    T113-i tina 启动时卡在uboot 显示emmc出错
    创龙科技专区
    • V
      vc LV 4 最后由 编辑
      [120]HELLO! BOOT0 is starting!
      [123]BOOT0 commit : 069ed30b88
      [126]set pll start
      [128]fix vccio detect value:0xc0
      [136]periph0 has been enabled
      [139]set pll end
      [140][pmu]: bus read error
      [143]board init ok
      [145]enable_jtag
      [146]get_pmu_exist() = -1
      [149]ddr_efuse_type: 0x0
      [151]trefi:7.8ms
      [154][AUTO DEBUG] single rank and full DQ!
      [158]ddr_efuse_type: 0x0
      [160]trefi:7.8ms
      [163][AUTO DEBUG] rank 0 row = 15
      [166][AUTO DEBUG] rank 0 bank = 8
      [169][AUTO DEBUG] rank 0 page size = 2 KB
      [173]DRAM BOOT DRIVE INFO: V0.34
      [177]DRAM CLK = 792 MHz
      [179]DRAM Type = 3 (2:DDR2,3:DDR3)
      [182]DRAMC ZQ value: 0x7b7bfb
      [185]DRAM ODT value: 0x42.
      [188]ddr_efuse_type: 0x0
      [191]DRAM SIZE = 512 MB
      [198]DRAM simple test OK.
      [200]rtc standby flag is 0x0, super standby flag is 0x0
      [205]dram size =512
      [208]card no is 0
      [210]sdcard 0 line count 4
      [212][mmc]: mmc driver ver 2021-05-21 14:47
      [222][mmc]: Wrong media type 0x0
      [225][mmc]: ***Try SD card 0***
      [254][mmc]: HSSDR52/SDR25 4 bit
      [257][mmc]: 50000000 Hz
      [259][mmc]: 3781 MB
      [261][mmc]: ***SD/MMC 0 init OK!!!***
      [365]Loading boot-pkg Succeed(index=0).
      [369]Entry_name        = u-boot
      [377]Entry_name        = optee
      [381]Entry_name        = dtb
      [384]mmc not para
      [385]Jump to second Boot.
      M/TC: OP-TEE version: 2a99a16f (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Thu Aug 17 11:13:02 UTC 2023 arm
      E/TC:0 0 platform_standby_fdt_parse:126 no pmu0 node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.07-g0317dec-dirty (Mar 26 2024 - 09:11:55 +0000) Allwinner Technology
      [00.457]CPU:   Allwinner Family
      [00.460]Model: sun8iw20
      I2C:   ready
      [00.480]DRAM:  512 MiB
      [00.483]Relocation Offset is: 1ce93000
      [00.513]secure enable bit: 0
      E/TC:0   fdt_getprop_u32:336 prop trace_level not found
      [00.527]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.534]gic: sec monitor mode
      SPI ALL:   ready
      [00.539]line:719 init_clocks
      [00.542]flash init start
      [00.544]workmode = 0,storage type = 1
      [00.548][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
      [00.553][mmc]: get sdc_type fail and use default host:tm1.
      [00.559][mmc]: can't find node "mmc0",will add new node
      [00.564][mmc]: fdt err returned <no error>
      [00.568][mmc]: Using default timing para
      [00.571][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.607][mmc]: card_caps:0x3000000a
      [00.610][mmc]: host_caps:0x3000003f
      [00.617]sunxi flash init ok
      get value error
      [00.621]drv_disp_init
      [00.680]drv_disp_init finish
      [04.695]env/env.c:env_load:233:Waiting for display 1 timeout
      [04.700]Loading Environment from SUNXI_FLASH... OK
      [04.737]boot_gui_init:start
      [04.747]LCD open finish
      bad fb1_cfg[w=0,h=0,bpp=32,format=0]
      [04.753]boot_gui_init:finish
      [04.763]bmp_name=bootlogo.bmp size 1036854
      [04.824]Item0 (Map) magic is bad
      [04.827]the secure storage item0 copy0 magic is bad
      [04.835]Item0 (Map) magic is bad
      [04.838]the secure storage item0 copy1 magic is bad
      [04.843]Item0 (Map) magic is bad
      [04.873]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [04.884]usb prepare ok
      [05.187]overtime
      [05.190]do_burn_from_boot usb : no usb exist
      cann't get the boot_base from the env
      [05.199]update part info
      [05.202]update bootcmd
      [05.215]change working_fdt 0x5c852e68 to 0x5c832e68
      get value error
      [05.222][mmc]: get sunxi-mmc0 string failed
      [05.227]The storage not support sample function
      [05.251]update dts
      phy_mode=rgmii, phy_interface=7
      get phy-tx-delay fail!geth_sys_init fail!
      [05.261]Board Net Initialization Failed
      [05.265]No ethernet found.
      =====YTR==workmode=0==if_need_auto_force_burn=0, nRet=-1,auto_update_system
      Hit <SPACE> key to stop autoboot in  1s
      [05.532]no vendor_boot partition is found
      The loading address of the kernel is not in the boot image
      ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
      ERROR: reserving fdt memory region failed (addr=5c8dd000 size=271000)
      [05.564]Starting kernel ...
      [05.567][mmc]: MMC Device 2 not found
      [05.570][mmc]: mmc 2 not find, so not exit
      Tronlong_support 1 条回复 最后回复 回复 引用 分享 2
      • Tronlong_support
        Tronlong_support LV 5 @vc915813805 最后由 Tronlong_support 编辑
        @vc915813805 您好,可是使用SD卡启动方式,看下是否可以正常启动。
        • T
          tigers LV 4 最后由 编辑
          出现了同样的问题,您后俩有解决吗?
