    百问网D1开发板HDMI、IR、WIFI 适配
      ddrddr LV 5 最后由 编辑
      HDMI、IR、WIFI 适配
      • DTS 文件
        • ./device/config/chips/d1-h/configs/nezha/uboot-board.dts
        • ./device/config/chips/d1-h/configs/nezha/linux-5.4/board.dts
      • 分区文件
        • ./target/allwinner/d1-h-nezha/swupdate/sys_partition_ab.fex
      默认 HDMI 输出
      这里我希望开机就是默认输出到 HDMI,需要对 ./device/config/chips/d1-h/configs/nezha/uboot-board.dts 进行修改
      对 uboot-board.dts 中的 disp 节的代码进行修改,patch 文件如下,把默认的输出设备改为 HDMI 输出
      diff --git a/configs/nezha/uboot-board.dts b/configs/nezha/uboot-board.dts
      index 81a521e..ca1b898 100644
      --- a/configs/nezha/uboot-board.dts
      +++ b/configs/nezha/uboot-board.dts
      @@ -214,31 +214,29 @@
      -	screen0_output_type      = <1>;
      -	screen0_output_mode      = <4>;
      -	screen1_output_type      = <3>;
      -	screen1_output_mode      = <10>;
      -	screen1_output_format    = <0>;
      -	screen1_output_bits      = <0>;
      -	screen1_output_eotf      = <4>;
      -	screen1_output_cs        = <257>;
      -	screen1_output_dvi_hdmi  = <2>;
      -	screen1_output_range     = <2>;
      -	screen1_output_scan      = <0>;
      -	screen1_output_aspect_ratio = <8>;
      -	dev0_output_type         = <1>;
      -	dev0_output_mode         = <4>;
      -	dev0_screen_id           = <0>;
      -	dev0_do_hpd              = <0>;
      -	dev1_output_type         = <4>;
      -	dev1_output_mode         = <10>;
      -	dev1_screen_id           = <1>;
      -	dev1_do_hpd              = <1>;
      +	screen0_output_type      = <3>;
      +	screen0_output_mode      = <10>;
      +	screen1_output_type      = <1>;
      +    screen1_output_mode      = <4>;
      +    screen0_output_format = <0>;
      +    screen0_output_bits = <0>;
      +    screen0_output_eotf = <4>;
      +    screen0_output_cs = <257>;
      +    screen0_output_dvi_hdmi = <2>;
      +    screen0_output_range = <2>;
      +    screen0_output_scan = <0>;
      +    screen0_output_aspect_ratio = <8>;
      +    dev0_output_type         = <4>;
      +	dev0_output_mode         = <10>;	dev0_screen_id           = <0>;
      +	dev0_do_hpd              = <1>;
      Wi-Fi、IR 适配
      查看核心板的原理图可以看到 XR829 蓝牙+WiFi 模块的 WL_REG_ON 管脚需要修改,在 SDK 原本的设备树中 WL_REG_ON 管脚是 PG12,但是开发板的管脚是 PB12
      [外链图片转存失败,源站可能有防盗链机制,建议将图片保存下来直接上传
      红外接收头的输入管脚接到的是 PG16,和 SDK 原本的 PB12 不同,也需要修改
      board.dts 的 patch 文件如下
      diff --git a/configs/nezha/linux-5.4/board.dts b/configs/nezha/linux-5.4/board.dts
      old mode 100755
      new mode 100644
      index 963aa17..15eed8c
      --- a/configs/nezha/linux-5.4/board.dts
      +++ b/configs/nezha/linux-5.4/board.dts
      @@ -464,14 +464,14 @@
       	s_cir0_pins_a: s_cir@0 {
      -		pins = "PB12";
      +		pins = "PG16";
       		function = "ir";
       		drive-strength = <10>;
       		bias-pull-up;
       	s_cir0_pins_b: s_cir@1 {
      -		pins = "PB12";
      +		pins = "PG16";
       		function = "gpio_in";
      @@ -566,7 +566,7 @@
       			clock-names = "32k-fanout1";
       			wlan_busnum    = <0x1>;
      -			wlan_regon    = <&pio PG 12 GPIO_ACTIVE_HIGH>;
      +			wlan_regon    = <&pio PB 12 GPIO_ACTIVE_HIGH>;
      @@ -1391,7 +1391,7 @@ pull up or pull down(default 0), driver level(default 1), data>
       	pinctrl-0 = <&s_cir0_pins_a>;
       	pinctrl-1 = <&s_cir0_pins_b>;
      -	status = "disabled";
      +	status = "okay";
       &ir1 {
      修改完了设备树后还需要修改一下 menuconfig 的配置,执行下面命令打开 kernel 的 menuconfig 的窗口
      make kernel_menuconfig
      然后使用 / 键进入搜索,搜索 IR_RX_SUNXI,可以看到我这里已经使能了,SDK 默认可能是没有使能的,需要修改下,前面标有(1),按下数字 1 键就可以跳转到这个位置
      这时红外功能就可以用了,后续会注册到 /dev/input/event* 中
      核心板的 Wi-Fi 模块有可能会是 24MHz 的晶振,而 SDK 默认的是 40MHz 的,需要修改下,运行命令打开 menuconfig
      make menuconfig
      使用 / 进入搜索模式,搜索 XR829,把 kmod-net-xr829-40M 改成 kmod-net-xr829
      失能掉 xr829 with 40M sdd
      确保 xr829-firmware 是使能的
      然后退出保存即可。
      烧录测试
      在 SDK 根目录以此运行如下命令完成编译和打包
      source build/envsetup.sh
      lunch
      make -j99
      pack
      将 Ubuntu 虚拟机编译出的镜像传输到 Windows 实体机中
      烧录到开发板中
      启动开发板,./device/config/chips/d1-h/configs/nezha/configs/bootlogo.bmp
      通过 HDMI 采集器可以看到在开发板启动的时候默认进入了 HDMI 的显示了
      ifconfig 命令查看网卡,可以看到 wlan0 了,使用 wifi_connect_ap_test 命令连接到 Wi-Fi
      wifi_connect_ap_test [ssid] [passwd]
      命令尝试连接到一个 Wi-Fi,连接完后尝试 ping 百度来看看
      ping baidu.com -Iwlan0
      可以看到通过 Wi-Fi 可以正常访问到互联网了
      再看看红外 O不OK
      cat /proc/bus/input/devices
      可以看到红外的输入对应的是 event1,然后使用 hexdump 查看下输出
