    T113 无法启动
      jeffrey LV 2 最后由 编辑
      燒入編譯的image 之後無法啟動
      log 如下
      [32]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : 1417090655
      [38]set pll start
      [44]periph0 has been enabled
      [47]set pll end
      [48][pmu]: bus read error
      [51]board init ok
      [53]enable_jtag
      [54]key press : ?
      [56]ZQ value = 0x2e
      [58]get_pmu_exist() = -1
      [60]DRAM BOOT DRIVE INFO: V0.33
      [63]DRAM CLK = 792 MHz
      [65]DRAM Type = 3 (2:DDR2,3:DDR3)
      [69]DRAMC read ODT  off.
      [71]DRAM ODT value: 0x42.
      [74]ddr_efuse_type: 0xa
      [77]DRAM SIZE =128 M
      [79]dram_tpr4:0x0
      [80]PLL_DDR_CTRL_REG:0xf8004100
      [83]DRAM_CLK_REG:0xc0000000
      [86][TIMING DEBUG] MR2= 0x18
      [94]DRAM simple test OK.
      [96]rtc standby flag is 0x0, super standby flag is 0x0
      [101]dram size =128
      [104]card no is 2
      [106]sdcard 2 line count 4
      [108][mmc]: mmc driver ver 2021-05-21 14:47
      [118][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [123][mmc]: ***Try MMC card 2***
      [146][mmc]: RMCA OK!
      [148][mmc]: wrong freq 2 at spd md 2
      [152][mmc]: mmc 2 bias 0
      [155][mmc]: MMC 5.1
      [157][mmc]: HSSDR52/SDR25 4 bit
      [160][mmc]: 50000000 Hz
      [162][mmc]: 7396 MB
      [164][mmc]: ***SD/MMC 2 init OK!!!***
      [255]Loading boot-pkg Succeed(index=0).
      [259]Entry_name        = u-boot
      [266]Entry_name        = optee
      [270]Entry_name        = dtb
      [273]tunning data addr:0x430003e8
      [276]Jump to second Boot.
      M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
      U-Boot 2018.07 (Dec 11 2023 - 06:46:44 +0000) Allwinner Technology
      [00.326]CPU:   Allwinner Family
      [00.329]Model: sun8iw20
      [00.332]DRAM:  128 MiB
      [00.335]Relocation Offset is: 04ec9000
      [00.361]secure enable bit: 0
      [00.375]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.381]gic: sec monitor mode
      sunxi flash map init
      [00.386]flash init start
      [00.388]workmode = 0,storage type = 2
      [00.392][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
      [00.398][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.422][mmc]: Best spd md: 1-HSSDR52/SDR25, freq: 2-50000000, Bus width: 4
      [00.429]sunxi flash init ok
      [00.431]line:703 init_clocks
      [00.434]drv_disp_init
      [00.439]handle_num : 6
      [00.450]drv_disp_init finish
      [00.454]Loading Environment from SUNXI_FLASH... Can't find env-redund partition
      *** Warning - no device, using default environment
      Failed (-19)
      [00.474]boot_gui_init:start
      [00.477]set disp.dev2_output_type fail. using defval=0
      [00.483]set disp.fb0_rot_used fail. using defval=0
      [00.487]set disp.fb0_rot_degree fail. using defval=0
      [00.493]boot_gui_init:finish
      [00.504]Get bootloader and boot-resource partition number fail!
      [00.510]Item0 (Map) magic is bad
      [00.513]the secure storage item0 copy0 magic is bad
      [00.517]Item0 (Map) magic is bad
      [00.520]the secure storage item0 copy1 magic is bad
      [00.525]Item0 (Map) magic is bad
      [00.528]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.539]usb prepare ok
      [00.663]LCD open finish
      [00.746]usb sof ok
      [00.747]usb probe ok
      [00.749]usb setup ok
      set address 0x24
      set address 0x24 ok
      try to update
      [01.154]do_burn_from_boot usb : have no handshake
      cann't get the boot_base from the env
      [01.173]update part info
      [01.175]update bootcmd
      [01.178]change working_fdt 0x44888e70 to 0x44868e70
      [01.183][mmc]: no mmc-hs400-1_8v!
      [01.186][mmc]: delete mmc-hs200-1_8v from dtb
      [01.190][mmc]: delete mmc-ddr-1_8v from dtb
      [01.194][mmc]: get max-frequency ok 50000000 Hz
      [01.220]update dts
      ## Error: "distro_bootcmd" not defined
      按照Tina_Linux_系统软件_开发指南 編的image
      source build/envsetup.sh
      lunch t113-evb1_auto-tina
      make -j1
      pack
      用PhoenixSuit, 選用分區擦除升級
      有人能幫忙看看問題出在哪嗎?
        zoipuus LV 5 最后由 编辑
