    第一次用F133,驱动I80接口失败,求助大佬
      zhangjingxun12 LV 4 最后由 编辑
      这是第一次弄全志soc和linux,一路跟着tina的文档走,前面调试rgb屏测试ok,不过后面想用i80接口,结果这几天折腾,没折腾明白,网上没找到对应的(有其他的,但没看明白,实力限制……),发个帖求助下大佬们,因为初次搞这个,操作步骤粗鄙不堪入目之处,请多多见谅,后面可以多给小弟批评指正下,多谢!
      先说问题
      进入系统后,启动日志:
      [34]HELLO! BOOT0 is starting!
      [37]BOOT0 commit : 88480af
      [40]set pll start
      [42]periph0 has been enabled
      [44]set pll end
      [46][pmu]: bus read error
      [48]board init ok
      [50]ZQ value = 0x30
      [52]get_pmu_exist() = -1
      [54]DRAM BOOT DRIVE INFO: V0.33
      [57]DRAM CLK = 528 MHz
      [59]DRAM Type = 2 (2:DDR2,3:DDR3)
      [62]DRAMC read ODT  off.
      [65]DRAM ODT off.
      [67]ddr_efuse_type: 0xa
      [69]DRAM SIZE =64 M
      [71]dram_tpr4:0x0
      [73]PLL_DDR_CTRL_REG:0xf8002b00
      [76]DRAM_CLK_REG:0xc0000000
      [78][TIMING DEBUG] MR2= 0x0
      [83]DRAM simple test OK.
      [85]dram size =64
      [87]spinor id is: ef 40 19, read cmd: 0b
      [90]Succeed in reading toc file head.
      [94]The size of toc is 10c000.
      [273]Entry_name        = opensbi
      [276]Entry_name        = u-boot
      [280]Entry_name        = dtb
      [282]Jump to second Boot.
      OpenSBI auto-t113-linux-V0.8-1-g771d82e
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
      U-Boot 2018.05-g2a1965a (Jul 10 2022 - 02:50:57 +0000) Allwinner Technology
      [00.367]DRAM:  64 MiB
      [00.369]Relocation Offset is: 01ed9000
      [00.374]secure enable bit: 0
      [00.377]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.383]flash init start
      [00.385]workmode = 0,storage type = 3
      [00.392]spi sunxi_slave->max_hz:100000000
      SF: write offset not multiple of erase size
      [01.109]spi sample_mode:1 sample_delay:1d
      [01.114]spi sunxi_slave->max_hz:100000000
      SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
      [01.126]sunxi flash init ok
      [01.128]line:703 init_clocks
      [01.131]drv_disp_init
      [01.149]unable to map hdmi registers
      [01.152]drv_disp_init finish
      [01.156]Loading Environment from SUNXI_FLASH... OK
      [01.170]boot_gui_init:start
      [01.173]set disp.dev2_output_type fail. using defval=0
      [01.180]boot_gui_init:finish
      [01.190]sunxi bmp info error : unable to open logo file bootlogo.bmp
      [01.196]out of usb burn from boot: not need burn key
      [01.201]get secure storage map err
      root_partition is rootfs
      set root to /dev/mtdblock5
      [01.212]update part info
      [01.215]update bootcmd
      [01.217]change working_fdt 0x42a98da0 to 0x42a78da0
      disable nand error: FDT_ERR_NOTFOUND
      [01.247]update dts
      noncached_alloc(): addr = 0x42ae8480
      noncached_alloc(): addr = 0x42ae84c0
      noncached_alloc(): addr = 0x42ae8500
      noncached_alloc(): addr = 0x42ac27c0
      geth_sys_init:639: get node 'gmac0' error
      geth_sys_init fail!
      [01.267]Board Net Initialization Failed
      [01.271]No ethernet found.
      [01.370]LCD open finish        0
      [02.417]no vendor_boot partition is found
      Android's image name: f133-mq_r
      Detect comp none
      [02.433]
      Starting kernel ...
      [    0.000000] Linux version 5.4.61 (test@test-virtual-machine) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #102 PREEMPT Wed Jul 17 03:01:59 UTC 2024
      [    0.000000] Zone ranges:
      [    0.000000]   DMA32    [mem 0x0000000040000000-0x0000000043ffffff]
      [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000043ffffff]
      [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
      [    0.000000]   DMA32 zone: 224 pages used for memmap
      [    0.000000]   DMA32 zone: 16384 pages, LIFO batch:3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16160
      [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mtdblock5 rootfstype=squashfs init=/pseudo_init partitions=boot-resource@mtdblock1:env@mtdblock2:env-redund@mtdblock3:boot@mtdblock4:rootfs@mtdblock5:UDISK@mtdblock6 cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=3 androidboot.boot_type=3 gpt=1 uboot_message=2018.05-g2a1965a(07/10/2022-02:50:57) mbr_offset=1556480
      [    0.000000] Dentry cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.000000] Inode-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
      [    0.000000] Memory: 56072K/65536K available (3963K kernel code, 419K rwdata, 1676K rodata, 136K init, 222K bss, 9464K reserved, 0K cma-reserved)
      [    0.000006] sched_clock: 64 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.000027] riscv_timer_clockevent depends on broadcast, but no broadcast function available
      [    0.000363] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000925] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000945] pid_max: default: 32768 minimum: 301
      [    0.001116] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.001139] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.003003] ASID allocator initialised with 65536 entries
      [    0.003180] rcu: Hierarchical SRCU implementation.
      [    0.003869] devtmpfs: initialized
      [    0.022074] random: get_random_u32 called from bucket_table_alloc.isra.27+0xfa/0x11c with crng_init=0
      [    0.022946] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.022978] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
      [    0.023140] pinctrl core: initialized pinctrl subsystem
      [    0.024565] NET: Registered protocol family 16
      [    0.025315] DMA: preallocated 256 KiB pool for atomic allocations
      [    0.025902] cpuidle: using governor menu
      [    0.064749] rtc_ccu: sunxi ccu init OK
      [    0.073056] clock: sunxi ccu init OK
      [    0.074810] clock: sunxi ccu init OK
      [    0.103572] iommu: Default domain type: Translated
      [    0.103766] sunxi iommu: irq = 4
      [    0.104930] SCSI subsystem initialized
      [    0.105150] usbcore: registered new interface driver usbfs
      [    0.105234] usbcore: registered new interface driver hub
      [    0.105340] usbcore: registered new device driver usb
      [    0.106322] Advanced Linux Sound Architecture Driver Initialized.
      [    0.107207] pwm module init!
      [    0.108815] g2d 5410000.g2d: Adding to iommu group 0
      [    0.109329] G2D: rcq version initialized.major:252
      [    0.109940] clocksource: Switched to clocksource riscv_clocksource
      [    0.121725] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.124830] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    0.125661] NET: Registered protocol family 2
      [    0.126536] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.126591] TCP established hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.126609] TCP bind hash table entries: 512 (order: 0, 4096 bytes, linear)
      [    0.126624] TCP: Hash tables configured (established 512 bind 512)
      [    0.126791] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.126837] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.127072] NET: Registered protocol family 1
      [    0.128254] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.128875] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.129124] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [    0.129193] sunxi_spi_resource_get()2163 - sample_mode:1 sample_delay:29
      [    0.129250] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [    0.130225] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base ffffffd00405a000, irq 31
      [    0.132323] workingset: timestamp_bits=62 max_order=14 bucket_order=0
      [    0.137849] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.138093] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.138379] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
      [    0.138752] fuse: init (API version 7.31)
      [    0.159206] io scheduler mq-deadline registered
      [    0.159222] io scheduler kyber registered
      //	disp初始化
      [    0.160168] [DISP]disp_module_init
      [    0.160764] disp 5000000.disp: Adding to iommu group 0
      [    0.161372] [DISP] disp_init,line:2386:
      [    0.161379] smooth display screen:0 type:1 mode:4
      // lcd初始化
      [    0.161519] lcd_init
      [    0.162442] display_fb_request,fb_id:0
      [    0.164044] [DISP] Fb_copy_boot_fb,line:1505:
      [    0.164052] src_height(480) > dst_height(240),please cut the height
      [    0.164566] disp_al_manager_apply ouput_type:1
      [    0.164686] lcd_clk_config
      [    0.164714] [DISP] lcd_clk_config,line:895:
      [    0.164724] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
      [    0.164724]      clk real:pll(297000000),clk(288000000),dclk(0) dsi_rate(0)
      [    0.165384] [DISP]disp_module_init finish
      // 初始化完成
      [    0.166269] sunxi_sid_init()551 - insmod ok
      [    0.166844] pwm-regulator: supplied by regulator-dummy
      [    0.168566] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    0.169052] uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.169458] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
      [    0.169485] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    0.901824] printk: console [ttyS0] enabled
      [    0.907650] misc dump reg init
      [    0.912094] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.923384] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.930643] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.937997] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.945427] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.951966] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.958911] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.966651] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    0.974595] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.982747] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.990495] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.997223] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.004867] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
      [    1.013067] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    1.020810] [ADDR_MGT] addr_mgt_probe: success.
      [    1.027372] spi-nor spi0.0: w25q256 (32768 Kbytes)
      [    1.037933] 7 sunxipart partitions found on MTD device spi0.0
      [    1.044469] Creating 7 MTD partitions on "spi0.0":
      [    1.049818] 0x000000000000-0x000000180000 : "uboot"
      [    1.060809] 0x000000180000-0x000000190000 : "boot-resource"
      [    1.080774] 0x000000190000-0x0000001d0000 : "env"
      [    1.090766] 0x0000001d0000-0x000000210000 : "env-redund"
      [    1.110713] 0x000000210000-0x000000990000 : "boot"
      [    1.120792] 0x000000990000-0x000001110000 : "rootfs"
      [    1.140711] 0x000001110000-0x000002000000 : "UDISK"
      [    1.151730] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.162746] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.173538] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.184770] sunxi-rtc 7090000.rtc: registered as rtc0
      [    1.190542] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    1.201147] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T01:48:07 UTC (6487)
      [    1.210372] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    1.216333] sunxi cedar version 1.1
      [    1.220563] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.226850] VE: install start!!!
      [    1.226850]
      [    1.232424] VE: cedar-ve the get irq is 6
      [    1.232424]
      [    1.238767] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
      [    1.238767]
      [    1.250410] VE: install end!!!
      [    1.250410]
      [    1.255457] VE: sunxi_cedar_probe
      [    1.260173] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    1.270510] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    1.280594] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.286778] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.293187] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.299594] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.306032] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.312599] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.319103] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.325677] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.332240] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.341805] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.352957] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    1.373154] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.397401] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    1.405082] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
      [    1.412215] ashmem: initialized
      [    1.415741] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
      [    1.422620] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.434591] exFAT: Version 1.3.0
      [    1.443037] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.454731] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    1.454731]
      [    1.472032] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    1.483505] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    1.491683] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
      [    1.499335] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
      [    1.506756] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    1.516485] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
      [    1.523390] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    1.530012] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
      [    1.536801] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.550507] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    1.561940] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    1.574246] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    1.583699] NET: Registered protocol family 10
      [    1.590012] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    1.597568] Segment Routing with IPv6
      [    1.601987] NET: Registered protocol family 17
      [    1.608786] HDMI 2.0 driver init start!
      [    1.613210] boot_hdmi=false
      [    1.616379] ERROR: can not get hdmi_cts_compatibility
      [    1.622072] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    1.627539] ERROR: can not get ddc_en_io_ctrl
      [    1.632453] ERROR: can not get hdmi_power_cnt
      [    1.638751] HDMI2.0 module init end
      [    1.669910] UBI error: cannot open mtd sys, error -2
      [    1.675558] UBI: block: can't open volume on ubi0_-1, err=-19
      [    1.683395] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    1.693150] clk: Not disabling unused clocks
      [    1.697919] ALSA device list:
      [    1.701304] cfg80211: failed to load regulatory.db
      [    1.706688]   #0: audiocodec
      [    1.710043] alloc_fd: slot 0 not NULL!
      [    1.718663] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
      [    1.731227] devtmpfs: mounted
      [    1.734722] Freeing unused kernel memory: 136K
      [    1.739673] This architecture does not have kernel memory protection.
      [    1.746982] Run /pseudo_init as init process
      [    1.764008] random: fast init done
      [    3.071008] MTD: Couldn't look up '/dev/by-name/rootfs_data': -2
      mount: mounting /dev/by-name/rootfs_data on /overlay failed: No such file or directory
      Mount Failed: formating /dev/by-name/rootfs_data to jffs2 ...
      mkfs.jffs2: error!: Unrecognisable erase size
      [    3.610097] jffs2: notice: (99) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
      [    3.707454] random: crng init done
      [    5.239976] hdmi_hpd_sys_config_release
      [   20.156128] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [   20.267209] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
      [   20.273730] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.294444] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [   20.314953] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.340686] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.356451] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [   20.370895] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [   20.390608] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   20.403338] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [   20.416776] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [   20.431008] mmc0: new high speed SDIO card at address 0001
      [   31.849997] pio-18: disabling
      [   31.853340] pio-33: disabling
      [   31.856647] usb1-vbus: disabling
      ------run rc.final file-----
      ------run profile file-----
      nodev   debugfs
      root@TinaLinux:/# [   34.165790] file system registered
      [   34.207543] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [   34.268250] read descriptors
      [   34.272099] read strings
      [   34.437927] sunxi_set_cur_vol_work()485 WARN: get power supply failed
      [   34.509331] configfs-gadget gadget: high-speed config #1: c
      root@TinaLinux:/#
      lcd初始化部分,设备树设置的320*240,不知道这里fb的800哪里来的
      然后查看disp的sys信息
      root@TinaLinux:/# cat /sys/class/disp/disp/attr/sys
      screen 0:
      de_rate 300000000 hz, ref_fps:-1
      mgr0: 0x0 fmt[rgb] cs[0x204] range[full] eotf[0x4] bits[8bits] err[1] force_sync[0] unblank direct_show[false] iommu[1]
      dmabuf: cache[0] cache max[0] umap skip[0] umap skip max[32]
              lcd output      backlight(  0)  fps:60.2           0x   0
              err:12387       skip:86 irq:12389       vsync:0 vsync_skip:0
         BUF    enable ch[1] lyr[0] z[16] prem[N] a[pixel 255] fmt[  0] fb[ 320, 240; 320, 240; 320, 240] crop[   0,   0, 320, 240] frame[   0,   0, 800, 480] addr[fff80000,       0,       0] flags[0x       0] trd[0,0]
      depth[ 0] root@TinaLinux:/#
      root@TinaLinux:/#
      可以看到mgr0是0x0,后面frame又是800x480,有问题,但不知出在哪儿……前面rgb屏frame也是这样,不过我用测试代码修改了fb_var_screeninfo才行
      切换到dispdbg,用suspend命令
      root@TinaLinux:/# cd /sys/kernel/debug/dispdbg/
      root@TinaLinux:/sys/kernel/debug/dispdbg# echo disp0 > name
      root@TinaLinux:/sys/kernel/debug/dispdbg# echo suspend >command
      root@TinaLinux:/sys/kernel/debug/dispdbg# echo 1 >start
      [ 1170.840215] disp_suspend
      [ 1170.843048] [DISP] disp_lcd_disable,line:2369:
      [ 1170.843053] lcd_panel_fun[0](--).cfg_close_flow is NULL
      [ 1170.870085] disp_suspend finish
      lcd_panel_fun0.cfg_close_flow is NULL这个搞的有点蒙,在lcdpanel里,这里cfg_close_flow是有的,不知道这里为啥是个NULL,另外lcd_panel_fun0这里括号,是我在源码
      lichee/linux-5.4/drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c----->disp_lcd_disable中改的
      DE_WRN("lcd_panel_fun[%d](%s--%s).cfg_close_flow is NULL\n", lcd->disp,lcdp->panel_info.lcd_model_name,lcdp->panel_info.lcd_driver_name);
      但似乎,都是空值,所以是不是驱动挂的不是指定的panel呢?
      下面是我添加驱动到配置的具体步骤,新手操作,粗鄙难入眼之处,请多担待……
      再说步骤
      根据手头的Tina的开发文档,及自己的理解,我分为以下几个步骤:
      1. 在lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/路径添加ili9341_80.c和ili9341_80.h
        如下,c文件
       * drivers/video/fbdev/sunxi/disp2/disp/lcd/ili9341/ili9341.c
       * Copyright (c) 2007-2018 Allwinnertech Co., Ltd.
       * Author: zhengxiaobin <zhengxiaobin@allwinnertech.com>
       * This software is licensed under the terms of the GNU General Public
       * License version 2, as published by the Free Software Foundation, and
       * may be copied, distributed, and modified under those terms.
       * This program is distributed in the hope that it will be useful,
       * but WITHOUT ANY WARRANTY; without even the implied warranty of
       * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
       * GNU General Public License for more details.
      [lcd0]
      lcd_used            = 1
      lcd_driver_name     = "ili9341"
      lcd_x               = 240
      lcd_y               = 320
      lcd_width           = 108
      lcd_height          = 64
      lcd_dclk_freq       = 60
      lcd_pwm_used        = 0
      lcd_pwm_ch          = 0
      lcd_pwm_freq        = 50000
      lcd_pwm_pol         = 1
      lcd_pwm_max_limit   = 255
      lcd_hbp             = 20
      ;10 + 20 + 10 + 240*3 = 760  real set 1000
      lcd_ht              = 1000
      lcd_hspw            = 10
      lcd_vbp             = 5
      lcd_vt              = 340
      lcd_vspw            = 2
      lcd_frm             = 0
      lcd_if              = 0
      lcd_hv_if	= 8
      lcd_hv_clk_phase    = 0
      lcd_hv_sync_polarity   = 0
      lcd_hv_srgb_seq		= 0
      lcd_io_phase        = 0x0000
      lcd_gamma_en        = 0
      lcd_bright_curve_en = 1
      lcd_cmap_en         = 0
      lcd_rb_swap	= 0
      deu_mode            = 0
      lcdgamma4iep        = 22
      smart_color         = 90
      ;reset
      lcd_gpio_0			= port:PD16<1><0><default><1>
      lcdd2                = port:PD00<2><0><2><default>
      lcdd3				 = port:PD01<2><0><2><default>
      lcdd4                = port:PD02<2><0><2><default>
      lcdd5                = port:PD03<2><0><2><default>
      lcdd6                = port:PD04<2><0><2><default>
      lcdd7                = port:PD05<2><0><2><default>
      lcdd10               = port:PD06<2><0><2><default>
      lcdd11               = port:PD07<2><0><2><default>
      lcdd12               = port:PD08<2><0><2><default>
      lcdd13               = port:PD09<2><0><2><default>
      lcdd14               = port:PD10<2><0><2><default>
      lcdd15               = port:PD11<2><0><2><default>
      lcdd18               = port:PD12<2><0><2><default>
      lcdd19               = port:PD13<2><0><2><default>
      lcdd20               = port:PD14<2><0><2><default>
      lcdd21               = port:PD15<2><0><2><default>
      lcdclk              = port:PD18<7><0><3><default>
      lcdde               = port:PD19<7><0><3><default>
      lcdhsync            = port:PD20<7><0><3><default>
      lcdvsync            = port:PD21<7><0><3><default>
      #include "ili9341_80.h"
      #define CPU_TRI_MODE
      #define ili9341c_spi_reset_1 sunxi_lcd_gpio_set_value(0, 0, 1)
      #define ili9341c_spi_reset_0 sunxi_lcd_gpio_set_value(0, 0, 0)
      static void lcd_panel_ili9341_init(struct disp_panel_para *info);
      extern s32 tcon0_cpu_set_tri_mode(u32 sel);
      void write_tcon_register(int offset, int value)
      	volatile int *tcon_reg = (int *)(0xf1c0c000 + offset);
      	int reg = 0;
      	reg = *((volatile int *)tcon_reg);
      	reg |= value;
      	*((volatile int *)tcon_reg) = reg;
      static void lcd_cfg_panel_info(struct panel_extend_para *info)
      	u32 i = 0, j = 0;
      	u32 items;
      	u8 lcd_gamma_tbl[][2] = {
      	    //{input value, corrected value}
      	    {0, 0},     {15, 15},   {30, 30},   {45, 45},   {60, 60},
      	    {75, 75},   {90, 90},   {105, 105}, {120, 120}, {135, 135},
      	    {150, 150}, {165, 165}, {180, 180}, {195, 195}, {210, 210},
      	    {225, 225}, {240, 240}, {255, 255},
      	u32 lcd_cmap_tbl[2][3][4] = {
      		for (j = 0; j < num; j++) {
      			u32 value = 0;
      			value =
      			    lcd_gamma_tbl[i][1] +
      			    ((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1]) *
      			     j) /
      				num;
      			    (value << 16) + (value << 8) + value;
      	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
      				   (lcd_gamma_tbl[items - 1][1] << 8) +
      				   lcd_gamma_tbl[items - 1][1];
      static s32 lcd_open_flow(u32 sel)
      	LCD_OPEN_FUNC(sel, LCD_power_on, 40);
      #ifdef CPU_TRI_MODE
      	LCD_OPEN_FUNC(sel, LCD_panel_init, 50);
      	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
      #else
      static s32 lcd_close_flow(u32 sel)
      	LCD_CLOSE_FUNC(sel, LCD_bl_close, 50);
      #ifdef CPU_TRI_MODE
      	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 10);
      	LCD_CLOSE_FUNC(sel, LCD_panel_exit, 10);
      #else
      	LCD_CLOSE_FUNC(sel, LCD_power_off, 10);
      	sunxi_lcd_power_enable(sel, 0);
      	sunxi_lcd_pin_cfg(sel, 1);
      	sunxi_lcd_pin_cfg(sel, 0);
      	sunxi_lcd_power_disable(sel, 0);
      	sunxi_lcd_pwm_enable(sel);
      	/*config lcd_bl_en pin to open lcd backlight*/
      	sunxi_lcd_backlight_enable(sel);
      	/*config lcd_bl_en pin to close lcd backlight*/
      	sunxi_lcd_pwm_disable(sel);
      static void LCD_WRITE_DATA(u32 value)
          sunxi_lcd_cpu_write_data(0,value&0xFFFF);
      static void LCD_WRITE_COMMAND(u32 value)
          sunxi_lcd_cpu_write_index(0,value&0xFFFF);
      	struct disp_panel_para *info =
      	    kmalloc(sizeof(struct disp_panel_para), GFP_KERNEL | __GFP_ZERO);
      	bsp_disp_get_panel_info(sel, info);
      	lcd_panel_ili9341_init(info);
      	kfree(info);
      	return;
      	LCD_WRITE_COMMAND(0x28);
      	LCD_WRITE_COMMAND(0x10);
      	sunxi_lcd_delay_ms(300);
      	kfree(info);
      	return;
      	//************* Start Initial Sequence **********//
      	//************* Reset LCD Driver ****************//
      	ili9341c_spi_reset_1;
      	sunxi_lcd_delay_ms(1);
      	ili9341c_spi_reset_0;
      	/*Delay 10ms  This delay time is necessary*/
      	sunxi_lcd_delay_ms(10);
      	/*Delay 120 ms*/
      	sunxi_lcd_delay_ms(120);
      	/************** Start Initial Sequence ***********/
      	/*Pixel Format Set*/
      	LCD_WRITE_COMMAND(0x3A);
      	LCD_WRITE_DATA(0x55);
      	LCD_WRITE_COMMAND(0xF6);
      	LCD_WRITE_DATA(0x01);
      	LCD_WRITE_DATA(0x33);
      	LCD_WRITE_COMMAND(0xB5);
      	LCD_WRITE_DATA(0x04);
      	LCD_WRITE_DATA(0x0A);
      	LCD_WRITE_DATA(0x14);
      	LCD_WRITE_COMMAND(0x35);
      	LCD_WRITE_DATA(0x00);
      	LCD_WRITE_COMMAND(0xCF);
      	LCD_WRITE_DATA(0xEA);
      	LCD_WRITE_DATA(0xF0);
      	LCD_WRITE_COMMAND(0xED);
      	LCD_WRITE_DATA(0x64);
      	LCD_WRITE_DATA(0x03);
      	LCD_WRITE_DATA(0x12);
      	LCD_WRITE_DATA(0x81);
      	LCD_WRITE_COMMAND(0xE8);
      	LCD_WRITE_DATA(0x85);
      	LCD_WRITE_DATA(0x78);
      	LCD_WRITE_COMMAND(0xCB);
      	LCD_WRITE_DATA(0x39);
      	LCD_WRITE_DATA(0x2C);
      	LCD_WRITE_DATA(0x06);
      	LCD_WRITE_COMMAND(0xF7);
      	LCD_WRITE_DATA(0x20);
      	LCD_WRITE_COMMAND(0xEA);
      	/*VRH[5:0]*/
      	LCD_WRITE_COMMAND(0xC0);
      	LCD_WRITE_DATA(0x21);
      	LCD_WRITE_COMMAND(0xC1);
      	LCD_WRITE_DATA(0x10);
      	LCD_WRITE_COMMAND(0xC5);
      	LCD_WRITE_DATA(0x31);
      	LCD_WRITE_DATA(0x3C);
      	LCD_WRITE_COMMAND(0x36);
      	LCD_WRITE_DATA(0x08);
      	LCD_WRITE_COMMAND(0xB0);
      	/*E0,E9D340*/
      	LCD_WRITE_DATA(0xE9);
      	LCD_WRITE_COMMAND(0xB1);
      	LCD_WRITE_DATA(0x13);
      	LCD_WRITE_COMMAND(0xB6);
      	LCD_WRITE_DATA(0xA2);
      	LCD_WRITE_COMMAND(0xF2);
      	LCD_WRITE_DATA(0x02);
      	LCD_WRITE_DATA(0x30);
      	LCD_WRITE_DATA(0x07);
      	LCD_WRITE_COMMAND(0x26);
      	LCD_WRITE_COMMAND(0xE0);
      	LCD_WRITE_DATA(0x0F);
      	LCD_WRITE_DATA(0x24);
      	LCD_WRITE_DATA(0x51);
      	LCD_WRITE_DATA(0x50);
      	LCD_WRITE_DATA(0x45);
      	LCD_WRITE_DATA(0x0a);
      	LCD_WRITE_DATA(0x15);
      	LCD_WRITE_DATA(0x40);
      	LCD_WRITE_COMMAND(0xE1);
      	LCD_WRITE_DATA(0x22);
      	LCD_WRITE_DATA(0x38);
      	LCD_WRITE_DATA(0x32);
      	LCD_WRITE_DATA(0x2c);
      	LCD_WRITE_DATA(0x34);
      	LCD_WRITE_COMMAND(0x11);
      	LCD_WRITE_COMMAND(0x29);
      	/*Display on*/
      	LCD_WRITE_COMMAND(0x2C);
      void lcd_reflush(void)
      	/************** Reset LCD Driver *****************/
      	/*Delay 120 ms*/
      	/*VRH[5:0]*/
      	LCD_WRITE_DATA(0x4F);
      	/*Display on*/
      static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      struct __lcd_panel ili9341_80_panel = {
          /* panel driver name, must mach the name of lcd_drv_name in sys_config.fex
      	.name = "ili9341_80",
      	.func = {
      		.cfg_panel_info = lcd_cfg_panel_info,
      		.cfg_open_flow = lcd_open_flow,
      		.cfg_close_flow = lcd_close_flow,
      		.lcd_user_defined_func = lcd_user_defined_func,
      H文件
      #ifndef __ILI9341_80_PANEL_H__
      #define  __ILI9341_80_PANEL_H__
      #include "panels.h"
      extern struct __lcd_panel ili9341_80_panel;
      2.在kconfig添加驱动项
      文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/Kconfig,增加
      config LCD_SUPPORT_ILI9341_80_PANEL
      	bool "LCD support ili9341 i80 panel"
      	default y
      	---help---
      		If you want to support led panel for display driver, select it.This panel used for ili9341 i80 mode.
      1. makfile添加编译
        文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/Makefile,在屏幕编译部分添加
      disp-$(CONFIG_LCD_SUPPORT_HE0801A068) += lcd/he0801a068.o
      disp-$(CONFIG_LCD_SUPPORT_K101_MM2QA01_A) += lcd/K101_MM2QA01_A.o
      disp-$(CONFIG_LCD_SUPPORT_ILI9341_80_PANEL) += lcd/ili9341_80.o
      1. 将上面的panel添加到panels
        文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/panels.h
        在后面最后一行#endif前添加
      #ifdef CONFIG_LCD_SUPPORT_ILI9341_80_PANEL
      extern __lcd_panel_t ili9341_80_panel;
      文件lichee/brandy-2.0/u-boot-2018/drivers/video/sunxi/disp2/disp/lcd/panels.c
      panel_array结构体最后的null前面添加
      	&ili9341_80_panel,
      1. 修改设备树
        在lichee/linux-5.4/arch/riscv/boot/dts/sunxi/sun20iw1p1.dtsi添加I80的引脚分配
      pio: pinctrl@2000000 {
      	I8080_16bit_pins_a: I8080_16bit@0 {
      		pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
      			"PD6", "PD7" ,"PD8","PD9","PD10", "PD11","PD12","PD13","PD14","PD15", \
      		function = "lcd0";
      		drive-strength = <30>;
      		bias-disable;
      	I8080_16bit_pins_b: I8080_16bit@1 {
      		function = "io_disabled";
      		bias-disable;
      在device/config/chips/f133/configs/mq_r/linux-5.4/board.dts
      添加lcd0的配置,将其他lcd0屏蔽
      根据Tina_lcd的文档,lcd_cpu_if取值
      0: 18bit/1cycle (RGB666)
      2: 16bit/3cycle (RGB666)
      4: 16bit/2cycle (RGB666)
      6: 16bit/2cycle (RGB666)
      8: 16bit/1cycle (RGB565)
      10: 9bit/1cycle (RGB666)
      12: 8bit/3cycle (RGB666)
      14: 8bit/2cycle (RGB565)
      ;8080 320240/
      &lcd0 {
      lcd_used = <1>;
      lcd_driver_name = "ili9341_80";
      lcd_backlight = <80>;
      lcd_if = <1>;
      lcd_cpu_if = <8>;
      lcd_x = <320>;
      lcd_y = <240>;
      lcd_width = <108>;
      lcd_height = <64>;
      lcd_dclk_freq = <16>;
      lcd_hbp = <20>;
      lcd_ht = <360>;
      lcd_hspw = <10>;
      lcd_vbp = <8>;
      lcd_vt = <256>;
      lcd_vspw = <4>;
      lcd_pwm_used        = <1>;
      lcd_pwm_ch          = <7>;
      lcd_pwm_freq        = <500>;
      lcd_pwm_pol         = <0>;
      lcd_lvds_if         = <0>;
      lcd_lvds_colordepth = <1>;
      lcd_lvds_mode       = <0>;
      lcd_frm             = <0>;
      lcd_gamma_en        = <0>;
      lcd_bright_curve_en = <0>;
      lcd_cmap_en         = <0>;
      deu_mode            = <0>;
      lcdgamma4iep        = <22>;
      smart_color         = <90>;
      pinctrl-0 = <&I8080_16bit_pins_a>;
      pinctrl-1 = <&I8080_16bit_pins_b>;
      lcd_gpio_0 = <&pio PD 16 GPIO_ACTIVE_HIGH>;
      status              = "okay";
      在device/config/chips/f133/configs/mq_r/uboot-board.dts同样修改
      ;8080 320*240*/
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_if              = <1>;
      	lcd_cpu_if			= <8>;
          lcd_x = <320>;
          lcd_y = <240>;
          lcd_width = <108>;
          lcd_height = <64>;
          lcd_hbp = <20>;
          lcd_ht = <360>;
          lcd_hspw = <10>;
          lcd_vbp = <8>;
          lcd_vt = <256>;
          lcd_vspw = <4>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_pol         = <0>;
      	lcd_lvds_if         = <0>;
      	lcd_frm             = <0>;
      	lcd_gamma_en        = <0>;
      	lcd_cmap_en         = <0>;
      	deu_mode            = <0>;
      	smart_color         = <90>;
      	status              = "okay";
      board.dts和uboot_board.dts中disp部分如下:
      &disp {
      	fb0_width                = <320>;
      	fb0_height               = <240>;
      	fb0_width                = <320>;
      	fb0_height               = <240>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      1. 在lichee/brandy-2.0/u-boot-2018/configs/sun20iw1p1_defconfig屏幕部分添加
        CONFIG_LCD_SUPPORT_ILI9341_80_PANEL=y
      2. 编译打包烧录
      这是整个操作步骤,最后结果就是开头部分,是哪里没有改到还是弄错了的
