD_fes_verify_value, start 0x89d8, size high 0x0:low 0x20000
      [27.632]fill gap start: volume boot sects 0x47ec
      [29.120]fill gap end: volume boot
      FEX_CMD_fes_verify_value, start 0x8bd0, size high 0x0:low 0x83c800
      FEX_CMD_fes_verify_value 0x1beccd2
      到这一步后出现错误
      H 1 条回复 最后回复 回复 引用 分享 0
        hongyancl LV 5 @Godoword 最后由 编辑
        @godoword 在 D1系列烧录出现问题 中说:
        家帮忙看下是什么情况
        下面是log
        您的问题解决了吗,现在也遇到了这个问题。
