    V851S用AIC8800D80报错
    • X
      xiaok LV 3 最后由 编辑
      • 用的这个SDK编译的,https://github.com/YuzukiHD/TinyVision/tree/main/tina
      • 启动日志
      [    1.540141] ALSA device list:
      [    1.540147]   #0: audiocodec
      [    1.540150]   #1: snddaudio0
      [    1.541510] EXT4-fs (mmcblk0p4): couldn't mount as ext3 due to feature incompatibilities
      [    1.551713] EXT4-fs (mmcblk0p4): couldn't mount as ext2 due to feature incompatibilities
      [    1.566473] EXT4-fs (mmcblk0p4): mounted filesystem without journal. Opts: (null)
      [    1.566552] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
      [    1.567442] devtmpfs: mounted
      [    1.569547] Freeing unused kernel memory: 1024K
      [    1.569674] will run init ...
      [    1.855838] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    1.867562] EXT4-fs (mmcblk0p6): mounted filesystem with journalled data mode. Opts: data=journal
      [    1.893059] EXT4-fs (mmcblk0p4): warning: mounting unchecked fs, running e2fsck is recommended
      [    1.894094] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null)
      [    1.961598] aicbsp_init
      [    1.961608] aicbsp_init, Driver Release Tag: aic-bsp-compatible(sdio)-20231031-000
      [    1.963152] -->aicbt_rfkill_init
      [    1.963497] <--aicbt_rfkill_init
      [    1.976150] >>> rwnx_mod_init()
      [    1.976159] rwnx 20231031-004-6.4.3.0 - - 241c091M (master)
      [    1.976163] Driver Release Tag: aic-rwnx-compatible(sdio)-20231031-004
      [    1.976173] aicbsp: aicbsp_set_subsys, subsys: AIC_WIFI, state to: 1
      [    1.976177] aicbsp: aicbsp_set_subsys, power state change to 1 dure to AIC_WIFI
      [    1.976180] aicbsp: aicbsp_platform_power_on
      [    1.976194] sunxi-wlan soc@03000000:wlan@0: bus_index: 1
      [    1.976337] aicbsp: aicbsp_platform_power_on disable MMC_CAP_UHS_DDR50 for host c3af7000
      [    2.036752] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.036946] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
      [    2.062451] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.093261] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.100027] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
      [    2.105979] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.108455] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.119127] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.119210] sunxi-mmc sdc1: sdc set ios:clk 20000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    2.119396] sunxi-mmc sdc1: sdc set ios:clk 21428571Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    2.121489] mmc1: new high speed SDIO card at address 390b
      [    2.138535] aicbsp: aicbsp_sdio_probe:2
      [    2.138547] aicbsp: aicbsp_sdio_probe:2, matched chip: aic8800d80
      [    2.138552] aicbsp: aicbsp_sdio_probe after replace:1
      [    2.138559] aicbsp: aicbsp_sdio_probe host max clock frequecy: 20000000
      [    2.138564] aicbsp: aicwf_sdio_reg_init
      [    2.164435] aicbsp: aicbsp_8800d80_fw_init, rev id: 0x7, subrev id: 0x82
      [    2.166463] rwnx_request_firmware, name: aic8800d80/fw_patch_table_8800d80_u02.bin
      [    2.166501] aicbt_patch_info_unpack bt patch version: - Dec 07 2023 21:16:27 - git 487f432
      [    2.167158] rwnx_request_firmware, name: aic8800d80/fw_adid_8800d80_u02.bin
      [    2.169309] rwnx_request_firmware, name: aic8800d80/fw_patch_8800d80_u02.bin
      [    2.180599] aicbt_patch_table_load bt uart baud: 1500000, flowctrl: 1, lpm_enable: 1, tx_pwr: 24608, bt mode:5.
      [    2.208550] rwnx_request_firmware, name: aic8800d80/fmacfw_8800d80_u02.bin
      [    2.337814] aicsdio: aicwf_sdio_probe:1
      [    2.337825] aicsdio: aicwf_sdio_reg_init
      [    2.367622] aicbsp: aicbsp_resv_mem_alloc_skb, alloc resv_mem_txdata succuss, id: 0, size: 98304
      [    2.368098] >>> rwnx_platform_init()
      [    2.368106] >>> rwnx_cfg80211_init()
      [    2.368122] rwnx_cfg80211_init sizeof(struct rwnx_hw):27648
      [    2.368185] >>> rwnx_init_aic()
      [    2.368192] >>> rwnx_cmd_mgr_init()
      [    2.368944] >>> rwnx_send_set_stack_start_req()
      [    2.369438] is 5g support = 1, vendor_info = 0x00
      [    2.369731] Firmware Version: mi Nov 02 2023 19:30:14 - gde5899f
      [    2.369743] rwnx_platform_on: 947 fw=aic8800d80/aic_userconfig_8800d80.txt
      [    2.377471] aicbsp: err:<aicwf_sdio_bus_pwrctl,1256>: bus down
      [    2.384059] >>> rwnx_platform_on()
      [    2.384064] >>> rwnx_plat_fmac_load()
      [    2.385006] userconfig file path:aic8800d80/aic_userconfig_8800d80.txt
      [    2.385317] rwnx_plat_userconfig_parsing, enable = 1
      [    2.385335] rwnx_plat_userconfig_parsing, lvl_11b_11ag_1m_2g4 = 18
      [    2.385350] rwnx_plat_userconfig_parsing, lvl_11b_11ag_2m_2g4 = 18
      [    2.385366] rwnx_plat_userconfig_parsing, lvl_11b_11ag_5m5_2g4 = 18
      [    2.385383] rwnx_plat_userconfig_parsing, lvl_11b_11ag_11m_2g4 = 18
      [    2.385401] rwnx_plat_userconfig_parsing, lvl_11b_11ag_6m_2g4 = 18
      [    2.385420] rwnx_plat_userconfig_parsing, lvl_11b_11ag_9m_2g4 = 18
      [    2.385440] rwnx_plat_userconfig_parsing, lvl_11b_11ag_12m_2g4 = 18
      [    2.385461] rwnx_plat_userconfig_parsing, lvl_11b_11ag_18m_2g4 = 18
      [    2.385483] rwnx_plat_userconfig_parsing, lvl_11b_11ag_24m_2g4 = 16
      [    2.385506] rwnx_plat_userconfig_parsing, lvl_11b_11ag_36m_2g4 = 16
      [    2.385530] rwnx_plat_userconfig_parsing, lvl_11b_11ag_48m_2g4 = 16
      [    2.385555] rwnx_plat_userconfig_parsing, lvl_11b_11ag_54m_2g4 = 16
      [    2.385581] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs0_2g4 = 18
      [    2.385608] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs1_2g4 = 18
      [    2.385636] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs2_2g4 = 18
      [    2.385665] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs3_2g4 = 18
      [    2.385695] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs4_2g4 = 16
      [    2.385727] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs5_2g4 = 16
      [    2.385759] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs6_2g4 = 15
      [    2.385793] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs7_2g4 = 15
      [    2.385827] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs8_2g4 = 14
      [    2.385863] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs9_2g4 = 14
      [    2.385896] rwnx_plat_userconfig_parsing, lvl_11ax_mcs0_2g4 = 18
      [    2.385930] rwnx_plat_userconfig_parsing, lvl_11ax_mcs1_2g4 = 18
      [    2.385965] rwnx_plat_userconfig_parsing, lvl_11ax_mcs2_2g4 = 18
      [    2.386000] rwnx_plat_userconfig_parsing, lvl_11ax_mcs3_2g4 = 18
      [    2.386037] rwnx_plat_userconfig_parsing, lvl_11ax_mcs4_2g4 = 16
      [    2.386075] rwnx_plat_userconfig_parsing, lvl_11ax_mcs5_2g4 = 16
      [    2.386114] rwnx_plat_userconfig_parsing, lvl_11ax_mcs6_2g4 = 15
      [    2.386154] rwnx_plat_userconfig_parsing, lvl_11ax_mcs7_2g4 = 15
      [    2.386195] rwnx_plat_userconfig_parsing, lvl_11ax_mcs8_2g4 = 14
      [    2.386237] rwnx_plat_userconfig_parsing, lvl_11ax_mcs9_2g4 = 14
      [    2.386281] rwnx_plat_userconfig_parsing, lvl_11ax_mcs10_2g4 = 13
      [    2.386326] rwnx_plat_userconfig_parsing, lvl_11ax_mcs11_2g4 = 13
      [    2.386400] rwnx_plat_userconfig_parsing, lvl_11a_6m_5g = 18
      [    2.386475] rwnx_plat_userconfig_parsing, lvl_11a_9m_5g = 18
      [    2.386550] rwnx_plat_userconfig_parsing, lvl_11a_12m_5g = 18
      [    2.386626] rwnx_plat_userconfig_parsing, lvl_11a_18m_5g = 18
      [    2.386703] rwnx_plat_userconfig_parsing, lvl_11a_24m_5g = 16
      [    2.386781] rwnx_plat_userconfig_parsing, lvl_11a_36m_5g = 16
      [    2.386860] rwnx_plat_userconfig_parsing, lvl_11a_48m_5g = 15
      [    2.386940] rwnx_plat_userconfig_parsing, lvl_11a_54m_5g = 15
      [    2.387034] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs0_5g = 18
      [    2.387129] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs1_5g = 18
      [    2.387225] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs2_5g = 18
      [    2.387322] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs3_5g = 18
      [    2.387420] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs4_5g = 16
      [    2.387519] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs5_5g = 16
      [    2.387620] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs6_5g = 15
      [    2.387721] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs7_5g = 14
      [    2.387823] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs8_5g = 14
      [    2.387927] rwnx_plat_userconfig_parsing, lvl_11n_11ac_mcs9_5g = 14
      [    2.388021] rwnx_plat_userconfig_parsing, lvl_11ax_mcs0_5g = 18
      [    2.388117] rwnx_plat_userconfig_parsing, lvl_11ax_mcs1_5g = 18
      [    2.388214] rwnx_plat_userconfig_parsing, lvl_11ax_mcs2_5g = 18
      [    2.388312] rwnx_plat_userconfig_parsing, lvl_11ax_mcs3_5g = 18
      [    2.388411] rwnx_plat_userconfig_parsing, lvl_11ax_mcs4_5g = 16
      [    2.388510] rwnx_plat_userconfig_parsing, lvl_11ax_mcs5_5g = 16
      [    2.388611] rwnx_plat_userconfig_parsing, lvl_11ax_mcs6_5g = 14
      [    2.388713] rwnx_plat_userconfig_parsing, lvl_11ax_mcs7_5g = 14
      [    2.388815] rwnx_plat_userconfig_parsing, lvl_11ax_mcs8_5g = 13
      [    2.388919] rwnx_plat_userconfig_parsing, lvl_11ax_mcs9_5g = 13
      [    2.389024] rwnx_plat_userconfig_parsing, lvl_11ax_mcs10_5g = 12
      [    2.389131] rwnx_plat_userconfig_parsing, lvl_11ax_mcs11_5g = 12
      [    2.389732] rwnx_plat_userconfig_parsing, ofst2x_enable = 0
      [    2.389844] rwnx_plat_userconfig_parsing, ofst_2g4_11b_chan_1_4 = 0
      [    2.389957] rwnx_plat_userconfig_parsing, ofst_2g4_11b_chan_5_9 = 0
      [    2.390072] rwnx_plat_userconfig_parsing, ofst_2g4_11b_chan_10_13 = 2
      [    2.390194] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_highrate_chan_1_4 = 0
      [    2.390317] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_highrate_chan_5_9 = 3
      [    2.390444] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_highrate_chan_10_13 = 3
      [    2.390569] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_lowrate_chan_1_4 = 0
      [    2.390695] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_lowrate_chan_5_9 = 0
      [    2.390824] rwnx_plat_userconfig_parsing, ofst_2g4_ofdm_lowrate_chan_10_13 = 2
      [    2.390951] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_42 = 5
      [    2.391078] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_58 = 0
      [    2.391208] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_106 = 0
      [    2.391340] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_122 = 0
      [    2.391472] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_138 = 0
      [    2.391606] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_lowrate_chan_155 = 3
      [    2.391741] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_42 = 5
      [    2.391877] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_58 = 0
      [    2.392015] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_106 = 0
      [    2.392155] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_122 = 0
      [    2.392296] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_138 = 0
      [    2.392576] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_highrate_chan_155 = 3
      [    2.392721] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_42 = 5
      [    2.392864] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_58 = 0
      [    2.393009] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_106 = 0
      [    2.393155] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_122 = 0
      [    2.393303] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_138 = 0
      [    2.393452] rwnx_plat_userconfig_parsing, ofst_5g_ofdm_midrate_chan_155 = 3
      [    2.393699] rwnx_plat_userconfig_parsing, xtal_enable = 0
      [    2.393823] rwnx_plat_userconfig_parsing, xtal_cap = 5
      [    2.393955] rwnx_plat_userconfig_parsing, xtal_cap_fine = 31
      [    2.393978] >>> rwnx_send_rf_calib_req()
      [    2.562425]
      [    2.562425] insmod_device_driver
      [    2.562425]
      [    2.563029] device_chose finished 122!
      [    3.021622] >>> rwnx_send_txpwr_lvl_v3_req()
      [    3.021947] >>> rwnx_send_txpwr_ofst2x_req()
      [    3.021954] rwnx_send_txpwr_ofst2x_req:Do not use txpwr_ofst2x
      [    3.021957] >>> rwnx_msg_free()
      [    3.021961] >>> rwnx_send_get_macaddr_req()
      [    3.022362] get macaddr: 48:8f:4c:bf:30:b0
      [    3.022367] >>> rwnx_send_reset()
      [    3.023176] >>> rwnx_send_version_req()
      [    3.023461] >>> rwnx_set_vers()
      [    3.023484] >>> rwnx_send_me_config_req()
      [    3.023501] ieee80211 phy0: HT supp 1, VHT supp 1, HE supp 1
      [    3.024217] >>> rwnx_send_me_chan_config_req()
      [    3.025144] >>> rwnx_send_me_chan_config_req()
      [    3.025534] >>> rwnx_dbgfs_register()
      [    3.025644] rwnx_interface_add: wlan%d, 2, 10interface add:48 8f 4c bf 30 b0
      [    3.077422] ieee80211 phy0: New interface create wlan0
      [    3.084956] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
      [    3.084966] [BT_LPM] bluesleep_init: Driver Release Tag: aic-btlpm-20220429-005
      [    3.087246] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.3.3
      [    3.087255] [BT_LPM] bluesleep_init: Driver Release Tag: aic-btlpm-20220429-005
      [    3.123241] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [    3.123258] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [    3.123268] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [    3.123277] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [    3.158960] [VIN_WARN]Get isp clk failed!
      [    3.158989] [VIN_ERR]Get temp top clk source1 failed!
      [    3.165040] [VIN_ERR]set vin top clock rate error
      [    3.204879] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.214431] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.223958] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.233296] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
      [    3.233697] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.243186] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.252673] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.261984] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
      [    3.262381] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.271867] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.281353] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.290681] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
      [    3.291077] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.300561] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.310044] sunxi_i2c_do_xfer()2045 - [i2c3] incomplete xfer (status: 0x20, dev addr: 0x37)
      [    3.319370] [VIN_DEV_I2C]gc2053_mipi read retry 3, read addr is 0xf0
      [    3.319375] [gc2053_mipi] error, chip found is not an target chip.
      [    3.338739] [VIN_ERR]registering gc2053_mipi, No such device!
      [    3.454816] random: dd: uninitialized urandom read (512 bytes read)
      [    3.804743] file system registered
      [    3.829162] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [    3.865567] read descriptors
      [    3.865590] read strings
      [    4.050735] sunxi_set_cur_vol_work()430 WARN: get power supply failed
      [    4.101398] android_work: sent uevent USB_STATE=CONNECTED
      [    4.121283] configfs-gadget gadget: high-speed config #1: c
      [    4.121559] android_work: sent uevent USB_STATE=CONFIGURED
      [    6.014480] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [    6.135629] random: wpa_supplicant: uninitialized urandom read (3 bytes read)
      [    6.135653] random: wpa_supplicant: uninitialized urandom read (1024 bytes read)
      [    9.263526] random: crng init done
      • wifi -o sta 报错
      1970-01-01 00:00:09:063: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:09:063: WMG_DEBUG [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1429]:  wpa_supplicant is not running, need to start it
      root@TinaLinux:/# Successfully initialized wpa_supplicant
      wlan0: Unsupported driver 'nl80211'
      1970-01-01 00:00:10:120: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:11:160: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:12:203: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:13:250: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:14:295: WMG_EXCESSIVE [src/os/linux/utils.c:check_process_is_exist:32]: wpa_supplicant not exist
      1970-01-01 00:00:14:295: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:357]:  failed to start wpa_supplicant times 1
      1970-01-01 00:00:14:304: WMG_ERROR [src/os/linux/linux_wpa.c:start_supplicant:357]:  failed to start wpa_supplicant times 2
      1970-01-01 00:00:14:304: WMG_ERROR [src/os/linux/linux_wpa.c:linux_connect_to_supplicant:1432]:  start wpa_supplicant failed
      1970-01-01 00:00:14:305: WMG_ERROR [src/wmg_sta.c:sta_mode_enable:416]:  failed to connect to wpa_supplicant
      1970-01-01 00:00:14:305: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:297]:  wifi sta mode enable faile
      1970-01-01 00:00:14:305: WMG_DEBUG [src/wmg_common.c:wifimg_switch_mode:320]:  switch after current_mode_bitmap:0x0
      1970-01-01 00:00:14:305: WMG_ERROR [src/wmg_common.c:wifimg_switch_mode:327]:  switch mode faile
      1970-01-01 00:00:14:305: WMG_ERROR [src/wifimg.c:__wifi_on:34]:  failed to switch wifi mode
      1970-01-01 00:00:14:305: WMG_ERROR [wifi_daemon.c:cmd_handle_o:58]:  wifi on sta mode failed
      • 手动执行 wpa_supplicant 不加 -D nl80211 参数不会报错,但是也连不上
      root@TinaLinux:/# ip a
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1
          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
          inet 127.0.0.1/8 scope host lo
             valid_lft forever preferred_lft forever
          inet6 ::1/128 scope host
      2: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN qlen 1
          link/sit 0.0.0.0 brd 0.0.0.0
      3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN qlen 1000
          link/ether 48:8f:4c:bf:30:b0 brd ff:ff:ff:ff:ff:ff
      root@TinaLinux:/# ifconfig wlan0 up
      root@TinaLinux:/# wpa_supplicant -i wlan0 -c /etc/wpa_supplicant.conf &
      wlan0: Associated with 01:80:c2:00:00:03
      wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
      root@TinaLinux:/# udhcpc -i wlan0
      udhcpc: started, v1.33.2
      udhcpc: sending discover
      wlan0: CTRL-EVENT-EAP-FAILURE EAP authentication failed
      • 内核配置部分
      CONFIG_BT=y
      CONFIG_BT_RFCOMM=y
      CONFIG_BT_RFCOMM_TTY=y
      # CONFIG_BT_HS is not set
      # CONFIG_BT_LE is not set
      CONFIG_XR_BT_LPM=y
      CONFIG_XR_BT_FDI=y
      CONFIG_BT_HCIUART=y
      CONFIG_BT_HCIUART_H4=y
      CONFIG_HFP_OVER_PCM=y
      CONFIG_CFG80211=y
      CONFIG_NL80211_TESTMODE=y
      CONFIG_CFG80211_DEBUGFS=y
      CONFIG_CFG80211_INTERNAL_REGDB=y
      CONFIG_CFG80211_WEXT=y
      CONFIG_MAC80211=y
      CONFIG_MAC80211_RC_MINSTREL_VHT=y
      CONFIG_RFKILL=y
      CONFIG_RFKILL_GPIO=y
      CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
      CONFIG_DEVTMPFS=y
      CONFIG_DEVTMPFS_MOUNT=y
      大佬们,该如何排查解决.
      • 买了aic8800d40测试,还没到货
      S 1 条回复 最后回复 回复 引用 分享 1
        syk1324 LV 3 @xiaok 最后由 编辑
        @xiaok 您好!我遇到同样的问题。请问解决了吗?
        X 1 条回复 最后回复 回复 引用 分享 0
        • X
          xiaok LV 3 @syk1324 最后由 编辑
          @syk1324 没有解决,后面换RTL8821CS和RTL8189FS全都正常,AIC8800不行。
